Other Parts Discussed in Thread: AMIC120, SYSCONFIG
Hello
We are using the AMIC110 as an EtherCat slave device (both PRUs are in use). Is it possible to realize another Ethernet connection to the AMIC by just adding a third PHY, which will be connected via RMII? The data sheet mentions an EMAC interface as well as all the necessary pins, but is also says that the EMAC is implemented in the AMIC120 device. Another thought - the PinMux tool does not mention the EMAC neither.
Is it although available on the AMIC110? Are there any application notes about it?
best regards
Thomas
