Part Number: TDA2P-ACD
Hello
Does the ISP of TDA2P support X3C? The video format of X3C is 12b-combined HDR4.
Is there any limitation on the use case of TDA2P+X3C?
Hello
Hi Zhao,
Can you please provide some more information on 12bit combined HDR4 format? What is the output data? What kind of processing is required for this format?
Brijesh
Hello Brijesh
HDR4 uses HCG LCG SPD VS to active 24-bit linear image data. And combined the 24-bit raw data to 12-bit combined raw data.
Hello Guangyue Zhao,
ok understood, What kind of ISP processing that you are looking for this format?
Adding Gang Hua to help on further question related to ISP.
Brijesh
Hello Brijesh
Thank you for your support.
Hello Gang
Is there any additional information needed for you to solve this task?
Hi Guangyue,
TDA2P ISP was designed and used with up to 20-bit WDR sensors.
Going to 24-bit may be stretching beyond its capability.
I would not recommend doing that unless you have very limited requirements on output image quality.
