Hi team,
Here's an issue from the customer may need your help:
There is a file in the development tool chain for tda4: Ti-processor-SDK-RTOS-j721e-EVM-08_04_00_06/tiovx/kernels_J7/include/TI/J7_dmpac_do f.h
The data structure for DOF is as follows:
/*! * \brief The configuration data structure used by the TIVX_KERNEL_DMPAC_DOF kernel. * * \ingroup group_vision_function_dmpac_dof */ typedef struct { /*! Range [0, 62] Recommended = 48, 48 if horizontal_search_range is 191 then (vertical_search_range[0] (upward) + vertical_search_range[1] (downward) <= 112) */ uint16_t vertical_search_range[2]; /*! Range [0, 191] Recommended value = 191 if vertical_search_range[0] = vertical_search_range[1] = 62 then horizontal_search_range <= 170 */ uint16_t horizontal_search_range; /*! 0: Disabled; 1: Enable post-processing median filter [recommended] */ uint16_t median_filter_enable; /*! Range [0, 31] recommended = 24 */ uint16_t motion_smoothness_factor; /*! 0 = Motion neutral, 5x5 Census Transform 1 = Forward motion 2 = Reverse motion 3 = Motion neutral, 7x Census Transform */ uint16_t motion_direction; /*! Predictor for the base image */ uint16_t base_predictor[2]; /*! Predictor for the intermediate pyramid level */ uint16_t inter_predictor[2]; /*! IIR filter alpha value recommended = 0x66 */ uint16_t iir_filter_alpha; /*! Number of internal delay slots to use for applying previous flow vector * output to temporal predictor. The use of this field and the valid values * it can take is as explained below: * - Range [0 TIVX_DMPAC_DOF_MAX_FLOW_VECTOR_DELAY] * - This field is validated and used only if temporal predictor is ON. This * is a pre-condition for all the cases below. * 1) When pipelining is OFF, then this field must be set to 0. The understanding * is that with this configuration, external delay object shall be used for * providing the input flow vector. * 2) When pipelining is ON and if an external delay object is used, then this * field must be set to 0. * 3) When pipelining is ON and if no external delay object is used, then this * field must be set to a valid non-zero value. * * In case (3) above, the node stores pointers to the previous output flow vectors * to be used as potential inputs later so it is important that under this configuration * the higher level application does not alter the output buffer data in any way. Also, the * node parameter must be configured with the buffer depth appropriately such that all the * configured buffers are used and recycled during the pipelining operation. */ uint16_t flow_vector_internal_delay_num; } tivx_dmpac_dof_params_t;
Regarding a few parameters in DOF, the customer has the following questions:
1) What does vertical_search_range and horizontal_search_range mean? Looks like a search range, but what do they represent? The block match?
2) Motion_smothickness_factor, how does this parameter work with the algorithm? How to understand it at the algorithmic level?
3) Motion_direction, literally, the customer is not sure what it means.
4) IIR_filter_alpha, what does "iir" do in the algorithm?
OR is there any docs tell more about the principle of the specific implementation of the DOF algorithm for reference? Thanks.
Cherry
