Part Number: AMIC120
Other Parts Discussed in Thread: AM4376
Hi
In the AMIC120 datasheet,
https://www.ti.com/lit/ds/symlink/amic120.pdf
Spec of performance is 2000 or 2500 MIPS in Table 3-1 Device Features Comparison.
which is correct?
thanks,
GR
Hello Gr,
Thank you for the query.
I am checking internally and will update you.
Sreenivasa
Hello GR,
AM437x and AMIC120 devices are pin compatible. The IDK board is the same for both devices
Refer below the AM437x MIPS table.
Sreenivasa
Hello Sreenivasa,
Thank you to your information.
In this Table, I think AM437x running at 300MHz is 750MIPS(AM4376).
But In datasheet of AMIC120, AMIC120 running at 300MHz is 2000 or 2500MIPS.
Is correct MIPS in AMIC120 750MIPS?
thanks,
GR
Hello GR,
Thank you for the note.
Your understanding is correct.
The datasheet for the AMIC120 needs to be updated.
Sreenivasa
