Dear TI experts,
How to check DDR CBT status(enable/disable) on TDA4VM?If enabled, I also need to obtain the AP/DRAM IO Configuration related settings, please tell me the feasible method.
Regards.
Dear TI experts,
Regards.
Command bus training should be enabled unless you are using a hand-edited DDR DTSI / header file compared to what the J7 DDR Register Config tool outputs.
A few spots you could check:
IO settings are user inputs to the J7 DDR Register Config tool. https://www.ti.com/lit/pdf/spracu8
Kevin
