Part Number: AM5706
According to the data manual (page 394) of AM570x, the land (pad) pattern size is recommended as φ 0.35.
However, the customer wants to reduce the mounting pad size of AM5706 balls to φ 0.3.
Some application notes mention that “For optimal reliability, TI recommends a 1:1 ratio between the package pad and the PCB pad on the BGA. The ratio may be reduced to 1:0.8 if trace routing constraints make it absolutely necessary.”
https://www.ti.com/jp/lit/pdf/snoa021?keyMatch=AN-1126
From this description, can they reduce the land pattern size to φ 0.3 (1 : 0.8 = 0.35 : 0.28) by NSMD (Non-Solder Mask Defined pads)?
Thanks and regards,
Hideaki
