TDA4VM: autorun gstream on weston
Part Number: TDA4VM
Hi guys,
I make a video_demo.service for auto run before weston ready.
[Unit]
Description=Demo video Service
After=multi-user.target weston.service
Requires=weston.service
#Before=graphical.target
ConditionPathExists=$XDG_RUNTIME_DIR/$WAYLAND_DISPLAY
[Service]
Type=forking
Environment="DISPLAY=:0"
Environment="WAYLAND_DISPLAY=wayland-0"
ExecStart=/usr/local/bin/demo_video.sh
StandardOutput=journal+console
[Install]
WantedBy=multi-user.target
the demo_video.sh:
#!/bin/bash
sleep 1
__say () {
    echo $1 > /dev/console
__say "Start DEMO CAMERAS.."
sleep 1
if [ -f /etc/profile.d/weston.sh ]; then
        source /etc/profile.d/weston.sh
else
        if test -z "$XDG_RUNTIME_DIR"; then
                export XDG_RUNTIME_DIR=/run/user/`id -u`
                if ! test -d "$XDG_RUNTIME_DIR"; then
                        mkdir --parents $XDG_RUNTIME_DIR
                        chmod 0700 $XDG_RUNTIME_DIR
                fi
        fi
fi
        sleep 3
        __say "Streaming demo video "
        GST_DEBUG=4 gst-launch-1.0 \
                videotestsrc ! video/x-raw,width=1280,height=720 ! waylandsink &
        sleep 5
        __say "test cmd end"
It does not work by using sytemctl.
error log:
[ 2615.596899] demo_8cam.sh[2449]: Caught SIGSEGV
[ 2615.597178] demo_8cam.sh[2449]: Spinning. Please run 'gdb gst-launch-1.0 2449' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
test cmd end
DEMO END.
[ 1331.139021] demo_8cam.sh[1648]: 0:00:00.000441635  1648     0x1dee2400 INFO                GST_INIT gst.c:586:init_pre: Initializing GStreamer Core Library version 1.16.3
[ 1331.139510] demo_8cam.sh[1648]: 0:00:00.000599750  1648     0x1dee2400 INFO                GST_INIT gst.c:587:init_pre: Using library installed in /usr/lib
[ 1331.139814] demo_8cam.sh[1648]: 0:00:00.000650310  1648     0x1dee2400 INFO                GST_INIT gst.c:605:init_pre: Linux j7-evm 5.10.153-01333-g30c6cf295792-dirty #103 SMP PREEMPT Thu Feb 9 23:14:49 PST 2023 aarch64
[ 1331.140365] demo_8cam.sh[1648]: 0:00:00.001479820  1648     0x1dee2400 INFO                GST_INIT gstmessage.c:128:_priv_gst_message_initialize: init messages
[ 1331.140699] demo_8cam.sh[1648]: 0:00:00.002837180  1648     0x1dee2400 INFO                GST_INIT gstcontext.c:84:_priv_gst_context_initialize: init contexts
[ 1331.141002] demo_8cam.sh[1648]: 0:00:00.003316040  1648     0x1dee2400 INFO      GST_PLUGIN_LOADING gstplugin.c:318:_priv_gst_plugin_initialize: registering 0 static plugins
[ 1331.141360] demo_8cam.sh[1648]: 0:00:00.003748250  1648     0x1dee2400 INFO      GST_PLUGIN_LOADING gstplugin.c:226:gst_plugin_register_static: registered static plugin "staticelements"
[ 1331.141653] demo_8cam.sh[1648]: 0:00:00.003802955  1648     0x1dee2400 INFO      GST_PLUGIN_LOADING gstplugin.c:228:gst_plugin_register_static: added static plugin "staticelements", result: 1
[ 1331.142573] demo_8cam.sh[1648]: 0:00:00.005645370  1648     0x1dee2400 INFO            GST_REGISTRY gstregistry.c:1733:ensure_current_registry: reading registry cache: /home/root/.cache/gstreamer-1.0/registry.aarch64.bin
[ 1331.182484] demo_8cam.sh[1648]: 0:00:00.045491830  1648     0x1dee2400 INFO            GST_REGISTRY gstregistrybinary.c:621:priv_gst_registry_binary_read_cache: loaded /home/root/.cache/gstreamer-1.0/registry.aarch64.bin in 0.039706 seconds
[ 1331.183409] demo_8cam.sh[1648]: 0:00:00.046512955  1648     0x1dee2400 INFO            GST_REGISTRY gstregistry.c:1592:scan_and_update_registry: Validating plugins from registry cache: /home/root/.cache/gstreamer-1.0/registry.aarch64.bin
[ 1331.190831] demo_8cam.sh[1648]: 0:00:00.053843560  1648     0x1dee2400 INFO            GST_REGISTRY gstregistry.c:1691:scan_and_update_registry: Registry cache has not changed
[ 1331.191227] demo_8cam.sh[1648]: 0:00:00.053935175  1648     0x1dee2400 INFO            GST_REGISTRY gstregistry.c:1768:ensure_current_registry: registry reading and updating done, result = 1
[ 1331.191664] demo_8cam.sh[1648]: 0:00:00.053984235  1648     0x1dee2400 INFO                GST_INIT gst.c:806:init_post: GLib runtime version: 2.62.6
[ 1331.191946] demo_8cam.sh[1648]: 0:00:00.054025070  1648     0x1dee2400 INFO                GST_INIT gst.c:808:init_post: GLib headers version: 2.62.6
[ 1331.192446] demo_8cam.sh[1648]: 0:00:00.054060150  1648     0x1dee2400 INFO                GST_INIT gst.c:810:init_post: initialized GStreamer successfully
[ 1331.192724] demo_8cam.sh[1648]: 0:00:00.054173485  1648     0x1dee2400 INFO            GST_PIPELINE gstparse.c:336:gst_parse_launch_full: parsing pipeline description 'videotestsrc ! video/x-raw,width=1280,height=720 ! waylandsink '
[ 1331.194869] demo_8cam.sh[1648]: 0:00:00.057786415  1648     0x1dee2400 INFO      GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/gstreamer-1.0/libgstvideotestsrc.so" loaded
[ 1331.195290] demo_8cam.sh[1648]: 0:00:00.057928355  1648     0x1dee2400 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "videotestsrc"
[ 1331.195696] demo_8cam.sh[1648]: 0:00:00.058502775  1648     0x1dee2400 INFO        GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseSrc@0x1e1009f0> adding pad 'src'
[ 1331.199232] demo_8cam.sh[1648]: 0:00:00.062222490  1648     0x1dee2400 INFO      GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/gstreamer-1.0/libgstwaylandsink.so" loaded
[ 1331.529086] demo_8cam.sh[1648]: 0:00:00.062318335  1648     0x1dee2400 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "waylandsink"
[ 1331.529756] demo_8cam.sh[1648]: 0:00:00.062681320  1648     0x1dee2400 INFO        GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseSink@0x1e0f9be0> adding pad 'sink'
[ 1331.530088] demo_8cam.sh[1648]: 0:00:00.062778545  1648     0x1dee2400 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "pipeline"
[ 1331.530392] demo_8cam.sh[1648]: 0:00:00.063144510  1648     0x1dee2400 INFO            GST_PIPELINE grammar.y:648:gst_parse_perform_link: linking some pad of GstVideoTestSrc named videotestsrc0 to some pad of GstWaylandSink named waylandsink0 (0/0) with caps "video/x-raw, width=(int)1280, height=(int)720"
[ 1331.530719] demo_8cam.sh[1648]: 0:00:00.064700955  1648     0x1dee2400 INFO      GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/gstreamer-1.0/libgstcoreelements.so" loaded
[ 1331.531000] demo_8cam.sh[1648]: 0:00:00.064766965  1648     0x1dee2400 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "capsfilter"
[ 1331.531275] demo_8cam.sh[1648]: 0:00:00.065002725  1648     0x1dee2400 INFO        GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseTransform@0x1e10a2c0> adding pad 'sink'
[ 1331.531583] demo_8cam.sh[1648]: 0:00:00.065064590  1648     0x1dee2400 INFO        GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseTransform@0x1e10a2c0> adding pad 'src'
[ 1331.531867] demo_8cam.sh[1648]: 0:00:00.065119015  1648     0x1dee2400 INFO              GST_STATES gstbin.c:2090:gst_bin_get_state_func:<pipeline0> getting state
[ 1331.532280] demo_8cam.sh[1648]: 0:00:00.065191730  1648     0x1dee2400 INFO              GST_STATES gstelement.c:2688:gst_element_continue_state:<capsfilter0> completed state change to NULL
[ 1331.532558] demo_8cam.sh[1648]: 0:00:00.065250535  1648     0x1dee2400 INFO               GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
[ 1331.533122] demo_8cam.sh[1648]: 0:00:00.065299590  1648     0x1dee2400 INFO        GST_ELEMENT_PADS gstutils.c:1771:gst_element_link_pads_full: trying to link element videotestsrc0:(any) to element capsfilter0:sink
[ 1331.533447] demo_8cam.sh[1648]: 0:00:00.065341410  1648     0x1dee2400 INFO        GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad capsfilter0:sink
[ 1331.533734] demo_8cam.sh[1648]: 0:00:00.065387350  1648     0x1dee2400 INFO                GST_PADS gstutils.c:1587:prepare_link_maybe_ghosting: videotestsrc0 and capsfilter0 in same bin, no need for ghost pads
[ 1331.534012] demo_8cam.sh[1648]: 0:00:00.065442265  1648     0x1dee2400 INFO                GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link videotestsrc0:src and capsfilter0:sink
[ 1331.534341] demo_8cam.sh[1648]: 0:00:00.065497730  1648     0x1dee2400 INFO                GST_PADS gstpad.c:4237:gst_pad_peer_query:<capsfilter0:src> pad has no peer
[ 1331.534625] demo_8cam.sh[1648]: 0:00:00.065557635  1648     0x1dee2400 INFO                GST_PADS gstpad.c:2585:gst_pad_link_full: linked videotestsrc0:src and capsfilter0:sink, successful
[ 1331.868209] demo_8cam.sh[1648]: 0:00:00.065593620  1648     0x1dee2400 INFO               GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
[ 1331.868532] demo_8cam.sh[1648]: 0:00:00.065632670  1648     0x1dee2400 INFO               GST_EVENT gstpad.c:5812:gst_pad_send_event_unchecked:<videotestsrc0:src> Received event on flushing pad. Discarding
[ 1331.868796] demo_8cam.sh[1648]: 0:00:00.065685765  1648     0x1dee2400 INFO        GST_ELEMENT_PADS gstutils.c:1771:gst_element_link_pads_full: trying to link element capsfilter0:src to element waylandsink0:(any)
[ 1331.869077] demo_8cam.sh[1648]: 0:00:00.065724660  1648     0x1dee2400 INFO        GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad capsfilter0:src
[ 1331.871157] demo_8cam.sh[1648]: 0:00:00.065766950  1648     0x1dee2400 INFO                GST_PADS gstutils.c:1034:gst_pad_check_link: trying to link capsfilter0:src and waylandsink0:sink
[ 1331.871457] demo_8cam.sh[1648]: 0:00:00.065914710  1648     0x1dee2400 INFO                GST_PADS gstutils.c:1587:prepare_link_maybe_ghosting: capsfilter0 and waylandsink0 in same bin, no need for ghost pads
[ 1331.871725] demo_8cam.sh[1648]: 0:00:00.065966030  1648     0x1dee2400 INFO                GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link capsfilter0:src and waylandsink0:sink
[ 1331.871989] demo_8cam.sh[1648]: 0:00:00.066070660  1648     0x1dee2400 INFO                GST_PADS gstpad.c:2585:gst_pad_link_full: linked capsfilter0:src and waylandsink0:sink, successful
[ 1331.872341] demo_8cam.sh[1648]: 0:00:00.066106345  1648     0x1dee2400 INFO               GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
[ 1331.872599] demo_8cam.sh[1648]: 0:00:00.066148895  1648     0x1dee2400 INFO               GST_EVENT gstpad.c:5812:gst_pad_send_event_unchecked:<capsfilter0:src> Received event on flushing pad. Discarding
[ 1331.872859] demo_8cam.sh[1648]: Setting pipeline to PAUSED ...
[ 1331.873118] demo_8cam.sh[1648]: 0:00:00.066347340  1648     0x1dee2400 INFO              GST_STATES gstbin.c:2503:gst_bin_element_set_state:<waylandsink0> current NULL pending VOID_PENDING, desired next READY
[ 1331.873406] demo_8cam.sh[1648]: Caught SIGSEGV
[ 1331.873669] demo_8cam.sh[1648]: Spinning.  Please run 'gdb gst-launch-1.0 1648' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
test cmd end
but it can run by console
GST_DEBUG=4 gst-launch-1.0 videotestsrc ! video/x-raw,width=1280,height=720 ! waylandsink &
root@j7-evm:/opt/edge_ai_apps# GST_DEBUG=4 gst-launch-1.0 videotestsrc ! video/x-raw,width=1280,height=720 ! waylandsink
0:00:00.000354550  1672     0x28e45400 INFO                GST_INIT gst.c:586:init_pre: Initializing GStreamer Core Library version 1.16.3
0:00:00.000498080  1672     0x28e45400 INFO                GST_INIT gst.c:587:init_pre: Using library installed in /usr/lib
0:00:00.000544765  1672     0x28e45400 INFO                GST_INIT gst.c:605:init_pre: Linux j7-evm 5.10.153-01333-g30c6cf295792-dirty #103 SMP PREEMPT Thu Feb 9 23:14:49 PST 2023 aarch64
0:00:00.001354100  1672     0x28e45400 INFO                GST_INIT gstmessage.c:128:_priv_gst_message_initialize: init messages
0:00:00.002547195  1672     0x28e45400 INFO                GST_INIT gstcontext.c:84:_priv_gst_context_initialize: init contexts
0:00:00.003071265  1672     0x28e45400 INFO      GST_PLUGIN_LOADING gstplugin.c:318:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.003309845  1672     0x28e45400 INFO      GST_PLUGIN_LOADING gstplugin.c:226:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.003352480  1672     0x28e45400 INFO      GST_PLUGIN_LOADING gstplugin.c:228:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.003442080  1672     0x28e45400 INFO            GST_REGISTRY gstregistry.c:1733:ensure_current_registry: reading registry cache: /home/root/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.042904680  1672     0x28e45400 INFO            GST_REGISTRY gstregistrybinary.c:621:priv_gst_registry_binary_read_cache: loaded /home/root/.cache/gstreamer-1.0/registry.aarch64.bin in 0.039385 seconds
0:00:00.043300910  1672     0x28e45400 INFO            GST_REGISTRY gstregistry.c:1592:scan_and_update_registry: Validating plugins from registry cache: /home/root/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.050563600  1672     0x28e45400 INFO            GST_REGISTRY gstregistry.c:1691:scan_and_update_registry: Registry cache has not changed
0:00:00.050630315  1672     0x28e45400 INFO            GST_REGISTRY gstregistry.c:1768:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.050666845  1672     0x28e45400 INFO                GST_INIT gst.c:806:init_post: GLib runtime version: 2.62.6
0:00:00.050762215  1672     0x28e45400 INFO                GST_INIT gst.c:808:init_post: GLib headers version: 2.62.6
0:00:00.050795005  1672     0x28e45400 INFO                GST_INIT gst.c:810:init_post: initialized GStreamer successfully
0:00:00.050897385  1672     0x28e45400 INFO            GST_PIPELINE gstparse.c:336:gst_parse_launch_full: parsing pipeline description 'videotestsrc ! video/x-raw,width=1280,height=720 ! waylandsink '
0:00:00.054235325  1672     0x28e45400 INFO      GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/gstreamer-1.0/libgstvideotestsrc.so" loaded
0:00:00.054323840  1672     0x28e45400 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "videotestsrc"
0:00:00.054884990  1672     0x28e45400 INFO        GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseSrc@0x29062b50> adding pad 'src'
0:00:00.058466130  1672     0x28e45400 INFO      GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/gstreamer-1.0/libgstwaylandsink.so" loaded
0:00:00.058530600  1672     0x28e45400 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "waylandsink"
0:00:00.059069690  1672     0x28e45400 INFO        GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseSink@0x2905bc30> adding pad 'sink'
0:00:00.059156230  1672     0x28e45400 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "pipeline"
0:00:00.059518960  1672     0x28e45400 INFO            GST_PIPELINE grammar.y:648:gst_parse_perform_link: linking some pad of GstVideoTestSrc named videotestsrc0 to some pad of GstWaylandSink named waylandsink0 (0/0) with caps "video/x-raw, width=(int)1280, height=(int)720"
0:00:00.391890255  1672     0x28e45400 INFO      GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/gstreamer-1.0/libgstcoreelements.so" loaded
0:00:00.391961390  1672     0x28e45400 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "capsfilter"
0:00:00.392198185  1672     0x28e45400 INFO        GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseTransform@0x2906c2c0> adding pad 'sink'
0:00:00.392256275  1672     0x28e45400 INFO        GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseTransform@0x2906c2c0> adding pad 'src'
0:00:00.392308525  1672     0x28e45400 INFO              GST_STATES gstbin.c:2090:gst_bin_get_state_func:<pipeline0> getting state
0:00:00.392382750  1672     0x28e45400 INFO              GST_STATES gstelement.c:2688:gst_element_continue_state:<capsfilter0> completed state change to NULL
0:00:00.392436220  1672     0x28e45400 INFO               GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:00.392482560  1672     0x28e45400 INFO        GST_ELEMENT_PADS gstutils.c:1771:gst_element_link_pads_full: trying to link element videotestsrc0:(any) to element capsfilter0:sink
0:00:00.392522265  1672     0x28e45400 INFO        GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad capsfilter0:sink
0:00:00.392559830  1672     0x28e45400 INFO                GST_PADS gstutils.c:1587:prepare_link_maybe_ghosting: videotestsrc0 and capsfilter0 in same bin, no need for ghost pads
0:00:00.392613070  1672     0x28e45400 INFO                GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link videotestsrc0:src and capsfilter0:sink
0:00:00.392667085  1672     0x28e45400 INFO                GST_PADS gstpad.c:4237:gst_pad_peer_query:<capsfilter0:src> pad has no peer
0:00:00.392721570  1672     0x28e45400 INFO                GST_PADS gstpad.c:2585:gst_pad_link_full: linked videotestsrc0:src and capsfilter0:sink, successful
0:00:00.392755535  1672     0x28e45400 INFO               GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:00.392790170  1672     0x28e45400 INFO               GST_EVENT gstpad.c:5812:gst_pad_send_event_unchecked:<videotestsrc0:src> Received event on flushing pad. Discarding
0:00:00.392839630  1672     0x28e45400 INFO        GST_ELEMENT_PADS gstutils.c:1771:gst_element_link_pads_full: trying to link element capsfilter0:src to element waylandsink0:(any)
0:00:00.392876735  1672     0x28e45400 INFO        GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad capsfilter0:src
0:00:00.392916545  1672     0x28e45400 INFO                GST_PADS gstutils.c:1034:gst_pad_check_link: trying to link capsfilter0:src and waylandsink0:sink
0:00:00.393062480  1672     0x28e45400 INFO                GST_PADS gstutils.c:1587:prepare_link_maybe_ghosting: capsfilter0 and waylandsink0 in same bin, no need for ghost pads
0:00:00.723150760  1672     0x28e45400 INFO                GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link capsfilter0:src and waylandsink0:sink
0:00:00.723330305  1672     0x28e45400 INFO                GST_PADS gstpad.c:2585:gst_pad_link_full: linked capsfilter0:src and waylandsink0:sink, successful
0:00:00.723366820  1672     0x28e45400 INFO               GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:00.723405430  1672     0x28e45400 INFO               GST_EVENT gstpad.c:5812:gst_pad_send_event_unchecked:<capsfilter0:src> Received event on flushing pad. Discarding
0:00:00.723658800  1672     0x28e45400 INFO              GST_STATES gstbin.c:2503:gst_bin_element_set_state:<waylandsink0> current NULL pending VOID_PENDING, desired next READY
0:00:00.725281680  1672     0x28e45400 INFO              GST_STATES gstelement.c:2688:gst_element_continue_state:<waylandsink0> completed state change to READY
0:00:00.725349525  1672     0x28e45400 INFO              GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<waylandsink0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.725411900  1672     0x28e45400 INFO              GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'waylandsink0' changed state to 2(READY) successfully
0:00:00.725465810  1672     0x28e45400 INFO              GST_STATES gstbin.c:2503:gst_bin_element_set_state:<capsfilter0> current NULL pending VOID_PENDING, desired next READY
0:00:00.725508165  1672     0x28e45400 INFO              GST_STATES gstelement.c:2688:gst_element_continue_state:<capsfilter0> completed state change to READY
0:00:00.725546435  1672     0x28e45400 INFO              GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.725593920  1672     0x28e45400 INFO              GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 2(READY) successfully
0:00:00.725635590  1672     0x28e45400 INFO              GST_STATES gstbin.c:2503:gst_bin_element_set_state:<videotestsrc0> current NULL pending VOID_PENDING, desired next READY
0:00:00.725676725  1672     0x28e45400 INFO              GST_STATES gstelement.c:2688:gst_element_continue_state:<videotestsrc0> completed state change to READY
0:00:00.725714090  1672     0x28e45400 INFO              GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<videotestsrc0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.725759865  1672     0x28e45400 INFO              GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'videotestsrc0' changed state to 2(READY) successfully
0:00:00.725807285  1672     0x28e45400 INFO              GST_STATES gstelement.c:2660:gst_element_continue_state:<pipeline0> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.725845220  1672     0x28e45400 INFO              GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed NULL to READY (PAUSED pending)
0:00:01.056718120  1672     0x28e45400 INFO              GST_STATES gstelement.c:2668:gst_element_continue_state:<pipeline0> continue state change READY to PAUSED, final PAUSED
0:00:01.056800460  1672     0x28e45400 INFO              GST_STATES gstbin.c:2503:gst_bin_element_set_state:<waylandsink0> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.056864435  1672     0x28e45400 INFO              GST_STATES gstbin.c:2959:gst_bin_change_state_func:<pipeline0> child 'waylandsink0' is changing state asynchronously to PAUSED
0:00:01.056907850  1672     0x28e45400 INFO              GST_STATES gstbin.c:2503:gst_bin_element_set_state:<capsfilter0> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.056960775  1672     0x28e45400 INFO              GST_STATES gstelement.c:2688:gst_element_continue_state:<capsfilter0> completed state change to PAUSED
0:00:01.056999890  1672     0x28e45400 INFO              GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:01.057045925  1672     0x28e45400 INFO              GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 3(PAUSED) successfully
0:00:01.057085720  1672     0x28e45400 INFO              GST_STATES gstbin.c:2503:gst_bin_element_set_state:<videotestsrc0> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.057208680  1672     0x28e45400 INFO                 basesrc gstbasesrc.c:1373:gst_base_src_do_seek:<videotestsrc0> seeking: time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:01.057325150  1672     0x28e45400 INFO                    task gsttask.c:460:gst_task_set_lock: setting stream lock 0x29056130 on task 0x29077050
0:00:01.057363905  1672     0x28e45400 INFO                GST_PADS gstpad.c:6159:gst_pad_start_task:<videotestsrc0:src> created task 0x29077050
0:00:01.057721960  1672     0x28e45400 INFO              GST_STATES gstelement.c:2688:gst_element_continue_state:<videotestsrc0> completed state change to PAUSED
0:00:01.057767745  1672     0x28e45400 INFO              GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<videotestsrc0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:01.057818015  1672     0x28e45400 INFO              GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'videotestsrc0' changed state to 3(PAUSED) successfully
Pipeline is PREROLLING ...
0:00:01.058002720  1672     0x2902a280 INFO        GST_ELEMENT_PADS gstelement.c:925:gst_element_get_static_pad: no such pad 'sink' in element "videotestsrc0"
0:00:01.058118900  1672     0x2902a280 FIXME                default gstutils.c:3980:gst_pad_create_stream_id_internal:<videotestsrc0:src> Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:01.059154460  1672     0x2902a280 INFO               GST_EVENT gstevent.c:820:gst_event_new_caps: creating caps event video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, framerate=(fraction)30/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive
0:00:01.390169195  1672     0x2902a280 INFO           basetransform gstbasetransform.c:1317:gst_base_transform_setcaps:<capsfilter0> reuse caps
0:00:01.390282200  1672     0x2902a280 INFO               GST_EVENT gstevent.c:820:gst_event_new_caps: creating caps event video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, framerate=(fraction)30/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive
0:00:01.425011705  1672     0x2902a280 INFO               GST_EVENT gstevent.c:900:gst_event_new_segment: creating segment event time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:01.425120455  1672     0x2902a280 INFO                 basesrc gstbasesrc.c:2962:gst_base_src_loop:<videotestsrc0> marking pending DISCONT
0:00:01.426563890  1672     0x2902a280 WARN             waylandsink wlvideoformat.c:137:gst_video_format_to_wl_dmabuf_format: wayland dmabuf video format not found
0:00:01.426913785  1672     0x2902a280 INFO              GST_STATES gstbin.c:3421:bin_handle_async_done:<pipeline0> committing state from READY to PAUSED, old pending PAUSED
0:00:01.426959155  1672     0x2902a280 INFO              GST_STATES gstbin.c:3444:bin_handle_async_done:<pipeline0> completed state change, pending VOID
0:00:01.426998730  1672     0x2902a280 INFO              GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
0:00:01.427829165  1672     0x28e45400 INFO               GST_EVENT gstevent.c:1449:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:01.427899355  1672     0x28e45400 INFO                     bin gstbin.c:2783:gst_bin_do_latency_func:<pipeline0> configured latency of 0:00:00.000000000
0:00:01.427956570  1672     0x28e45400 INFO              GST_STATES gstbin.c:2503:gst_bin_element_set_state:<waylandsink0> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:01.428025295  1672     0x28e45400 INFO              GST_STATES gstelement.c:2688:gst_element_continue_state:<waylandsink0> completed state change to PLAYING
0:00:01.428073510  1672     0x28e45400 INFO              GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<waylandsink0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:01.428123645  1672     0x28e45400 INFO              GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'waylandsink0' changed state to 4(PLAYING) successfully
0:00:01.428170950  1672     0x28e45400 INFO              GST_STATES gstbin.c:2503:gst_bin_element_set_state:<capsfilter0> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:01.428215075  1672     0x28e45400 INFO              GST_STATES gstelement.c:2688:gst_element_continue_state:<capsfilter0> completed state change to PLAYING
0:00:01.428255110  1672     0x28e45400 INFO              GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:01.461173595  1672     0x2902a280 WARN             waylandsink wlvideoformat.c:137:gst_video_format_to_wl_dmabuf_format: wayland dmabuf video format not found
0:00:01.756949220  1672     0x28e45400 INFO              GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 4(PLAYING) successfully
0:00:01.757009845  1672     0x28e45400 INFO              GST_STATES gstbin.c:2503:gst_bin_element_set_state:<videotestsrc0> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:01.757059560  1672     0x28e45400 INFO              GST_STATES gstelement.c:2688:gst_element_continue_state:<videotestsrc0> completed state change to PLAYING
0:00:01.757100745  1672     0x28e45400 INFO              GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<videotestsrc0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:01.757150560  1672     0x28e45400 INFO              GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'videotestsrc0' changed state to 4(PLAYING) successfully
0:00:01.757196135  1672     0x28e45400 INFO              GST_STATES gstelement.c:2688:gst_element_continue_state:<pipeline0> completed state change to PLAYING
0:00:01.757234405  1672     0x28e45400 INFO              GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
New clock: GstSystemClock
0:00:01.861174980  1672     0x2902a280 WARN             waylandsink wlvideoformat.c:137:gst_video_format_to_wl_dmabuf_format: wayland dmabuf video format not found
