Linking problems with Reuse Startup Code Space option set
DSP C6413
"Reuse Startup Code Space" in DSP/BIOS (5.32.03) configuration makes this GROUP appear in generated linker cmd file:
GROUP {
            .sysinitgap {. += 0x8;}
            .sysinit:
            .IRAM$heap: {
                _IRAM_base = IRAM$B;
                _IRAM_length = IRAM$L;
                . += 0x2000;
        } START(IRAM$B), SIZE(IRAM$L) > IRAM
new linker (Code Generation Tools 6.1.2) complains:
error: symbol "IRAM$B" used in expression before it
   has been assigned a value
and
 error: symbol "IRAM$L" used in expression before it
without this option set this part of the file looks like this:
  .IRAM$heap: {
            IRAM$B = .;
            _IRAM_base = .;
            IRAM$L = 0x2000;
            _IRAM_length = 0x2000;
            . += 0x2000;
        } > IRAM
Any suggestions?
  • I moved your question to the C6000 forum to see if can get an answer for you.
    It looks like this might be related to a known linker issue of Code Generation Tools version 6.1.x. I suggest trying CGT version 6.0.14 as this version of BIOS was built and validated on that version. From the Release Notes for BIOS 5.32.03:
    Validation Information
    This release was built using the following components:
    • C28x  Code Generation Tools version 5.0.0B2
    • C55x Code Genereation Tools version 3.3.2
    • C6x Code Generation Tools version 6.0.14
    This release was validated using the following components:
    • CCS 3.3
