Part Number: DRA829V
Other Parts Discussed in Thread: DRA829
On TI DRA829 EVM(J721E SOM) reference design a Serial NOR flash is running on OSPI(MCU_OSPI0 Block) and used as a primary Bootload memory.
We were thinking of using Serial NOR Flash memory running on QSPI instead of using OSPI as the one placed on the Jacinto Main Board running QSPI.
Can you please confirm that the QSPI memory using the MCU_OSPI1 IF on the DRA829 block is OK to use as a primary bootloader?
Thanks!
Best Regards
Goran
Goran
