Part Number: TMS320C6657
I know the datasheet gives some input clock requirement parameters for CORECLK P/N. For reference:
Table 5-6. Main PLL Controller/SRIO/HyperLink/PCIe Clock Input Timing Requirements
But I don't see the differential voltage swing requirements, etc.
Are these LVDS inputs? LJCB inputs? THat is what I understand from:
6.3 Power Supply to Peripheral I/O Mapping
CVDD -> LJCB -> CORECLK
If they are LJCB inputs, then the datasheet references this document:
https://www.ti.com/lit/an/sprabi2d/sprabi2d.pdf
3.4 Input Clock Termination Requirements (I don't see CORECLK listed here?)
7.4.4 LJCB Differential Clock Inputs
These sections indicate HCSL clock inputs are allowable with AC-coupling capacitors.
The LJCB inputs have internal biasing so no termination is needed on the DSP-side of the AC caps.
So, assuming AC-caps are needed and we don't need to worry about the exact bias voltages, then what is the required minimum / maximum differential voltage difference needed for the CLK signals?
