Stock example of LOG_printf() writes incorrectly to trace$buf
Other Parts Discussed in Thread: CCSTUDIO
Thanks for reading.
I copied and ran c:\CCstudio_v3.1\examples\sim64xx\bios\quetest\quetest1.pjt
I open view->memory at location trace$buf and saw this:
trace$buf
0000D000 ............|$..
0000D010 ....a.......'$..
0000D020 ....b.......'$..
0000D030 ....c.......'$..
0000D040....d........'$..
It should say, "writing a", "reading a", etc.
Any clue whats wrong with LOG_printf?
-jim
  • Found it myself. Thanks ti-wiki !
    http://www.tiexpressdsp.com/index.php?title=Accessing_DSP_BIOS_logs_without_JTAG
    I was looking at memory as "char".
    If instead I had done TI-32bit, I might have reverse engineered it lone-sef !
    Log_printf() puts out encrypted message as follow:
    sequence number, arg0, arg1, then address of the guts.
    Silly me thought it was just a simple string. (actually I like TI method better.)
    ------Anyone got INTEL code to pull LOG_printf() message out somehow???---------------
    email me if you do....
    -jim
    gpscruise@gmail.com
  • Hi Jim,
    I am curious about why you need to change the way the LOG message sits in memory? The point of the LOG_printf() is to output a message to the Message Log window inside CCS (basically a less invasive version of printf()). I don't think the way LOG_printf works can be changed.
  • Log_printf() puts stuff in trace$buf.
    I want to copy trace$buf to another area and customize it there.
    Q: How do I get the address of trace$buf in C, not assembly?
    It isn't
    _trace$buf
    so I can't call it from C.
    There is no underscore.
  • Because it lacks the leading underscore it cannot be accessed through C, only Assembly.
  • Where is the C6x assembly manual online?
    Heres what I have so far.  My assembly is rusty...
    //implementing           myframebuf= frame$buf
    asm(".global frame$buf");
    asm(".global _myframebuf");
    What processor are you targeting?  Go to the Product Folder for the specific process on http://www.ti.com.  You should find an User's Guide called DSP CPU and Instruction Set Reference Guide for the instruction set.
    However, I believe you are looking for the assembly tools manual.  If so, this document should be included in the CCS installation directory on your PC.  For example, in the C:\CCStudio_v3.3\docs\PDF\manuals_ccs_full_c6000.html
  • Got it, thanks.   C6416   spru189f.pdf
    //this creates a C pointer to the ASM trace$buf    Used to read LOG_printf() results from C.
    int mytracebuf;
    main() {
    asm(" .global trace$buf");
    asm(" .global _mytracebuf");
    asm(" mvkl trace$buf,a1");
    asm(" mvkh trace$buf,a1");
    asm(" mvkl _mytracebuf,a2");
    asm(" mvkh _mytracebuf,a2");
    asm(" stw a1,*a2");
    thanks. I will mark this closed, unless you see any gotchas in my inline-asm code...
    -jim
