SK-AM62: qspi norflash driver error under RT-linux
Part Number: SK-AM62
Other Parts Discussed in Thread: AM625
Hello TI team:
At present, we use the AM625 processor to connect the QSPI NORFLASH (model: S25hl512t and is25lp01g) two flash drives to test the erasure read drive under RT-linux. Both of them appear to be incomplete in some flash areas after writing. It is suspected that the problem is the QSPI host controller driver. I see that you have introduced on your official website that the test of s25hs512t QSPI-NOR Flash can be started under uboot, so you should also have a test under the kernel, Can you send me the flash driver, or can you tell me how to change the driver? Thanks!
Here is your introduction to launching Uboot with S25hs512t QSPI-NOR Flash: software-dl.ti.com/.../UG-QSPI.html
