Part Number: AM5728
Other Parts Discussed in Thread: TMDSIDK572
Hi Team,
can you help to answer the three question below:
- If Linux(-RT) runs on the MPU (2x ARM Cortex-A15), how does it interact with an industrial communication protocol (such as EtherCAT, Profinet IO, etc.) that is implemented using the PRU-ICSS?
- What productive software is available for industrial communication protocols that can be implemented using the PRU-ICSS? How is licensing for this software handled? How is the software for the industrial communication protocols loaded into the PRU-ICSS when Linux(-RT) runs on the MPU?
- If Linux(-RT) runs on the MPU (2x ARM Cortex-A15), is it possible to run TI-RTOS simultaneously on the DSP (2x C66x) or IPU (2x Cortex-M4) in order to achieve hard real-time behavior for industrial communication protocols?
adding 3 more question January 18:
- The current actual state of support for industrial protocols for the "TI AM57x" processor is described on the "PRU-ICSS Industrial Software for Sitara
Processors" website (https://www.ti.com/tool/PRU-ICSS-INDUSTRIAL-SW) as supporting all industrial protocols for the "TI AM57x" processor. However, in the document "Industrial Communication Protocols Supported on Sitara
Processors and MCUs (SPRACH6D)" (https://www.ti.com/lit/an/sprach6d/sprach6d.pdf?ts=1673963348396&ref_url=https%253A%252F%252Fwww.ti.com%252Ftool%252FPROCESSOR-SDK-AM57X) it is stated that TI only supports industrial protocols for the "TI AM64x" and "TI AM243x" processors. For the "TI AM57x" processor, it is referred to a "3rd party model" or a "Processors Third Party Search Tool" (https://www.ti.com/tool/PROCESSORS-3P-SEARCH). According to the table of the "Arm®-based MPU, Arm-based MCU and DSP third-party search tools", only "OPC UA" is supported for the "TI AM57x" processor!
- On the "PRU-ICSS Industrial Software for Sitara
Processors" website (https://www.ti.com/tool/PRU-ICSS-INDUSTRIAL-SW), software packages can be downloaded for each industrial protocol.For the "Profinet Slave" protocol (PRU-ICSS-PROFINET-SLAVE), the "AM5728" processor is also listed in the "Supported products & hardware" list. Can this software package now be used for the implementation of "Profinet Slave"?
- What industrial protocols can be implemented and tested on the "AM572x Industrial Development Kit (IDK)" (TMDSIDK572)?
Jan
