RE: TDA4VM: edgeai-tidl-tools issue while running on TDA4VM device
Other Parts Discussed in Thread: TDA4VM
Hi Pratik,
Sorry, it is my environmental reason, other models have no problem. I have another problem about model deployment, please help solve.I have not changed anything in edgeai-tidl-tools. The model can be compiled and inference on the PC successfully.The log on PC as follows:
And then, I copy the below folders from PC to the EVM(J721E).
Setp 3, I did the following:
 cd edgeai-tidl-tools
export DEVICE=j7
 source ./setup.sh
Setp 4, ./root@tda4vm-sk:/opt/edgeai-tidl-tools/examples/osrt_python/ort# python3 ./onnxrt_ep.py. It can not run on TDA4VM.
Available execution providers : ['TIDLExecutionProvider', 'TIDLCompilationProvider', 'CPUExecutionProvider']
Running 4 Models - ['cl-ort-resnet18-v1', 'cl-ort-caffe_squeezenet_v1_1', 'ss-ort-deeplabv3lite_mobilenetv2', 'od-ort-ssd-lite_mobilenetv2_fpn']
Running_Model : cl-ort-resnet18-v1
2022-08-30 10:23:15.006334085 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'layer4.0.downsample.1.num_batches_tracked'. It is not used by any node and should be removed from the model.
2022-08-30 10:23:15.006423800 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'layer4.0.bn2.num_batches_tracked'. It is not used by any node and should be removed from the model.
2022-08-30 10:23:15.006453300 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'layer4.1.bn2.num_batches_tracked'. It is not used by any node and should be removed from the model.
2022-08-30 10:23:15.006476555 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'layer2.0.bn1.num_batches_tracked'. It is not used by any node and should be removed from the model.
2022-08-30 10:23:15.006497650 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'layer1.1.bn2.num_batches_tracked'. It is not used by any node and should be removed from the model.
2022-08-30 10:23:15.006515840 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'layer3.0.bn2.num_batches_tracked'. It is not used by any node and should be removed from the model.
2022-08-30 10:23:15.006534120 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'layer1.0.bn2.num_batches_tracked'. It is not used by any node and should be removed from the model.
2022-08-30 10:23:15.006551900 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'layer1.1.bn1.num_batches_tracked'. It is not used by any node and should be removed from the model.
2022-08-30 10:23:15.006569570 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'layer2.0.downsample.1.num_batches_tracked'. It is not used by any node and should be removed from the model.
2022-08-30 10:23:15.006587240 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'layer1.0.bn1.num_batches_tracked'. It is not used by any node and should be removed from the model.
2022-08-30 10:23:15.006606435 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'layer2.0.bn2.num_batches_tracked'. It is not used by any node and should be removed from the model.
2022-08-30 10:23:15.006625405 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'layer4.1.bn1.num_batches_tracked'. It is not used by any node and should be removed from the model.
2022-08-30 10:23:15.006642380 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'layer4.0.bn1.num_batches_tracked'. It is not used by any node and should be removed from the model.
2022-08-30 10:23:15.006661140 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'layer3.1.bn2.num_batches_tracked'. It is not used by any node and should be removed from the model.
2022-08-30 10:23:15.006679730 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'layer2.1.bn2.num_batches_tracked'. It is not used by any node and should be removed from the model.
2022-08-30 10:23:15.006698155 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'bn1.num_batches_tracked'. It is not used by any node and should be removed from the model.
2022-08-30 10:23:15.006718150 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'layer2.1.bn1.num_batches_tracked'. It is not used by any node and should be removed from the model.
2022-08-30 10:23:15.006740245 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'layer3.0.bn1.num_batches_tracked'. It is not used by any node and should be removed from the model.
2022-08-30 10:23:15.006761610 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'layer3.0.downsample.1.num_batches_tracked'. It is not used by any node and should be removed from the model.
2022-08-30 10:23:15.006780995 [W:onnxruntime:, graph.cc:3106 CleanUnusedInitializers] Removing initializer 'layer3.1.bn1.num_batches_tracked'. It is not used by any node and should be removed from the model.
libtidl_onnxrt_EP loaded 0x2072ad60
Final number of subgraphs created are : 1, - Offloaded Nodes - 52, Total Nodes - 52
APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=4) !!!
MEM: Init ... Done !!!
IPC: Init ... !!!
IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
4614.967089 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
4614.967360 s: VX_ZONE_INIT:Enabled
4614.967437 s: VX_ZONE_ERROR:Enabled
4614.967576 s: VX_ZONE_WARNING:Enabled
4614.968984 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
4614.969217 s: VX_ZONE_INIT:[tivxHostInitLocal:86] Initialization Done for HOST !!!
4615.002619 s: VX_ZONE_ERROR:[ownContextSendCmd:814] Command ack message returned failure cmd_status: -1
4615.002648 s: VX_ZONE_ERROR:[ownContextSendCmd:850] tivxEventWait() failed.
4615.002761 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
4615.002801 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
4615.002840 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
4615.002881 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!!
4615.002977 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
4615.003017 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
TIDL_RT_OVX: ERROR: Verifying TIDL graph ... Failed !!!
TIDL_RT_OVX: ERROR: Verify OpenVX graph failed
./onnxrt_ep.py:100: DeprecationWarning: LANCZOS is deprecated and will be removed in Pillow 10 (2023-07-01). Use Resampling.LANCZOS instead.
imgs.append(Image.open(image_files[i]).convert('RGB').resize((width, height), PIL.Image.LANCZOS))
4615.060725 s: VX_ZONE_ERROR:[ownContextSendCmd:814] Command ack message returned failure cmd_status: -1
4615.060757 s: VX_ZONE_ERROR:[ownContextSendCmd:850] tivxEventWait() failed.
4615.060772 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
4615.060781 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
4615.060790 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
4615.060800 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!!
4615.060812 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
4615.060821 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
4615.060941 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
4615.060953 s: VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
4615.060962 s: VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
ERROR: Running TIDL graph ... Failed !!!
4615.087787 s: VX_ZONE_ERROR:[ownContextSendCmd:814] Command ack message returned failure cmd_status: -1
4615.087818 s: VX_ZONE_ERROR:[ownContextSendCmd:850] tivxEventWait() failed.
4615.087845 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
4615.087864 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
4615.087882 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
4615.087901 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!!
4615.087922 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
4615.087941 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
4615.088081 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
4615.088092 s: VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
4615.088100 s: VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
4615.114986 s: VX_ZONE_ERROR:[ownContextSendCmd:814] Command ack message returned failure cmd_status: -1
4615.115015 s: VX_ZONE_ERROR:[ownContextSendCmd:850] tivxEventWait() failed.
4615.115029 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
4615.115037 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
4615.115046 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
4615.115056 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!!
4615.115068 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
4615.115077 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
4615.115184 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
4615.115192 s: VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
4615.115203 s: VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
4615.142019 s: VX_ZONE_ERROR:[ownContextSendCmd:814] Command ack message returned failure cmd_status: -1
4615.142049 s: VX_ZONE_ERROR:[ownContextSendCmd:850] tivxEventWait() failed.
4615.142063 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
4615.142072 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
4615.142081 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
4615.142091 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!!
4615.142104 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
4615.142113 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
4615.142221 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
4615.142229 s: VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
4615.142237 s: VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
4615.169042 s: VX_ZONE_ERROR:[ownContextSendCmd:814] Command ack message returned failure cmd_status: -1
4615.169070 s: VX_ZONE_ERROR:[ownContextSendCmd:850] tivxEventWait() failed.
4615.169083 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
4615.169092 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
4615.169101 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
4615.169111 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!!
4615.169123 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
4615.169132 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
4615.169234 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
4615.169243 s: VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
4615.169278 s: VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
4615.196150 s: VX_ZONE_ERROR:[ownContextSendCmd:814] Command ack message returned failure cmd_status: -1
4615.196179 s: VX_ZONE_ERROR:[ownContextSendCmd:850] tivxEventWait() failed.
4615.196192 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
4615.196201 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
4615.196210 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
4615.196220 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!!
4615.196233 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
4615.196241 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
4615.196349 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
4615.196357 s: VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
4615.196365 s: VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
4615.223210 s: VX_ZONE_ERROR:[ownContextSendCmd:814] Command ack message returned failure cmd_status: -1
4615.223240 s: VX_ZONE_ERROR:[ownContextSendCmd:850] tivxEventWait() failed.
4615.223254 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
4615.223263 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
4615.223271 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
4615.223281 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!!
4615.223294 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
4615.223302 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
4615.223405 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
4615.223413 s: VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
4615.223423 s: VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
4615.250188 s: VX_ZONE_ERROR:[ownContextSendCmd:814] Command ack message returned failure cmd_status: -1
4615.250218 s: VX_ZONE_ERROR:[ownContextSendCmd:850] tivxEventWait() failed.
4615.250232 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
4615.250242 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
4615.250250 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
4615.250260 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!!
4615.250273 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
4615.250281 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
4615.250410 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
4615.250422 s: VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
4615.250430 s: VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
4615.277388 s: VX_ZONE_ERROR:[ownContextSendCmd:814] Command ack message returned failure cmd_status: -1
4615.277416 s: VX_ZONE_ERROR:[ownContextSendCmd:850] tivxEventWait() failed.
4615.277429 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
4615.277438 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
4615.277446 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
4615.277456 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!!
4615.277468 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
4615.277477 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
4615.277583 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
4615.277592 s: VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
4615.277602 s: VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
4615.304353 s: VX_ZONE_ERROR:[ownContextSendCmd:814] Command ack message returned failure cmd_status: -1
4615.304382 s: VX_ZONE_ERROR:[ownContextSendCmd:850] tivxEventWait() failed.
4615.304395 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
4615.304404 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
4615.304414 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
4615.304424 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!!
4615.304437 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
4615.304445 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
4615.304553 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
4615.304562 s: VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
4615.304572 s: VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
4615.331440 s: VX_ZONE_ERROR:[ownContextSendCmd:814] Command ack message returned failure cmd_status: -1
4615.331470 s: VX_ZONE_ERROR:[ownContextSendCmd:850] tivxEventWait() failed.
4615.331484 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
4615.331493 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
4615.331501 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
4615.331509 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!!
4615.331522 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
4615.331531 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
4615.331636 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
4615.331649 s: VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
4615.331654 s: VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
^C 4615.358661 s: VX_ZONE_ERROR:[ownContextSendCmd:814] Command ack message returned failure cmd_status: -1
4615.358689 s: VX_ZONE_ERROR:[ownContextSendCmd:850] tivxEventWait() failed.
4615.358702 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
4615.358710 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
4615.358719 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
4615.358729 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!!
4615.358741 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
4615.358750 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
4615.358855 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
4615.358864 s: VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
4615.358871 s: VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
Traceback (most recent call last):
File "./onnxrt_ep.py", line 271, in <module>
run_model(model, mIdx)
File "./onnxrt_ep.py", line 200, in run_model
imgs, output, proc_time, sub_graph_time, height, width = infer_image(sess, input_images, config)
File "./onnxrt_ep.py", line 114, in infer_image
output = list(sess.run(None, {input_name: input_data}))
File "/usr/local/lib/python3.8/dist-packages/onnxruntime/capi/onnxruntime_inference_collection.py", line 188, in run
return self._sess.run(output_names, input_feed, run_options)
KeyboardInterrupt
4615.383060 s: VX_ZONE_INIT:[tivxHostDeInitLocal:100] De-Initialization Done for HOST !!!
4615.387453 s: VX_ZONE_INIT:[tivxDeInitLocal:193] De-Initialization Done !!!
APP: Deinit ... !!!
REMOTE_SERVICE: Deinit ... !!!
REMOTE_SERVICE: Deinit ... Done !!!
IPC: Deinit ... !!!
IPC: DeInit ... Done !!!
MEM: Deinit ... !!!
DDR_SHARED_MEM: Alloc's: 7 alloc's of 12813124 bytes
DDR_SHARED_MEM: Free's : 7 free's of 12813124 bytes
DDR_SHARED_MEM: Open's : 0 allocs of 0 bytes
DDR_SHARED_MEM: Total size: 536870912 bytes
MEM: Deinit ... Done !!!
APP: Deinit ... Done !!!
Please help me solve this problem. Thank you.
Maiunlei
  • Hi Maiunlei,
    Can you please confirm which sdk version you are using for this experiment ?
    linux sdk comes with edgeai-tidl-tools directory, are you using same or you have cloned again ?
    What is TIDL_TOOLS_PATH set to ?
    This will help us to reproduce this issue at our end and help you better.
    Pratik
  • Hi Pratik,
    I found the reason, my previous version about pc, evm and sdk may not correspond. I can also run " python3 onnxrt_ep.py" successfully.But, the program runs particularly slowly. A warning has emerged.
    My questions:
    1. Inferencing on evm is slow, is this normal?
    2.Can you explain the difference between " python3 onnxrt_ep.py" , " python3 onnxrt_ep.py -d" and " python3 onnxrt_ep.py -c" ?
    3.If I want to use "root@tda4vm-sk:/opt/edge_ai_apps/apps_python# ./app_edgeai.py ../configs/image_classification.yaml" to run my own training model, what parameters to modify? For example, the param.yaml content of the mode. Is there any relevant thread or links for this question?
    Thank you,
    Maiunlei
  • Hi Maiunlei,
    I have replicated this issue, here are my observation.
    Yes, the inferencing took some time to complete, and warnings are also visible at my end.
    But to confirm the model inferencing results you can check output dumps for models here : /opt/edgeai-tidl-tools/output_images.
    Deference between python3 onnxrt_ep.py -d python3 onnxrt_ep.py -c is available here : https://github.com/TexasInstruments/edgeai-tidl-tools/blob/master/examples/osrt_python/README.md
    I cant locate similar documentation for enabling this at this moment but for any custom compiled model to execute on target you need below mentioned files/folders.
    Artifacts , dataset.yaml, model , param.yaml, run.log.
    After this you need to set the model_artifact path in config file to use it for inferencing.
    Pratik
