hello ;
Do i hve to load a separate gel for evm6424 or made changes in da one i hve ? , if i want to burn code in Nor Flash.
Like it was done in some of the previous board
thank u
hello ;
thank u
The EVM6424 GEL file out of the box configures the EMIF already, you should not have to modify or use another GEL file. For step by step how to burn the flash on the C6424 EVM check out this post.
hello,sorry to disturp you
i am using C6424 to design a system,everything is OK except bootloader.My system is designed by myself, not the EVM6424.In this situation, how could I burn the nor flash step by step?
Thank you sincerely.
Peter Xu
