AM6442: HF-FS AM6442 - uboot reboot 2 times, and there is a "workaround" keywords
Part Number: AM6442
Hi champs:
I already made the AM64 HS-FS working well on the TI EVM.
The below is the log I captured, plz review in detail.
  3 Questions:
     Q1. What's the meaning of this: i2231 workaround?
           What's the potential side-effect of this?
           When will this be official fixed and in which SDK will fix it?
 U-Boot SPL 2021.01 (Nov 23 2022 - 00:34:11 -0800)
EEPROM not available at 80, trying to read at 81
Resetting on cold boot to workaround ErrataID:i2331
resetting ...
     Q2. You can see the SLP boot 2 times, is this normal even the workaround fixed?
     Q3. In the formal fix of this, I assume the SPL will boot only 1 time, right?
BR RIo
resetting ...
SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.7--v08.04.07 (Jolly Jellyfi')
SPL initial stack usage: 13424 bytes
Trying to boot from MMC2
Authentication passed
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.7(release):08.04.01.005-655-g52a79b0ed
NOTICE:  BL31: Built : 01:19:38, Nov  8 2022
I/TC:
I/TC: OP-TEE version: 3.19.0-22-g1c025012 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #2 Wed Nov 23 02:16:41 UTC 2022 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.7--v08.04.07 (Jolly Jellyfi')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
U-Boot SPL 2021.01 (Nov 23 2022 - 01:10:17 -0800)
U-Boot 2021.01 (Nov 23 2022 - 01:10:17 -0800)
SoC:   AM64X SR2.0 HS-FS
Model: Texas Instruments AM642 SK
Board: AM64B-SKEVM rev A
DRAM:  2 GiB
NAND:  0 MiB
MMC:   mmc@fa00000: 1
Loading Environment from FAT... OK
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   eth0: ethernet@8000000port@1
Warning: ethernet@8000000port@2 MAC addresses don't match:
Address in ROM is               34:08:e1:80:af:38
Address in environment is       70:ff:76:1e:bc:2c
, eth1: ethernet@8000000port@2
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
1490 bytes read in 4 ms (363.3 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
1 bytes read in 2 ms (0 Bytes/s)
Already setup.
7812031 bytes read in 326 ms (22.9 MiB/s)
## Loading kernel from FIT Image at 90000000 ...
   Using 'k3-am642-sk.dtb' configuration
   Trying 'kernel@1' kernel subimage
     Description:  Linux kernel
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0x900000f4
     Data Size:    7682461 Bytes = 7.3 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x80008000
     Entry Point:  0x80008000
   Verifying Hash Integrity ... OK
## Loading fdt from FIT Image at 90000000 ...
   Trying 'k3-am642-sk.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Compression:  uncompressed
     Data Start:   0x90761c9c
     Data Size:    56364 Bytes = 55 KiB
   Booting using the fdt blob at 0x90761c9c
   Uncompressing Kernel Image
   Loading Device Tree to 000000008ffef000, end 000000008ffff5ba ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.10.140-rt73-g3a997318d8 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT_RT Wed Sep 28 04:42:20 UTC 2022
[    0.000000] Machine model: Texas Instruments AM642 SK
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node m4f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node m4f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a57fffff]
[    0.000000]   node   0: [mem 0x00000000a5800000-0x00000000ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000] On node 0 totalpages: 524288
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 524288 pages, LIFO batch:63
[    0.000000] cma: Reserved 512 MiB at 0x00000000dd000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 18 pages/cpu s35008 r8192 d30528 u73728
[    0.000000] pcpu-alloc: s35008 r8192 d30528 u73728 alloc=18*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=fc40000.spi.0:1m(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system) root=PARTUUID=7c6f56e7-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 1399584K/2097152K available (10752K kernel code, 1186K rwdata, 4172K rodata, 1728K init, 435K bss, 173280K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000] rcu:     RCU priority boosting: priority 1 delay 500 ms.
[    0.000000] rcu:     RCU_SOFTIRQ processing moved to rcuc kthreads.
[    0.000000]  No expedited grace period (rcu_normal_after_boot).
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001840000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @81c00000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000081430000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000081440000
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008606] Console: colour dummy device 80x25
[    0.013211] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023884] pid_max: default: 32768 minimum: 301
[    0.028725] LSM: Security Framework initializing
[    0.033517] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.041097] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.051282] rcu: Hierarchical SRCU implementation.
[    0.056859] Platform MSI: msi-controller@1820000 domain created
[    0.063355] PCI/MSI: /bus@f4000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.072739] EFI services will not be available.
[    0.077764] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[    0.091592] Detected VIPT I-cache on CPU1
[    0.095734] GICv3: CPU1: found redistributor 1 region 0:0x0000000001860000
[    0.102767] GICv3: CPU1: using allocated LPI pending table @0x0000000081450000
[    0.110204] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.117048] smp: Brought up 1 node, 2 CPUs
[    0.121287] SMP: Total of 2 processors activated.
[    0.126110] CPU features: detected: 32-bit EL0 Support
[    0.131376] CPU features: detected: CRC32 instructions
[    0.144647] CPU: All CPU(s) started at EL2
[    0.148857] alternatives: patching kernel code
[    0.154795] devtmpfs: initialized
[    0.168840] KASLR disabled due to lack of seed
[    0.173652] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.183631] futex hash table entries: 512 (order: 4, 65536 bytes, linear)
[    0.208694] pinctrl core: initialized pinctrl subsystem
[    0.214802] DMI not present or invalid.
[    0.219593] NET: Registered protocol family 16
[    0.226531] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.233972] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.242112] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.251053] thermal_sys: Registered thermal governor 'step_wise'
[    0.251792] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.264993] ASID allocator initialised with 32768 entries
[    0.302702] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.309659] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.316533] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.323396] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.331740] cryptd: max_cpu_qlen set to 1000
[    0.340523] k3-chipinfo 43000014.chipid: Family:AM64X rev:SR2.0 JTAGID[0x1bb3802f] Detected
[    0.349909] vcc_3v3_sys: supplied by vusb_main5v0
[    0.356642] iommu: Default domain type: Translated
[    0.362215] SCSI subsystem initialized
[    0.366836] mc: Linux media interface: v0.10
[    0.371317] videodev: Linux video capture interface: v2.00
[    0.377063] pps_core: LinuxPPS API ver. 1 registered
[    0.382222] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.391589] PTP clock support registered
[    0.395652] EDAC MC: Ver: 3.0.0
[    0.399852] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fc9100
[    0.406831] omap-mailbox 29040000.mailbox: omap mailbox rev 0x66fc9100
[    0.413669] omap-mailbox 29060000.mailbox: omap mailbox rev 0x66fc9100
[    0.421257] FPGA manager framework
[    0.424918] Advanced Linux Sound Architecture Driver Initialized.
[    0.432515] clocksource: Switched to clocksource arch_sys_counter
[    0.439044] VFS: Disk quotas dquot_6.6.0
[    0.443135] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.458302] NET: Registered protocol family 2
[    0.463128] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.472260] tcp_listen_portaddr_hash hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.481195] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.489502] TCP bind hash table entries: 16384 (order: 7, 917504 bytes, linear)
[    0.498073] TCP: Hash tables configured (established 16384 bind 16384)
[    0.505203] UDP hash table entries: 1024 (order: 5, 131072 bytes, linear)
[    0.512366] UDP-Lite hash table entries: 1024 (order: 5, 131072 bytes, linear)
[    0.520195] NET: Registered protocol family 1
[    0.525468] RPC: Registered named UNIX socket transport module.
[    0.531607] RPC: Registered udp transport module.
[    0.536416] RPC: Registered tcp transport module.
[    0.541225] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.547821] PCI: CLS 0 bytes, default 64
[    0.552841] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.566363] Initialise system trusted keyrings
[    0.571354] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    0.584373] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.591318] NFS: Registering the id_resolver key type
[    0.596612] Key type id_resolver registered
[    0.600915] Key type id_legacy registered
[    0.605197] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.612065] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.620012] 9p: Installing v9fs 9p2000 file system support
[    0.669359] Key type asymmetric registered
[    0.673606] Asymmetric key parser 'x509' registered
[    0.678700] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.686290] io scheduler mq-deadline registered
[    0.690921] io scheduler kyber registered
[    0.698145] pinctrl-single f4000.pinctrl: 180 pins, size 720
[    0.705458] pinctrl-single a40000.timesync-router: 512 pins, size 2048
[    0.723797] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.750374] brd: module loaded
[    0.764973] loop: module loaded
[    0.769388] megasas: 07.714.04.00-rc1
[    0.778577] tun: Universal TUN/TAP device driver, 1.6
[    0.784774] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.791235] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.797376] sky2: driver version 1.30
[    0.802615] VFIO - User Level meta-driver version: 0.3
[    0.809546] i2c /dev entries driver
[    0.814651] sdhci: Secure Digital Host Controller Interface driver
[    0.821063] sdhci: Copyright(c) Pierre Ossman
[    0.826385] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.834125] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.842578] optee: probing for conduit method.
[    0.847281] optee: revision 3.19 (1c025012)
[    0.847687] optee: dynamic shared memory is enabled
[    0.857507] optee: initialized driver
[    0.864183] NET: Registered protocol family 17
[    0.869048] 9pnet: Installing 9P2000 support
[    0.873571] Key type dns_resolver registered
[    0.878430] printk: bootconsole [ns16550a0]: printing thread started
[    0.878497] Loading compiled-in X.509 certificates
[    0.899732] ti-sci 44043000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.4.7--v08.04.07 (Jolly Jellyfi')
[    0.956119] omap-gpmc 3b000000.memory-controller: GPMC revision 6.0
[    0.956146] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[    0.963977] omap_i2c 20000000.i2c: bus 0 rev0.12 at 100 kHz
[    0.966045] pca953x 1-0070: supply vcc not found, using dummy regulator
[    0.966232] pca953x 1-0070: using no AI
[    0.989626] omap_i2c 20010000.i2c: bus 1 rev0.12 at 400 kHz
[    0.991328] omap_i2c 20020000.i2c: bus 2 rev0.12 at 100 kHz
[    0.991868] ti-sci-intr bus@f4000:bus@4000000:interrupt-controller1: Interrupt Router 5 domain created
[    0.992123] ti-sci-intr bus@f4000:interrupt-controller0: Interrupt Router 3 domain created
[    0.992634] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
  r硎薹╞琨cdma 485c0100.dma-controller: Number of rings: 68
[    1.008810] ti-bcdma 485c0100.dma-controller: Channels: 24 (bchan: 12, tchan: 6, rchan: 6)
[    1.037997] printk: console [ttyS2]: printing thread started
[    1.010998] ti-pktdma 485c0000.dma-controller: Number of rings: 288
[    1.038036] printk: console [ttyS2] enabled
[    1.038041] printk: bootconsole [ns16550a0] disabled
[    1.058567] printk: bootconsole [ns16550a0]: printing thread stopped
[    1.063998] omap8250 2840000.serial: PM domain pd:155 will not be powered off
[    1.064574] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 17, base_baud = 3000000) is a 8250
[    1.064800] serial serial0: tty port ttyS6 registered
[    1.074567] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[    1.074620] 7 cmdlinepart partitions found on MTD device fc40000.spi.0
[    1.074626] Creating 7 MTD partitions on "fc40000.spi.0":
[    1.074634] 0x000000000000-0x000000100000 : "ospi.tiboot3"
[    1.076376] 0x000000100000-0x000000300000 : "ospi.tispl"
[    1.077970] 0x000000300000-0x000000700000 : "ospi.u-boot"
[    1.079380] 0x000000700000-0x000000740000 : "ospi.env"
[    1.081032] 0x000000740000-0x000000780000 : "ospi.env.backup"
[    1.082593] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[    1.084059] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[    1.119627] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[    1.156528] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.159700] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[    1.159720] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
[    1.159854] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA00903, cpsw version 0x6BA80903 Ports: 3 quirks:00000002
[    1.160091] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.4
[    1.160099] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[    1.161140] pps pps0: new PPS source ptp0
[    1.161623] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
[    1.169216] am65-cpts 39000000.cpts: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
[    1.170235] k3-j72xx-soc-thermal b00000.temperature-sensor: invalid resource
[    1.170290] k3-j72xx-soc-thermal: probe of b00000.temperature-sensor failed with error -22
[    1.174979] gpio-478 (btuart_rts_sel): hogged as output/high
[    1.185191] vdd_mmc1: supplied by vcc_3v3_sys
[    1.186520] wlan_en: supplied by com8_ls_en
[    1.191175] debugfs: Directory 'pd:114' with parent 'pm_genpd' already present!
[    1.206415] ALSA device list:
[    1.206432]   No soundcards found.
[    1.207041] mmc0: CQHCI version 5.10
[    1.207712] mmc1: CQHCI version 5.10
[    1.281521] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[    1.282864] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[    1.284444] Waiting for root device PARTUUID=7c6f56e7-02...
[    1.289286] sdhci-am654 fa10000.mmc: card claims to support voltages below defined range
[    1.301324] mmc0: new SDIO card at address 0001
[    1.337061] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[    1.338053] mmcblk1: mmc1:aaaa SD32G 29.7 GiB
[    1.339972]  mmcblk1: p1 p2
[    1.381993] EXT4-fs (mmcblk1p2): recovery complete
[    1.383664] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.383777] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.397491] devtmpfs: mounted
[    1.398925] Freeing unused kernel memory: 1728K
[    1.399066] Run /sbin/init as init process
[    1.554918] systemd[1]: System time before build time, advancing clock.
[    1.609278] NET: Registered protocol family 10
[    1.610826] Segment Routing with IPv6
[    1.634515] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    1.635105] systemd[1]: Detected architecture arm64.
Welcome to Arago 2021.09!
[    1.685708] systemd[1]: Set hostname to <am64xx-evm>.
[    2.077744] systemd[1]: /lib/systemd/system/startwlansta.service:7: Unknown key name 'After' in section 'Service', ignoring.
[    2.079381] systemd[1]: /lib/systemd/system/startwlanap.service:7: Unknown key name 'After' in section 'Service', ignoring.
[    2.145077] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock ? /run/docker.sock; please update the unit file accordingly.
[    2.289345] random: systemd: uninitialized urandom read (16 bytes read)
[    2.289779] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    2.289800] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    2.295266] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[  OK  ] Created slice system-serial\x2dgett[    2.340807] random: systemd: uninitialized urandom read (16 bytes read)
y.slice.
[    2.343403] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-syslog\x2dng.s[    2.364836] random: systemd: uninitialized urandom read (16 bytes read)
lice.
[    2.367453] systemd[1]: Created slice system-syslog\x2dng.slice.
[  OK  ] Created slice User and Session Slic[    2.391433] systemd[1]: Created slice User and Session Slice.
e.
[  OK  ] Started Dispatch Password s to [    2.413409] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Forward Password Rests [    2.437272] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Reached target Paths.[    2.461176] systemd[1]: Reached target Paths.
[  OK  ] Reached target Remote File Systems systemd[1]: Reached target Remote File Systems.
[0m.
[  OK  ] Reached target Slices.[    2.504938] systemd[1]: Reached target Slices.
[  OK  ] Reached target Swap.[    2.524961] systemd[1]: Reached target Swap.
[  OK  ] Listening on RPCbind Server Activat[    2.546181] systemd[1]: Listening on RPCbind Server Activation Socket.
ion Socket.
[  OK  ] Reached target RPC Port Mapper.[    2.568944] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Listening on Process Core Dump Sock[    2.595091] systemd[1]: Listening on Process Core Dump Socket.
et.
[  OK  ] Listening on initctl Compatibility [    2.617367] systemd[1]: Listening on initctl Compatibility Named Pipe.
Named Pipe.
[  OK  ] Listening on Journal Socket (/dev/l[    2.650787] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    2.651923] systemd[1]: Listening on Journal Socket (/dev/log).
og).
[  OK  ] Listening on Journal Socket.
[    2.681793] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Network Service Netlin[    2.694111] systemd[1]: Listening on Network Service Netlink Socket.
k Socket.
[  OK  ] Listening on udev Control Socket    2.717812] systemd[1]: Listening on udev Control Socket.
m.
[  OK  ] Listening on udev Kernel Socket[    2.741457] systemd[1]: Listening on udev Kernel Socket.
[    2.772145] systemd[1]: Mounting Huge Pages File System...
         Mounting POSIX Message Queue File System..[    2.799690] systemd[1]: Mounting POSIX Message Queue File System...
         Mounting Kernel Debug File System...
[    2.831736] systemd[1]: Mounting Kernel Debug File System...
         Mounting Temporary Directory (/tmp)...
[    2.850899] systemd[1]: Mounting Temporary Directory (/tmp)...
         Starting Create list of stdes for the curr[    2.870777] systemd[1]: Starting Create list of static device nodes for the current kernel...
ent kernel...
[    2.904440] systemd[1]: Starting RPC Bind...
[    2.925535] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
         Starting Journal Service...[    2.936214] systemd[1]: Starting Journal Service...
         Starting Load Kernel Modules...[    2.974606] systemd[1]: Starting Load Kernel Modules...
         Starting Remount Root and Kernel File Systems systemd[1]: Starting Remount Root and Kernel File Systems...
[0m...
[    3.036156] systemd[1]: Starting udev Coldplug all Devices...
[    3.056001] cryptodev: loading out-of-tree module taints kernel.
[  OK  ] Started RPC Bind.
[    3.089029] cryptodev: driver 1.10 loaded.
[    3.089370] systemd[1]: Started RPC Bind.
[    3.097352] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[  OK  ] Mounted Huge Pages File System.[    3.110483] systemd[1]: Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File Sy[    3.133846] systemd[1]: Mounted POSIX Message Queue File System.
stem.
[  OK  ] Started Journal Service.[    3.161868] systemd[1]: Started Journal Service.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Temporary Directory (/tmp).
[  OK  ] Started Create list of sta?nodes for the current kernel.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Remount Root and Kernel File Systems.
[    3.297681] random: systemd: uninitialized urandom read (16 bytes read)
         Mounting Kernel Configuration File System.[    3.311740] random: systemd-journal: uninitialized urandom read (16 bytes read)
[    3.335116] random: systemd: uninitialized urandom read (16 bytes read)
         Starting Flush Journal to Persistent Storage...
[    3.362615] systemd-journald[201]: Received client request to flush runtime journal.
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Mounting /var/volatile...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /media/ram.
[  OK  ] Mounted /var/volatile.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started udev Coldplug all Devices.
[    4.630530] random: systemd: uninitialized urandom read (16 bytes read)
         Starting udev Wait for Complete Device Initialization...
[    4.644992] random: systemd-journal: uninitialized urandom read (16 bytes read)
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Set.[    4.798359] random: systemd: uninitialized urandom read (16 bytes read)
[  OK  ] Reached target System Time Synchronized.
[    5.306496] random: crng init done
[    5.306515] random: 62 urandom warning(s) missed due to ratelimiting
[  OK  ] Started Load/Save Random Seed.
[    5.960571] Bluetooth: Core ver 2.22
[    5.960759] NET: Registered protocol family 31
[    5.960764] Bluetooth: HCI device and connection manager initialized
[    5.960791] Bluetooth: HCI socket layer initialized
[    5.960805] Bluetooth: L2CAP socket layer initialized
[    5.960831] Bluetooth: SCO socket layer initialized
[    6.031753] Bluetooth: HCI UART driver ver 2.3
[    6.031785] Bluetooth: HCI UART protocol H4 registered
[    6.073286] Bluetooth: HCI UART protocol LL registered
[    6.073723] Bluetooth: HCI UART protocol Broadcom registered
[    6.073782] Bluetooth: HCI UART protocol QCA registered
[    6.135978] Bluetooth: hci0: change remote baud rate command in firmware
[    6.160915] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@a4000000
[    6.181041] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
[    6.181220] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
[    6.181692] remoteproc remoteproc0: 5000000.m4fss is available
[    6.185307] remoteproc remoteproc0: powering up 5000000.m4fss
[    6.185339] remoteproc remoteproc0: Booting fw image am64-mcu-m4f0_0-fw, size 85476
[    6.289139]  remoteproc0#vdev0buffer: assigned reserved memory node m4f-dma-memory@a4000000
[    6.289380]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[    6.289393] remoteproc remoteproc0: remote processor 5000000.m4fss is now up
[    6.434267] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[    6.434528] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[    6.434739] virtio_rpmsg_bus virtio0: rpmsg host is online
[    6.463394] platform 78000000.r5f: configured R5F for remoteproc mode
[    6.463912] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[    6.464485] remoteproc remoteproc1: 78000000.r5f is available
[    6.475552] remoteproc remoteproc1: powering up 78000000.r5f
[    6.475584] remoteproc remoteproc1: Booting fw image am64-main-r5f0_0-fw, size 86352
[    6.480637] platform 78200000.r5f: configured R5F for remoteproc mode
[    6.485470] platform 78200000.r5f: assigned reserved memory node r5f-dma-memory@a1000000
[    6.485987] remoteproc remoteproc2: 78200000.r5f is available
[    6.489140] remoteproc remoteproc2: powering up 78200000.r5f
[    6.489176] remoteproc remoteproc2: Booting fw image am64-main-r5f0_1-fw, size 141772
[    6.493396]  remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
[    6.494603] virtio_rpmsg_bus virtio1: rpmsg host is online
[    6.494721]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
[    6.494733] remoteproc remoteproc1: remote processor 78000000.r5f is now up
[    6.494892] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[    6.499840]  remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a1000000
[    6.501031] virtio_rpmsg_bus virtio2: rpmsg host is online
[    6.501178]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
[    6.501191] remoteproc remoteproc2: remote processor 78200000.r5f is now up
[    6.501875] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[    6.566205] platform 78400000.r5f: configured R5F for remoteproc mode
[    6.574024] platform 78400000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[    6.574530] remoteproc remoteproc3: 78400000.r5f is available
[    6.576965] remoteproc remoteproc3: powering up 78400000.r5f
[    6.577000] remoteproc remoteproc3: Booting fw image am64-main-r5f1_0-fw, size 93260
[    6.612614] platform 78600000.r5f: configured R5F for remoteproc mode
[    6.618822] platform 78600000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[    6.619329] remoteproc remoteproc4: 78600000.r5f is available
[    6.621846] remoteproc remoteproc4: powering up 78600000.r5f
[    6.621878] remoteproc remoteproc4: Booting fw image am64-main-r5f1_1-fw, size 91520
[    6.622548]  remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
[    6.623167] virtio_rpmsg_bus virtio3: rpmsg host is online
[    6.623231]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
[    6.623240] remoteproc remoteproc3: remote processor 78400000.r5f is now up
[    6.624148] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
[    6.637025]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
[    6.638431] virtio_rpmsg_bus virtio4: rpmsg host is online
[    6.638515]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
[    6.638525] remoteproc remoteproc4: remote processor 78600000.r5f is now up
[    6.639494] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xe
[*     ] A start job is running for udev Waiice Initialization (8s / 3min 2s)
[   10.949667] remoteproc remoteproc5: 30034000.pru is available
[   10.972783] remoteproc remoteproc6: 30004000.rtu is available
[   10.974544] remoteproc remoteproc7: 3000a000.txpru is available
[   10.992453] remoteproc remoteproc8: 30038000.pru is available
[   11.002400] remoteproc remoteproc9: 30006000.rtu is available
[   11.022690] remoteproc remoteproc10: 3000c000.txpru is available
[   11.025663] remoteproc remoteproc11: 300b4000.pru is available
[   11.026359] remoteproc remoteproc12: 30084000.rtu is available
[   11.029409] remoteproc remoteproc13: 3008a000.txpru is available
[   11.033314] remoteproc remoteproc14: 300b8000.pru is available
[**    ] A start job is running for udev Waiice Initialization (8s / 3min 2s)
[  OK  ] Listening on Load/Save RF tch Status /dev/rfkill Watch.
         Starting Load/Save RF Kill Switch Status...
[  OK  ] Started Load/Save RF Kill Switch Status.
[   11.773002] usbcore: registered new interface driver usbfs
[   11.790237] usbcore: registered new interface driver hub
[   11.809408] usbcore: registered new device driver usb
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[   11.970145] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   12.007918] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[  OK  ] Found device /dev/mmcblk1p1.
         Starting File System Check on /dev/mmcblk1p1...
[   12.283568] wl18xx_driver wl18xx.0.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
[   12.306799] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[   12.306892] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[   12.307364] xhci-hcd xhci-hcd.1.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[   12.324912] xhci-hcd xhci-hcd.1.auto: irq 526, io mem 0x0f410000
[   12.325502] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   12.325518] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   12.325526] usb usb1: Product: xHCI Host Controller
[   12.325531] usb usb1: Manufacturer: Linux 5.10.140-rt73-g3a997318d8 xhci-hcd
[   12.325537] usb usb1: SerialNumber: xhci-hcd.1.auto
[   12.341514] hub 1-0:1.0: USB hub found
[   12.349332] hub 1-0:1.0: 1 port detected
[   12.350051] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[   12.350079] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[   12.350101] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[   12.350187] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   12.350329] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[   12.350339] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   12.350346] usb usb2: Product: xHCI Host Controller
[   12.350352] usb usb2: Manufacturer: Linux 5.10.140-rt73-g3a997318d8 xhci-hcd
[   12.350358] usb usb2: SerialNumber: xhci-hcd.1.auto
[   12.365412] hub 2-0:1.0: USB hub found
[  OK  ] Started File System Check on /dev/m[   12.366449] hub 2-0:1.0: 1 port detected
mcblk1p1.
         Mounting /run/media/mmcblk1p1...
[  OK  ] Started udev Wait for Complete Device Initialization.
[  OK  ] Mounted /run/media/mmcblk1p1.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[   12.689410] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[  OK  ] Reached target System Initialization.
[   12.705020] wlcore: loaded
[  OK  ] Started Daily rotation of log files.
[  OK  ] Started Timer service to update the IP on OLED each 10s.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting Docker Socket for the API.
[  OK  ] Listening on dropbear.socket.
         Starting Reboot and dump vmcore via kexec...
[  OK  ] Listening on Docker Socket for the API.
[  OK  ] Started Reboot and dump vmcore via kexec.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[  OK  ] Started Job spooling tools.
         Starting Bluetooth service...
[  OK  ] Started Periodic Command Scheduler.
[  OK  ] Started D-Bus System Message Bus.
         Starting Ethernet Bridge Filtering Tables...
         Starting Print notice about GPLv3 packages...
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
[  OK  ] Started irqbalance daemon.
         Starting Matrix GUI...
         Starting startwlanap...
         Starting startwlansta...
         Starting System Logger Daemon "default" instance...
         Starting Login Service...
[  OK  ] Started TEE Supplicant.
         Starting telnetd.service...
[  OK  ] Started Matrix GUI.
[  OK  ] Started startwlansta.
[  OK  ] Started startwlanap.
[  OK  ] Started Ethernet Bridge Filtering Tables.
[  OK  ] Started IPv6 Packet Filtering Framework.
[  OK  ] Started IPv4 Packet Filtering Framework.
[  OK  ] Reached target Network (Pre).
         Starting Network Service...
[  OK  ] Started System Logger Daemon "default" instance.
[  OK  ] Started telnetd.service.
         Starting syslog.service...
[  OK  ] Started Bluetooth service.
[  OK  ] Reached target Bluetooth.
         Starting Hostname Service...
[   14.179759] NET: Registered protocol family 38
[  OK  ] Started syslog.service.
[  OK  ] Started Network Service.
         Starting Wait for Network to be Configured...
         Starting Network Name Resolution...
[   15.077425] wlcore: using inverted interrupt logic: 2
[   15.173105] wlcore: PHY firmware version: Rev 8.2.0.0.245
[   15.281285] wlcore: firmware booted (Rev 8.9.0.0.86)
[   15.400714] am65-cpsw-nuss 8000000.ethernet: down msc_sl e0000000 tmo 0
[   15.497729] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 16
[   15.538290] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
[   15.538331] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
[  OK  ] Started Login Service.
[   15.660668] am65-cpsw-nuss 8000000.ethernet: down msc_sl e0000000 tmo 0
[   15.819040] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[   15.819085] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[  OK  ] Started Hostname Service.
[   15.874358] startwlanap.sh[837]: adding wlan1 interface
[   16.115146] startwlanap.sh[842]: Configuration file: /usr/share/wl18xx/hostapd.conf
[   16.301968] wlcore: down
[   16.269683] startwlanap.sh[842]: wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
[   16.349715] startwlanap.sh[842]: Using interface wlan1 with hwaddr 6c:79:b8:fa:d7:4d and ssid "AM64xSK-AP_b8fad7"
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Enable and configure wl18xx bluetooth stack...
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
[   16.569986] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
         Starting Simple Network Mant Protocol (SNMP) Daemon....
         Starting Permit User Sessions...
[  OK  ] Started Vsftpd ftp daemon.
[   16.580362] startwlanap.sh[842]: wlan1: interface state COUNTRY_UPDATE->ENABLED
[   16.580883] startwlanap.sh[842]: wlan1: AP-ENABLED
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[  OK  ] Started Enable and configure wl18xx bluetooth stack.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started Simple Network Manment Protocol (SNMP) Daemon..
NOTICE: This file system contains the following GPLv3 packages:
        autoconf
        bash
        bc
        binutils
        cifs-utils
        coreutils-stdbuf
        coreutils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        gettext
        gstreamer1.0-libav
        gzip
        hidapi
        less
        libasm1
        libbfd
        libdw1
        libelf1
        libgdbm-compat4
        libgdbm6
        libgettextlib
        libgettextsrc
        libgmp10
        libidn2-0
        libmpc3
        libmpfr6
        libreadline8
        libunistring2
        m4
        make
        nettle
        parted
        tar
        which
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Started Print notice about GPLv3 packages.
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project am64xx-evm ttyS2
Arago 2021.09 am64xx-evm ttyS2
am64xx-evm login: [  136.285280] Initializing XFRM netlink socket
[  137.886148] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[  137.906194] Bridge firewalling registered
[  139.749608] process 'docker/tmp/qemu-check411348082/check' started with executable stack
  • Hello Rio,
    from what I understand there's only going to be this workaround, that consists of the AM64x being warm reset after a power-on reset.
    re Q1)
    Errata i2331 for the AM64x (https://www.ti.com/lit/er/sprz457f/sprz457f.pdf?ts=1671081100800) describes an issue that causes a lockup of the processor upon reading from a CPSW register after a power-on reset. The workaround consists of resetting the processor again with a warm reset. This is implemented in U-Boot which now checks if the cause of the last reset was a power-on reset, in which case it triggers a warm reset. That causes the SPL to be running a second time.
    There's at least one thread on E2E where one of your colleagues stated that there are no plans to fix this issue in hardware via a new silicon revision, so this workaround probably needs to stay.
    Your colleagues might of course have newer information on this, in which case I'd be very interested in seeing any updated information.
    re Q2) this is the workaround in action
    re Q3) no, this has to stay, and the SPL will always boot twice, unless a project doesn't use the CPSW, in which case you could modify U-Boot to remove the workaround
    Dominic
  • Hi Dominc:
    THanks for the help.
    I will close this issue.
    BR Rio
  • Hi Dominic,
    Your response above is correct and accurate. Thank you very much for providing comments and helping the E2E forums.
