"Pwm_GetOutputState" standard API undefined inside Static Source Code of PWM
Hello Team,
In  ti-processor-sdk-rtos-j721e-evm-08_05_00 MCAL for PWM driver , we are getting compilation issue for "Pwm_GetOutputState"  API.
As per autosar 4.3.1 specification, "Pwm_GetOutputState"  is an mandatory API, if driver is not supporting this feature then atleast an empty or dummy function need to be defined.
Please find the attached screenshot of error for reference
Pradeep R
  • Hi Pradeep,
    Due to hardware limitation it is not implemented, I will raise an internal ticket for this as well.
    Tarun Mukesh
  • Hello Tarun,
    Thankyou for the feedback, please provide us the internal ticket for reference.
    Pradeep R
  • Hi Pradeep,
    Internal ticket for reference is MCAL-9513
    Tarun Mukesh
  • Hello Pradeep,
    You can find the patch attached below for the issue with dummy function.
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/6811.0001_2D00_PWM_2D00_get_2D00_output_2D00_state_2D00_dummy_2D00_API_2D00_implemented.patch
    Steps to apply the patch:
    Steps to apply the patch and see the files changed in Linux machine :
    • 1)  Download the patch into local directory.
    • 2)  Go into ti-processor-sdk-rtos-j721e-evm-08_02_00_05/mcusw path
    • 3)  git init
    • 4)  git add .
    • 5)  git commit -asm "Original SDK 8.5"
    • 6)  git apply (path to patch in local directory)/(patch_name).patch
    • 7)  git status
    Tarun Mukesh
  • Hello Tarun,
    Let me try the patch and update you.
    Pradeep R
  • Hello Tarun,
    As we are not using Linux Platform, Can you please provide steps to apply patch on Windows Platform and see the changes.
    Pradeep R
  • Pradeep,
    You can download git onto your WIndows machine and you can apply the patch .
    In git bash terminal, you can do the same.
    if you get warnings due to special characters you can ignore those because changes in OS .
    Tarun Mukesh
  • Hello Tarun,
    As we are not committing the MCAL through git hub respository, we are using SVN.
    Could you please share the patch in the form of .c and .h files for the static code.
    Pradeep R
    * Copyright (c) 2020 Texas Instruments Incorporated
    * All rights reserved not granted herein.
    * Limited License.
    * Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive
    * license under copyrights and patents it now or hereafter owns or controls to make,
    * have made, use, import, offer to sell and sell ("Utilize") this software subject to the
    * terms herein.  With respect to the foregoing patent license, such license is granted
    * solely to the extent that any such patent is necessary to Utilize the software alone.
    * The patent license shall not apply to any combinations which include this software,
    * other than combinations with devices manufactured by or for TI ("TI Devices").
    * No hardware patent is licensed hereunder.
    * Redistributions must preserve existing copyright notices and reproduce this license
    * (including the above copyright notice and the disclaimer and (if applicable) source
    * code license limitations below) in the documentation and/or other materials provided
    * with the distribution
    * Redistribution and use in binary form, without modification, are permitted provided
    * that the following conditions are met:
    * *       No reverse engineering, decompilation, or disassembly of this software is
    * permitted with respect to any software provided in binary form.
    * *       any redistribution and use are licensed by TI for use only with TI Devices.
    * *       Nothing shall obligate TI to provide you with source code for the software
    * licensed and provided to you in object code.
    * If software source code is provided to you, modification and redistribution of the
    * source code are permitted provided that the following conditions are met:
    * *       any redistribution and use of the source code, including any resulting derivative
    * works, are licensed by TI for use only with TI Devices.
    * *       any redistribution and use of any object code compiled from the source code
    * and any resulting derivative works, are licensed by TI for use only with TI Devices.
    * Neither the name of Texas Instruments Incorporated nor the names of its suppliers
    * may be used to endorse or promote products derived from this software without
    * specific prior written permission.
    * DISCLAIMER.
    * THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS
    * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
    * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
    * IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT,
    * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
    * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
    * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
    * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
    * OF THE POSSIBILITY OF SUCH DAMAGE.
     *  \file     Pwm.c
     *  \brief    This file includes services for initialization and control of the
     *            PWM unit (pulse width modulation).
     *            The PWM module generates pulses with variable pulse width.It
     *            allows the selection of the duty cycle and the signal period time.
    /*                             Include Files                                  */
    #include "string.h"
     * Design: MCAL-6824,MCAL-7572
    #include "Pwm.h"
    #include "SchM_Pwm.h"
    #if (STD_ON == PWM_DEV_ERROR_DETECT)
    #include "Det.h"
    #endif
    #include "Pwm_Irq.h"
    #include "Pwm_Priv.h"
    /* There are static inline functions in hw_types.h file. Map them as well */
    #define PWM_START_SEC_CODE
    #include "Pwm_MemMap.h"
    #include "hw_include/hw_types.h"
    #define PWM_STOP_SEC_CODE
    /*                           Macros & Typedefs                                */
    /* AUTOSAR version information check has to match definition in header file */
    #if ((PWM_AR_RELEASE_MAJOR_VERSION != (4U)) || \
        (PWM_AR_RELEASE_MINOR_VERSION != (3U)) ||  \
        (PWM_AR_RELEASE_REVISION_VERSION != (1U)))
        #error "Pwm: AUTOSAR Version Numbers of Pwm are different!!"
    #endif
    /* AUTOSAR SW version information check has to match definition in header file */
    #if ((PWM_SW_MAJOR_VERSION != (2U)) || \
        (PWM_SW_MINOR_VERSION != (0U)) ||  \
        (PWM_SW_PATCH_VERSION != (0U)))
        #error "Pwm: Software Version Numbers are inconsistent!!"
    #endif
    /*                         Structures and Enums                               */
    /* None */
    /*                 Internal Function Declarations                             */
    /* None */
    /*                            Global Variables                                */
    #define PWM_START_SEC_VAR_INIT_32
    /** \brief Pwm driver init status */
    PWM_VAR_DATA_INIT_32_SECTION volatile VAR(uint8, PWM_VAR_INIT)
        Pwm_DrvStatus = PWM_STATUS_UNINIT;
    #define PWM_STOP_SEC_VAR_INIT_32
    #define PWM_START_SEC_VAR_NO_INIT_UNSPECIFIED
    /** \brief Pwm driver interrupt status flag*/
    PWM_VAR_DATA_NO_INIT_UNSPECIFIED_SECTION volatile VAR(Pwm_OutputStateType, PWM_VAR_NO_INIT)
        Pwm_Intrflag[PWM_MAX_NUM_CHANNELS];
    /** \brief PWM driver object. */
        VAR(Pwm_ChObjType, PWM_VAR_NO_INIT) Pwm_ChObj[PWM_MAX_NUM_CHANNELS];
    /* Pwm_ChObj is not static storage class, as this requires to be accessed by
        debug interface provided.  */
    #define PWM_STOP_SEC_VAR_NO_INIT_UNSPECIFIED
    /*                          Function Definitions                              */
    * Design: MCAL-6806,MCAL-6798,MCAL-6786,MCAL-6828,MCAL-6767,MCAL-6752,MCAL-6834,MCAL-6779,MCAL-6789,MCAL-6768,MCAL-7510,MCAL-7584
    * Design: MCAL-7610,MCAL-7552,MCAL-7568,MCAL-7581,MCAL-7579,MCAL-7528,MCAL-7565,MCAL-7635,MCAL-7598,MCAL-7608,MCAL-7545,MCAL-7607
    /* Initializes PWM unit and sets default period and duty cycle values from
     * parameter ConfigPtr.
    PWM_FUNC_TEXT_SECTION FUNC(void, PWM_CODE) Pwm_Init(
                               P2CONST(Pwm_ConfigType, AUTOMATIC, PWM_PBCFG) CfgPtr)
        uint32                 chIdx,chnum;
        const Pwm_ConfigType  *ConfigPtr = CfgPtr;
    #if (STD_ON == PWM_PRE_COMPILE_VARIANT)
        * Design: MCAL-6841,MCAL-7631,MCAL-6788,MCAL-7585,MCAL-7566
        ConfigPtr = &PWM_INIT_CONFIG_PC;
    #endif /* (STD_ON == PWM_PRE_COMPILE_VARIANT) */
        * Design: MCAL-6841,MCAL-7631,MCAL-6804,MCAL-7569
        * Design: MCAL-6798,MCAL-7552,MCAL-6856,MCAL-7574,MCAL-7555,MCAL-7629
        if (NULL == ConfigPtr)
             * ConfigPtr must not be NULL. In case it is NULL report an error and
             * return immediately.
             (void)Pwm_reportDetError(PWM_SID_INIT, PWM_E_INIT_FAILED);
        else if (PWM_STATUS_INIT == Pwm_DrvStatus)
             * Pwm module must not be initialized.
             * Otherwise call the Det with PWM_E_ALREADY_INITIALIZED
            (void)Pwm_reportDetError(PWM_SID_INIT, PWM_E_ALREADY_INITIALIZED);
       else
    #endif /* (STD_ON == PWM_DEV_ERROR_DETECT) */
            * Design: MCAL-6828,MCAL-7581,MCAL-6767,MCAL-7579,MCAL-6755,MCAL-7556,MCAL-7519
            /* Only initialize configured resources */
            for (chnum = 0U; chnum < PWM_NUM_CHANNELS; chnum++)
                if(((&PwmChannelConfigSet_PC)->chCfg[chnum].channelId) >=
                (uint32)PWM_MAX_NUM_CHANNELS)
                    /*Invalid channel */
                    (void)Pwm_reportDetError(PWM_SID_INIT, PWM_E_PARAM_CHANNEL);
    #endif
                for (chIdx = 0U; chIdx < PWM_MAX_NUM_CHANNELS; chIdx++)
                    if(chIdx == ((&PwmChannelConfigSet_PC)->chCfg[chnum].channelId))
                        /* Reset Channel object */
                        Pwm_ResetChObj(&Pwm_ChObj[chIdx]);
                        /* Copy the configuration */
                        Pwm_CopyConfig(&Pwm_ChObj[chIdx],
                        &ConfigPtr->chCfg[chnum],&PwmChannelConfigSet_PC.chCfg[chnum]);
                        /*Set interrupt flag as per polarity : this is toggled in the
                        ISR for supporting notifications*/
                        Pwm_Intrflag[chIdx] = Pwm_ChObj[chIdx].chCfg.polarity;
                        * Design: MCAL-6884,MCAL-7628,MCAL-6779,MCAL-7635,MCAL-6789,MCAL-7598
                        /* HW Channel Init */
                        Pwm_HwUnitInit(&Pwm_ChObj[chIdx]);
                        * Design: MCAL-6752,MCAL-7528,MCAL-7531
                        /* The function Pwm_Init shall disable all notifications */
    #if (STD_ON == PWM_NOTIFICATION_SUPPORTED)
                        Pwm_ChObj[chIdx].channelNotifyActiveFlag = (uint32) FALSE;
    #endif
                        Pwm_ChObj[chIdx].channelState = PWM_STATUS_INIT;
                        break;
            Pwm_DrvStatus = PWM_STATUS_INIT;
    #endif
        return;
     * Design: MCAL-6890,MCAL-7600,MCAL-6875,MCAL-7559,MCAL-6789,MCAL-7598,MCAL-6840,MCAL-7637,MCAL-6827,MCAL-7634,MCAL-6870,MCAL-7632,MCAL-6805,MCAL-7606,MCAL-6891,MCAL-7595,MCAL-6886,MCAL-7609,MCAL-7583
    #if (STD_ON == PWM_DEINIT_API)
    PWM_FUNC_TEXT_SECTION FUNC(void, PWM_CODE) Pwm_DeInit(void)
        uint32                chIdx;
        if (PWM_STATUS_INIT != Pwm_DrvStatus)
            * Design: MCAL-6833,MCAL-7611
            /* If the driver is not initialized, the function shall raise the error
             * PWM_E_UNINIT */
            Pwm_reportDetError(PWM_SID_DEINIT, PWM_E_UNINIT);
        else
    #endif
            /* Set driver status  to uninitialized */
                if(PWM_STATUS_INIT == (Pwm_ChObj[chIdx].channelState))
    #ifdef PWM_USE_EPWM
                    Pwm_IpDeInit_epwm(&Pwm_ChObj[chIdx]);
    #endif /*PWM_USE_EPWM*/
    #ifdef PWM_USE_GPT
                    Pwm_IpDeInit(&Pwm_ChObj[chIdx]);
    #endif /*PWM_USE_GPT*/
                    * Design: MCAL-6875,MCAL-7559
                    * The function Pwm_Deinit shall disable all interrupt
                    * notifications controlled by the PWM driver.
    #endif
                    Pwm_ChObj[chIdx].channelState = PWM_STATUS_UNINIT;
            /* Reset driver object */
            Pwm_ResetChObj(&Pwm_ChObj[0U]);
        return;
    #endif /*(STD_ON == PWM_DEINIT_API)*/
    #if (STD_ON == PWM_SET_DUTY_CYCLE_API)
    /*  Sets parameter DutyCycle as new duty cycle for channel ChannelNumber.
     *  DutyCycle is a percentage of the period with 0x8000 being equivalent
     *  to 100%.
     * Design: MCAL-6759,MCAL-7636,MCAL-6839,MCAL-7509,MCAL-6751,MCAL-7511,MCAL-6832,MCAL-7596,MCAL-6801,MCAL-7544,MCAL-6880,MCAL-7547,MCAL-6863,MCAL-7530,MCAL-6805,MCAL-7606,MCAL-6864,MCAL-7602,MCAL-6891,MCAL-7595,MCAL-6886,MCAL-7609,MCAL-6851,MCAL-7642,MCAL-6813,MCAL-7537,MCAL-7567,MCAL-7520,MCAL-7643
    PWM_FUNC_TEXT_SECTION FUNC(void, PWM_CODE) Pwm_SetDutyCycle(
        Pwm_ChannelType ChannelNumber, uint16 DutyCycle)
        if (ChannelNumber >= (uint32)PWM_MAX_NUM_CHANNELS)
            (void)Pwm_reportDetError(PWM_SID_SET_DUTY_CYCLE, PWM_E_PARAM_CHANNEL);
        * Design: MCAL-6833,MCAL-7611,MCAL-6872,MCAL-7523,MCAL-7536
        else
            Pwm_ChObjType *chObj = &Pwm_ChObj[ChannelNumber];
            if ((PWM_STATUS_INIT != Pwm_DrvStatus) &&
            (PWM_STATUS_INIT != chObj->channelState))
                (void)Pwm_reportDetError(PWM_SID_SET_DUTY_CYCLE, PWM_E_UNINIT);
            else if (DutyCycle > PWM_DUTY_100_PERCENT)
            else
                SchM_Enter_Pwm_PWM_EXCLUSIVE_AREA_0();
                * Design: MCAL-6759,MCAL-7636,MCAL-7621,MCAL-7633,MCAL-7518,MCAL-7614
                Pwm_SetDutyCycle_Internal(chObj, DutyCycle);
                SchM_Exit_Pwm_PWM_EXCLUSIVE_AREA_0();
        return;
    #endif /*(STD_ON == PWM_SET_DUTY_CYCLE_API)*/
    #if (STD_ON == PWM_SET_PERIOD_AND_DUTY_API)
    /*  Sets DutyCycle and Period of ChannelNumber. DutyCycle is a percentage of
     *  the period with 0x8000 being equivalent to 100%. */
      * Design: MCAL-6774,MCAL-7563,MCAL-6757,MCAL-7532,MCAL-6787,MCAL-7512,MCAL-6801,MCAL-7544,MCAL-6880,MCAL-7547,MCAL-6880,MCAL-7547,MCAL-6815,MCAL-7526,MCAL-6864,MCAL-7602,MCAL-6891,MCAL-7595,MCAL-6886,MCAL-7609,MCAL-6822,MCAL-7560,MCAL-6793,MCAL-7615,MCAL-6785,MCAL-7575,MCAL-6777,MCAL-7582
    PWM_FUNC_TEXT_SECTION FUNC(void, PWM_CODE) Pwm_SetPeriodAndDuty(
        Pwm_ChannelType ChannelNumber, Pwm_PeriodType Period, uint16 DutyCycle)
            (void)Pwm_reportDetError(PWM_SID_SET_PERIOD_AND_DUTY, PWM_E_PARAM_CHANNEL);
         * Design: MCAL-6833,MCAL-7611,MCAL-6872,MCAL-7523,MCAL-6805,MCAL-7606,MCAL-6815,MCAL-7526,MCAL-7601,MCAL-7588,MCAL-7541,MCAL-7506
        else
                (void)Pwm_reportDetError(PWM_SID_SET_PERIOD_AND_DUTY, PWM_E_UNINIT);
            else if (chObj->chCfg.channelClass != PWM_VARIABLE_PERIOD)
                            PWM_SID_SET_PERIOD_AND_DUTY, PWM_E_PERIOD_UNCHANGEABLE);
            else if (DutyCycle > 0x8000U)
            else
                * Design: MCAL-6757,MCAL-7532,MCAL-6845,MCAL-7625
                /* Period passed here is in unit ticks */
                chObj->chCfg.hwPeriod = Period;
    #ifdef PWM_USE_EPWM
                Pwm_SetTimeBasePeriod_epwm(chObj->baseAddr, chObj->chCfg.hwPeriod);
                 * Design: MCAL-6777,MCAL-7582
                if (Period == 0U)
                    Pwm_SetDutyCycle_Internal(chObj, (uint16) 0U);
                else
        return;
    #endif /*(STD_ON == PWM_SET_PERIOD_AND_DUTY_API)*/
    #if (STD_ON == PWM_SET_OUTPUT_TO_IDLE_API)
    /* Sets output state immediately to idle level. */
     * Design: MCAL-6784,MCAL-7626,MCAL-6756,MCAL-7515,MCAL-6766,MCAL-7542,MCAL-6887,MCAL-7604,MCAL-6776MCAL-7546,MCAL-6818,MCAL-7641
    PWM_FUNC_TEXT_SECTION FUNC(void, PWM_CODE) Pwm_SetOutputToIdle(
        Pwm_ChannelType ChannelNumber)
            (void)Pwm_reportDetError(PWM_SID_SET_OUTPUT_TO_IDLE, PWM_E_PARAM_CHANNEL);
         * Design: MCAL-6833,MCAL-7611,MCAL-6872,MCAL-7523,MCAL-7502,MCAL-7522
        else
                (void)Pwm_reportDetError(PWM_SID_SET_OUTPUT_TO_IDLE, PWM_E_UNINIT);
            else
                /* Set output to idle state */
                Pwm_SetIdleState(chObj);
                chObj->channelForcedIdle = (boolean)TRUE;
        return;
    #endif /*(STD_ON == PWM_SET_OUTPUT_TO_IDLE_API)*/
    FUNC(Pwm_OutputStateType, PWM_CODE) Pwm_GetOutputState(
     /* Function not implmented due to hardware limitation
        Dummy Function*/
     return PWM_LOW;
     * Design: MCAL-6807,MCAL-7539,MCAL-6848,MCAL-7627,MCAL-6830,MCAL-7594,MCAL-6780,MCAL-7517,MCAL-6882,MCAL-7521,MCAL-6805,MCAL-7606,MCAL-6864,MCAL-7602,MCAL-6891,MCAL-7595,MCAL-6886,MCAL-7609,MCAL-6773,MCAL-7619
    PWM_FUNC_TEXT_SECTION FUNC(void, PWM_CODE) Pwm_DisableNotification(
            (void)Pwm_reportDetError(PWM_SID_DISABLE_NOTIFICATION, PWM_E_PARAM_CHANNEL);
        else
                (void)Pwm_reportDetError(PWM_SID_DISABLE_NOTIFICATION, PWM_E_UNINIT);
            else
             * Design: MCAL-6807,MCAL-7539,MCAL-7605
    #ifdef PWM_USE_EPWM
                Pwm_EtIntrClear_epwm(chObj->baseAddr);
                Pwm_EtIntrDisable_epwm(chObj->baseAddr);
    #ifdef PWM_USE_GPT
                Pwm_IntrClear(ChannelNumber);
                Pwm_IntDisableAll(ChannelNumber);
                /* Set the notification active flag to FALSE */
                chObj->channelNotifyActiveFlag = (uint32) FALSE;
        return;
    #endif /* #if (STD_ON == PWM_NOTIFICATION_SUPPORTED)*/
        /* Enables notification for channel Channel. */
         * Design: MCAL-6800,MCAL-7586,MCAL-6889,MCAL-7554,MCAL-6865,MCAL-7593,MCAL-6765,MCAL-7624,MCAL-6882,MCAL-7521,MCAL-6805,MCAL-7606,MCAL-6864,MCAL-7602,MCAL-6891,MCAL-7595,MCAL-6886,MCAL-7609,MCAL-6823,MCAL-7525
    PWM_FUNC_TEXT_SECTION FUNC(void, PWM_CODE) Pwm_EnableNotification(
        Pwm_ChannelType ChannelNumber, Pwm_EdgeNotificationType Notification)
            (void)Pwm_reportDetError(PWM_SID_ENABLE_NOTIFICATION, PWM_E_PARAM_CHANNEL);
         * Design: MCAL-6833,MCAL-7611,MCAL-7523,MCAL-6872
        else
                (void)Pwm_reportDetError(PWM_SID_ENABLE_NOTIFICATION, PWM_E_UNINIT);
            else if ((Pwm_NotifyFuncType) NULL_PTR == chObj->chCfg.notificationHandler)
            else
    #endif /* #if (STD_ON == PWM_DEV_ERROR_DETECT)*/
            /* Dynamic coverage of below false condition is not possible as
             * false condition is verified in earlier stage it self
                if (PWM_STATUS_UNINIT != chObj->channelState)
                    /* Critical section, block the interrupts */
                    /* Cancel all pending interrupts */
                     * Design: MCAL-6889,MCAL-7554,MCAL-6762,MCAL-7622
    #ifdef PWM_USE_EPWM
                    /* Enable notification only if the duty cycle is not 0% or 100% */
                    if ((chObj->chCfg.dutyCycle == PWM_DUTY_0_PERCENT) ||
                            (chObj->chCfg.dutyCycle == PWM_DUTY_100_PERCENT))
                        /*Do not enable rising/falling edge notification as it is
                        * meaningless if duty cycle is 0% or 100% */
    #ifdef PWM_USE_GPT
                        TIMERIntDisable(chObj->baseAddr, (TIMER_INT_OVF_EN_FLAG |
                                                TIMER_IRQENABLE_SET_MAT_EN_FLAG_MASK));
                        TIMERDisable(chObj->baseAddr);
    #ifdef PWM_USE_EPWM
                        /* Generate interrupt when count equal to zero,
                         * but do not enable rising/falling edge notification as it is
                        Pwm_EtIntrCfg_epwm(chObj->baseAddr, CSL_EPWM_ET_INTR_EVT_CNT_EQ_ZRO,
                            CSL_EPWM_ET_INTR_PERIOD_FIRST_EVT);
                    else
                        /* Set PWM output edge notification according to the notification */
    #ifdef PWM_USE_GPT
                        chObj->Notification = Notification;
                        if(PWM_DUTY_50_PERCENT == chObj->chCfg.dutyCycle)
                            (void)TIMERIntEnable(chObj->baseAddr, TIMER_INT_OVF_EN_FLAG);
                        else
                            (void)TIMERIntEnable(chObj->baseAddr, (TIMER_INT_OVF_EN_FLAG |
    #ifdef PWM_USE_EPWM
                        PWM_NotifySetIntMode(chObj, Notification);
    #ifdef PWM_USE_EPWM
                    Pwm_EtIntrEnable_epwm(chObj->baseAddr);
                    chObj->channelNotifyActiveFlag = (uint32) TRUE;
        return;
    #endif
    #if (STD_ON == PWM_REGISTER_READBACK_API)
     * Design: MCAL-6852,MCAL-7590,MCAL-6871,MCAL-7540,MCAL-6846
    PWM_FUNC_TEXT_SECTION FUNC(Std_ReturnType, PWM_CODE) Pwm_RegisterReadback(
        Pwm_ChannelType PwmChannel,
        P2VAR(Pwm_RegisterReadbackType, AUTOMATIC, PWM_APPL_DATA) RegRbPtr)
        Std_ReturnType        retVal     = ((Std_ReturnType) E_NOT_OK);
        uint32 baseAddr;
        /* HW unit ID is the index, so search for matching HW unit */
        Pwm_ChObjType *chObj = &Pwm_ChObj[PwmChannel];
        if (PwmChannel >= (uint32)PWM_MAX_NUM_CHANNELS)
            (void)Pwm_reportDetError(PWM_SID_REGISTER_READBACK, PWM_E_PARAM_CHANNEL);
        else if ((PWM_STATUS_INIT != Pwm_DrvStatus) &&
            (void)Pwm_reportDetError(PWM_SID_REGISTER_READBACK, PWM_E_UNINIT);
        else if (NULL_PTR == RegRbPtr)
            (void)Pwm_reportDetError(PWM_SID_REGISTER_READBACK, PWM_E_PARAM_POINTER);
        /*Dynamic coverage of below code is not possibleas its been verified in earlier stage */
        else if (NULL == chObj)
    #endif
        /* Dynamic coverage of false condition is not possible as it is default is true */
        else
            (void) memset(RegRbPtr, 0, sizeof (Pwm_RegisterReadbackType));
            baseAddr = chObj->baseAddr;
    #ifdef PWM_USE_GPT
            Pwm_IpRegisterReadback(baseAddr,RegRbPtr);
    #endif
    #ifdef PWM_USE_EPWM
            Pwm_IpRegisterReadback_epwm(baseAddr,RegRbPtr);
    #endif
            retVal = (Std_ReturnType) E_OK;
        return (retVal);
    #endif
     * Design:MCAL-6812,MCAL-7573,MCAL-7548,MCAL-7640
    #if (STD_ON == PWM_VERSION_INFO_API)
    PWM_FUNC_TEXT_SECTION FUNC(void, PWM_CODE) Pwm_GetVersionInfo(
                P2VAR(Std_VersionInfoType, AUTOMATIC, PWM_APPL_DATA) VersionInfoPtr)
        if (NULL_PTR == VersionInfoPtr)
             * Design: MCAL-6847,MCAL-7527,MCAL-6838,
            Pwm_reportDetError(PWM_SID_GET_VERSION_INFO, PWM_E_PARAM_POINTER);
        else
    #endif
            VersionInfoPtr->vendorID         = PWM_VENDOR_ID;
            VersionInfoPtr->moduleID         = PWM_MODULE_ID;
            VersionInfoPtr->sw_major_version = (uint8) PWM_SW_MAJOR_VERSION;
            VersionInfoPtr->sw_minor_version = (uint8) PWM_SW_MINOR_VERSION;
            VersionInfoPtr->sw_patch_version = (uint8) PWM_SW_PATCH_VERSION;
        return;
    #endif /* PWM_VERSION_INFO_API*/
    7585.Pwm.h
    Pradeep,
    My advise is to use patches rather than sharing files, sometimes sharing of files leads data loss and will be immensely difficult to track . If you have patches you can apply to latest SDK releases if not updated in the release.
    Tarun Mukesh
  • Hello Tarun,
    Now the Patch is working.
    The fix is working fine at our end and the issue is resolved
    Thankyou.
    Pradeep R
  • Thanks pradeep for acknowledgment.
    Tarun Mukesh
