Part Number: AM3358
Hello!
rootpart=1:2
flagpart=1:5
bootdir=/boot
pru1textfile=/lib/firmware/pru-display/text.bin
pru1text=0x4a338000
pru1datafile=/lib/firmware/pru-display/data.bin
pru1data=0x4a302000
shareddatafile=/lib/firmware/pru-display/splash.bin
shareddata=0x4a310000
bootfile=zImage
console=ttyO0,115200n8
fdtaddr=0x88000000
fdtfile=xl-bone.dtb
loadaddr=0x82000000
mmcroot=/dev/mmcblk1p2 ro
mmcrootfstype=ext4 rootwait
optargs=consoleblank=0
mmcargs=setenv bootargs console=${console} root=${mmcroot} rootfstype=${mmcrootfstype} ${optargs}
loadfdt=load mmc ${rootpart} ${fdtaddr} ${bootdir}/${fdtfile}
loadimage=load mmc ${rootpart} ${loadaddr} ${bootdir}/${bootfile}
boot_three=setenv rootpart 1:3; setenv mmcroot /dev/mmcblk1p3
findroot=\
if test -e mmc ${flagpart} three; then \
if test -e mmc ${flagpart} three_ok; then \
run boot_three; \
elif test ! -e mmc ${flagpart} three_tried; then \
fatwrite mmc ${flagpart} ${loadaddr} three_tried 4; \
run boot_three; \
fi; \
elif test -e mmc ${flagpart} two; then \
if test ! -e mmc ${flagpart} two_ok; then \
if test -e mmc ${flagpart} two_tried; then \
run boot_three; \
else \
fatwrite mmc ${flagpart} ${loadaddr} two_tried 4; \
fi; \
fi; \
fi;
uenvcmd=\
run findroot; \
echo Using root partition ${rootpart}; \
if test "${fdtfile}" = "xl-bone.dtb"; then \
prussc 0 32 6 14 2666; \
load mmc ${rootpart} ${pru1text} ${pru1textfile}; \
load mmc ${rootpart} ${pru1data} ${pru1datafile}; \
load mmc ${rootpart} ${shareddata} ${shareddatafile}; \
pruboot 1; \
fi; \
if run loadfdt; then \
echo Loaded ${fdtfile}; \
if run loadimage; then \
run mmcargs; \
bootz ${loadaddr} - ${fdtaddr}; \
fi; \
fi;
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.158-gd9ca44672c (oe-user@oe-host) (arm-poky-linux-gnueabi-gcc (GCC) 9.5.0, GNU ld (GNU Binutils) 2.34.0.20200910) #1 PREEMPT Tue Jan 24 02:11:13 UTC 2023
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Vorne XL (BeagleBone Black)
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Failed to reserve 512 MiB
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000080000000-0x000000009fdfffff]
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e8fffff]
[ 0.000000] node 0: [mem 0x000000009e900000-0x000000009e9fffff]
[ 0.000000] node 0: [mem 0x000000009ea00000-0x000000009fdfffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fdfffff]
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129412
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait consoleblank=0
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 499452K/522240K available (10240K kernel code, 757K rwdata, 3548K rodata, 1024K init, 283K bss, 22788K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[ 0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segment@200000/target-module@31000
[ 0.000010] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000028] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000394] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
[ 0.001786] Console: colour dummy device 80x30
[ 0.001827] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.001834] This ensures that you still see kernel messages. Please
[ 0.001840] update your kernel commandline.
[ 0.001890] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[ 0.090471] pid_max: default: 32768 minimum: 301
[ 0.090627] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.090643] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.091519] CPU: Testing write buffer coherency: ok
[ 0.091596] CPU0: Spectre v2: using BPIALL workaround
[ 0.092652] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.092814] rcu: Hierarchical SRCU implementation.
[ 0.092911] EFI services will not be available.
[ 0.093301] devtmpfs: initialized
[ 0.105544] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.105811] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.105836] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[ 0.105970] pinctrl core: initialized pinctrl subsystem
[ 0.106789] DMI not present or invalid.
[ 0.107499] NET: Registered protocol family 16
[ 0.108069] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.126385] l3-aon-clkctrl:0000:0: failed to disable
[ 0.127592] thermal_sys: Registered thermal governor 'fair_share'
[ 0.127604] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.127618] thermal_sys: Registered thermal governor 'step_wise'
[ 0.127626] thermal_sys: Registered thermal governor 'user_space'
[ 0.128259] cpuidle: using governor ladder
[ 0.128302] cpuidle: using governor menu
[ 1.274097] No ATAGs?
[ 1.274127] hw-breakpoint: debug architecture 0x4 unsupported.
[ 1.300880] iommu: Default domain type: Translated
[ 1.303078] SCSI subsystem initialized
[ 1.303551] mc: Linux media interface: v0.10
[ 1.303593] videodev: Linux video capture interface: v2.00
[ 1.303707] pps_core: LinuxPPS API ver. 1 registered
[ 1.303719] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.303741] PTP clock support registered
[ 1.304729] Advanced Linux Sound Architecture Driver Initialized.
[ 1.306094] clocksource: Switched to clocksource dmtimer
[ 1.313547] NET: Registered protocol family 2
[ 1.313839] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.314935] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 1.315000] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 1.315042] TCP bind hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 1.315080] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.315189] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 1.315212] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 1.315353] NET: Registered protocol family 1
[ 1.315955] RPC: Registered named UNIX socket transport module.
[ 1.315970] RPC: Registered udp transport module.
[ 1.315977] RPC: Registered tcp transport module.
[ 1.315983] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.315995] NET: Registered protocol family 44
[ 1.316016] PCI: CLS 0 bytes, default 64
[ 1.317180] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 1.318425] Initialise system trusted keyrings
[ 1.318841] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 1.322738] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.323604] NFS: Registering the id_resolver key type
[ 1.323671] Key type id_resolver registered
[ 1.323682] Key type id_legacy registered
[ 1.323783] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.323794] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.323833] ntfs: driver 2.1.32 [Flags: R/O].
[ 1.324473] Key type asymmetric registered
[ 1.324493] Asymmetric key parser 'x509' registered
[ 1.324542] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 1.324554] io scheduler mq-deadline registered
[ 1.324563] io scheduler kyber registered
[ 1.594479] ti-sysc: probe of 44e31000.target-module failed with error -16
[ 1.644571] ti-sysc: probe of 48040000.target-module failed with error -16
[ 1.739488] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 1.867801] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[ 1.867849] edma 49000000.dma: TI EDMA DMA engine driver
[ 1.887212] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[ 1.939249] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 1.943844] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 20, base_baud = 3000000) is a 8250
[ 2.629250] printk: console [ttyS0] enabled
[ 2.635437] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 38, base_baud = 3000000) is a 8250
[ 2.645972] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 39, base_baud = 3000000) is a 8250
[ 2.657904] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 2.666453] random: crng init done
[ 2.686418] brd: module loaded
[ 2.696377] loop: module loaded
[ 2.766129] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 2.776287] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 2.786029] cpsw-switch 4a100000.switch: initialized cpsw ale version 1.4
[ 2.792983] cpsw-switch 4a100000.switch: ALE Table size 1024
[ 2.798831] cpsw-switch 4a100000.switch: cpts: overflow check period 500 (jiffies)
[ 2.806475] cpsw-switch 4a100000.switch: CPTS: ref_clk_freq:250000000 calc_mult:2147483648 calc_shift:29 error:0 nsec/sec
[ 2.817589] cpsw-switch 4a100000.switch: Detected MACID = 00:35:ff:95:da:53
[ 2.825469] cpsw-switch 4a100000.switch: initialized (regs 0x4a100000, pool size 256) hw_ver:0019010C 1.12 (0)
[ 2.836771] i2c /dev entries driver
[ 2.843136] cpuidle: enable-method property 'ti,am3352' found operations
[ 2.850621] sdhci: Secure Digital Host Controller Interface driver
[ 2.856878] sdhci: Copyright(c) Pierre Ossman
[ 2.862297] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.870467] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[ 2.879189] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.899820] pinctrl-single 44e10800.pinmux: pin PIN107 already requested by 44e10800.pinmux; cannot claim for 48038000.mcasp
[ 2.926102] pinctrl-single 44e10800.pinmux: pin-107 (48038000.mcasp) status -22
[ 2.933451] pinctrl-single 44e10800.pinmux: could not request pin 107 (PIN107) from group mcasp0_pins on device pinctrl-single
[ 2.946440] davinci-mcasp 48038000.mcasp: Error applying setting, reverse things back
[ 2.954346] davinci-mcasp: probe of 48038000.mcasp failed with error -22
[ 2.962117] NET: Registered protocol family 10
[ 2.967758] Segment Routing with IPv6
[ 2.971517] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.977547] mmc1: SDHCI controller on 481d8000.mmc [481d8000.mmc] using External DMA
[ 2.987139] NET: Registered protocol family 17
[ 2.992126] Key type dns_resolver registered
[ 2.997219] omap_voltage_late_init: Voltage driver support not added
[ 3.004598] Loading compiled-in X.509 certificates
[ 3.021734] gpio-26 (relay_output): hogged as output/low
[ 3.027332] gpio-27 (input_mode_output): hogged as output/low
[ 3.033662] OMAP GPIO hardware version 0.1
[ 3.066644] tps65217-pmic: Failed to locate of_node [id: -1]
[ 3.077510] mmc1: new high speed MMC card at address 0001
[ 3.084266] mmcblk1: mmc1:0001 M62704 3.56 GiB
[ 3.089797] tps65217-bl: Failed to locate of_node [id: -1]
[ 3.095702] mmcblk1boot0: mmc1:0001 M62704 partition 1 2.00 MiB
[ 3.103872] mmcblk1boot1: mmc1:0001 M62704 partition 2 2.00 MiB
[ 3.110162] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 3.116251] mmcblk1rpmb: mmc1:0001 M62704 partition 3 512 KiB, chardev (243:0)
[ 3.124024] pinctrl-single 44e10800.pinmux: pin PIN40 already requested by 44e10800.pinmux; cannot claim for 0-0070
[ 3.134558] pinctrl-single 44e10800.pinmux: pin-40 (0-0070) status -22
[ 3.141129] pinctrl-single 44e10800.pinmux: could not request pin 40 (PIN40) from group nxp_hdmi_bonelt_pins on device pinctrl-single
[ 3.153278] tda998x 0-0070: Error applying setting, reverse things back
[ 3.159950] tda998x: probe of 0-0070 failed with error -22
[ 3.165565] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 3.171844] gpio-46 (xl_status_output): hogged as output/low
[ 3.177600] gpio-48 (digital_display): hogged as output/low
[ 3.183207] gpio-50 (digital_display): hogged as output/low
[ 3.188828] gpio-51 (digital_display): hogged as output/low
[ 3.194434] gpio-60 (digital_display): hogged as output/low
[ 3.202993] mmcblk1: p1 p2
[ 3.207559] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 3.213755] gpio-66 (spi_select): hogged as output/low
[ 3.220010] gpio-67 (spi_select): hogged as output/low
[ 3.225191] gpio-68 (spi_select): hogged as output/low
[ 3.230485] gpio-69 (spi_select): hogged as output/low
[ 3.242172] cpu cpu0: _opp_add_static_v2: opp key field not found
[ 3.248516] cpu cpu0: _of_add_opp_table_v2: Failed to add OPP, -19
[ 3.255026] cpu cpu0: OPP table can't be empty
[ 3.261142] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[ 3.273117] ALSA device list:
[ 3.278760] No soundcards found.
[ 3.282815] sdhci-omap 48060000.mmc: Got CD GPIO
[ 3.287933] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
[ 3.346405] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
[ 3.360966] EXT4-fs (mmcblk1p2): INFO: recovery required on readonly filesystem
[ 3.368496] EXT4-fs (mmcblk1p2): write access will be enabled during recovery
[ 3.795364] EXT4-fs (mmcblk1p2): recovery complete
[ 3.801497] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.809755] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.817511] devtmpfs: mounted
[ 3.822003] Freeing unused kernel memory: 1024K
[ 3.827121] Run /sbin/init as init process
[ 4.009130] systemd[1]: System time before build time, advancing clock.
[ 4.062617] systemd[1]: systemd 244.5+ running in system mode. (-PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 4.085107] systemd[1]: Detected architecture arm.
Welcome to Poky (Yocto Project Reference Distro) 3.1.22 (dunfell)!
[ 4.137160] systemd[1]: Set hostname to <xl>.
[ 4.431337] systemd[1]: sysinit.target: Wants dependency dropin /etc/systemd/system/sysinit.target.wants/networking.service target /etc/init.d/networking has different name
[ 4.630248] systemd[1]: multi-user.target: Wants dependency dropin /etc/systemd/system/multi-user.target.wants/syslog.service target /lib/systemd/system/rsyslog.service has different name
[ 4.879674] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 4.918246] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 4.956893] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 4.996815] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 5.036777] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 5.076445] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 5.116396] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 5.156426] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 5.211778] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 5.246533] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 5.287449] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 5.327045] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 5.372034] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 5.381535] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 5.417451] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 5.457488] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 5.497069] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 5.537197] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 5.552234] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.602661] systemd[1]: Mounting Kernel Debug File System...
[ 5.653108] systemd[1]: Starting Create list of static device nodes for the current kernel...
Starting Create list of st…odes for the current kernel...
[ 5.713502] systemd[1]: Starting RPC Bind...
[ 5.762529] systemd[1]: Starting File System Check on Root Device...
[ 5.828037] systemd[1]: Starting Journal Service...
[ 5.878966] systemd[1]: Starting Load Kernel Modules...
[ 5.947374] systemd[1]: Starting udev Coldplug all Devices...
[ 6.017735] pfi: loading out-of-tree module taints kernel.
[ 6.024009] pfi: interface=eth0, pin=47
[ 6.040595] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 6.062289] pfi: initialization succeeded
[ 6.088059] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 6.127673] systemd[1]: Mounted Kernel Debug File System.
[ OK ] Mounted Kernel Debug File System.
[ 6.160389] systemd[1]: Started Create list of static device nodes for the current kernel.
[ OK ] Started Create list of sta… nodes for the current kernel.
[ 6.227338] systemd[1]: Started File System Check on Root Device.
[ OK ] Started File System Check on Root Device.
[ 6.260775] systemd[1]: Started Load Kernel Modules.
[ OK ] Started Load Kernel Modules.
[ 6.318406] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 6.377457] systemd[1]: Mounting Kernel Configuration File System...
[ 6.423054] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 6.492436] systemd[1]: Starting Apply Kernel Variables...
Starting Apply Kernel Variables...[ 6.547187] EXT4-fs (mmcblk1p2): re-mounted. Opts: nodelalloc
[ 6.620740] systemd[1]: Mounted Kernel Configuration File System.
