Can the data received by VPFE
I am now using the MT9D131 for DM365_EVM board, but now the problem is the camera can not output the the SRGB-10 data, if you know, can I change the configuration of VPFE_Capture.c for getting the YUV data from the camera.
Another question, can I change the VPFE_Capture.c for permet the vpfe to receive a video with frame rate less than 30 fps.
Thank you very much
  • Mingming Chen,
    You should be able to configure ISIF/CCDC of dm365 VPFE to capture RAW. If the sensor outputs NTSC/PAL YUV422, ISIF/CCDC has support for that also. You should also
    be able to program clocks properly to get desired frame rate. Please refer to VPFE user guide for more details.
