TDA4VM: TX RX error for Ethernet Debug
Part Number: TDA4VM
Hi TI expects,
RTOS version: SDK8.4
Linux version: Linux 8.4
When debugging CPSW2G port1  and KSZ9031 phy through RGMII interface, some errors may occur and I cannot ping between the PC and the board. Please give me some suggestions to make Ethernet work properly.
I also attach some files as below.
Regards.
    Can you please check the RGMII Tx and Rx delays set in the phy? I am suspecting that the Rx delay is not set on the phy side when it should be. can you confirm this.
    Tanmay
  • Hi Tanmay,
    Thanks for your replay.
    I have check my code and make sure that Tx and Rx delays had been set.
    Please help confirm whether the delays setting is normal.
    Are there any other configurations that need attention?
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.120 (zhangweizhen@motovis) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Mon Jan 9 08:36:20 UTC 2023
    [    0.000000] Machine model: Texas Instruments K3 J721E SoC
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000aeffffff]
    [    0.000000]   node   0: [mem 0x00000000af000000-0x00000000afffffff]
    [    0.000000]   node   0: [mem 0x00000000b0000000-0x00000000b7ffffff]
    [    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
    [    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000e5ffffff]
    [    0.000000]   node   0: [mem 0x00000000e6000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008a6ffffff]
    [    0.000000]   node   0: [mem 0x00000008a7000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] On node 0 totalpages: 1048576
    [    0.000000]   DMA zone: 8192 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 524288 pages, LIFO batch:63
    [    0.000000]   Normal zone: 8192 pages used for memmap
    [    0.000000]   Normal zone: 524288 pages, LIFO batch:63
    [    0.000000] cma: Reserved 400 MiB at 0x00000000e7000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112
    [    0.000000] pcpu-alloc: s50008 r8192 d31912 u90112 alloc=22*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=ccd1ca75-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x000000009a800000-0x000000009e800000] (64MB)
    [    0.000000] Memory: 1828008K/4194304K available (10880K kernel code, 1126K rwdata, 4188K rodata, 1792K init, 431K bss, 1956696K reserved, 409600K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8a7800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008a7030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a7040000
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008426] Console: colour dummy device 80x25
    [    0.012999] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023671] pid_max: default: 32768 minimum: 301
    [    0.028434] LSM: Security Framework initializing
    [    0.033203] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.040789] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.049698] rcu: Hierarchical SRCU implementation.
    [    0.054781] Platform MSI: msi-controller@1820000 domain created
    [    0.061080] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070387] EFI services will not be available.
    [    0.075143] smp: Bringing up secondary CPUs ...
    [    0.088478] Detected PIPT I-cache on CPU1
    [    0.088503] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.088515] GICv3: CPU1: using allocated LPI pending table @0x00000008a7050000
    [    0.088555] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.088613] smp: Brought up 1 node, 2 CPUs
    [    0.117961] SMP: Total of 2 processors activated.
    [    0.122767] CPU features: detected: 32-bit EL0 Support
    [    0.128022] CPU features: detected: CRC32 instructions
    [    0.142529] CPU: All CPU(s) started at EL2
    [    0.146731] alternatives: patching kernel code
    [    0.151862] devtmpfs: initialized
    [    0.161266] KASLR disabled due to lack of seed
    [    0.165937] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.175903] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.189047] pinctrl core: initialized pinctrl subsystem
    [    0.194751] DMI not present or invalid.
    [    0.199036] NET: Registered protocol family 16
    [    0.204343] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.211680] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.219748] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.228069] thermal_sys: Registered thermal governor 'step_wise'
    [    0.228072] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.234723] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.248364] ASID allocator initialised with 65536 entries
    [    0.270639] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.277498] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.284348] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.291195] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.298718] cryptd: max_cpu_qlen set to 1000
    [    0.304996] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.313818] vsys_3v3: supplied by evm_12v0
    [    0.318193] vsys_5v0: supplied by evm_12v0
    [    0.322511] vdd_mmc1: supplied by vsys_3v3
    [    0.327414] iommu: Default domain type: Translated
    [    0.332560] SCSI subsystem initialized
    [    0.336678] mc: Linux media interface: v0.10
    [    0.341050] videodev: Linux video capture interface: v2.00
    [    0.346682] pps_core: LinuxPPS API ver. 1 registered
    [    0.351752] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.361092] PTP clock support registered
    [    0.365110] EDAC MC: Ver: 3.0.0
    [    0.368930] FPGA manager framework
    [    0.372440] Advanced Linux Sound Architecture Driver Initialized.
    [    0.379092] clocksource: Switched to clocksource arch_sys_counter
    [    0.385433] VFS: Disk quotas dquot_6.6.0
    [    0.389469] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.399257] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
    [    0.405553] NET: Registered protocol family 2
    [    0.410367] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.418997] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.427766] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.435970] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
    [    0.443851] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.450681] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.457577] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.464999] NET: Registered protocol family 1
    [    0.469773] RPC: Registered named UNIX socket transport module.
    [    0.475828] RPC: Registered udp transport module.
    [    0.480632] RPC: Registered tcp transport module.
    [    0.485439] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.492025] PCI: CLS 0 bytes, default 64
    [    0.496484] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.507017] Initialise system trusted keyrings
    [    0.511656] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.520016] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.526260] NFS: Registering the id_resolver key type
    [    0.531495] Key type id_resolver registered
    [    0.535768] Key type id_legacy registered
    [    0.539893] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.546742] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.554399] 9p: Installing v9fs 9p2000 file system support
    [    0.579289] Key type asymmetric registered
    [    0.583475] Asymmetric key parser 'x509' registered
    [    0.588475] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.596035] io scheduler mq-deadline registered
    [    0.600660] io scheduler kyber registered
    [    0.606359] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.612556] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.621404] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.627689] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.635690] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.644002] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.652354] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.659533] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.668678] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.682010] brd: module loaded
    [    0.689043] loop: module loaded
    [    0.692714] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys'
    [    0.700648] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.10.120 #1
    [    0.706870] Hardware name: Texas Instruments K3 J721E SoC (DT)
    [    0.712826] Call trace:
    [    0.715334]  dump_backtrace+0x0/0x1a0
    [    0.719071]  show_stack+0x18/0x68
    [    0.722458]  dump_stack+0xd0/0x12c
    [    0.725930]  sysfs_warn_dup+0x60/0x80
    [    0.729665]  sysfs_create_dir_ns+0xe0/0xf8
    [    0.733847]  kobject_add_internal+0x98/0x288
    [    0.738204]  kobject_add+0x94/0x100
    [    0.741764]  device_add+0xe0/0x740
    [    0.745235]  platform_device_add+0x100/0x238
    [    0.749594]  platform_device_register_full+0xcc/0x150
    [    0.754755]  dma_buf_phys_init+0x6c/0x9c
    [    0.758756]  do_one_initcall+0x54/0x1b8
    [    0.762672]  kernel_init_freeable+0x220/0x2a0
    [    0.767122]  kernel_init+0x14/0x114
    [    0.770679]  ret_from_fork+0x10/0x34
    [    0.774338] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same name in the same directory.
    [    0.787564] megasas: 07.714.04.00-rc1
    [    0.793139] tun: Universal TUN/TAP device driver, 1.6
    [    0.798616] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.805023] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.811102] sky2: driver version 1.30
    [    0.815448] VFIO - User Level meta-driver version: 0.3
    [    0.821260] i2c /dev entries driver
    [    0.825550] sdhci: Secure Digital Host Controller Interface driver
    [    0.831873] sdhci: Copyright(c) Pierre Ossman
    [    0.836508] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.842856] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.849213] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.856456] optee: probing for conduit method.
    [    0.861022] optee: revision 3.17 (15a746d2)
    [    0.861172] optee: dynamic shared memory is enabled
    [    0.875984] optee: initialized driver
    [    0.881171] NET: Registered protocol family 17
    [    0.885801] 9pnet: Installing 9P2000 support
    [    0.890210] Key type dns_resolver registered
    [    0.894681] Loading compiled-in X.509 certificates
    [    0.905264] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.911612] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.919845] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
    [    0.986846] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    0.994766] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    1.000935] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.007093] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    1.013621] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    1.020461] pca953x 3-0020: using no AI
    [    1.047134] pca953x 3-0020: failed writing register
    [    1.052175] pca953x: probe of 3-0020 failed with error -121
    [    1.058244] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    1.065057] pca953x 3-0022: using AI
    [    1.068765] pca953x 3-0022: failed writing register
    [    1.073789] pca953x: probe of 3-0022 failed with error -121
    [    1.079529] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    1.089282] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz
    [    1.095711] pca953x 5-0020: supply vcc not found, using dummy regulator
    [    1.102537] pca953x 5-0020: using no AI
    [    1.127135] pca953x 5-0020: failed writing register
    [    1.132173] pca953x: probe of 5-0020 failed with error -121
    [    1.138269] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
    [    1.144437] omap_i2c 2040000.i2c: bus 6 rev0.12 at 100 kHz
    [    1.150470] omap_i2c 2050000.i2c: bus 7 rev0.12 at 100 kHz
    [    1.156971] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    1.166962] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    1.175790] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    1.185685] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.207375] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.215047] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.223327] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.231603] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.240490] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    1.248173] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    1.256449] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    1.264725] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.273562] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    1.281239] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    1.289514] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    1.297788] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.307129] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    1.316999] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.323758] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.332941] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    1.343105] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.349864] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.357921] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    1.367380] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 31, base_baud = 3000000) is a 8250
    [    1.376125] printk: console [ttyS2] enabled
    [    1.384561] printk: bootconsole [ns16550a0] disabled
    [    1.395073] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 32, base_baud = 3000000) is a 8250
    [    1.404060] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 33, base_baud = 3000000) is a 8250
    [    1.413758] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    1.424271] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    1.434425] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    1.444667] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    1.455972] scsi host0: ufshcd
    [    1.461369] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.507101] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.515879] davinci_mdio 46000f00.mdio: phy[7]: device 46000f00.mdio:07, driver Micrel KSZ9031 Gigabit PHY
    [    1.525567] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.539732] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    1.649618] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    1.655460] mmc0: CQHCI version 5.10
    [    1.666927] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    1.673831] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    1.680702] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    1.687551] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    1.694394] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    1.697715] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.704883] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.715966] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.724104] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.732190] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.741072] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    1.748619] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    1.756751] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    1.764906] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.773633] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    1.781178] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    1.789312] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    1.797395] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.806694] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.817533] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    1.829666] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.874833] cdns-ufshcd 4e84000.ufs: link startup failed 1
    [    1.880330] cdns-ufshcd 4e84000.ufs: UFS Host state=0
    [    1.885376] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.893023] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
    [    1.899452] mmc0: Command Queue Engine enabled
    [    1.899744] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
    [    1.903890] mmc0: new HS400 MMC card at address 0001
    [    1.910309] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
    [    1.919298] mmcblk0: mmc0:0001 BGUF4R 29.1 GiB
    [    1.922662] davinci_mdio 46000f00.mdio: phy[7]: device 46000f00.mdio:07, driver Micrel KSZ9031 Gigabit PHY
    [    1.926750] mmcblk0boot0: mmc0:0001 BGUF4R partition 1 31.9 MiB
    [    1.936275] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
    [    1.936278] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
    [    1.936281] cdns-ufshcd 4e84000.ufs: Clk gate=1
    [    1.936285] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
    [    1.942274] mmcblk0boot1: mmc0:0001 BGUF4R partition 2 31.9 MiB
    [    1.948857] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.955217] mmcblk0rpmb: mmc0:0001 BGUF4R partition 3 4.00 MiB, chardev (237:0)
    [    1.959771] cdns-ufshcd 4e84000.ufs: last intr at 1782622 us, last intr status=0x404
    [    2.001553] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
    [    2.002381] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    2.009037] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
    [    2.016132] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    2.024493] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
    [    2.031691] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    2.032208] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    2.037692] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
    [    2.045445] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    2.052712] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
    [    2.065529] mmc1: CQHCI version 5.10
    [    2.070611] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
    [    2.070616] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
    [    2.070637] host_regs: 00000000: 1587031f 00000000 00000210 00000000
    [    2.080757] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    2.092431] host_regs: 00000010: 00000000 00000000 00000000 00000000
    [    2.098791] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    2.106240] host_regs: 00000020: 00000000 00000470 00000000 00000000
    [    2.112723] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    2.120622] host_regs: 00000030: 00000008 00000001 00000000 00000000
    [    2.120624] host_regs: 00000040: 00000000 00000000 00000000 00000000
    [    2.120626] host_regs: 00000050: 00000000 00000000 00000000 00000000
    [    2.126974] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.135029] host_regs: 00000060: 00000000 00000000 00000000 00000000
    [    2.141840] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.147701] host_regs: 00000070: 00000000 00000000 00000000 00000000
    [    2.147703] host_regs: 00000080: 00000000 00000000 00000000 00000000
    [    2.147706] host_regs: 00000090: 00000000 00000000 00000000 00000000
    [    2.147712] cdns-ufshcd 4e84000.ufs: No record of pa_err
    [    2.154067] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.162304] cdns-ufshcd 4e84000.ufs: No record of dl_err
    [    2.168642] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.176101] cdns-ufshcd 4e84000.ufs: No record of nl_err
    [    2.182435] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.188773] cdns-ufshcd 4e84000.ufs: No record of tl_err
    [    2.195479] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    2.200402] cdns-ufshcd 4e84000.ufs: No record of dme_err
    [    2.200405] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
    [    2.200408] cdns-ufshcd 4e84000.ufs: No record of fatal_err
    [    2.208492] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    2.213778] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1783747 us
    [    2.221846] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    2.227141] cdns-ufshcd 4e84000.ufs: No record of resume_fail
    [    2.235388] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.240684] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
    [    2.257379] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    2.259690] cdns-ufshcd 4e84000.ufs: No record of dev_reset
    [    2.259693] cdns-ufshcd 4e84000.ufs: No record of host_reset
    [    2.265265] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    2.273317] cdns-ufshcd 4e84000.ufs: No record of task_abort
    [    2.280446] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    2.348772] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.357392] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.364883] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.372961] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.381038] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.389628] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    2.397120] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    2.405202] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    2.413280] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.421888] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    2.429236] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    2.437627] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    2.444957] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    2.452263] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    2.459576] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    2.468053] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    2.475578] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    2.483080] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    2.491169] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    2.499256] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.508054] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.515553] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.523639] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.531725] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.540374] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    2.547868] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    2.555951] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    2.564036] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.587109] ALSA device list:
    [    2.590068]   No soundcards found.
    [    3.123934] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    3.132296] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    3.139888] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    3.147977] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    3.156069] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.164515] Waiting for root device PARTUUID=ccd1ca75-02...
    [    3.164818] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    3.177572] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    3.185667] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    3.193812] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.202535] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    3.210086] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    3.218176] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    3.226298] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.261290] mmc1: new high speed SDHC card at address aaaa
    [    3.267237] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
    [    3.276018]  mmcblk1: p1 p2
    [    3.279894] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    3.287387] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    3.295465] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    3.303547] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.312188] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    3.319689] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    3.327769] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    3.335847] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.344447] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    3.351940] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    3.360017] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    3.368098] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.463074] EXT4-fs (mmcblk1p2): warning: mounting fs with errors, running e2fsck is recommended
    [    3.476079] EXT4-fs (mmcblk1p2): recovery complete
    [    3.481864] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    3.489979] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    3.505947] devtmpfs: mounted
    [    3.509990] Freeing unused kernel memory: 1792K
    [    3.514634] Run /sbin/init as init process
    [    3.518720]   with arguments:
    [    3.518722]     /sbin/init
    [    3.518724]   with environment:
    [    3.518726]     HOME=/
    [    3.518728]     TERM=linux
    [    3.857644] systemd[1]: System time before build time, advancing clock.
    [    3.900238] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    3.921990] systemd[1]: Detected architecture arm64.
    [    3.961750] systemd[1]: Set hostname to <j7-evm>.
    [    4.178190] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
    [    4.187094] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
    [    4.216450] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock \xe2\x86\x92 /run/docker.sock; please update the unit file accordingly.
    [    4.292369] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.299150] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    4.311490] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    4.321605] systemd[1]: Created slice system-getty.slice.
    [    4.343191] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.350617] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    4.371188] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.378460] systemd[1]: Created slice User and Session Slice.
    [    4.399338] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    4.423224] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    4.447220] systemd[1]: Reached target Paths.
    [    4.463161] systemd[1]: Reached target Remote File Systems.
    [    4.483143] systemd[1]: Reached target Slices.
    [    4.499153] systemd[1]: Reached target Swap.
    [    4.525313] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    4.547211] systemd[1]: Reached target RPC Port Mapper.
    [    4.571681] systemd[1]: Listening on Process Core Dump Socket.
    [    4.595361] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    4.629965] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    4.638404] systemd[1]: Listening on Journal Socket (/dev/log).
    [    4.659507] systemd[1]: Listening on Journal Socket.
    [    4.679512] systemd[1]: Listening on Network Service Netlink Socket.
    [    4.703390] systemd[1]: Listening on udev Control Socket.
    [    4.723308] systemd[1]: Listening on udev Kernel Socket.
    [    4.745867] systemd[1]: Mounting Huge Pages File System...
    [    4.769740] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.797689] systemd[1]: Mounting Kernel Debug File System...
    [    4.824349] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    4.843377] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
    [    4.857224] systemd[1]: Starting Start psplash boot splash screen...
    [    4.881925] systemd[1]: Starting RPC Bind...
    [    4.899360] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    4.911837] systemd[1]: Starting Journal Service...
    [    4.939682] systemd[1]: Starting Load Kernel Modules...
    [    4.958301] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.986122] systemd[1]: Starting udev Coldplug all Devices...
    [    5.005098] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [    5.014366] systemd[1]: Started RPC Bind.
    [    5.032640] systemd[1]: Started Journal Service.
    [    5.253544] systemd-journald[167]: Received client request to flush runtime journal.
    [    5.395756] urandom_read_iter: 45 callbacks suppressed
    [    5.395761] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.423189] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.436312] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    6.405894] urandom_read_iter: 23 callbacks suppressed
    [    6.405899] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.423218] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.864427] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.642868] urandom_read_iter: 5 callbacks suppressed
    [    7.642875] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.671143] random: crng init done
    [    7.674546] random: 1 urandom warning(s) missed due to ratelimiting
    [    8.929496] EXT4-fs error (device mmcblk1p2): ext4_lookup:1708: inode #654081: comm sed: deleted inode referenced: 654181
    [    8.968419] EXT4-fs error (device mmcblk1p2): ext4_mb_generate_buddy:802: group 85, block bitmap and bg descriptor inconsistent: 32765 vs 32766 free clusters
    [    8.990636] EXT4-fs error (device mmcblk1p2): ext4_validate_block_bitmap:390: comm hostname-update: bg 83: bad block bitmap checksum
    [    9.731130] !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!ksz9031_config_init
    [    9.744367] ksz9031_config_init interface is [11]
    [    9.755130] ksz9031_config_init ksz9031_config_rgmii_delay
    [    9.760716] !!!!!!!!!!!!!!!!!ksz9031_config_rgmii_delay interface is [11]
    [    9.771140] ksz9031_config_rgmii_delay PHY_INTERFACE_MODE_RGMII_RXID
    [    9.787497] ksz9031_config_init 1
    [    9.805711] EXT4-fs error (device mmcblk1p2): ext4_lookup:1708: inode #654081: comm weston: deleted inode referenced: 654181
    [    9.805859] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:07] driver [Micrel KSZ9031 Gigabit PHY] (irq=POLL)
    [    9.839139] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [   10.355611] EXT4-fs error (device mmcblk1p2): ext4_validate_inode_bitmap:105: comm snmpd: Corrupt inode bitmap - block_group = 34, inode_bitmap = 1048594
    [   10.377970] EXT4-fs error (device mmcblk1p2): ext4_validate_inode_bitmap:105: comm snmpd: Corrupt inode bitmap - block_group = 35, inode_bitmap = 1048595
    [   10.401492] EXT4-fs error (device mmcblk1p2): ext4_validate_inode_bitmap:105: comm snmpd: Corrupt inode bitmap - block_group = 36, inode_bitmap = 1048596
    [   10.425733] EXT4-fs error (device mmcblk1p2): ext4_validate_inode_bitmap:105: comm snmpd: Corrupt inode bitmap - block_group = 37, inode_bitmap = 1048597
    [   10.449114] EXT4-fs error (device mmcblk1p2): ext4_validate_inode_bitmap:105: comm snmpd: Corrupt inode bitmap - block_group = 38, inode_bitmap = 1048598
    [   10.469148] EXT4-fs error (device mmcblk1p2): ext4_validate_inode_bitmap:105: comm snmpd: Corrupt inode bitmap - block_group = 39, inode_bitmap = 1048599
    [   13.948420] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [   32.542444] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [   32.559366] platform 41000000.r5f: configured R5F for IPC-only mode
    [   32.565940] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [   32.575450] remoteproc remoteproc0: 41000000.r5f is available
    [   32.581254] remoteproc remoteproc0: attaching to 41000000.r5f
    [   32.587182] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [   32.593885]  remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [   32.603744] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   32.609803]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [   32.616069] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   32.622051] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [   32.623585] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   32.633077] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [   32.640542] remoteproc remoteproc0: remote processor 41000000.r5f is now attached
    [   32.654260] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   32.667929] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   32.681846] platform 5c00000.r5f: configured R5F for IPC-only mode
    [   32.689055] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [   32.696846] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [   32.706814] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [   32.717182] remoteproc remoteproc1: 5c00000.r5f is available
    [   32.722908] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [   32.723773] remoteproc remoteproc1: attaching to 5c00000.r5f
    [   32.731038] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   32.737317] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [   32.751673]  remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [   32.751682] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [   32.767521] virtio_rpmsg_bus virtio1: rpmsg host is online
    [   32.769445] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [   32.782517] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [   32.783189] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [   32.802242] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   32.812251]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [   32.820009] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   32.827504] remoteproc remoteproc1: remote processor 5c00000.r5f is now attached
    [   32.834950] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   32.836209] platform 5d00000.r5f: configured R5F for IPC-only mode
    [   32.843053] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   32.849974] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [   32.857299] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   32.866471] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [   32.876586] remoteproc remoteproc2: 5d00000.r5f is available
    [   32.882824] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [   32.887818] remoteproc remoteproc2: attaching to 5d00000.r5f
    [   32.896358] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [   32.909815] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   32.910517] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [   32.924837] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [   32.925536]  remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [   32.941789] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [   32.949999] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [   32.951495] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   32.962705] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   32.971879] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   32.980035] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [   32.987496] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   32.995878]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [   33.003591] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   33.017431] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   33.023099] remoteproc remoteproc2: remote processor 5d00000.r5f is now attached
    [   33.034360] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [   33.046361] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [   33.052322] platform 5e00000.r5f: configured R5F for IPC-only mode
    [   33.057735] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [   33.064727] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [   33.079132] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   33.081000] remoteproc remoteproc3: 5e00000.r5f is available
    [   33.093307] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [   33.093365] remoteproc remoteproc3: attaching to 5e00000.r5f
    [   33.101684] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [   33.106617] platform 5e00000.r5f: R5F core initialized in IPC-only mode
    [   33.115291] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [   33.121190]  remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [   33.129595] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   33.139031] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   33.152539]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [   33.162502] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
    [   33.165383] remoteproc remoteproc3: remote processor 5e00000.r5f is now attached
    [   33.177256] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   33.184913] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   33.185802] platform 5f00000.r5f: configured R5F for remoteproc mode
    [   33.193014] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   33.201133] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [   33.207437] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   33.216622] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [   33.226367] remoteproc remoteproc4: 5f00000.r5f is available
    [   33.232959] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [   33.240788] remoteproc remoteproc4: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
    [   33.246767] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [   33.256134] remoteproc remoteproc4: powering up 5f00000.r5f
    [   33.268776] remoteproc remoteproc4: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
    [   33.277882] remoteproc remoteproc4: request_firmware failed: -2
    [   33.278413] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   33.293052] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [   33.300869] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [   33.314583] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [   33.325477] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   33.335040] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   33.342623] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   33.350735] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   33.351436] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [   33.358843] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   33.369832] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
    [   33.383657] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [   33.384548] remoteproc remoteproc5: 4d80800000.dsp is available
    [   33.391855] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [   33.397146] remoteproc remoteproc5: attaching to 4d80800000.dsp
    [   33.405664] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [   33.411908] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
    [   33.419721] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   33.426061]  remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [   33.445677] virtio_rpmsg_bus virtio4: rpmsg host is online
    [   33.451242] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [   33.451954]  remoteproc5#vdev0buffer: registered virtio4 (type 7)
    [   33.464925] remoteproc remoteproc5: remote processor 4d80800000.dsp is now attached
    [   33.472731] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [   33.477035] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [   33.481582] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [   33.491169] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
    [   33.497975] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [   33.505426] remoteproc remoteproc6: 4d81800000.dsp is available
    [   33.513767] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   33.519432] remoteproc remoteproc6: attaching to 4d81800000.dsp
    [   33.533077] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   33.533235] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
    [   33.541257] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   33.547359]  remoteproc6#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [   33.555728] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   33.565195] virtio_rpmsg_bus virtio5: rpmsg host is online
    [   33.573469] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   33.578406] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [   33.587572]  remoteproc6#vdev0buffer: registered virtio5 (type 7)
    [   33.600232] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [   33.608424] remoteproc remoteproc6: remote processor 4d81800000.dsp is now attached
    [   33.616895] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [   33.625747] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [   33.627318] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
    [   33.634637] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   33.645613] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [   33.658321] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [   33.659403] remoteproc remoteproc7: 64800000.dsp is available
    [   33.666558] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [   33.671615] remoteproc remoteproc7: attaching to 64800000.dsp
    [   33.680138] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [   33.685413] remoteproc remoteproc7: unsupported resource 65538
    [   33.693920] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   33.699368] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [   33.714157]  remoteproc7#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
    [   33.714254] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   33.731519] virtio_rpmsg_bus virtio6: rpmsg host is online
    [   33.732035] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   33.737057] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd
    [   33.745733] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   33.755144]  remoteproc7#vdev0buffer: registered virtio6 (type 7)
    [   33.760708] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   33.771174] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x15
    [   33.775599] remoteproc remoteproc7: remote processor 64800000.dsp is now attached
    [   33.790001] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xe
    [   33.790072] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [   33.803244] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
    [   33.805575] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [   33.820177] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [   33.831173] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   33.831277] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
    [   33.852448] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [   33.855402] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
    [   33.874279] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [   33.887312] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
    [   33.887836] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [   33.907159] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   33.907345] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
    [   33.922716] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   33.930841] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
    [   33.932904] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   33.938245] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
    [   33.951163] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   33.962689] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
    [   33.967166] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   33.984036] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [   33.995255] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [   34.008139] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [   34.018958] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   34.029249] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [   34.038356] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [   34.047385] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [   34.060925] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   34.070257] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   34.077765] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   34.085858] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   34.094003] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   34.197237] pvrsrvkm: loading out-of-tree module taints kernel.
    [   34.212615] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power domains
    [   34.223636] PVR_K:  973: Read BVNC 22.104.208.318 from HW device registers
    [   34.230544] PVR_K:  973: RGX Device registered with BVNC 22.104.208.318
    [   34.237578] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
    [   34.246024] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [   34.254709] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [   34.263740] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [   34.275705] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   34.284605] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [   34.292170] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [   34.300266] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [   34.308350] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   34.317415] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   34.324921] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   34.333014] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   34.341100] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [  266.231112] device eth0 entered promiscuous mode
    [  316.471095] EXT4-fs (mmcblk1p2): error count since last fsck: 888
    [  316.477187] EXT4-fs (mmcblk1p2): initial error at time 1661850399: ext4_lookup:1708: inode 654081
    [  316.486044] EXT4-fs (mmcblk1p2): last error at time 1661850400: ext4_free_inode:360
    Regards.
  • Hi Tanmay,
    The block diagram is as follows.
    The logic analyzer captures the data of tx rx, compares the data under normal conditions under qnx, and finds that the data is still quite different.
    ethernet normal under qnx
    ethernet abnormal under linux
    Regards.
  • Hi Tanmay,
    Do I need to set delay in phy side(KSZ9031)? Because I have set delay in switch side(SJA1105).
    Regards.
  • Hi Tanmay,
    Is there any progress on this question?
    I eagerly await your feedback.
    Regards.
    Regarding the delays, the MAC interface in CPSW has internal Tx-delay configured. So you only need to ensure that the rx delay is configured in the phy. But you are using switch as well. Can you clarify the following things for me :
    • How is the CPSW mac connected to switch, is it mac2mac?
    • If its mac2mac, how is this connection handled.
    • What is the delay configuration in switch?
    • the wireshark traces screen shot you have attached with the question do not have any replies from the pc? where were these traces captured? pc or evm?
    Tanmay
  • Hi Tanmay Patil,
           Sorry for delay.
      • replay:Yes. It is mac2mac.
      • replay:The block diagram is as below.
      • replay:I do the dellay config in my code as below.The same configuration is normal under qnx
      •     uint32_t txc1_delay = 0;
           	uint32_t rxc1_delay = 0;
            uint32_t txc4_delay = 0x1f;
           	uint32_t rxc4_delay = 0x1f;
        	uint32_t val_1 = 0x0000;
        	uint32_t val_4 = 0x0000;
        	/* PORT1 : KSZ9031*/
        	/* Set Bypass mode and power down the delay line */
        	SJA1105_spiRead(&val_1, 0x100811, 1);
            val_1 |= 0x0303;
        	appLogWaitMsecs(1);
        	SJA1105_spiWrite(&val_1, 0x100811, 1);
            /* power on the delay line */
        	val_1 &= ~0x0101;
        	val_1 &= ~(uint32_t)((0x1f << 2));
        	val_1 &= ~(uint32_t)((0x1f << 10));
        	val_1 |= (uint32_t)((txc1_delay << 2));
        	val_1 |= (uint32_t)((rxc1_delay << 10));
        	appLogWaitMsecs(1);
            /* disable bypass mode after delay line is powered up */
            val_1 &= ~0x0303;
        	/* PORT4 : SOC*/
        	SJA1105_spiRead(&val_4, 0x100814, 1);
            val_4 |= 0x0303;
        	appLogWaitMsecs(1);
        	SJA1105_spiWrite(&val_4, 0x100814, 1);
        	val_4 &= ~0x0101;
        	val_4 &= ~(uint32_t)((0x1f << 2));
        	val_4 &= ~(uint32_t)((0x1f << 10));
        	val_4 |= (uint32_t)((txc4_delay << 2));
        	val_4 |= (uint32_t)((rxc4_delay << 10));
        	appLogWaitMsecs(1);
            val_4 &= ~0x0303;
      • replay:Yes.It can not receive any replies. I capture the traces on evm.
    I also post the ethtool traces, please help me check whether it is normal.
    root@j7-evm:~# ethtool -i eth0
    driver: am65-cpsw-nuss
    version: 5.10.120
    firmware-version:
    expansion-rom-version:
    bus-info: 46000000.ethernet
    supports-statistics: yes
    supports-test: no
    supports-eeprom-access: no
    supports-register-dump: yes
    supports-priv-flags: yes
    root@j7-evm:~# ethtool  eth0
    Settings for eth0:
            Supported ports: [ TP    MII ]
            Supported link modes:   10baseT/Half 10baseT/Full
                                    100baseT/Half 100baseT/Full
                                    1000baseT/Full
            Supported pause frame use: Symmetric
            Supports auto-negotiation: Yes
            Supported FEC modes: Not reported
            Advertised link modes:  10baseT/Half 10baseT/Full
                                    1000baseT/Full
            Advertised pause frame use: Symmetric
            Advertised auto-negotiation: Yes
            Advertised FEC modes: Not reported
            Link partner advertised link modes:  10baseT/Half 10baseT/Full
                                                 1000baseT/Full
            Link partner advertised pause frame use: Symmetric Receive-only
            Link partner advertised auto-negotiation: Yes
            Link partner advertised FEC modes: Not reported
            Speed: 1000Mb/s
            Duplex: Full
            Auto-negotiation: on
            master-slave cfg: preferred slave
            master-slave status: slave
            Port: Twisted Pair
            PHYAD: 7
            Transceiver: external
            MDI-X: Unknown
            Supports Wake-on: d
            Wake-on: d
            Current message level: 0x000020f7 (8439)
                                   drv probe link ifdown ifup rx_err tx_err hw
            Link detected: yes
    root@j7-evm:~# ethtool -k eth0
    Features for eth0:
    rx-checksumming: on
    tx-checksumming: on
            tx-checksum-ipv4: off [fixed]
            tx-checksum-ip-generic: on
            tx-checksum-ipv6: off [fixed]
            tx-checksum-fcoe-crc: off [fixed]
            tx-checksum-sctp: off [fixed]
    scatter-gather: on
            tx-scatter-gather: on
            tx-scatter-gather-fraglist: off [fixed]
    tcp-segmentation-offload: off
            tx-tcp-segmentation: off [fixed]
            tx-tcp-ecn-segmentation: off [fixed]
            tx-tcp-mangleid-segmentation: off [fixed]
            tx-tcp6-segmentation: off [fixed]
    generic-segmentation-offload: on
    generic-receive-offload: on
    large-receive-offload: off [fixed]
    rx-vlan-offload: off [fixed]
    tx-vlan-offload: off [fixed]
    ntuple-filters: off [fixed]
    receive-hashing: off [fixed]
    highdma: off [fixed]
    rx-vlan-filter: on [fixed]
    vlan-challenged: off [fixed]
    tx-lockless: off [fixed]
    netns-local: off [fixed]
    tx-gso-robust: off [fixed]
    tx-fcoe-segmentation: off [fixed]
    tx-gre-segmentation: off [fixed]
    tx-gre-csum-segmentation: off [fixed]
    tx-ipxip4-segmentation: off [fixed]
    tx-ipxip6-segmentation: off [fixed]
    tx-udp_tnl-segmentation: off [fixed]
    tx-udp_tnl-csum-segmentation: off [fixed]
    tx-gso-partial: off [fixed]
    tx-tunnel-remcsum-segmentation: off [fixed]
    tx-sctp-segmentation: off [fixed]
    tx-esp-segmentation: off [fixed]
    tx-udp-segmentation: off [fixed]
    tx-gso-list: off [fixed]
    fcoe-mtu: off [fixed]
    tx-nocache-copy: off
    loopback: off [fixed]
    rx-fcs: off [fixed]
    rx-all: off [fixed]
    tx-vlan-stag-hw-insert: off [fixed]
    rx-vlan-stag-hw-parse: off [fixed]
    rx-vlan-stag-filter: off [fixed]
    l2-fwd-offload: off [fixed]
    hw-tc-offload: on
    esp-hw-offload: off [fixed]
    esp-tx-csum-hw-offload: off [fixed]
    rx-udp_tunnel-port-offload: off [fixed]
    tls-hw-tx-offload: off [fixed]
    tls-hw-rx-offload: off [fixed]
    rx-gro-hw: off [fixed]
    tls-hw-record: off [fixed]
    rx-gro-list: off
    macsec-hw-offload: off [fixed]
    hsr-tag-ins-offload: off [fixed]
    hsr-tag-rm-offload: off [fixed]
    hsr-fwd-offload: off [fixed]
    hsr-dup-offload: off [fixed]
    Regards.
    Do you see anything on PC when you do a transfer? Does PC receive anything?
    Can you please check if the switch is receiving any packets or not? So its essentially two communications : cpsw to switch and switch to phy. The switch must also have statistics right? Can you check where exactly the break is present?
    What is the address of the phy on the mdio bus? Can you confirm that you have updated the address in the device-tree node for the phy?
    Otherwise there seems to be no issues in the ethtool traces.
    Tanmay
