TDA4VM: Get stuck when running verify graph
Part Number: TDA4VM
Hi team,
The onnx vgg model will convert successfully when converting a model that TI can run, but it will get stuck at verify graph, but no error is reported. This is a encapsulation made by the API of the library openvx referenced by TI, what could be the cause?
The development board is the 7.3 version SDK.
Could you help check this case? Thanks.
Cherry
  • Hi Cherry,
    Could you please enable the remote core logs and share the same?
    You could do this by running "source ./vision_apps_init.sh" before running the application.
    Please share the application logs after enabling the remote core logs.
    With this, we could check if there is a hang in C7x.
    Nikhil
