Other Parts Discussed in Thread: AM6548
I need support regarding PPS signal. The PPS signal is necessary for calibration of latencies. And at the end for obtaining clock synchronization accuracy. I tried first simple steps to verify ability to use PPS.
HW: TMDX654IDKEVM PROC062A
SW: PROCESSOR-SDK-LINUX-RT-AM65X 08.02.00.01
Check the PPS signal for synchronized clock of PTP device on one IDK board.
1. Start clock synchronization of interfaces on extension board
# phc2sys -c eth1 -s eth3 -O 0
2. Get interface related PTP device
root@am65xx-evm:~# ethtool -T eth3
Time stamping parameters for eth3:
Capabilities:
hardware-transmit
software-transmit
hardware-receive
software-receive
software-system-clock
hardware-raw-clock
PTP Hardware Clock: 3
Hardware Transmit Timestamp Modes:
off
on
Hardware Receive Filter Modes:
none
all
$root@am65xx-evm:~# ethtool -T eth1
Time stamping parameters for eth1:
Capabilities:
hardware-transmit
software-transmit
hardware-receive
software-receive
hardware-raw-clock
PTP Hardware Clock: 4
off
on
none
all3. Enable PPS signal output (LD3 and LD5 on extension board)
# echo 1 > /sys/class/ptp/ptp3/pps_enable # echo 1 > /sys/class/ptp/ptp4/pps_enable
Observed behavior
The PPS signals have shifted start of period, it is visible by eyes on blinking LEDs.
Questions
Is the PPS signal in based on the correct PTP device?
Is the PPS signal starting each 1s absolute time of PTP clock?
Check the PPS signal for synchronized clock of PTP device between two IDK board.
1. Connect two IDK boards via interface on extension board.
2. Get interface related PTP device, both boards eth3 - ptp3
Capabilities:
hardware-transmit
software-transmit
hardware-receive
software-receive
hardware-raw-clock
off
on
none
all3. Start clock master
# ptp4l -f oc.cfg -i eth3 &
4. Start slave synchronization
# ptp4l -f oc.cfg -i eth3 -s &
5. Check the status of synchronization
root@am65xx-evm:~# pmc -u -b 0 'GET TIME_STATUS_NP'
sending: GET TIME_STATUS_NP
70ff76.fffe.1d6230-0 seq 0 RESPONSE MANAGEMENT TIME_STATUS_NP
master_offset -2
ingress_time 1648099864499217328
cumulativeScaledRateOffset +0.000000000
scaledLastGmPhaseChange 0
gmTimeBaseIndicator 0
lastGmPhaseChange 0x0000'0000000000000000.0000
gmPresent true
gmIdentity 70ff76.fffe.1d60c86. Enable PPS signal output on both boards
Observed behavior
Despite the synchronized state obtained from manager the LEDs signalize PPS signal with some eye visible delay between first and second board.
Event without calibrated ingress and egress latencies, I expect synchronization accuracy less then ability to se it by eye.
Questions
Why are not the PPS signals synchronized?
Can you support us with the clarification of observed behavior?
Lukas Libal
3113.oc.cfg
