PROCESSOR-SDK-AM64X: AM64x-EVM network issue
Part Number: PROCESSOR-SDK-AM64X
There are some strange issue on Linux on AM64x-EVM... This is descriptions of different tests and issues
Tested on two board AM64x-EVM
  • AM64x-EVM HS - HW rev PROC101A(003)
  • AM64x-EVM GP - HW rev PROC101B(001)
  • TI SDK release 08.04.01.04
  • systemd networkd manager is disabled
Test scenario 1 (same behavior on both board)
  • connect the board to SE network via ETH1 (switch)
  • ifconfig eth1 up
  • dhclient eth1
  • ping from PC - OK
  • attach/detach cable - ping OK
  • detach from eth1 and attach cable to eth2(pru2)
  • ifconfig eth2 up
  • dhclient eth2
ETH2 does not work  with ping
Test scenario 2
  • connect two boards directly eth1(switch) <-> eth1(switch)
  • setup static ip address
    ifconfig eth1 192.168.1.100
    ifconfig eth1 192.168.1.200
PING boards
10 packets transmitted, 8 packets received, 20% packet loss
16 packets transmitted, 10 packets received, 37% packet loss
  • connect two boards directly eth1(switch) <-> eth2(PRU2) and turn on at same time
    ifconfig eth2 192.168.1.200
PING does not work... It will work after detach/attach cable
    For both test scenarios could you please attach a console log of your test steps and add a ifconfig -a result prior to performing the ping operation (not cut and paste into the e2e thread).
    For test scenario 2 I would like to confirm that the eth1 and eth2 are on the same board. Would you be able to provide a block diagram of the setup for both scenarios?
    root@am64xx-evm:~# uname -a
    Linux am64xx-evm 5.10.140-rt73-g3a997318d8 #1 SMP PREEMPT_RT Wed Sep 28 04:42:20 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux
    root@am64xx-evm:~# ifconfig
    eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500  metric 1
            ether ac:1f:0f:85:08:b4  txqueuelen 1000  (Ethernet)
            RX packets 0  bytes 0 (0.0 B)
            RX errors 0  dropped 0  overruns 0  frame 0
            TX packets 0  bytes 0 (0.0 B)
            TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
    eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500  metric 1
            inet6 fe80::72ff:76ff:fe1e:2e2d  prefixlen 64  scopeid 0x20<link>
            ether 70:ff:76:1e:2e:2d  txqueuelen 1000  (Ethernet)
            RX packets 7  bytes 808 (808.0 B)
            TX packets 44  bytes 6496 (6.3 KiB)
    eth2: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500  metric 1
            ether 70:ff:76:1e:2e:2e  txqueuelen 1000  (Ethernet)
    lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536  metric 1
            inet 127.0.0.1  netmask 255.0.0.0
            inet6 ::1  prefixlen 128  scopeid 0x10<host>
            loop  txqueuelen 1000  (Local Loopback)
            RX packets 85  bytes 6676 (6.5 KiB)
            TX packets 85  bytes 6676 (6.5 KiB)
    root@am64xx-evm:~# ifconfig eth1 192.168.1.100
    root@am64xx-evm:~# ifconfig -a
    can0: flags=128<NOARP>  mtu 16  metric 1
            unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 10  (UNSPEC)
            device interrupt 36
    can1: flags=128<NOARP>  mtu 16  metric 1
            device interrupt 38
    docker0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500  metric 1
            inet 172.17.0.1  netmask 255.255.0.0  broadcast 172.17.255.255
            ether 02:42:e0:b5:77:1f  txqueuelen 0  (Ethernet)
            inet 192.168.1.100  netmask 255.255.255.0  broadcast 192.168.1.255
            TX packets 64  bytes 10018 (9.7 KiB)
    root@am64xx-evm:~# ping 192.168.1.200
    PING 192.168.1.200 (192.168.1.200): 56 data bytes
    64 bytes from 192.168.1.200: seq=8 ttl=64 time=0.587 ms
    ^C
    --- 192.168.1.200 ping statistics ---
    15 packets transmitted, 1 packets received, 93% packet loss
    round-trip min/avg/max = 0.587/0.587/0.587 ms
            device interrupt 36
            device interrupt 38
            RX packets 14  bytes 1334 (1.3 KiB)
            TX packets 94  bytes 13210 (12.9 KiB)
    root@am64xx-evm:~#
            device interrupt 36
            device interrupt 38
            ether f4:84:4c:fa:a5:f6  txqueuelen 1000  (Ethernet)
            inet6 fe80::72ff:76ff:fe1e:2a28  prefixlen 64  scopeid 0x20<link>
            ether 70:ff:76:1e:2a:28  txqueuelen 1000  (Ethernet)
            RX packets 20  bytes 3442 (3.3 KiB)
            TX packets 52  bytes 7958 (7.7 KiB)
            ether 70:ff:76:1e:2a:29  txqueuelen 1000  (Ethernet)
            RX packets 82  bytes 6220 (6.0 KiB)
            TX packets 82  bytes 6220 (6.0 KiB)
    root@am64xx-evm:~# ifconfig eth1 192.168.1.200
            device interrupt 36
            device interrupt 38
            ether 02:42:5d:9c:71:c1  txqueuelen 0  (Ethernet)
            inet 192.168.1.200  netmask 255.255.255.0  broadcast 192.168.1.255
            RX packets 27  bytes 4488 (4.3 KiB)
            TX packets 76  bytes 11222 (10.9 KiB)
    root@am64xx-evm:~# ping 192.168.1.100
    PING 192.168.1.100 (192.168.1.100): 56 data bytes
    64 bytes from 192.168.1.100: seq=1 ttl=64 time=0.629 ms
    ^C
    --- 192.168.1.100 ping statistics ---
    11 packets transmitted, 1 packets received, 90% packet loss
    round-trip min/avg/max = 0.629/0.629/0.629 ms
            device interrupt 36
            device interrupt 38
            RX packets 51  bytes 7358 (7.1 KiB)
            TX packets 119  bytes 14996 (14.6 KiB)
            RX packets 89  bytes 7004 (6.8 KiB)
            TX packets 89  bytes 7004 (6.8 KiB)
            device interrupt 36
            device interrupt 38
            RX packets 2  bytes 160 (160.0 B)
            TX packets 46  bytes 7182 (7.0 KiB)
            RX packets 84  bytes 6472 (6.3 KiB)
            TX packets 84  bytes 6472 (6.3 KiB)
    root@am64xx-evm:~#
    ^C
    5 packets transmitted, 0 packets received, 100% packet loss
            device interrupt 36
            device interrupt 38
            ether 02:42:25:da:63:41  txqueuelen 0  (Ethernet)
            TX packets 53  bytes 7796 (7.6 KiB)
            RX packets 88  bytes 6920 (6.7 KiB)
            TX packets 88  bytes 6920 (6.7 KiB)
    root@am64xx-evm:~# ifconfig eth2 192.168.1.200
    ^C
    10 packets transmitted, 0 packets received, 100% packet loss
            device interrupt 36
            device interrupt 38
    eth1: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500  metric 1
    eth2: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500  metric 1
            inet6 fe80::72ff:76ff:fe1e:2a29  prefixlen 64  scopeid 0x20<link>
            RX packets 44  bytes 6832 (6.6 KiB)
            TX packets 66  bytes 8780 (8.5 KiB)
            RX packets 83  bytes 6332 (6.1 KiB)
            TX packets 83  bytes 6332 (6.1 KiB)
    ^C
            device interrupt 36
            device interrupt 38
            RX packets 46  bytes 7236 (7.0 KiB)
            TX packets 73  bytes 9394 (9.1 KiB)
            RX packets 87  bytes 6780 (6.6 KiB)
            TX packets 87  bytes 6780 (6.6 KiB)
    root@am64xx-evm:~#
    root@am64xx-evm:~# dmesg | grep eth
    [    0.000000] psci: probing for conduit method from DT.
    [    0.851893] optee: probing for conduit method.
    [    2.220235] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA00903, cpsw version 0x6BA80903 Ports: 3 quirks:00000002
    [    2.220463] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.4
    [    2.220471] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    2.221806] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [   12.323274] icssg-prueth icssg1-eth: TI PRU ethernet driver initialized: single EMAC mode
    [   15.581796] remoteproc remoteproc11: Booting fw image ti-pruss/am65x-sr2-pru0-prueth-fw.elf, size 37644
    [   15.602493] remoteproc remoteproc12: Booting fw image ti-pruss/am65x-sr2-rtu0-prueth-fw.elf, size 30860
    [   15.606236] remoteproc remoteproc13: Booting fw image ti-pruss/am65x-sr2-txpru0-prueth-fw.elf, size 36948
    [   15.654556] net eth2: started
    [   15.766988] am65-cpsw-nuss 8000000.ethernet: down msc_sl e0000000 tmo 0
    [   15.829454] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 16
    [   15.889874] am65-cpsw-nuss 8000000.ethernet eth1: PHY [0.1:03] driver [TI DP83869] (irq=POLL)
    [   15.889916] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [   15.990869] am65-cpsw-nuss 8000000.ethernet: down msc_sl e0000000 tmo 0
    [   16.052367] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [   16.052412] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [   18.971463] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
    [   18.971531] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 5.10.140-rt73-g3a997318d8 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain 2
    [    0.000000] Machine model: Texas Instruments AM642 EVM
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a57fffff]
    [    0.000000]   node   0: [mem 0x00000000a5800000-0x00000000ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000] On node 0 totalpages: 524288
    [    0.000000]   DMA zone: 8192 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 524288 pages, LIFO batch:63
    [    0.000000] cma: Reserved 512 MiB at 0x00000000dd000000
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 18 pages/cpu s35008 r8192 d30528 u73728
    [    0.000000] pcpu-alloc: s35008 r8192 d30528 u73728 alloc=18*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=fc40000.spi.0:1m(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088kt
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 1399596K/2097152K available (10752K kernel code, 1186K rwdata, 4172K rodata, 1728K init, 435K bss, 173268K reserved, 524288K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] rcu:     RCU priority boosting: priority 1 delay 500 ms.
    [    0.000000] rcu:     RCU_SOFTIRQ processing moved to rcuc kthreads.
    [    0.000000]  No expedited grace period (rcu_normal_after_boot).
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001840000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000080030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008592] Console: colour dummy device 80x25
    [    0.013195] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023868] pid_max: default: 32768 minimum: 301
    [    0.028699] LSM: Security Framework initializing
    [    0.033485] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.041064] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.051162] rcu: Hierarchical SRCU implementation.
    [    0.056731] Platform MSI: msi-controller@1820000 domain created
    [    0.063216] PCI/MSI: /bus@f4000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.072588] EFI services will not be available.
    [    0.077595] smp: Bringing up secondary CPUs ...
    [    0.091413] Detected VIPT I-cache on CPU1
    [    0.095554] GICv3: CPU1: found redistributor 1 region 0:0x0000000001860000
    [    0.102586] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
    [    0.110022] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.116855] smp: Brought up 1 node, 2 CPUs
    [    0.121085] SMP: Total of 2 processors activated.
    [    0.125908] CPU features: detected: 32-bit EL0 Support
    [    0.131174] CPU features: detected: CRC32 instructions
    [    0.144319] CPU: All CPU(s) started at EL2
    [    0.148527] alternatives: patching kernel code
    [    0.154494] devtmpfs: initialized
    [    0.168253] KASLR disabled due to lack of seed
    [    0.173052] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.183028] futex hash table entries: 512 (order: 4, 65536 bytes, linear)
    [    0.207624] pinctrl core: initialized pinctrl subsystem
    [    0.213707] DMI not present or invalid.
    [    0.218490] NET: Registered protocol family 16
    [    0.225355] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.232791] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.240930] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.249836] thermal_sys: Registered thermal governor 'step_wise'
    [    0.250560] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.263747] ASID allocator initialised with 65536 entries
    [    0.303054] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.309999] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.316917] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.323779] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.332062] cryptd: max_cpu_qlen set to 1000
    [    0.340547] k3-chipinfo 43000014.chipid: Family:AM64X rev:SR1.0 JTAGID[0x0bb3802f] Detected
    [    0.349952] vsys_5v0: supplied by evm_12v0
    [    0.354760] vsys_3v3: supplied by evm_12v0
    [    0.360221] vddb_3v3_display: supplied by vsys_3v3
    [    0.366590] iommu: Default domain type: Translated
    [    0.372130] SCSI subsystem initialized
    [    0.376853] mc: Linux media interface: v0.10
    [    0.381294] videodev: Linux video capture interface: v2.00
    [    0.387049] pps_core: LinuxPPS API ver. 1 registered
    [    0.392203] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.401553] PTP clock support registered
    [    0.405598] EDAC MC: Ver: 3.0.0
    [    0.409774] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fc9100
    [    0.416735] omap-mailbox 29040000.mailbox: omap mailbox rev 0x66fc9100
    [    0.423568] omap-mailbox 29060000.mailbox: omap mailbox rev 0x66fc9100
    [    0.431180] FPGA manager framework
    [    0.434824] Advanced Linux Sound Architecture Driver Initialized.
    [    0.442341] clocksource: Switched to clocksource arch_sys_counter
    [    0.448890] VFS: Disk quotas dquot_6.6.0
    [    0.452981] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.468109] NET: Registered protocol family 2
    [    0.472923] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.482062] tcp_listen_portaddr_hash hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.490925] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.499192] TCP bind hash table entries: 16384 (order: 7, 917504 bytes, linear)
    [    0.507608] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.514730] UDP hash table entries: 1024 (order: 5, 131072 bytes, linear)
    [    0.521856] UDP-Lite hash table entries: 1024 (order: 5, 131072 bytes, linear)
    [    0.529676] NET: Registered protocol family 1
    [    0.534934] RPC: Registered named UNIX socket transport module.
    [    0.541056] RPC: Registered udp transport module.
    [    0.545864] RPC: Registered tcp transport module.
    [    0.550670] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.557262] PCI: CLS 0 bytes, default 64
    [    0.562136] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.575683] Initialise system trusted keyrings
    [    0.580659] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.593428] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.600358] NFS: Registering the id_resolver key type
    [    0.605920] Key type id_resolver registered
    [    0.610251] Key type id_legacy registered
    [    0.614526] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.621398] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.629344] 9p: Installing v9fs 9p2000 file system support
    [    0.679029] Key type asymmetric registered
    [    0.683290] Asymmetric key parser 'x509' registered
    [    0.688350] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.695931] io scheduler mq-deadline registered
    [    0.700561] io scheduler kyber registered
    [    0.707877] pinctrl-single f4000.pinctrl: 180 pins, size 720
    [    0.715122] pinctrl-single a40000.timesync-router: 512 pins, size 2048
    [    0.733715] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.760055] brd: module loaded
    [    0.774136] loop: module loaded
    [    0.778709] megasas: 07.714.04.00-rc1
    [    0.788161] tun: Universal TUN/TAP device driver, 1.6
    [    0.794270] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.800746] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.806895] sky2: driver version 1.30
    [    0.812184] VFIO - User Level meta-driver version: 0.3
    [    0.819135] i2c /dev entries driver
    [    0.824307] sdhci: Secure Digital Host Controller Interface driver
    [    0.830681] sdhci: Copyright(c) Pierre Ossman
    [    0.835682] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.843397] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.856547] optee: revision 3.18 (8e155bae)
    [    0.856964] optee: dynamic shared memory is enabled
    [    0.866801] optee: initialized driver
    [    0.873559] NET: Registered protocol family 17
    [    0.878456] 9pnet: Installing 9P2000 support
    [    0.882961] Key type dns_resolver registered
    [    0.887795] printk: bootconsole [ns16550a0]: printing thread started
    [    0.887856] Loading compiled-in X.509 certificates
    [    0.907587] ti-sci 44043000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.4.7--v08.04.07 (Jolly Jellyfi')
    [    0.968084] omap-gpmc 3b000000.memory-controller: GPMC revision 6.0
    [    0.968108] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
    [    0.971060] omap_i2c 20000000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.976106] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    0.976313] pca953x 1-0022: using AI
    [    1.028161] Console: switching to mono frame buffer device 12x2
    [    1.056990] ssd1307fb 1-003c: fb0: Solomon SSD1307 framebuffer device registered, using 192 bytes of video memory
    [    1.057233] omap_i2c 20010000.i2c: bus 1 rev0.12 at 400 kHz
    [    1.058811] omap_i2c 20020000.i2c: bus 2 rev0.12 at 100 kHz
    [    1.060201] omap_i2c 20030000.i2c: bus 3 rev0.12 at 100 kHz
    [    1.060716] ti-sci-intr bus@f4000:bus@4000000:interrupt-controller1: Interrupt Router 5 domain created
    [    1.061021] ti-sci-intr bus@f4000:interrupt-controller0: Interrupt Router 3 domain created
    [    1.061485] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.075575] j721e-pcie f102000.pcie: host bridge /bus@f4000/pcie@f102000 ranges:
    [    1.075637] j721e-pcie f102000.pcie:       IO 0x0068001000..0x0068010fff -> 0x0068001000
    [    1.075663] j721e-pcie f102000.pcie:      MEM 0x0068011000..0x006fffffff -> 0x0068011000
    [    1.075687] j721e-pcie f102000.pcie:   IB MEM 0x0000000000..0x0fffffffff -> 0x0000000000
    [    2.080444] j721e-pcie f102000.pcie: PCI host bridge to bus 0000:00
    [    2.080470] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    2.080483] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x68001000-0x68010fff])
    [    2.080491] pci_bus 0000:00: root bus resource [mem 0x68011000-0x6fffffff]
    [    2.080544] pci 0000:00:00.0: [104c:b010] type 01 class 0x060400
    [    2.080566] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0xfffffffff 64bit pref]
    [    2.080667] pci 0000:00:00.0: supports D1
    [    2.080674] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.083605] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.086126] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    2.086172] pci 0000:00:00.0: BAR 0: no space for [mem size 0x1000000000 64bit pref]
    [    2.086181] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x1000000000 64bit pref]
    [    2.086192] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.087376] pcieport 0000:00:00.0: PME: Signaling with IRQ 44
    [    2.088375] ti-bcdma 485c0100.dma-controller: Number of rings: 68
    [    2.090037] ti-bcdma 485c0100.dma-controller: Channels: 24 (bchan: 12, tchan: 6, rchan: 6)
    [    2.092261] ti-pktdma 485c0000.dma-controller: Number of rings: 288
    [    2.102393] ti-pktdma 485c0000.dma-controller: Channels: 44 (tchan: 29, rchan: 15)
    [    2.106404] printk: console [ttyS2] disabled
    [    2.111797] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 16, base_baud = 3000000) is a 8250
    [    2.118130] printk: console [ttyS2]: printing thread started
    [    2.118151] printk: console [ttyS2] enabled
    [    2.118156] printk: bootconsole [ns16550a0] disabled
    [    2.135428] printk: bootconsole [ns16550a0]: printing thread stopped
    [    2.141970] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    2.142019] 7 cmdlinepart partitions found on MTD device fc40000.spi.0
    [    2.142025] Creating 7 MTD partitions on "fc40000.spi.0":
    [    2.142032] 0x000000000000-0x000000100000 : "ospi.tiboot3"
    [    2.143690] 0x000000100000-0x000000300000 : "ospi.tispl"
    [    2.145082] 0x000000300000-0x000000700000 : "ospi.u-boot"
    [    2.146574] 0x000000700000-0x000000740000 : "ospi.env"
    [    2.147984] 0x000000740000-0x000000780000 : "ospi.env.backup"
    [    2.149392] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    2.150944] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    2.180701] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    2.218335] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    2.220092] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    2.221370] pps pps0: new PPS source ptp0
    [    2.226567] am65-cpts 39000000.cpts: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [    2.227547] k3-j72xx-soc-thermal b00000.temperature-sensor: invalid resource
    [    2.227600] k3-j72xx-soc-thermal: probe of b00000.temperature-sensor failed with error -22
    [    2.230573] gpio-mux mux-controller: 2-way mux-controller registered
    [    2.231429] mmc0: CQHCI version 5.10
    [    2.242172] vdd_mmc1: supplied by vsys_3v3
    [    2.260492] mmc1: CQHCI version 5.10
    [    2.260559] debugfs: Directory 'pd:114' with parent 'pm_genpd' already present!
    [    2.275500] ALSA device list:
    [    2.275516]   No soundcards found.
    [    2.285227] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    2.303039] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    2.311515] Waiting for root device PARTUUID=2aeb0bb3-02...
    [    2.357271] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
    [    2.358235] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
    [    2.370071]  mmcblk1: p1 p2
    [    2.376220] mmc0: Command Queue Engine enabled
    [    2.376257] mmc0: new HS200 MMC card at address 0001
    [    2.377130] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    2.377357] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    2.377570] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    2.377848] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
    [    2.841214] EXT4-fs (mmcblk1p2): 1 orphan inode deleted
    [    2.841250] EXT4-fs (mmcblk1p2): recovery complete
    [    2.853860] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    2.854000] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    2.857452] devtmpfs: mounted
    [    2.858905] Freeing unused kernel memory: 1728K
    [    2.859047] Run /sbin/init as init process
    [    2.859051]   with arguments:
    [    2.859053]     /sbin/init
    [    2.859056]   with environment:
    [    2.859058]     HOME=/
    [    2.859060]     TERM=linux
    [    3.017074] systemd[1]: System time before build time, advancing clock.
    [    3.072649] NET: Registered protocol family 10
    [    3.074259] Segment Routing with IPv6
    [    3.103437] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 )
    [    3.104004] systemd[1]: Detected architecture arm64.
    [    3.157392] systemd[1]: Set hostname to <am64xx-evm>.
    [    3.550536] systemd[1]: /lib/systemd/system/startwlansta.service:7: Unknown key name 'After' in section 'Service', ignoring.
    [    3.552202] systemd[1]: /lib/systemd/system/startwlanap.service:7: Unknown key name 'After' in section 'Service', ignoring.
    [    3.612705] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock \xe2\x86\x92 /run/docker.sock; please update the .
    [    3.755554] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.755966] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    3.755988] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    3.761134] systemd[1]: Created slice system-getty.slice.
    [    3.802656] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.805132] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    3.825547] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.828199] systemd[1]: Created slice system-syslog\x2dng.slice.
    [    3.857127] systemd[1]: Created slice User and Session Slice.
    [    3.879119] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    3.903095] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    3.926952] systemd[1]: Reached target Paths.
    [    3.938743] systemd[1]: Reached target Remote File Systems.
    [    3.958757] systemd[1]: Reached target Slices.
    [    3.978766] systemd[1]: Reached target Swap.
    [    3.999952] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    4.022744] systemd[1]: Reached target RPC Port Mapper.
    [    4.050769] systemd[1]: Listening on Process Core Dump Socket.
    [    4.075129] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    4.115774] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    4.116887] systemd[1]: Listening on Journal Socket (/dev/log).
    [    4.143633] systemd[1]: Listening on Journal Socket.
    [    4.167697] systemd[1]: Listening on Network Service Netlink Socket.
    [    4.191537] systemd[1]: Listening on udev Control Socket.
    [    4.215229] systemd[1]: Listening on udev Kernel Socket.
    [    4.245578] systemd[1]: Mounting Huge Pages File System...
    [    4.264122] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.293231] systemd[1]: Mounting Kernel Debug File System...
    [    4.316880] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    4.336261] systemd[1]: Starting Create list of static device nodes for the current kernel...
    [    4.369950] systemd[1]: Starting RPC Bind...
    [    4.387027] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    4.395309] systemd[1]: Starting Journal Service...
    [    4.439273] systemd[1]: Starting Load Kernel Modules...
    [    4.470518] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.478059] cryptodev: loading out-of-tree module taints kernel.
    [    4.486927] cryptodev: driver 1.10 loaded.
    [    4.516575] systemd[1]: Starting udev Coldplug all Devices...
    [    4.548915] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [    4.562227] systemd[1]: Started RPC Bind.
    [    4.586712] systemd[1]: Mounted Huge Pages File System.
    [    4.608314] systemd[1]: Mounted POSIX Message Queue File System.
    [    4.631657] systemd[1]: Started Journal Service.
    [    4.775417] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    4.780016] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.789646] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    4.812728] systemd-journald[219]: Received client request to flush runtime journal.
    [    6.283976] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.345147] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    6.496638] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.814472] random: crng init done
    [    6.814493] random: 62 urandom warning(s) missed due to ratelimiting
    [    6.955298] CAN device driver interface
    [    7.236841] 93xx46 spi1.0: 16-bit eeprom
    [    7.553200] davinci_mdio 300b2400.mdio: Configuring MDIO in manual mode
    [    7.594520] davinci_mdio 300b2400.mdio: davinci mdio revision 1.7, bus freq 1000000
    [    7.659147] davinci_mdio 300b2400.mdio: phy[15]: device 300b2400.mdio:0f, driver TI DP83869
    [    7.735138] platform 78000000.r5f: configured R5F for remoteproc mode
    [    7.735730] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [    7.736189] remoteproc remoteproc0: 78000000.r5f is available
    [    7.741630] remoteproc remoteproc0: powering up 78000000.r5f
    [    7.741661] remoteproc remoteproc0: Booting fw image am64-main-r5f0_0-fw, size 86352
    [    7.745839] platform 78200000.r5f: configured R5F for remoteproc mode
    [    7.759982] platform 78200000.r5f: assigned reserved memory node r5f-dma-memory@a1000000
    [    7.760498] remoteproc remoteproc1: 78200000.r5f is available
    [    7.761781]  remoteproc0#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [    7.762744] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    7.762860]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    7.762871] remoteproc remoteproc0: remote processor 78000000.r5f is now up
    [    7.763765] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    7.770652] remoteproc remoteproc1: powering up 78200000.r5f
    [    7.770683] remoteproc remoteproc1: Booting fw image am64-main-r5f0_1-fw, size 141772
    [    7.782693]  remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a1000000
    [    7.783343] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    7.783439]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    7.783450] remoteproc remoteproc1: remote processor 78200000.r5f is now up
    [    7.784576] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    7.860027] platform 78400000.r5f: configured R5F for remoteproc mode
    [    7.867423] platform 78400000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [    7.868066] remoteproc remoteproc2: 78400000.r5f is available
    [    7.869511] platform 78600000.r5f: configured R5F for remoteproc mode
    [    7.870013] platform 78600000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [    7.870804] remoteproc remoteproc3: 78600000.r5f is available
    [    7.874145] remoteproc remoteproc2: powering up 78400000.r5f
    [    7.874175] remoteproc remoteproc2: Booting fw image am64-main-r5f1_0-fw, size 93260
    [    7.876970] remoteproc remoteproc3: powering up 78600000.r5f
    [    7.877001] remoteproc remoteproc3: Booting fw image am64-main-r5f1_1-fw, size 91520
    [    7.893909]  remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [    7.898634]  remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [    7.901786] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    7.901918]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [    7.901930] remoteproc remoteproc3: remote processor 78600000.r5f is now up
    [    7.902008] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    7.902087]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [    7.902096] remoteproc remoteproc2: remote processor 78400000.r5f is now up
    [    7.902161] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [    7.903234] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [    8.018720] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@a4000000
    [    8.019163] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
    [    8.019312] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
    [    8.019761] remoteproc remoteproc4: 5000000.m4fss is available
    [    8.026891] remoteproc remoteproc4: powering up 5000000.m4fss
    [    8.026922] remoteproc remoteproc4: Booting fw image am64-mcu-m4f0_0-fw, size 85476
    [    8.041779]  remoteproc4#vdev0buffer: assigned reserved memory node m4f-dma-memory@a4000000
    [    8.042503] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    8.042583]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [    8.042594] remoteproc remoteproc4: remote processor 5000000.m4fss is now up
    [    8.043435] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xd
    [    8.043657] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xe
    [    8.703148] m_can_platform 20701000.can: m_can device registered (irq=36, version=32)
    [    8.707830] m_can_platform 20711000.can: m_can device registered (irq=38, version=32)
    [    8.832031] remoteproc remoteproc5: 30034000.pru is available
    [    8.854954] remoteproc remoteproc6: 30004000.rtu is available
    [    8.882837] remoteproc remoteproc7: 3000a000.txpru is available
    [    8.899212] remoteproc remoteproc8: 30038000.pru is available
    [    8.919058] remoteproc remoteproc9: 30006000.rtu is available
    [    8.919771] remoteproc remoteproc10: 3000c000.txpru is available
    [    8.920474] remoteproc remoteproc11: 300b4000.pru is available
    [    8.955225] remoteproc remoteproc12: 30084000.rtu is available
    [    8.958006] remoteproc remoteproc13: 3008a000.txpru is available
    [    9.007983] remoteproc remoteproc14: 300b8000.pru is available
    [    9.017467] remoteproc remoteproc15: 30086000.rtu is available
    [    9.025398] remoteproc remoteproc16: 3008c000.txpru is available
    [   12.323243] TI DP83869 300b2400.mdio:0f: attached PHY driver [TI DP83869] (mii_bus:phy_addr=300b2400.mdio:0f, irq=POLL)
    [   12.847087] usbcore: registered new interface driver usbfs
    [   12.847159] usbcore: registered new interface driver hub
    [   12.847235] usbcore: registered new device driver usb
    [   15.015534] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   15.056160] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   15.579096] remoteproc remoteproc11: powering up 300b4000.pru
    [   15.581843] remoteproc remoteproc11: unsupported resource 5
    [   15.581871] remoteproc remoteproc11: remote processor 300b4000.pru is now up
    [   15.581920] remoteproc remoteproc12: powering up 30084000.rtu
    [   15.602555] remoteproc remoteproc12: remote processor 30084000.rtu is now up
    [   15.602603] remoteproc remoteproc13: powering up 3008a000.txpru
    [   15.606413] remoteproc remoteproc13: remote processor 3008a000.txpru is now up
    [   15.619271] pps pps1: new PPS source ptp2
    [  137.155048] Initializing XFRM netlink socket
    [  138.815582] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [  138.828837] Bridge firewalling registered
    [  140.848204] process 'docker/tmp/qemu-check226957826/check' started with executable stack
    [    0.008586] Console: colour dummy device 80x25
    [    0.013186] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023857] pid_max: default: 32768 minimum: 301
    [    0.028679] LSM: Security Framework initializing
    [    0.033466] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.041047] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.051159] rcu: Hierarchical SRCU implementation.
    [    0.056724] Platform MSI: msi-controller@1820000 domain created
    [    0.063206] PCI/MSI: /bus@f4000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.072573] EFI services will not be available.
    [    0.077590] smp: Bringing up secondary CPUs ...
    [    0.091402] Detected VIPT I-cache on CPU1
    [    0.095544] GICv3: CPU1: found redistributor 1 region 0:0x0000000001860000
    [    0.102579] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
    [    0.110016] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.116853] smp: Brought up 1 node, 2 CPUs
    [    0.121084] SMP: Total of 2 processors activated.
    [    0.125905] CPU features: detected: 32-bit EL0 Support
    [    0.154352] devtmpfs: initialized
    [    0.168110] KASLR disabled due to lack of seed
    [    0.172908] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.182887] futex hash table entries: 512 (order: 4, 65536 bytes, linear)
    [    0.207402] pinctrl core: initialized pinctrl subsystem
    [    0.213477] DMI not present or invalid.
    [    0.218246] NET: Registered protocol family 16
    [    0.225108] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.232544] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.240680] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.249582] thermal_sys: Registered thermal governor 'step_wise'
    [    0.250309] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.263494] ASID allocator initialised with 65536 entries
    [    0.302781] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.309728] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.316646] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.323509] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.331790] cryptd: max_cpu_qlen set to 1000
    [    0.340325] k3-chipinfo 43000014.chipid: Family:AM64X rev:SR1.0 JTAGID[0x0bb3802f] Detected
    [    0.349725] vsys_5v0: supplied by evm_12v0
    [    0.354530] vsys_3v3: supplied by evm_12v0
    [    0.360006] vddb_3v3_display: supplied by vsys_3v3
    [    0.366378] iommu: Default domain type: Translated
    [    0.371918] SCSI subsystem initialized
    [    0.376630] mc: Linux media interface: v0.10
    [    0.381070] videodev: Linux video capture interface: v2.00
    [    0.386822] pps_core: LinuxPPS API ver. 1 registered
    [    0.391976] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.401329] PTP clock support registered
    [    0.405373] EDAC MC: Ver: 3.0.0
    [    0.409549] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fc9100
    [    0.416515] omap-mailbox 29040000.mailbox: omap mailbox rev 0x66fc9100
    [    0.423347] omap-mailbox 29060000.mailbox: omap mailbox rev 0x66fc9100
    [    0.430963] FPGA manager framework
    [    0.434606] Advanced Linux Sound Architecture Driver Initialized.
    [    0.442124] clocksource: Switched to clocksource arch_sys_counter
    [    0.448668] VFS: Disk quotas dquot_6.6.0
    [    0.452757] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.467873] NET: Registered protocol family 2
    [    0.472705] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.481839] tcp_listen_portaddr_hash hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.490704] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.498975] TCP bind hash table entries: 16384 (order: 7, 917504 bytes, linear)
    [    0.507397] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.514513] UDP hash table entries: 1024 (order: 5, 131072 bytes, linear)
    [    0.521648] UDP-Lite hash table entries: 1024 (order: 5, 131072 bytes, linear)
    [    0.529438] NET: Registered protocol family 1
    [    0.534723] RPC: Registered named UNIX socket transport module.
    [    0.540853] RPC: Registered udp transport module.
    [    0.545662] RPC: Registered tcp transport module.
    [    0.550468] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.557061] PCI: CLS 0 bytes, default 64
    [    0.561946] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.575507] Initialise system trusted keyrings
    [    0.580504] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.593244] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.600481] NFS: Registering the id_resolver key type
    [    0.605770] Key type id_resolver registered
    [    0.610065] Key type id_legacy registered
    [    0.614306] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.621186] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.629052] 9p: Installing v9fs 9p2000 file system support
    [    0.679297] Key type asymmetric registered
    [    0.683539] Asymmetric key parser 'x509' registered
    [    0.688626] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.696209] io scheduler mq-deadline registered
    [    0.700839] io scheduler kyber registered
    [    0.708062] pinctrl-single f4000.pinctrl: 180 pins, size 720
    [    0.715269] pinctrl-single a40000.timesync-router: 512 pins, size 2048
    [    0.733872] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.760274] brd: module loaded
    [    0.774390] loop: module loaded
    [    0.778890] megasas: 07.714.04.00-rc1
    [    0.788320] tun: Universal TUN/TAP device driver, 1.6
    [    0.794511] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.800964] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.807118] sky2: driver version 1.30
    [    0.812426] VFIO - User Level meta-driver version: 0.3
    [    0.819318] i2c /dev entries driver
    [    0.824514] sdhci: Secure Digital Host Controller Interface driver
    [    0.830882] sdhci: Copyright(c) Pierre Ossman
    [    0.835872] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.843580] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.851922] optee: probing for conduit method.
    [    0.856617] optee: revision 3.18 (8e155bae)
    [    0.857044] optee: dynamic shared memory is enabled
    [    0.866850] optee: initialized driver
    [    0.873660] NET: Registered protocol family 17
    [    0.878512] 9pnet: Installing 9P2000 support
    [    0.883024] Key type dns_resolver registered
    [    0.887860] printk: bootconsole [ns16550a0]: printing thread started
    [    0.887926] Loading compiled-in X.509 certificates
    [    0.908155] ti-sci 44043000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.4.7--v08.04.07 (Jolly Jellyfi')
    [    0.968902] omap-gpmc 3b000000.memory-controller: GPMC revision 6.0
    [    0.968927] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
    [    0.975025] omap_i2c 20000000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.977392] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    0.977571] pca953x 1-0022: using AI
    [    1.027987] Console: switching to mono frame buffer device 12x2
    [    1.056816] ssd1307fb 1-003c: fb0: Solomon SSD1307 framebuffer device registered, using 192 bytes of video memory
    [    1.057060] omap_i2c 20010000.i2c: bus 1 rev0.12 at 400 kHz
    [    1.058662] omap_i2c 20020000.i2c: bus 2 rev0.12 at 100 kHz
    [    1.060085] omap_i2c 20030000.i2c: bus 3 rev0.12 at 100 kHz
    [    1.060600] ti-sci-intr bus@f4000:bus@4000000:interrupt-controller1: Interrupt Router 5 domain created
    [    1.060901] ti-sci-intr bus@f4000:interrupt-controller0: Interrupt Router 3 domain created
    [    1.061362] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.076099] j721e-pcie f102000.pcie: host bridge /bus@f4000/pcie@f102000 ranges:
    [    1.076165] j721e-pcie f102000.pcie:       IO 0x0068001000..0x0068010fff -> 0x0068001000
    [    1.076191] j721e-pcie f102000.pcie:      MEM 0x0068011000..0x006fffffff -> 0x0068011000
    [    1.076215] j721e-pcie f102000.pcie:   IB MEM 0x0000000000..0x0fffffffff -> 0x0000000000
    [    2.080944] j721e-pcie f102000.pcie: PCI host bridge to bus 0000:00
    [    2.080969] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    2.080983] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x68001000-0x68010fff])
    [    2.080992] pci_bus 0000:00: root bus resource [mem 0x68011000-0x6fffffff]
    [    2.081044] pci 0000:00:00.0: [104c:b010] type 01 class 0x060400
    [    2.081066] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0xfffffffff 64bit pref]
    [    2.081155] pci 0000:00:00.0: supports D1
    [    2.081161] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.084080] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.086686] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    2.086745] pci 0000:00:00.0: BAR 0: no space for [mem size 0x1000000000 64bit pref]
    [    2.086755] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x1000000000 64bit pref]
    [    2.086768] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.087806] pcieport 0000:00:00.0: PME: Signaling with IRQ 44
    [    2.088779] ti-bcdma 485c0100.dma-controller: Number of rings: 68
    [    2.090526] ti-bcdma 485c0100.dma-controller: Channels: 24 (bchan: 12, tchan: 6, rchan: 6)
    [    2.092652] ti-pktdma 485c0000.dma-controller: Number of rings: 288
    [    2.102813] ti-pktdma 485c0000.dma-controller: Channels: 44 (tchan: 29, rchan: 15)
    [    2.106707] printk: console [ttyS2] disabled
    [    2.111500] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 16, base_baud = 3000000) is a 8250
    [    2.117730] printk: console [ttyS2]: printing thread started
    [    2.117751] printk: console [ttyS2] enabled
    [    2.117756] printk: bootconsole [ns16550a0] disabled
    [    2.135091] printk: bootconsole [ns16550a0]: printing thread stopped
    [    2.145593] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    2.145641] 7 cmdlinepart partitions found on MTD device fc40000.spi.0
    [    2.145648] Creating 7 MTD partitions on "fc40000.spi.0":
    [    2.145655] 0x000000000000-0x000000100000 : "ospi.tiboot3"
    [    2.147412] 0x000000100000-0x000000300000 : "ospi.tispl"
    [    2.148817] 0x000000300000-0x000000700000 : "ospi.u-boot"
    [    2.150257] 0x000000700000-0x000000740000 : "ospi.env"
    [    2.151636] 0x000000740000-0x000000780000 : "ospi.env.backup"
    [    2.153110] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    2.154667] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    2.184553] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    2.222120] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    2.223849] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    2.223995] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA00903, cpsw version 0x6BA80903 Ports: 3 quirks:00000002
    [    2.224220] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.4
    [    2.224228] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    2.225126] pps pps0: new PPS source ptp0
    [    2.225551] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    2.230347] am65-cpts 39000000.cpts: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [    2.231328] k3-j72xx-soc-thermal b00000.temperature-sensor: invalid resource
    [    2.231380] k3-j72xx-soc-thermal: probe of b00000.temperature-sensor failed with error -22
    [    2.234338] gpio-mux mux-controller: 2-way mux-controller registered
    [    2.234866] mmc0: CQHCI version 5.10
    [    2.246203] vdd_mmc1: supplied by vsys_3v3
    [    2.256376] mmc1: CQHCI version 5.10
    [    2.257027] debugfs: Directory 'pd:114' with parent 'pm_genpd' already present!
    [    2.272624] ALSA device list:
    [    2.272640]   No soundcards found.
    [    2.284908] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    2.301366] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    2.302693] Waiting for root device PARTUUID=6629ffe8-02...
    [    2.351753] mmc1: new ultra high speed SDR104 SDHC card at address 59b4
    [    2.352693] mmcblk1: mmc1:59b4 USD00 29.5 GiB
    [    2.354687]  mmcblk1: p1 p2
    [    2.371057] mmc0: Command Queue Engine enabled
    [    2.371093] mmc0: new HS200 MMC card at address 0001
    [    2.372280] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    2.372507] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    2.372723] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    2.373596] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
    [    2.711396] EXT4-fs (mmcblk1p2): 1 orphan inode deleted
    [    2.711429] EXT4-fs (mmcblk1p2): recovery complete
    [    2.718083] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    2.718270] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    2.721567] devtmpfs: mounted
    [    2.723088] Freeing unused kernel memory: 1728K
    [    2.726231] Run /sbin/init as init process
    [    2.726238]   with arguments:
    [    2.726240]     /sbin/init
    [    2.726242]   with environment:
    [    2.726244]     HOME=/
    [    2.726246]     TERM=linux
    [    2.874866] systemd[1]: System time before build time, advancing clock.
    [    2.926449] NET: Registered protocol family 10
    [    2.928049] Segment Routing with IPv6
    [    2.956209] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 )
    [    2.956806] systemd[1]: Detected architecture arm64.
    [    3.003091] systemd[1]: Set hostname to <am64xx-evm>.
    [    3.380090] systemd[1]: /lib/systemd/system/startwlansta.service:7: Unknown key name 'After' in section 'Service', ignoring.
    [    3.381723] systemd[1]: /lib/systemd/system/startwlanap.service:7: Unknown key name 'After' in section 'Service', ignoring.
    [    3.440805] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock \xe2\x86\x92 /run/docker.sock; please update the .
    [    3.576982] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.577395] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    3.577416] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    3.582612] systemd[1]: Created slice system-getty.slice.
    [    3.622443] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.624938] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    3.645364] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.648067] systemd[1]: Created slice system-syslog\x2dng.slice.
    [    3.676811] systemd[1]: Created slice User and Session Slice.
    [    3.698918] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    3.722825] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    3.746729] systemd[1]: Reached target Paths.
    [    3.758530] systemd[1]: Reached target Remote File Systems.
    [    3.778525] systemd[1]: Reached target Slices.
    [    3.798534] systemd[1]: Reached target Swap.
    [    3.820847] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    3.842541] systemd[1]: Reached target RPC Port Mapper.
    [    3.869028] systemd[1]: Listening on Process Core Dump Socket.
    [    3.890938] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    3.927783] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    3.928890] systemd[1]: Listening on Journal Socket (/dev/log).
    [    3.955353] systemd[1]: Listening on Journal Socket.
    [    3.967574] systemd[1]: Listening on Network Service Netlink Socket.
    [    3.991345] systemd[1]: Listening on udev Control Socket.
    [    4.014998] systemd[1]: Listening on udev Kernel Socket.
    [    4.045340] systemd[1]: Mounting Huge Pages File System...
    [    4.073577] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.104994] systemd[1]: Mounting Kernel Debug File System...
    [    4.128378] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    4.147972] systemd[1]: Starting Create list of static device nodes for the current kernel...
    [    4.185913] systemd[1]: Starting RPC Bind...
    [    4.206960] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    4.218947] systemd[1]: Starting Journal Service...
    [    4.248585] systemd[1]: Starting Load Kernel Modules...
    [    4.277397] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.291904] cryptodev: loading out-of-tree module taints kernel.
    [    4.302704] cryptodev: driver 1.10 loaded.
    [    4.327852] systemd[1]: Starting udev Coldplug all Devices...
    [    4.334666] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [    4.380179] systemd[1]: Started RPC Bind.
    [    4.399859] systemd[1]: Mounted Huge Pages File System.
    [    4.427473] systemd[1]: Mounted POSIX Message Queue File System.
    [    4.451370] systemd[1]: Mounted Kernel Debug File System.
    [    4.479564] systemd[1]: Started Journal Service.
    [    4.593884] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.594787] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    4.609622] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    4.666724] systemd-journald[181]: Received client request to flush runtime journal.
    [    5.735512] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.772552] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    6.008227] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.395449] random: crng init done
    [    6.395467] random: 62 urandom warning(s) missed due to ratelimiting
    [    6.540836] CAN device driver interface
    [    6.882854] 93xx46 spi1.0: 16-bit eeprom
    [    7.096038] davinci_mdio 300b2400.mdio: Configuring MDIO in manual mode
    [    7.134668] davinci_mdio 300b2400.mdio: davinci mdio revision 1.7, bus freq 1000000
    [    7.155778] davinci_mdio 300b2400.mdio: phy[15]: device 300b2400.mdio:0f, driver TI DP83869
    [    7.440449] platform 78000000.r5f: configured R5F for remoteproc mode
    [    7.440954] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [    7.441498] remoteproc remoteproc0: 78000000.r5f is available
    [    7.459124] platform 78200000.r5f: configured R5F for remoteproc mode
    [    7.459635] platform 78200000.r5f: assigned reserved memory node r5f-dma-memory@a1000000
    [    7.460438] remoteproc remoteproc1: 78200000.r5f is available
    [    7.460627] remoteproc remoteproc0: powering up 78000000.r5f
    [    7.460646] remoteproc remoteproc0: Booting fw image am64-main-r5f0_0-fw, size 86352
    [    7.470911]  remoteproc0#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [    7.471538] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    7.471637]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    7.471648] remoteproc remoteproc0: remote processor 78000000.r5f is now up
    [    7.471832] remoteproc remoteproc1: powering up 78200000.r5f
    [    7.471852] remoteproc remoteproc1: Booting fw image am64-main-r5f0_1-fw, size 141772
    [    7.472120] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    7.484670]  remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a1000000
    [    7.485813] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    7.485936]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    7.485947] remoteproc remoteproc1: remote processor 78200000.r5f is now up
    [    7.486320] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    7.499237] platform 78400000.r5f: configured R5F for remoteproc mode
    [    7.499730] platform 78400000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [    7.500213] remoteproc remoteproc2: 78400000.r5f is available
    [    7.501541] platform 78600000.r5f: configured R5F for remoteproc mode
    [    7.502503] platform 78600000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [    7.503579] remoteproc remoteproc3: 78600000.r5f is available
    [    7.504552] remoteproc remoteproc2: powering up 78400000.r5f
    [    7.504583] remoteproc remoteproc2: Booting fw image am64-main-r5f1_0-fw, size 93260
    [    7.507152] remoteproc remoteproc3: powering up 78600000.r5f
    [    7.507185] remoteproc remoteproc3: Booting fw image am64-main-r5f1_1-fw, size 91520
    [    7.522859]  remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [    7.523506] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    7.523609]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [    7.523620] remoteproc remoteproc2: remote processor 78400000.r5f is now up
    [    7.524521] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [    7.539627]  remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [    7.540280] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    7.540375]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [    7.540387] remoteproc remoteproc3: remote processor 78600000.r5f is now up
    [    7.541136] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [    7.645977] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@a4000000
    [    7.676588] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
    [    7.690243] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
    [    7.695873] remoteproc remoteproc4: 5000000.m4fss is available
    [    7.706243] remoteproc remoteproc4: powering up 5000000.m4fss
    [    7.706274] remoteproc remoteproc4: Booting fw image am64-mcu-m4f0_0-fw, size 85476
    [    7.730759]  remoteproc4#vdev0buffer: assigned reserved memory node m4f-dma-memory@a4000000
    [    7.731361] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    7.731422]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [    7.731431] remoteproc remoteproc4: remote processor 5000000.m4fss is now up
    [    7.732225] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xd
    [    7.732515] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xe
    [    8.287634] m_can_platform 20701000.can: m_can device registered (irq=36, version=32)
    [    8.297568] m_can_platform 20711000.can: m_can device registered (irq=38, version=32)
    [    8.514314] remoteproc remoteproc5: 30034000.pru is available
    [    8.515167] remoteproc remoteproc6: 30004000.rtu is available
    [    8.516812] remoteproc remoteproc7: 3000a000.txpru is available
    [    8.517521] remoteproc remoteproc8: 30038000.pru is available
    [    8.537662] remoteproc remoteproc9: 30006000.rtu is available
    [    8.540492] remoteproc remoteproc10: 3000c000.txpru is available
    [    8.589214] remoteproc remoteproc11: 300b4000.pru is available
    [    8.589943] remoteproc remoteproc12: 30084000.rtu is available
    [    8.593275] remoteproc remoteproc13: 3008a000.txpru is available
    [    8.595993] remoteproc remoteproc14: 300b8000.pru is available
    [    8.600362] remoteproc remoteproc15: 30086000.rtu is available
    [    8.601047] remoteproc remoteproc16: 3008c000.txpru is available
    [   12.108129] TI DP83869 300b2400.mdio:0f: attached PHY driver [TI DP83869] (mii_bus:phy_addr=300b2400.mdio:0f, irq=POLL)
    [   12.108162] icssg-prueth icssg1-eth: TI PRU ethernet driver initialized: single EMAC mode
    [   13.095362] usbcore: registered new interface driver usbfs
    [   13.095453] usbcore: registered new interface driver hub
    [   13.095542] usbcore: registered new device driver usb
    [   14.765660] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   14.813506] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   15.198920] remoteproc remoteproc11: powering up 300b4000.pru
    [   15.201738] remoteproc remoteproc11: Booting fw image ti-pruss/am65x-sr2-pru0-prueth-fw.elf, size 37644
    [   15.201785] remoteproc remoteproc11: unsupported resource 5
    [   15.201813] remoteproc remoteproc11: remote processor 300b4000.pru is now up
    [   15.201861] remoteproc remoteproc12: powering up 30084000.rtu
    [   15.229711] remoteproc remoteproc12: Booting fw image ti-pruss/am65x-sr2-rtu0-prueth-fw.elf, size 30860
    [   15.229783] remoteproc remoteproc12: remote processor 30084000.rtu is now up
    [   15.229837] remoteproc remoteproc13: powering up 3008a000.txpru
    [   15.232014] remoteproc remoteproc13: Booting fw image ti-pruss/am65x-sr2-txpru0-prueth-fw.elf, size 36948
    [   15.232080] remoteproc remoteproc13: remote processor 3008a000.txpru is now up
    [   15.244568] pps pps1: new PPS source ptp2
    [   15.270951] net eth2: started
    [   15.390808] am65-cpsw-nuss 8000000.ethernet: down msc_sl e0000000 tmo 0
    [   15.431437] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 16
    [   15.497105] am65-cpsw-nuss 8000000.ethernet eth1: PHY [0.1:03] driver [TI DP83869] (irq=POLL)
    [   15.497148] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [   15.602731] am65-cpsw-nuss 8000000.ethernet: down msc_sl e0000000 tmo 0
    [   15.684055] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [   15.684101] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [   19.354769] icssg-prueth icssg1-eth eth2: Link is Up - 1Gbps/Full - flow control off
    [   19.354867] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
    [  136.746821] Initializing XFRM netlink socket
    [  138.388070] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [  138.393270] Bridge firewalling registered
    [  140.212801] process 'docker/tmp/qemu-check086444470/check' started with executable stack
    root@am64xx-evm:~#
    In attachment, I am sending you report for "Test scenario 2" .... Also you have picture about test setup
    You have logs from two boards when you connect ETH1 and ETH1 between boards
    Second test on same test case scenario is ETH1 from one board to ETH2 to another board...
    Additional two logs are test where ETH1 and ETH2 between boards are connected
    Also, there are two files with dmesg log
    It is important part that both boards are started at same time... Used images are TI SDK release 08.04.01.04
    Let me know if you need more information
