TMS320C6748: TMS320C6748 DSP Developement Kit Example Code
Part Number: TMS320C6748
Other Parts Discussed in Thread: OMAPL138, CCSTUDIO
Where can I find some example code for this developement board?
The Resource Explorer has nothing?
  • Hello Jianzhong Xu,
    Thanks you for your help, still none the wiser though,  I've spent literally days installing SDK's ect. and trying to open/import some example code but still nothing is working other than the basic 'Hello World' example? why does it have to be so hard and criptic, surely there should be an easy way to install the demos and get going in minutes?
    regards
    Carl..
  • I have this installed: C:\ti\pdk_omapl138_1_0_11
    If I run the bach files to install the projects it comes up with path errors:
    C:\ti\pdk_omapl138_1_0_11\packages>pdksetupenv.bat
    Environment Configuration:
    SDK_INSTALL_PATH : C:/ti
    PDK_INSTALL_PATH : C:/ti/pdk_omapl138_1_0_11/packages
    GMAKE_INSTALL_PATH : C:/ti/xdctools_3_55_02_22_core
    PDK_SOC : omapl138
    PDK_VERSION : 1_0_11
    RULES_MAKE : C:/ti/pdk_omapl138_1_0_11/packages/ti/build/Rules.make
    C:\ti\pdk_omapl138_1_0_11\packages>pdkProjectCreate.bat OMAPL138 all little all all dsp
    Configuration:
    SOC : OMAPL138
    BOARD : all
    ENDIAN : little
    MODULE : all
    PROJECT_TYPE : all
    PROCESSOR : dsp
    PDK_SHORT_NAME : C:\ti\PDK_OM~1\packages\
    Checking Configuration...
    Complete
    PDK_PARTNO : OMAPL138
    PDK_ECLIPSE_ID : com.ti.pdk.omapl138
    RTSC_PLATFORM_NAME : ti.platforms.evmOMAPL138
    RTSC_TARGET : ti.targets.elf.C674
    CCS_DEVICE : "com.ti.ccstudio.deviceModel.C6000.GenericC674xDevice"
    Detecting all projects in PDK and importing them in the workspace C:\ti\PDK_OM~1\packages\\MyExampleProjects
    Detected Test Project: EMAC_lcdkOMAPL138_C674xLoopback_testProject
    The system cannot find the path specified.
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: GPIO_LedBlink_lcdkOMAPL138_c674xTestProject
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: I2C_Master_lcdkOMAPL138_c674xTestProject
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: I2C_Slave_lcdkOMAPL138_c674xTestProject
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: MCASP_Audio_lcdkOMAPL138_c674xExampleProject
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: MCBSP_DigLpbk_lcdkOMAPL138_c674xExampleProject
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: MMCSD_FatfsConsole_lcdkOMAPL138_c674xExampleProject
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: MMCSD_FatfsConsole_lcdkOMAPL138_DMA_c674xExampleProject
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: MMCSD_lcdkOMAPL138_c674xTestProject
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: MMCSD_lcdkOMAPL138_DMA_c674xTestProject
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: SPI_LoopbackExample_lcdkOMAPL138_c674xDMAExampleProject
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: SPI_LoopbackExample_lcdkOMAPL138_c674xExampleProject
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: UART_BasicExample_lcdkOMAPL138_c674xExampleProject
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: UART_BasicExample_lcdkOMAPL138_c674xDMATestProject
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: UART_BasicExample_lcdkOMAPL138_c674xTestProject
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: USB_DevAudio_lcdkOMAPL138_c674xExampleProject
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: USB_DevMsc_lcdkOMAPL138_c674xExampleProject
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: USB_HostMsc_lcdkOMAPL138_c674xExampleProject
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: OSAL_BasicExample_lcdkOMAPL138_c674xTestProject
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: NIMU_emacExampleclient_lcdkOMAPL138C674xBiosExampleProject
    Copying macros.ini
    0 file(s) copied.
    Detected Test Project: NIMU_emacExample_lcdkOMAPL138C674xBiosExampleProject
    Copying macros.ini
    0 file(s) copied.
    Project generation complete
  • Finally a bit of progress, chagning the CCS path in the pdkProjectCreate.bat to the latest CCS:
    if not defined CCS_INSTALL_PATH (
        set CCS_INSTALL_PATH= C:\ti\ccs1210\ccs
    This allowed it to create the examples folder in C:\ti\pdk_omapl138_1_0_11\packages\MyExampleProjects
    These could then be imported into CCS
    None of this was documented in the quick start, very frustrating!
