Part Number: TDA4VM
The camera gets a UYVY image, but the upper two lines and the lower three lines are some camera parameter information. I want to convert it to NV12 format and remove the parameter information at the same time. Is there any good method? Or which functions are simpler to use?
If you can't do it at the same time, how can you simply remove the parameter information?
