Other Parts Discussed in Thread: OMAPL138
Hoping can someone can give a hand here. I have a part M1710EZZGR that i presume has been EOL and I am looking for an alternative or a complete part# of M1710EZZGR?
Hello George,
Please provide any additional information you have about this device, a picture might be useful.
Where did the MPN you referenced come from? Is it the part marking, or reference on a schematic? My initial investigation is that it is an OMAPL138 DSP, but there are other possibilities as well.
Looking forward to the additional info.
~Leonard
George.
I doubt you will find a pin compatible replacement. I can not say this for sure as I could not locate the datasheet for your device. If you have the datasheet, can you provide the literature number? The literature number is usually found on the bottom corner of the document.
Selecting an alternate part will depend on what processor performance and peripherals you need for your application. You can see what is available here: https://www.ti.com/microcontrollers-mcus-processors/arm-based-processors/overview.html .
--Paul
Hi Leonard, I found out that it is OMAP1710 DM. Would you know of an alternative or be able to find this part?
I think the same problem exists, OMAP1710 is no longer available and I am not aware of any pin compatible replacements.
--Paul
