Hi! I found some mistakes about the DSK6455 edma chain example which chains channel 0 and channel 8 to start two different transfers.
Each of channels transfers 1024 bytes, while the result is that only channel 0 tansfer is done and channel 8 transfer is failed!
At last, it only verifys 512*2=1024 bytes data and doesn't verify the data transfered by the channel 8. I tried to correct it but failed. I need your advice!
Here is the souce below!
Thanks in advance!
* Copyright (c) Texas Instruments Inc 2002, 2003, 2004, 2005, 2006
* Use of this software is controlled by the terms and conditions found in the
* license agreement under which this software has been supplied.
* @file Edma_chain_example.c
* @path $(CSLPATH)\example\edma\edma_chain_example\src
* @desc Example of EDMA
* @n Target Platform: EVM
* @n <b> Example Description </b>
* @n This is an example of the CSL EDMA usage. This example illustrates a
* chain triggering where the completion of the transfer on one channels
* triggers the transfer on another channel. This example,
* 1. Initializes the CSL EDMA module
* 2. Opens and Sets up Edma module to default values
* 3. Opens EDMA channel 0 in the region 5
* 4. Sets up the EDMA PARAM entry for channel 0 using
* CSL_edma3ParamSetup() API
* 5. Opens EDMA channel 8 in the region 5
* 6. Sets up the EDMA PARAM entry for channel 8 using
* 7. Enable the channel 0 and 8
* 8. Manually triggers the channel 0, completion of this transfer
* triggers the transfer on channel 8.
* 9. Waits for EDMA transfer to complete
* 10. Does the data comparision to ensure the transffered data is proper
* or not and
* 11. Displays the messages based on step 10
* <b> Procedure to run the example </b>
* @verbatim
* 1. Configure the CCS setup to work with the emulator being used
* 2. Please refer CCS manual for setup configuration and loading
* proper GEL file
* 3. Launch CCS window
* 4. Open project Edma_chain_example.pjt
* 5. Build the project and load the .out file of the project.
* @endverbatim
* Revision History
* 08-Feb-2006 ds File Created
* 28-Mar-2006 ds Added clearing the EDMA error registers
#include <stdio.h>
#include <csl_edma3.h>
#include <soc.h>
/* Globals */
Uint8 srcBuff1[512];
Uint8 srcBuff2[512];
Uint8 dstBuff1[512];
Uint8 dstBuff2[512];
Uint32 passStatus = 1;
/* Forward declaration */
void edma_chain_example (void);
* @func main
* @desc
* This is the main routine for the file.
void main(void)
/* Invoke example */
edma_chain_example ();
return;
* @func edma_chain_example
* @arg
* NONE
* @desc
* This is the example routine which perform edma interrupt.
* It implements following steps
* 1. Intializes and Opens the Edma
* 2. Sets up the edma module using the API csl_edma3Hwsetup ()
* 4. Enables the edma region5 using CSL_EDMA3_CMD_DMAREGION_ENABLE.
* 5. Opens the channel 0 and get the param handle.
* 6. Sets up the edma param entry for channel 0
* 7. Opens the channel 8 and get the param handle.
* 8. Sets up the edma param entry for channel 8
* 9. Enables the channels using CSL_EDMA3_CMD_CHANNEL_ENABLE
* 10. Manually trigger the channel 0 using CSL_EDMA3_CMD_CHANNEL_SET.
* 10. Waits for transfer to complete.
* 11. Compares the data in the destination buffer is proper or not.
* 12. Closes the edma module and channel.
* @return
* NONE
CSL_Edma3Handle hModule;
CSL_Edma3HwSetup hwSetup;
CSL_Edma3Obj edmaObj;
CSL_Edma3ParamHandle hParamBasic;
CSL_Edma3ParamHandle hParamBasic1;
CSL_Edma3ChannelObj chObj;
CSL_Edma3ChannelObj chObj1;
CSL_Edma3CmdIntr regionIntr;
CSL_Edma3CmdDrae regionAccess;
CSL_Edma3ChannelHandle hChannel;
CSL_Edma3ChannelHandle hChannel1;
CSL_Edma3ParamSetup myParamSetup;
CSL_Edma3ParamSetup myParamSetup1;
CSL_Edma3Context context;
CSL_Edma3ChannelAttr chAttr;
CSL_Edma3ChannelAttr chAttr1;
CSL_Status status;
CSL_Edma3HwDmaChannelSetup dmahwSetup;
CSL_Edma3ChannelErr chErrClear;
volatile Uint32 loopIndex;
printf ("Running Edma Example\n");
/* Module Initialization */
status = CSL_edma3Init(&context);
if (status != CSL_SOK) {
printf ("Edma module initialization failed\n");
return;
/* Module level open */
hModule = CSL_edma3Open(&edmaObj,CSL_EDMA3,NULL,&status);
if ( (hModule == NULL) || (status != CSL_SOK)) {
printf ("Edma module open failed\n");
return;
/* Module setup */
dmahwSetup.paramNum = 0;
dmahwSetup.que = CSL_EDMA3_QUE_0;
hwSetup.dmaChaSetup = &dmahwSetup;
hwSetup.qdmaChaSetup = NULL;
status = CSL_edma3HwSetup(hModule,&hwSetup);
printf ("Hardware setup failed\n");
CSL_edma3Close (hModule);
return;
/* DRAE enable(Bits 0-15) for the shadow region 5 */
regionAccess.region = CSL_EDMA3_REGION_5 ;
regionAccess.drae = 0xFFFF ;
regionAccess.draeh = 0x0 ;
status = CSL_edma3HwControl(hModule,CSL_EDMA3_CMD_DMAREGION_ENABLE, \
®ionAccess);
printf ("Edma region enable command failed\n");
return;
/* Channel 0 open in context of shadow region 5 */
chAttr.regionNum = CSL_EDMA3_REGION_5;
chAttr.chaNum = CSL_EDMA3_CHA_DSP_EVT;
hChannel = CSL_edma3ChannelOpen(&chObj, CSL_EDMA3, &chAttr, &status);
if ((hChannel == NULL) || (status != CSL_SOK)) {
printf ("Edma channel open failed\n");
return;
/* Obtain a handle to parameter set 0 */
hParamBasic = CSL_edma3GetParamHandle(hChannel, 0, &status);
if (hParamBasic == NULL) {
printf ("Edma get param handle for param entry 0 failed\n");
return;
/* Setup the param set */
myParamSetup.option = CSL_EDMA3_OPT_MAKE( CSL_EDMA3_ITCCH_DIS, \
CSL_EDMA3_TCCH_EN, \
CSL_EDMA3_ITCINT_DIS, \
CSL_EDMA3_TCINT_EN,\
8,
CSL_EDMA3_TCC_NORMAL,\
CSL_EDMA3_FIFOWIDTH_NONE, \
CSL_EDMA3_STATIC_DIS, \
CSL_EDMA3_SYNC_AB, \
CSL_EDMA3_ADDRMODE_INCR, \
myParamSetup.srcAddr = (Uint32)srcBuff1;
myParamSetup.aCntbCnt = CSL_EDMA3_CNT_MAKE(512,2);
myParamSetup.dstAddr = (Uint32)dstBuff1;
myParamSetup.srcDstBidx = CSL_EDMA3_BIDX_MAKE(512,512);
myParamSetup.linkBcntrld = CSL_EDMA3_LINKBCNTRLD_MAKE(CSL_EDMA3_LINK_NULL,0);
myParamSetup.srcDstCidx = CSL_EDMA3_CIDX_MAKE(0,1);
myParamSetup.cCnt = 1;
status = CSL_edma3ParamSetup(hParamBasic, &myParamSetup);
printf("Edma parameter entry setup is failed\n");
return;
/* Channel 8 open in context of shadow region 5 */
chAttr1.regionNum = CSL_EDMA3_REGION_5;
chAttr1.chaNum = CSL_EDMA3_CHA_8;
hChannel1 = CSL_edma3ChannelOpen(&chObj1, CSL_EDMA3, &chAttr1, &status);
if ((hChannel1 == NULL) || (status != CSL_SOK)) {
return;
/* Obtain a handle to parameter set 8 */
hParamBasic1 = CSL_edma3GetParamHandle(hChannel1, 8, &status);
myParamSetup1.option = CSL_EDMA3_OPT_MAKE(CSL_EDMA3_ITCCH_DIS, \
CSL_EDMA3_TCINT_EN, \
1, \
CSL_EDMA3_TCC_NORMAL, \
TRUE,CSL_EDMA3_SYNC_AB, \
myParamSetup1.srcAddr = (Uint32)srcBuff2;
myParamSetup1.aCntbCnt = CSL_EDMA3_CNT_MAKE(512,2);
myParamSetup1.dstAddr = (Uint32)dstBuff2;
myParamSetup1.srcDstBidx = CSL_EDMA3_BIDX_MAKE(512,512);
myParamSetup1.linkBcntrld = CSL_EDMA3_LINKBCNTRLD_MAKE(CSL_EDMA3_LINK_NULL,0);
myParamSetup1.srcDstCidx = CSL_EDMA3_CIDX_MAKE(0,1);
myParamSetup1.cCnt = 1;
status = CSL_edma3ParamSetup(hParamBasic1,&myParamSetup1);
return;
/* Enable channel 0 */
status = CSL_edma3HwChannelControl(hChannel,CSL_EDMA3_CMD_CHANNEL_ENABLE, NULL);
printf("Edma channel enable command for channel 0 is failed\n");
return;
/* Enable channel 8 */
status = CSL_edma3HwChannelControl(hChannel1,CSL_EDMA3_CMD_CHANNEL_ENABLE, \
NULL);
printf("Edma channel enable command for channel 8 is failed\n");
return;
/* Initialize data */
for (loopIndex = 0; loopIndex < 512; loopIndex++) {
srcBuff1[loopIndex] = loopIndex;
srcBuff2[loopIndex] = loopIndex;
dstBuff1[loopIndex] = 0;
dstBuff2[loopIndex] = 0;
/* Trigger Channel 0 */
CSL_edma3HwChannelControl(hChannel,CSL_EDMA3_CMD_CHANNEL_SET,NULL);
regionIntr.region = CSL_EDMA3_REGION_5;
do {
/* Poll on interrupt bit 8 */
CSL_edma3GetHwStatus(hModule,CSL_EDMA3_QUERY_INTRPEND,®ionIntr);
} while (!(regionIntr.intr & 0x100));
/* Clear interrupt bit 8 */
status = CSL_edma3HwControl(hModule,CSL_EDMA3_CMD_INTRPEND_CLEAR, \
®ionIntr);
printf("Edma clear interrupt bit 0 command is failed\n");
return;
/* Check transfer */
if(Verify_Transfer(512, 1, 1, 0, 0, 0, 0, srcBuff1, dstBuff1,TRUE) == FALSE)
passStatus = 0;
if(Verify_Transfer(512, 1, 1, 0, 0, 0, 0, srcBuff2, dstBuff2,TRUE) == FALSE)
passStatus = 0;
if (passStatus == 1)
printf ("<<EXAMPLE PASSED>>: Edma Chain Transfer Passed\n");
else {
printf ("<<EXAMPLE FAILED>>: Edma Chain Transfer Failed\n");
return;
/* Disable the region 5 */
®ionAccess);
/* clear the EDMA error registers */
chErrClear.missed = TRUE;
chErrClear.secEvt = TRUE;
CSL_edma3HwChannelControl (hChannel, CSL_EDMA3_CMD_CHANNEL_DISABLE, NULL);
CSL_edma3HwChannelControl (hChannel, CSL_EDMA3_CMD_CHANNEL_CLEARERR,
&chErrClear);
CSL_edma3HwChannelControl (hChannel, CSL_EDMA3_CMD_CHANNEL_CLEAR, NULL);
/* Close channel */
status = CSL_edma3ChannelClose(hChannel);
printf("Edma channel close failed\n");
return;
/* Close edma module */
status = CSL_edma3Close(hModule);
printf("Edma module close failed\n");
return;
printf ("=============================================================\n");
return;
