SK-AM62: remoteproc kernel module crashed at boot up.
Part Number: SK-AM62
Other Parts Discussed in Thread: AM625,
I am trying to boot up AM62xx-SK board with SD card image.
At boot up i am seeing remoteproc kernel module crashed & udevd getting segmentation fault.
[ 3.392348] remoteproc remoteproc1: 78000000.r5f is available
[ 3.392445] remoteproc remoteproc1: attaching to 78000000.r5f
[ 3.392476] Unable to handle kernel paging request at virtual address ffff800014ffffff
[ 3.438200] printk: console [ttyS2]: printing thread stopped
[ 3.438488] Mem abort info:
[ 3.446947] ESR = 0x96000006
[ 3.450073] EC = 0x25: DABT (current EL), IL = 32 bits
[ 3.455438] SET = 0, FnV = 0
[ 3.458639] EA = 0, S1PTW = 0
[ 3.462543] Data abort info:
[ 3.465523] ISV = 0, ISS = 0x00000006
[ 3.469418] CM = 0, WnR = 0
[ 3.472398] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000082f77000
[ 3.479204] [ffff800014ffffff] pgd=00000000fffff003, p4d=00000000fffff003, pud=00000000ffffe003, pmd=0000000000000000
[ 3.490128] Internal error: Oops: 96000006 [#1] PREEMPT_RT SMP
[ 3.495979] Modules linked in: ti_k3_r5_remoteproc(+) dwc3_am62 virtio_rpmsg_bus ti_k3_m4_remoteproc j721e_csi2rx tps6598x rti_wdt typec videobuf2_dma_contig videobuf2_memops roles snd_soc_tlv320aic3x videobuf2_v4l2 sa2ul videobuf2_common sha512_generic authenc cdns_dphy pruss optee_rng rng_core
[ 3.522142] CPU: 2 PID: 309 Comm: udevd Not tainted 5.10.145-rt74-ga1ffa192dc #1
[ 3.529536] Hardware name: Texas Instruments AM625 SK (DT)
[ 3.535016] pstate: 00000005 (nzcv daif -PAN -UAO -TCO BTYPE=--)
[ 3.541011] pc : rproc_handle_resources.constprop.0+0x94/0x168
[ 3.546849] lr : rproc_boot+0x450/0x678
[ 3.550696] sp : ffff800013943780
[ 3.552482] pvrsrvkm: loading out-of-tree module taints kernel.
[ 3.554009] x29: ffff800013943780 x28: ffff000001ce7568
[ 3.565226] x27: ffff000001ce7000 x26: ffffffffffffffff
[ 3.570697] x25: ffff800015000000 x24: ffff800010eac600
[ 3.576014] x23: ffff000001ce7038 x22: 0000000000000000
[ 3.581329] x21: ffff800011272128 x20: ffff000001ce7000
[ 3.586629] x19: 0000000000000000 x18: 0000000000000002
[ 3.591929] x17: 0000000000000000 x16: 0000000000000000
[ 3.597228] x15: ffff000003e56900 x14: ffffffffffffffff
[ 3.602528] x13: ffffffffffffffff x12: ffffffffffffffff
[ 3.607828] x11: ffffffffffffffff x10: ffffffffffffffff
[ 3.613128] x9 : ffffffffffffffff x8 : ffffffffffffffff
[ 3.618427] x7 : ffffffffffffffff x6 : ffff000005d17100
[ 3.623726] x5 : ffff00007fbbbb38 x4 : 0000000000000000
[ 3.629025] x3 : 00000000000000fd x2 : 00000000ffffffff
[ 3.634325] x1 : ffff800015000003 x0 : ffff800015000000
[ 3.639626] Call trace:
[ 3.642064] rproc_handle_resources.constprop.0+0x94/0x168
[ 3.647545] rproc_boot+0x450/0x678
[ 3.651027] rproc_add+0x88/0x168
[ 3.654333] k3_r5_probe+0x72c/0xdb0 [ti_k3_r5_remoteproc]
[ 3.659821] platform_drv_probe+0x54/0xa8
[ 3.663822] really_probe+0xec/0x3e0
[ 3.667392] driver_probe_device+0x58/0xb8
[ 3.671478] device_driver_attach+0x74/0x80
[ 3.675652] __driver_attach+0x64/0xf8
[ 3.679391] bus_for_each_dev+0x70/0xc8
[ 3.683218] driver_attach+0x24/0x30
[ 3.686784] bus_add_driver+0x150/0x210
[ 3.690610] driver_register+0x64/0x120
[ 3.694437] __platform_driver_register+0x48/0x58
[ 3.699129] k3_r5_rproc_driver_init+0x20/0x1000 [ti_k3_r5_remoteproc]
[ 3.705648] do_one_initcall+0x54/0x1b8
[ 3.709477] do_init_module+0x44/0x1f0
[ 3.713217] load_module+0x2168/0x2668
[ 3.716956] __do_sys_finit_module+0xb8/0x100
[ 3.721302] __arm64_sys_finit_module+0x20/0x30
[ 3.725821] el0_svc_common.constprop.0+0x78/0x1c8
[ 3.730604] do_el0_svc+0x24/0x90
[ 3.733911] el0_svc+0x14/0x20
[ 3.736960] el0_sync_handler+0xb0/0xb8
[ 3.740784] el0_sync+0x180/0x1c0
[ 3.744096] Code: 128002b3 91172021 97ffeb61 1400002e (b87a6b20)
[ 3.750179] ---[ end trace 0000000000000002 ]--
Please find complete boot up Log available in attachment.
U-Boot SPL 2021.01-g3983bffabc (Dec 02 2022 - 00:58:20 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0008 '8.5.3--v08.05.03 (Chill Capybar')
SPL initial stack usage: 13424 bytes
Trying to boot from MMC2
Loading Environment from MMC... *** Warning - No MMC card found, using default environment
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.7(release):v2.7.0-359-g1309c6c805-dirty
NOTICE:  BL31: Built : 11:40:36, Sep  8 2022
I/TC:
I/TC: OP-TEE version: 3.19.0-15-gd6c5d0037-dev (gcc version 9.5.0 (GCC)) #1 Thu Oct 27 08:43:50 UTC 2022 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.5.3--v08.05.03 (Chill Capybar')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
U-Boot 2021.01-g3983bffabc (Dec 02 2022 - 00:58:20 +0000)
SoC:   AM62X SR1.0 GP
Model: Texas Instruments AM625 SK
EEPROM not available at 0x50, trying to read at 0x51
Board: AM62-SKEVM rev E3
DRAM:  2 GiB
MMC:   mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2
Loading Environment from MMC... OK
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   eth0: ethernet@8000000port@1
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
Failed to load 'uEnv.txt'
19497472 bytes read in 414 ms (44.9 MiB/s)
50106 bytes read in 5 ms (9.6 MiB/s)
   Loading Device Tree to 000000008fef0000, end 000000008fffffff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.10.145-rt74-ga1ffa192dc (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 9.5.0, GNU ld (GNU Binutils) 2.34.0.20200910) #1 SMP PREEMPT_RT Tue Oct 25 16:16:49 UTC 2022
[    0.000000] Machine model: Texas Instruments AM625 SK
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
[    0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 13 MiB
[    0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009d900000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9d900000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 13 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@9da00000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009c7fffff]
[    0.000000]   node   0: [mem 0x000000009c800000-0x000000009e6fffff]
[    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
[    0.000000]   node   0: [mem 0x000000009e780000-0x000000009fffffff]
[    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000] On node 0 totalpages: 524288
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 524288 pages, LIFO batch:63
[    0.000000] cma: Reserved 512 MiB at 0x00000000dd000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 18 pages/cpu s35008 r8192 d30528 u73728
[    0.000000] pcpu-alloc: s35008 r8192 d30528 u73728 alloc=18*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=0007f360-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 1455548K/2097152K available (11200K kernel code, 1248K rwdata, 4552K rodata, 1920K init, 476K bss, 117316K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000] rcu:     RCU priority boosting: priority 1 delay 500 ms.
[    0.000000] rcu:     RCU_SOFTIRQ processing moved to rcuc kthreads.
[    0.000000]  No expedited grace period (rcu_normal_after_boot).
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000080040000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000000] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008514] Console: colour dummy device 80x25
[    0.013111] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023791] pid_max: default: 32768 minimum: 301
[    0.028605] LSM: Security Framework initializing
[    0.033420] AppArmor: AppArmor initialized
[    0.037655] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.045238] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.055151] rcu: Hierarchical SRCU implementation.
[    0.060595] Platform MSI: msi-controller@1820000 domain created
[    0.066959] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.076246] EFI services will not be available.
[    0.081214] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[    0.094671] Detected VIPT I-cache on CPU1
[    0.098807] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.105845] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000
[    0.113280] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
[    0.128867] Detected VIPT I-cache on CPU2
[    0.132995] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[    0.140031] GICv3: CPU2: using allocated LPI pending table @0x0000000080070000
[    0.147452] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
[    0.162953] Detected VIPT I-cache on CPU3
[    0.167074] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[    0.174106] GICv3: CPU3: using allocated LPI pending table @0x0000000080080000
[    0.181523] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.188288] smp: Brought up 1 node, 4 CPUs
[    0.192492] SMP: Total of 4 processors activated.
[    0.197310] CPU features: detected: 32-bit EL0 Support
[    0.202572] CPU features: detected: CRC32 instructions
[    0.215398] CPU: All CPU(s) started at EL2
[    0.219606] alternatives: patching kernel code
[    0.225394] devtmpfs: initialized
[    0.236794] KASLR disabled due to lack of seed
[    0.241572] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.251553] futex hash table entries: 1024 (order: 5, 131072 bytes, linear)
[    0.273259] pinctrl core: initialized pinctrl subsystem
[    0.279260] DMI not present or invalid.
[    0.283912] NET: Registered protocol family 16
[    0.290523] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.297903] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.306006] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.314241] audit: initializing netlink subsys (disabled)
[    0.320042] audit: type=2000 audit(0.252:1): state=initialized audit_enabled=0 res=1
[    0.320618] thermal_sys: Registered thermal governor 'step_wise'
[    0.321234] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.341146] ASID allocator initialised with 65536 entries
[    0.372468] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.379381] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.386273] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.393136] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.527012] cryptd: max_cpu_qlen set to 1000
[    0.556114] alg: No test for fips(ansi_cprng) (fips_ansi_cprng)
[    0.575893] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[    0.585236] vcc_5v0: supplied by vmain_pd
[    0.589784] vcc_3v3_sys: supplied by vmain_pd
[    0.594892] vcc_1v8: supplied by vcc_3v3_sys
[    0.600321] iommu: Default domain type: Translated
[    0.605739] SCSI subsystem initialized
[    0.610030] mc: Linux media interface: v0.10
[    0.614443] videodev: Linux video capture interface: v2.00
[    0.620135] pps_core: LinuxPPS API ver. 1 registered
[    0.625210] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.634559] PTP clock support registered
[    0.638618] EDAC MC: Ver: 3.0.0
[    0.642563] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[    0.649800] FPGA manager framework
[    0.653399] Advanced Linux Sound Architecture Driver Initialized.
[    0.660626] clocksource: Switched to clocksource arch_sys_counter
[    0.667110] VFS: Disk quotas dquot_6.6.0
[    0.671186] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.678874] AppArmor: AppArmor Filesystem Enabled
[    0.689862] NET: Registered protocol family 2
[    0.694637] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.703498] tcp_listen_portaddr_hash hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.712372] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.720635] TCP bind hash table entries: 16384 (order: 7, 917504 bytes, linear)
[    0.729174] TCP: Hash tables configured (established 16384 bind 16384)
[    0.736191] UDP hash table entries: 1024 (order: 5, 131072 bytes, linear)
[    0.743321] UDP-Lite hash table entries: 1024 (order: 5, 131072 bytes, linear)
[    0.751156] NET: Registered protocol family 1
[    0.756199] RPC: Registered named UNIX socket transport module.
[    0.762294] RPC: Registered udp transport module.
[    0.767122] RPC: Registered tcp transport module.
[    0.771931] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.778526] PCI: CLS 0 bytes, default 64
[    0.783425] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.810662] Initialise system trusted keyrings
[    0.815473] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    0.827255] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.834180] NFS: Registering the id_resolver key type
[    0.839445] Key type id_resolver registered
[    0.843732] Key type id_legacy registered
[    0.847929] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.854811] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.862662] 9p: Installing v9fs 9p2000 file system support
[    0.902782] NET: Registered protocol family 38
[    0.907380] Key type asymmetric registered
[    0.911579] Asymmetric key parser 'x509' registered
[    0.916632] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.924216] io scheduler mq-deadline registered
[    0.928860] io scheduler kyber registered
[    0.936369] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    0.942795] pinctrl-single f4000.pinctrl: 171 pins, size 684
[    0.956851] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.978292] brd: module loaded
[    0.990795] loop: module loaded
[    0.994967] megasas: 07.714.04.00-rc1
[    1.002917] tun: Universal TUN/TAP device driver, 1.6
[    1.008378] CAN device driver interface
[    1.012854] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    1.019274] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.025385] sky2: driver version 1.30
[    1.030170] VFIO - User Level meta-driver version: 0.3
[    1.036602] i2c /dev entries driver
[    1.041335] sdhci: Secure Digital Host Controller Interface driver
[    1.047685] sdhci: Copyright(c) Pierre Ossman
[    1.052469] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.059631] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.067511] optee: probing for conduit method.
[    1.072146] optee: revision 3.19 (d6c5d003)
[    1.072456] optee: dynamic shared memory is enabled
[    1.082145] optee: initialized driver
[    1.087982] NET: Registered protocol family 17
[    1.092640] can: controller area network core
[    1.097208] NET: Registered protocol family 29
[    1.101913] 9pnet: Installing 9P2000 support
[    1.106378] Key type dns_resolver registered
[    1.111122] printk: bootconsole [ns16550a0]: printing thread started
[    1.111173] Loading compiled-in X.509 certificates
[    1.112175] alg: No test for pkcs1pad(rsa,sha1) (pkcs1pad(rsa-generic,sha1))
[    1.114804] Loaded X.509 cert 'Build time autogenerated kernel key: f59541a6734110248ac18e762441a26bd9534f18'
[    1.116282] AppArmor: AppArmor sha1 policy hashing enabled
[    1.126684] ti-sci 44043000.system-controller: ti,ctx-memory-region is required for suspend but not provided.
[    1.126701] ti-sci 44043000.system-controller: ti_sci_init_suspend failed, mem suspend will be non-functional.
[    1.126708] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.5.3--v08.05.03 (Chill Capybar')
[    1.162581] davinci-mcasp 2b10000.mcasp: IRQ common not found
[    1.167363] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[ H▒▒1.169622] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[    1.170241] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[    1.193720] printk: console [ttyS2]: printing thread started
[    1.170455] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    1.193738] printk: console [ttyS2] enabled
[    1.193742] printk: bootconsole [ns16550a0] disabled
[    1.216559] printk: bootconsole [ns16550a0]: printing thread stopped
[    1.221947] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[    1.222005] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[    1.222011] Creating 7 MTD partitions on "fc40000.spi.0":
[    1.222017] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    1.223487] 0x000000080000-0x000000280000 : "ospi.tispl"
[    1.224837] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    1.226157] 0x000000680000-0x0000006c0000 : "ospi.env"
[    1.227384] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[    1.228601] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[    1.229981] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[    1.239122] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[    1.276645] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.278957] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[    1.278973] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
[    1.279084] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000002
[    1.279284] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    1.279291] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[    1.280180] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
[    1.284131] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
[    1.284191] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:07 UTC (7)
[    1.387323] mmc0: CQHCI version 5.10
[    1.388900] davinci-mcasp 2b10000.mcasp: IRQ common not found
[    1.403965] reg-fixed-voltage regulator-6: Failed to register regulator: -517
[    1.404955] pca953x 1-0022: supply vcc not found, using dummy regulator
[    1.405112] pca953x 1-0022: using AI
[    1.432286] sii902x 1-003b: supply iovcc not found, using dummy regulator
[    1.432434] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
[    1.435535] i2c i2c-1: Added multiplexed i2c bus 2
[    1.438161] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
[    1.438701] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    1.439787] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[    1.443066] vdd_mmc1: supplied by vcc_3v3_sys
[    1.445046] wlan_lten: supplied by vcc_3v3_sys
[    1.446026] wlan_en: supplied by wlan_lten
[    1.448336] mmc2: CQHCI version 5.10
[    1.448478] mmc1: CQHCI version 5.10
[    1.449029] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    1.456247] ALSA device list:
[    1.456261]   No soundcards found.
[    1.490233] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
[    1.496125] sdhci-am654 fa20000.mmc: card claims to support voltages below defined range
[    1.500254] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[    1.501131] Waiting for root device PARTUUID=0007f360-02...
[    1.509119] mmc2: new high speed SDIO card at address 0001
[    1.525039] mmc0: Command Queue Engine enabled
[    1.525065] mmc0: new HS200 MMC card at address 0001
[    1.525841] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[    1.526061] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[    1.526258] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[    1.526476] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
[    1.527854]  mmcblk0: p1 p2
[    1.540166] mmc1: new high speed SDHC card at address aaaa
[    1.541010] mmcblk1: mmc1:aaaa SB16G 14.8 GiB
[    1.543645]  mmcblk1: p1 p2
[    1.970813] EXT4-fs (mmcblk1p2): recovery complete
[    1.972042] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.972143] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    1.979708] devtmpfs: mounted
[    1.981206] Freeing unused kernel memory: 1920K
[    1.981332] Run /sbin/init as init process
INIT: version 2.96 booting
Framebuffer /dev/fb0 not detected
Boot splashscreen disabled
Starting board_start
sysctl: cannot stat /proc/sys/net/ipv6/conf/default/hop_limit: No such file or directory
sysctl: cannot stat /proc/sys/net/ipv6/conf/all/hop_limit: No such file or directory
Starting udev
[    2.887560] udevd[292]: starting version 3.2.9
[    2.929305] random: udevd: uninitialized urandom read (16 bytes read)
[    2.930171] random: udevd: uninitialized urandom read (16 bytes read)
[    2.930229] random: udevd: uninitialized urandom read (16 bytes read)
[    2.959938] udevd[293]: starting eudev-3.2.9
[    3.097272] random: crng init done
[    3.097298] random: 4 urandom warning(s) missed due to ratelimiting
[    3.285559] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000
[    3.286112] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
[    3.286244] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
[    3.290532] remoteproc remoteproc0: 5000000.m4fss is available
[    3.294146] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
[    3.294178] remoteproc remoteproc0: powering up 5000000.m4fss
[    3.294229] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
[    3.294238] remoteproc remoteproc0: request_firmware failed: -2
[    3.361823] am65-cpsw-nuss 8000000.ethernet: down msc_sl e0000000 tmo 0
[    3.391329] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    3.391521] platform 78000000.r5f: configured R5F for IPC-only mode
[    3.391662] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9d900000
[    3.750179] ---[ end trace 0000000000000002 ]---
[    3.759675] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[    3.773625] udevd[293]: worker [309] terminated by signal 11 (Segmentation fault)
[    3.773660] udevd[293]: worker [309] failed while handling '/devices/platform/bus@f0000/bus@f0000:bus@b00000/bus@f0000:bus@b00000:r5fss@78000000'
[    3.777403] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[    3.807713] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[    3.820192] PVR_K:  311: Read BVNC 33.15.11.3 from HW device registers
[    3.826899] PVR_K:  311: RGX Device registered with BVNC 33.15.11.3
[    3.832130] am65-cpsw-nuss 8000000.ethernet: down msc_sl e0000000 tmo 0
[    3.860363] [drm] Initialized pvr 1.15.6133109 20170530 for fd00000.gpu on minor 1
[    3.899169] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
[    3.908788] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
[    4.871821] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    4.887505] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    4.939837] device eth0 entered promiscuous mode
[    4.972164] remoteproc remoteproc2: 30074000.pru is available
[    4.979416] remoteproc remoteproc3: 30078000.pru is available
[    4.987879] device eth1 entered promiscuous mode
[    5.073677] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22
[    5.127187] tps6598x 0-003f: Unable to find the interrupt, switching to polling
[    5.147177] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    5.154348] device lo entered promiscuous mode
[    5.199910] usbcore: registered new interface driver usbfs
[    5.205665] usbcore: registered new interface driver hub
[    5.211352] usbcore: registered new device driver usb
[    5.252989] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[    5.258583] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
[    5.266436] xhci-hcd xhci-hcd.3.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000002000010010
[    5.276093] xhci-hcd xhci-hcd.3.auto: irq 471, io mem 0x31100000
[    5.282563] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    5.290841] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.298067] usb usb1: Product: xHCI Host Controller
[    5.302940] usb usb1: Manufacturer: Linux 5.10.145-rt74-ga1ffa192dc xhci-hcd
[    5.309979] usb usb1: SerialNumber: xhci-hcd.3.auto
[    5.315542] hub 1-0:1.0: USB hub found
[    5.319372] hub 1-0:1.0: 1 port detected
[    5.325155] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[    5.330697] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2
[    5.338374] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[    5.341688] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    5.345031] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    5.359701] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    5.368010] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.375258] usb usb2: Product: xHCI Host Controller
[    5.380178] usb usb2: Manufacturer: Linux 5.10.145-rt74-ga1ffa192dc xhci-hcd
[    5.387250] usb usb2: SerialNumber: xhci-hcd.3.auto
[    5.392953] hub 2-0:1.0: USB hub found
[    5.396810] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
[    5.532677] wl18xx_driver wl18xx.2.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
[    5.543480] wl18xx_driver wl18xx.2.auto: Direct firmware load for ti-connectivity/wl18xx-conf.bin failed with error -2
[    5.554227] wlcore: ERROR could not get configuration binary ti-connectivity/wl18xx-conf.bin: -2
[    5.563103] wlcore: WARNING falling back to default config
[    5.604228] usbcore: registered new interface driver cdc_ether
Error: Write start address failed, return code -121
sysctl: cannot stat /proc/sys/net/ipv6/conf/default/autoconf: No such file or directory
sysctl: cannot stat /proc/sys/net/ipv6/conf/all/forwarding: No such file or directory
sysctl: cannot stat /proc/sys/net/ipv6/conf/default/forwarding: No such file or directory
sysctl: cannot stat /proc/sys/net/ipv6/conf/all/mc_forwarding: No such file or directory
sysctl: cannot stat /proc/sys/net/ipv6/conf/wlan1/forwarding: No such file or directory
Directory /lib/modules/5.10.145-rt74-ga1ffa192dc/extra exists.
[    5.865626] NET: Registered protocol family 10
[    5.871701] Segment Routing with IPv6
[    5.925281] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[    5.936288] wlcore: loaded
starting /home/root/web/webserver with 5 client
OK
[    6.341123] wl18xx_driver wl18xx.2.auto: Direct firmware load for ti-connectivity/wl18xx-fw-4.bin failed with error -2
[    6.351911] wlcore: ERROR could not get firmware ti-connectivity/wl18xx-fw-4.bin: -2
[    6.709155] wl18xx_driver wl18xx.2.auto: Direct firmware load for ti-connectivity/wl18xx-fw-4.bin failed with error -2
[    6.719977] wlcore: ERROR could not get firmware ti-connectivity/wl18xx-fw-4.bin: -2
[    6.885550] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[    6.914146] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
modprobe: FATAL: Module nf_nat_ipv6 not found in directory /lib/modules/5.10.145-rt74-ga1ffa192dc
[    7.077229] wl18xx_driver wl18xx.2.auto: Direct firmware load for ti-connectivity/wl18xx-fw-4.bin failed with error -2
[    7.088224] wlcore: ERROR could not get firmware ti-connectivity/wl18xx-fw-4.bin: -2
[    7.096388] wlcore: ERROR firmware boot failed despite 3 retries
[    7.102879] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Thu Jan 19 15:20:39 UTC 2023
ALSA: Restoring mixer settings...
Configuring network interfaces... [    7.845046] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
ifdown: interface usb0 not configured
ifdown: interface usb1 not configured
ifdown: interface wlan0 not configured
ifdown: interface wlan1 not configured
net.ipv6.conf.lo.hop_limit = 128
net.ipv6.conf.default.keep_addr_on_down = 1
net.ipv6.conf.lo.autoconf = 0
net.ipv6.conf.all.forwarding = 1
net.ipv6.conf.default.forwarding = 1
net.ipv6.conf.all.keep_addr_on_down = 1
net.ipv6.conf.lo.keep_addr_on_down = 1
net.ipv4.tcp_syncookies = 1
net.ipv4.conf.all.log_martians = 1
net.ipv4.conf.all.accept_redirects = 0
net.ipv4.conf.all.accept_source_route = 0
net.ipv4.icmp_echo_ignore_broadcasts = 1
net.ipv4.ip_forward = 0
net.ipv4.conf.default.accept_source_route = 0
net.ipv4.conf.default.accept_redirects = 0
net.ipv4.conf.default.send_redirects = 0
net.ipv4.conf.all.send_redirects = 0
kernel.randomize_va_space = 2
[    8.100260] am65-cpsw-nuss 8000000.ethernet: down msc_sl f0000000 tmo 0
[    8.111597] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[    9.124645] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_set_event_map+0x40/0x50)
[    9.134864] ti-sci 44043000.system-controller: Mbox send fail -110
[    9.141041] genirq: Failed to request resources for 8000000.ethernet (irq 214) on irqchip MSI-INTA
[    9.150034] am65-cpsw-nuss 8000000.ethernet: failure requesting rx irq 214, -110
[    9.380638] omap_i2c 20000000.i2c: controller timed out
[   10.180638] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: k3_ringacc_ring_free+0x134/0x230)
[   10.190656] ti-sci 44043000.system-controller: RM_RA:Mbox config send fail -110
[   10.197958] ti-pktdma 485c0000.dma-controller: TISCI ring free fail (-110) ring_idx 118
[   10.206115] am65-cpsw-nuss 8000000.ethernet: init_rx_chns failed
[   10.436645] omap_i2c 20000000.i2c: controller timed out
[   10.441901] tps6598x 0-003f: tps6598x_handle_interrupt_status: failed to read events
[   11.236640] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: k3_ringacc_ring_free+0x134/0x230)
[   11.246659] ti-sci 44043000.system-controller: RM_RA:Mbox config send fail -110
[   11.253960] ti-pktdma 485c0000.dma-controller: TISCI ring free fail (-110) ring_idx 19
[   12.292641] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_free_event_map+0x40/0x50)
[   12.302948] ti-sci 44043000.system-controller: Mbox send fail -110
[   12.318192] am65-cpsw-nuss 8000000.ethernet: down msc_sl f0000000 tmo 0
[   12.708648] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x28)
[   12.718621] ti-sci 44043000.system-controller: Mbox send fail -110
[   23.332624] mmc1: Timeout waiting for hardware interrupt.
[   23.338048] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   23.344479] mmc1: sdhci: Sys addr:  0x00000198 | Version:  0x00001004
[   23.350911] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[   23.357340] mmc1: sdhci: Argument:  0x00ea5880 | Trn mode: 0x0000002b
[   23.363770] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
[   23.370199] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[   23.376628] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
[   23.383057] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000003
[   23.389485] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[   23.395914] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001
[   23.402343] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[   23.408772] mmc1: sdhci: Cmd:       0x0000193a | Max curr: 0x00000000
[   23.415202] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x0076b27f
[   23.421632] mmc1: sdhci: Resp[2]:   0x325b5900 | Resp[3]:  0x00000900
[   23.428062] mmc1: sdhci: Host ctl2: 0x00000000
[   23.432497] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000080f2244c
[   23.439620] mmc1: sdhci: ============================================
[   33.572623] mmc1: Timeout waiting for hardware interrupt.
[   33.578040] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   33.584469] mmc1: sdhci: Sys addr:  0x00000198 | Version:  0x00001004
[   33.590900] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[   33.597329] mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000023
[   33.603757] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
[   33.610186] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[   33.616615] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
[   33.623043] mmc1: sdhci: Timeout:   0x0000000e | Int stat: 0x00018002
[   33.629473] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[   33.635902] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001
[   33.642330] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[   33.648760] mmc1: sdhci: Cmd:       0x00000c1b | Max curr: 0x00000000
[   33.655188] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x0076b27f
[   33.661618] mmc1: sdhci: Resp[2]:   0x325b5900 | Resp[3]:  0x00000900
[   33.668046] mmc1: sdhci: Host ctl2: 0x00000000
[   33.672482] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000080f2244c
[   33.679605] mmc1: sdhci: ============================================
[   43.812621] mmc1: Timeout waiting for hardware cmd interrupt.
[   43.818370] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   43.824799] mmc1: sdhci: Sys addr:  0x00000198 | Version:  0x00001004
[   43.831230] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[   43.837659] mmc1: sdhci: Argument:  0xaaaa0000 | Trn mode: 0x00000023
[   43.844088] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
[   43.850517] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[   43.856947] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
[   43.863376] mmc1: sdhci: Timeout:   0x0000000e | Int stat: 0x00018001
[   43.869805] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[   43.876235] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001
[   43.882663] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[   43.889092] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[   43.895521] mmc1: sdhci: Resp[0]:   0x00400900 | Resp[1]:  0x0076b27f
[   43.901950] mmc1: sdhci: Resp[2]:   0x325b5900 | Resp[3]:  0x00000900
[   43.908379] mmc1: sdhci: Host ctl2: 0x00000000
[   43.912814] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000080f2244c
[   43.919937] mmc1: sdhci: ============================================
[   54.052619] mmc1: Timeout waiting for hardware cmd interrupt.
[   54.058363] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   54.064793] mmc1: sdhci: Sys addr:  0x00000198 | Version:  0x00001004
[   54.071223] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[   54.077653] mmc1: sdhci: Argument:  0xaaaa0000 | Trn mode: 0x00000023
[   54.084083] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
[   54.090512] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[   54.096942] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
[   54.103371] mmc1: sdhci: Timeout:   0x0000000e | Int stat: 0x00018001
[   54.109800] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[   54.116230] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001
[   54.122659] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[   54.129088] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[   54.135518] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x0076b27f
[   54.141948] mmc1: sdhci: Resp[2]:   0x325b5900 | Resp[3]:  0x00000900
[   54.148377] mmc1: sdhci: Host ctl2: 0x00000000
[   54.152812] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000080f2244c
[   54.159935] mmc1: sdhci: ============================================
[   64.296618] mmc1: Timeout waiting for hardware cmd interrupt.
[   64.302359] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   64.308787] mmc1: sdhci: Sys addr:  0x00000198 | Version:  0x00001004
[   64.315217] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[   64.321646] mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000023
[   64.328075] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
[   64.334504] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[   64.340932] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
[   64.347361] mmc1: sdhci: Timeout:   0x0000000e | Int stat: 0x00018002
[   64.353791] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[   64.360220] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001
[   64.366649] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[   64.373077] mmc1: sdhci: Cmd:       0x00000c1a | Max curr: 0x00000000
[   64.379506] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x0076b27f
[   64.385935] mmc1: sdhci: Resp[2]:   0x325b5900 | Resp[3]:  0x00000900
[   64.392364] mmc1: sdhci: Host ctl2: 0x00000000
[   64.396798] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000080f2244c
[   64.403920] mmc1: sdhci: ============================================
  • Hello Siva,
    I assume this is an unmodified SK-AM62 evm?
    Please describe the software you are using. I assume you are using AM62x RT Linux SDK 08.04.01.03 - is that correct? Are you using the default filesystem image, or something else?
    Nick
