SK-AM62: console was not accessible after using /etc/init.d/network script.
Part Number: SK-AM62
I am seeing ethernet driver errors, mmc driver errors and console was not accessible for inputs after executing network start scripts.
Issue was observed on am62xx SK board.
/etc/init.d/networking stop
Deconfiguring network interfaces... ifdown: interface usb0 not configured
ifdown: interface usb1 not configured
ifdown: interface wlan0 not configured
ifdown: interface wlan1 not configured
done.
root@Nodef4844cfc97d4:~#
root@Nodef4844cfc97d4:~# /etc/init.d/networking start
done.
Configuring network interfaces... net.ipv6.conf.lo.hop_limit = 128
net.ipv6.conf.default.keep_addr_on_down = 1
net.ipv6.conf.lo.autoconf = 0
net.ipv6.conf.all.forwarding = 1
net.ipv6.conf.default.forwarding = 1
net.ipv6.conf.all.keep_addr_on_down = 1
net.ipv6.conf.lo.keep_addr_on_down = 1
net.ipv4.tcp_syncookies = 1
net.ipv4.conf.all.log_martians = 1
net.ipv4.conf.all.accept_redirects = 0
net.ipv4.conf.all.accept_source_route = 0
net.ipv4.icmp_echo_ignore_broadcasts = 1
net.ipv4.ip_forward = 0
net.ipv4.conf.default.accept_source_route = 0
net.ipv4.conf.default.accept_redirects = 0
net.ipv4.conf.default.send_redirects = 0
net.ipv4.conf.all.send_redirects = 0
kernel.randomize_va_space = 2
[   61.443239] am65-cpsw-nuss 8000000.ethernet: down msc_sl f0000000 tmo 0
[   61.456216] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[   62.464374] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_set_event_map+0x40/0x50)
[   62.474586] ti-sci 44043000.system-controller: Mbox send fail -110
[   62.480793] genirq: Failed to request resources for 8000000.ethernet (irq 214) on irqchip MSI-INTA
[   62.489801] am65-cpsw-nuss 8000000.ethernet: failure requesting rx irq 214, -110
[   62.912380] omap_i2c 20000000.i2c: controller timed out
[   63.520369] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: k3_ringacc_ring_free+0x134/0x230)
[   63.530387] ti-sci 44043000.system-controller: RM_RA:Mbox config send fail -110
[   63.537716] ti-pktdma 485c0000.dma-controller: TISCI ring free fail (-110) ring_idx 118
[   63.545933] am65-cpsw-nuss 8000000.ethernet: init_rx_chns failed
[   63.936373] omap_i2c 20000000.i2c: controller timed out
[   63.941628] tps6598x 0-003f: tps6598x_handle_interrupt_status: failed to read events
[   64.576372] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: k3_ringacc_ring_free+0x134/0x230)
[   64.586397] ti-sci 44043000.system-controller: RM_RA:Mbox config send fail -110
[   64.593735] ti-pktdma 485c0000.dma-controller: TISCI ring free fail (-110) ring_idx 19
[   65.636372] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_free_event_map+0x40/0x50)
[   65.646688] ti-sci 44043000.system-controller: Mbox send fail -110
[   73.760349] mmc1: Timeout waiting for hardware interrupt.
[   73.765774] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   73.772236] mmc1: sdhci: Sys addr:  0x00000158 | Version:  0x00001004
[   73.778671] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[   73.785126] mmc1: sdhci: Argument:  0x00ea6c50 | Trn mode: 0x0000002b
[   73.791560] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
[   73.798002] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[   73.804435] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
[   73.810876] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000003
[   73.817306] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[   73.823747] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001
[   73.830178] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[   73.836617] mmc1: sdhci: Cmd:       0x0000193a | Max curr: 0x00000000
[   73.843047] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x0076b27f
[   73.849487] mmc1: sdhci: Resp[2]:   0x325b5900 | Resp[3]:  0x00000900
[   73.855917] mmc1: sdhci: Host ctl2: 0x00000000
[   73.860364] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000080faa3f8
[   73.867488] mmc1: sdhci: ============================================
[   84.000348] mmc1: Timeout waiting for hardware interrupt.
[   84.005770] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   84.012228] mmc1: sdhci: Sys addr:  0x00000158 | Version:  0x00001004
[   84.018664] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[   84.025116] mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000023
[   84.031551] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
[   84.037992] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[   84.044422] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
[   84.050862] mmc1: sdhci: Timeout:   0x0000000e | Int stat: 0x00018002
[   84.057293] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[   84.063734] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001
[   84.070165] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[   84.076607] mmc1: sdhci: Cmd:       0x00000c1b | Max curr: 0x00000000
[   84.083037] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x0076b27f
[   84.089477] mmc1: sdhci: Resp[2]:   0x325b5900 | Resp[3]:  0x00000900
[   84.095907] mmc1: sdhci: Host ctl2: 0x00000000
[   84.100354] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000080faa3f8
[   84.107478] mmc1: sdhci: ============================================
[   94.240350] mmc1: Timeout waiting for hardware cmd interrupt.
[   94.246117] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   94.252575] mmc1: sdhci: Sys addr:  0x00000158 | Version:  0x00001004
[   94.259011] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[   94.265458] mmc1: sdhci: Argument:  0xaaaa0000 | Trn mode: 0x00000023
[   94.271891] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
[   94.278333] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[   94.284763] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
[   94.291203] mmc1: sdhci: Timeout:   0x0000000e | Int stat: 0x00018001
[   94.297634] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[   94.304075] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001
[   94.310506] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[   94.316947] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[   94.323379] mmc1: sdhci: Resp[0]:   0x00400900 | Resp[1]:  0x0076b27f
[   94.329818] mmc1: sdhci: Resp[2]:   0x325b5900 | Resp[3]:  0x00000900
[   94.336250] mmc1: sdhci: Host ctl2: 0x00000000
[   94.340698] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000080faa3f8
[   94.347822] mmc1: sdhci: ============================================
  • Hi Siva,
    The network error and the mmc1 dump seem to be irrelevant, but the console not accessible issue might be related to the mmc1 issue.
    What SD card do you use? Can you please take a picture of it?
    Which Processor SDK version do you use?
