Other Parts Discussed in Thread: TVP5158
Hello.
Basing on VS2 demo I am trying to write simple "Hello World" OMX application, however I am unable to get it working
due to the following assertion.
CAPTUREAPP: VIP 0: VID DEC 0400 (0x58): 5158:0002:0000
CAPTUREAPP: Detect video in progress for inst 0 !!!
TVP5158: 0x58: Downloading patch ...
TVP5158: 0x58: Downloading patch ... DONE !!!
TVP5158: 0x58: 5158:0002:0143
CAPTUREAPP: Detected video at CH0 (720x288@720Hz, 50)!!!
Display Controller Path configured for 0!!
Display Driver Opened!!
Assertion failed, (nOutMsgCount > 0), file src/omx_vfcc_drvif.c, line 1852
At the end of this post I have attached source code of my test application.
I will be grateful if someone help me solve the problem.
Regards.
Piotr Zięcik.
Source code:
#define OMX_INIT_STRUCT(_s_, _name_) do { \
memset(&(_s_), 0x0, sizeof(_name_)); \
(_s_).nSize = sizeof(_name_); \
(_s_).nVersion.s.nVersionMajor = OMX_UTL_COMP_VERSION_MAJOR; \
(_s_).nVersion.s.nVersionMinor = OMX_UTL_COMP_VERSION_MINOR; \
(_s_).nVersion.s.nRevision = OMX_UTL_COMP_VERSION_REVISION;\
(_s_).nVersion.s.nStep = OMX_UTL_COMP_VERSION_STEP; \
} while (0)
#define OMX_TRACE(_function_) do { \
OMX_ERRORTYPE e = _function_; \
System_printf("%s = %i\n", #_function_, e); \
} while (0)
OMX_CALLBACKTYPE TestCallbacks;
OMX_HANDLETYPE VFCC;
OMX_HANDLETYPE CTRLTVP;
OMX_HANDLETYPE VFDC;
OMX_HANDLETYPE CTRLDC;
OMX_ERRORTYPE TestEventHandler(OMX_IN OMX_HANDLETYPE hComponent,
OMX_IN OMX_PTR pAppData,
OMX_IN OMX_EVENTTYPE eEvent,
OMX_IN OMX_U32 nData1,
OMX_IN OMX_U32 nData2,
OMX_IN OMX_PTR pEventData)
System_printf("%s(): ENTER.\n", __FUNCTION__);
System_printf("%s(): LEAVE.\n", __FUNCTION__);
return OMX_ErrorNone;
OMX_ERRORTYPE TestEmptyBufferDone(OMX_IN OMX_HANDLETYPE hComponent,
OMX_IN OMX_BUFFERHEADERTYPE *pBuffer)
OMX_ERRORTYPE TestFillBufferDone(OMX_OUT OMX_HANDLETYPE hComponent,
OMX_OUT OMX_PTR pAppData,
OMX_OUT OMX_BUFFERHEADERTYPE *pBuffer)
void test(void) {
OMX_PARAM_VFCC_HWPORT_ID VFCC_HwPortID;
OMX_PARAM_VFCC_HWPORT_PROPERTIES VFCC_HwPortProperties;
OMX_PARAM_VFDC_DRIVERINSTID VFDC_DriverInstID;
OMX_PARAM_VFDC_CREATEMOSAICLAYOUT VFDC_MosaicLayout;
OMX_CONFIG_VFDC_MOSAICLAYOUT_PORT2WINMAP VFDC_Port2WinMap;
OMX_PARAM_CTRL_VIDDECODER_INFO CTRLTVP_VidDecoderInfo;
OMX_PARAM_BUFFER_MEMORYTYPE BufferMemory;
OMX_PARAM_PORTDEFINITIONTYPE PortDefinition;
TestCallbacks.EventHandler = TestEventHandler;
TestCallbacks.EmptyBufferDone = TestEmptyBufferDone;
TestCallbacks.FillBufferDone = TestFillBufferDone;
* OMX.TI.VPSSM3.VFCC
System_printf("\n%s(): Creating OMX.TI.VPSSM3.VFCC component ...\n", __FUNCTION__);
OMX_TRACE(OMX_GetHandle(&VFCC, "OMX.TI.VPSSM3.VFCC", &VFCC, &TestCallbacks));
System_printf("%s(): Setting OMX_TI_IndexParamVFCCHwPortID ...\n", __FUNCTION__);
OMX_INIT_STRUCT(VFCC_HwPortID, OMX_PARAM_VFCC_HWPORT_ID);
VFCC_HwPortID.eHwPortId = OMX_VIDEO_CaptureHWPortVIP1_PORTA;
OMX_TRACE(OMX_SetParameter(VFCC, (OMX_INDEXTYPE)OMX_TI_IndexParamVFCCHwPortID, (OMX_PTR)&VFCC_HwPortID));
System_printf("%s(): Setting OMX_TI_IndexParamVFCCHwPortProperties ...\n", __FUNCTION__);
OMX_INIT_STRUCT(VFCC_HwPortProperties, OMX_PARAM_VFCC_HWPORT_PROPERTIES);
VFCC_HwPortProperties.eCaptMode = OMX_VIDEO_CaptureModeSC_NON_MUX;
VFCC_HwPortProperties.eVifMode = OMX_VIDEO_CaptureVifMode_08BIT;
VFCC_HwPortProperties.eInColorFormat = OMX_COLOR_FormatYCbYCr;
VFCC_HwPortProperties.eScanType = OMX_VIDEO_CaptureScanTypeInterlaced;
VFCC_HwPortProperties.nMaxWidth = 720;
VFCC_HwPortProperties.nMaxHeight = 576;
VFCC_HwPortProperties.nMaxChnlsPerHwPort = 1;
OMX_TRACE(OMX_SetParameter(VFCC, (OMX_INDEXTYPE)OMX_TI_IndexParamVFCCHwPortProperties, (OMX_PTR)&VFCC_HwPortProperties));
System_printf("%s(): Setting OMX_TI_IndexParamBuffMemType on the first port ...\n", __FUNCTION__);
OMX_INIT_STRUCT(BufferMemory, OMX_PARAM_BUFFER_MEMORYTYPE);
BufferMemory.nPortIndex = OMX_VFCC_OUTPUT_PORT_START_INDEX;
BufferMemory.eBufMemoryType = OMX_BUFFER_MEMORY_DEFAULT;
OMX_TRACE(OMX_SetParameter(VFCC, (OMX_INDEXTYPE)OMX_TI_IndexParamBuffMemType, (OMX_PTR)&BufferMemory));
System_printf("%s(): Setting OMX_IndexParamPortDefinition on the first port ...\n", __FUNCTION__);
OMX_INIT_STRUCT(PortDefinition, OMX_PARAM_PORTDEFINITIONTYPE);
PortDefinition.nPortIndex = OMX_VFCC_OUTPUT_PORT_START_INDEX;
OMX_TRACE(OMX_GetParameter(VFCC, (OMX_INDEXTYPE)OMX_IndexParamPortDefinition, (OMX_PTR)&PortDefinition));
PortDefinition.format.video.eCompressionFormat = OMX_VIDEO_CodingUnused;
PortDefinition.format.video.eColorFormat = OMX_COLOR_FormatYCbYCr;
PortDefinition.format.video.nFrameWidth = 720;
PortDefinition.format.video.nFrameHeight = 576 / 2;
PortDefinition.format.video.nStride = 2 * 720;
PortDefinition.nBufferCountActual = 4;
OMX_TRACE(OMX_SetParameter(VFCC, (OMX_INDEXTYPE)OMX_IndexParamPortDefinition, (OMX_PTR)&PortDefinition));
* OMX.TI.VPSSM3.CTRL.TVP
System_printf("\n%s(): Creating OMX.TI.VPSSM3.CTRL.TVP component ...\n", __FUNCTION__);
OMX_TRACE(OMX_GetHandle(&CTRLTVP, "OMX.TI.VPSSM3.CTRL.TVP", &CTRLTVP, &TestCallbacks));
OMX_TRACE(OMX_SetParameter(CTRLTVP, (OMX_INDEXTYPE)OMX_TI_IndexParamVFCCHwPortID, (OMX_PTR)&VFCC_HwPortID));
OMX_TRACE(OMX_SetParameter(CTRLTVP, (OMX_INDEXTYPE)OMX_TI_IndexParamVFCCHwPortProperties, (OMX_PTR)&VFCC_HwPortProperties));
System_printf("%s(): Setting OMX_TI_IndexParamCTRLVidDecInfo ...\n", __FUNCTION__);
OMX_INIT_STRUCT(CTRLTVP_VidDecoderInfo, OMX_PARAM_CTRL_VIDDECODER_INFO);
CTRLTVP_VidDecoderInfo.videoStandard = OMX_VIDEO_DECODER_STD_AUTO_DETECT;
CTRLTVP_VidDecoderInfo.videoDecoderId = OMX_VID_DEC_TVP5158_DRV;
CTRLTVP_VidDecoderInfo.videoSystemId = OMX_VIDEO_DECODER_VIDEO_SYSTEM_PAL;
OMX_TRACE(OMX_SetParameter(CTRLTVP, (OMX_INDEXTYPE)OMX_TI_IndexParamCTRLVidDecInfo, (OMX_PTR)&CTRLTVP_VidDecoderInfo));
* OMX.TI.VPSSM3.VFDC
System_printf("\n%s(): Creating OMX.TI.VPSSM3.VFDC component ...\n", __FUNCTION__);
OMX_TRACE(OMX_GetHandle(&VFDC, "OMX.TI.VPSSM3.VFDC", &VFDC, &TestCallbacks));
System_printf("%s(): Setting OMX_TI_IndexParamVFDCDriverInstId ...\n", __FUNCTION__);
OMX_INIT_STRUCT(VFDC_DriverInstID, OMX_PARAM_VFDC_DRIVERINSTID);
VFDC_DriverInstID.nDrvInstID = OMX_VIDEO_DISPLAY_ID_HD0;
VFDC_DriverInstID.eDispVencMode = OMX_DC_MODE_1080I_60;
OMX_TRACE(OMX_SetParameter(VFDC, (OMX_INDEXTYPE)OMX_TI_IndexParamVFDCDriverInstId, (OMX_PTR)&VFDC_DriverInstID));
System_printf("%s(): Setting OMX_TI_IndexParamVFDCCreateMosaicLayout ...\n", __FUNCTION__);
OMX_INIT_STRUCT(VFDC_MosaicLayout, OMX_PARAM_VFDC_CREATEMOSAICLAYOUT);
VFDC_MosaicLayout.nDisChannelNum = 0;
VFDC_MosaicLayout.nNumWindows = 1;
VFDC_MosaicLayout.sMosaicWinFmt[0].winStartX = 0;
VFDC_MosaicLayout.sMosaicWinFmt[0].winStartY = 0;
VFDC_MosaicLayout.sMosaicWinFmt[0].winWidth = 720;
VFDC_MosaicLayout.sMosaicWinFmt[0].winHeight = 576;
VFDC_MosaicLayout.sMosaicWinFmt[0].pitch[VFDC_YUV_SP_Y_ADDR_IDX] = 2 * 720;
VFDC_MosaicLayout.sMosaicWinFmt[0].pitch[VFDC_YUV_SP_CBCR_ADDR_IDX] = 2 * 720;
VFDC_MosaicLayout.sMosaicWinFmt[0].dataFormat = VFDC_DF_YUV422I_YUYV;
VFDC_MosaicLayout.sMosaicWinFmt[0].bpp = VFDC_BPP_BITS16;
OMX_TRACE(OMX_SetParameter(VFDC, (OMX_INDEXTYPE)OMX_TI_IndexParamVFDCCreateMosaicLayout, (OMX_PTR)&VFDC_MosaicLayout));
System_printf("%s(): Setting OMX_TI_IndexConfigVFDCMosaicPort2WinMap ...\n", __FUNCTION__);
OMX_INIT_STRUCT(VFDC_Port2WinMap, OMX_CONFIG_VFDC_MOSAICLAYOUT_PORT2WINMAP);
VFDC_Port2WinMap.numWindows = 1;
OMX_TRACE(OMX_SetConfig (VFDC, (OMX_INDEXTYPE)OMX_TI_IndexConfigVFDCMosaicPort2WinMap, (OMX_PTR)&VFDC_Port2WinMap));
System_printf("%s(): Setting OMX_TI_IndexParamBuffMemType on first port ...\n", __FUNCTION__);
BufferMemory.nPortIndex = OMX_VFDC_INPUT_PORT_START_INDEX;
OMX_TRACE(OMX_SetParameter (VFDC, (OMX_INDEXTYPE)OMX_TI_IndexParamBuffMemType, (OMX_PTR)&BufferMemory));
PortDefinition.nPortIndex = OMX_VFDC_INPUT_PORT_START_INDEX;
OMX_TRACE(OMX_GetParameter(VFDC, (OMX_INDEXTYPE)OMX_IndexParamPortDefinition, (OMX_PTR)&PortDefinition));
OMX_TRACE(OMX_SetParameter(VFDC, (OMX_INDEXTYPE)OMX_IndexParamPortDefinition, (OMX_PTR)&PortDefinition));
* OMX.TI.VPSSM3.CTRL.DC
System_printf("\n%s(): Creating OMX.TI.VPSSM3.CTRL.DC component ...\n", __FUNCTION__);
OMX_TRACE(OMX_GetHandle(&CTRLDC, "OMX.TI.VPSSM3.CTRL.DC", &CTRLDC, &TestCallbacks));
OMX_TRACE(OMX_SetParameter(CTRLDC, (OMX_INDEXTYPE)OMX_TI_IndexParamVFDCDriverInstId, (OMX_PTR)&VFDC_DriverInstID));
* VFCC -> VFDC
System_printf("\nCreating Tunnel VFCC => VFDC ...\n");
OMX_TRACE(OMX_SetupTunnel(VFCC, OMX_VFCC_OUTPUT_PORT_START_INDEX, VFDC, OMX_VFDC_INPUT_PORT_START_INDEX));
OMX_TRACE(OMX_SendCommand(VFCC, OMX_CommandPortEnable, OMX_VFCC_OUTPUT_PORT_START_INDEX, NULL));
OMX_TRACE(OMX_SendCommand(VFDC, OMX_CommandPortEnable, OMX_VFDC_INPUT_PORT_START_INDEX, NULL));
* Going to IDLE ...
System_printf("Going to IDLE State ...\n");
OMX_TRACE(OMX_SendCommand(CTRLTVP, OMX_CommandStateSet, OMX_StateIdle, NULL));
TIMM_OSAL_SleepTask(1000);
OMX_TRACE(OMX_SendCommand(VFCC, OMX_CommandStateSet, OMX_StateIdle, NULL));
OMX_TRACE(OMX_SendCommand(CTRLDC, OMX_CommandStateSet, OMX_StateIdle, NULL));
OMX_TRACE(OMX_SendCommand(VFDC, OMX_CommandStateSet, OMX_StateIdle, NULL));
* Going to EXECUTING ...
System_printf("Going to EXECUTING State ...\n");
OMX_TRACE(OMX_SendCommand(CTRLTVP, OMX_CommandStateSet, OMX_StateExecuting, NULL));
OMX_TRACE(OMX_SendCommand(VFCC, OMX_CommandStateSet, OMX_StateExecuting, NULL));
OMX_TRACE(OMX_SendCommand(CTRLDC, OMX_CommandStateSet, OMX_StateExecuting, NULL));
OMX_TRACE(OMX_SendCommand(VFDC, OMX_CommandStateSet, OMX_StateExecuting, NULL));
System_printf("Sleeping ...\n");
while (1)
Execution log:
test(): ENTER.
test(): Creating OMX.TI.VPSSM3.VFCC component ...
OMX_GetHandle(&VFCC, "OMX.TI.VPSSM3.VFCC", &VFCC, &TestCallbacks) = 0
test(): Setting OMX_TI_IndexParamVFCCHwPortID ...
OMX_SetParameter(VFCC, (OMX_INDEXTYPE)OMX_TI_IndexParamVFCCHwPortID, (OMX_PTR)&VFCC_HwPortID) = 0
test(): Setting OMX_TI_IndexParamVFCCHwPortProperties ...
OMX_SetParameter(VFCC, (OMX_INDEXTYPE)OMX_TI_IndexParamVFCCHwPortProperties, (OMX_PTR)&VFCC_HwPortProperties) = 0
test(): Setting OMX_TI_IndexParamBuffMemType on the first port ...
OMX_SetParameter(VFCC, (OMX_INDEXTYPE)OMX_TI_IndexParamBuffMemType, (OMX_PTR)&BufferMemory) = 0
test(): Setting OMX_IndexParamPortDefinition on the first port ...
OMX_GetParameter(VFCC, (OMX_INDEXTYPE)OMX_IndexParamPortDefinition, (OMX_PTR)&PortDefinition) = 0
OMX_SetParameter(VFCC, (OMX_INDEXTYPE)OMX_IndexParamPortDefinition, (OMX_PTR)&PortDefinition) = 0
test(): Creating OMX.TI.VPSSM3.CTRL.TVP component ...
OMX_GetHandle(&CTRLTVP, "OMX.TI.VPSSM3.CTRL.TVP", &CTRLTVP, &TestCallbacks) = 0
OMX_SetParameter(CTRLTVP, (OMX_INDEXTYPE)OMX_TI_IndexParamVFCCHwPortID, (OMX_PTR)&VFCC_HwPortID) = 0
OMX_SetParameter(CTRLTVP, (OMX_INDEXTYPE)OMX_TI_IndexParamVFCCHwPortProperties, (OMX_PTR)&VFCC_HwPortProperties) = 0
test(): Setting OMX_TI_IndexParamCTRLVidDecInfo ...
OMX_SetParameter(CTRLTVP, (OMX_INDEXTYPE)OMX_TI_IndexParamCTRLVidDecInfo, (OMX_PTR)&CTRLTVP_VidDecoderInfo) = 0
test(): Creating OMX.TI.VPSSM3.VFDC component ...
OMX_GetHandle(&VFDC, "OMX.TI.VPSSM3.VFDC", &VFDC, &TestCallbacks) = 0
test(): Setting OMX_TI_IndexParamVFDCDriverInstId ...
OMX_SetParameter(VFDC, (OMX_INDEXTYPE)OMX_TI_IndexParamVFDCDriverInstId, (OMX_PTR)&VFDC_DriverInstID) = 0
test(): Setting OMX_TI_IndexParamVFDCCreateMosaicLayout ...
OMX_SetParameter(VFDC, (OMX_INDEXTYPE)OMX_TI_IndexParamVFDCCreateMosaicLayout, (OMX_PTR)&VFDC_MosaicLayout) = 0
test(): Setting OMX_TI_IndexConfigVFDCMosaicPort2WinMap ...
OMX_SetConfig (VFDC, (OMX_INDEXTYPE)OMX_TI_IndexConfigVFDCMosaicPort2WinMap, (OMX_PTR)&VFDC_Port2WinMap) = 0
test(): Setting OMX_TI_IndexParamBuffMemType on first port ...
OMX_SetParameter (VFDC, (OMX_INDEXTYPE)OMX_TI_IndexParamBuffMemType, (OMX_PTR)&BufferMemory) = 0
OMX_GetParameter(VFDC, (OMX_INDEXTYPE)OMX_IndexParamPortDefinition, (OMX_PTR)&PortDefinition) = 0
OMX_SetParameter(VFDC, (OMX_INDEXTYPE)OMX_IndexParamPortDefinition, (OMX_PTR)&PortDefinition) = 0
test(): Creating OMX.TI.VPSSM3.CTRL.DC component ...
OMX_GetHandle(&CTRLDC, "OMX.TI.VPSSM3.CTRL.DC", &CTRLDC, &TestCallbacks) = 0
OMX_SetParameter(CTRLDC, (OMX_INDEXTYPE)OMX_TI_IndexParamVFDCDriverInstId, (OMX_PTR)&VFDC_DriverInstID) = 0
OMX_SetupTunnel(VFCC, OMX_VFCC_OUTPUT_PORT_START_INDEX, VFDC, OMX_VFDC_INPUT_PORT_START_INDEX) = 0
OMX_SendCommand(VFCC, OMX_CommandPortEnable, OMX_VFCC_OUTPUT_PORT_START_INDEX, NULL) = 0
TestEventHandler(): ENTER.
TestEventHandler(): LEAVE.
OMX_SendCommand(VFDC, OMX_CommandPortEnable, OMX_VFDC_INPUT_PORT_START_INDEX, NULL) = 0
OMX_SendCommand(CTRLTVP, OMX_CommandStateSet, OMX_StateIdle, NULL) = 0
OMX_SendCommand(VFCC, OMX_CommandStateSet, OMX_StateIdle, NULL) = 0
OMX_SendCommand(CTRLDC, OMX_CommandStateSet, OMX_StateIdle, NULL) = 0
OMX_SendCommand(VFDC, OMX_CommandStateSet, OMX_StateIdle, NULL) = 0
OMX_SendCommand(CTRLTVP, OMX_CommandStateSet, OMX_StateExecuting, NULL) = 0
OMX_SendCommand(VFCC, OMX_CommandStateSet, OMX_StateExecuting, NULL) = 0
OMX_SendCommand(CTRLDC, OMX_CommandStateSet, OMX_StateExecuting, NULL) = 0
OMX_SendCommand(VFDC, OMX_CommandStateSet, OMX_StateExecuting, NULL) = 0
Sleeping ...
