Part Number: AM6412
Hi team,
Can AM6412 support below? Thanks.
- PWM/PTO outputs: 3,100KHz
- High speed counter input channels: 12,100Khz
Part Number: AM6412
Hi team,
Hello PY,
Thank you for the query.
Please share some additional information on the use case for better analysis.
Regards.
Sreenivasa
Hello PY,
Please check if this helps.
https://www.ti.com/lit/ug/tidu707/tidu707.pdf
Sreenivasa
Hi Sreenivasa,
Thank you. A couple of questions -
Hello PY,
Thank you for the inputs.
I need to understand more on the application to internally check.
Regards.
Sreenivasa
Hi Screenivasa,
Let's take it offline as customer info and application to be disclosed. Thanks.
