Part Number: AM6442
My customer has to fix their board design with AM6442 soon. Could you answer their questions below ?
AM64x has EXTINT pin, but there is no description about it in the TRM.
- Could you share the specification of EXINT ?
- How can they set Level, Edge, Priority, etc.. of this interrupt ?
- What’s difference of use case between EXINT and other interrupt using GPIO ?
- EXTINT seems to be in MAIN Power domain. Does it interrupt A53 or R5F core ?
- Do you have any explanation ? ex. Block diagram which they can understand a route of interrupt ?
- On the EVM, EXTINT is connected to Ethernet PHY. Should they also connect INT of every PHY to EXTINT on their board ? In this use case, is there any concern or caution ?
- They can’t find NMI in the TRM. According to the following document, only M4 has NMI, correct ?
- https://software-dl.ti.com/mcu-plus-sdk/esd/AM64X/latest/exports/docs/api_guide_am64x/KERNEL_DPL_HWI_PAGE.html
- Which pin can they use in order to interrupt from external to NMI ? How can they configurate this interrupt ?
Thanks and regards,
Hideaki
