Part Number: AM6442
Hi
I have made USB compliance tests and failed. The eye is open as expected but the upper and lower limit fails.
How can I fix that?
Martin
Part Number: AM6442
Hi
How can I fix that?
Martin
Hello Martin,
Thank you for the query.
Can you confirm if these eye diagram results are post-processed by the USB Electrical Test Tool? It is the only way to determine true pass/fail.
https://www.usb.org/document-library/usbet20
Sreenivasa
Hello Sreenivasa
The measurement was made with LeCroy QualiPHY. I just did another measurement and used the USB Electrical Test Tool to analyze the results. Looks a little bit better but still fails.
Martin
Hello Martin,
Thank you for the inputs.
Are you testing this on the EVM or a custom board.
If this is a custom board, have you had a chance to test on the EVM.
If this is a customer board, help me understand the USB interface implementation.
Sreenivasa
Hello Sreenivasa
It is a custom board. See the attached PDF for schematic.
The Common Mode Choke (L700) is a Murata DLM11SN900HY2
Martin
Hello Marting.
Are all the USB connections on the same board.
Pls help me understand the point where the measurements are being done.
Sreenivasa
Hello Marting.
Did you resolve the issue.
I have not heard from you and closing the thread.
Sreenivasa
