Part Number: TDA4VM
Hi, Experts,
Just like the post“ e2e.ti.com/.../tda4vm-gpu-render-a-scene-with-confusion-occasionally "Mentioned,
error still occured on SDK 8.4 GPU driver after fixed with 0001-HACK-server-Make-CCB-allocations-incoherent.patch, and log information is as follows:
\uFEFF[ OK ] Started udev Wait for Complete Device Initialization.
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily rotation of log files.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on dropbear.socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started Periodic Command Scheduler.
[ OK ] Started irqbalance daemon.
Starting Launch service...
Starting Permit User Sessions...
[ OK ] Started Permit User Sessions.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Reached target Login Prompts.
[ 6.672737] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
e2fsck 1.45.7 (28-Jan-2021)
/dev/mmcblk0p8: recovering journal
/dev/mmcblk0p8: clean, 15/2048 files, 2665/8192 blocks
[ 7.140262] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
/dev/mmcblk0p9: recovering journal
/dev/mmcblk0p9: clean, 24/2048 files, 1677/8192 blocks
[ 7.211567] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: (null)
[ 7.258915] EXT4-fs (mmcblk0p10): recovery complete
[ 7.263968] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null)
[ 7.341322] EXT4-fs (mmcblk0p11): recovery complete
[ 7.346739] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: (null)
[ 7.402874] EXT4-fs (mmcblk0p12): recovery complete
[ 7.407841] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: (null)
[ 7.469879] EXT4-fs (mmcblk0p14): recovery complete
[ 7.475362] EXT4-fs (mmcblk0p14): mounted filesystem with ordered data mode. Opts: (null)
tcpsvd: listening on 0.0.0.0:21, starting
root
<---- Launcher exit ---->
[ OK ] Started Launch service.
[ OK ] Reached target Multi-User System.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started Update UTMP about System Ru
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project j7-evm ttyS2
Arago 2021.09 j7-evm ttyS2
j7-evm login:
j7-evm login: root
root@j7-evm:/data/cache# PVR_SRVKM_PARAMS="EnablePageFaultDebug=1" /home/root/rc.pvr start
[ 16.481050] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power domains
[ 16.492456] PVR_K: 1108: Read BVNC 22.104.208.318 from HW device registers
[ 16.500232] PVR_K: 1108: RGX Device registered with BVNC 22.104.208.318
[ 16.507590] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
/home/root/rc.pvr: line 83: readlink: command not found
which: no openvt in (/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/sbin)
Couldn't start Weston automatically.
Loaded PowerVR consumer services.
root@j7-evm:/data/cache# pvrdebug -loggroups main,mts,cleanup,csw,bif,pm,rtd,spm,pow,hwr
----------------------- Start -----------------------
Set FW Log type to TRACE ( main mts cleanup csw bif pm rtd spm pow hwr )
Connecting to first (0) default pvr device
[ 18.804185] PVR_K: 1143: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
[ 18.830260] PVR_K: 1143: Shader binary image 'rgx.sh.22.104.208.318' loaded
------------------------ End ------------------------
root@j7-evm:/data/cache# echo "Y" >/sys/kernel/debug/pvr/apphint/0/AssertOnHWRTrigger
root@j7-evm:/data/cache# [ 31.803159] tlv71033: disabling
./camera_kit &
[1] 1250
root@j7-evm:/data/cache# APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=5) !!!
MEM: Init ... Done !!!
IPC: Init ... !!!
IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
37.079404 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
37.095502 s: VX_ZONE_INIT:Enabled
37.095550 s: VX_ZONE_ERROR:Enabled
37.095567 s: VX_ZONE_WARNING:Enabled
37.101904 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
37.103254 s: VX_ZONE_INIT:[tivxHostInitLocal:86] Initialization Done for HOST !!!
37.107274 s: ISS: Enumerating sensors ... !!!
37.203263 s: ISS: Enumerating sensors ... found 0 : JH_0X01F10_UYVY
37.203326 s: ISS: Initializing sensor [JH_0X01F10_UYVY], doing IM_SENSOR_CMD_PWRON ... !!!
37.203792 s: ISS: Initializing sensor [JH_0X01F10_UYVY], doing IM_SENSOR_CMD_CONFIG ... !!!
37.268249 s: ISS: Initializing sensor [JH_0X01F10_UYVY] ... Done !!!
37.270124 s: ISS: Starting sensor [JH_0X01F10_UYVY] ... !!!
37.346220 s: ISS: Starting sensor [JH_0X01F10_UYVY] ... !!!
[ 33.511496] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 33.663100] random: crng init done
[ 33.666501] random: 154 urandom warning(s) missed due to ratelimiting
[ 36.923124] PVR_K:(Error): 1112: DevicesWatchdogThread: Device status not OK!!! [500]
[ 36.935137] PVR_K: 1112: ------------[ PVR DBG: START (High) ]------------
[ 36.942147] PVR_K: 1112: OS kernel info: Linux 5.10.120-g95b90aa828 #1 SMP PREEMPT Tue Oct 11 13:45:01 CST 2022 aarch64
[ 36.953094] PVR_K: 1112: DDK info: Rogue_DDK_Linux_WS rogueddk 1.15@6133109 (release) j721e_linux
[ 36.962348] PVR_K: 1112: Time now: 36962340us
[ 36.966893] PVR_K: 1112: Services State: OK
[ 36.971322] PVR_K: 1112: Server Errors: 1
[ 36.975496] PVR_K: 1112: Connections Device ID:0(128) P1250-V1250-T1268-camera_kit
[ 36.983241] PVR_K: 1112: ------[ Driver Info ]------
[ 36.988355] PVR_K: 1112: Comparison of UM/KM components: MATCHING
[ 36.994595] PVR_K: 1112: KM Arch: 64 Bit
[ 36.998685] PVR_K: 1112: UM Connected Clients: 64 Bit
[ 37.003907] PVR_K: 1112: UM info: 1.15 @ 6133109 (release) build options: 0x80000810
[ 37.011821] PVR_K: 1112: KM info: 1.15 @ 6133109 (release) build options: 0x00000810
checksum error found!FN:0093,receive:00, pending:FA[ 37.019756] PVR_K: 1112: Window system: wayland
[ 37.028812] PVR_K: 1112: ------[ RGX Device ID:0 Start ]------
[ 37.034737] PVR_K: 1112: ------[ RGX Info ]------
[ 37.039705] PVR_K: 1112: Device Node (Info): 0000000075918497 (000000008a3e1a46)
[ 37.047182] PVR_K: 1112: RGX BVNC: 22.104.208.318 (rogue)
[ 37.052737] PVR_K: 1112: RGX Device State: Active
[ 37.057529] PVR_K: 1112: RGX Power State: ON
[ 37.061887] PVR_K: 1112: FW info: 1.15 @ 6133109 (release) build options: 0x80000810
[ 37.069800] PVR_K: 1112: BIF0 - OK
[ 37.073295] PVR_K: 1112: RGX FW State: DEAD - Asserted (HWRState 0x00000020: DM stalling;)
[ 37.081641] PVR_K: 1112: RGX FW Power State: RGXFWIF_POW_ON (APM disabled: 0 ok, 0 denied, 0 non-idle, 0 retry, 0 other, 0 total. Latency: 100 ms)
[ 37.094846] PVR_K: 1112: RGX DVFS: 0 frequency changes. Current frequency: 749.999 MHz (sampled at 36828036355 ns). FW frequency: 100.000 MHz.
[ 37.107783] PVR_K: 1112: RGX FW OS 0 - State: active; Freelists: Ok; Priority: 0; MTS on;
[ 37.116066] PVR_K: 1112: FW-T0 Assert: (gsRGXFWCtl.ui32StateFlags & RGXFW_STATE_ASSERT_ON_HWR_TRIGGER) == 0U (firmware/rogue/rgxfw_hwr.c:2993)
[ 37.128942] PVR_K: 1112: Number of HWR: GP(0/0+0), 2D(0/0+0), TA(0/0+0), 3D(0/1+0), CDM(0/0+0), RAY(0/0+0), FALSE(0,0,0,0,0,0)
[ 37.140432] PVR_K: 1112: DM 0 (GP)
[ 37.143932] PVR_K: 1112: DM 1 (HWRflags 0x00000000: working;)
[ 37.149855] PVR_K: 1112: DM 2 (HWRflags 0x00000000: working;)
[ 37.155698] PVR_K: 1112: DM 3 (HWRflags 0x00000020: guilty lockup;)
[ 37.162053] PVR_K: 1112: Recovery 1: PID = 1250, frame = 0, HWRTData = 0x00000000, EventStatus = 0x00004410, Guilty Lockup
[ 37.173401] PVR_K: 1112: CRTimer = 0x000002e12565, OSTimer = 32.886055761, CyclesElapsed = 40279552
[ 37.183748] PVR_K: 1112: DM 4 (HWRflags 0x00000000: working;)
checksum error found!FN:0098,receive:A6, pending:21[ 37.189605] PVR_K: 1112: DM 5 (HWRflags 0x00000000: working;)
[ 37.199911] PVR_K: 1112: RGX Kernel CCB WO:0xB RO:0x9
[ 37.205210] PVR_K: 1112: RGX Firmware CCB WO:0x1 RO:0x1
[ 37.210521] PVR_K: 1112: RGX Kernel CCB commands executed = 9
[ 37.216354] PVR_K: 1112: RGX SLR: Forced UFO updates requested = 0
[ 37.222616] PVR_K: 1112: RGX Errors: WGP:0, TRP:0
[ 37.227405] PVR_K: 1112: Thread0: FW IRQ count = 5
[ 37.232281] PVR_K: 1112: Last sampled IRQ count in LISR = 5
[ 37.237939] PVR_K: 1112: FW System config flags = 0x00120000 (Ctx switch options: Medium CSW profile; VDM CS INDEX mode; Assert on HWR;)
[ 37.250345] PVR_K: 1112: FW OS config flags = 0x0000000F (Ctx switch: TDM; TA; 3D; CDM;)
[ 37.258515] PVR_K: 1112: ------[ RGX registers ]------
[ 37.263740] PVR_K: 1112: RGX Register Base Address (Linear): 0x00000000152322d8
[ 37.271304] PVR_K: 1112: RGX Register Base Address (Physical): 0x4E20000000
[ 37.278360] PVR_K: 1112: CORE_ID : 0x0000000008470000
[ 37.285405] PVR_K: 1112: CORE_REVISION : 0x00D0013E
[ 37.291828] PVR_K: 1112: DESIGNER_REV_FIELD1 : 0x00000000
[ 37.298179] PVR_K: 1112: DESIGNER_REV_FIELD2 : 0x00000000
[ 37.304529] PVR_K: 1112: CHANGESET_NUMBER : 0x0000000000000000
[ 37.311572] PVR_K: 1112: CLK_CTRL : 0x0aaaaa002a1aaaaa
[ 37.318615] PVR_K: 1112: CLK_STATUS : 0x0000000000600441
[ 37.325658] PVR_K: 1112: CLK_CTRL2 : 0x0000000000000000
[ 37.332701] PVR_K: 1112: CLK_STATUS2 : 0x0000000000000000
[ 37.339815] PVR_K: 1112: EVENT_STATUS : 0x00004410
[ 37.346166] PVR_K: 1112: TIMER : 0x0000000003a44749
[ 37.353215] PVR_K: 1112: BIF_FAULT_BANK0_MMU_STATUS : 0x00000000
[ 37.359591] PVR_K: 1112: BIF_FAULT_BANK0_REQ_STATUS : 0x0000000000000000
[ 37.366637] PVR_K: 1112: BIF_FAULT_BANK1_MMU_STATUS : 0x00000000
[ 37.373031] PVR_K: 1112: BIF_FAULT_BANK1_REQ_STATUS : 0x0000000000000000
[ 37.380074] PVR_K: 1112: BIF_MMU_STATUS : 0x00000000
[ 37.386494] PVR_K: 1112: BIF_MMU_ENTRY : 0x00000000
[ 37.392891] PVR_K: 1112: BIF_MMU_ENTRY_STATUS : 0x0000000000000000
[ 37.399940] PVR_K: 1112: BIF_STATUS_MMU : 0x00000000
[ 37.406296] PVR_K: 1112: BIF_READS_EXT_STATUS : 0x00000000
[ 37.412648] PVR_K: 1112: BIF_READS_INT_STATUS : 0x00000000
[ 37.418997] PVR_K: 1112: BIFPM_STATUS_MMU : 0x00000000
[ 37.425347] PVR_K: 1112: BIFPM_READS_EXT_STATUS : 0x00000000
[ 37.431696] PVR_K: 1112: BIFPM_READS_INT_STATUS : 0x00000000
[ 37.438117] PVR_K: 1112: BIF_CAT_BASE_INDEX : 0x0000000000000100
[ 37.445195] PVR_K: 1112: BIF_CAT_BASE0 : 0x0000000000000000
[ 37.452242] PVR_K: 1112: BIF_CAT_BASE1 : 0x00000000874ae000
[ 37.459292] PVR_K: 1112: BIF_CAT_BASE2 : 0x0000000000000000
[ 37.466336] PVR_K: 1112: BIF_CAT_BASE3 : 0x0000000000000000
[ 37.473415] PVR_K: 1112: BIF_CAT_BASE4 : 0x0000000000000000
[ 37.480534] PVR_K: 1112: BIF_CAT_BASE5 : 0x0000000000000000
checksum error found!FN:00A4,receive:00, pending:DB
[ 37.487671] PVR_K: 1112: BIF_CAT_BASE6 : 0x0000000000000000
[ 37.499291] PVR_K: 1112: BIF_CAT_BASE7 : 0x0000000000000000
[ 37.506334] PVR_K: 1112: BIF_CTRL_INVAL : 0x00000000
[ 37.515199] PVR_K: 1112: BIF_CTRL : 0x000000C0
[ 37.521647] PVR_K: 1112: BIF_PM_CAT_BASE_VCE0 : 0x0000000000000000
[ 37.528827] PVR_K: 1112: BIF_PM_CAT_BASE_TE0 : 0x0000000000000000
[ 37.536040] PVR_K: 1112: BIF_PM_CAT_BASE_ALIST0 : 0x0000000000000000
[ 37.543136] PVR_K: 1112: BIF_PM_CAT_BASE_VCE1 : 0x0000000000000000
[ 37.550259] PVR_K: 1112: BIF_PM_CAT_BASE_TE1 : 0x0000000000000000
[ 37.557317] PVR_K: 1112: BIF_PM_CAT_BASE_ALIST1 : 0x0000000000000000
[ 37.564368] PVR_K: 1112: PERF_TA_PHASE : 0x00000000
[ 37.570769] PVR_K: 1112: PERF_TA_CYCLE : 0x00000000
[ 37.577140] PVR_K: 1112: PERF_3D_PHASE : 0x00000001
[ 37.583555] PVR_K: 1112: PERF_3D_CYCLE : 0xD0277EDE
[ 37.589907] PVR_K: 1112: PERF_TA_OR_3D_CYCLE : 0xD07031D6
checksum error found!FN:00A8,receive:00, pending:D0[ 37.596279] PVR_K: 1112: PERF_TA_AND_3D_CYCLE : 0x00000000
[ 37.607028] PVR_K: 1112: PERF_COMPUTE_PHASE : 0x00000000
[ 37.613550] PVR_K: 1112: PERF_COMPUTE_CYCLE : 0x00000000
[ 37.619902] PVR_K: 1112: PM_PARTIAL_RENDER_ENABLE : 0x00000000
[ 37.626325] PVR_K: 1112: ISP_RENDER : 0x00000003
[ 37.632726] PVR_K: 1112: TLA_STATUS : 0x0000000000000000
too large payload data![ 37.639782] PVR_K: 1112: MCU_FENCE : 0x0000018000000000
[ 37.648843] PVR_K: 1112: VDM_CONTEXT_STORE_STATUS : 0x00000001
[ 37.655368] PVR_K: 1112: VDM_CONTEXT_STORE_TASK0 : 0x0000000000000000
[ 37.662435] PVR_K: 1112: VDM_CONTEXT_STORE_TASK1 : 0x0000000000000000
[ 37.669488] PVR_K: 1112: VDM_CONTEXT_STORE_TASK2 : 0x0000000000000000
[ 37.676612] PVR_K: 1112: VDM_CONTEXT_RESUME_TASK0 : 0x0000000000000000
[ 37.683656] PVR_K: 1112: VDM_CONTEXT_RESUME_TASK1 : 0x0000000000000000
[ 37.690723] PVR_K: 1112: VDM_CONTEXT_RESUME_TASK2 : 0x0000000000000000
[ 37.697767] PVR_K: 1112: ISP_CTL : 0x0002B000
[ 37.704116] PVR_K: 1112: ISP_STATUS : 0x00000002
[ 37.710466] PVR_K: 1112: MTS_INTCTX : 0x00000000
[ 37.716814] PVR_K: 1112: MTS_BGCTX : 0x00000001
[ 37.723236] PVR_K: 1112: MTS_BGCTX_COUNTED_SCHEDULE : 0x00000000
[ 37.729595] PVR_K: 1112: MTS_SCHEDULE : 0x00000000
[ 37.735949] PVR_K: 1112: MTS_GPU_INT_STATUS : 0x00004410
[ 37.742299] PVR_K: 1112: CDM_CONTEXT_STORE_STATUS : 0x00000000
[ 37.748648] PVR_K: 1112: CDM_CONTEXT_PDS0 : 0x0000000000000000
[ 37.755690] PVR_K: 1112: CDM_CONTEXT_PDS1 : 0x0000000000000000
[ 37.762736] PVR_K: 1112: CDM_TERMINATE_PDS : 0x0000000000000000
[ 37.769831] PVR_K: 1112: CDM_TERMINATE_PDS1 : 0x0000000000000000
[ 37.776950] PVR_K: 1112: SIDEKICK_IDLE : 0x0000007E
[ 37.783300] PVR_K: 1112: SLC_IDLE : 0x000000FF
[ 37.789654] PVR_K: 1112: SLC_STATUS0 : 0x00000000
[ 37.796031] PVR_K: 1112: SLC_STATUS1 : 0x0000000000000000
[ 37.803076] PVR_K: 1112: SLC_STATUS2 : 0x0000000000000000
[ 37.810118] PVR_K: 1112: SLC_CTRL_BYPASS : 0x01000000
[ 37.816536] PVR_K: 1112: SLC_CTRL_MISC : 0x0000000000200003
[ 37.823650] PVR_K: 1112: MIPS_ADDR_REMAP1_CONFIG1 : 0x1FC00001
[ 37.830002] PVR_K: 1112: MIPS_ADDR_REMAP1_CONFIG2 : 0x0000000085abb00c
[ 37.837065] PVR_K: 1112: MIPS_ADDR_REMAP2_CONFIG1 : 0x1FC01001
[ 37.843418] PVR_K: 1112: MIPS_ADDR_REMAP2_CONFIG2 : 0x00000000858f500c
[ 37.850459] PVR_K: 1112: MIPS_ADDR_REMAP3_CONFIG1 : 0x1FC02001
[ 37.856813] PVR_K: 1112: MIPS_ADDR_REMAP3_CONFIG2 : 0x000000008686700c
[ 37.863855] PVR_K: 1112: MIPS_ADDR_REMAP4_CONFIG1 : 0x1FC00000
[ 37.870284] PVR_K: 1112: MIPS_ADDR_REMAP4_CONFIG2 : 0x000000000000000c
[ 37.877325] PVR_K: 1112: MIPS_ADDR_REMAP5_CONFIG1 : 0x00000001
checksum error found!FN:8000,receive:00, pending:66[ 37.883701] PVR_K: 1112: MIPS_ADDR_REMAP5_CONFIG2 : 0x0000000085abb00c
[ 37.895140] PVR_K: 1112: MIPS_WRAPPER_CONFIG : 0x000000000001cf80
[ 37.902352] PVR_K: 1112: MIPS_EXCEPTION_STATUS : 0x00000022
[ 37.908859] PVR_K: 1112: ---- [ MIPS internal state ] ----
[ 37.914509] PVR_K: 1112: PC : 0x9FC02338
[ 37.920936] PVR_K: 1112: STATUS_REGISTER : 0x00481006
[ 37.927291] PVR_K: 1112: CAUSE_REGISTER : 0x00800824
[ 37.933643] PVR_K: 1112: Cause exception: Breakpoint exception (FW assert)
[ 37.940948] PVR_K: 1112: BAD_REGISTER : 0xC0001B4C
[ 37.947393] PVR_K: 1112: EPC : 0xC00003AC
[ 37.953890] PVR_K: 1112: SP : 0xCF600EA8
[ 37.960404] PVR_K: 1112: BAD_INSTRUCTION : 0x00000000
[ 37.966873] PVR_K: 1112: TLB :
[ 37.972361] PVR_K: 1112: 0) VA 0xCF800000 ( 64k) -> PA0 0xe20000000 DV , PA1 0x00000000 C
checksum error found!FN:00B6,receive:00, pending:66[ 37.981135] PVR_K: 1112: 1) VA 0xCF000000 ( 16k) -> PA0 0x85b70000 DVGC, PA1 0x85b74000 DVGC
[ 37.994128] PVR_K: 1112: 2) VA 0xCF600000 ( 4k) -> PA0 0x858f6000 DV C, PA1 0x00000000 C
[ 38.002746] PVR_K: 1112: 3) VA 0xC0032000 ( 4k) -> PA0 0x8588a000 DVGC, PA1 0x8588b000 DVGC
[ 38.011581] PVR_K: 1112: 4) VA 0xC0036000 ( 4k) -> PA0 0x858f6000 DVGC, PA1 0x8685f000 DVG
[ 38.020240] PVR_K: 1112: 5) VA 0xC000A000 ( 4k) -> PA0 0x858d7000 DVGC, PA1 0x83bdd000 DVGC
[ 38.028869] PVR_K: 1112: 6) VA 0xC0028000 ( 4k) -> PA0 0x874b2000 DVGC, PA1 0x8752c000 DVGC
[ 38.037502] PVR_K: 1112: 7) VA 0xC001A000 ( 4k) -> PA0 0x86873000 DVG , PA1 0x86802000 DVG
[ 38.046125] PVR_K: 1112: 8) VA 0xC0072000 ( 4k) -> PA0 0x00000000 C, PA1 0x874ce000 DV C
[ 38.054730] PVR_K: 1112: 9) VA 0xC0020000 ( 4k) -> PA0 0x8687e000 DVG , PA1 0x84fab000 DVG
[ 38.063411] PVR_K: 1112: 10) VA 0xC000C000 ( 4k) -> PA0 0x84e00000 DVGC, PA1 0x85a46000 DVGC
[ 38.072027] PVR_K: 1112: 11) VA 0xC0000000 ( 4k) -> PA0 0x84d6b000 DVGC, PA1 0x84e39000 DVGC
[ 38.080638] PVR_K: 1112: 12) VA 0xC0002000 ( 4k) -> PA0 0x84c1e000 DVGC, PA1 0x84cf7000 DVGC
[ 38.089241] PVR_K: 1112: 13) VA 0xC0008000 ( 4k) -> PA0 0x858a0000 DVGC, PA1 0x86874000 DVGC
[ 38.097849] PVR_K: 1112: 14) VA 0xC001E000 ( 4k) -> PA0 0x84e95000 VGC, PA1 0x8592a000 DVG
[ 38.106530] PVR_K: 1112: 15) VA 0xC000E000 ( 4k) -> PA0 0x83a86000 DVGC, PA1 0x84c33000 DVGC
[ 38.115176] PVR_K: 1112: Overlap between TLB entry 2 and 4
[ 38.120746] PVR_K: 1112: --------------------------------
[ 38.126229] PVR_K: 1112: ------[ RGX FW Trace Info ]------
[ 38.131826] PVR_K: 1112: Debug log type: trace ( main mts cleanup csw bif pm rtd spm pow hwr )
[ 38.140521] PVR_K: 1112: ------[ RGX FW thread 0 trace START ]------
[ 38.146958] PVR_K: 1112: FWT[traceptr]: 330
[ 38.151228] PVR_K: 1112: FWT[tracebufsize]: 2EE0
[ 38.156017] PVR_K: 1112: FWT[00000000]: 7001105b 00000000 0068ed64 00000001 70027011 00000000 0068ed73 00000000 00000001 7001700d 00000000 0068ed99 00000001 70017006 00000000 0068eda5 00000000 70037003 00000000 0068edba 00000000 00000001 00000400 7005a02e 00000000 0068edfa 00000001 00000001 00000000 00000000
[ 38.183427] PVR_K: 1112: FWT[00000078]: 00000000 7003a015 00000000 0068ee0e 00000001 00000001 00000000 7000700e 00000000 0068ee23 70017012 00000000 0068ee35 00000000 7001700d 00000000 0068ee69 00000001 70017006 00000000 0068ee74 00000000 70037003 00000000 0068ee82 00000000 00000001 00000400 7005a02e 00000000
checksum error found!FN:00BC,receive:00, pending:A9[ 38.210958] PVR_K: 1112: FWT[000000f0]: 0068ee99 00000001 00000001 00000000 00000000 00000000 7000700e 00000000 0068eead 70017012 00000000 00698675 00000000 7003a002 00000000 0069869b 00000001 00000001 00000000 7001700d 00000000 006986b3 00000001 70017006 00000000 006986bc 00000000 70037003 00000000 006986c8
[ 38.242684] PVR_K: 1112: FWT[00000168]: 00000000 00000001 00000400 7005a02e 00000000 006986dd 00000001 00000003 00000000 00000000 00000000 7000700e 00000000 006986f1 70017012 00000000 00b2cfcf 00000000 70037013 00000000 00b2cfe2 00000001 2abc00d1 00000000 70027011 00000000 00b2cff6 00000001 00000001 7001700d
[ 38.270128] PVR_K: 1112: FWT[000001e0]: 00000000 00b2d00b 00000001 70017006 00000000 00b2d014 00000000 70037003 00000000 00b2d020 00000000 00000001 00000400 7005a02e 00000000 00b2d038 00000001 00000003 00000000 00000000 00000000 7000700e 00000000 00b2d050 70017012 00000000 02698675 00000000 7001700d 00000000
[ 38.297747] PVR_K: 1112: FWT[00000258]: 02698698 00000001 70017006 00000000 026986a2 00000000 70037003 00000000 026986ae 00000000 00000001 00000400 7005a02e 00000000 026986c4 00000001 00000003 00000000 00000000 00000000 7000700e 00000000 026986d8 70017012 00000000 02deb8b2 00000000 70037013 00000000 02deb8c0
checksum error found!FN:00C1,receive:00, pending:0F
[ 38.325230] PVR_K: 1112: FWT[000002d0]: 00000002 2abc0066 00000000 70037013 00000000 02deb8fd 00000003 2abc0065 00000000 7003100e 00000000 02deb90f 00000100 00000003 c0028300 70017006 00000000 02deb938 00000000 70037003 00000000 02deb94f 00000000 00000001 00000400 7003700a 00000000 02deb97d 00000000 00000003
[ 38.357167] PVR_K: 1112: FWT[00000348]: c0028320 70037009 00000000 02deb98a 00000003 c0073000 c0073000 70011045 00000000 02deb9c7 00000001 7003a012 00000000 02deb9dc 00000002 00000003 00000000 7003800e 00000000 02deb9f5 c0028000 00000003 00000000 7006800f 00000000 02deb9ff ffffffff 00000003 00000000 874ae000
[ 38.384577] PVR_K: 1112: FWT[000003c0]: ffffffff ffffffff 70018003 00000000 02deba0b 00000001 70028004 00000000 02deba24 00000001 00000001 700310c6 00000000 02deba3a 00000002 000003ff 0002b000 70021087 00000000 02deba43 00000000 0000000a 70021087 00000000 02deba4a 00000001 0000000a 70081079 00000000 02deba5b
[ 38.412031] PVR_K: 1112: FWT[00000438]: c0028300 00000000 00000000 000004e2 00000001 00000000 00000001 00000001 7005a02e 00000000 02debada 00000002 00000001 00000000 00000000 00000000 7000700e 00000000 02debbe2 7001700d 00000000 02debc56 00000001 70017006 00000000 02debc7b 00000000 70037003 00000000 02debc9d
[ 38.439405] PVR_K: 1112: FWT[000004b0]: 00000000 00000001 00000400 70001004 00000000 02debcc9 70021016 00000000 02debceb c0028300 000000c8 70021017 00000000 02debcf8 c002a000 00000001 70021017 00000000 02debd00 c002b000 00000519 70018002 00000000 02debd1c c0028000 70028005 00000000 02debd2e 00000001 00000000
[ 38.466865] PVR_K: 1112: FWT[00000528]: 7005a02e 00000000 02debd48 00000002 00000001 00000000 00000000 00000001 7000a00d 00000000 02debd54 7000700e 00000000 02debd6f 70037003 00000000 02debd84 00000003 00000000 00004410 7005a02e 00000000 02debd9d 00000006 00000001 00000000 00000000 00000002 7002a00f 00000000
[ 38.494284] PVR_K: 1112: FWT[000005a0]: 02debda8 00000000 00000000 7000700e 00000000 02debdb6 70017012 00000000 02debdc8 00000000 70037013 00000000 02debdea 00000004 2abc0065 00000000 7003100e 00000000 02debdfa 000001f8 00000003 c0028300 70017006 00000000 02debe17 00000000 70037003 00000000 02debe28 00000000
checksum error found!FN:00C5,receive:00, pending:E8[ 38.521662] PVR_K: 1112: FWT[00000618]: 00000001 00004410 7003700a 00000000 02debe4f 00000000 00000003 c0028320 70037009 00000000 02debe5e 00000003 c0073000 c0073100 7003800e 00000000 02debe6e c0028000 00000003 00000000 7006800f 00000000 02debe7b 00000001 00000003 00000000 874ae000 00000000 874ae000 70028004
[ 38.553449] PVR_K: 1112: FWT[00000690]: 00000000 02debe8b 00000001 00000001 700310c6 00000000 02debe9d 00000002 000003ff 0002b000 70021087 00000000 02debea5 00000000 0000000a 70021087 00000000 02debeac 00000001 0000000a 70081079 00000000 02debebb c0028300 00000100 00000000 000004e2 00000001 00000000 00000002
[ 38.586452] PVR_K: 1112: FWT[00000708]: 00000002 7005a02e 00000000 02debeee 00000006 00000001 00000000 00000000 00000002 7002a00f 00000000 02debefa 00000000 00000001 7003a012 00000000 02debf0a 00000002 00000001 00000000 7000700e 00000000 02debf2b 70037013 00000000 02debf45 00000005 2abc0065 00000000 7003100e
[ 38.613907] PVR_K: 1112: FWT[00000780]: 00000000 02debf54 000002f0 00000003 c0028300 70037013 00000000 02debf74 00000006 2abc0065 00000000 7003100e 00000000 02debf7c 000003e8 00000003 c0028300 70037013 00000000 02debf8b 00000007 2abc0065 00000000 7003100e 00000000 02debf93 000004e0 00000003 c0028300 70037013
checksum error found!FN:00CB,receive:00, pending:E1[ 38.642510] PVR_K: 1112: FWT[000007f8]: 00000000 02debfa3 00000008 2abc0065 00000000 7003100e 00000000 02debfab 000005e0 00000003 c0028300 7001700d 00000000 02debfc2 00000001 70017006 00000000 02debfcd 00000000 70037003 00000000 02debfdc 00000000 00000001 00004410 7005a02e 00000000 02debff8 00000002 00000001
[ 38.674092] PVR_K: 1112: FWT[00000870]: 00000000 00000002 00000002 7000700e 00000000 02dec00b 70017012 00000000 02dec01c 00000000 7001700d 00000000 02dec056 00000000 70017012 00000000 02dec063 00000000 7001700d 00000000 02dec06a 00000000 70017012 00000000 02df3a47 00000000 7003b049 00000000 02df3a62 00000003
checksum error found!FN:00D0,receive:00, pending:93[ 38.701672] PVR_K: 1112: FWT[000008e8]: 00007b98 00ee0980 7003b054 00000000 02df3a76 00000000 00000003 00000000 7003b030 00000000 02df3a7f 00000003 00000000 00000003 7001700d 00000000 02df3a9c 00000000 70017012 00000000 02df3aab 00000000 7001700d 00000000 02df3ac5 00000000 70017012 00000000 02dfb49c 00000000
[ 38.733957] PVR_K: 1112: FWT[00000960]: 7003b049 00000000 02dfb4b3 00000003 0000f5e9 00ee0980 7003b054 00000000 02dfb4ce 00000000 00000003 00000001 7004b056 00000000 02dfb501 00000000 00000003 00000001 00000000 7003b060 00000000 02dfb520 00000000 00000003 00000000 7003b030 00000000 02dfb529 00000003 00000000
[ 38.761381] PVR_K: 1112: FWT[000009d8]: 00000002 7001700d 00000000 02dfb54a 00000000 70017012 00000000 02dfb559 00000000 7001700d 00000000 02dfb573 00000000 70017012 00000000 02e02f47 00000000 7003b049 00000000 02e02f5e 00000003 00017093 00ee0980 7003b055 00000000 02e02f71 00000000 00000003 00000001 7004b056
[ 38.788811] PVR_K: 1112: FWT[00000a50]: 00000000 02e02fa1 00000000 00000003 00000001 00000000 7003b060 00000000 02e02fb6 00000000 00000003 00000001 7003b030 00000000 02e02fbf 00000003 00000001 00000002 7001700d 00000000 02e02fdf 00000000 70017012 00000000 02e02fef 00000000 7001700d 00000000 02e03008 00000000
[ 38.816254] PVR_K: 1112: FWT[00000ac8]: 70017012 00000000 02e0a9de 00000000 7003b049 00000000 02e0a9f5 00000003 0001eb2a 00ee0980 7003b055 00000000 02e0aa06 00000000 00000003 00000001 7004b056 00000000 02e0aa35 00000000 00000003 00000001 00000000 7003b060 00000000 02e0aa49 00000000 00000003 00000001 7003b030
[ 38.843939] PVR_K: 1112: FWT[00000b40]: 00000000 02e0aa51 00000003 00000001 00000001 7001700d 00000000 02e0aa73 00000000 70017012 00000000 02e0aa82 00000000 7001700d 00000000 02e0aa9b 00000000 70017012 00000000 02e1246e 00000000 7003b049 00000000 02e12485 00000003 000265ba 00ee0980 7003b055 00000000 02e12496
[ 38.871321] PVR_K: 1112: FWT[00000bb8]: 00000000 00000003 00000001 7004b056 00000000 02e124c6 00000000 00000003 00000001 00000000 7003b060 00000000 02e124d7 00000000 00000003 00000001 7003b030 00000000 02e124df 00000003 00000001 00000000 7001b023 00000000 02e124e8 00000003 7002b028 00000000 02e124f3 00000003
[ 38.898679] PVR_K: 1112: FWT[00000c30]: 00000001 7002b04e 00000000 02e124fc 00000000 00004410 7002b03a 00000000 02e12526 00000000 00000002 7002b03a 00000000 02e1252b 00000000 00000003 7002b03a 00000000 02e12531 00000000 00000004 7001b03b 00000000 02e12535 00000080 7001b04d 00000000 02e1253d 00000003 700010c7
[ 38.926038] PVR_K: 1112: FWT[00000ca8]: 00000000 02e12542 70011018 00000000 02e125c0 00000bb1 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 38.953383] PVR_K: 1112: FWT[00000d20]: 00000000 ... 00000000
[ 38.963748] PVR_K: 1112: FWT[END]: 372 lines were all zero
[ 38.969349] PVR_K: 1112: ------[ RGX FW thread 0 trace END ]------
[ 38.975631] PVR_K: 1112: ------[ Full CCB Status ]------
[ 38.981032] PVR_K: 1112: FWCtx 0xC0028300 (TQ_3D-P1250-T1268-camera_kit)
[ 38.987815] PVR_K: 1112: |--Ready TQ_3D @ 256 Int=2 Ext=2
[ 38.993677] PVR_K: 1112: |--Ready UPDATE @ 456 Int=2 Ext=2
[ 38.999630] PVR_K: 1112: | `--Addr:0xc002a000 Val=0x00000002
[ 39.005763] PVR_K: 1112: |--Ready TQ_3D @ 504 Int=3 Ext=3
[ 39.011435] PVR_K: 1112: |--Ready UPDATE @ 704 Int=3 Ext=3
[ 39.017177] PVR_K: 1112: | `--Addr:0xc002a000 Val=0x00000003
[ 39.023271] PVR_K: 1112: |--Ready TQ_3D @ 752 Int=4 Ext=4
[ 39.028927] PVR_K: 1112: |--Ready UPDATE @ 952 Int=4 Ext=4
[ 39.034667] PVR_K: 1112: | `--Addr:0xc002a000 Val=0x00000004
[ 39.040755] PVR_K: 1112: |--Ready TQ_3D @ 1000 Int=5 Ext=5
[ 39.046498] PVR_K: 1112: |--Ready UPDATE @ 1200 Int=5 Ext=5
[ 39.052325] PVR_K: 1112: | `--Addr:0xc002a000 Val=0x00000005
[ 39.058415] PVR_K: 1112: |--Ready TQ_3D @ 1248 Int=6 Ext=6
[ 39.064158] PVR_K: 1112: `--Ready UPDATE @ 1448 Int=6 Ext=6
[ 39.069999] PVR_K: 1112: |--Addr:0xc002a000 Val=0x00000006
[ 39.076088] PVR_K: 1112: `--Addr:0xc002b009 Val=0x00000519
[ 39.082180] PVR_K: 1112: FWCtx 0xC0028040 (TA-P1250-T1268-camera_kit)
[ 39.088707] PVR_K: 1112: |--Waiting FENCE @ 0 Int=7 Ext=0
[ 39.094361] PVR_K: 1112: | `--Addr:0xc002d000 Val=0x00000000
[ 39.100449] PVR_K: 1112: |--Waiting TA @ 48 Int=7 Ext=0
[ 39.105930] PVR_K: 1112: `--Waiting UPDATE @ 160 Int=7 Ext=0
[ 39.111845] PVR_K: 1112: |--Addr:0xc002d000 Val=0x00000001
[ 39.117938] PVR_K: 1112: `--Addr:0xc002b019 Val=0x00000519
[ 39.124028] PVR_K: 1112: FWCtx 0xC00280E0 (3D-P1250-T1268-camera_kit)
[ 39.130550] PVR_K: 1112: |--Waiting FENCE_PR @ 0 Int=7 Ext=0
[ 39.136465] PVR_K: 1112: | `--Addr:0xc002d000 Val=0x00000001
[ 39.142553] PVR_K: 1112: |--Waiting 3D @ 48 Int=7 Ext=0
[ 39.148038] PVR_K: 1112: `--Waiting UPDATE @ 440 Int=7 Ext=0
[ 39.153953] PVR_K: 1112: |--Addr:0xc002d000 Val=0x00000002
[ 39.160040] PVR_K: 1112: |--Addr:0xc002b011 Val=0x00000519
[ 39.166130] PVR_K: 1112: `--Addr:0xc002b021 Val=0x00000519
[ 39.172221] PVR_K: 1112: ------[ RGX Device ID:0 End ]------
[ 39.177966] PVR_K: 1112: ------[ System Summary Device ID:0 ]------
[ 39.184315] PVR_K: 1112: Device System Power State: ON
[ 39.189537] PVR_K: 1112: MaxHWTOut: 500000us, WtTryCt: 10000, WDGTOut(on,off): (10000ms,3600000ms)
[ 39.198571] PVR_K: 1112: ------[ Server Thread Summary ]------
[ 39.204488] PVR_K: 1112: pvr_defer_free : Running
[ 39.209450] PVR_K: 1112: Number of deferred cleanup items : 0
[ 39.215624] PVR_K: 1112: pvr_device_wdg : Running
[ 39.220586] PVR_K: 1112: pvr_cacheop : Running
[ 39.225297] PVR_K: 1112: Configuration: QSZ: 16, UKT: -1, KDFT: 131072, LINESIZE: 64, PGSIZE: 4096, KDF: Yes, URBF: Yes
[ 39.236501] PVR_K: 1112: Pending deferred CacheOp entries : 0
[ 39.242676] PVR_K: 1112: ------[ AppHint Settings ]------
[ 39.248157] PVR_K: 1112: Build Vars
[ 39.251906] PVR_K: 1112: EnableTrustedDeviceAceConfig: N
[ 39.257649] PVR_K: 1112: CleanupThreadPriority: 0x00000005
[ 39.263565] PVR_K: 1112: CacheOpThreadPriority: 0x00000001
[ 39.269485] PVR_K: 1112: WatchdogThreadPriority: 0x00000000
[ 39.275487] PVR_K: 1112: HWPerfClientBufferSize: 0x000c0000
[ 39.281488] PVR_K: 1112: Module Params
[ 39.285503] PVR_K: 1112: EnablePageFaultDebug: Y
[ 39.290552] PVR_K: 1112: Debug Info Params
[ 39.294911] PVR_K: 1112: CacheOpConfig: 0x0000000c
[ 39.300133] PVR_K: 1112: CacheOpUMKMThresholdSize: 0xffffffff
[ 39.306308] PVR_K: 1112: Debug Info Params Device ID: 0
[ 39.311789] PVR_K: 1112: AssertOnHWRTrigger: Y
[ 39.316669] PVR_K: 1112: EnableLogGroup: main,mts,cleanup,csw,bif,pm,rtd,spm,pow,hwr
[ 39.324840] PVR_K: 1112: ------[ HTB Log state: Off ]------
[ 39.330500] PVR_K: 1112: ------[ Active Sync Checkpoints ]------
[ 39.336596] PVR_K: 1112: - ID = 4, FWAddr = 0xc002b020, r1:e1:f0: es3_DoKick3D_0
[ 39.344149] PVR_K: 1112: - ID = 3, FWAddr = 0xc002b018, r1:e1:f0: es3_DoKickTA_0
[ 39.351699] PVR_K: 1112: - ID = 2, FWAddr = 0xc002b010, r1:e1:f0: update fence
[ 39.359078] PVR_K: 1112: - ID = 1, FWAddr = 0xc002b008, r1:e1:f0: TQM
[ 39.365692] ------[ Native Fence Sync: timelines ]------
[ 39.370997] foreign_sync: @0 ctx=1 refs=1
[ 39.375007] sw: RM_SWTimeline-camera_kit-1250 @0 cur=0
[ 39.380144] rogue-ta3d: @1 ctx=3 refs=2
[ 39.383971] @0: (+-) refs=3 fwaddr=0xc002b011 enqueue=1 status=Active 0-update fence
[ 39.392056] rogue-tq3d: @0 ctx=5 refs=1
[ 39.395892] QE-camera_kit-1250: @2 ctx=6 refs=2
[ 39.400411] @1: (+-) refs=2 fwaddr=0xc002b009 enqueue=1 status=Active 1-TQM
[ 39.407713] V3-camera_kit-1250: @1 ctx=7 refs=2
[ 39.412233] @0: (+-) refs=2 fwaddr=0xc002b019 enqueue=1 status=Active 0-es3_DoKickTA_0
[ 39.420488] P3-camera_kit-1250: @1 ctx=8 refs=2
[ 39.425007] @0: (+-) refs=2 fwaddr=0xc002b021 enqueue=1 status=Active 0-es3_DoKick3D_0
[ 39.433263] PVR_K: 1112: ------------[ PVR DBG: END ]------------
[ 39.439482] ------------[ cut here ]------------
[ 39.444172] WARNING: CPU: 1 PID: 1112 at /home/hawayi/bsp/tda4vm/sdk_8.4.0.11/board-support/extra-drivers/ti-img-rogue-driver-1.15.6133109/binary_j721e_linux_wayland_release/target_aarch64/kbuild/services/server/common/pvr_notifier.c:529 PVRSRVDebugRequest+0x4d0/0x660 [pvrsrvkm]
[ 39.468796] Modules linked in: pvrsrvkm(O) crct10dif_ce phy_can_transceiver ti_k3_r5_remoteproc sa2ul sha512_generic authenc ti_k3_dsp_remoteproc rti_wdt rng_core overlay rpmsg_kdrv_switch cryptodev(O)
[ 39.486700] CPU: 1 PID: 1112 Comm: pvr_device_wdg Tainted: G O 5.10.120-g95b90aa828 #1
[ 39.495896] Hardware name: Texas Instruments K3 J721E SoC (DT)
[ 39.501714] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO BTYPE=--)
[ 39.507767] pc : PVRSRVDebugRequest+0x4d0/0x660 [pvrsrvkm]
[ 39.513294] lr : PVRSRVDebugRequest+0x4d0/0x660 [pvrsrvkm]
[ 39.518762] sp : ffff8000116cbc80
[ 39.522064] x29: ffff8000116cbc80 x28: 0000000000000000
[ 39.527365] x27: ffff800012ef3918 x26: ffff800008bae590
[ 39.532665] x25: ffff000006ba7500 x24: 0000000000000009
[ 39.537965] x23: 0000000000000002 x22: 0000000000000000
[ 39.543263] x21: 0000000000000000 x20: ffff000006ba75d8
[ 39.548562] x19: ffff000006ba8a20 x18: 0000000000000010
[ 39.553861] x17: 0000000000000000 x16: 0000000000000000
[ 39.559161] x15: ffff000001f52130 x14: 00000000000002db
[ 39.564459] x13: 0000000000000000 x12: 000000000000002f
[ 39.569758] x11: 0000000000000181 x10: 000000000000cad2
[ 39.575058] x9 : 000000000000cad2 x8 : 0000000000000000
[ 39.580356] x7 : ffff00007fd3bbc0 x6 : ffff00007fd3b0c0
[ 39.585655] x5 : 0000000000000000 x4 : 0000000926ae54eb
[ 39.590955] x3 : 0000000000000000 x2 : ffffffffffffff00
[ 39.596254] x1 : 0000000000000000 x0 : ffff000006ba6980
[ 39.601553] Call trace:
[ 39.604056] PVRSRVDebugRequest+0x4d0/0x660 [pvrsrvkm]
[ 39.609236] DevicesWatchdogThread_ForEachVaCb+0x14c/0x158 [pvrsrvkm]
[ 39.615714] List_PVRSRV_DEVICE_NODE_ForEach_va+0x74/0xb0 [pvrsrvkm]
[ 39.622106] DevicesWatchdogThread+0x144/0x210 [pvrsrvkm]
[ 39.627544] OSThreadRun+0x24/0x60 [pvrsrvkm]
[ 39.631898] kthread+0x140/0x160
[ 39.635117] ret_from_fork+0x10/0x34
[ 39.638679] ---[ end trace 839e93a6f5f95abb ]---
root@j7-evm:/data/cache# cat /sys/kernel/debug/pvr/firmware_trace > firmware_trace.log
root@j7-evm:/data/cache# cat /sys/kernel/debug/pvr/debug_dump > debug_dump.log
Time now: 129149943us
Services State: OK
Server Errors: 1
KM Arch: 64 Bit
RGX Power State: ON
BIF0 - OK
RGX DVFS: 0 frequency changes. Current frequency: 750.000 MHz (sampled at 121308036020 ns). FW frequency: 100.000 MHz.
DM 0 (GP)
TIMER : 0x0000000013ac3bbf
PERF_3D_CYCLE : 0xCD7FCDFB
PERF_TA_OR_3D_CYCLE : 0xCD7FD39B
PC : 0x9FC02338
CAUSE_REGISTER : 0x40800C24
EPC : 0xC00003AC
SP : 0xCF600EA8
TLB :
FWT[traceptr]: 330
Build Vars
Module Params
Debug Info Params
Debug log type: trace ( main mts cleanup csw bif pm rtd spm pow hwr ) 6876516:T0-MAIN> Host Sync Partition marker: 1 6876531:T0-MTS> KCCB Slot 0: Return value 1 6876569:T0-MTS> Bg Task complete DM Bitfield: 1 6876581:T0-MTS> Kick MTS Irq task DM=0 6876602:T0-MTS> Irq Task DM = 0, Breq = 1, SBIrq = 0x400 6876666:T0-POW> Check Pow state: Int: 0x1, Ext: 0x1, Pow flags: 0x0, Fence Counters: Check: 0 - Update: 0 6876686:T0-POW> Idle timer start. Pow state int: 0x1, ext: 0x1, flags: 0x0 6876707:T0-MTS> Irq Task complete. 6876725:T0-MTS> Bg Task OSid = 0 6876777:T0-MTS> Bg Task complete DM Bitfield: 1 6876788:T0-MTS> Kick MTS Irq task DM=0 6876802:T0-MTS> Irq Task DM = 0, Breq = 1, SBIrq = 0x400 6876825:T0-POW> Check Pow state: Int: 0x1, Ext: 0x1, Pow flags: 0x0, Fence Counters: Check: 0 - Update: 0 6876845:T0-MTS> Irq Task complete. 6915701:T0-MTS> Bg Task OSid = 0 6915739:T0-POW> GPU idle (might be powered down). Pow state int: 0x1, ext: 0x1, flags: 0x0 6915763:T0-MTS> Bg Task complete DM Bitfield: 1 6915772:T0-MTS> Kick MTS Irq task DM=0 6915784:T0-MTS> Irq Task DM = 0, Breq = 1, SBIrq = 0x400 6915805:T0-POW> Check Pow state: Int: 0x1, Ext: 0x3, Pow flags: 0x0, Fence Counters: Check: 0 - Update: 0 6915825:T0-MTS> Irq Task complete. 11718607:T0-MTS> Bg Task OSid = 0 11718626:T0-MTS> KCCB Slot 1: Cmd=0x2abc00d1, OSid=0 11718646:T0-MTS> KCCB Slot 1: Return value 1 11718667:T0-MTS> Bg Task complete DM Bitfield: 1 11718676:T0-MTS> Kick MTS Irq task DM=0 11718688:T0-MTS> Irq Task DM = 0, Breq = 1, SBIrq = 0x400 11718712:T0-POW> Check Pow state: Int: 0x1, Ext: 0x3, Pow flags: 0x0, Fence Counters: Check: 0 - Update: 0 11718736:T0-MTS> Irq Task complete. 40470133:T0-MTS> Bg Task OSid = 0 40470168:T0-MTS> Bg Task complete DM Bitfield: 1 40470178:T0-MTS> Kick MTS Irq task DM=0 40470190:T0-MTS> Irq Task DM = 0, Breq = 1, SBIrq = 0x400 40470212:T0-POW> Check Pow state: Int: 0x1, Ext: 0x3, Pow flags: 0x0, Fence Counters: Check: 0 - Update: 0 40470232:T0-MTS> Irq Task complete. 48150706:T0-MTS> Bg Task OSid = 0 48150720:T0-MTS> KCCB Slot 2: Cmd=0x2abc0066, OSid=0 48150781:T0-MTS> KCCB Slot 3: Cmd=0x2abc0065, OSid=0 48150799:T0-MAIN> cCCB Woff update = 256, DM = 3, FWCtx = 0xc0028300 48150840:T0-MTS> Kick MTS Irq task DM=0 48150863:T0-MTS> Irq Task DM = 0, Breq = 1, SBIrq = 0x400 48150909:T0-MTS> Ready-to-run debug OSid = 0, DM = 3, item = 0xc0028320 48150922:T0-MTS> Client command header DM = 3, client CCB = 0xc0073000, cmd = 0xc0073000 48150983:T0-MAIN> GPU Units init (# mask: 0x1) 48151004:T0-POW> Cancel power off request int: 0x2, ext: 0x3, pow flags: 0x0 48151029:T0-BIF> Activate MemCtx=0xc0028000 DM=3 secure=0 48151039:T0-BIF> Setup reg=-1 DM=3, expect=0x00000000874ae000, actual=0xffffffffffffffff 48151051:T0-BIF> Alloc PC reg 1 48151076:T0-BIF> Grab reg 1 refcount now 1 48151098:T0-MAIN> Updating Tiles In Flight (Dusts=2, PartitionMask=0x000003ff, ISPCtl=0x0002b000) 48151107:T0-MAIN> Phantom 0: USCTiles=10 48151114:T0-MAIN> Phantom 1: USCTiles=10 48151131:T0-MAIN> Kick 3D TQ: FWCtx 0xc0028300 @ 0, CSW resume:0. (PID:1250, prio:1, frame:0, ext:0x00000001, int:0x00000001) 48151258:T0-POW> Check Pow state: Int: 0x2, Ext: 0x1, Pow flags: 0x0, Fence Counters: Check: 0 - Update: 0 48151522:T0-MTS> Irq Task complete. 48151638:T0-MTS> Bg Task complete DM Bitfield: 1 48151675:T0-MTS> Kick MTS Irq task DM=0 48151709:T0-MTS> Irq Task DM = 0, Breq = 1, SBIrq = 0x400 48151753:T0-MAIN> 3D Transfer finished 48151787:T0-MAIN> UFO Updates for FWCtx 0xc0028300 @ 200 48151800:T0-MAIN> UFO Update: [0xc002a000] = 0x00000001 48151808:T0-MAIN> UFO Update: [0xc002b000] = 0x00000519 48151836:T0-BIF> Deactivate MemCtx=0xc0028000 48151854:T0-BIF> Ungrab reg 1 refcount now 0 48151880:T0-POW> Check Pow state: Int: 0x2, Ext: 0x1, Pow flags: 0x0, Fence Counters: Check: 0 - Update: 1 48151892:T0-POW> Initiate powoff query for RD-DMs. 48151919:T0-MTS> Irq Task complete. 48151940:T0-MTS> Irq Task DM = 3, Breq = 0, SBIrq = 0x4410 48151965:T0-POW> Check Pow state: Int: 0x6, Ext: 0x1, Pow flags: 0x0, Fence Counters: Check: 0 - Update: 2 48151976:T0-POW> Any RD-DM pending? 0, Any RD-DM Active? 0 48151990:T0-MTS> Irq Task complete. 48152008:T0-MTS> Bg Task OSid = 0 48152042:T0-MTS> KCCB Slot 4: Cmd=0x2abc0065, OSid=0 48152058:T0-MAIN> cCCB Woff update = 504, DM = 3, FWCtx = 0xc0028300 48152087:T0-MTS> Kick MTS Irq task DM=0 48152104:T0-MTS> Irq Task DM = 0, Breq = 1, SBIrq = 0x4410 48152143:T0-MTS> Ready-to-run debug OSid = 0, DM = 3, item = 0xc0028320 48152158:T0-MTS> Client command header DM = 3, client CCB = 0xc0073000, cmd = 0xc0073100 48152174:T0-BIF> Activate MemCtx=0xc0028000 DM=3 secure=0 48152187:T0-BIF> Setup reg=1 DM=3, expect=0x00000000874ae000, actual=0x00000000874ae000 48152203:T0-BIF> Grab reg 1 refcount now 1 48152221:T0-MAIN> Updating Tiles In Flight (Dusts=2, PartitionMask=0x000003ff, ISPCtl=0x0002b000) 48152229:T0-MAIN> Phantom 0: USCTiles=10 48152236:T0-MAIN> Phantom 1: USCTiles=10 48152251:T0-MAIN> Kick 3D TQ: FWCtx 0xc0028300 @ 256, CSW resume:0. (PID:1250, prio:1, frame:0, ext:0x00000002, int:0x00000002) 48152302:T0-POW> Check Pow state: Int: 0x6, Ext: 0x1, Pow flags: 0x0, Fence Counters: Check: 0 - Update: 2 48152314:T0-POW> Any RD-DM pending? 0, Any RD-DM Active? 1 48152330:T0-POW> Cancel power off request int: 0x2, ext: 0x1, pow flags: 0x0 48152363:T0-MTS> Irq Task complete. 48152389:T0-MTS> KCCB Slot 5: Cmd=0x2abc0065, OSid=0 48152404:T0-MAIN> cCCB Woff update = 752, DM = 3, FWCtx = 0xc0028300 48152436:T0-MTS> KCCB Slot 6: Cmd=0x2abc0065, OSid=0 48152444:T0-MAIN> cCCB Woff update = 1000, DM = 3, FWCtx = 0xc0028300 48152459:T0-MTS> KCCB Slot 7: Cmd=0x2abc0065, OSid=0 48152467:T0-MAIN> cCCB Woff update = 1248, DM = 3, FWCtx = 0xc0028300 48152483:T0-MTS> KCCB Slot 8: Cmd=0x2abc0065, OSid=0 48152491:T0-MAIN> cCCB Woff update = 1504, DM = 3, FWCtx = 0xc0028300 48152514:T0-MTS> Bg Task complete DM Bitfield: 1 48152525:T0-MTS> Kick MTS Irq task DM=0 48152540:T0-MTS> Irq Task DM = 0, Breq = 1, SBIrq = 0x4410 48152568:T0-POW> Check Pow state: Int: 0x2, Ext: 0x1, Pow flags: 0x0, Fence Counters: Check: 2 - Update: 2 48152587:T0-MTS> Irq Task complete. 48152604:T0-MTS> Bg Task OSid = 0 48152662:T0-MTS> Bg Task complete DM Bitfield: 0 48152675:T0-MTS> Bg Task OSid = 0 48152682:T0-MTS> Bg Task complete DM Bitfield: 0 48183879:T0-MTS> Bg Task OSid = 0 48183906:T0-HWR> DM3 has taken 31640 ticks and deadline is 15600000 ticks 48183926:T0-HWR> Fast CRC Check result for Core0, DM3 is HWRNeeded=0 48183935:T0-HWR> Final result for DM3 is HWRNeeded=0 with HWRChecksToGo=3 48183964:T0-MTS> Bg Task complete DM Bitfield: 0 48183979:T0-MTS> Bg Task OSid = 0 48184005:T0-MTS> Bg Task complete DM Bitfield: 0 48215196:T0-MTS> Bg Task OSid = 0 48215219:T0-HWR> DM3 has taken 62953 ticks and deadline is 15600000 ticks 48215246:T0-HWR> Fast CRC Check result for Core0, DM3 is HWRNeeded=1 48215297:T0-HWR> USC Slots result for Core0, DM3 is HWRNeeded=1 USCSlotsUsedByDM=0 48215328:T0-HWR> Extra Registers Check result for Core0, DM3 is HWRNeeded=0 48215337:T0-HWR> Final result for DM3 is HWRNeeded=0 with HWRChecksToGo=2 48215370:T0-MTS> Bg Task complete DM Bitfield: 0 48215385:T0-MTS> Bg Task OSid = 0 48215411:T0-MTS> Bg Task complete DM Bitfield: 0 48246599:T0-MTS> Bg Task OSid = 0 48246622:T0-HWR> DM3 has taken 94355 ticks and deadline is 15600000 ticks 48246641:T0-HWR> Full Signature Check result for Core0, DM3 is HWRNeeded=1 48246689:T0-HWR> USC Slots result for Core0, DM3 is HWRNeeded=1 USCSlotsUsedByDM=0 48246710:T0-HWR> Extra Registers Check result for Core0, DM3 is HWRNeeded=1 48246719:T0-HWR> Final result for DM3 is HWRNeeded=1 with HWRChecksToGo=2 48246751:T0-MTS> Bg Task complete DM Bitfield: 0 48246767:T0-MTS> Bg Task OSid = 0 48246792:T0-MTS> Bg Task complete DM Bitfield: 0 48277982:T0-MTS> Bg Task OSid = 0 48278005:T0-HWR> DM3 has taken 125738 ticks and deadline is 15600000 ticks 48278022:T0-HWR> Full Signature Check result for Core0, DM3 is HWRNeeded=1 48278069:T0-HWR> USC Slots result for Core0, DM3 is HWRNeeded=1 USCSlotsUsedByDM=0 48278089:T0-HWR> Extra Registers Check result for Core0, DM3 is HWRNeeded=1 48278097:T0-HWR> Final result for DM3 is HWRNeeded=1 with HWRChecksToGo=1 48278131:T0-MTS> Bg Task complete DM Bitfield: 0 48278146:T0-MTS> Bg Task OSid = 0 48278171:T0-MTS> Bg Task complete DM Bitfield: 0 48309358:T0-MTS> Bg Task OSid = 0 48309381:T0-HWR> DM3 has taken 157114 ticks and deadline is 15600000 ticks 48309398:T0-HWR> Full Signature Check result for Core0, DM3 is HWRNeeded=1 48309446:T0-HWR> USC Slots result for Core0, DM3 is HWRNeeded=1 USCSlotsUsedByDM=0 48309463:T0-HWR> Extra Registers Check result for Core0, DM3 is HWRNeeded=1 48309471:T0-HWR> Final result for DM3 is HWRNeeded=1 with HWRChecksToGo=0 48309480:T0-HWR> DM3 timed out 48309491:T0-HWR> RGX DM3 phase count=0x00000001 48309500:T0-HWR> Core 0 RGX_CR_EVENT_STATUS=0x00004410 48309542:T0-HWR> USC slots: 0 used by DM2 48309547:T0-HWR> USC slots: 0 used by DM3 48309553:T0-HWR> USC slots: 0 used by DM4 48309557:T0-HWR> USC slots: 128 empty 48309565:T0-HWR> DM3 has locked up 48309570:T0-MAIN> GPU has locked up (see HWR logs for more info) ASSERTION (gsRGXFWCtl.ui32StateFlags & RGXFW_STATE_ASSERT_ON_HWR_TRIGGER) == 0U failed at firmware/rogue/rgxfw_hwr.c:2993
can you help me?
Harvey
