AM62X-PET-CALC: PMIC phase node layout query and Crystal layout query
Part Number: AM62X-PET-CALC
Hi TI
For the crystal layout , any guide slide can be share? Any comments to below layout design in My project?
For the PMIC switch phase node layout , any layout guide for buck inductor , whether need remove the plane under inductor?
BR Jingcheng
  • I can only comment on the crystal circuit implementation.
    What is the component located between the two load capacitors and connected between the XI and XO signals? There should not be any components other than the crystal connected between XI and XO.  Any coupling between XI and XO signal traces should be minimized, so you should separate the traces where they are routed close together.  What is on the adjacent layer of the PCB. There should be a continuous (unbroken) ground plane area under the entire crystal circuit to avoid any coupling from other signals.
  • Hello Jingcheng
    For the PMIC query below, please start a new thread adding the PMIC number and layout for the PMIC team to support.
    For the PMIC switch phase node layout, any layout guide for buck inductor , whether need remove the plane under inductor?
    Sreenivasa
