AM6442: R5 SPI DMA Troubleshooting
Part Number: AM6442
MCSPI project: It is freeRTOS R5 application will communicate to other sensor through SPI interface.
IPC RP Message Linux Echo : It is example application which communicates to A53 (mcu_plus_sdk_am64x_08_04_00_17\examples\drivers\ipc\ipc_rpmsg_echo_linux)
Customer have integrated the IPC RP Message Linux Echo into the SPI project. Customer has the UART1 for IPC communication and for the MCSPI project  have 2 SPI channels which is using the DMA mode operation(with UDMA PKTDMA_0). After integrating the MCSPI project and echo Linux, No (IPC RPMSG ECHO)messages were showing on the USART1 console.
After changed the mode of operation from DMA to Interrupt for the SPI channels, they able to get the logs in UART1 console.
Do they need to change any pin configuration or any settings in sys config for DMA to work for MCSPI?
MCSPI settings with DMA mode(not working):
MCSPI settings with Interrupt mode(working):
IPC UART1 settings:
Console log:
  • Hello Venkat,
    It does not look like the hardware team finished looking into the issue with certain SD card brands, so it is entirely possible that the SD card issues observed on AM64-SK would also be present on AM64-SKB.
    Lawrence mentioned that you tested different SD card brands & models, and saw different behavior with different SD cards. Can I get you to share what you tested, and what you observed? I'll take that information back to the hardware team when I ask them to take another look.
    Nick
