TDA4VM: Setting up Lauterbach with Trace32
Part Number: TDA4VM
Hello Team,
  We are tryng to setup the Lauterbach Debugger module  LA-3505 PowerDebug Probe and LA-7843 Arm7 A/R.We have installed Trace32 but we are facing some issue.
It would be great if you can help us setting up Trace32 from the initial level or provide some reference.
We are at beginner level and trying to setup the hardware + sodtware for the first time.
Ketaki
  • Hello Ketaki,
    For checking out your setup you should be able to run the bare metal TDA4VM demo scripts which Lauterbach provides with the ARM target install.  Those scripts also can be downloaded from the Lauterbach website.  If your install is new enough you can find them at ./T32/demo/arm/hardware/j721e/ else you can download them from their website at : https://www.lauterbach.com/frames.html?scripts.html .  If you have some tool issues Lauterbach support will be able to walk you through them.  TI does share some expanded scripts usually form our CDDS portal which can be used past bare metal.  A lot of the TI information does assume some level of familiarity with environments, as such you might need to get training if its all completely new to your team.  I'll attach a short video to help
    Richard W.
