I'm converting my model to bin failed,
here is my error log,
ONNX Model (Proto) File : ../../test/testvecs/models/public/onnx/efficientnet_b0_224.onnx
TIDL Network File : ../../test/testvecs/config/tidl_models/onnx/tidl_net_efficientnet_b0_224.bin
TIDL IO Info File : ../../test/testvecs/config/tidl_models/onnx/tidl_io_efficientnet_b0_224_
Current ONNX OpSet Version : 13
ONNX operator ReduceMean is not suported now.. By passing
Could not find Indata for data ID 7
Could not find Indata for data ID 21
Could not find Indata for data ID 35
Could not find Indata for data ID 50
Could not find Indata for data ID 64
Could not find Indata for data ID 79
Could not find Indata for data ID 93
Could not find Indata for data ID 108
Could not find Indata for data ID 123
Could not find Indata for data ID 137
Could not find Indata for data ID 152
Could not find Indata for data ID 167
Could not find Indata for data ID 181
Could not find Indata for data ID 196
Could not find Indata for data ID 211
Could not find Indata for data ID 226
~~~~~Running TIDL in PC emulation mode to collect Activations range for each layer~~~~~
Processing config file #0 : /data/huangtehui/TI/ti-processor-sdk-rtos-j721e-evm-07_03_00_07/tidl_j7_02_00_00_07/ti_dl/test/testvecs/config/tidl_models/onnx/tidl_import_efficientnet_b0_224.txt.qunat_stats_config.txt
Segmentation fault
------------------ Network Compiler Traces -----------------------------
Wrong Network structure: Higher ( 128 > 127) number of co-ex Layers
Wrong Network structure: Higher ( 129 > 127) number of co-ex Layers
Error : Error Code = <ERR_WRONG_NETWORK_STRUCTURE>
Could not open /data/huangtehui/TI/ti-processor-sdk-rtos-j721e-evm-07_03_00_07/tidl_j7_02_00_00_07/ti_dl/test/testvecs/config/tidl_models/onnx/efficientnet_b0_224/perfSimInfo.bin
Segmentation fault
ERROR: TIDL_E_QUANT_STATS_NOT_AVAILABLE] tidl_quant_stats_tool.out fails to collect dynamic range. Please look into quant stats log. This model will get fault on target.
WARNING: [TIDL_E_DATAFLOW_INFO_NULL] ti_cnnperfsim.out fails to allocate memory in MSMC. Please look into perfsim log. This model can only be used on PC emulation, it will get fault on target.
** 1 WARNINGS 1 ERRORS **
