TDA4VM: Why does the remoteproc mode fail on tda4-vh evm?
Part Number: TDA4VH
Hi,TI
I am using tda4-vh evm board. and boot ok  with prebuilt binary using sdk version 08.05.00.11.
When uboot startup,I canceled the rproc boot process.So only kernel and dtb/dtbo have been loaded and boot.
When  the driver k3-dsp-rproc and ti_k3_r5_remoteproc have been insmod autolly,I can see it's using remoteproc mode,not IPC-only mode.
But when I run and check the vision_apps_init.sh to printe other cores msg, I found that they are stuck in sync.
What do I need to change to boot non-a72 core normally or which step is wrong?
    Could you please share the full logs?
    In the logs for ./vision_apps_init.sh, could you tell me if there are any core that is still "Waiting for HLOS to be ready" and not proceeded from there?
    It would be because of this core that all the cores are stuck in APP: Sync.
    Nikhil
  • Sorry, correct my statement. What I see is that mcuX_0 and all c7X cores in sync when starting, but mcuX_1 cores are not. The specific process is as follows
    I use emmc-boot to start, and then put rootfs in the 12th emm-user partition,The environment variable is set as follows.
    => env default -fa
    ## Resetting to default environment
    => setenv bootcmd 'run findfdt; setenv bootpart 0:c;setenv mmcdev 0;mmc dev ${mmcdev};setenv dorprocboot 1;setenv name_overlays k3-j784s4-vision-apps.dtbo; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern'
    => boot
    Start the log as follows:
    Model: Texas Instruments J784S4 EVM
    DRAM:  32 GiB
    Flash: 0 Bytes
    MMC:   mmc@4f80000: 0, mmc@4fb0000: 1
    Loading Environment from MMC... OK
    In:    serial@2880000
    Out:   serial@2880000
    Err:   serial@2880000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    Net:   eth0: ethernet@46000000port@1
    Hit any key to stop autoboot:  0
    => env default -fa
    => boot
    switch to partitions #0, OK
    mmc0(part 0) is current device
    k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
    k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
    1400100 bytes read in 26 ms (51.4 MiB/s)
    Load Remote Processor 2 with data@addr=0x82000000 1400100 bytes: Success!
    297932 bytes read in 14 ms (20.3 MiB/s)
    Load Remote Processor 3 with data@addr=0x82000000 297932 bytes: Success!
    179128 bytes read in 12 ms (14.2 MiB/s)
    Load Remote Processor 4 with data@addr=0x82000000 179128 bytes: Success!
    Load Remote Processor 5 with data@addr=0x82000000 179128 bytes: Success!
    592760 bytes read in 17 ms (33.3 MiB/s)
    Load Remote Processor 6 with data@addr=0x82000000 592760 bytes: Success!
    Load Remote Processor 7 with data@addr=0x82000000 179128 bytes: Success!
    14815416 bytes read in 180 ms (78.5 MiB/s)
    Load Remote Processor 8 with data@addr=0x82000000 14815416 bytes: Success!
    15208632 bytes read in 183 ms (79.3 MiB/s)
    Load Remote Processor 9 with data@addr=0x82000000 15208632 bytes: Success!
    Load Remote Processor 10 with data@addr=0x82000000 14815416 bytes: Success!
    14815416 bytes read in 179 ms (78.9 MiB/s)
    Load Remote Processor 11 with data@addr=0x82000000 14815416 bytes: Success!
    18608640 bytes read in 222 ms (79.9 MiB/s)
    86934 bytes read in 10 ms (8.3 MiB/s)
    13942 bytes read in 9 ms (1.5 MiB/s)
       Loading Device Tree to 000000008fee7000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.153-g90c3a58fd2 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Sun Dec 18 12:04:18 UTC 2022
    [    0.000000] Machine model: Texas Instruments J784S4 EVM
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@aa000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@aa100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 48 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000af000000, size 80 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@af000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b4100000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@b4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b7400000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b7400000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b7500000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@b7500000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ba800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_2-dma-memory@ba800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ba900000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_2-memory@ba900000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000bdc00000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_3-dma-memory@bdc00000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000bdd00000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_3-memory@bdd00000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e1000000, size 80 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@e1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e6000000, size 8 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e6800000, size 24 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e6800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 1024 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x0000000fffffefff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000c0ffffff]
    [    0.000000]   node   0: [mem 0x00000000c1000000-0x00000000e0ffffff]
    [    0.000000]   node   0: [mem 0x00000000e1000000-0x00000000e7ffffff]
    [    0.000000]   node   0: [mem 0x00000000e8000000-0x00000000ffffefff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008bfffffff]
    [    0.000000]   node   0: [mem 0x00000008c0000000-0x0000000fffffefff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000fffffefff]
    [    0.000000] On node 0, zone Normal: 1 pages in unavailable ranges
    [    0.000000] cma: Reserved 360 MiB at 0x00000000e9400000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 8257534
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs) root=PARTUUID=35019295-16bc-ed45-ad98-b4b3993f8c35 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x000000009a800000-0x000000009e800000] (64MB)
    [    0.000000] Memory: 30211456K/33554424K available (10880K kernel code, 1148K rwdata, 4212K rodata, 1792K init, 432K bss, 2974328K reserved, 368640K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008c0050000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c0060000
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000003] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008466] Console: colour dummy device 80x25
    [    0.013043] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023723] pid_max: default: 32768 minimum: 301
    [    0.028504] LSM: Security Framework initializing
    [    0.033411] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.041322] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.051089] rcu: Hierarchical SRCU implementation.
    [    0.056287] Platform MSI: msi-controller@1820000 domain created
    [    0.062550] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.071926] EFI services will not be available.
    [    0.077047] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    I/TC: Secondary CPU 2 initializing
    I/TC: Secondary CPU 2 switching to normal world boot
    I/TC: Secondary CPU 3 initializing
    I/TC: Secondary CPU 3 switching to normal world boot
    I/TC: Secondary CPU 4 initializing
    I/TC: Secondary CPU 4 switching to normal world boot
    I/TC: Secondary CPU 5 initializing
    I/TC: Secondary CPU 5 switching to normal world boot
    [    0.090441] Detected PIPT I-cache on CPU1
    [    0.090465] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.090479] GICv3: CPU1: using allocated LPI pending table @0x00000008c0070000
    [    0.090520] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.099407] Detected PIPT I-cache on CPU2
    [    0.099434] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
    [    0.099449] GICv3: CPU2: using allocated LPI pending table @0x00000008c0080000
    [    0.099488] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
    [    0.108341] Detected PIPT I-cache on CPU3
    [    0.108369] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
    [    0.108384] GICv3: CPU3: using allocated LPI pending table @0x00000008c0090000
    [    0.108424] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
    [    0.117271] Detected PIPT I-cache on CPU4
    [    0.117303] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
    [    0.117319] GICv3: CPU4: using allocated LPI pending table @0x00000008c00a0000
    [    0.117361] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
    [    0.126257] Detected PIPT I-cache on CPU5
    [    0.126289] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
    [    0.126305] GICv3: CPU5: using allocated LPI pending table @0x00000008c00b0000
    [    0.126346] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
    [    0.135189] Detected PIPT I-cache on CPU6
    [    0.135220] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
    [    0.135236] GICv3: CPU6: using allocated LPI pending table @0x00000008c00c0000
    [    0.135276] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
    [    0.144105] Detected PIPT I-cache on CPU7
    [    0.144139] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
    [    0.144155] GICv3: CPU7: using allocated LPI pending table @0x00000008c00d0000
    [    0.144194] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
    [    0.144330] smp: Brought up 1 node, 8 CPUs
    [    0.325544] SMP: Total of 8 processors activated.
    [    0.330364] CPU features: detected: 32-bit EL0 Support
    [    0.335645] CPU features: detected: CRC32 instructions
    [    0.351593] CPU: All CPU(s) started at EL2
    [    0.355830] alternatives: patching kernel code
    [    0.361228] devtmpfs: initialized
    [    0.396969] KASLR disabled due to lack of seed
    [    0.401879] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.411869] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
    [    0.423044] pinctrl core: initialized pinctrl subsystem
    [    0.429031] DMI not present or invalid.
    [    0.433349] NET: Registered protocol family 16
    [    0.439659] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
    [    0.447776] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.456597] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.465532] thermal_sys: Registered thermal governor 'step_wise'
    [    0.465537] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.472033] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.485847] ASID allocator initialised with 65536 entries
    [    0.530832] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.537715] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.544576] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.551432] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.560246] cryptd: max_cpu_qlen set to 1000
    [    0.569194] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
    [    0.578461] vsys_3v3: supplied by evm_12v0
    [    0.583188] vsys_5v0: supplied by evm_12v0
    [    0.589211] iommu: Default domain type: Translated
    [    0.594638] SCSI subsystem initialized
    [    0.598947] mc: Linux media interface: v0.10
    [    0.603384] videodev: Linux video capture interface: v2.00
    [    0.609221] pps_core: LinuxPPS API ver. 1 registered
    [    0.614319] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.623689] PTP clock support registered
    [    0.627738] EDAC MC: Ver: 3.0.0
    [    0.632546] FPGA manager framework
    [    0.636145] Advanced Linux Sound Architecture Driver Initialized.
    [    0.643690] clocksource: Switched to clocksource arch_sys_counter
    [    0.650100] VFS: Disk quotas dquot_6.6.0
    [    0.654174] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.673645] Carveout Heap: Exported 512 MiB at 0x00000000c1000000
    [    0.679979] NET: Registered protocol family 2
    [    0.685105] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.696419] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
    [    0.705540] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.714647] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
    [    0.722692] TCP: Hash tables configured (established 262144 bind 65536)
    [    0.729629] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.736985] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.744898] NET: Registered protocol family 1
    [    0.750018] RPC: Registered named UNIX socket transport module.
    [    0.756095] RPC: Registered udp transport module.
    [    0.760909] RPC: Registered tcp transport module.
    [    0.765724] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.772324] PCI: CLS 0 bytes, default 64
    [    0.777499] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.792784] Initialise system trusted keyrings
    [    0.797569] workingset: timestamp_bits=46 max_order=23 bucket_order=0
    [    0.816415] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.823353] NFS: Registering the id_resolver key type
    [    0.828568] Key type id_resolver registered
    [    0.832854] Key type id_legacy registered
    [    0.837124] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.843987] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.851763] 9p: Installing v9fs 9p2000 file system support
    [    0.877486] Key type asymmetric registered
    [    0.881689] Asymmetric key parser 'x509' registered
    [    0.886715] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.894283] io scheduler mq-deadline registered
    [    0.898914] io scheduler kyber registered
    [    0.906636] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.912862] pinctrl-single 11c000.pinctrl: 72 pins, size 288
    [    0.924117] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.930476] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.943173] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.974157] brd: module loaded
    [    0.987719] loop: module loaded
    [    0.992313] megasas: 07.714.04.00-rc1
    [    1.001899] tun: Universal TUN/TAP device driver, 1.6
    [    1.007612] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    1.014034] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    1.020165] sky2: driver version 1.30
    [    1.025278] VFIO - User Level meta-driver version: 0.3
    [    1.031873] i2c /dev entries driver
    [    1.037631] sdhci: Secure Digital Host Controller Interface driver
    [    1.043960] sdhci: Copyright(c) Pierre Ossman
    [    1.048894] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.056171] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.062715] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.071198] optee: probing for conduit method.
    [    1.075769] optee: revision 3.19 (afacf356)
    [    1.076132] optee: dynamic shared memory is enabled
    [    1.085757] optee: initialized driver
    [    1.091833] NET: Registered protocol family 17
    [    1.096566] 9pnet: Installing 9P2000 support
    [    1.101010] Key type dns_resolver registered
    [    1.105510] Loading compiled-in X.509 certificates
    [    1.117246] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    1.123776] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    1.132626] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar')
    [    1.177648] pca953x 0-0020: supply vcc not found, using dummy regulator
    [    1.184584] pca953x 0-0020: using no AI
    [    1.212805] pca953x 0-0022: supply vcc not found, using dummy regulator
    [    1.219752] pca953x 0-0022: using AI
    [    1.224421] omap_i2c 2000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.232087] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created
    [    1.240814] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created
    [    1.250196] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
    [    1.258944] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
    [    1.273168] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
    [    1.283062] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.289833] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.304192] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
    [    1.314355] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.321133] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.329487] printk: console [ttyS2] disabled
    [    1.333914] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 21, base_baud = 3000000) is a 8250
    [    1.342670] printk: console [ttyS2] enabled
    [    1.351116] printk: bootconsole [ns16550a0] disabled
    [    1.403709] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.412958] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.421354] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.434297] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.441522] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.448278] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
    [    1.499708] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.508803] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
    [    1.517027] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.529885] am65-cpsw-nuss c200000.ethernet: Use random MAC address
    [    1.536165] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
    [    1.543293] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
    [    1.549976] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:250000000, add_val:3 pps:0
    [    1.562026] mmc0: CQHCI version 5.10
    [    1.575545] vdd_mmc1: supplied by vsys_3v3
    [    1.581741] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
    [    1.588955] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
    [    1.596210] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
    [    1.603429] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100
    [    1.608508] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.610678] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
    [    1.624677] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100
    [    1.704616] mmc0: Command Queue Engine enabled
    [    1.709089] mmc0: new HS200 MMC card at address 0001
    [    1.714856] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    1.719660] mmcblk0boot0: mmc0:0001 G1M15L partition 1 31.5 MiB
    [    1.725844] mmcblk0boot1: mmc0:0001 G1M15L partition 2 31.5 MiB
    [    1.731982] mmcblk0rpmb: mmc0:0001 G1M15L partition 3 4.00 MiB, chardev (237:0)
    [    1.742299]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
    [    2.357800] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
    [    2.372468] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
    [    2.391375] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    2.396382] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    2.402997] Creating 7 MTD partitions on "47040000.spi.0":
    [    2.408480] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    2.415733] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    2.422763] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    2.429862] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    2.436810] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    2.444281] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    2.451397] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    2.460868] mmc1: CQHCI version 5.10
    [    2.461970] debugfs: Directory 'pd:73' with parent 'pm_genpd' already present!
    [    2.471817] debugfs: Directory 'pd:72' with parent 'pm_genpd' already present!
    [    2.479464] debugfs: Directory 'pd:333' with parent 'pm_genpd' already present!
    [    2.486826] debugfs: Directory 'pd:332' with parent 'pm_genpd' already present!
    [    2.501190] ALSA device list:
    [    2.504169]   No soundcards found.
    [    2.505811] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    2.523271] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: (null)
    [    2.531550] VFS: Mounted root (ext4 filesystem) on device 179:12.
    [    2.539363] devtmpfs: mounted
    [    2.543135] Freeing unused kernel memory: 1792K
    [    2.555769] Run /sbin/init as init process
    [    2.646610] systemd[1]: System time before build time, advancing clock.
    [    2.669691] mmc1: new high speed SDHC card at address aaaa
    [    2.675937] mmcblk1: mmc1:aaaa SC32G 29.7 GiB
    [    2.683089] NET: Registered protocol family 10
    [    2.685217]  mmcblk1: p1 p2 p3 p4
    [    2.688849] Segment Routing with IPv6
    [    2.706520] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    2.729139] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [    2.776299] systemd[1]: Set hostname to <j784s4-evm>.
    [    2.783851] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.790548] systemd[1]: Initializing machine ID from random generator.
    [    3.058006] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
    [    3.148742] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.155599] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    3.167969] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    3.181599] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    3.203881] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.213110] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    3.238177] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    3.260195] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    3.284154] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    3.308043] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    3.323971] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    3.343928] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    3.359952] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    3.377514] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    3.399951] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    3.422982] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    3.444239] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    3.474321] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    3.483150] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    3.508570] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    3.524524] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    3.548480] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    3.572322] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    3.598397] systemd[1]: Mounting Huge Pages File System...
    [    3.621983] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.650111] systemd[1]: Mounting Kernel Debug File System...
    [    3.674091] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    3.698423] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st…odes for the current kernel...
    [    3.729974] systemd[1]: Starting Start psplash boot splash screen...
    [    3.758241] systemd[1]: Starting RPC Bind...
    [    3.772050] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    3.788873] systemd[1]: Starting Journal Service...
    [    3.805479] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    3.805625] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.826504] systemd[1]: Starting Load Kernel Modules...
    [    3.842397] cryptodev: loading out-of-tree module taints kernel.
    [    3.848750] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.857581] cryptodev: driver 1.10 loaded.
    [    3.864813] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    3.886976] EXT4-fs (mmcblk0p12): re-mounted. Opts: (null)
    [    3.900999] systemd[1]: Starting udev Coldplug all Devices...
    [    3.933383] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    3.952461] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta… nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    4.214854] systemd-journald[196]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
             Starting Create System Users...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create System Users.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Rebuild Dynamic Linker Cache...
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Create Volatile Files and Directories.
    [    4.861017] random: systemd: uninitialized urandom read (16 bytes read)
             Starting Run pending postinsts...
    [    4.914111] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    4.922374] random: systemd: uninitialized urandom read (16 bytes read)
             Starting Rebuild Journal Catalog...
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Rebuild Journal Catalog.
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started udev Coldplug all Devices.
             Starting udev Wait for Complete Device Initialization...
    [    5.301479] random: crng init done
    [    5.305029] random: 70 urandom warning(s) missed due to ratelimiting
    [  OK  ] Started Load/Save Random Seed.
    [    5.377314] CAN device driver interface
    [    5.397627] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b4000000
    [    5.420143] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [    5.440250] remoteproc remoteproc0: 64800000.dsp is available
    [    5.492656] PVR_K:  231: Read BVNC 36.53.104.796 from HW device registers
    [    5.511987] remoteproc remoteproc0: attaching to 64800000.dsp
    [    5.524945] PVR_K:  231: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [    5.536002] vdec 4210000.video-codec: sram node not found
    [    5.568701] remoteproc remoteproc0: unsupported resource 65538
    [    5.575029] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [    5.581947]  remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@b4000000
    [    5.582918] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    5.588802] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [    5.596394] vdec 4220000.video-codec: sram node not found
    [  OK  ] Started Network Time Synchronizatio[    5.605552]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    n.
    [  OK  ] Reached target System Time Set.[    5.626717] remoteproc remoteproc0: remote processor 64800000.dsp is now attached
    [    5.640508] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
    [    5.642904] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@b7400000
    [  OK  ] Reached target System Time Synchronized.
    [    5.668647] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
    [    5.675655] remoteproc remoteproc1: 65800000.dsp is available
    [    5.678866] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    5.693891] platform 41000000.r5f: configured R5F for IPC-only mode
    [    5.701516] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    5.702626] remoteproc remoteproc1: attaching to 65800000.dsp
    [    5.713260] remoteproc remoteproc2: 41000000.r5f is available
    [    5.716832] remoteproc remoteproc1: unsupported resource 65538
    [    5.722576] remoteproc remoteproc2: attaching to 41000000.r5f
    [    5.728488] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode
    [    5.734463] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    5.740921]  remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-c71_1-dma-memory@b7400000
    [    5.748011]  remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    5.758165] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    5.763266] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [    5.767526] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    5.773546]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    5.779470]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [    5.784736] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
    [    5.785079] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [    5.785762] remoteproc remoteproc1: remote processor 65800000.dsp is now attached
    [    5.791084] remoteproc remoteproc2: remote processor 41000000.r5f is now attached
    [    5.805452] k3-dsp-rproc 66800000.dsp: assigned reserved memory node vision-apps-c71_2-dma-memory@ba800000
    [    5.841605] platform 5c00000.r5f: configured R5F for IPC-only mode
    [    5.844516] k3-dsp-rproc 66800000.dsp: configured DSP for IPC-only mode
    [    5.849551] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    5.891004] remoteproc remoteproc4: 5c00000.r5f is available
    [    5.900816] remoteproc remoteproc4: attaching to 5c00000.r5f
    [    5.907190] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [    5.914801] remoteproc remoteproc3: 66800000.dsp is available
    [    5.923460] remoteproc remoteproc3: attaching to 66800000.dsp
    [    5.929446]  remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    5.939470] remoteproc remoteproc3: unsupported resource 65538
    [    5.956941] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    5.962835] k3-dsp-rproc 66800000.dsp: DSP initialized in IPC-only mode
    [    5.981441] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
    [    6.002671]  remoteproc4#vdev0buffer: registered virtio3 (type 7)
    [    6.010641]  remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-c71_2-dma-memory@ba800000
    [    6.024706] remoteproc remoteproc4: remote processor 5c00000.r5f is now attached
    [    6.035309] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    6.040052] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [    6.041591]  remoteproc3#vdev0buffer: registered virtio4 (type 7)
    [    6.054149] remoteproc remoteproc3: remote processor 66800000.dsp is now attached
    [    6.065146] platform 5d00000.r5f: configured R5F for IPC-only mode
    [    6.076110] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [    6.077321] k3-dsp-rproc 67800000.dsp: assigned reserved memory node vision-apps-c71_3-dma-memory@bdc00000
    [    6.089441] remoteproc remoteproc5: 5d00000.r5f is available
    [    6.101075] remoteproc remoteproc5: attaching to 5d00000.r5f
    [    6.107061] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [    6.113751]  remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [    6.124273] virtio_rpmsg_bus virtio5: rpmsg host is online
    [    6.130125] k3-dsp-rproc 67800000.dsp: configured DSP for IPC-only mode
    [    6.137105] remoteproc remoteproc6: 67800000.dsp is available
    [    6.144048] remoteproc remoteproc6: attaching to 67800000.dsp
    [    6.150102] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [    6.152156]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
    [    6.170789] remoteproc remoteproc6: unsupported resource 65538
    [    6.171257] m_can_platform 40528000.can: m_can device registered (irq=15, version=32)
    [    6.177023] k3-dsp-rproc 67800000.dsp: DSP initialized in IPC-only mode
    [    6.186368] remoteproc remoteproc5: remote processor 5d00000.r5f is now attached
    [    6.197422] m_can_platform 40568000.can: m_can device registered (irq=17, version=32)
    [    6.217111]  remoteproc6#vdev0buffer: assigned reserved memory node vision-apps-c71_3-dma-memory@bdc00000
    [    6.226977] platform 5e00000.r5f: configured R5F for IPC-only mode
    [    6.233578] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [    6.236499] virtio_rpmsg_bus virtio6: rpmsg host is online
    [    6.242793] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd
    [    6.251324]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
    [    6.254849] remoteproc remoteproc7: 5e00000.r5f is available
    [    6.254946] remoteproc remoteproc7: attaching to 5e00000.r5f
    [    6.255163] platform 5e00000.r5f: R5F core initialized in IPC-only mode
    [    6.255186]  remoteproc7#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [    6.256221] m_can_platform 26a1000.can: m_can device registered (irq=29, version=32)
    [    6.268849] virtio_rpmsg_bus virtio7: rpmsg host is online
    [    6.277559] remoteproc remoteproc6: remote processor 67800000.dsp is now attached
    [    6.291146] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xd
    [    6.357762]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
    [    6.408794] remoteproc remoteproc7: remote processor 5e00000.r5f is now attached
    [    6.430936] platform 5f00000.r5f: configured R5F for IPC-only mode
    [    6.438311] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [  OK  ] Started Rebuild Dynamic Linker Cach[    6.451552] remoteproc remoteproc8: 5f00000.r5f is available
    e.
    [    6.459419] remoteproc remoteproc8: attaching to 5f00000.r5f
    [    6.466107] platform 5f00000.r5f: R5F core initialized in IPC-only mode
    [    6.473191]  remoteproc8#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [    6.483459] virtio_rpmsg_bus virtio8: rpmsg host is online
    [    6.490252]  remoteproc8#vdev0buffer: registered virtio8 (type 7)
    [    6.497977] remoteproc remoteproc8: remote processor 5f00000.r5f is now attached
    [    6.505822] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0xd
    [    6.515979] platform 5900000.r5f: configured R5F for IPC-only mode
    [    6.526223] platform 5900000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
             Starting Update is Completed...
    [    6.540550] remoteproc remoteproc9: 5900000.r5f is available
    [    6.546682] remoteproc remoteproc9: attaching to 5900000.r5f
    [    6.552698] platform 5900000.r5f: R5F core initialized in IPC-only mode
    [    6.559815]  remoteproc9#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
    [    6.570110] virtio_rpmsg_bus virtio9: rpmsg host is online
    [  OK  ] Started Update is Completed.
    [    6.578119]  remoteproc9#vdev0buffer: registered virtio9 (type 7)
    [    6.587781] remoteproc remoteproc9: remote processor 5900000.r5f is now attached
    [    6.592276] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0xd
    [    6.602735] platform 5a00000.r5f: configured R5F for IPC-only mode
    [    6.604467] platform 5a00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@aa000000
    [    6.623612] remoteproc remoteproc10: 5a00000.r5f is available
    [    6.629638] remoteproc remoteproc10: attaching to 5a00000.r5f
    [    6.635853] platform 5a00000.r5f: R5F core initialized in IPC-only mode
    [    6.642859]  remoteproc10#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@aa000000
    [    6.653675] virtio_rpmsg_bus virtio10: rpmsg host is online
    [    6.662820]  remoteproc10#vdev0buffer: registered virtio10 (type 7)
    [    6.669202] remoteproc remoteproc10: remote processor 5a00000.r5f is now attached
    [    6.675743] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0xd
    [    6.684324] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0x15
    [    6.691953] virtio_rpmsg_bus virtio10: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.699879] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
    [    6.709423] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.717247] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
    [    6.724743] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.732562] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0x15
    [    6.740021] virtio_rpmsg_bus virtio9: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.747917] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
    [    6.755566] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.763411] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x15
    [    6.770836] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.778617] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
    [    6.786060] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
    [    6.793523] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.801339] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x15
    [    6.808792] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.816621] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0x15
    [    6.823977] virtio_rpmsg_bus virtio8: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.831859] virtio_rpmsg_bus virtio3: creating channel ti.ethfw.notifyservice addr 0x1e
    [    6.840153] virtio_rpmsg_bus virtio3: creating channel rpmsg-kdrv addr 0x1a
    [    6.850571] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 2
    [    6.861539] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0) 15/Dec/2022 SHA:53d1099b
    [    6.872539] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 2
    [    6.883277] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0) 15/Dec/2022 SHA:53d1099b
    [    6.968243] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.976095] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_mtu[0]:2024 flow_idx:114 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:0
    [    7.009090] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac0: virt_cpsw_nuss mac loaded
    [    7.017069] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:114 tx_psil_dst_id:4A00 mac_only:0
    [    7.029768] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
    [    7.043128] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:115 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:1d:92:c2 mac-only:1
    [    7.068676] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac loaded
    [    7.076715] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rdev_features:00000007 rdev_mtu:1522 flow_id:115 tx_psil_dst_id:4A01 mac_only:1
    [    7.089380] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c2
    [    7.477699] usbcore: registered new interface driver usbfs
    [    7.483455] usbcore: registered new interface driver hub
    [    7.489643] usbcore: registered new device driver usb
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [  OK  ] Found device /dev/mmcblk0p9.
    [  OK  ] Found device /dev/mmcblk0p4.
    [  OK  ] Found device /dev/mmcblk0p7.
             Starting File System Check on /dev/mmcblk0p10...
             Starting File System Check on /dev/mmcblk0p11...
             Starting File System Check on /dev/mmcblk0p3...
             Starting File System Check on /dev/mmcblk0p4...
             Starting File System Check on /dev/mmcblk0p5...
             Starting File System Check on /dev/mmcblk0p6...
             Starting File System Check on /dev/mmcblk0p7...
             Starting File System Check on /dev/mmcblk0p8...
             Starting File System Check on /dev/mmcblk0p9...
             Starting File System Check on /dev/mmcblk1p3...
    [  OK  ] Found device /dev/mmcblk1p4.
    [  OK  ] Started File System Check on /dev/mmcblk0p10.
             Mounting /run/media/mmcblk0p10...
             Starting File System Check on /dev/mmcblk1p4...
    [  OK  ] Started File System Check on /dev/mmcblk0p11.
    [  OK  ] Started File System Check on /dev/mmcblk0p3.
             Mounting /run/media/mmcblk0p11...
    [    8.872626] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null)
             Mounting /run/media/mmcblk0p3...
    [  OK  ] Started File System Check on /dev/mmcblk0p4.
    [  OK  ] Mounted /run/media/mmcblk0p10.
             Mounting /run/media/mmcblk0p4...
    [  OK  ] Started File System Check on /dev/mmcblk0p9.
             Mounting /run/media/mmcblk0p9...
    [    8.940568] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Started File System Check on /dev/mmcblk0p6.
    [  OK  ] Started File System Check on /dev/mmcblk0p7.
    [  OK  ] Started File System Check on /dev/mmcblk0p8.
    [  OK  ] Started     8.978675] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
    39mFile System Check on /dev/mmcblk1p3.
    [  OK  ] Mounted /run/media/mmcblk0p11.
    /dev/mmcblk0p5: f[    8.998074] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
             Mounting /run/media/mmcblk0p6...
             Mounting /run/media/mmcblk0p7...
             Mounting /run/media/mmcblk0p8...
             Mounting /run/media/mmcblk1p3...
    [    9.030662] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: (null)
    [    9.048676] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
    [    9.056900] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
    [    9.064640] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Started File System Check on /dev/mmcblk1p4.
    [  OK  ] Mounted /run/media/mmcblk0p3.
    [  OK  ] Mounted /run/media/mmcblk0p4.
    [  OK  ] Mounted /run/media/mmcblk0p9.
    [  OK  ] Mounted /run/media/mmcblk0p6.
    [  OK  ] Mounted /run/media/mmcblk0p7.
    [  OK  ] Mounted /run/media/mmcblk0p8.
    [  OK  ] Found device /dev/mmcblk1p1.
    [  OK  ] Found device /dev/mmcblk1p2.
    [  OK  ] Started udev Wait for Complete Device Initialization.
             Mounting /run/media/mmcblk1p4...
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
             Starting File System Check on /dev/mmcblk1p1...
             Starting File System Check on /dev/mmcblk1p2...
    [    9.174561] EXT4-fs (mmcblk1p3): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Mounted /run/media/mmcblk1p3.
    [    9.236787] EXT4-fs (mmcblk1p4): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Mounted /run/media/mmcblk1p4.
    [  OK  ] Started File System Check on /dev/mmcblk1p2.
             Mounting /run/media/mmcblk1p2...
    [    9.515500] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Started File System Check on /dev/mmcblk1p1.
    [  OK  ] Mounted /run/media/mmcblk1p2.
             Mounting /run/media/mmcblk1p1...
    [  OK  ] Mounted /run/media/mmcblk1p1.
    [  OK  ] Started File System Check on /dev/mmcblk0p5.
             Mounting /run/media/mmcblk0p5...
    [   10.220902] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Mounted /run/media/mmcblk0p5.
    [  OK  ] Started Run pending postinsts.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting rc.pvr.service...
             Starting Login Service...
    [  OK  ] Started TEE Supplicant.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Reached target Network (Pre).
             Starting Network Service...
    [  OK  ] Started Telephony service.
    [   11.063043] Bluetooth: Core ver 2.22
    [   11.066811] NET: Registered protocol family 31
    [   11.071315] Bluetooth: HCI device and connection manager initialized
    [   11.078354] Bluetooth: HCI socket layer initialized
    [   11.083291] Bluetooth: L2CAP socket layer initialized
    [   11.088510] Bluetooth: SCO socket layer initialized
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [  OK  ] Started Login Service.
    [   11.333172] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac started
    [   11.365695] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac0: virt_cpsw_nuss mac started
    [   11.396236] am65-cpsw-nuss c200000.ethernet: down msc_sl e0000000 tmo 0
    [   11.407875] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
    [   11.429570] am65-cpsw-nuss c200000.ethernet eth1: PHY [c200f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [   11.438937] am65-cpsw-nuss c200000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [   11.461386] am65-cpsw-nuss 46000000.ethernet: down msc_sl f0000000 tmo 0
    [   11.472266] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [   11.490909] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [   11.500458] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [  OK  ] Started rc.pvr.service.
             Starting weston.service...
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
    NOTICE: This file system contains the following GPLv3 packages:
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gstreamer1.0-libav-dev
            gstreamer1.0-libav
            gzip
            less
            libasm1
            libbfd
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libreadline-dev
            libreadline8
            libunistring-dev
            libunistring2
            m4-dev
            m4
            make
            nettle-dev
            nettle
            parted
            python3-rfc3987
            python3-strict-rfc3339
            tar
            which
            zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
    [  OK  ] Started weston.service.
             Starting telnetd.service...
    [  OK  ] Started telnetd.service.
    [   14.716956] PVR_K:  1786: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
    [   14.727886] PVR_K:  1786: Shader binary image 'rgx.sh.36.53.104.796' loaded
    [   15.605247] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [   15.613986] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project j784s4-evm ttyS2
    Arago 2021.09 j784s4-evm ttyS2
    j784s4-evm login: root
    root@j784s4-evm:~#
    root@j784s4-evm:~#
    root@j784s4-evm:~#
    root@j784s4-evm:~#
    root@j784s4-evm:~# cd /opt/vision_apps/
    root@j784s4-evm:/opt/vision_apps#
    root@j784s4-evm:/opt/vision_apps# ./vision_apps_init.sh
    root@j784s4-evm:/opt/vision_apps# [MCU2_0]    964.355078 s: CIO: Init ... Done !!!
    [MCU2_0]    964.355130 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_0]    964.355161 s: CPU is running FreeRTOS
    [MCU2_0]    964.355182 s: APP: Init ... !!!
    [MCU2_0]    964.355201 s: SCICLIENT: Init ... !!!
    [MCU2_0]    964.355342 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [MCU2_0]    964.355375 s: SCICLIENT: DMSC FW revision 0x8
    [MCU2_0]    964.355403 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU2_0]    964.355434 s: SCICLIENT: Init ... Done !!!
    [MCU2_0]    964.355458 s: UDMA: Init ... !!!
    [MCU2_0]    964.356407 s: UDMA: Init ... Done !!!
    [MCU2_0]    964.356445 s: UDMA: Init ... !!!
    [MCU2_0]    964.356970 s: UDMA: Init for CSITX/CSIRX ... Done !!!
    [MCU2_0]    964.357008 s: MEM: Init ... !!!
    [MCU2_0]    964.357041 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e2000000 of size 16777216 bytes !!!
    [MCU2_0]    964.357101 s: MEM: Init ... Done !!!
    [MCU2_0]    964.357123 s: IPC: Init ... !!!
    [MCU2_0]    964.357172 s: IPC: 11 CPUs participating in IPC !!!
    [MCU2_0]    964.357212 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_0]    976.627573 s: IPC: HLOS is ready !!!
    [MCU2_0]    976.652503 s: IPC: Init ... Done !!!
    [MCU2_0]    976.652557 s: APP: Syncing with 10 CPUs ... !!!
    [MCU2_0]    977.346871 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU2_0]    977.346909 s: REMOTE_SERVICE: Init ... !!!
    [MCU2_0]    977.348642 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU2_0]    977.348686 s: ETHFW: Init ... !!!
    [MCU2_0]    977.454893 s: Warning: Using 6 MAC address(es) from static pool
    [MCU2_0]    977.454984 s: ETHFW: Shared multicasts (software fanout):
    [MCU2_0]    977.455016 s:   01:00:5e:00:00:01
    [MCU2_0]    977.455060 s:   01:00:5e:00:00:fb
    [MCU2_0]    977.455102 s:   01:00:5e:00:00:fc
    [MCU2_0]    977.455144 s:   33:33:00:00:00:01
    [MCU2_0]    977.455185 s:   33:33:ff:1d:92:c2
    [MCU2_0]    977.455227 s:   01:80:c2:00:00:00
    [MCU2_0]    977.455268 s:   01:80:c2:00:00:03
    [MCU2_0]    977.455310 s: ETHFW: Reserved multicasts:
    [MCU2_0]    977.455334 s:   01:80:c2:00:00:0e
    [MCU2_0]    977.455375 s:   01:1b:19:00:00:00
    [MCU2_0]    977.455578 s: EnetMcm: CPSW_9G on MAIN NAVSS
    [MCU2_0]    977.474838 s:
    [MCU2_0] ETHFW Version   : 0.02.00
    [MCU2_0]    977.474907 s: ETHFW Build Date: Dec 15, 2022
    [MCU2_0]    977.474933 s: ETHFW Build Time: 05:15:47
    [MCU2_0]    977.474955 s: ETHFW Commit SHA: 53d1099b
    [MCU2_0]    977.475014 s: ETHFW: Init ... DONE !!!
    [MCU2_0]    977.475038 s: ETHFW: Remove server Init ... !!!
    [MCU2_0]    977.475198 s: CpswProxyServer: Virtual port configuration:
    [MCU2_0]    977.475238 s:   mpu_1_0 <-> Switch port 0: mpu_1_0_ethswitch-device-0
    [MCU2_0]    977.475277 s:   mcu_2_1 <-> Switch port 1: mcu_2_1_ethswitch-device-1
    [MCU2_0]    977.475315 s:   mpu_1_0 <-> MAC port 1: mpu_1_0_ethmac-device-1
    [MCU2_0]    977.475351 s:   mcu_2_1 <-> MAC port 4: mcu_2_1_ethmac-device-4
    [MCU2_0]    977.476320 s: CpswProxyServer: initialization completed (core: mcu2_0)
    [MCU2_0]    977.476361 s: ETHFW: Remove server Init ... DONE !!!
    [MCU2_0]    977.477424 s: Starting lwIP, local interface IP is dhcp-enabled
    [MCU2_0]    977.483816 s: Host MAC address: 70:ff:76:1d:92:c3
    [MCU2_0]    977.487624 s: [LWIPIF_LWIP] Enet LLD netif initialized successfully
    [MCU2_0]    977.522687 s: [LWIPIF_LWIP_IC] Interface started successfully
    [MCU2_0]    977.522737 s: [LWIPIF_LWIP_IC] NETIF INIT SUCCESS
    [MCU2_0]    977.526874 s: FVID2: Init ... !!!
    [MCU2_0]    977.526940 s: FVID2: Init ... Done !!!
    [MCU2_0]    977.526967 s: SCICLIENT: Sciclient_pmSetModuleState module=275 state=2
    [MCU2_0]    977.527116 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.527163 s: DSS: Init ... !!!
    [MCU2_0]    977.527185 s: DSS: Display type is eDP !!!
    [MCU2_0]    977.527209 s: DSS: SoC init ... !!!
    [MCU2_0]    977.527230 s: SCICLIENT: Sciclient_pmSetModuleState module=218 state=0
    [MCU2_0]    977.527312 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.527340 s: SCICLIENT: Sciclient_pmSetModuleState module=404 state=2
    [MCU2_0]    977.527412 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.527438 s: SCICLIENT: Sciclient_pmSetModuleState module=217 state=2
    [MCU2_0]    977.527546 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.527573 s: SCICLIENT: Sciclient_pmSetModuleState module=404 state=2
    [MCU2_0]    977.527640 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.527666 s: SCICLIENT: Sciclient_pmSetModuleState module=217 state=2
    [MCU2_0]    977.527728 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.527754 s: SCICLIENT: Sciclient_pmSetModuleState module=218 state=0
    [MCU2_0]    977.527816 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.527843 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=218 clk=3 freq=148500000
    [MCU2_0]    977.529338 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success
    [MCU2_0]    977.529374 s: SCICLIENT: Sciclient_pmModuleClkRequest module=218 clk=3 state=2 flag=2
    [MCU2_0]    977.529552 s: SCICLIENT: Sciclient_pmModuleClkRequest success
    [MCU2_0]    977.529581 s: SCICLIENT: Sciclient_pmSetModuleState module=218 state=2
    [MCU2_0]    977.529718 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.529745 s: DSS: SoC init ... Done !!!
    [MCU2_0]    977.529768 s: DSS: Board init ... !!!
    [MCU2_0]    977.529790 s: DSS: Board init ... Done !!!
    [MCU2_0]    977.548666 s: DSS: Init ... Done !!!
    [MCU2_0]    977.548714 s: VHWA: VPAC Init ... !!!
    [MCU2_0]    977.548737 s: SCICLIENT: Sciclient_pmSetModuleState module=399 state=2
    [MCU2_0]    977.548964 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.548999 s: VHWA: LDC Init ... !!!
    [MCU2_0]    977.551208 s: VHWA: LDC Init ... Done !!!
    [MCU2_0]    977.551255 s: VHWA: MSC Init ... !!!
    [MCU2_0]    977.560342 s: VHWA: MSC Init ... Done !!!
    [MCU2_0]    977.560388 s: VHWA: NF Init ... !!!
    [MCU2_0]    977.561499 s: VHWA: NF Init ... Done !!!
    [MCU2_0]    977.561539 s: VHWA: VISS Init ... !!!
    [MCU2_0]    977.566895 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6
    [MCU2_0]    977.569332 s: VHWA: VISS Init ... Done !!!
    [MCU2_0]    977.569379 s: VHWA: VPAC Init ... Done !!!
    [MCU2_0]    977.569416 s:  VX_ZONE_INIT:Enabled
    [MCU2_0]    977.569442 s:  VX_ZONE_ERROR:Enabled
    [MCU2_0]    977.569465 s:  VX_ZONE_WARNING:Enabled
    [MCU2_0]    977.570510 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-0
    [MCU2_0]    977.570704 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_NF
    [MCU2_0]    977.571000 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_LDC1
    [MCU2_0]    977.571192 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC1
    [MCU2_0]    977.571380 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC2
    [MCU2_0]    977.571598 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_VISS1
    [MCU2_0]    977.571779 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE1
    [MCU2_0]    977.572031 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE2
    [MCU2_0]    977.572236 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY1
    [MCU2_0]    977.572429 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY2
    [MCU2_0]    977.572600 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CSITX
    [MCU2_0]    977.572808 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE3
    [MCU2_0]    977.573113 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE4
    [MCU2_0]    977.573320 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE5
    [MCU2_0]    977.573517 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE6
    [MCU2_0]    977.573710 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE7
    [MCU2_0]    977.573998 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE8
    [MCU2_0]    977.574201 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M1
    [MCU2_0]    977.574405 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M2
    [MCU2_0]    977.574597 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M3
    [MCU2_0]    977.574787 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M4
    [MCU2_0]    977.575096 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CSITX2
    [MCU2_0]    977.575322 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE9
    [MCU2_0]    977.575526 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE10
    [MCU2_0]    977.575713 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE11
    [MCU2_0]    977.576000 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE12
    [MCU2_0]    977.576048 s:  VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!!
    [MCU2_0]    977.576079 s: APP: OpenVX Target kernel init ... !!!
    [MCU2_0]    977.603516 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU2_0]    977.603564 s: CSI2RX: Init ... !!!
    [MCU2_0]    977.603586 s: SCICLIENT: Sciclient_pmSetModuleState module=189 state=2
    [MCU2_0]    977.603691 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.603720 s: SCICLIENT: Sciclient_pmSetModuleState module=72 state=2
    [MCU2_0]    977.603837 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.603942 s: SCICLIENT: Sciclient_pmSetModuleState module=73 state=2
    [MCU2_0]    977.604041 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.604069 s: SCICLIENT: Sciclient_pmSetModuleState module=74 state=2
    [MCU2_0]    977.604149 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.604176 s: SCICLIENT: Sciclient_pmSetModuleState module=212 state=2
    [MCU2_0]    977.604244 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.604271 s: SCICLIENT: Sciclient_pmSetModuleState module=213 state=2
    [MCU2_0]    977.604345 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.604371 s: SCICLIENT: Sciclient_pmSetModuleState module=214 state=2
    [MCU2_0]    977.604441 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.604680 s: CSI2RX: Init ... Done !!!
    [MCU2_0]    977.604709 s: CSI2TX: Init ... !!!
    [MCU2_0]    977.604729 s: SCICLIENT: Sciclient_pmSetModuleState module=189 state=2
    [MCU2_0]    977.604804 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.604832 s: SCICLIENT: Sciclient_pmSetModuleState module=75 state=2
    [MCU2_0]    977.604996 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.605032 s: SCICLIENT: Sciclient_pmSetModuleState module=76 state=2
    [MCU2_0]    977.605111 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.605139 s: SCICLIENT: Sciclient_pmSetModuleState module=402 state=2
    [MCU2_0]    977.605200 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    977.605281 s: CSI2TX: Init ... Done !!!
    [MCU2_0]    977.605305 s: ISS: Init ... !!!
    [MCU2_0]    977.605336 s: IssSensor_Init ... Done !!!
    [MCU2_0]    977.605391 s: IttRemoteServer_Init ... Done !!!
    [MCU2_0]    977.605420 s: VISS REMOTE SERVICE: Init ... !!!
    [MCU2_0]    977.605478 s: VISS REMOTE SERVICE: Init ... Done !!!
    [MCU2_0]    977.605505 s: UDMA Copy: Init ... !!!
    [MCU2_0]    977.606681 s: UDMA Copy: Init ... Done !!!
    [MCU2_0]    977.606762 s: APP: Init ... Done !!!
    [MCU2_0]    977.606788 s: APP: Run ... !!!
    [MCU2_0]    977.606810 s: IPC: Starting echo test ...
    [MCU2_0]    977.611690 s: APP: Run ... Done !!!
    [MCU2_0]    977.638403 s: [LWIPIF_LWIP_IC] Interface started successfully
    [MCU2_0]    977.638444 s: [LWIPIF_LWIP_IC] NETIF INIT SUCCESS
    [MCU2_0]    977.638533 s: Added interface 'br4', IP is 0.0.0.0
    [MCU2_0]    977.640523 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[.] mcu3_1[.] mcu4_0[.] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_0]    977.640647 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[.] mcu4_0[.] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_0]    977.640750 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[.] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_0]    977.640854 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_0]    977.641070 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_0]    977.641180 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_0]    977.641284 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[.] c7x_4[.]
    [MCU2_0]    977.641385 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[.]
    [MCU2_0]    977.641488 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU2_0]    977.712636 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6
    [MCU2_0]    982.000635 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a3c31674,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c2, FlowIdx:115, FlowIdxOffset:1
    [MCU2_0]    982.012210 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3c31674,CoreKey:38acb7e6,mode:disable
    [MCU2_0]    982.012577 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3c31674,CoreKey:38acb7e6,mode:disable
    [MCU2_0]    982.012901 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3c31674,CoreKey:38acb7e6,mode:disable
    [MCU2_0]    982.030423 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a3c31674,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1, FlowIdx:114, FlowIdxOffset:0
    [MCU2_0]    982.036118 s: Cpsw_ioctlInternal: CPSW: Registered MAC address. ALE entry:11, Policer Entry:2
    [MCU2_0]    982.044511 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3c31674,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:1, vlanId:0, FlowIdx:114, FlowIdOffset:0
    [MCU2_0]    982.047647 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3c31674,CoreKey:38acb7e6, MacAddress:1:0:5e:0:0:1, vlanId:0, FlowIdx:114, FlowIdOffset:0
    [MCU2_0]    982.050788 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3c31674,CoreKey:38acb7e6, MacAddress:33:33:ff:1d:92:c1, vlanId:0, FlowIdx:114, FlowIdOffset:0
    [MCU2_0]    982.185172 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3c31674,CoreKey:38acb7e6,mode:disable
    [MCU2_0]    982.222842 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3c31674,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:0, vlanId:0, FlowIdx:114, FlowIdOffset:0
    [MCU2_0]    982.226521 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3c31674,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:3, vlanId:0, FlowIdx:114, FlowIdOffset:0
    [MCU2_0]    982.229639 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3c31674,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:e, vlanId:0, FlowIdx:114, FlowIdOffset:0
    [MCU2_0]    982.229751 s: CpswProxyServer_isRsvdMcast: Reserved mcast cannot be added to filter
    [MCU2_0]    982.271011 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3c31674,CoreKey:38acb7e6,mode:disable
    [MCU2_0]    982.271354 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3c31674,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:fb, vlanId:0, FlowIdx:114, FlowIdOffset:0
    [MCU2_0]    983.910857 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3c31674,CoreKey:38acb7e6,mode:disable
    [MCU2_0]    984.040719 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3c31674,CoreKey:38acb7e6, MacAddress:33:33:0:1:0:3, vlanId:0, FlowIdx:114, FlowIdOffset:0
    [MCU2_1]    964.284652 s: CIO: Init ... Done !!!
    [MCU2_1]    964.284702 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_1]    964.284734 s: CPU is running FreeRTOS
    [MCU2_1]    964.284755 s: APP: Init ... !!!
    [MCU2_1]    964.284774 s: SCICLIENT: Init ... !!!
    [MCU2_1]    964.284927 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [MCU2_1]    964.284961 s: SCICLIENT: DMSC FW revision 0x8
    [MCU2_1]    964.284988 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU2_1]    964.285020 s: SCICLIENT: Init ... Done !!!
    [MCU2_1]    964.285043 s: UDMA: Init ... !!!
    [MCU2_1]    964.286138 s: UDMA: Init ... Done !!!
    [MCU2_1]    964.286177 s: MEM: Init ... !!!
    [MCU2_1]    964.286213 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e3000000 of size 16777216 bytes !!!
    [MCU2_1]    964.286276 s: MEM: Init ... Done !!!
    [MCU2_1]    964.286299 s: IPC: Init ... !!!
    [MCU2_1]    964.286343 s: IPC: 11 CPUs participating in IPC !!!
    [MCU2_1]    964.286382 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_1]    976.794901 s: IPC: HLOS is ready !!!
    [MCU2_1]    976.818421 s: IPC: Init ... Done !!!
    [MCU2_1]    976.818469 s: APP: Syncing with 10 CPUs ... !!!
    [MCU2_1]    977.346868 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU2_1]    977.346907 s: REMOTE_SERVICE: Init ... !!!
    [MCU2_1]    977.348667 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU2_1]    977.348709 s: FVID2: Init ... !!!
    [MCU2_1]    977.348771 s: FVID2: Init ... Done !!!
    [MCU2_1]    977.348797 s: VHWA: DMPAC: Init ... !!!
    [MCU2_1]    977.348823 s: SCICLIENT: Sciclient_pmSetModuleState module=92 state=2
    [MCU2_1]    977.348968 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_1]    977.348999 s: SCICLIENT: Sciclient_pmSetModuleState module=96 state=2
    [MCU2_1]    977.349087 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_1]    977.349123 s: VHWA: DOF Init ... !!!
    [MCU2_1]    977.355496 s: VHWA: DOF Init ... Done !!!
    [MCU2_1]    977.355547 s: VHWA: SDE Init ... !!!
    [MCU2_1]    977.357046 s: VHWA: SDE Init ... Done !!!
    [MCU2_1]    977.357084 s: VHWA: DMPAC: Init ... Done !!!
    [MCU2_1]    977.357124 s:  VX_ZONE_INIT:Enabled
    [MCU2_1]    977.357151 s:  VX_ZONE_ERROR:Enabled
    [MCU2_1]    977.357177 s:  VX_ZONE_WARNING:Enabled
    [MCU2_1]    977.358169 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-1
    [MCU2_1]    977.358366 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_SDE
    [MCU2_1]    977.358545 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_DOF
    [MCU2_1]    977.358591 s:  VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!!
    [MCU2_1]    977.358621 s: APP: OpenVX Target kernel init ... !!!
    [MCU2_1]    977.358860 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU2_1]    977.358895 s: APP: Init ... Done !!!
    [MCU2_1]    977.358921 s: APP: Run ... !!!
    [MCU2_1]    977.358944 s: IPC: Starting echo test ...
    [MCU2_1]    977.363448 s: APP: Run ... Done !!!
    [MCU2_1]    977.364772 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_1]    977.364893 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_1]    977.365001 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_1]    977.365105 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_1]    977.365210 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[.] c7x_4[.]
    [MCU2_1]    977.365319 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[.]
    [MCU2_1]    977.365425 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU2_1]    977.410723 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU2_1]    977.640401 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_0]    964.311525 s: CIO: Init ... Done !!!
    [MCU3_0]    964.311578 s: ### CPU Frequency = 1000000000 Hz
    [MCU3_0]    964.311611 s: CPU is running FreeRTOS
    [MCU3_0]    964.311633 s: APP: Init ... !!!
    [MCU3_0]    964.311652 s: SCICLIENT: Init ... !!!
    [MCU3_0]    964.311799 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [MCU3_0]    964.311834 s: SCICLIENT: DMSC FW revision 0x8
    [MCU3_0]    964.311863 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU3_0]    964.311895 s: SCICLIENT: Init ... Done !!!
    [MCU3_0]    964.311918 s: MEM: Init ... !!!
    [MCU3_0]    964.311950 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e4000000 of size 8388608 bytes !!!
    [MCU3_0]    964.312009 s: MEM: Init ... Done !!!
    [MCU3_0]    964.312030 s: IPC: Init ... !!!
    [MCU3_0]    964.312076 s: IPC: 11 CPUs participating in IPC !!!
    [MCU3_0]    964.312114 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU3_0]    976.939485 s: IPC: HLOS is ready !!!
    [MCU3_0]    976.962242 s: IPC: Init ... Done !!!
    [MCU3_0]    976.962289 s: APP: Syncing with 10 CPUs ... !!!
    [MCU3_0]    977.346870 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU3_0]    977.346909 s: REMOTE_SERVICE: Init ... !!!
    [MCU3_0]    977.348693 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU3_0]    977.348750 s:  VX_ZONE_INIT:Enabled
    [MCU3_0]    977.348775 s:  VX_ZONE_ERROR:Enabled
    [MCU3_0]    977.348799 s:  VX_ZONE_WARNING:Enabled
    [MCU3_0]    977.349826 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU3-0
    [MCU3_0]    977.349876 s:  VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!!
    [MCU3_0]    977.349908 s: APP: OpenVX Target kernel init ... !!!
    [MCU3_0]    977.349934 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU3_0]    977.349960 s: APP: Init ... Done !!!
    [MCU3_0]    977.349982 s: APP: Run ... !!!
    [MCU3_0]    977.350004 s: IPC: Starting echo test ...
    [MCU3_0]    977.354701 s: APP: Run ... Done !!!
    [MCU3_0]    977.355933 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[.] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU3_0]    977.356054 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[.] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[.] c7x_4[.]
    [MCU3_0]    977.356204 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[.] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[.] c7x_4[P]
    [MCU3_0]    977.356362 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[.] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_0]    977.356550 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_0]    977.356657 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_0]    977.364060 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[s] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_0]    977.410669 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[s] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_0]    977.640411 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[s] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_1]    964.340296 s: CIO: Init ... Done !!!
    [MCU3_1]    964.340351 s: ### CPU Frequency = 1000000000 Hz
    [MCU3_1]    964.340383 s: CPU is running FreeRTOS
    [MCU3_1]    964.340404 s: APP: Init ... !!!
    [MCU3_1]    964.340424 s: SCICLIENT: Init ... !!!
    [MCU3_1]    964.340571 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [MCU3_1]    964.340608 s: SCICLIENT: DMSC FW revision 0x8
    [MCU3_1]    964.340636 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU3_1]    964.340667 s: SCICLIENT: Init ... Done !!!
    [MCU3_1]    964.340691 s: MEM: Init ... !!!
    [MCU3_1]    964.340723 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e4800000 of size 8388608 bytes !!!
    [MCU3_1]    964.340781 s: MEM: Init ... Done !!!
    [MCU3_1]    964.340803 s: IPC: Init ... !!!
    [MCU3_1]    964.340846 s: IPC: 11 CPUs participating in IPC !!!
    [MCU3_1]    964.340885 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU3_1]    977.154098 s: IPC: HLOS is ready !!!
    [MCU3_1]    977.176770 s: IPC: Init ... Done !!!
    [MCU3_1]    977.176818 s: APP: Syncing with 10 CPUs ... !!!
    [MCU3_1]    977.346871 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU3_1]    977.346911 s: REMOTE_SERVICE: Init ... !!!
    [MCU3_1]    977.348722 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU3_1]    977.348776 s:  VX_ZONE_INIT:Enabled
    [MCU3_1]    977.348802 s:  VX_ZONE_ERROR:Enabled
    [MCU3_1]    977.348825 s:  VX_ZONE_WARNING:Enabled
    [MCU3_1]    977.349856 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU3-1
    [MCU3_1]    977.349905 s:  VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!!
    [MCU3_1]    977.349946 s: APP: OpenVX Target kernel init ... !!!
    [MCU3_1]    977.349973 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU3_1]    977.349999 s: APP: Init ... Done !!!
    [MCU3_1]    977.350022 s: APP: Run ... !!!
    [MCU3_1]    977.350043 s: IPC: Starting echo test ...
    [MCU3_1]    977.354722 s: APP: Run ... Done !!!
    [MCU3_1]    977.355902 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[s] mcu4_0[x] mcu4_1[x] c7x_1[.] c7x_2[P] c7x_3[.] c7x_4[.]
    [MCU3_1]    977.356072 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[s] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[.] c7x_4[.]
    [MCU3_1]    977.356196 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[s] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[.] c7x_4[P]
    [MCU3_1]    977.356338 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[s] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_1]    977.356538 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_1]    977.356829 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_1]    977.364073 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_1]    977.410692 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[s] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_1]    977.640437 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[s] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_0]    964.411206 s: CIO: Init ... Done !!!
    [MCU4_0]    964.411263 s: ### CPU Frequency = 1000000000 Hz
    [MCU4_0]    964.411293 s: CPU is running FreeRTOS
    [MCU4_0]    964.411315 s: APP: Init ... !!!
    [MCU4_0]    964.411334 s: SCICLIENT: Init ... !!!
    [MCU4_0]    964.411481 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [MCU4_0]    964.411515 s: SCICLIENT: DMSC FW revision 0x8
    [MCU4_0]    964.411543 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU4_0]    964.411574 s: SCICLIENT: Init ... Done !!!
    [MCU4_0]    964.411597 s: UDMA: Init ... !!!
    [MCU4_0]    964.412668 s: UDMA: Init ... Done !!!
    [MCU4_0]    964.412705 s: MEM: Init ... !!!
    [MCU4_0]    964.412739 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e5000000 of size 8388608 bytes !!!
    [MCU4_0]    964.412798 s: MEM: Init ... Done !!!
    [MCU4_0]    964.412828 s: IPC: Init ... !!!
    [MCU4_0]    964.412875 s: IPC: 11 CPUs participating in IPC !!!
    [MCU4_0]    964.412915 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU4_0]    977.240747 s: IPC: HLOS is ready !!!
    [MCU4_0]    977.263430 s: IPC: Init ... Done !!!
    [MCU4_0]    977.263478 s: APP: Syncing with 10 CPUs ... !!!
    [MCU4_0]    977.346869 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU4_0]    977.346908 s: REMOTE_SERVICE: Init ... !!!
    [MCU4_0]    977.348910 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU4_0]    977.348950 s: FVID2: Init ... !!!
    [MCU4_0]    977.349006 s: FVID2: Init ... Done !!!
    [MCU4_0]    977.349035 s: VHWA: VPAC Init ... !!!
    [MCU4_0]    977.349063 s: SCICLIENT: Sciclient_pmSetModuleState module=400 state=2
    [MCU4_0]    977.349206 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU4_0]    977.349308 s: VHWA: LDC Init ... !!!
    [MCU4_0]    977.353758 s: VHWA: LDC Init ... Done !!!
    [MCU4_0]    977.353798 s: VHWA: MSC Init ... !!!
    [MCU4_0]    977.362982 s: VHWA: MSC Init ... Done !!!
    [MCU4_0]    977.363017 s: VHWA: NF Init ... !!!
    [MCU4_0]    977.364063 s: VHWA: NF Init ... Done !!!
    [MCU4_0]    977.364099 s: VHWA: VISS Init ... !!!
    [MCU4_0]    977.371700 s: VHWA: VISS Init ... Done !!!
    [MCU4_0]    977.371745 s: VHWA: VPAC Init ... Done !!!
    [MCU4_0]    977.371786 s:  VX_ZONE_INIT:Enabled
    [MCU4_0]    977.371811 s:  VX_ZONE_ERROR:Enabled
    [MCU4_0]    977.371840 s:  VX_ZONE_WARNING:Enabled
    [MCU4_0]    977.372749 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU4-0
    [MCU4_0]    977.372950 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC2_NF
    [MCU4_0]    977.373133 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC2_LDC1
    [MCU4_0]    977.373314 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC2_MSC1
    [MCU4_0]    977.373488 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC2_MSC2
    [MCU4_0]    977.373711 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC2_VISS1
    [MCU4_0]    977.373755 s:  VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!!
    [MCU4_0]    977.373788 s: APP: OpenVX Target kernel init ... !!!
    [MCU4_0]    977.404166 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU4_0]    977.404207 s: VISS REMOTE SERVICE: Init ... !!!
    [MCU4_0]    977.404268 s: VISS REMOTE SERVICE: Init ... Done !!!
    [MCU4_0]    977.404297 s: UDMA Copy: Init ... !!!
    [MCU4_0]    977.405357 s: UDMA Copy: Init ... Done !!!
    [MCU4_0]    977.405396 s: APP: Init ... Done !!!
    [MCU4_0]    977.405421 s: APP: Run ... !!!
    [MCU4_0]    977.405443 s: IPC: Starting echo test ...
    [MCU4_0]    977.410023 s: APP: Run ... Done !!!
    [MCU4_0]    977.411486 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[.] mcu3_1[.] mcu4_0[s] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU4_0]    977.411609 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[.] mcu4_0[s] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU4_0]    977.411718 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU4_0]    977.411828 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU4_0]    977.411936 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[P] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU4_0]    977.412041 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[.] c7x_4[.]
    [MCU4_0]    977.412146 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[.]
    [MCU4_0]    977.412251 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_0]    977.640455 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_1]    964.404305 s: CIO: Init ... Done !!!
    [MCU4_1]    964.404360 s: ### CPU Frequency = 1000000000 Hz
    [MCU4_1]    964.404392 s: CPU is running FreeRTOS
    [MCU4_1]    964.404413 s: APP: Init ... !!!
    [MCU4_1]    964.404434 s: SCICLIENT: Init ... !!!
    [MCU4_1]    964.404581 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [MCU4_1]    964.404616 s: SCICLIENT: DMSC FW revision 0x8
    [MCU4_1]    964.404644 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU4_1]    964.404675 s: SCICLIENT: Init ... Done !!!
    [MCU4_1]    964.404699 s: MEM: Init ... !!!
    [MCU4_1]    964.404730 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e5800000 of size 8388608 bytes !!!
    [MCU4_1]    964.404792 s: MEM: Init ... Done !!!
    [MCU4_1]    964.404813 s: IPC: Init ... !!!
    [MCU4_1]    964.404856 s: IPC: 11 CPUs participating in IPC !!!
    [MCU4_1]    964.404905 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU4_1]    977.324308 s: IPC: HLOS is ready !!!
    [MCU4_1]    977.346781 s: IPC: Init ... Done !!!
    [MCU4_1]    977.346828 s: APP: Syncing with 10 CPUs ... !!!
    [MCU4_1]    977.346870 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU4_1]    977.346907 s: REMOTE_SERVICE: Init ... !!!
    [MCU4_1]    977.348811 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU4_1]    977.348862 s:  VX_ZONE_INIT:Enabled
    [MCU4_1]    977.348886 s:  VX_ZONE_ERROR:Enabled
    [MCU4_1]    977.348917 s:  VX_ZONE_WARNING:Enabled
    [MCU4_1]    977.349935 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU4-1
    [MCU4_1]    977.349982 s:  VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!!
    [MCU4_1]    977.350012 s: APP: OpenVX Target kernel init ... !!!
    [MCU4_1]    977.350039 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU4_1]    977.350065 s: APP: Init ... Done !!!
    [MCU4_1]    977.350088 s: APP: Run ... !!!
    [MCU4_1]    977.350109 s: IPC: Starting echo test ...
    [MCU4_1]    977.354788 s: APP: Run ... Done !!!
    [MCU4_1]    977.355986 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[.] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU4_1]    977.356120 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[.] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[.] c7x_3[P] c7x_4[.]
    [MCU4_1]    977.356227 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[.] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[.]
    [MCU4_1]    977.356346 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[.] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_1]    977.356574 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_1]    977.356694 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_1]    977.364096 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_1]    977.410701 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_1]    977.640463 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [C7x_1 ]    964.575136 s: CIO: Init ... Done !!!
    [C7x_1 ]    964.575154 s: ### CPU Frequency = 1000000000 Hz
    [C7x_1 ]    964.575167 s: CPU is running FreeRTOS
    [C7x_1 ]    964.575176 s: APP: Init ... !!!
    [C7x_1 ]    964.575185 s: SCICLIENT: Init ... !!!
    [C7x_1 ]    964.575317 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [C7x_1 ]    964.575333 s: SCICLIENT: DMSC FW revision 0x8
    [C7x_1 ]    964.575344 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C7x_1 ]    964.575356 s: SCICLIENT: Init ... Done !!!
    [C7x_1 ]    964.575365 s: UDMA: Init ... !!!
    [C7x_1 ]    964.576332 s: UDMA: Init ... Done !!!
    [C7x_1 ]    964.576345 s: MEM: Init ... !!!
    [C7x_1 ]    964.576357 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 104000000 of size 67108864 bytes !!!
    [C7x_1 ]    964.576378 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 68000000 of size 3145728 bytes !!!
    [C7x_1 ]    964.576398 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 458752 bytes !!!
    [C7x_1 ]    964.576416 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!!
    [C7x_1 ]    964.576434 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 10c000000 of size 67108864 bytes !!!
    [C7x_1 ]    964.576453 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000001) @ 100000000 of size 67108864 bytes !!!
    [C7x_1 ]    964.576472 s: MEM: Created heap (DDR_SCRATCH_NON_, id=6, flags=0x00000001) @ 108000000 of size 67108864 bytes !!!
    [C7x_1 ]    964.576491 s: MEM: Init ... Done !!!
    [C7x_1 ]    964.576500 s: IPC: Init ... !!!
    [C7x_1 ]    964.576516 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_1 ]    964.576533 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_1 ]    976.253558 s: IPC: HLOS is ready !!!
    [C7x_1 ]    976.258617 s: IPC: Init ... Done !!!
    [C7x_1 ]    976.258636 s: APP: Syncing with 10 CPUs ... !!!
    [C7x_1 ]    977.346872 s: APP: Syncing with 10 CPUs ... Done !!!
    [C7x_1 ]    977.346894 s: REMOTE_SERVICE: Init ... !!!
    [C7x_1 ]    977.347143 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_1 ]    977.347171 s:  VX_ZONE_INIT:Enabled
    [C7x_1 ]    977.347189 s:  VX_ZONE_ERROR:Enabled
    [C7x_1 ]    977.347201 s:  VX_ZONE_WARNING:Enabled
    [C7x_1 ]    977.347551 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1
    [C7x_1 ]    977.347689 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_2
    [C7x_1 ]    977.347807 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_3
    [C7x_1 ]    977.347878 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_4
    [C7x_1 ]    977.347950 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_5
    [C7x_1 ]    977.348031 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_6
    [C7x_1 ]    977.348102 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_7
    [C7x_1 ]    977.348169 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_8
    [C7x_1 ]    977.348202 s:  VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!!
    [C7x_1 ]    977.348218 s: APP: OpenVX Target kernel init ... !!!
    [C7x_1 ]    977.348935 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_1 ]    977.348955 s: APP: Init ... Done !!!
    [C7x_1 ]    977.348966 s: APP: Run ... !!!
    [C7x_1 ]    977.348978 s: IPC: Starting echo test ...
    [C7x_1 ]    977.349122 s: APP: Run ... Done !!!
    [C7x_1 ]    977.351995 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[s] c7x_2[x] c7x_3[.] c7x_4[P]
    [C7x_1 ]    977.352204 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[s] c7x_2[x] c7x_3[P] c7x_4[P]
    [C7x_1 ]    977.353729 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
    [C7x_1 ]    977.355892 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[.] mcu4_0[x] mcu4_1[.] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
    [C7x_1 ]    977.355952 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
    [C7x_1 ]    977.356011 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
    [C7x_1 ]    977.364095 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
    [C7x_1 ]    977.410715 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
    [C7x_1 ]    977.640465 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
    [C7x_2 ]    964.775020 s: CIO: Init ... Done !!!
    [C7x_2 ]    964.775037 s: ### CPU Frequency = 1000000000 Hz
    [C7x_2 ]    964.775051 s: CPU is running FreeRTOS
    [C7x_2 ]    964.775061 s: APP: Init ... !!!
    [C7x_2 ]    964.77[   29.948430] Initializing XFRM netlink socket
    5070 s: SCICLIENT: Init ... !!!
    [C7x_2 ]    964.775197 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [C7x_2 ]    964.775213 s: SCICLIENT: DMSC FW revision 0x8
    [C7x_2 ]    964.775226 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C7x_2 ]    964.775238 s: SCICLIENT: Init ... Done !!!
    [C7x_2 ]    964.775249 s: UDMA: Init ... !!!
    [C7x_2 ]    964.776225 s: UDMA: Init ... Done !!!
    [C7x_2 ]    964.776239 s: MEM: Init ... !!!
    [C7x_2 ]    964.776252 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 114000000 of size 67108864 bytes !!!
    [C7x_2 ]    964.776274 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 69000000 of size 3145728 bytes !!!
    [C7x_2 ]    964.776294 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 65800000 of size 458752 bytes !!!
    [C7x_2 ]    964.776313 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 65e00000 of size 16384 bytes !!!
    [C7x_2 ]    964.776332 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 11c000000 of size 67108864 bytes !!!
    [C7x_2 ]    964.776352 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000001) @ 110000000 of size 67108864 bytes !!!
    [C7x_2 ]    964.776372 s: MEM: Created heap (DDR_SCRATCH_NON_, id=6, flags=0x00000001) @ 118000000 of size 67108864 bytes !!!
    [C7x_2 ]    964.776393 s: MEM: Init ... Done !!!
    [C7x_2 ]    964.776403 s: IPC: Init ... !!!
    [C7x_2 ]    964.776419 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_2 ]    964.776437 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_2 ]    976.428806 s: IPC: HLOS is ready !!!
    [C7x_2 ]    976.433888 s: IPC: Init ... Done !!!
    [C7x_2 ]    976.433911 s: APP: Syncing with 10 CPUs ... !!!
    [C7x_2 ]    977.346871 s: APP: Syncing with 10 CPUs ... Done !!!
    [C7x_2 ]    977.346892 s: REMOTE_SERVICE: Init ... !!!
    [C7x_2 ]    977.347135 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_2 ]    977.347164 s:  VX_ZONE_INIT:Enabled
    [C7x_2 ]    977.347180 s:  VX_ZONE_ERROR:Enabled
    [C7x_2 ]    977.347193 s:  VX_ZONE_WARNING:Enabled
    [C7x_2 ]    977.348237 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-2
    [C7x_2 ]    977.348315 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-2_PRI_2
    [C7x_2 ]    977.348388 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-2_PRI_3
    [C7x_2 ]    977.348456 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-2_PRI_4
    [C7x_2 ]    977.348525 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-2_PRI_5
    [C7x_2 ]    977.348594 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-2_PRI_6
    [C7x_2 ]    977.348662 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-2_PRI_7
    [C7x_2 ]    977.348731 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-2_PRI_8
    [C7x_2 ]    977.348758 s:  VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!!
    [C7x_2 ]    977.348775 s: APP: OpenVX Target kernel init ... !!!
    [C7x_2 ]    977.351282 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_2 ]    977.351305 s: UDMA Copy: Init ... !!!
    [C7x_2 ]    977.352919 s: UDMA Copy: Init ... Done !!!
    [C7x_2 ]    977.352939 s: APP: Init ... Done !!!
    [C7x_2 ]    977.352951 s: APP: Run ... !!!
    [C7x_2 ]    977.352961 s: IPC: Starting echo test ...
    [C7x_2 ]    977.353094 s: APP: Run ... Done !!!
    [C7x_2 ]    977.353870 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[s] c7x_3[.] c7x_4[.]
    [C7x_2 ]    977.353942 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[.]
    [C7x_2 ]    977.354001 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
    [C7x_2 ]    977.355888 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
    [C7x_2 ]    977.355988 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
    [C7x_2 ]    977.356047 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
    [C7x_2 ]    977.364111 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
    [C7x_2 ]    977.410730 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
    [C7x_2 ]    977.640478 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
    [C7x_3 ]    964.974413 s: CIO: Init ... Done !!!
    [C7x_3 ]    964.974431 s: ### CPU Frequency = 1000000000 Hz
    [C7x_3 ]    964.974444 s: CPU is running FreeRTOS
    [C7x_3 ]    964.974454 s: APP: Init ... !!!
    [C7x_3 ]    964.974464 s: SCICLIENT: Init ... !!!
    [C7x_3 ]    964.974603 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [C7x_3 ]    964.974619 s: SCICLIENT: DMSC FW revision 0x8
    [C7x_3 ]    964.974632 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C7x_3 ]    964.974645 s: SCICLIENT: Init ... Done !!!
    [C7x_3 ]    964.974656 s: UDMA: Init ... !!!
    [C7x_3 ]    964.975672 s: UDMA: Init ... Done !!!
    [C7x_3 ]    964.975685 s: MEM: Init ... !!!
    [C7x_3 ]    964.975698 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 124000000 of size 67108864 bytes !!!
    [C7x_3 ]    964.975721 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 6a000000 of size 3145728 bytes !!!
    [C7x_3 ]    964.975740 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 66800000 of size 458752 bytes !!!
    [C7x_3 ]    964.975759 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 66e00000 of size 16384 bytes !!!
    [C7x_3 ]    964.975777 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 12c000000 of size 67108864 bytes !!!
    [C7x_3 ]    964.975798 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000001) @ 120000000 of size 67108864 bytes !!!
    [C7x_3 ]    964.975818 s: MEM: Created heap (DDR_SCRATCH_NON_, id=6, flags=0x00000001) @ 128000000 of size 67108864 bytes !!!
    [C7x_3 ]    964.975838 s: MEM: Init ... Done !!!
    [C7x_3 ]    964.975849 s: IPC: Init ... !!!
    [C7x_3 ]    964.975867 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_3 ]    964.975885 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_3 ]    976.705949 s: IPC: HLOS is ready !!!
    [C7x_3 ]    976.710632 s: IPC: Init ... Done !!!
    [C7x_3 ]    976.710651 s: APP: Syncing with 10 CPUs ... !!!
    [C7x_3 ]    977.346872 s: APP: Syncing with 10 CPUs ... Done !!!
    [C7x_3 ]    977.346895 s: REMOTE_SERVICE: Init ... !!!
    [C7x_3 ]    977.347157 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_3 ]    977.347186 s:  VX_ZONE_INIT:Enabled
    [C7x_3 ]    977.347201 s:  VX_ZONE_ERROR:Enabled
    [C7x_3 ]    977.347212 s:  VX_ZONE_WARNING:Enabled
    [C7x_3 ]    977.347520 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-3
    [C7x_3 ]    977.347769 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-3_PRI_2
    [C7x_3 ]    977.347868 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-3_PRI_3
    [C7x_3 ]    977.347953 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-3_PRI_4
    [C7x_3 ]    977.348039 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-3_PRI_5
    [C7x_3 ]    977.348128 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-3_PRI_6
    [C7x_3 ]    977.348218 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-3_PRI_7
    [C7x_3 ]    977.348316 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-3_PRI_8
    [C7x_3 ]    977.348347 s:  VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!!
    [C7x_3 ]    977.348367 s: APP: OpenVX Target kernel init ... !!!
    [C7x_3 ]    977.349166 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_3 ]    977.349186 s: UDMA Copy: Init ... !!!
    [C7x_3 ]    977.351226 s: UDMA Copy: Init ... Done !!!
    [C7x_3 ]    977.351249 s: APP: Init ... Done !!!
    [C7x_3 ]    977.351263 s: APP: Run ... !!!
    [C7x_3 ]    977.351275 s: IPC: Starting echo test ...
    [C7x_3 ]    977.351483 s: APP: Run ... Done !!!
    [C7x_3 ]    977.352231 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[x] c7x_3[s] c7x_4[.]
    [C7x_3 ]    977.352308 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[x] c7x_3[s] c7x_4[P]
    [C7x_3 ]    977.353842 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
    [C7x_3 ]    977.355870 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
    [C7x_3 ]    977.355951 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
    [C7x_3 ]    977.356034 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
    [C7x_3 ]    977.364120 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
    [C7x_3 ]    977.410740 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
    [C7x_3 ]    977.640489 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
    [C7x_4 ]    965.173782 s: CIO: Init ... Done !!!
    [C7x_4 ]    965.173799 s: ### CPU Frequency = 1000000000 Hz
    [C7x_4 ]    965.173813 s: CPU is running FreeRTOS
    [C7x_4 ]    965.173823 s: APP: Init ... !!!
    [C7x_4 ]    965.173833 s: SCICLIENT: Init ... !!!
    [C7x_4 ]    965.173976 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [C7x_4 ]    965.173992 s: SCICLIENT: DMSC FW revision 0x8
    [C7x_4 ]    965.174005 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C7x_4 ]    965.174017 s: SCICLIENT: Init ... Done !!!
    [C7x_4 ]    965.174028 s: UDMA: Init ... !!!
    [C7x_4 ]    965.175032 s: UDMA: Init ... Done !!!
    [C7x_4 ]    965.175045 s: MEM: Init ... !!!
    [C7x_4 ]    965.175058 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 134000000 of size 67108864 bytes !!!
    [C7x_4 ]    965.175081 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 6b000000 of size 3145728 bytes !!!
    [C7x_4 ]    965.175101 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 67800000 of size 458752 bytes !!!
    [C7x_4 ]    965.175120 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 67e00000 of size 16384 bytes !!!
    [C7x_4 ]    965.175138 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 13c000000 of size 67108864 bytes !!!
    [C7x_4 ]    965.175159 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000001) @ 130000000 of size 67108864 bytes !!!
    [C7x_4 ]    965.175179 s: MEM: Created heap (DDR_SCRATCH_NON_, id=6, flags=0x00000001) @ 138000000 of size 67108864 bytes !!!
    [C7x_4 ]    965.175199 s: MEM: Init ... Done !!!
    [C7x_4 ]    965.175209 s: IPC: Init ... !!!
    [C7x_4 ]    965.175226 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_4 ]    965.175244 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_4 ]    976.907137 s: IPC: HLOS is ready !!!
    [C7x_4 ]    976.911222 s: IPC: Init ... Done !!!
    [C7x_4 ]    976.911239 s: APP: Syncing with 10 CPUs ... !!!
    [C7x_4 ]    977.346873 s: APP: Syncing with 10 CPUs ... Done !!!
    [C7x_4 ]    977.346896 s: REMOTE_SERVICE: Init ... !!!
    [C7x_4 ]    977.347165 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_4 ]    977.347194 s:  VX_ZONE_INIT:Enabled
    [C7x_4 ]    977.347209 s:  VX_ZONE_ERROR:Enabled
    [C7x_4 ]    977.347223 s:  VX_ZONE_WARNING:Enabled
    [C7x_4 ]    977.347523 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-4
    [C7x_4 ]    977.347786 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-4_PRI_2
    [C7x_4 ]    977.347881 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-4_PRI_3
    [C7x_4 ]    977.347963 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-4_PRI_4
    [C7x_4 ]    977.348044 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-4_PRI_5
    [C7x_4 ]    977.348128 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-4_PRI_6
    [C7x_4 ]    977.348218 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-4_PRI_7
    [C7x_4 ]    977.348307 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-4_PRI_8
    [C7x_4 ]    977.348331 s:  VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!!
    [C7x_4 ]    977.348345 s: APP: OpenVX Target kernel init ... !!!
    [C7x_4 ]    977.349160 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_4 ]    977.349183 s: UDMA Copy: Init ... !!!
    [C7x_4 ]    977.351043 s: UDMA Copy: Init ... Done !!!
    [C7x_4 ]    977.351061 s: APP: Init ... Done !!!
    [C7x_4 ]    977.351075 s: APP: Run ... !!!
    [C7x_4 ]    977.351087 s: IPC: Starting echo test ...
    [C7x_4 ]    977.351234 s: APP: Run ... Done !!!
    [C7x_4 ]    977.352009 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[x] c7x_3[.] c7x_4[s]
    [C7x_4 ]    977.352237 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[x] c7x_3[P] c7x_4[s]
    [C7x_4 ]    977.353858 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[x] mcu3_1[x] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
    [C7x_4 ]    977.355901 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
    [C7x_4 ]    977.355988 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
    [C7x_4 ]    977.356521 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
    [C7x_4 ]    977.364144 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
    [C7x_4 ]    977.410756 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
    [C7x_4 ]    977.640501 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
    I can see that all cores started normally, and then restart.
    When I delete the 'run boot_rprocs' in bootcmd,the uboot env  is set as follows.
    => env default -fa
    ## Resetting to default environment
    => pri
    addr_fit=0x90000000
    arch=arm
    args_all=setenv optargs earlycon=ns16550a,mmio32,0x02880000 ${mtdparts}
    args_mmc=run finduuid;setenv bootargs console=${console} ${optargs} root=PARTUUID=${uuid} rw rootfstype=${mmcrootfstype}
    args_ufs=setenv devtype scsi;setenv bootpart 1:1;run ufs_finduuid;setenv bootargs console = ${console} ${optargs}root=PARTUUID=${uuid} rw rootfstype=${scsirootfstype};setenv devtype scsi;setenv bootpart 1:1
    baudrate=115200
    board=j784s4
    board_name=j784s4
    boot=mmc
    boot_fdt=try
    boot_fit=0
    boot_rprocs=if test ${dorprocboot} -eq 1 && test ${boot} = mmc; then rproc init;run boot_rprocs_mmc;fi;
    boot_rprocs_mmc=env set rproc_id;env set rproc_fw;env set secure_suffix;if test ${boot_fit} -eq 1; then env set secure_suffix -sec;fi;for i in ${rproc_fw_binaries}; do if test -z "${rproc_id}" ; then env set rproc_id $i;else env set rproc_fw $i${secure_suffix};run rproc_load_and_boot_one;env set rproc_id;env set rproc_fw;fi;done
    bootcmd=run findfdt; run envboot; run init_${boot}; run main_cpsw0_qsgmii_phyinit; run boot_rprocs; if test ${boot_fit} -eq 1; then run get_fit_${boot}; run get_overlaystring; run run_fit; else; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern; fi;
    bootdelay=2
    bootdir=/boot
    bootenvfile=uEnv.txt
    bootm_size=0x10000000
    bootpart=1:2
    bootscript=echo Running bootscript from mmc${mmcdev} ...; source ${loadaddr}
    console=ttyS2,115200n8
    cpu=armv8
    default_device_tree=k3-j784s4-evm.dtb
    dfu_alt_info_emmc=rawemmc raw 0 0x800000 mmcpart 1;rootfs part 0 1 mmcpart 0;tiboot3.bin.raw raw 0x0 0x400 mmcpart 1;tispl.bin.raw raw 0x400 0x1000 mmcpart 1;u-boot.img.raw raw 0x1400 0x2000 mmcpart 1;u-env.raw raw 0x3400 0x100 mmcpart 1;sysfw.itb.raw raw 0x3600 0x800 mmcpart 1
    dfu_alt_info_mmc=boot part 1 1;rootfs part 1 2;tiboot3.bin fat 1 1;tispl.bin fat 1 1;u-boot.img fat 1 1;uEnv.txt fat 1 1;sysfw.itb fat 1 1
    dfu_alt_info_ospi=tiboot3.bin raw 0x0 0x080000;tispl.bin raw 0x080000 0x200000;u-boot.img raw 0x280000 0x400000;u-boot-env raw 0x680000 0x020000;sysfw.itb raw 0x6c0000 0x100000;rootfs raw 0x800000 0x3800000
    dfu_alt_info_ram=tispl.bin ram 0x80080000 0x200000;u-boot.img ram 0x81000000 0x400000
    do_main_cpsw0_qsgmii_phyinit=1
    dorprocboot=0
    dtboaddr=0x89000000
    envboot=mmc dev ${mmcdev}; if mmc rescan; then echo SD/MMC found on device ${mmcdev};if run loadbootscript; then run bootscript;else if run loadbootenv; then echo Loaded env from ${bootenvfile};run importbootenv;fi;if test -n $uenvcmd; then echo Running uenvcmd ...;run uenvcmd;fi;fi;fi;
    fdt_addr_r=0x88000000
    fdtaddr=0x88000000
    fdtoverlay_addr_r=0x80200000
    findfdt=setenv name_fdt ${default_device_tree};setenv fdtfile ${name_fdt}
    finduuid=part uuid ${boot} ${bootpart} uuid
    get_fdt_mmc=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${name_fdt}
    get_fdt_ufs=load ${devtype} ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}
    get_fit_mmc=load mmc ${bootpart} ${addr_fit} ${bootdir}/${name_fit}
    get_kern_mmc=load mmc ${bootpart} ${loadaddr} ${bootdir}/${name_kern}
    get_kern_ufs=load ${devtype} ${bootpart} ${loadaddr} ${bootdir}/${name_kern}
    get_overlay_mmc=fdt address ${fdtaddr};fdt resize 0x100000;for overlay in $name_overlays;do;load mmc ${bootpart} ${dtboaddr} ${bootdir}/${overlay} && fdt apply ${dtboaddr};done;
    get_overlay_ufs=fdt address ${fdtaddr};fdt resize 0x100000;for overlay in $name_overlays;do;load scsi ${bootpart} ${dtboaddr} ${bootdir}/${overlay} && fdt apply ${dtboaddr};done;
    get_overlaystring=for overlay in $name_overlays;do;setenv overlaystring ${overlaystring}'#'${overlay};done;
    importbootenv=echo Importing environment from mmc${mmcdev} ...; env import -t ${loadaddr} ${filesize}
    init_main_cpsw0_qsgmii_phy=gpio set gpio@22_17;gpio clear gpio@22_16
    init_mmc=run args_all args_mmc
    init_ufs=ufs init; scsi scan; run args_ufs
    kernel_addr_r=0x82000000
    loadaddr=0x82000000
    loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenvfile}
    loadbootscript=load mmc ${mmcdev} ${loadaddr} boot.scr
    loadfdt=load ${devtype} ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}
    loadimage=load ${devtype} ${bootpart} ${loadaddr} ${bootdir}/${bootfile}
    main_cpsw0_qsgmii_phyinit=if test ${do_main_cpsw0_qsgmii_phyinit} -eq 1 && test ${dorprocboot} -eq 1 && test ${boot} = mmc; then run init_main_cpsw0_qsgmii_phy; run toggle_mux2_ethfw;fi;
    mmcboot=mmc dev ${mmcdev}; devnum=${mmcdev}; devtype=mmc; if mmc rescan; then echo SD/MMC found on device ${mmcdev};if run loadimage; then run args_mmc; if test ${boot_fit} -eq 1; then run run_fit; else run mmcloados;fi;fi;fi;
    mmcdev=1
    mmcloados=if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run loadfdt; then bootz ${loadaddr} - ${fdtaddr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi;
    mmcrootfstype=ext4 rootwait
    mtdids=nor0=47040000.spi.0,nor0=47034000.hyperbus
    mtdparts=mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs)
    name_fit=fitImage
    name_kern=Image
    partitions=uuid_disk=${uuid_gpt_disk};name=rootfs,start=0,size=-,uuid=${uuid_gpt_rootfs}
    pxefile_addr_r=0x80100000
    ramdisk_addr_r=0x88080000
    rd_spec=-
    rdaddr=0x88080000
    rproc_fw_binaries=2 /lib/firmware/j784s4-main-r5f0_0-fw 3 /lib/firmware/j784s4-main-r5f0_1-fw 4 /lib/firmware/j784s4-main-r5f1_0-fw 5 /lib/firmware/j784s4-main-r5f1_1-fw 6 /lib/firmware/j784s4-main-r5f2_0-fw 7 /lib/firmware/j784s4-main-r5f2_1-fw 8 /lib/firmware/j784s4-c71_0-fw 9 /lib/firmware/j784s4-c71_1-fw 10 /lib/firmware/j784s4-c71_2-fw 11 /lib/firmware/j784s4-c71_3-fw
    rproc_load_and_boot_one=if load mmc ${bootpart} $loadaddr ${rproc_fw}; then if rproc load ${rproc_id} ${loadaddr} ${filesize}; then rproc start ${rproc_id};fi;fi
    run_fit=bootm ${addr_fit}#${fdtfile}${overlaystring}
    run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr}
    scriptaddr=0x80000000
    scsirootfstype=ext4 rootwait
    soc=k3
    toggle_mux2_ethfw=gpio set gpio@22_13; gpio set gpio@22_14;gpio set gpio@22_15
    ufs_finduuid=part uuid scsi ${bootpart} uuid
    update_to_fit=setenv loadaddr ${addr_fit}; setenv bootfile ${name_fit}
    vendor=ti
    Environment size: 6175/131067 bytes
    => setenv bootcmd 'run findfdt; setenv bootpart 0:c;setenv mmcdev 0;mmc dev ${mmcdev};setenv dorprocboot 1;setenv name_overlays k3-j784s4-vision-apps.dtbo; run init_${boot};  run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern'
    Start the log as follows:
    U-Boot SPL 2021.01 (Feb 20 2023 - 09:41:19 +0800)
    SYSFW ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar')
    SPL initial stack usage: 13472 bytes
    Trying to boot from MMC1
    Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
    init_env from device 17 not supported!
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.7(release):v2.7.0-359-g1309c6c805-dirty
    NOTICE:  BL31: Built : 12:02:48, Dec 18 2022
    I/TC:
    I/TC: OP-TEE version: 3.19.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Sun Dec 18 12:03:06 UTC 2022 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar')
    I/TC: HUK Initialized
    I/TC: Activated SA2UL device
    I/TC: Fixing SA2UL firewall owner for GP device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot 2021.01 (Feb 20 2023 - 09:41:19 +0800)
    SoC:   J784S4 SR1.0 GP
    Model: Texas Instruments J784S4 EVM
    DRAM:  32 GiB
    Flash: 0 Bytes
    MMC:   mmc@4f80000: 0, mmc@4fb0000: 1
    Loading Environment from MMC... OK
    In:    serial@2880000
    Out:   serial@2880000
    Err:   serial@2880000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    Net:   eth0: ethernet@46000000port@1
    Hit any key to stop autoboot:  0
    => env default -fa
    => pri
    addr_fit=0x90000000
    arch=arm
    baudrate=115200
    board=j784s4
    board_name=j784s4
    boot=mmc
    boot_fdt=try
    boot_fit=0
    bootdelay=2
    bootdir=/boot
    bootpart=1:2
    cpu=armv8
    dorprocboot=0
    dtboaddr=0x89000000
    fdtaddr=0x88000000
    loadaddr=0x82000000
    mmcdev=1
    name_fit=fitImage
    name_kern=Image
    rd_spec=-
    rdaddr=0x88080000
    soc=k3
    vendor=ti
    => boot
    switch to partitions #0, OK
    mmc0(part 0) is current device
    18608640 bytes read in 222 ms (79.9 MiB/s)
    86934 bytes read in 10 ms (8.3 MiB/s)
    13942 bytes read in 10 ms (1.3 MiB/s)
       Loading Device Tree to 000000008fee7000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.153-g90c3a58fd2 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Sun Dec 18 12:04:18 UTC 2022
    [    0.000000] Machine model: Texas Instruments J784S4 EVM
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@aa000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@aa100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 48 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000af000000, size 80 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@af000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b4100000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@b4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b7400000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b7400000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b7500000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@b7500000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ba800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_2-dma-memory@ba800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ba900000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_2-memory@ba900000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000bdc00000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_3-dma-memory@bdc00000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000bdd00000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_3-memory@bdd00000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e1000000, size 80 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@e1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e6000000, size 8 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e6800000, size 24 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e6800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 1024 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x0000000fffffefff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000c0ffffff]
    [    0.000000]   node   0: [mem 0x00000000c1000000-0x00000000e0ffffff]
    [    0.000000]   node   0: [mem 0x00000000e1000000-0x00000000e7ffffff]
    [    0.000000]   node   0: [mem 0x00000000e8000000-0x00000000ffffefff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008bfffffff]
    [    0.000000]   node   0: [mem 0x00000008c0000000-0x0000000fffffefff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000fffffefff]
    [    0.000000] On node 0, zone Normal: 1 pages in unavailable ranges
    [    0.000000] cma: Reserved 360 MiB at 0x00000000e9400000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 8257534
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs) root=PARTUUID=35019295-16bc-ed45-ad98-b4b3993f8c35 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x000000009a800000-0x000000009e800000] (64MB)
    [    0.000000] Memory: 30211456K/33554424K available (10880K kernel code, 1148K rwdata, 4212K rodata, 1792K init, 432K bss, 2974328K reserved, 368640K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008c0050000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c0060000
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008462] Console: colour dummy device 80x25
    [    0.013036] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023715] pid_max: default: 32768 minimum: 301
    [    0.028484] LSM: Security Framework initializing
    [    0.033363] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.041240] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.050813] rcu: Hierarchical SRCU implementation.
    [    0.055994] Platform MSI: msi-controller@1820000 domain created
    [    0.062245] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.071611] EFI services will not be available.
    [    0.076636] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    I/TC: Secondary CPU 2 initializing
    I/TC: Secondary CPU 2 switching to normal world boot
    I/TC: Secondary CPU 3 initializing
    I/TC: Secondary CPU 3 switching to normal world boot
    I/TC: Secondary CPU 4 initializing
    I/TC: Secondary CPU 4 switching to normal world boot
    I/TC: Secondary CPU 5 initializing
    I/TC: Secondary CPU 5 switching to normal world boot
    [    0.089959] Detected PIPT I-cache on CPU1
    [    0.089984] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.089998] GICv3: CPU1: using allocated LPI pending table @0x00000008c0070000
    [    0.090037] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.098839] Detected PIPT I-cache on CPU2
    [    0.098864] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
    [    0.098878] GICv3: CPU2: using allocated LPI pending table @0x00000008c0080000
    [    0.098918] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
    [    0.107665] Detected PIPT I-cache on CPU3
    [    0.107693] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
    [    0.107708] GICv3: CPU3: using allocated LPI pending table @0x00000008c0090000
    [    0.107747] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
    [    0.116508] Detected PIPT I-cache on CPU4
    [    0.116535] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
    [    0.116549] GICv3: CPU4: using allocated LPI pending table @0x00000008c00a0000
    [    0.116590] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
    [    0.125344] Detected PIPT I-cache on CPU5
    [    0.125374] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
    [    0.125388] GICv3: CPU5: using allocated LPI pending table @0x00000008c00b0000
    [    0.125429] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
    [    0.134163] Detected PIPT I-cache on CPU6
    [    0.134195] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
    [    0.134210] GICv3: CPU6: using allocated LPI pending table @0x00000008c00c0000
    [    0.134249] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
    [    0.142978] Detected PIPT I-cache on CPU7
    [    0.143012] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
    [    0.143027] GICv3: CPU7: using allocated LPI pending table @0x00000008c00d0000
    [    0.143067] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
    [    0.143165] smp: Brought up 1 node, 8 CPUs
    [    0.324354] SMP: Total of 8 processors activated.
    [    0.329172] CPU features: detected: 32-bit EL0 Support
    [    0.334450] CPU features: detected: CRC32 instructions
    [    0.350313] CPU: All CPU(s) started at EL2
    [    0.354546] alternatives: patching kernel code
    [    0.359845] devtmpfs: initialized
    [    0.368002] KASLR disabled due to lack of seed
    [    0.372683] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.382669] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
    [    0.393299] pinctrl core: initialized pinctrl subsystem
    [    0.398984] DMI not present or invalid.
    [    0.403283] NET: Registered protocol family 16
    [    0.409109] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
    [    0.417213] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.426017] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.434520] thermal_sys: Registered thermal governor 'step_wise'
    [    0.434525] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.440936] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.454735] ASID allocator initialised with 65536 entries
    [    0.479625] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.486505] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.493366] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.500224] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.508572] cryptd: max_cpu_qlen set to 1000
    [    0.516774] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
    [    0.525915] vsys_3v3: supplied by evm_12v0
    [    0.530471] vsys_5v0: supplied by evm_12v0
    [    0.535938] iommu: Default domain type: Translated
    [    0.541250] SCSI subsystem initialized
    [    0.545404] mc: Linux media interface: v0.10
    [    0.549814] videodev: Linux video capture interface: v2.00
    [    0.555592] pps_core: LinuxPPS API ver. 1 registered
    [    0.560685] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.570052] PTP clock support registered
    [    0.574091] EDAC MC: Ver: 3.0.0
    [    0.578452] FPGA manager framework
    [    0.581984] Advanced Linux Sound Architecture Driver Initialized.
    [    0.588898] clocksource: Switched to clocksource arch_sys_counter
    [    0.595301] VFS: Disk quotas dquot_6.6.0
    [    0.599376] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.613735] Carveout Heap: Exported 512 MiB at 0x00000000c1000000
    [    0.620062] NET: Registered protocol family 2
    [    0.625086] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.636199] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
    [    0.645350] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.654451] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
    [    0.662460] TCP: Hash tables configured (established 262144 bind 65536)
    [    0.669371] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.676737] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.684636] NET: Registered protocol family 1
    [    0.689648] RPC: Registered named UNIX socket transport module.
    [    0.695724] RPC: Registered udp transport module.
    [    0.700537] RPC: Registered tcp transport module.
    [    0.705349] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.711943] PCI: CLS 0 bytes, default 64
    [    0.716865] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.730191] Initialise system trusted keyrings
    [    0.734958] workingset: timestamp_bits=46 max_order=23 bucket_order=0
    [    0.743556] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.749971] NFS: Registering the id_resolver key type
    [    0.755177] Key type id_resolver registered
    [    0.759468] Key type id_legacy registered
    [    0.763626] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.770494] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.778226] 9p: Installing v9fs 9p2000 file system support
    [    0.803100] Key type asymmetric registered
    [    0.807303] Asymmetric key parser 'x509' registered
    [    0.812329] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.819898] io scheduler mq-deadline registered
    [    0.824533] io scheduler kyber registered
    [    0.831273] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.837483] pinctrl-single 11c000.pinctrl: 72 pins, size 288
    [    0.847898] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.854245] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.864546] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.883731] brd: module loaded
    [    0.892718] loop: module loaded
    [    0.896858] megasas: 07.714.04.00-rc1
    [    0.903753] tun: Universal TUN/TAP device driver, 1.6
    [    0.909382] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.915807] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.921910] sky2: driver version 1.30
    [    0.926799] VFIO - User Level meta-driver version: 0.3
    [    0.933099] i2c /dev entries driver
    [    0.938467] sdhci: Secure Digital Host Controller Interface driver
    [    0.944800] sdhci: Copyright(c) Pierre Ossman
    [    0.949659] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.956690] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.963178] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.971298] optee: probing for conduit method.
    [    0.975880] optee: revision 3.19 (afacf356)
    [    0.976160] optee: dynamic shared memory is enabled
    [    0.985728] optee: initialized driver
    [    0.991306] NET: Registered protocol family 17
    [    0.995971] 9pnet: Installing 9P2000 support
    [    1.000402] Key type dns_resolver registered
    [    1.004937] Loading compiled-in X.509 certificates
    [    1.015645] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    1.022116] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    1.030931] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar')
    [    1.073077] pca953x 0-0020: supply vcc not found, using dummy regulator
    [    1.079973] pca953x 0-0020: using no AI
    [    1.105852] pca953x 0-0022: supply vcc not found, using dummy regulator
    [    1.112738] pca953x 0-0022: using AI
    [    1.117306] omap_i2c 2000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.124695] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created
    [    1.133407] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created
    [    1.142754] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
    [    1.151488] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
    [    1.164620] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
    [    1.174518] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.181290] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.191651] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
    [    1.201833] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.208608] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.216686] printk: console [ttyS2] disabled
    [    1.221101] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 21, base_baud = 3000000) is a 8250
    [    1.229864] printk: console [ttyS2] enabled
    [    1.238308] printk: bootconsole [ns16550a0] disabled
    [    1.288922] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.298038] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.306392] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.319292] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.326515] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.333112] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
    [    1.380919] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.389909] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
    [    1.398084] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.410896] am65-cpsw-nuss c200000.ethernet: Use random MAC address
    [    1.417171] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
    [    1.424299] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
    [    1.430790] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:250000000, add_val:3 pps:0
    [    1.441677] mmc0: CQHCI version 5.10
    [    1.447238] vdd_mmc1: supplied by vsys_3v3
    [    1.452843] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
    [    1.459878] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
    [    1.466885] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
    [    1.473893] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100
    [    1.480923] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
    [    1.486487] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.487916] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100
    [    1.582706] mmc0: Command Queue Engine enabled
    [    1.587180] mmc0: new HS200 MMC card at address 0001
    [    1.592565] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    1.597261] mmcblk0boot0: mmc0:0001 G1M15L partition 1 31.5 MiB
    [    1.603333] mmcblk0boot1: mmc0:0001 G1M15L partition 2 31.5 MiB
    [    1.609402] mmcblk0rpmb: mmc0:0001 G1M15L partition 3 4.00 MiB, chardev (237:0)
    [    1.619557]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
    [    2.226092] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
    [    2.237155] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
    [    2.251251] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    2.256243] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    2.262857] Creating 7 MTD partitions on "47040000.spi.0":
    [    2.268339] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    2.274801] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    2.281136] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    2.287500] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    2.293636] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    2.300314] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    2.306664] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    2.314956] mmc1: CQHCI version 5.10
    [    2.316071] debugfs: Directory 'pd:73' with parent 'pm_genpd' already present!
    [    2.325843] debugfs: Directory 'pd:72' with parent 'pm_genpd' already present!
    [    2.333539] debugfs: Directory 'pd:333' with parent 'pm_genpd' already present!
    [    2.340932] debugfs: Directory 'pd:332' with parent 'pm_genpd' already present!
    [    2.354633] ALSA device list:
    [    2.357614]   No soundcards found.
    [    2.369820] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    2.384555] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: (null)
    [    2.392802] VFS: Mounted root (ext4 filesystem) on device 179:12.
    [    2.400601] devtmpfs: mounted
    [    2.404218] Freeing unused kernel memory: 1792K
    [    2.408970] Run /sbin/init as init process
    [    2.496999] systemd[1]: System time before build time, advancing clock.
    [    2.528549] NET: Registered protocol family 10
    [    2.530789] mmc1: new high speed SDHC card at address aaaa
    [    2.533846] Segment Routing with IPv6
    [    2.538976] mmcblk1: mmc1:aaaa SC32G 29.7 GiB
    [    2.551271]  mmcblk1: p1 p2 p3 p4
    [    2.555024] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    2.577212] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [    2.637394] systemd[1]: Set hostname to <j784s4-evm>.
    [    2.848717] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
    [    2.928153] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.934963] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    2.947323] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    2.959214] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    2.981039] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.989351] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    3.013051] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.021214] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    3.041296] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    3.065260] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    3.089153] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    3.105111] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    3.125084] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    3.141112] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    3.158379] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    3.181095] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    3.203780] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    3.225315] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    3.254813] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    3.263409] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    3.285598] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    3.301587] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    3.325528] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    3.345371] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    3.369437] systemd[1]: Mounting Huge Pages File System...
    [    3.389251] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.417333] systemd[1]: Mounting Kernel Debug File System...
    [    3.437291] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    3.457389] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st…odes for the current kernel...
    [    3.485169] systemd[1]: Starting Start psplash boot splash screen...
    [    3.513471] systemd[1]: Starting RPC Bind...
    [    3.533128] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    3.547466] systemd[1]: Starting Journal Service...
    [    3.567618] systemd[1]: Starting Load Kernel Modules...
    [    3.581933] cryptodev: loading out-of-tree module taints kernel.
    [    3.589341] cryptodev: driver 1.10 loaded.
    [    3.593310] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    3.612201] EXT4-fs (mmcblk0p12): re-mounted. Opts: (null)
    [    3.623254] systemd[1]: Starting udev Coldplug all Devices...
    [    3.649370] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    3.665515] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta… nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    3.914882] systemd-journald[198]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
    [    3.929930] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    3.941332] random: systemd: uninitialized urandom read (16 bytes read)
             Starting Create Static Device Nodes in /dev    3.955275] random: systemd-journal: uninitialized urandom read (16 bytes read)
    m...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting udev Wait for Complete Device Initialization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [    4.467749] random: crng init done
    [    4.471454] random: 64 urandom warning(s) missed due to ratelimiting
    [  OK  ] Started Load/Save Random Seed.
    [    4.502752] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b4000000
    [    4.533430] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
    [    4.540511] remoteproc remoteproc0: 64800000.dsp is available
    [    4.552432] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@b7400000
    [  OK  ] Started Network Time Synchronizatio[    4.573094] vdec 4210000.video-codec: sram node not found
    n.
    [    4.575518] k3-dsp-rproc 65800000.dsp: configured DSP for remoteproc mode
    [    4.592989] remoteproc remoteproc1: 65800000.dsp is available
    [  OK  ] Reached target System Time Set.
    [    4.605414] k3-dsp-rproc 66800000.dsp: assigned reserved memory node vision-apps-c71_2-dma-memory@ba800000
    [  OK  ] Reached target System Time Synchronized.
    [    4.622254] CAN device driver interface
    [    4.622511] k3-dsp-rproc 66800000.dsp: configured DSP for remoteproc mode
    [    4.633896] remoteproc remoteproc2: 66800000.dsp is available
    [    4.645322] k3-dsp-rproc 67800000.dsp: assigned reserved memory node vision-apps-c71_3-dma-memory@bdc00000
    [    4.660176] k3-dsp-rproc 67800000.dsp: configured DSP for remoteproc mode
    [    4.663413] PVR_K:  250: Read BVNC 36.53.104.796 from HW device registers
    [    4.669147] remoteproc remoteproc3: 67800000.dsp is available
    [    4.676343] PVR_K:  250: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [    4.694179] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
    [    4.832402] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    4.842674] vdec 4220000.video-codec: sram node not found
    [    4.844722] platform 41000000.r5f: configured R5F for IPC-only mode
    [    4.856546] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    4.866570] remoteproc remoteproc4: 41000000.r5f is available
    [    4.872512] remoteproc remoteproc4: attaching to 41000000.r5f
    [    4.878895] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    4.885728]  remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    4.895792] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    4.903505]  remoteproc4#vdev0buffer: registered virtio0 (type 7)
    [    4.909939] remoteproc remoteproc4: remote processor 41000000.r5f is now attached
    [    4.910215] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    4.935525] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    4.943926] m_can_platform 40528000.can: m_can device registered (irq=15, version=32)
    [    4.946055] platform 5c00000.r5f: configured R5F for remoteproc mode
    [    4.960354] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    4.970506] m_can_platform 40568000.can: m_can device registered (irq=17, version=32)
    [    4.974443] remoteproc remoteproc5: 5c00000.r5f is available
    [    4.989078] m_can_platform 26a1000.can: m_can device registered (irq=29, version=32)
    [    4.989719] platform 5e00000.r5f: configured R5F for remoteproc mode
    [    5.005456] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [    5.017603] remoteproc remoteproc6: 5e00000.r5f is available
    [    5.027913] platform 5900000.r5f: configured R5F for remoteproc mode
    [    5.035127] platform 5900000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
    [    5.046630] remoteproc remoteproc7: 5900000.r5f is available
    [    5.112493] remoteproc remoteproc6: powering up 5e00000.r5f
    [    5.118108] remoteproc remoteproc6: Booting fw image j784s4-main-r5f1_0-fw, size 179128
    [    5.128971]  remoteproc6#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [    5.138975] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    5.144552]  remoteproc6#vdev0buffer: registered virtio1 (type 7)
    [    5.150687] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
    [    5.170710] remoteproc remoteproc5: powering up 5c00000.r5f
    [    5.176314] remoteproc remoteproc5: Booting fw image j784s4-main-r5f0_0-fw, size 1400100
    [    5.189578]  remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    5.199655] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    5.206615]  remoteproc5#vdev0buffer: registered virtio2 (type 7)
    [    5.212757] remoteproc remoteproc5: remote processor 5c00000.r5f is now up
    [    5.221963] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [    5.232938] remoteproc remoteproc7: powering up 5900000.r5f
    [    5.238546] remoteproc remoteproc7: Booting fw image j784s4-main-r5f2_0-fw, size 592760
    [    5.249639]  remoteproc7#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
    [    5.252495] remoteproc remoteproc0: powering up 64800000.dsp
    [    5.259792] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    5.265904] remoteproc remoteproc0: Booting fw image j784s4-c71_0-fw, size 14815416
    [    5.270531]  remoteproc7#vdev0buffer: registered virtio3 (type 7)
    [    5.279252] remoteproc remoteproc0: unsupported resource 65538
    [    5.284371] remoteproc remoteproc7: remote processor 5900000.r5f is now up
    [    5.302343] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xb4200000
    [    5.315210]  remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@b4000000
    [    5.326149] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    5.331736]  remoteproc0#vdev0buffer: registered virtio4 (type 7)
    [    5.337916] remoteproc remoteproc0: remote processor 64800000.dsp is now up
    [    5.362616] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [    5.379088] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
    [    5.386391] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [    5.515229] remoteproc remoteproc1: powering up 65800000.dsp
    [    5.520943] remoteproc remoteproc1: Booting fw image j784s4-c71_1-fw, size 15208632
    [    5.528755] remoteproc remoteproc1: unsupported resource 65538
    [    5.538421] k3-dsp-rproc 65800000.dsp: booting DSP core using boot addr = 0xb7600000
    [    5.546607]  remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-c71_1-dma-memory@b7400000
    [    5.556968] virtio_rpmsg_bus virtio5: rpmsg host is online
    [    5.562620]  remoteproc1#vdev0buffer: registered virtio5 (type 7)
    [    5.562909] remoteproc remoteproc2: powering up 66800000.dsp
    [    5.568745] remoteproc remoteproc1: remote processor 65800000.dsp is now up
    [    5.574433] remoteproc remoteproc2: Booting fw image j784s4-c71_2-fw, size 14815416
    [    5.575419] remoteproc remoteproc2: unsupported resource 65538
    [    5.594520] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [    5.602406] remoteproc remoteproc3: powering up 67800000.dsp
    [    5.608136] remoteproc remoteproc3: Booting fw image j784s4-c71_3-fw, size 14815416
    [    5.616925] k3-dsp-rproc 66800000.dsp: booting DSP core using boot addr = 0xbaa00000
    [    5.624838] remoteproc remoteproc3: unsupported resource 65538
    [    5.637265]  remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-c71_2-dma-memory@ba800000
    [    5.647473] virtio_rpmsg_bus virtio6: rpmsg host is online
    [    5.654675] k3-dsp-rproc 67800000.dsp: booting DSP core using boot addr = 0xbde00000
    [    5.662584]  remoteproc2#vdev0buffer: registered virtio6 (type 7)
    [    5.668724] remoteproc remoteproc2: remote processor 66800000.dsp is now up
    [    5.676043]  remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-c71_3-dma-memory@bdc00000
    [    5.686192] virtio_rpmsg_bus virtio7: rpmsg host is online
    [    5.688044] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd
    [    5.693771]  remoteproc3#vdev0buffer: registered virtio7 (type 7)
    [    5.705155] remoteproc remoteproc3: remote processor 67800000.dsp is now up
    [    5.726492] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xd
    [    6.275415] usbcore: registered new interface driver usbfs
    [    6.281207] usbcore: registered new interface driver hub
    [    6.286747] usbcore: registered new device driver usb
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [  OK  ] Found device /dev/mmcblk0p8.
             Starting File System Check on /dev/mmcblk0p8...
    [  OK  ] Found device /dev/mmcblk0p11.
    [  OK  ] Started File System Check on /dev/mmcblk0p8.
    [  OK  ] Found device /dev/mmcblk0p9.
             Mounting /run/media/mmcblk0p8...
             Starting File System Check on /dev/mmcblk0p10...
    [    7.253926] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
             Starting File System Check on /dev/mmcblk0p11...
             Starting File System Check on /dev/mmcblk0p7...
             Starting File System Check on /dev/mmcblk0p9...
    [  OK  ] Mounted /run/media/mmcblk0p8.
    [  OK  ] Found device /dev/mmcblk0p3.
    [  OK  ] Found device /dev/mmcblk0p4.
    [  OK  ] Started File System Check on /dev/mmcblk0p10.
    [  OK  ] Found device /dev/mmcblk0p5.
    [  OK  ] Found device /dev/mmcblk0p6.
    [  OK  ] Started File System Check on /dev/mmcblk0p11.
    [  OK  ] Started File System Check on /dev/mmcblk0p7.
    [  OK  ] Started File System Check on /dev/mmcblk0p9.
             Mounting /run/media/mmcblk0p10...
             Mounting /run/media/mmcblk0p11...
    [    7.460671] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null)
             Mounting /run/media/mmcblk0p7...
    [    7.486214] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: (null)
             Mounting /run/media/mmcblk0p9...
    [    7.507371] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
             Starting File System Check on /dev/mmcblk0p3...
    [    7.522028] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: (null)
             Starting File System Check on /dev/mmcblk0p4...
             Starting File System Check on /dev/mmcblk0p5...
             Starting File System Check on /dev/mmcblk0p6...
    [  OK  ] Mounted /run/media/mmcblk0p10.
    [  OK  ] Mounted /run/media/mmcblk0p11.
    [  OK  ] Mounted /run/media/mmcblk0p7.
    [  OK  ] Mounted /run/media/mmcblk0p9.
    [  OK  ] Found device /dev/mmcblk1p3.
    [  OK  ] Started File System Check on /dev/mmcblk0p3.
    [  OK  ] Started File System Check on /dev/mmcblk0p4.
    [  OK  ] Started File System Check on /dev/mmcblk0p5.
    [  OK  ] Started File System Check on /dev/mmcblk0p6.
             Mounting /run/media/mmcblk0p3...
             Mounting /run/media/mmcblk0p4...
    [    7.718116] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
             Mounting /run/media/mmcblk0p5...
    [    7.744078] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
             Mounting /run/media/mmcblk0p6...
    [    7.758037] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
             Starting File System Check on /dev/mmcblk1p3    7.774799] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
    0m...
    [  OK  ] Started udev Wait for Complete Device Initialization.
    [  OK  ] Mounted /run/media/mmcblk0p3.
    [  OK  ] Mounted /run/media/mmcblk0p4.
    [  OK  ] Mounted /run/media/mmcblk0p5.
    [  OK  ] Mounted /run/media/mmcblk0p6.
    [  OK  ] Found device /dev/mmcblk1p4.
    [  OK  ] Found device /dev/mmcblk1p2.
    [  OK  ] Found device /dev/mmcblk1p1.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
             Starting File System Check on /dev/mmcblk1p1...
             Starting File System Check on /dev/mmcblk1p2...
             Starting File System Check on /dev/mmcblk1p4...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting rc.pvr.service...
             Starting Login Service...
    [  OK  ] Started TEE Supplicant.
    [  OK  ] Started File System Check on /dev/mmcblk1p3.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Reached target Network (Pre).
             Mounting /run/media/mmcblk1p3...
             Starting Network Service...
    [  OK  ] Started Telephony service.
    [    8.092772] Bluetooth: Core ver 2.22
    [    8.096515] NET: Registered protocol family 31
    [    8.101003] Bluetooth: HCI device and connection manager initialized
    [    8.112939] Bluetooth: HCI socket layer initialized
    [    8.118089] Bluetooth: L2CAP socket layer initialized
    [    8.123217] Bluetooth: SCO socket layer initialized
    [  OK  ] Listening on Load/Save RF …itch S[    8.166380] EXT4-fs (mmcblk1p3): mounted filesystem with ordered data mode. Opts: (null)
    tatus /dev/rfkill Watch.
    [  OK  ] Started File System Check on /dev/mmcblk1p2.
    [  OK  ] Mounted /run/media/mmcblk1p3.
             Mounting /run/media/mmcblk1p2...
    [  OK  ] Started File System Check on /dev/mmcblk1p4.
             Mounting /run/media/mmcblk1p4...
    [    8.358440] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Started Network Service.
    [    8.393604] am65-cpsw-nuss c200000.ethernet: down msc_sl e0000000 tmo 0
    [  OK  ] Started File System Check on /dev/mmcblk1p1.
    [  OK  ] Mounted /run/media/m[    8.411893] EXT4-fs (mmcblk1p4): mounted filesystem with ordered data mode. Opts: (null)
    mcblk1p2.
             Mounting /run/media/mmcblk1p1...
             Starting Wait for Network to be Configured...
    [    8.435525] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
             Starting Network Name Resolution...
    [    8.455246] am65-cpsw-nuss c200000.ethernet eth1: PHY [c200f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    8.467913] am65-cpsw-nuss c200000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [  OK  ] Mounted /run/media/mmcblk1p4.
    [  OK  ] Started Login Service.
    [    8.512930] am65-cpsw-nuss 46000000.ethernet: down msc_sl f0000000 tmo 0
    [    8.528361] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [  OK  ] Mounted /run/media/mmcblk1p1.
    [    8.550825] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [  OK  ] Started rc.pvr.service.
    [    8.560508] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
             Starting weston.service...
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
    NOTICE: This file system contains the following GPLv3 packages:
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gstreamer1.0-libav-dev
            gstreamer1.0-libav
            gzip
            less
            libasm1
            libbfd
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libreadline-dev
            libreadline8
            libunistring-dev
            libunistring2
            m4-dev
            m4
            make
            nettle-dev
            nettle
            parted
            python3-rfc3987
            python3-strict-rfc3339
            tar
            which
            zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
    [  OK  ] Started weston.service.
             Starting telnetd.service...
    [  OK  ] Started telnetd.service.
    [   11.744925] PVR_K:  1737: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
    [   11.755873] PVR_K:  1737: Shader binary image 'rgx.sh.36.53.104.796' loaded
    [   12.658463] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [   12.667193] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   13.105627] PVR_K:(Error):   138: RGXSafetyEventHandler: Safety Watchdog Trigger ! [358]
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project j784s4-evm ttyS2
    Arago 2021.09 j784s4-evm ttyS2
    j784s4-evm login:
    j784s4-evm login: [   26.563954] Initializing XFRM netlink socket
    root
    root@j784s4-evm:~# cd /opt/vision_apps/
    root@j784s4-evm:/opt/vision_apps#
    root@j784s4-evm:/opt/vision_apps# ./vision_apps_init.sh
    root@j784s4-evm:/opt/vision_apps# [MCU2_0]   2299.286365 s: CIO: Init ... Done !!!
    [MCU2_0]   2299.286416 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_0]   2299.286448 s: CPU is running FreeRTOS
    [MCU2_0]   2299.286469 s: APP: Init ... !!!
    [MCU2_0]   2299.286489 s: SCICLIENT: Init ... !!!
    [MCU2_0]   2299.286632 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [MCU2_0]   2299.286667 s: SCICLIENT: DMSC FW revision 0x8
    [MCU2_0]   2299.286695 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU2_0]   2299.286727 s: SCICLIENT: Init ... Done !!!
    [MCU2_0]   2299.286750 s: UDMA: Init ... !!!
    [MCU2_0]   2299.287685 s: UDMA: Init ... Done !!!
    [MCU2_0]   2299.287721 s: UDMA: Init ... !!!
    [MCU2_0]   2299.288228 s: UDMA: Init for CSITX/CSIRX ... Done !!!
    [MCU2_0]   2299.288266 s: MEM: Init ... !!!
    [MCU2_0]   2299.288297 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e2000000 of size 16777216 bytes !!!
    [MCU2_0]   2299.288357 s: MEM: Init ... Done !!!
    [MCU2_0]   2299.288379 s: IPC: Init ... !!!
    [MCU2_0]   2299.288426 s: IPC: 11 CPUs participating in IPC !!!
    [MCU2_0]   2299.288467 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_0]   2299.288496 s: IPC: HLOS is ready !!!
    [MCU2_0]   2299.309938 s: IPC: Init ... Done !!!
    [MCU2_0]   2299.309982 s: APP: Syncing with 10 CPUs ... !!!
    [MCU2_1]    964.284652 s: CIO: Init ... Done !!!
    [MCU2_1]    964.284702 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_1]    964.284734 s: CPU is running FreeRTOS
    [MCU2_1]    964.284755 s: APP: Init ... !!!
    [MCU2_1]    964.284774 s: SCICLIENT: Init ... !!!
    [MCU2_1]    964.284927 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [MCU2_1]    964.284961 s: SCICLIENT: DMSC FW revision 0x8
    [MCU2_1]    964.284988 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU2_1]    964.285020 s: SCICLIENT: Init ... Done !!!
    [MCU2_1]    964.285043 s: UDMA: Init ... !!!
    [MCU2_1]    964.286138 s: UDMA: Init ... Done !!!
    [MCU2_1]    964.286177 s: MEM: Init ... !!!
    [MCU2_1]    964.286213 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e3000000 of size 16777216 bytes !!!
    [MCU2_1]    964.286276 s: MEM: Init ... Done !!!
    [MCU2_1]    964.286299 s: IPC: Init ... !!!
    [MCU2_1]    964.286343 s: IPC: 11 CPUs participating in IPC !!!
    [MCU2_1]    964.286382 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_1]    976.794901 s: IPC: HLOS is ready !!!
    [MCU2_1]    976.818421 s: IPC: Init ... Done !!!
    [MCU2_1]    976.818469 s: APP: Syncing with 10 CPUs ... !!!
    [MCU2_1]    977.346868 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU2_1]    977.346907 s: REMOTE_SERVICE: Init ... !!!
    [MCU2_1]    977.348667 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU2_1]    977.348709 s: FVID2: Init ... !!!
    [MCU2_1]    977.348771 s: FVID2: Init ... Done !!!
    [MCU2_1]    977.348797 s: VHWA: DMPAC: Init ... !!!
    [MCU2_1]    977.348823 s: SCICLIENT: Sciclient_pmSetModuleState module=92 state=2
    [MCU2_1]    977.348968 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_1]    977.348999 s: SCICLIENT: Sciclient_pmSetModuleState module=96 state=2
    [MCU2_1]    977.349087 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_1]    977.349123 s: VHWA: DOF Init ... !!!
    [MCU2_1]    977.355496 s: VHWA: DOF Init ... Done !!!
    [MCU2_1]    977.355547 s: VHWA: SDE Init ... !!!
    [MCU2_1]    977.357046 s: VHWA: SDE Init ... Done !!!
    [MCU2_1]    977.357084 s: VHWA: DMPAC: Init ... Done !!!
    [MCU2_1]    977.357124 s:  VX_ZONE_INIT:Enabled
    [MCU2_1]    977.357151 s:  VX_ZONE_ERROR:Enabled
    [MCU2_1]    977.357177 s:  VX_ZONE_WARNING:Enabled
    [MCU2_1]    977.358169 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-1
    [MCU2_1]    977.358366 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_SDE
    [MCU2_1]    977.358545 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_DOF
    [MCU2_1]    977.358591 s:  VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!!
    [MCU2_1]    977.358621 s: APP: OpenVX Target kernel init ... !!!
    [MCU2_1]    977.358860 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU2_1]    977.358895 s: APP: Init ... Done !!!
    [MCU2_1]    977.358921 s: APP: Run ... !!!
    [MCU2_1]    977.358944 s: IPC: Starting echo test ...
    [MCU2_1]    977.363448 s: APP: Run ... Done !!!
    [MCU2_1]    977.364772 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_1]    977.364893 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_1]    977.365001 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_1]    977.365105 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_1]    977.365210 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[.] c7x_4[.]
    [MCU2_1]    977.365319 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[.]
    [MCU2_1]    977.365425 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU2_1]    977.410723 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU2_1]    977.640401 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_0]   2299.122971 s: CIO: Init ... Done !!!
    [MCU3_0]   2299.123023 s: ### CPU Frequency = 1000000000 Hz
    [MCU3_0]   2299.123055 s: CPU is running FreeRTOS
    [MCU3_0]   2299.123076 s: APP: Init ... !!!
    [MCU3_0]   2299.123097 s: SCICLIENT: Init ... !!!
    [MCU3_0]   2299.123250 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [MCU3_0]   2299.123284 s: SCICLIENT: DMSC FW revision 0x8
    [MCU3_0]   2299.123312 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU3_0]   2299.123343 s: SCICLIENT: Init ... Done !!!
    [MCU3_0]   2299.123366 s: MEM: Init ... !!!
    [MCU3_0]   2299.123398 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e4000000 of size 8388608 bytes !!!
    [MCU3_0]   2299.123457 s: MEM: Init ... Done !!!
    [MCU3_0]   2299.123480 s: IPC: Init ... !!!
    [MCU3_0]   2299.123522 s: IPC: 11 CPUs participating in IPC !!!
    [MCU3_0]   2299.123560 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU3_0]   2299.123596 s: IPC: HLOS is ready !!!
    [MCU3_0]   2299.145151 s: IPC: Init ... Done !!!
    [MCU3_0]   2299.145192 s: APP: Syncing with 10 CPUs ... !!!
    [MCU3_1]    964.340296 s: CIO: Init ... Done !!!
    [MCU3_1]    964.340351 s: ### CPU Frequency = 1000000000 Hz
    [MCU3_1]    964.340383 s: CPU is running FreeRTOS
    [MCU3_1]    964.340404 s: APP: Init ... !!!
    [MCU3_1]    964.340424 s: SCICLIENT: Init ... !!!
    [MCU3_1]    964.340571 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [MCU3_1]    964.340608 s: SCICLIENT: DMSC FW revision 0x8
    [MCU3_1]    964.340636 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU3_1]    964.340667 s: SCICLIENT: Init ... Done !!!
    [MCU3_1]    964.340691 s: MEM: Init ... !!!
    [MCU3_1]    964.340723 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e4800000 of size 8388608 bytes !!!
    [MCU3_1]    964.340781 s: MEM: Init ... Done !!!
    [MCU3_1]    964.340803 s: IPC: Init ... !!!
    [MCU3_1]    964.340846 s: IPC: 11 CPUs participating in IPC !!!
    [MCU3_1]    964.340885 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU3_1]    977.154098 s: IPC: HLOS is ready !!!
    [MCU3_1]    977.176770 s: IPC: Init ... Done !!!
    [MCU3_1]    977.176818 s: APP: Syncing with 10 CPUs ... !!!
    [MCU3_1]    977.346871 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU3_1]    977.346911 s: REMOTE_SERVICE: Init ... !!!
    [MCU3_1]    977.348722 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU3_1]    977.348776 s:  VX_ZONE_INIT:Enabled
    [MCU3_1]    977.348802 s:  VX_ZONE_ERROR:Enabled
    [MCU3_1]    977.348825 s:  VX_ZONE_WARNING:Enabled
    [MCU3_1]    977.349856 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU3-1
    [MCU3_1]    977.349905 s:  VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!!
    [MCU3_1]    977.349946 s: APP: OpenVX Target kernel init ... !!!
    [MCU3_1]    977.349973 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU3_1]    977.349999 s: APP: Init ... Done !!!
    [MCU3_1]    977.350022 s: APP: Run ... !!!
    [MCU3_1]    977.350043 s: IPC: Starting echo test ...
    [MCU3_1]    977.354722 s: APP: Run ... Done !!!
    [MCU3_1]    977.355902 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[s] mcu4_0[x] mcu4_1[x] c7x_1[.] c7x_2[P] c7x_3[.] c7x_4[.]
    [MCU3_1]    977.356072 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[s] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[.] c7x_4[.]
    [MCU3_1]    977.356196 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[s] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[.] c7x_4[P]
    [MCU3_1]    977.356338 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[s] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_1]    977.356538 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_1]    977.356829 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_1]    977.364073 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_1]    977.410692 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[s] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_1]    977.640437 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[s] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_0]   2299.279524 s: CIO: Init ... Done !!!
    [MCU4_0]   2299.279576 s: ### CPU Frequency = 1000000000 Hz
    [MCU4_0]   2299.279608 s: CPU is running FreeRTOS
    [MCU4_0]   2299.279630 s: APP: Init ... !!!
    [MCU4_0]   2299.279651 s: SCICLIENT: Init ... !!!
    [MCU4_0]   2299.279799 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [MCU4_0]   2299.279833 s: SCICLIENT: DMSC FW revision 0x8
    [MCU4_0]   2299.279860 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU4_0]   2299.279891 s: SCICLIENT: Init ... Done !!!
    [MCU4_0]   2299.279914 s: UDMA: Init ... !!!
    [MCU4_0]   2299.281017 s: UDMA: Init ... Done !!!
    [MCU4_0]   2299.281053 s: MEM: Init ... !!!
    [MCU4_0]   2299.281085 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e5000000 of size 8388608 bytes !!!
    [MCU4_0]   2299.281150 s: MEM: Init ... Done !!!
    [MCU4_0]   2299.281172 s: IPC: Init ... !!!
    [MCU4_0]   2299.281218 s: IPC: 11 CPUs participating in IPC !!!
    [MCU4_0]   2299.281257 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU4_0]   2299.281286 s: IPC: HLOS is ready !!!
    [MCU4_0]   2299.302760 s: IPC: Init ... Done !!!
    [MCU4_0]   2299.302803 s: APP: Syncing with 10 CPUs ... !!!
    [MCU4_1]    964.404305 s: CIO: Init ... Done !!!
    [MCU4_1]    964.404360 s: ### CPU Frequency = 1000000000 Hz
    [MCU4_1]    964.404392 s: CPU is running FreeRTOS
    [MCU4_1]    964.404413 s: APP: Init ... !!!
    [MCU4_1]    964.404434 s: SCICLIENT: Init ... !!!
    [MCU4_1]    964.404581 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [MCU4_1]    964.404616 s: SCICLIENT: DMSC FW revision 0x8
    [MCU4_1]    964.404644 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU4_1]    964.404675 s: SCICLIENT: Init ... Done !!!
    [MCU4_1]    964.404699 s: MEM: Init ... !!!
    [MCU4_1]    964.404730 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e5800000 of size 8388608 bytes !!!
    [MCU4_1]    964.404792 s: MEM: Init ... Done !!!
    [MCU4_1]    964.404813 s: IPC: Init ... !!!
    [MCU4_1]    964.404856 s: IPC: 11 CPUs participating in IPC !!!
    [MCU4_1]    964.404905 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU4_1]    977.324308 s: IPC: HLOS is ready !!!
    [MCU4_1]    977.346781 s: IPC: Init ... Done !!!
    [MCU4_1]    977.346828 s: APP: Syncing with 10 CPUs ... !!!
    [MCU4_1]    977.346870 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU4_1]    977.346907 s: REMOTE_SERVICE: Init ... !!!
    [MCU4_1]    977.348811 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU4_1]    977.348862 s:  VX_ZONE_INIT:Enabled
    [MCU4_1]    977.348886 s:  VX_ZONE_ERROR:Enabled
    [MCU4_1]    977.348917 s:  VX_ZONE_WARNING:Enabled
    [MCU4_1]    977.349935 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU4-1
    [MCU4_1]    977.349982 s:  VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!!
    [MCU4_1]    977.350012 s: APP: OpenVX Target kernel init ... !!!
    [MCU4_1]    977.350039 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU4_1]    977.350065 s: APP: Init ... Done !!!
    [MCU4_1]    977.350088 s: APP: Run ... !!!
    [MCU4_1]    977.350109 s: IPC: Starting echo test ...
    [MCU4_1]    977.354788 s: APP: Run ... Done !!!
    [MCU4_1]    977.355986 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[.] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU4_1]    977.356120 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[.] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[.] c7x_3[P] c7x_4[.]
    [MCU4_1]    977.356227 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[.] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[.]
    [MCU4_1]    977.356346 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[.] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_1]    977.356574 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_1]    977.356694 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_1]    977.364096 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_1]    977.410701 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_1]    977.640463 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [C7x_1 ]   2299.280844 s: CIO: Init ... Done !!!
    [C7x_1 ]   2299.280860 s: ### CPU Frequency = 1000000000 Hz
    [C7x_1 ]   2299.280873 s: CPU is running FreeRTOS
    [C7x_1 ]   2299.280883 s: APP: Init ... !!!
    [C7x_1 ]   2299.280891 s: SCICLIENT: Init ... !!!
    [C7x_1 ]   2299.281104 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [C7x_1 ]   2299.281122 s: SCICLIENT: DMSC FW revision 0x8
    [C7x_1 ]   2299.281134 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C7x_1 ]   2299.281146 s: SCICLIENT: Init ... Done !!!
    [C7x_1 ]   2299.281155 s: UDMA: Init ... !!!
    [C7x_1 ]   2299.282100 s: UDMA: Init ... Done !!!
    [C7x_1 ]   2299.282116 s: MEM: Init ... !!!
    [C7x_1 ]   2299.282129 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 104000000 of size 67108864 bytes !!!
    [C7x_1 ]   2299.282152 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 68000000 of size 3145728 bytes !!!
    [C7x_1 ]   2299.282171 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 458752 bytes !!!
    [C7x_1 ]   2299.282190 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!!
    [C7x_1 ]   2299.282208 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 10c000000 of size 67108864 bytes !!!
    [C7x_1 ]   2299.282227 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000001) @ 100000000 of size 67108864 bytes !!!
    [C7x_1 ]   2299.282246 s: MEM: Created heap (DDR_SCRATCH_NON_, id=6, flags=0x00000001) @ 108000000 of size 67108864 bytes !!!
    [C7x_1 ]   2299.282266 s: MEM: Init ... Done !!!
    [C7x_1 ]   2299.282275 s: IPC: Init ... !!!
    [C7x_1 ]   2299.282292 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_1 ]   2299.282311 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_1 ]   2299.282326 s: IPC: HLOS is ready !!!
    [C7x_1 ]   2299.285743 s: IPC: Init ... Done !!!
    [C7x_1 ]   2299.285759 s: APP: Syncing with 10 CPUs ... !!!
    [C7x_2 ]   2299.512624 s: CIO: Init ... Done !!!
    [C7x_2 ]   2299.512643 s: ### CPU Frequency = 1000000000 Hz
    [C7x_2 ]   2299.512658 s: CPU is running FreeRTOS
    [C7x_2 ]   2299.512671 s: APP: Init ... !!!
    [C7x_2 ]   2299.512682 s: SCICLIENT: Init ... !!!
    [C7x_2 ]   2299.512819 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [C7x_2 ]   2299.512839 s: SCICLIENT: DMSC FW revision 0x8
    [C7x_2 ]   2299.512854 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C7x_2 ]   2299.512867 s: SCICLIENT: Init ... Done !!!
    [C7x_2 ]   2299.512880 s: UDMA: Init ... !!!
    [C7x_2 ]   2299.513864 s: UDMA: Init ... Done !!!
    [C7x_2 ]   2299.513881 s: MEM: Init ... !!!
    [C7x_2 ]   2299.513897 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 114000000 of size 67108864 bytes !!!
    [C7x_2 ]   2299.513923 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 69000000 of size 3145728 bytes !!!
    [C7x_2 ]   2299.513945 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 65800000 of size 458752 bytes !!!
    [C7x_2 ]   2299.513965 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 65e00000 of size 16384 bytes !!!
    [C7x_2 ]   2299.513986 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 11c000000 of size 67108864 bytes !!!
    [C7x_2 ]   2299.514007 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000001) @ 110000000 of size 67108864 bytes !!!
    [C7x_2 ]   2299.514030 s: MEM: Created heap (DDR_SCRATCH_NON_, id=6, flags=0x00000001) @ 118000000 of size 67108864 bytes !!!
    [C7x_2 ]   2299.514052 s: MEM: Init ... Done !!!
    [C7x_2 ]   2299.514064 s: IPC: Init ... !!!
    [C7x_2 ]   2299.514084 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_2 ]   2299.514107 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_2 ]   2299.514124 s: IPC: HLOS is ready !!!
    [C7x_2 ]   2299.517611 s: IPC: Init ... Done !!!
    [C7x_2 ]   2299.517628 s: APP: Syncing with 10 CPUs ... !!!
    [C7x_3 ]   2299.606074 s: CIO: Init ... Done !!!
    [C7x_3 ]   2299.606094 s: ### CPU Frequency = 1000000000 Hz
    [C7x_3 ]   2299.606110 s: CPU is running FreeRTOS
    [C7x_3 ]   2299.606121 s: APP: Init ... !!!
    [C7x_3 ]   2299.606131 s: SCICLIENT: Init ... !!!
    [C7x_3 ]   2299.606268 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [C7x_3 ]   2299.606289 s: SCICLIENT: DMSC FW revision 0x8
    [C7x_3 ]   2299.606304 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C7x_3 ]   2299.606318 s: SCICLIENT: Init ... Done !!!
    [C7x_3 ]   2299.606329 s: UDMA: Init ... !!!
    [C7x_3 ]   2299.607351 s: UDMA: Init ... Done !!!
    [C7x_3 ]   2299.607370 s: MEM: Init ... !!!
    [C7x_3 ]   2299.607385 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 124000000 of size 67108864 bytes !!!
    [C7x_3 ]   2299.607410 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 6a000000 of size 3145728 bytes !!!
    [C7x_3 ]   2299.607431 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 66800000 of size 458752 bytes !!!
    [C7x_3 ]   2299.607450 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 66e00000 of size 16384 bytes !!!
    [C7x_3 ]   2299.607470 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 12c000000 of size 67108864 bytes !!!
    [C7x_3 ]   2299.607491 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000001) @ 120000000 of size 67108864 bytes !!!
    [C7x_3 ]   2299.607513 s: MEM: Created heap (DDR_SCRATCH_NON_, id=6, flags=0x00000001) @ 128000000 of size 67108864 bytes !!!
    [C7x_3 ]   2299.607534 s: MEM: Init ... Done !!!
    [C7x_3 ]   2299.607545 s: IPC: Init ... !!!
    [C7x_3 ]   2299.607566 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_3 ]   2299.607590 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_3 ]   2299.607607 s: IPC: HLOS is ready !!!
    [C7x_3 ]   2299.611128 s: IPC: Init ... Done !!!
    [C7x_3 ]   2299.611145 s: APP: Syncing with 10 CPUs ... !!!
    [C7x_4 ]   2299.644559 s: CIO: Init ... Done !!!
    [C7x_4 ]   2299.644579 s: ### CPU Frequency = 1000000000 Hz
    [C7x_4 ]   2299.644595 s: CPU is running FreeRTOS
    [C7x_4 ]   2299.644607 s: APP: Init ... !!!
    [C7x_4 ]   2299.644618 s: SCICLIENT: Init ... !!!
    [C7x_4 ]   2299.644750 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [C7x_4 ]   2299.644770 s: SCICLIENT: DMSC FW revision 0x8
    [C7x_4 ]   2299.644785 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C7x_4 ]   2299.644800 s: SCICLIENT: Init ... Done !!!
    [C7x_4 ]   2299.644813 s: UDMA: Init ... !!!
    [C7x_4 ]   2299.645786 s: UDMA: Init ... Done !!!
    [C7x_4 ]   2299.645804 s: MEM: Init ... !!!
    [C7x_4 ]   2299.645819 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 134000000 of size 67108864 bytes !!!
    [C7x_4 ]   2299.645846 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 6b000000 of size 3145728 bytes !!!
    [C7x_4 ]   2299.645867 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 67800000 of size 458752 bytes !!!
    [C7x_4 ]   2299.645886 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 67e00000 of size 16384 bytes !!!
    [C7x_4 ]   2299.645906 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 13c000000 of size 67108864 bytes !!!
    [C7x_4 ]   2299.645926 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000001) @ 130000000 of size 67108864 bytes !!!
    [C7x_4 ]   2299.645947 s: MEM: Created heap (DDR_SCRATCH_NON_, id=6, flags=0x00000001) @ 138000000 of size 67108864 bytes !!!
    [C7x_4 ]   2299.645968 s: MEM: Init ... Done !!!
    [C7x_4 ]   2299.645980 s: IPC: Init ... !!!
    [C7x_4 ]   2299.646001 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_4 ]   2299.646024 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_4 ]   2299.646042 s: IPC: HLOS is ready !!!
    [C7x_4 ]   2299.649579 s: IPC: Init ... Done !!!
    [C7x_4 ]   2299.649596 s: APP: Syncing with 10 CPUs ... !!!
    McuX_0 and all c7X cores in sync when starting, but mcuX_1 cores are not.
  • After testing, we found that TDA4-VM is OK, but TDA4-VH is not.
    The test results on TDA4-VH are consistent with the phenomena in this thread
    Can somebody help me?
    Sorry for the delay,
    Could you let me know which SDK version are you using in TDA4VH?
    Is it SDK 08.05.00.14? If not, could you please try using this version? I believe, some fixes regarding booting has gone into this SDK.
    Nikhil
  • Hi, I am using SDK 08.05.00.11.
    Then I verified it on the SDK 08.05.00.14 and found that not only the phenomenon did not return to normal, but also the core MCUX_ 1's messages printing log does not appear after run ./vision_apps_init.sh.
    U-Boot SPL 2021.01-g7996ed51f1 (Dec 18 2022 - 12:04:04 +0000)
    SYSFW ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar')
    SPL initial stack usage: 13472 bytes
    Trying to boot from MMC2
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.7(release):v2.7.0-359-g1309c6c805-dirty
    NOTICE:  BL31: Built : 12:02:48, Dec 18 2022
    I/TC:
    I/TC: OP-TEE version: 3.19.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Sun Dec 18 12:03:06 UTC 2022
    aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar')
    I/TC: HUK Initialized
    I/TC: Activated SA2UL device
    I/TC: Fixing SA2UL firewall owner for GP device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot SPL 2021.01-g7996ed51f1 (Dec 18 2022 - 12:03:17 +0000)
    U-Boot 2021.01-g7996ed51f1 (Dec 18 2022 - 12:03:17 +0000)
    SoC:   J784S4 SR1.0 GP
    Model: Texas Instruments J784S4 EVM
    DRAM:  32 GiB
    Flash: 0 Bytes
    MMC:   mmc@4f80000: 0, mmc@4fb0000: 1
    Loading Environment from MMC... OK
    In:    serial@2880000
    Out:   serial@2880000
    Err:   serial@2880000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    Net:   eth0: ethernet@46000000port@1
    Hit any key to stop autoboot:  0
    => run findfdt; setenv bootpart 0:8;setenv mmcdev 0;mmc dev ${mmcdev};setenv dorprocboot 1;setenv name_overlays k3-j784s4-vision-apps.dtbo; run init_${boot};  r
    un get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern;
    switch to partitions #0, OK
    mmc0(part 0) is current device
    18608640 bytes read in 221 ms (80.3 MiB/s)
    87334 bytes read in 10 ms (8.3 MiB/s)
    13942 bytes read in 9 ms (1.5 MiB/s)
       Loading Device Tree to 000000008fee7000, end 000000008fffffff ... OK
    Starting kernel ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    I/TC: Secondary CPU 2 initializing
    I/TC: Secondary CPU 2 switching to normal world boot
    I/TC: Secondary CPU 3 initializing
    I/TC: Secondary CPU 3 switching to normal world boot
    I/TC: Secondary CPU 4 initializing
    I/TC: Secondary CPU 4 switching to normal world boot
    I/TC: Secondary CPU 5 initializing
    I/TC: Secondary CPU 5 switching to normal world boot
    [  OK  ] Started Dispatch Password ▒…ts to Console Directory Watch.
    [  OK  ] Started Forward Password R▒…uests to Wall Directory Watch.
             Starting Create list of st▒…odes for the current kernel...
    [  OK  ] Started Create list of sta▒… nodes for the current kernel.
    [DEPEND] Dependency failed for Star▒…progress communication helper.
    [FAILED] Failed to start Remount Root and Kernel File Systems.
    See 'systemctl status systemd-remount-fs.service' for details.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Found device /dev/mmcblk0p10.
    [  OK  ] Found device /dev/mmcblk0p12.
             Mounting /csp_data...
             Mounting /csp_log...
             Mounting /csp_ota...
    [  OK  ] Mounted /csp_data.
    [  OK  ] Mounted /csp_log.
    [  OK  ] Mounted /csp_ota.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Listening on Load/Save RF ▒…itch Status /dev/rfkill Watch.
             Starting Simple Network Ma▒…ent Protocol (SNMP) Daemon....
    [  OK  ] Started Simple Network Man▒…ement Protocol (SNMP) Daemon..
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gstreamer1.0-libav
            gzip
            less
            libasm1
            libbfd
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libreadline-dev
            libreadline8
            libunistring-dev
            libunistring2
            m4-dev
            m4
            make
            nettle-dev
            nettle
            parted
            python3-rfc3987
            tar
            which
            zeromq
     _____                    _____           _         _
                  |___|                    |___|
    j784s4-evm login: root
    root@j784s4-evm:~# 4;160R
    -sh: 4: command not found
    -sh: 160R: command not found
    root@j784s4-evm:/opt/vision_apps# [MCU2_0]     11.718239 s: CIO: Init ... Done !!!
    [MCU2_0]     11.718297 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_0]     11.718328 s: CPU is running FreeRTOS
    [MCU2_0]     11.718350 s: APP: Init ... !!!
    [MCU2_0]     11.718370 s: SCICLIENT: Init ... !!!
    [MCU2_0]     11.718513 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [MCU2_0]     11.718547 s: SCICLIENT: DMSC FW revision 0x8
    [MCU2_0]     11.718576 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU2_0]     11.718607 s: SCICLIENT: Init ... Done !!!
    [MCU2_0]     11.718631 s: UDMA: Init ... !!!
    [MCU2_0]     11.719680 s: UDMA: Init ... Done !!!
    [MCU2_0]     11.719718 s: UDMA: Init ... !!!
    [MCU2_0]     11.720269 s: UDMA: Init for CSITX/CSIRX ... Done !!!
    [MCU2_0]     11.720309 s: MEM: Init ... !!!
    [MCU2_0]     11.720344 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e2000000 of size 16777216 bytes !!!
    [MCU2_0]     11.720406 s: MEM: Init ... Done !!!
    [MCU2_0]     11.720428 s: IPC: Init ... !!!
    [MCU2_0]     11.720479 s: IPC: 11 CPUs participating in IPC !!!
    [MCU2_0]     11.720521 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_0]     11.720551 s: IPC: HLOS is ready !!!
    [MCU2_0]     11.742980 s: IPC: Init ... Done !!!
    [MCU2_0]     11.743027 s: APP: Syncing with 10 CPUs ... !!!
    [MCU3_0]     11.601861 s: CIO: Init ... Done !!!
    [MCU3_0]     11.601917 s: ### CPU Frequency = 1000000000 Hz
    [MCU3_0]     11.601951 s: CPU is running FreeRTOS
    [MCU3_0]     11.601973 s: APP: Init ... !!!
    [MCU3_0]     11.601993 s: SCICLIENT: Init ... !!!
    [MCU3_0]     11.602164 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [MCU3_0]     11.602202 s: SCICLIENT: DMSC FW revision 0x8
    [MCU3_0]     11.602230 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU3_0]     11.602261 s: SCICLIENT: Init ... Done !!!
    [MCU3_0]     11.602284 s: MEM: Init ... !!!
    [MCU3_0]     11.602317 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e4000000 of size 8388608 bytes !!!
    [MCU3_0]     11.602377 s: MEM: Init ... Done !!!
    [MCU3_0]     11.602399 s: IPC: Init ... !!!
    [MCU3_0]     11.602445 s: IPC: 11 CPUs participating in IPC !!!
    [MCU3_0]     11.602495 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU3_0]     11.602523 s: IPC: HLOS is ready !!!
    [MCU3_0]     11.625297 s: IPC: Init ... Done !!!
    [MCU3_0]     11.625342 s: APP: Syncing with 10 CPUs ... !!!
    [MCU4_0]     11.714828 s: CIO: Init ... Done !!!
    [MCU4_0]     11.714887 s: ### CPU Frequency = 1000000000 Hz
    [MCU4_0]     11.714919 s: CPU is running FreeRTOS
    [MCU4_0]     11.714942 s: APP: Init ... !!!
    [MCU4_0]     11.714963 s: SCICLIENT: Init ... !!!
    [MCU4_0]     11.715117 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [MCU4_0]     11.715154 s: SCICLIENT: DMSC FW revision 0x8
    [MCU4_0]     11.715183 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU4_0]     11.715218 s: SCICLIENT: Init ... Done !!!
    [MCU4_0]     11.715243 s: UDMA: Init ... !!!
    [MCU4_0]     11.716403 s: UDMA: Init ... Done !!!
    [MCU4_0]     11.716452 s: MEM: Init ... !!!
    [MCU4_0]     11.716490 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e5000000 of size 8388608 bytes !!!
    [MCU4_0]     11.716549 s: MEM: Init ... Done !!!
    [MCU4_0]     11.716572 s: IPC: Init ... !!!
    [MCU4_0]     11.716620 s: IPC: 11 CPUs participating in IPC !!!
    [MCU4_0]     11.716660 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU4_0]     11.716691 s: IPC: HLOS is ready !!!
    [MCU4_0]     11.739567 s: IPC: Init ... Done !!!
    [MCU4_0]     11.739609 s: APP: Syncing with 10 CPUs ... !!!
    [C7x_1 ]     11.750982 s: CIO: Init ... Done !!!
    [C7x_1 ]     11.751003 s: ### CPU Frequency = 1000000000 Hz
    [C7x_1 ]     11.751017 s: CPU is running FreeRTOS
    [C7x_1 ]     11.751027 s: APP: Init ... !!!
    [C7x_1 ]     11.751036 s: SCICLIENT: Init ... !!!
    [C7x_1 ]     11.751173 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [C7x_1 ]     11.751193 s: SCICLIENT: DMSC FW revision 0x8
    [C7x_1 ]     11.751206 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C7x_1 ]     11.751218 s: SCICLIENT: Init ... Done !!!
    [C7x_1 ]     11.751228 s: UDMA: Init ... !!!
    [C7x_1 ]     11.752208 s: UDMA: Init ... Done !!!
    [C7x_1 ]     11.752225 s: MEM: Init ... !!!
    [C7x_1 ]     11.752239 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 104000000 of size 67108864 bytes !!!
    [C7x_1 ]     11.752263 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 68000000 of size 3145728 bytes !!!
    [C7x_1 ]     11.752283 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 458752 bytes !!!
    [C7x_1 ]     11.752302 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!!
    [C7x_1 ]     11.752321 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 10c000000 of size 67108864 bytes !!!
    [C7x_1 ]     11.752340 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000001) @ 100000000 of size 67108864 bytes !!!
    [C7x_1 ]     11.752359 s: MEM: Created heap (DDR_SCRATCH_NON_, id=6, flags=0x00000001) @ 108000000 of size 67108864 bytes !!!
    [C7x_1 ]     11.752379 s: MEM: Init ... Done !!!
    [C7x_1 ]     11.752389 s: IPC: Init ... !!!
    [C7x_1 ]     11.752409 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_1 ]     11.752431 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_1 ]     11.752447 s: IPC: HLOS is ready !!!
    [C7x_1 ]     11.755835 s: IPC: Init ... Done !!!
    [C7x_1 ]     11.755860 s: APP: Syncing with 10 CPUs ... !!!
    [C7x_2 ]     11.904047 s: CIO: Init ... Done !!!
    [C7x_2 ]     11.904066 s: ### CPU Frequency = 1000000000 Hz
    [C7x_2 ]     11.904084 s: CPU is running FreeRTOS
    [C7x_2 ]     11.904095 s: APP: Init ... !!!
    [C7x_2 ]     11.904105 s: SCICLIENT: Init ... !!!
    [C7x_2 ]     11.904248 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [C7x_2 ]     11.904269 s: SCICLIENT: DMSC FW revision 0x8
    [C7x_2 ]     11.904283 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C7x_2 ]     11.904297 s: SCICLIENT: Init ... Done !!!
    [C7x_2 ]     11.904308 s: UDMA: Init ... !!!
    [C7x_2 ]     11.905346 s: UDMA: Init ... Done !!!
    [C7x_2 ]     11.905364 s: MEM: Init ... !!!
    [C7x_2 ]     11.905379 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 114000000 of size 67108864 bytes !!!
    [C7x_2 ]     11.905405 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 69000000 of size 3145728 bytes !!!
    [C7x_2 ]     11.905428 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 65800000 of size 458752 bytes !!!
    [C7x_2 ]     11.905448 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 65e00000 of size 16384 bytes !!!
    [C7x_2 ]     11.905469 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 11c000000 of size 67108864 bytes !!!
    [C7x_2 ]     11.905490 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000001) @ 110000000 of size 67108864 bytes !!!
    [C7x_2 ]     11.905511 s: MEM: Created heap (DDR_SCRATCH_NON_, id=6, flags=0x00000001) @ 118000000 of size 67108864 bytes !!!
    [C7x_2 ]     11.905532 s: MEM: Init ... Done !!!
    [C7x_2 ]     11.905545 s: IPC: Init ... !!!
    [C7x_2 ]     11.905566 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_2 ]     11.905588 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_2 ]     11.905606 s: IPC: HLOS is ready !!!
    [C7x_2 ]     11.909083 s: IPC: Init ... Done !!!
    [C7x_2 ]     11.909102 s: APP: Syncing with 10 CPUs ... !!!
    [C7x_3 ]     11.923335 s: CIO: Init ... Done !!!
    [C7x_3 ]     11.923353 s: ### CPU Frequency = 1000000000 Hz
    [C7x_3 ]     11.923369 s: CPU is running FreeRTOS
    [C7x_3 ]     11.923380 s: APP: Init ... !!!
    [C7x_3 ]     11.923391 s: SCICLIENT: Init ... !!!
    [C7x_3 ]     11.923530 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [C7x_3 ]     11.923550 s: SCICLIENT: DMSC FW revision 0x8
    [C7x_3 ]     11.923563 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C7x_3 ]     11.923577 s: SCICLIENT: Init ... Done !!!
    [C7x_3 ]     11.923589 s: UDMA: Init ... !!!
    [C7x_3 ]     11.924575 s: UDMA: Init ... Done !!!
    [C7x_3 ]     11.924594 s: MEM: Init ... !!!
    [C7x_3 ]     11.924609 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 124000000 of size 67108864 bytes !!!
    [C7x_3 ]     11.924635 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 6a000000 of size 3145728 bytes !!!
    [C7x_3 ]     11.924655 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 66800000 of size 458752 bytes !!!
    [C7x_3 ]     11.924675 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 66e00000 of size 16384 bytes !!!
    [C7x_3 ]     11.924694 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 12c000000 of size 67108864 bytes !!!
    [C7x_3 ]     11.924715 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000001) @ 120000000 of size 67108864 bytes !!!
    [C7x_3 ]     11.924736 s: MEM: Created heap (DDR_SCRATCH_NON_, id=6, flags=0x00000001) @ 128000000 of size 67108864 bytes !!!
    [C7x_3 ]     11.924757 s: MEM: Init ... Done !!!
    [C7x_3 ]     11.924768 s: IPC: Init ... !!!
    [C7x_3 ]     11.924788 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_3 ]     11.924811 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_3 ]     11.924827 s: IPC: HLOS is ready !!!
    [C7x_3 ]     11.928346 s: IPC: Init ... Done !!!
    [C7x_3 ]     11.928364 s: APP: Syncing with 10 CPUs ... !!!
    [C7x_4 ]     11.932770 s: CIO: Init ... Done !!!
    [C7x_4 ]     11.932788 s: ### CPU Frequency = 1000000000 Hz
    [C7x_4 ]     11.932803 s: CPU is running FreeRTOS
    [C7x_4 ]     11.932816 s: APP: Init ... !!!
    [C7x_4 ]     11.932826 s: SCICLIENT: Init ... !!!
    [C7x_4 ]     11.932959 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar]
    [C7x_4 ]     11.932979 s: SCICLIENT: DMSC FW revision 0x8
    [C7x_4 ]     11.932992 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C7x_4 ]     11.933005 s: SCICLIENT: Init ... Done !!!
    [C7x_4 ]     11.933016 s: UDMA: Init ... !!!
    [C7x_4 ]     11.933992 s: UDMA: Init ... Done !!!
    [C7x_4 ]     11.934008 s: MEM: Init ... !!!
    [C7x_4 ]     11.934023 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 134000000 of size 67108864 bytes !!!
    [C7x_4 ]     11.934047 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 6b000000 of size 3145728 bytes !!!
    [C7x_4 ]     11.934067 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 67800000 of size 458752 bytes !!!
    [C7x_4 ]     11.934086 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 67e00000 of size 16384 bytes !!!
    [C7x_4 ]     11.934105 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 13c000000 of size 67108864 bytes !!!
    [C7x_4 ]     11.934125 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000001) @ 130000000 of size 67108864 bytes !!!
    [C7x_4 ]     11.934145 s: MEM: Created heap (DDR_SCRATCH_NON_, id=6, flags=0x00000001) @ 138000000 of size 67108864 bytes !!!
    [C7x_4 ]     11.934165 s: MEM: Init ... Done !!!
    [C7x_4 ]     11.934176 s: IPC: Init ... !!!
    [C7x_4 ]     11.934196 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_4 ]     11.934216 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_4 ]     11.934231 s: IPC: HLOS is ready !!!
    [C7x_4 ]     11.937547 s: IPC: Init ... Done !!!
    [C7x_4 ]     11.937564 s: APP: Syncing with 10 CPUs ... !!!
    root@j784s4-evm:/opt/vision_apps# dmesg^C
    root@j784s4-evm:/opt/vision_apps# ^C
    root@j784s4-evm:/opt/vision_apps# lsmod
    Module                  Size  Used by
    xfrm_user              40960  2
    xfrm_algo              16384  1 xfrm_user
    md5                    16384  0
    ecb                    16384  0
    aes_neon_bs            28672  0
    aes_neon_blk           28672  1 aes_neon_bs
    des_generic            16384  0
    libdes                 24576  1 des_generic
    cbc                    16384  0
    bluetooth             421888  2
    ecdh_generic           16384  1 bluetooth
    ecc                    32768  1 ecdh_generic
    rfkill                 24576  2 bluetooth
    cdns3                  53248  0
    udc_core               32768  1 cdns3
    roles                  16384  1 cdns3
    usbcore               266240  1 cdns3
    rpmsg_char             20480  0
    ti_am335x_adc          24576  0
    usb_common             16384  3 usbcore,cdns3,udc_core
    kfifo_buf              16384  1 ti_am335x_adc
    crct10dif_ce           20480  1
    ti_j721e_cpsw_virt_mac    32768  0
    phy_can_transceiver    16384  1
    ti_k3_r5_remoteproc    28672  0
    m_can_platform         16384  0
    m_can                  28672  1 m_can_platform
    ti_am335x_tscadc       16384  1 ti_am335x_adc
    can_dev                36864  1 m_can
    wave5                  90112  0
    v4l2_mem2mem           40960  1 wave5
    pci_endpoint_test      20480  0
    sa2ul                  40960  0
    videobuf2_dma_contig    24576  1 wave5
    cdns_mhdp8546          32768  0
    pvrsrvkm             1171456  0
    videobuf2_memops       20480  1 videobuf2_dma_contig
    cdns_dsi               24576  0
    ti_k3_dsp_remoteproc    20480  0
    videobuf2_v4l2         32768  2 v4l2_mem2mem,wave5
    sha512_generic         16384  1 sa2ul
    videobuf2_common       57344  3 videobuf2_v4l2,v4l2_mem2mem,wave5
    virtio_rpmsg_bus       24576  0
    authenc                16384  1 sa2ul
    cdns_dphy              16384  0
    cdns3_ti               16384  0
    optee_rng              16384  0
    rng_core               24576  2 optee_rng
    sch_fq_codel           20480  3
    rpmsg_kdrv_switch      20480  0
    cryptodev              57344  1
    ipv6                  462848  54
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.153-g90c3a58fd2 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9
    .10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Sun Dec 18 12:04:18 UTC 2022
    [    0.000000] Machine model: Texas Instruments J784S4 EVM
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@aa000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@aa100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 48 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000af000000, size 80 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@af000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b4100000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@b4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b7400000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b7400000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b7500000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@b7500000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ba800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_2-dma-memory@ba800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ba900000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_2-memory@ba900000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000bdc00000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_3-dma-memory@bdc00000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000bdd00000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_3-memory@bdd00000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e1000000, size 80 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@e1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e6000000, size 8 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e6800000, size 24 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e6800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 1024 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x0000000fffffefff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000c0ffffff]
    [    0.000000]   node   0: [mem 0x00000000c1000000-0x00000000e0ffffff]
    [    0.000000]   node   0: [mem 0x00000000e1000000-0x00000000e7ffffff]
    [    0.000000]   node   0: [mem 0x00000000e8000000-0x00000000ffffefff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008bfffffff]
    [    0.000000]   node   0: [mem 0x00000008c0000000-0x0000000fffffefff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000fffffefff]
    [    0.000000] On node 0 totalpages: 8388606
    [    0.000000]   DMA zone: 8192 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 524287 pages, LIFO batch:63
    [    0.000000]   Normal zone: 122880 pages used for memmap
    [    0.000000]   Normal zone: 7864319 pages, LIFO batch:63
    [    0.000000] On node 0, zone Normal: 1 pages in unavailable ranges
    [    0.000000] cma: Reserved 360 MiB at 0x00000000e9400000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112
    [    0.000000] pcpu-alloc: s50008 r8192 d31912 u90112 alloc=22*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 8257534
    [    0.000000] Kernel command line: loglevel=0 console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tis
    pl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbm
    c.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs) root=PARTUUID=f788ba3d-211a-f942-9acc-261d043e0053 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x000000009a800000-0x000000009e800000] (64MB)
    [    0.000000] Memory: 30211456K/33554424K available (10880K kernel code, 1148K rwdata, 4212K rodata, 1792K init, 432K bss, 2974328K reserved, 368640K cma-reser
    ved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008c0050000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c0060000
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000003] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.000277] Console: colour dummy device 80x25
    [    0.000308] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.000315] pid_max: default: 32768 minimum: 301
    [    0.000369] LSM: Security Framework initializing
    [    0.000522] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.000653] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.002023] rcu: Hierarchical SRCU implementation.
    [    0.002271] Platform MSI: msi-controller@1820000 domain created
    [    0.002418] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.002509] EFI services will not be available.
    [    0.002894] smp: Bringing up secondary CPUs ...
    [    0.011564] Detected PIPT I-cache on CPU1
    [    0.011589] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.011603] GICv3: CPU1: using allocated LPI pending table @0x00000008c0070000
    [    0.011642] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.020486] Detected PIPT I-cache on CPU2
    [    0.020512] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
    [    0.020526] GICv3: CPU2: using allocated LPI pending table @0x00000008c0080000
    [    0.020564] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
    [    0.029308] Detected PIPT I-cache on CPU3
    [    0.029335] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
    [    0.029350] GICv3: CPU3: using allocated LPI pending table @0x00000008c0090000
    [    0.029388] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
    [    0.038153] Detected PIPT I-cache on CPU4
    [    0.038181] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
    [    0.038195] GICv3: CPU4: using allocated LPI pending table @0x00000008c00a0000
    [    0.038236] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
    [    0.046990] Detected PIPT I-cache on CPU5
    [    0.047019] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
    [    0.047035] GICv3: CPU5: using allocated LPI pending table @0x00000008c00b0000
    [    0.047075] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
    [    0.055820] Detected PIPT I-cache on CPU6
    [    0.055850] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
    [    0.055865] GICv3: CPU6: using allocated LPI pending table @0x00000008c00c0000
    [    0.055905] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
    [    0.064668] Detected PIPT I-cache on CPU7
    [    0.064701] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
    [    0.064717] GICv3: CPU7: using allocated LPI pending table @0x00000008c00d0000
    [    0.064757] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
    [    0.064853] smp: Brought up 1 node, 8 CPUs
    [    0.064864] SMP: Total of 8 processors activated.
    [    0.064870] CPU features: detected: 32-bit EL0 Support
    [    0.064874] CPU features: detected: CRC32 instructions
    [    0.075555] CPU: All CPU(s) started at EL2
    [    0.075600] alternatives: patching kernel code
    [    0.076353] devtmpfs: initialized
    [    0.081270] KASLR disabled due to lack of seed
    [    0.081406] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.081419] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
    [    0.084992] pinctrl core: initialized pinctrl subsystem
    [    0.085341] DMI not present or invalid.
    [    0.085702] NET: Registered protocol family 16
    [    0.087003] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
    [    0.087815] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.088619] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.089011] thermal_sys: Registered thermal governor 'step_wise'
    [    0.089016] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.089264] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.089442] ASID allocator initialised with 65536 entries
    [    0.109033] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.109039] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.109043] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.109046] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.110509] cryptd: max_cpu_qlen set to 1000
    [    0.114285] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
    [    0.114731] vsys_3v3: supplied by evm_12v0
    [    0.115070] vsys_5v0: supplied by evm_12v0
    [    0.116305] iommu: Default domain type: Translated
    [    0.116530] SCSI subsystem initialized
    [    0.116825] mc: Linux media interface: v0.10
    [    0.116848] videodev: Linux video capture interface: v2.00
    [    0.116911] pps_core: LinuxPPS API ver. 1 registered
    [    0.116915] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.116925] PTP clock support registered
    [    0.116944] EDAC MC: Ver: 3.0.0
    [    0.118127] FPGA manager framework
    [    0.118187] Advanced Linux Sound Architecture Driver Initialized.
    [    0.118818] clocksource: Switched to clocksource arch_sys_counter
    [    0.118959] VFS: Disk quotas dquot_6.6.0
    [    0.118996] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.126093] Carveout Heap: Exported 512 MiB at 0x00000000c1000000
    [    0.126171] NET: Registered protocol family 2
    [    0.126731] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.130123] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
    [    0.130346] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.131187] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
    [    0.131595] TCP: Hash tables configured (established 262144 bind 65536)
    [    0.131712] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.132024] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.132442] NET: Registered protocol family 1
    [    0.132988] RPC: Registered named UNIX socket transport module.
    [    0.132992] RPC: Registered udp transport module.
    [    0.132994] RPC: Registered tcp transport module.
    [    0.132996] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.133006] PCI: CLS 0 bytes, default 64
    [    0.133938] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.138924] Initialise system trusted keyrings
    [    0.139114] workingset: timestamp_bits=46 max_order=23 bucket_order=0
    [    0.141013] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.141421] NFS: Registering the id_resolver key type
    [    0.141445] Key type id_resolver registered
    [    0.141448] Key type id_legacy registered
    [    0.141491] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.141495] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.141637] 9p: Installing v9fs 9p2000 file system support
    [    0.161157] Key type asymmetric registered
    [    0.161163] Asymmetric key parser 'x509' registered
    [    0.161207] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.161211] io scheduler mq-deadline registered
    [    0.161214] io scheduler kyber registered
    [    0.163805] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.164029] pinctrl-single 11c000.pinctrl: 72 pins, size 288
    [    0.168413] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.168497] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.172509] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.184668] brd: module loaded
    [    0.190575] loop: module loaded
    [    0.191486] megasas: 07.714.04.00-rc1
    [    0.194415] tun: Universal TUN/TAP device driver, 1.6
    [    0.194865] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.194869] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.194905] sky2: driver version 1.30
    [    0.195976] VFIO - User Level meta-driver version: 0.3
    [    0.196999] i2c /dev entries driver
    [    0.198613] sdhci: Secure Digital Host Controller Interface driver
    [    0.198617] sdhci: Copyright(c) Pierre Ossman
    [    0.199015] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.200221] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.200560] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.201930] optee: probing for conduit method.
    [    0.201948] optee: revision 3.19 (afacf356)
    [    0.202190] optee: dynamic shared memory is enabled
    [    0.202469] optee: initialized driver
    [    0.204263] NET: Registered protocol family 17
    [    0.204348] 9pnet: Installing 9P2000 support
    [    0.204406] Key type dns_resolver registered
    [    0.204524] Loading compiled-in X.509 certificates
    [    0.210637] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.210894] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.213523] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar')
    [    0.240960] pca953x 0-0020: supply vcc not found, using dummy regulator
    [    0.241049] pca953x 0-0020: using no AI
    [    0.263891] pca953x 0-0022: supply vcc not found, using dummy regulator
    [    0.263986] pca953x 0-0022: using AI
    [    0.264858] omap_i2c 2000000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.266562] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created
    [    0.266831] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created
    [    0.267001] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
    [    0.267261] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
    [    0.271652] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    0.271676] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    0.271695] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    0.271710] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xfffffffff
    fff -> 0x0000000000
    [    1.275484] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [    1.275494] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    1.275502] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    1.275509] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    1.275548] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    1.275558] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    1.275675] pci 0000:00:00.0: supports D1
    [    1.275683] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    1.279147] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    1.282468] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    1.282489] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    1.282866] pcieport 0000:00:00.0: PME: Signaling with IRQ 33
    [    1.283580] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    1.283607] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    1.283623] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    1.283638] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.284006] j721e-pcie 2910000.pcie: Failed to init phy
    [    1.285326] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
    [    1.285331] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.285335] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.287668] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
    [    1.287674] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.287679] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.288258] printk: console [ttyS2] disabled
    [    1.288302] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 19, base_baud = 3000000) is a 8250
    [    1.288339] printk: console [ttyS2] enabled
    [    1.288344] printk: bootconsole [ns16550a0] disabled
    [    1.330830] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.332406] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.332484] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.332628] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.332633] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.333299] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
    [    1.374843] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.376344] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
    [    1.376422] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.376546] am65-cpsw-nuss c200000.ethernet: Use random MAC address
    [    1.376555] am65-cpsw-nuss c200000.ethernet: initialized
    [    1.376559] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
    [    1.377201] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:250000000, add_val:3 pps:0
    [    1.379047] mmc0: CQHCI version 5.10
    [    1.383855] vdd_mmc1: supplied by vsys_3v3
    [    1.385293] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
    [    1.385753] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
    [    1.386212] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
    [    1.386669] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100
    [    1.387171] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
    [    1.387639] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100
    [    1.417494] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.504551] mmc0: Command Queue Engine enabled
    [    1.504563] mmc0: new HS200 MMC card at address 0001
    [    1.504996] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    1.505130] mmcblk0boot0: mmc0:0001 G1M15L partition 1 31.5 MiB
    [    1.505262] mmcblk0boot1: mmc0:0001 G1M15L partition 2 31.5 MiB
    [    1.505407] mmcblk0rpmb: mmc0:0001 G1M15L partition 3 4.00 MiB, chardev (237:0)
    [    1.508029]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
    [    2.111352] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.111377] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.111394] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.111410] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.114373] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [    3.114384] pci_bus 0001:00: root bus resource [bus 00-ff]
    [    3.114393] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
    [    3.114399] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    3.114436] pci 0001:00:00.0: [104c:b013] type 01 class 0x060400
    [    3.114445] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    3.114559] pci 0001:00:00.0: supports D1
    [    3.114566] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    3.118027] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.121442] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
    [    3.121464] pci 0001:00:00.0: PCI bridge to [bus 01]
    [    3.121857] pcieport 0001:00:00.0: PME: Signaling with IRQ 358
    [    3.123072] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
    [    3.125364] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
    [    3.130927] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    3.130949] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    3.130953] Creating 7 MTD partitions on "47040000.spi.0":
    [    3.130957] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    3.131959] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    3.132935] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    3.133900] 0x000000680
    000-0x0000006c0000 : "ospi.env"
    [    3.134876] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    3.135811] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    3.136742] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    3.139356] mmc1: CQHCI version 5.10
    [    3.140585] debugfs: Directory 'pd:73' with parent 'pm_genpd' already present!
    [    3.140614] debugfs: Directory 'pd:72' with parent 'pm_genpd' already present!
    [    3.140990] debugfs: Directory 'pd:333' with parent 'pm_genpd' already present!
    [    3.141011] debugfs: Directory 'pd:332' with parent 'pm_genpd' already present!
    [    3.146684] ALSA device list:
    [    3.146689]   No soundcards found.
    [    3.187504] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    3.222163] mmc1: new high speed SDHC card at address aaaa
    [    3.222778] mmcblk1: mmc1:aaaa SC32G 29.7 GiB
    [    3.225019]  mmcblk1: p1 p2 p3 p4
    [    5.074523] EXT4-fs (mmcblk0p8): recovery complete
    [    5.087946] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
    [    5.087993] VFS: Mounted root (ext4 filesystem) on device 179:8.
    [    5.088484] devtmpfs: mounted
    [    5.089078] Freeing unused kernel memory: 1792K
    [    5.089175] Run /sbin/init as init process
    [    5.089177]   with arguments:
    [    5.089179]     /sbin/init
    [    5.089181]   with environment:
    [    5.089183]     HOME=/
    [    5.089184]     TERM=linux
    [    5.158358] systemd[1]: System time before build time, advancing clock.
    [    5.184420] NET: Registered protocol family 10
    [    5.185314] Segment Routing with IPv6
    [    5.197810] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +AC
    L +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    5.198248] systemd[1]: Detected architecture arm64.
    [    5.227321] systemd[1]: Set hostname to <j784s4-evm>.
    [    5.435237] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock
    \xe2\x86\x92 /run/docker.sock; please update the unit file accordingly.
    [    5.496322] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.496487] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    5.496497] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    5.499788] systemd[1]: Created slice system-getty.slice.
    [    5.515027] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.516648] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    5.530998] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.532443] systemd[1]: Created slice User and Session Slice.
    [    5.547218] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    5.563197] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    5.579194] systemd[1]: Reached target Paths.
    [    5.591053] systemd[1]: Reach
    ed target Remote File Systems.
    [    5.607019] systemd[1]: Reached target Slices.
    [    5.619030] systemd[1]: Reached target Swap.
    [    5.632425] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    5.647045] systemd[1]: Reached target RPC Port Mapper.
    [    5.665684] systemd[1]: Listening on Process Core Dump Socket.
    [    5.683248] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    5.704528] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    5.705087] systemd[1]: Listening on Journal Socket (/dev/log).
    [    5.723497] systemd[1]: Listening on Journal Socket.
    [    5.735514] systemd[1]: Listening on Network Service Netlink Socket.
    [    5.751463] systemd[1]: Listening on udev Control Socket.
    [    5.767371] systemd[1]: Listening on udev Kernel Socket.
    [    5.791570] systemd[1]: Mounting Huge Pages File System...
    [    5.807424] systemd[1]: Mounting POSIX Message Queue File System...
    [    5.827402] systemd[1]: Mounting Kernel Debug File System...
    [    5.843242] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    5.859490] systemd[1]: Starting Create list of static device nodes for the current kernel...
    [    5.879098] systemd[1]: Starting Start psplash boot splash screen...
    [    5.899348] systemd[1]: Starting RPC Bind...
    [    5.915152] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    5.920442] systemd[1]: Starting Journal Service...
    [    5.940861] systemd[1]: Starting Load Kernel Modules...
    [    5.955824] cryptodev: loading out-of-tree module taints kernel.
    [    5.957213] cryptodev: driver 1.10 loaded.
    [    5.960363] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    5.978108] EXT4-fs (mmcblk0p8): re-mounted. Opts: (null)
    [    5.984549] systemd[1]: Starting udev Coldplug all Devices...
    [    6.006400] systemd[1]: Started RPC Bind.
    [    6.019702] systemd[1]: Mounted Huge Pages File System.
    [    6.039585] systemd[1]: Mounted POSIX Message Queue File System.
    [    6.059405] systemd[1]: Started Journal Service.
    [    6.345732] systemd-journald[197]: Received client request to flush runtime journal.
    [    6.524048] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.531296] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    6.611342] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.013814] random: crng init done
    [    7.013826] random: 57 urandom warning(s) missed due to ratelimiting
    [    7.161998] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b4000000
    [    7.169290] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.183920] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
    [    7.184264] remoteproc remoteproc0: 64800000.dsp is available
    [    7.196853] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.197061] vdec 4210000.video-codec: sram node not found
    [    7.200294] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c
    [    7.207121] k3-dsp-rproc 65800000.dsp: configured DSP for remoteproc mode
    [    7.207526] remoteproc remoteproc1: 65800000.dsp is available
    [    7.212905] CAN device driver interface
    [    7.215031] PVR_K:  238: Read BVNC 36.53.104.796 from HW device registers
    [    7.215050] PVR_K:  238: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [    7.216503] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.218124] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
    [    7.219794] k3-dsp-rproc 66800000.dsp: assigned reserved memory node vision-apps-c71_2-dma-memory@ba800000
    [    7.221774] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.236909] k3-dsp-rproc 66800000.dsp: configured DSP for remoteproc mode
    [    7.237126] remoteproc remoteproc2: 66800000.dsp is available
    [    7.238547] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.242649] k3-dsp-rproc 67800000.dsp: assigned reserved memory node vision-apps-c71_3-dma-memory@bdc00000
    [    7.243589] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.258384] k3-dsp-rproc 67800000.dsp: configured DSP for remoteproc mode
    [    7.258528] remoteproc remoteproc3: 67800000.dsp is available
    [    7.269444] vdec 4220000.video-codec: sram node not found
    [    7.269879] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.272413] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.293596] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.400691] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    7.400906] platform 41000000.r5f: configured R5F for IPC-only mode
    [    7.401118] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    7.402670] remoteproc remoteproc4: 41000000.r5f is available
    [    7.402761] remoteproc remoteproc4: attaching to 41000000.r5f
    [    7.406992] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    7.407023]  remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    7.407595] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    7.409152]  remoteproc4#vdev0buffer: registered virtio0 (type 7)
    [    7.409165] remoteproc remoteproc4: remote processor 41000000.r5f is now attached
    [    7.409584] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.414182] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.419844] platform 5c00000.r5f: configured R5F for remoteproc mode
    [    7.420804] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    7.421813] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    7.422142] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    7.424361] remoteproc remoteproc5: 5c00000.r5f is available
    [    7.428138] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.433236] platform 5e00000.r5f: configured R5F for remoteproc mode
    [    7.434163] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [    7.463559] remoteproc remoteproc6: 5e00000.r5f is available
    [    7.466243] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.475715] platform 5900000.r5f: configured R5F for remoteproc mode
    [    7.483845] platform 5900000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
    [    7.487235] remoteproc remoteproc7: 5900000.r5f is available
    [    7.493364] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.510271] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.514606] remoteproc remoteproc6: powering up 5e00000.r5f
    [    7.514630] remoteproc remoteproc6: Booting fw image j784s4-main-r5f1_0-fw, size 179128
    [    7.514645] m_can_platform 40528000.can: m_can device registered (irq=15, version=32)
    [    7.518194] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.521700]  remoteproc6#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [    7.522296] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    7.522398]  remoteproc6#vdev0buffer: registered virtio1 (type 7)
    [    7.522415] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
    [    7.524564] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.528931] remoteproc remoteproc5: powering up 5c00000.r5f
    [    7.528956] remoteproc remoteproc5: Booting fw image j784s4-main-r5f0_0-fw, size 1400100
    [    7.534949]  remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    7.535522] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    7.535609]  remoteproc5#vdev0buffer: registered virtio2 (type 7)
    [    7.535619] remoteproc remoteproc5: remote processor 5c00000.r5f is now up
    [    7.537606] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.592800] remoteproc remoteproc7: powering up 5900000.r5f
    [    7.592829] remoteproc remoteproc7: Booting fw image j784s4-main-r5f2_0-fw, size 592760
    [    7.598712]  remoteproc7#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
    [    7.599435] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    7.599527]  remoteproc7#vdev0buffer: registered virtio3 (type 7)
    [    7.599537] remoteproc remoteproc7: remote processor 5900000.r5f is now up
    [    7.601570] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.616293] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [    7.685243] remoteproc remoteproc0: powering up 64800000.dsp
    [    7.685268] remoteproc remoteproc0: Booting fw image j784s4-c71_0-fw, size 14815416
    [    7.685380] remoteproc remoteproc0: unsupported resource 65538
    [    7.691906] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xb4200000
    [    7.692397]  remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@b4000000
    [    7.693147] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    7.693222]  remoteproc0#vdev0buffer: registered virtio4 (type 7)
    [    7.693232] remoteproc remoteproc0: remote processor 64800000.dsp is now up
    [    7.698675] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.729777] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
    [    7.733279] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [    7.746632] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [    7.840897] remoteproc remoteproc1: powering up 65800000.dsp
    [    7.840920] remoteproc remoteproc1: Booting fw image j784s4-c71_1-fw, size 15208632
    [    7.841021] remoteproc remoteproc1: unsupported resource 65538
    [    7.847550] k3-dsp-rproc 65800000.dsp: booting DSP core using boot addr = 0xb7600000
    [    7.848018]  remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-c71_1-dma-memory@b7400000
    [    7.848577] virtio_rpmsg_bus virtio5: rpmsg host is online
    [    7.848665]  remoteproc1#vdev0buffer: registered virtio5 (type 7)
    [    7.848676] remoteproc remoteproc1: remote processor 65800000.dsp is now up
    [    7.853639] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.860191] remoteproc remoteproc2: powering up 66800000.dsp
    [    7.860215] remoteproc remoteproc2: Booting fw image j784s4-c71_2-fw, size 14815416
    [    7.860325] remoteproc remoteproc2: unsupported resource 65538
    [    7.866288] k3-dsp-rproc 66800000.dsp: booting DSP core using boot addr = 0xbaa00000
    [    7.866879]  remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-c71_2-dma-memory@ba800000
    [    7.867485] virtio_rpmsg_bus virtio6: rpmsg host is online
    [    7.867572]  remoteproc2#vdev0buffer: registered virtio6 (type 7)
    [    7.867587] remoteproc remoteproc2: remote processor 66800000.dsp is now up
    [    7.868214] remoteproc remoteproc3: powering up 67800000.dsp
    [    7.868241] remoteproc remoteproc3: Booting fw image j784s4-c71_3-fw, size 14815416
    [    7.868382] remoteproc remoteproc3: unsupported resource 65538
    [    7.872306] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.873890] k3-dsp-rproc 67800000.dsp: booting DSP core using boot addr = 0xbde00000
    [    7.877237]  remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-c71_3-dma-memory@bdc00000
    [    7.877901] virtio_rpmsg_bus virtio7: rpmsg host is online
    [    7.877996]  remoteproc3#vdev0buffer: registered virtio7 (type 7)
    [    7.878010] remoteproc remoteproc3: remote processor 67800000.dsp is now up
    [    7.882973] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.899871] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [    7.919242] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd
    [    7.928291] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xd
    [    7.935750] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.940685] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.943688] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    7.992439] usbcore: registered new interface driver usbfs
    [    7.992528] usbcore: registered new interface driver hub
    [    7.992622] usbcore: registered new device driver usb
    [    8.072841] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [    8.206887] EXT4-fs (mmcblk0p12): recovery complete
    [    8.223438] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: (null)
    [    8.261135] EXT4-fs (mmcblk0p11): recovery complete
    [    8.261150] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: (null)
    [    8.276119] EXT4-fs (mmcblk0p10): recovery complete
    [    8.276132] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null)
    [    9.015018] Bluetooth: Core ver 2.22
    [    9.015120] NET: Registered protocol family 31
    [    9.015129] Bluetooth: HCI device and connection manager initialized
    [    9.015144] Bluetooth: HCI socket layer initialized
    [    9.015153] Bluetooth: L2CAP socket layer initialized
    [    9.015184] Bluetooth: SCO socket layer initialized
    [    9.134098] am65-cpsw-nuss c200000.ethernet: down msc_sl e0000000 tmo 0
    [    9.152896] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
    [    9.173284] am65-cpsw-nuss c200000.ethernet eth1: PHY [c200f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    9.173321] am65-cpsw-nuss c200000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [    9.194178] am65-cpsw-nuss 46000000.ethernet: down msc_sl f0000000 tmo 0
    [    9.202894] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    9.219003] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    9.219025] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [   12.650209] PVR_K:  746: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
    [   12.654226] PVR_K:  746: Shader binary image 'rgx.sh.36.53.104.796' loaded
    [   13.312357] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [   13.312385] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   13.996921] PVR_K:(Error):    99: RGXSafetyEventHandler: Safety Watchdog Trigger ! [358]
    [   27.565491] Initializing XFRM netlink socket
  • It looks like core MCUX_ 1 has not been started by remoterproc mode.So other cores stuck here.
  • check "ti-processor-sdk-rtos-j784s4-evm-08_05_00_11\vision_apps\vision_apps_build_flags.mak", which says and shall means don't build executables for MCU1_1 and so on. is that correct on your setup?
    # Since MCU R5F runs in locked step mode in vision apps, dont set these to 'yes'
    BUILD_CPU_MCU1_1?=no
  • I have confirmed that BUILD_CPU_MCU1_1 is set to no, and I have not changed this configuration.
  • MCUX_1 in my description does not refer to MCU1_1.It refers to MCU2_1 MCU3_1 MCU4_1.
    Thank you for sharing the logs.
    From the logs, I see that the MCUx_1 firmwares are not loaded by the kernel. Could you please confirm if they are available in the lib file?
    Could you please confirm if the firmwares are mapped in the kernel dtsi file?
    Also, may I know why are you proceeding with remoteproc mode rather than IPC-only mode which is much efficient?
    Could you please elaborate on your usecase here to go with remoteproc mode?
    Nikhil
  • From the logs, I see that the MCUx_1 firmwares are not loaded by the kernel. Could you please confirm if they are available in the lib file?
    MCUx_1 firmwares must be OK. The reasons are as follows:
    1) I use the prebuild package.
    2) As I did in the previous comparative experiment, all firmwares can be started when I use the  IPC-only mode normally, so all the firmwares must be OK.  When using the remote mode, I only changed the uboot environment variables, but I did not change the firmware.
    Because I am using the prebuilt package, I have not changed the dtsi file.
    Of course, this is also my suspicion. I tried to make some changes in dtsi file , but it didn't work.
    All I hope you can test to see if it can be reproduced.
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1206389/tda4-j784s4-evm-takes-a-long-time-to-load-firmware-after-uboot-how-to-solve-this-problem
    The link is a problem that our team members have discovered, but we haven't found the cause and solution yet. So I tried to use remoteproc mode to avoid the process of loading firmwares in uboot
    Thank you for sharing the information.
    I did check the implementation internally and not seeing the logs of MCUx_1 is expected as when the kernel booting occurs, in the current kernel device tree, the core is setup in a lock-step mode.
    The cluster is not in Split-mode, hence, you wouldn't see any loading on Core 1.
    Hence, please proceed as suggested in the attached thread.
    Nikhil
  • I did check the implementation internally and not seeing the logs of MCUx_1 is expected as when the kernel booting occurs, in the current kernel device tree, the core is setup in a lock-step mode.
    Is there a better solution besides my colleague tried? Is there SDK update support?
    Split-mode for MCU cores poses an issue in the SDK currently.
    Hence, as suggested in the below thread, could you try loading mcu firmwares from uboot and large c7 firmwares from kernel.
    e2e.ti.com/.../quote]
    Nikhil
  • Split-mode for MCU cores poses an issue in the SDK currently.
    Thanks!I get it!
    We will try.
    Thank you very much!
