PROCESSOR-SDK-AM62X: Unhandled External Abort received on 0x80000001 from S-EL1
Part Number: PROCESSOR-SDK-AM62X
My image can boot using eval kit but failed to boot using my custom board. Can you please tell me that which dts files should I change and what should I modified?
ERROR:   Unhandled External Abort received on 0x80000001 from S-EL1
ERROR:   exception reason=1 syndrome=0x92000010
Unhandled Exception from EL1
x0             = 0xffff800011797090
x1             = 0xffff000001b68000
x2             = 0x0000000000000000
x3             = 0xffff0000050bd600
x4             = 0xffff000000283e10
x5             = 0x000000000000008b
x6             = 0x0000000000000041
x7             = 0xffff8000111d4000
x8             = 0xffff8000110ba494
x9             = 0x0140000000000000
x10            = 0x0000000000001000
x11            = 0xffff800011cbd000
x12            = 0x0000000000000001
x13            = 0x0000000000000000
x14            = 0x00000000000002c7
x15            = 0x0000649ca7ca8254
x16            = 0x00000000a2589e35
x17            = 0x000000000000001c
x18            = 0x00000000be26a04d
x19            = 0xffff00000406e080
x20            = 0xffff000000283c10
x21            = 0xffff00000406e090
x22            = 0xffff000000283c00
x23            = 0xffff00000406e120
x24            = 0x0000000000000024
x25            = 0xffff800008c15100
x26            = 0xffff800011182348
x27            = 0x0000000000000100
x28            = 0x0000000000000013
x29            = 0xffff80001167b910
x30            = 0xffff800008c1232c
scr_el3        = 0x000000000000073d
sctlr_el3      = 0x0000000030cd183f
cptr_el3       = 0x0000000000000000
tcr_el3        = 0x0000000080803520
daif           = 0x00000000000002c0
mair_el3       = 0x00000000004404ff
spsr_el3       = 0x0000000080000005
elr_el3        = 0xffff800008c1233c
ttbr0_el3      = 0x000000009e7920c0
esr_el3        = 0x0000000092000010
far_el3        = 0xffff800011797090
spsr_el1       = 0x0000000060000005
elr_el1        = 0xffff8000104b3b0c
spsr_abt       = 0x0000000000000000
spsr_und       = 0x0000000000000000
spsr_irq       = 0x0000000000000000
spsr_fiq       = 0x0000000000000000
sctlr_el1      = 0x0000000034d4d91d
actlr_el1      = 0x0000000000000000
cpacr_el1      = 0x0000000000300000
csselr_el1     = 0x0000000000000000
sp_el1         = 0xffff80001167b910
esr_el1        = 0x0000000056000000
ttbr0_el1      = 0x00000000841e7000
ttbr1_el1      = 0x00b8000082ee5000
mair_el1       = 0x000c0400bb44ffff
amair_el1      = 0x0000000000000000
tcr_el1        = 0x00000032b5d03590
tpidr_el1      = 0xffff80006ec5d000
tpidr_el0      = 0x0000ffff93b911e0
tpidrro_el0    = 0x0000000000000000
par_el1        = 0x0000000000000000
mpidr_el1      = 0x0000000080000001
afsr0_el1      = 0x0000000000000000
afsr1_el1      = 0x0000000000000000
contextidr_el1 = 0x0000000000000000
vbar_el1       = 0xffff800010010800
cntp_ctl_el0   = 0x0000000000000005
cntp_cval_el0  = 0x0000000078553f12
cntv_ctl_el0   = 0x0000000000000000
cntv_cval_el0  = 0x0000000000000000
cntkctl_el1    = 0x00000000000000d6
sp_el0         = 0x000000009e78cc40
isr_el1        = 0x0000000000000040
dacr32_el2     = 0x0000000000000000
ifsr32_el2     = 0x0000000000000000
cpuectlr_el1   = 0x0000000000000040
cpumerrsr_el1  = 0x00000000000800d3
l2merrsr_el1   = 0x000000001000fa40
cpuactlr_el1   = 0x00001000090ca000
    We'll need more data points
    1/. Which SDK version your SW is based off
    2/. What SW changes was made
    3/. Full boot log
    4/. ...
    -Hong
  • 1. We are using ti-processor-sdk-linux-am62xx-evm-08.04.01.03
    2. We only change the DDR for the k3-am62x-sk-ddr4-1600MTs.dtsi in /home/$USER/ti-processor-sdk-linux-am62xx-evm-08.04.01.03/board-support/u-boot-2021.01+gitAUTOINC+2dd2e1d366-g2dd2e1d366/arch/arm/dts. (Changing the memory frequency to 625Hz and the driver impedance to 48Ohm)
    // SPDX-License-Identifier: GPL-2.0+
     * This file was generated with the
     * AM62x SysConfig DDR Subsystem Register Configuration Tool v0.09.08
     * Fri Mar 17 2023 10:28:39 GMT+0800 (Singapore Standard Time)
     * DDR Type: DDR4
     * Frequency = 625MHz (1250MTs)
     * Density: 16Gb
     * Number of Ranks: 1
    #define DDRSS_PLL_FHS_CNT 6
    #define DDRSS_PLL_FREQUENCY_1 312500000
    #define DDRSS_PLL_FREQUENCY_2 312500000
    #define DDRSS_CTL_0_DATA 0x00000A00
    #define DDRSS_CTL_1_DATA 0x00000000
    #define DDRSS_CTL_2_DATA 0x00000000
    #define DDRSS_CTL_3_DATA 0x00000000
    #define DDRSS_CTL_4_DATA 0x00000000
    #define DDRSS_CTL_5_DATA 0x00000000
    #define DDRSS_CTL_6_DATA 0x00000000
    #define DDRSS_CTL_7_DATA 0x0006B1F6
    #define DDRSS_CTL_8_DATA 0x00000000
    #define DDRSS_CTL_9_DATA 0x00000000
    #define DDRSS_CTL_10_DATA 0x00000000
    #define DDRSS_CTL_11_DATA 0x0006B1F6
    #define DDRSS_CTL_12_DATA 0x00000000
    #define DDRSS_CTL_13_DATA 0x00000000
    #define DDRSS_CTL_14_DATA 0x00000000
    #define DDRSS_CTL_15_DATA 0x0006B1F6
    #define DDRSS_CTL_16_DATA 0x00000000
    #define DDRSS_CTL_17_DATA 0x00000000
    #define DDRSS_CTL_18_DATA 0x00000000
    #define DDRSS_CTL_19_DATA 0x01010100
    #define DDRSS_CTL_20_DATA 0x01000100
    #define DDRSS_CTL_21_DATA 0x01000110
    #define DDRSS_CTL_22_DATA 0x02010002
    #define DDRSS_CTL_23_DATA 0x0001E848
    #define DDRSS_CTL_24_DATA 0x0004C4B4
    #define DDRSS_CTL_25_DATA 0x02550255
    #define DDRSS_CTL_26_DATA 0x00000255
    #define DDRSS_CTL_27_DATA 0x00000000
    #define DDRSS_CTL_28_DATA 0x00000000
    #define DDRSS_CTL_29_DATA 0x00000000
    #define DDRSS_CTL_30_DATA 0x00000000
    #define DDRSS_CTL_31_DATA 0x00000000
    #define DDRSS_CTL_32_DATA 0x00000000
    #define DDRSS_CTL_33_DATA 0x00000000
    #define DDRSS_CTL_34_DATA 0x00000000
    #define DDRSS_CTL_35_DATA 0x00000000
    #define DDRSS_CTL_36_DATA 0x00000000
    #define DDRSS_CTL_37_DATA 0x00000000
    #define DDRSS_CTL_38_DATA 0x0400091C
    #define DDRSS_CTL_39_DATA 0x1C1C1C1C
    #define DDRSS_CTL_40_DATA 0x0400091C
    #define DDRSS_CTL_41_DATA 0x1C1C1C1C
    #define DDRSS_CTL_42_DATA 0x0400091C
    #define DDRSS_CTL_43_DATA 0x1C1C1C1C
    #define DDRSS_CTL_44_DATA 0x05050404
    #define DDRSS_CTL_45_DATA 0x00001F04
    #define DDRSS_CTL_46_DATA 0x05020017
    #define DDRSS_CTL_47_DATA 0x05001D09
    #define DDRSS_CTL_48_DATA 0x001F0405
    #define DDRSS_CTL_49_DATA 0x05020017
    #define DDRSS_CTL_50_DATA 0x05001D09
    #define DDRSS_CTL_51_DATA 0x001F0405
    #define DDRSS_CTL_52_DATA 0x05020017
    #define DDRSS_CTL_53_DATA 0x06001D09
    #define DDRSS_CTL_54_DATA 0x00180806
    #define DDRSS_CTL_55_DATA 0x0400AB63
    #define DDRSS_CTL_56_DATA 0x06060009
    #define DDRSS_CTL_57_DATA 0x00001808
    #define DDRSS_CTL_58_DATA 0x0400AB63
    #define DDRSS_CTL_59_DATA 0x06060009
    #define DDRSS_CTL_60_DATA 0x00001808
    #define DDRSS_CTL_61_DATA 0x0400AB63
    #define DDRSS_CTL_62_DATA 0x03000009
    #define DDRSS_CTL_63_DATA 0x0B0A0002
    #define DDRSS_CTL_64_DATA 0x0B0A0B0A
    #define DDRSS_CTL_65_DATA 0x01010000
    #define DDRSS_CTL_66_DATA 0x03151515
    #define DDRSS_CTL_67_DATA 0x09090909
    #define DDRSS_CTL_68_DATA 0x00000909
    #define DDRSS_CTL_69_DATA 0x00000101
    #define DDRSS_CTL_70_DATA 0x00000000
    #define DDRSS_CTL_71_DATA 0x01000000
    #define DDRSS_CTL_72_DATA 0x00DB0803
    #define DDRSS_CTL_73_DATA 0x0000130B
    #define DDRSS_CTL_74_DATA 0x000000DB
    #define DDRSS_CTL_75_DATA 0x0000130B
    #define DDRSS_CTL_76_DATA 0x000000DB
    #define DDRSS_CTL_77_DATA 0x0000130B
    #define DDRSS_CTL_78_DATA 0x00000005
    #define DDRSS_CTL_79_DATA 0x00000000
    #define DDRSS_CTL_80_DATA 0x00000000
    #define DDRSS_CTL_81_DATA 0x00000000
    #define DDRSS_CTL_82_DATA 0x00000000
    #define DDRSS_CTL_83_DATA 0x00000000
    #define DDRSS_CTL_84_DATA 0x00000000
    #define DDRSS_CTL_85_DATA 0x00000000
    #define DDRSS_CTL_86_DATA 0x00000000
    #define DDRSS_CTL_87_DATA 0x00080008
    #define DDRSS_CTL_88_DATA 0x00000008
    #define DDRSS_CTL_89_DATA 0x00000000
    #define DDRSS_CTL_90_DATA 0x00000000
    #define DDRSS_CTL_91_DATA 0x00000000
    #define DDRSS_CTL_92_DATA 0x00000000
    #define DDRSS_CTL_93_DATA 0x00000000
    #define DDRSS_CTL_94_DATA 0x00010001
    #define DDRSS_CTL_95_DATA 0x00025501
    #define DDRSS_CTL_96_DATA 0x025500E1
    #define DDRSS_CTL_97_DATA 0x025500E1
    #define DDRSS_CTL_98_DATA 0x00E100E1
    #define DDRSS_CTL_99_DATA 0x00E100E1
    #define DDRSS_CTL_100_DATA 0x00000000
    #define DDRSS_CTL_101_DATA 0x00000000
    #define DDRSS_CTL_102_DATA 0x00000000
    #define DDRSS_CTL_103_DATA 0x00000000
    #define DDRSS_CTL_104_DATA 0x00000000
    #define DDRSS_CTL_105_DATA 0x00000000
    #define DDRSS_CTL_106_DATA 0x03010000
    #define DDRSS_CTL_107_DATA 0x00010000
    #define DDRSS_CTL_108_DATA 0x00000000
    #define DDRSS_CTL_109_DATA 0x01000000
    #define DDRSS_CTL_110_DATA 0x80104002
    #define DDRSS_CTL_111_DATA 0x00040003
    #define DDRSS_CTL_112_DATA 0x00040005
    #define DDRSS_CTL_113_DATA 0x00030000
    #define DDRSS_CTL_114_DATA 0x00050004
    #define DDRSS_CTL_115_DATA 0x00000004
    #define DDRSS_CTL_116_DATA 0x00040003
    #define DDRSS_CTL_117_DATA 0x00040005
    #define DDRSS_CTL_118_DATA 0x00000000
    #define DDRSS_CTL_119_DATA 0x0004C2C0
    #define DDRSS_CTL_120_DATA 0x0004C2C0
    #define DDRSS_CTL_121_DATA 0x0004C2C0
    #define DDRSS_CTL_122_DATA 0x0004C2C0
    #define DDRSS_CTL_123_DATA 0x0004C2C0
    #define DDRSS_CTL_124_DATA 0x00000000
    #define DDRSS_CTL_125_DATA 0x0000854D
    #define DDRSS_CTL_126_DATA 0x0004C2C0
    #define DDRSS_CTL_127_DATA 0x0004C2C0
    #define DDRSS_CTL_128_DATA 0x0004C2C0
    #define DDRSS_CTL_129_DATA 0x0004C2C0
    #define DDRSS_CTL_130_DATA 0x0004C2C0
    #define DDRSS_CTL_131_DATA 0x00000000
    #define DDRSS_CTL_132_DATA 0x0000854D
    #define DDRSS_CTL_133_DATA 0x0004C2C0
    #define DDRSS_CTL_134_DATA 0x0004C2C0
    #define DDRSS_CTL_135_DATA 0x0004C2C0
    #define DDRSS_CTL_136_DATA 0x0004C2C0
    #define DDRSS_CTL_137_DATA 0x0004C2C0
    #define DDRSS_CTL_138_DATA 0x00000000
    #define DDRSS_CTL_139_DATA 0x0000854D
    #define DDRSS_CTL_140_DATA 0x00000000
    #define DDRSS_CTL_141_DATA 0x00000000
    #define DDRSS_CTL_142_DATA 0x00000000
    #define DDRSS_CTL_143_DATA 0x00000000
    #define DDRSS_CTL_144_DATA 0x00000000
    #define DDRSS_CTL_145_DATA 0x00000000
    #define DDRSS_CTL_146_DATA 0x00000000
    #define DDRSS_CTL_147_DATA 0x00000000
    #define DDRSS_CTL_148_DATA 0x00000000
    #define DDRSS_CTL_149_DATA 0x00000000
    #define DDRSS_CTL_150_DATA 0x00000000
    #define DDRSS_CTL_151_DATA 0x00000000
    #define DDRSS_CTL_152_DATA 0x00000000
    #define DDRSS_CTL_153_DATA 0x00000000
    #define DDRSS_CTL_154_DATA 0x00000000
    #define DDRSS_CTL_155_DATA 0x00000000
    #define DDRSS_CTL_156_DATA 0x070B0000
    #define DDRSS_CTL_157_DATA 0x070B070B
    #define DDRSS_CTL_158_DATA 0x08000000
    #define DDRSS_CTL_159_DATA 0x00000808
    #define DDRSS_CTL_160_DATA 0x000E0000
    #define DDRSS_CTL_161_DATA 0x00080808
    #define DDRSS_CTL_162_DATA 0x0E000000
    #define DDRSS_CTL_163_DATA 0x08080800
    #define DDRSS_CTL_164_DATA 0x00000000
    #define DDRSS_CTL_165_DATA 0x0000080E
    #define DDRSS_CTL_166_DATA 0x00040003
    #define DDRSS_CTL_167_DATA 0x00000007
    #define DDRSS_CTL_168_DATA 0x00000000
    #define DDRSS_CTL_169_DATA 0x00000000
    #define DDRSS_CTL_170_DATA 0x00000000
    #define DDRSS_CTL_171_DATA 0x00000000
    #define DDRSS_CTL_172_DATA 0x00000000
    #define DDRSS_CTL_173_DATA 0x00000000
    #define DDRSS_CTL_174_DATA 0x01000000
    #define DDRSS_CTL_175_DATA 0x00000000
    #define DDRSS_CTL_176_DATA 0x00001500
    #define DDRSS_CTL_177_DATA 0x0000100E
    #define DDRSS_CTL_178_DATA 0x00000000
    #define DDRSS_CTL_179_DATA 0x00000000
    #define DDRSS_CTL_180_DATA 0x00000001
    #define DDRSS_CTL_181_DATA 0x00000002
    #define DDRSS_CTL_182_DATA 0x00000C00
    #define DDRSS_CTL_183_DATA 0x00001000
    #define DDRSS_CTL_184_DATA 0x00000C00
    #define DDRSS_CTL_185_DATA 0x00001000
    #define DDRSS_CTL_186_DATA 0x00000C00
    #define DDRSS_CTL_187_DATA 0x00001000
    #define DDRSS_CTL_188_DATA 0x00000000
    #define DDRSS_CTL_189_DATA 0x00000000
    #define DDRSS_CTL_190_DATA 0x00000000
    #define DDRSS_CTL_191_DATA 0x00000000
    #define DDRSS_CTL_192_DATA 0x00000000
    #define DDRSS_CTL_193_DATA 0x00000000
    #define DDRSS_CTL_194_DATA 0x00000000
    #define DDRSS_CTL_195_DATA 0x00000000
    #define DDRSS_CTL_196_DATA 0x00000000
    #define DDRSS_CTL_197_DATA 0x00000000
    #define DDRSS_CTL_198_DATA 0x00000000
    #define DDRSS_CTL_199_DATA 0x00000000
    #define DDRSS_CTL_200_DATA 0x00000000
    #define DDRSS_CTL_201_DATA 0x00000000
    #define DDRSS_CTL_202_DATA 0x00000000
    #define DDRSS_CTL_203_DATA 0x00000000
    #define DDRSS_CTL_204_DATA 0x00022400
    #define DDRSS_CTL_205_DATA 0x00000301
    #define DDRSS_CTL_206_DATA 0x00000000
    #define DDRSS_CTL_207_DATA 0x00000224
    #define DDRSS_CTL_208_DATA 0x00000301
    #define DDRSS_CTL_209_DATA 0x00000000
    #define DDRSS_CTL_210_DATA 0x00000224
    #define DDRSS_CTL_211_DATA 0x00000301
    #define DDRSS_CTL_212_DATA 0x00000000
    #define DDRSS_CTL_213_DATA 0x00000224
    #define DDRSS_CTL_214_DATA 0x00000301
    #define DDRSS_CTL_215_DATA 0x00000000
    #define DDRSS_CTL_216_DATA 0x00000224
    #define DDRSS_CTL_217_DATA 0x00000301
    #define DDRSS_CTL_218_DATA 0x00000000
    #define DDRSS_CTL_219_DATA 0x00000224
    #define DDRSS_CTL_220_DATA 0x00000301
    #define DDRSS_CTL_221_DATA 0x00000000
    #define DDRSS_CTL_222_DATA 0x00000000
    #define DDRSS_CTL_223_DATA 0x00000000
    #define DDRSS_CTL_224_DATA 0x00000000
    #define DDRSS_CTL_225_DATA 0x00000000
    #define DDRSS_CTL_226_DATA 0x00000000
    #define DDRSS_CTL_227_DATA 0x00000000
    #define DDRSS_CTL_228_DATA 0x00000000
    #define DDRSS_CTL_229_DATA 0x00000000
    #define DDRSS_CTL_230_DATA 0x00000000
    #define DDRSS_CTL_231_DATA 0x00000000
    #define DDRSS_CTL_232_DATA 0x00000000
    #define DDRSS_CTL_233_DATA 0x00000000
    #define DDRSS_CTL_234_DATA 0x00000000
    #define DDRSS_CTL_235_DATA 0x00000000
    #define DDRSS_CTL_236_DATA 0x00001401
    #define DDRSS_CTL_237_DATA 0x00001401
    #define DDRSS_CTL_238_DATA 0x00001401
    #define DDRSS_CTL_239_DATA 0x00001401
    #define DDRSS_CTL_240_DATA 0x00001401
    #define DDRSS_CTL_241_DATA 0x00001401
    #define DDRSS_CTL_242_DATA 0x00000093
    #define DDRSS_CTL_243_DATA 0x00000093
    #define DDRSS_CTL_244_DATA 0x00000093
    #define DDRSS_CTL_245_DATA 0x00000093
    #define DDRSS_CTL_246_DATA 0x00000093
    #define DDRSS_CTL_247_DATA 0x00000093
    #define DDRSS_CTL_248_DATA 0x00000000
    #define DDRSS_CTL_249_DATA 0x00000000
    #define DDRSS_CTL_250_DATA 0x00000000
    #define DDRSS_CTL_251_DATA 0x00000000
    #define DDRSS_CTL_252_DATA 0x00000000
    #define DDRSS_CTL_253_DATA 0x00000000
    #define DDRSS_CTL_254_DATA 0x00000000
    #define DDRSS_CTL_255_DATA 0x00000000
    #define DDRSS_CTL_256_DATA 0x00000000
    #define DDRSS_CTL_257_DATA 0x00000000
    #define DDRSS_CTL_258_DATA 0x00000000
    #define DDRSS_CTL_259_DATA 0x00000000
    #define DDRSS_CTL_260_DATA 0x00000000
    #define DDRSS_CTL_261_DATA 0x00000000
    #define DDRSS_CTL_262_DATA 0x00000000
    #define DDRSS_CTL_263_DATA 0x00000000
    #define DDRSS_CTL_264_DATA 0x00000000
    #define DDRSS_CTL_265_DATA 0x00000000
    #define DDRSS_CTL_266_DATA 0x00000000
    #define DDRSS_CTL_267_DATA 0x00000000
    #define DDRSS_CTL_268_DATA 0x00000000
    #define DDRSS_CTL_269_DATA 0x00000000
    #define DDRSS_CTL_270_DATA 0x00000000
    #define DDRSS_CTL_271_DATA 0x00000000
    #define DDRSS_CTL_272_DATA 0x00000000
    #define DDRSS_CTL_273_DATA 0x00000000
    #define DDRSS_CTL_274_DATA 0x00000000
    #define DDRSS_CTL_275_DATA 0x00000000
    #define DDRSS_CTL_276_DATA 0x00000000
    #define DDRSS_CTL_277_DATA 0x00010000
    #define DDRSS_CTL_278_DATA 0x00000000
    #define DDRSS_CTL_279_DATA 0x00000000
    #define DDRSS_CTL_280_DATA 0x00000000
    #define DDRSS_CTL_281_DATA 0x00000101
    #define DDRSS_CTL_282_DATA 0x00000000
    #define DDRSS_CTL_283_DATA 0x00000000
    #define DDRSS_CTL_284_DATA 0x00000000
    #define DDRSS_CTL_285_DATA 0x00000000
    #define DDRSS_CTL_286_DATA 0x00000000
    #define DDRSS_CTL_287_DATA 0x00000000
    #define DDRSS_CTL_288_DATA 0x00000000
    #define DDRSS_CTL_289_DATA 0x00000000
    #define DDRSS_CTL_290_DATA 0x0C181511
    #define DDRSS_CTL_291_DATA 0x00000304
    #define DDRSS_CTL_292_DATA 0x00000000
    #define DDRSS_CTL_293_DATA 0x00000000
    #define DDRSS_CTL_294_DATA 0x00000000
    #define DDRSS_CTL_295_DATA 0x00000000
    #define DDRSS_CTL_296_DATA 0x00000000
    #define DDRSS_CTL_297_DATA 0x00000000
    #define DDRSS_CTL_298_DATA 0x00000000
    #define DDRSS_CTL_299_DATA 0x00000000
    #define DDRSS_CTL_300_DATA 0x00000000
    #define DDRSS_CTL_301_DATA 0x00000000
    #define DDRSS_CTL_302_DATA 0x00000000
    #define DDRSS_CTL_303_DATA 0x00000000
    #define DDRSS_CTL_304_DATA 0x00000000
    #define DDRSS_CTL_305_DATA 0x00040000
    #define DDRSS_CTL_306_DATA 0x00800200
    #define DDRSS_CTL_307_DATA 0x00000000
    #define DDRSS_CTL_308_DATA 0x02000400
    #define DDRSS_CTL_309_DATA 0x00000080
    #define DDRSS_CTL_310_DATA 0x00040000
    #define DDRSS_CTL_311_DATA 0x00800200
    #define DDRSS_CTL_312_DATA 0x00000000
    #define DDRSS_CTL_313_DATA 0x00000000
    #define DDRSS_CTL_314_DATA 0x00000000
    #define DDRSS_CTL_315_DATA 0x00000100
    #define DDRSS_CTL_316_DATA 0x01010000
    #define DDRSS_CTL_317_DATA 0x00000000
    #define DDRSS_CTL_318_DATA 0x3FFF0000
    #define DDRSS_CTL_319_DATA 0x000FFF00
    #define DDRSS_CTL_320_DATA 0xFFFFFFFF
    #define DDRSS_CTL_321_DATA 0x00FFFF00
    #define DDRSS_CTL_322_DATA 0x0A000000
    #define DDRSS_CTL_323_DATA 0x0001FFFF
    #define DDRSS_CTL_324_DATA 0x01010101
    #define DDRSS_CTL_325_DATA 0x01010101
    #define DDRSS_CTL_326_DATA 0x00000118
    #define DDRSS_CTL_327_DATA 0x00000C01
    #define DDRSS_CTL_328_DATA 0x00000000
    #define DDRSS_CTL_329_DATA 0x00000000
    #define DDRSS_CTL_330_DATA 0x00000000
    #define DDRSS_CTL_331_DATA 0x01000000
    #define DDRSS_CTL_332_DATA 0x00000100
    #define DDRSS_CTL_333_DATA 0x00010000
    #define DDRSS_CTL_334_DATA 0x00000000
    #define DDRSS_CTL_335_DATA 0x00000000
    #define DDRSS_CTL_336_DATA 0x00000000
    #define DDRSS_CTL_337_DATA 0x00000000
    #define DDRSS_CTL_338_DATA 0x00000000
    #define DDRSS_CTL_339_DATA 0x00000000
    #define DDRSS_CTL_340_DATA 0x00000000
    #define DDRSS_CTL_341_DATA 0x00000000
    #define DDRSS_CTL_342_DATA 0x00000000
    #define DDRSS_CTL_343_DATA 0x00000000
    #define DDRSS_CTL_344_DATA 0x00000000
    #define DDRSS_CTL_345_DATA 0x00000000
    #define DDRSS_CTL_346_DATA 0x00000000
    #define DDRSS_CTL_347_DATA 0x00000000
    #define DDRSS_CTL_348_DATA 0x00000000
    #define DDRSS_CTL_349_DATA 0x00000000
    #define DDRSS_CTL_350_DATA 0x00000000
    #define DDRSS_CTL_351_DATA 0x00000000
    #define DDRSS_CTL_352_DATA 0x00000000
    #define DDRSS_CTL_353_DATA 0x00000000
    #define DDRSS_CTL_354_DATA 0x00000000
    #define DDRSS_CTL_355_DATA 0x00000000
    #define DDRSS_CTL_356_DATA 0x00000000
    #define DDRSS_CTL_357_DATA 0x00000000
    #define DDRSS_CTL_358_DATA 0x00000000
    #define DDRSS_CTL_359_DATA 0x00000000
    #define DDRSS_CTL_360_DATA 0x00000000
    #define DDRSS_CTL_361_DATA 0x00000000
    #define DDRSS_CTL_362_DATA 0x00000000
    #define DDRSS_CTL_363_DATA 0x00000000
    #define DDRSS_CTL_364_DATA 0x00000000
    #define DDRSS_CTL_365_DATA 0x00000000
    #define DDRSS_CTL_366_DATA 0x00000000
    #define DDRSS_CTL_367_DATA 0x00000000
    #define DDRSS_CTL_368_DATA 0x00000000
    #define DDRSS_CTL_369_DATA 0x00000000
    #define DDRSS_CTL_370_DATA 0x0C000000
    #define DDRSS_CTL_371_DATA 0x060C0606
    #define DDRSS_CTL_372_DATA 0x06060C06
    #define DDRSS_CTL_373_DATA 0x00010101
    #define DDRSS_CTL_374_DATA 0x02000000
    #define DDRSS_CTL_375_DATA 0x05020101
    #define DDRSS_CTL_376_DATA 0x00000505
    #define DDRSS_CTL_377_DATA 0x02020200
    #define DDRSS_CTL_378_DATA 0x02020202
    #define DDRSS_CTL_379_DATA 0x02020202
    #define DDRSS_CTL_380_DATA 0x02020202
    #define DDRSS_CTL_381_DATA 0x00000000
    #define DDRSS_CTL_382_DATA 0x00000000
    #define DDRSS_CTL_383_DATA 0x04000100
    #define DDRSS_CTL_384_DATA 0x1D000004
    #define DDRSS_CTL_385_DATA 0x00002616
    #define DDRSS_CTL_386_DATA 0x00000200
    #define DDRSS_CTL_387_DATA 0x00000200
    #define DDRSS_CTL_388_DATA 0x00000200
    #define DDRSS_CTL_389_DATA 0x00000200
    #define DDRSS_CTL_390_DATA 0x0000AB63
    #define DDRSS_CTL_391_DATA 0x00017CDC
    #define DDRSS_CTL_392_DATA 0x0C0D0302
    #define DDRSS_CTL_393_DATA 0x001D090A
    #define DDRSS_CTL_394_DATA 0x00002616
    #define DDRSS_CTL_395_DATA 0x00000200
    #define DDRSS_CTL_396_DATA 0x00000200
    #define DDRSS_CTL_397_DATA 0x00000200
    #define DDRSS_CTL_398_DATA 0x00000200
    #define DDRSS_CTL_399_DATA 0x0000AB63
    #define DDRSS_CTL_400_DATA 0x00017CDC
    #define DDRSS_CTL_401_DATA 0x0C0D0302
    #define DDRSS_CTL_402_DATA 0x001D090A
    #define DDRSS_CTL_403_DATA 0x00002616
    #define DDRSS_CTL_404_DATA 0x00000200
    #define DDRSS_CTL_405_DATA 0x00000200
    #define DDRSS_CTL_406_DATA 0x00000200
    #define DDRSS_CTL_407_DATA 0x00000200
    #define DDRSS_CTL_408_DATA 0x0000AB63
    #define DDRSS_CTL_409_DATA 0x00017CDC
    #define DDRSS_CTL_410_DATA 0x0C0D0302
    #define DDRSS_CTL_411_DATA 0x0000090A
    #define DDRSS_CTL_412_DATA 0x00000000
    #define DDRSS_CTL_413_DATA 0x0302000A
    #define DDRSS_CTL_414_DATA 0x01000500
    #define DDRSS_CTL_415_DATA 0x01010001
    #define DDRSS_CTL_416_DATA 0x00010001
    #define DDRSS_CTL_417_DATA 0x01010001
    #define DDRSS_CTL_418_DATA 0x02010000
    #define DDRSS_CTL_419_DATA 0x00000200
    #define DDRSS_CTL_420_DATA 0x02000201
    #define DDRSS_CTL_421_DATA 0x00000000
    #define DDRSS_CTL_422_DATA 0x00202020
    #define DDRSS_PI_0_DATA 0x00000A00
    #define DDRSS_PI_1_DATA 0x00000000
    #define DDRSS_PI_2_DATA 0x00000000
    #define DDRSS_PI_3_DATA 0x01000000
    #define DDRSS_PI_4_DATA 0x00000001
    #define DDRSS_PI_5_DATA 0x00010064
    #define DDRSS_PI_6_DATA 0x00000000
    #define DDRSS_PI_7_DATA 0x00000000
    #define DDRSS_PI_8_DATA 0x00000000
    #define DDRSS_PI_9_DATA 0x00000000
    #define DDRSS_PI_10_DATA 0x00000000
    #define DDRSS_PI_11_DATA 0x00000000
    #define DDRSS_PI_12_DATA 0x00000000
    #define DDRSS_PI_13_DATA 0x00010001
    #define DDRSS_PI_14_DATA 0x00000000
    #define DDRSS_PI_15_DATA 0x00010001
    #define DDRSS_PI_16_DATA 0x00000005
    #define DDRSS_PI_17_DATA 0x00000000
    #define DDRSS_PI_18_DATA 0x00000000
    #define DDRSS_PI_19_DATA 0x00000000
    #define DDRSS_PI_20_DATA 0x00000000
    #define DDRSS_PI_21_DATA 0x00000000
    #define DDRSS_PI_22_DATA 0x00000000
    #define DDRSS_PI_23_DATA 0x00000000
    #define DDRSS_PI_24_DATA 0x280D0001
    #define DDRSS_PI_25_DATA 0x00000000
    #define DDRSS_PI_26_DATA 0x00010000
    #define DDRSS_PI_27_DATA 0x00003200
    #define DDRSS_PI_28_DATA 0x00000000
    #define DDRSS_PI_29_DATA 0x00000000
    #define DDRSS_PI_30_DATA 0x00060602
    #define DDRSS_PI_31_DATA 0x00000000
    #define DDRSS_PI_32_DATA 0x00000000
    #define DDRSS_PI_33_DATA 0x00000000
    #define DDRSS_PI_34_DATA 0x00000001
    #define DDRSS_PI_35_DATA 0x00000055
    #define DDRSS_PI_36_DATA 0x000000AA
    #define DDRSS_PI_37_DATA 0x000000AD
    #define DDRSS_PI_38_DATA 0x00000052
    #define DDRSS_PI_39_DATA 0x0000006A
    #define DDRSS_PI_40_DATA 0x00000095
    #define DDRSS_PI_41_DATA 0x00000095
    #define DDRSS_PI_42_DATA 0x000000AD
    #define DDRSS_PI_43_DATA 0x00000000
    #define DDRSS_PI_44_DATA 0x00000000
    #define DDRSS_PI_45_DATA 0x00010100
    #define DDRSS_PI_46_DATA 0x00000014
    #define DDRSS_PI_47_DATA 0x000007D0
    #define DDRSS_PI_48_DATA 0x00000300
    #define DDRSS_PI_49_DATA 0x00000000
    #define DDRSS_PI_50_DATA 0x00000000
    #define DDRSS_PI_51_DATA 0x01000000
    #define DDRSS_PI_52_DATA 0x00010101
    #define DDRSS_PI_53_DATA 0x01000000
    #define DDRSS_PI_54_DATA 0x00000000
    #define DDRSS_PI_55_DATA 0x00010000
    #define DDRSS_PI_56_DATA 0x00000000
    #define DDRSS_PI_57_DATA 0x00000000
    #define DDRSS_PI_58_DATA 0x00000000
    #define DDRSS_PI_59_DATA 0x00000000
    #define DDRSS_PI_60_DATA 0x00001400
    #define DDRSS_PI_61_DATA 0x00000000
    #define DDRSS_PI_62_DATA 0x01000000
    #define DDRSS_PI_63_DATA 0x00000404
    #define DDRSS_PI_64_DATA 0x00000001
    #define DDRSS_PI_65_DATA 0x0001010E
    #define DDRSS_PI_66_DATA 0x02040100
    #define DDRSS_PI_67_DATA 0x00010000
    #define DDRSS_PI_68_DATA 0x00000034
    #define DDRSS_PI_69_DATA 0x00000000
    #define DDRSS_PI_70_DATA 0x00000000
    #define DDRSS_PI_71_DATA 0x00000000
    #define DDRSS_PI_72_DATA 0x00000000
    #define DDRSS_PI_73_DATA 0x00000000
    #define DDRSS_PI_74_DATA 0x00000000
    #define DDRSS_PI_75_DATA 0x00000005
    #define DDRSS_PI_76_DATA 0x01000000
    #define DDRSS_PI_77_DATA 0x04000100
    #define DDRSS_PI_78_DATA 0x00020000
    #define DDRSS_PI_79_DATA 0x00010002
    #define DDRSS_PI_80_DATA 0x00000001
    #define DDRSS_PI_81_DATA 0x00020001
    #define DDRSS_PI_82_DATA 0x00020002
    #define DDRSS_PI_83_DATA 0x00000000
    #define DDRSS_PI_84_DATA 0x00000000
    #define DDRSS_PI_85_DATA 0x00000000
    #define DDRSS_PI_86_DATA 0x00000000
    #define DDRSS_PI_87_DATA 0x00000000
    #define DDRSS_PI_88_DATA 0x00000000
    #define DDRSS_PI_89_DATA 0x00000000
    #define DDRSS_PI_90_DATA 0x00000000
    #define DDRSS_PI_91_DATA 0x00000300
    #define DDRSS_PI_92_DATA 0x0A090B0C
    #define DDRSS_PI_93_DATA 0x04060708
    #define DDRSS_PI_94_DATA 0x01000005
    #define DDRSS_PI_95_DATA 0x00000800
    #define DDRSS_PI_96_DATA 0x00000000
    #define DDRSS_PI_97_DATA 0x00010008
    #define DDRSS_PI_98_DATA 0x00000000
    #define DDRSS_PI_99_DATA 0x0000AA00
    #define DDRSS_PI_100_DATA 0x00000000
    #define DDRSS_PI_101_DATA 0x00010000
    #define DDRSS_PI_102_DATA 0x00000000
    #define DDRSS_PI_103_DATA 0x00000000
    #define DDRSS_PI_104_DATA 0x00000000
    #define DDRSS_PI_105_DATA 0x00000000
    #define DDRSS_PI_106_DATA 0x00000000
    #define DDRSS_PI_107_DATA 0x00000000
    #define DDRSS_PI_108_DATA 0x00000000
    #define DDRSS_PI_109_DATA 0x00000000
    #define DDRSS_PI_110_DATA 0x00000000
    #define DDRSS_PI_111_DATA 0x00000000
    #define DDRSS_PI_112_DATA 0x00000000
    #define DDRSS_PI_113_DATA 0x00000000
    #define DDRSS_PI_114_DATA 0x00000000
    #define DDRSS_PI_115_DATA 0x00000000
    #define DDRSS_PI_116_DATA 0x00000000
    #define DDRSS_PI_117_DATA 0x00000000
    #define DDRSS_PI_118_DATA 0x00000000
    #define DDRSS_PI_119_DATA 0x00000000
    #define DDRSS_PI_120_DATA 0x00000000
    #define DDRSS_PI_121_DATA 0x00000000
    #define DDRSS_PI_122_DATA 0x00000000
    #define DDRSS_PI_123_DATA 0x00000000
    #define DDRSS_PI_124_DATA 0x00000008
    #define DDRSS_PI_125_DATA 0x00000000
    #define DDRSS_PI_126_DATA 0x00000000
    #define DDRSS_PI_127_DATA 0x00000000
    #define DDRSS_PI_128_DATA 0x00000000
    #define DDRSS_PI_129_DATA 0x00000000
    #define DDRSS_PI_130_DATA 0x00000000
    #define DDRSS_PI_131_DATA 0x00000000
    #define DDRSS_PI_132_DATA 0x00000000
    #define DDRSS_PI_133_DATA 0x00010100
    #define DDRSS_PI_134_DATA 0x00000000
    #define DDRSS_PI_135_DATA 0x00000000
    #define DDRSS_PI_136_DATA 0x0001E848
    #define DDRSS_PI_137_DATA 0x0004C4B4
    #define DDRSS_PI_138_DATA 0x00000100
    #define DDRSS_PI_139_DATA 0x00000000
    #define DDRSS_PI_140_DATA 0x00000000
    #define DDRSS_PI_141_DATA 0x00000000
    #define DDRSS_PI_142_DATA 0x00000000
    #define DDRSS_PI_143_DATA 0x00000000
    #define DDRSS_PI_144_DATA 0x01000000
    #define DDRSS_PI_145_DATA 0x00010003
    #define DDRSS_PI_146_DATA 0x02000101
    #define DDRSS_PI_147_DATA 0x01030001
    #define DDRSS_PI_148_DATA 0x00010400
    #define DDRSS_PI_149_DATA 0x06000105
    #define DDRSS_PI_150_DATA 0x01070001
    #define DDRSS_PI_151_DATA 0x00000000
    #define DDRSS_PI_152_DATA 0x00000000
    #define DDRSS_PI_153_DATA 0x00000000
    #define DDRSS_PI_154_DATA 0x00010000
    #define DDRSS_PI_155_DATA 0x00000000
    #define DDRSS_PI_156_DATA 0x00000000
    #define DDRSS_PI_157_DATA 0x00000000
    #define DDRSS_PI_158_DATA 0x00000000
    #define DDRSS_PI_159_DATA 0x00010000
    #define DDRSS_PI_160_DATA 0x00000004
    #define DDRSS_PI_161_DATA 0x00000000
    #define DDRSS_PI_162_DATA 0x00000000
    #define DDRSS_PI_163_DATA 0x00000000
    #define DDRSS_PI_164_DATA 0x00005E00
    #define DDRSS_PI_165_DATA 0x005E005E
    #define DDRSS_PI_166_DATA 0x000F0F0F
    #define DDRSS_PI_167_DATA 0x00000039
    #define DDRSS_PI_168_DATA 0x00000039
    #define DDRSS_PI_169_DATA 0x00040039
    #define DDRSS_PI_170_DATA 0x04000400
    #define DDRSS_PI_171_DATA 0xC8040009
    #define DDRSS_PI_172_DATA 0x0400091C
    #define DDRSS_PI_173_DATA 0x00091CC8
    #define DDRSS_PI_174_DATA 0x001CC804
    #define DDRSS_PI_175_DATA 0x000000DB
    #define DDRSS_PI_176_DATA 0x0000130B
    #define DDRSS_PI_177_DATA 0x000000DB
    #define DDRSS_PI_178_DATA 0x0000130B
    #define DDRSS_PI_179_DATA 0x000000DB
    #define DDRSS_PI_180_DATA 0x0400130B
    #define DDRSS_PI_181_DATA 0x01010404
    #define DDRSS_PI_182_DATA 0x00001801
    #define DDRSS_PI_183_DATA 0x00180018
    #define DDRSS_PI_184_DATA 0x010C010C
    #define DDRSS_PI_185_DATA 0x0000010C
    #define DDRSS_PI_186_DATA 0x00000000
    #define DDRSS_PI_187_DATA 0x05000000
    #define DDRSS_PI_188_DATA 0x01010505
    #define DDRSS_PI_189_DATA 0x01010101
    #define DDRSS_PI_190_DATA 0x00181818
    #define DDRSS_PI_191_DATA 0x00000000
    #define DDRSS_PI_192_DATA 0x00000000
    #define DDRSS_PI_193_DATA 0x0D000000
    #define DDRSS_PI_194_DATA 0x0A0A0D0D
    #define DDRSS_PI_195_DATA 0x0303030A
    #define DDRSS_PI_196_DATA 0x00000000
    #define DDRSS_PI_197_DATA 0x00000000
    #define DDRSS_PI_198_DATA 0x00000000
    #define DDRSS_PI_199_DATA 0x00000000
    #define DDRSS_PI_200_DATA 0x00000000
    #define DDRSS_PI_201_DATA 0x00000000
    #define DDRSS_PI_202_DATA 0x00000000
    #define DDRSS_PI_203_DATA 0x00000000
    #define DDRSS_PI_204_DATA 0x00000000
    #define DDRSS_PI_205_DATA 0x00000000
    #define DDRSS_PI_206_DATA 0x00000000
    #define DDRSS_PI_207_DATA 0x00000000
    #define DDRSS_PI_208_DATA 0x00000000
    #define DDRSS_PI_209_DATA 0x0A080000
    #define DDRSS_PI_210_DATA 0x0A08000D
    #define DDRSS_PI_211_DATA 0x0A08000D
    #define DDRSS_PI_212_DATA 0x0000000D
    #define DDRSS_PI_213_DATA 0x00000000
    #define DDRSS_PI_214_DATA 0x00000000
    #define DDRSS_PI_215_DATA 0x00000000
    #define DDRSS_PI_216_DATA 0x00000000
    #define DDRSS_PI_217_DATA 0x15000000
    #define DDRSS_PI_218_DATA 0x0015009D
    #define DDRSS_PI_219_DATA 0x0015009D
    #define DDRSS_PI_220_DATA 0x0101009D
    #define DDRSS_PI_221_DATA 0x00001B01
    #define DDRSS_PI_222_DATA 0x1F0F0053
    #define DDRSS_PI_223_DATA 0x05000001
    #define DDRSS_PI_224_DATA 0x001B0A0D
    #define DDRSS_PI_225_DATA 0x1F0F0053
    #define DDRSS_PI_226_DATA 0x05000001
    #define DDRSS_PI_227_DATA 0x001B0A0D
    #define DDRSS_PI_228_DATA 0x1F0F0053
    #define DDRSS_PI_229_DATA 0x05000001
    #define DDRSS_PI_230_DATA 0x00010A0D
    #define DDRSS_PI_231_DATA 0x0A090600
    #define DDRSS_PI_232_DATA 0x000B0605
    #define DDRSS_PI_233_DATA 0x00009A40
    #define DDRSS_PI_234_DATA 0x00000017
    #define DDRSS_PI_235_DATA 0x180A0800
    #define DDRSS_PI_236_DATA 0x09061C1C
    #define DDRSS_PI_237_DATA 0x0B06050A
    #define DDRSS_PI_238_DATA 0x00009A40
    #define DDRSS_PI_239_DATA 0x00000017
    #define DDRSS_PI_240_DATA 0x180A0800
    #define DDRSS_PI_241_DATA 0x09061C1C
    #define DDRSS_PI_242_DATA 0x0B06050A
    #define DDRSS_PI_243_DATA 0x00009A40
    #define DDRSS_PI_244_DATA 0x00000017
    #define DDRSS_PI_245_DATA 0x180A0800
    #define DDRSS_PI_246_DATA 0x00001C1C
    #define DDRSS_PI_247_DATA 0x00002616
    #define DDRSS_PI_248_DATA 0x00017CDC
    #define DDRSS_PI_249_DATA 0x00002616
    #define DDRSS_PI_250_DATA 0x00017CDC
    #define DDRSS_PI_251_DATA 0x00002616
    #define DDRSS_PI_252_DATA 0x00017CDC
    #define DDRSS_PI_253_DATA 0x02550255
    #define DDRSS_PI_254_DATA 0x03030255
    #define DDRSS_PI_255_DATA 0x00025503
    #define DDRSS_PI_256_DATA 0x02550255
    #define DDRSS_PI_257_DATA 0x0B070B07
    #define DDRSS_PI_258_DATA 0x00000B07
    #define DDRSS_PI_259_DATA 0x0006B1F6
    #define DDRSS_PI_260_DATA 0x00000000
    #define DDRSS_PI_261_DATA 0x00000000
    #define DDRSS_PI_262_DATA 0x00000000
    #define DDRSS_PI_263_DATA 0x000000E1
    #define DDRSS_PI_264_DATA 0x0006B1F6
    #define DDRSS_PI_265_DATA 0x00000000
    #define DDRSS_PI_266_DATA 0x00000000
    #define DDRSS_PI_267_DATA 0x00000000
    #define DDRSS_PI_268_DATA 0x000000E1
    #define DDRSS_PI_269_DATA 0x0006B1F6
    #define DDRSS_PI_270_DATA 0x00000000
    #define DDRSS_PI_271_DATA 0x00000000
    #define DDRSS_PI_272_DATA 0x00000000
    #define DDRSS_PI_273_DATA 0x020000E1
    #define DDRSS_PI_274_DATA 0x00000080
    #define DDRSS_PI_275_DATA 0x00020000
    #define DDRSS_PI_276_DATA 0x00000080
    #define DDRSS_PI_277_DATA 0x00020000
    #define DDRSS_PI_278_DATA 0x00000080
    #define DDRSS_PI_279_DATA 0x00000000
    #define DDRSS_PI_280_DATA 0x00000000
    #define DDRSS_PI_281_DATA 0x00040404
    #define DDRSS_PI_282_DATA 0x00000000
    #define DDRSS_PI_283_DATA 0x02010102
    #define DDRSS_PI_284_DATA 0x67676767
    #define DDRSS_PI_285_DATA 0x00000202
    #define DDRSS_PI_286_DATA 0x00000000
    #define DDRSS_PI_287_DATA 0x00000000
    #define DDRSS_PI_288_DATA 0x00000000
    #define DDRSS_PI_289_DATA 0x00000000
    #define DDRSS_PI_290_DATA 0x00000000
    #define DDRSS_PI_291_DATA 0x0D100F00
    #define DDRSS_PI_292_DATA 0x0003020E
    #define DDRSS_PI_293_DATA 0x00000001
    #define DDRSS_PI_294_DATA 0x01000000
    #define DDRSS_PI_295_DATA 0x00020201
    #define DDRSS_PI_296_DATA 0x00000000
    #define DDRSS_PI_297_DATA 0x00000224
    #define DDRSS_PI_298_DATA 0x00000301
    #define DDRSS_PI_299_DATA 0x00000000
    #define DDRSS_PI_300_DATA 0x00000000
    #define DDRSS_PI_301_DATA 0x00000000
    #define DDRSS_PI_302_DATA 0x00001401
    #define DDRSS_PI_303_DATA 0x00000093
    #define DDRSS_PI_304_DATA 0x00000000
    #define DDRSS_PI_305_DATA 0x00000224
    #define DDRSS_PI_306_DATA 0x00000301
    #define DDRSS_PI_307_DATA 0x00000000
    #define DDRSS_PI_308_DATA 0x00000000
    #define DDRSS_PI_309_DATA 0x00000000
    #define DDRSS_PI_310_DATA 0x00001401
    #define DDRSS_PI_311_DATA 0x00000093
    #define DDRSS_PI_312_DATA 0x00000000
    #define DDRSS_PI_313_DATA 0x00000224
    #define DDRSS_PI_314_DATA 0x00000301
    #define DDRSS_PI_315_DATA 0x00000000
    #define DDRSS_PI_316_DATA 0x00000000
    #define DDRSS_PI_317_DATA 0x00000000
    #define DDRSS_PI_318_DATA 0x00001401
    #define DDRSS_PI_319_DATA 0x00000093
    #define DDRSS_PI_320_DATA 0x00000000
    #define DDRSS_PI_321_DATA 0x00000224
    #define DDRSS_PI_322_DATA 0x00000301
    #define DDRSS_PI_323_DATA 0x00000000
    #define DDRSS_PI_324_DATA 0x00000000
    #define DDRSS_PI_325_DATA 0x00000000
    #define DDRSS_PI_326_DATA 0x00001401
    #define DDRSS_PI_327_DATA 0x00000093
    #define DDRSS_PI_328_DATA 0x00000000
    #define DDRSS_PI_329_DATA 0x00000224
    #define DDRSS_PI_330_DATA 0x00000301
    #define DDRSS_PI_331_DATA 0x00000000
    #define DDRSS_PI_332_DATA 0x00000000
    #define DDRSS_PI_333_DATA 0x00000000
    #define DDRSS_PI_334_DATA 0x00001401
    #define DDRSS_PI_335_DATA 0x00000093
    #define DDRSS_PI_336_DATA 0x00000000
    #define DDRSS_PI_337_DATA 0x00000224
    #define DDRSS_PI_338_DATA 0x00000301
    #define DDRSS_PI_339_DATA 0x00000000
    #define DDRSS_PI_340_DATA 0x00000000
    #define DDRSS_PI_341_DATA 0x00000000
    #define DDRSS_PI_342_DATA 0x00001401
    #define DDRSS_PI_343_DATA 0x00000093
    #define DDRSS_PI_344_DATA 0x00000000
    #define DDRSS_PHY_0_DATA 0x04C00000
    #define DDRSS_PHY_1_DATA 0x00000000
    #define DDRSS_PHY_2_DATA 0x00000200
    #define DDRSS_PHY_3_DATA 0x00000000
    #define DDRSS_PHY_4_DATA 0x00000000
    #define DDRSS_PHY_5_DATA 0x00000000
    #define DDRSS_PHY_6_DATA 0x00000000
    #define DDRSS_PHY_7_DATA 0x00000000
    #define DDRSS_PHY_8_DATA 0x00000001
    #define DDRSS_PHY_9_DATA 0x00000000
    #define DDRSS_PHY_10_DATA 0x00000000
    #define DDRSS_PHY_11_DATA 0x010101FF
    #define DDRSS_PHY_12_DATA 0x00010000
    #define DDRSS_PHY_13_DATA 0x00C00004
    #define DDRSS_PHY_14_DATA 0x00CC0008
    #define DDRSS_PHY_15_DATA 0x00660201
    #define DDRSS_PHY_16_DATA 0x00000000
    #define DDRSS_PHY_17_DATA 0x00000000
    #define DDRSS_PHY_18_DATA 0x00000000
    #define DDRSS_PHY_19_DATA 0x0000AAAA
    #define DDRSS_PHY_20_DATA 0x00005555
    #define DDRSS_PHY_21_DATA 0x0000B5B5
    #define DDRSS_PHY_22_DATA 0x00004A4A
    #define DDRSS_PHY_23_DATA 0x00005656
    #define DDRSS_PHY_24_DATA 0x0000A9A9
    #define DDRSS_PHY_25_DATA 0x0000B7B7
    #define DDRSS_PHY_26_DATA 0x00004848
    #define DDRSS_PHY_27_DATA 0x00000000
    #define DDRSS_PHY_28_DATA 0x00000000
    #define DDRSS_PHY_29_DATA 0x08000000
    #define DDRSS_PHY_30_DATA 0x0F000008
    #define DDRSS_PHY_31_DATA 0x00000F0F
    #define DDRSS_PHY_32_DATA 0x00E4E400
    #define DDRSS_PHY_33_DATA 0x00070820
    #define DDRSS_PHY_34_DATA 0x000C0020
    #define DDRSS_PHY_35_DATA 0x00062000
    #define DDRSS_PHY_36_DATA 0x00000000
    #define DDRSS_PHY_37_DATA 0x55555555
    #define DDRSS_PHY_38_DATA 0xAAAAAAAA
    #define DDRSS_PHY_39_DATA 0x55555555
    #define DDRSS_PHY_40_DATA 0xAAAAAAAA
    #define DDRSS_PHY_41_DATA 0x00005555
    #define DDRSS_PHY_42_DATA 0x01000100
    #define DDRSS_PHY_43_DATA 0x00800180
    #define DDRSS_PHY_44_DATA 0x00000000
    #define DDRSS_PHY_45_DATA 0x00000000
    #define DDRSS_PHY_46_DATA 0x00000000
    #define DDRSS_PHY_47_DATA 0x00000000
    #define DDRSS_PHY_48_DATA 0x00000000
    #define DDRSS_PHY_49_DATA 0x00000000
    #define DDRSS_PHY_50_DATA 0x00000000
    #define DDRSS_PHY_51_DATA 0x00000000
    #define DDRSS_PHY_52_DATA 0x00000000
    #define DDRSS_PHY_53_DATA 0x00000000
    #define DDRSS_PHY_54_DATA 0x00000000
    #define DDRSS_PHY_55_DATA 0x00000000
    #define DDRSS_PHY_56_DATA 0x00000000
    #define DDRSS_PHY_57_DATA 0x00000000
    #define DDRSS_PHY_58_DATA 0x00000000
    #define DDRSS_PHY_59_DATA 0x00000000
    #define DDRSS_PHY_60_DATA 0x00000000
    #define DDRSS_PHY_61_DATA 0x00000000
    #define DDRSS_PHY_62_DATA 0x00000000
    #define DDRSS_PHY_63_DATA 0x00000000
    #define DDRSS_PHY_64_DATA 0x00000000
    #define DDRSS_PHY_65_DATA 0x00000004
    #define DDRSS_PHY_66_DATA 0x00000000
    #define DDRSS_PHY_67_DATA 0x00000000
    #define DDRSS_PHY_68_DATA 0x00000000
    #define DDRSS_PHY_69_DATA 0x00000000
    #define DDRSS_PHY_70_DATA 0x00000000
    #define DDRSS_PHY_71_DATA 0x00000000
    #define DDRSS_PHY_72_DATA 0x041F07FF
    #define DDRSS_PHY_73_DATA 0x00000000
    #define DDRSS_PHY_74_DATA 0x01BBB001
    #define DDRSS_PHY_75_DATA 0x2000BBB0
    #define DDRSS_PHY_76_DATA 0x20000140
    #define DDRSS_PHY_77_DATA 0x07FF0200
    #define DDRSS_PHY_78_DATA 0x0000DD01
    #define DDRSS_PHY_79_DATA 0x10100303
    #define DDRSS_PHY_80_DATA 0x10101010
    #define DDRSS_PHY_81_DATA 0x10101010
    #define DDRSS_PHY_82_DATA 0x00021010
    #define DDRSS_PHY_83_DATA 0x00100010
    #define DDRSS_PHY_84_DATA 0x00100010
    #define DDRSS_PHY_85_DATA 0x00100010
    #define DDRSS_PHY_86_DATA 0x00100010
    #define DDRSS_PHY_87_DATA 0x02000010
    #define DDRSS_PHY_88_DATA 0x51515041
    #define DDRSS_PHY_89_DATA 0x31804000
    #define DDRSS_PHY_90_DATA 0x04BF0340
    #define DDRSS_PHY_91_DATA 0x01008080
    #define DDRSS_PHY_92_DATA 0x03040001
    #define DDRSS_PHY_93_DATA 0x00000403
    #define DDRSS_PHY_94_DATA 0x42100010
    #define DDRSS_PHY_95_DATA 0x010C053E
    #define DDRSS_PHY_96_DATA 0x000F0C12
    #define DDRSS_PHY_97_DATA 0x01000140
    #define DDRSS_PHY_98_DATA 0x00600120
    #define DDRSS_PHY_99_DATA 0x00000C00
    #define DDRSS_PHY_100_DATA 0x000001A0
    #define DDRSS_PHY_101_DATA 0x20100200
    #define DDRSS_PHY_102_DATA 0x00000004
    #define DDRSS_PHY_103_DATA 0x76543210
    #define DDRSS_PHY_104_DATA 0x00000008
    #define DDRSS_PHY_105_DATA 0x02800280
    #define DDRSS_PHY_106_DATA 0x02800280
    #define DDRSS_PHY_107_DATA 0x02800280
    #define DDRSS_PHY_108_DATA 0x02800280
    #define DDRSS_PHY_109_DATA 0x00000280
    #define DDRSS_PHY_110_DATA 0x00008000
    #define DDRSS_PHY_111_DATA 0x00800080
    #define DDRSS_PHY_112_DATA 0x00800080
    #define DDRSS_PHY_113_DATA 0x00800080
    #define DDRSS_PHY_114_DATA 0x00800080
    #define DDRSS_PHY_115_DATA 0x00800080
    #define DDRSS_PHY_116_DATA 0x00800080
    #define DDRSS_PHY_117_DATA 0x00800080
    #define DDRSS_PHY_118_DATA 0x00800080
    #define DDRSS_PHY_119_DATA 0x01000080
    #define DDRSS_PHY_120_DATA 0x01000000
    #define DDRSS_PHY_121_DATA 0x00000000
    #define DDRSS_PHY_122_DATA 0x00000000
    #define DDRSS_PHY_123_DATA 0x00080200
    #define DDRSS_PHY_124_DATA 0x00000000
    #define DDRSS_PHY_125_DATA 0x00000000
    #define DDRSS_PHY_126_DATA 0x00000000
    #define DDRSS_PHY_127_DATA 0x00000000
    #define DDRSS_PHY_128_DATA 0x00000000
    #define DDRSS_PHY_129_DATA 0x00000000
    #define DDRSS_PHY_130_DATA 0x00000000
    #define DDRSS_PHY_131_DATA 0x00000000
    #define DDRSS_PHY_132_DATA 0x00000000
    #define DDRSS_PHY_133_DATA 0x00000000
    #define DDRSS_PHY_134_DATA 0x00000000
    #define DDRSS_PHY_135_DATA 0x00000000
    #define DDRSS_PHY_136_DATA 0x00000000
    #define DDRSS_PHY_137_DATA 0x00000000
    #define DDRSS_PHY_138_DATA 0x00000000
    #define DDRSS_PHY_139_DATA 0x00000000
    #define DDRSS_PHY_140_DATA 0x00000000
    #define DDRSS_PHY_141_DATA 0x00000000
    #define DDRSS_PHY_142_DATA 0x00000000
    #define DDRSS_PHY_143_DATA 0x00000000
    #define DDRSS_PHY_144_DATA 0x00000000
    #define DDRSS_PHY_145_DATA 0x00000000
    #define DDRSS_PHY_146_DATA 0x00000000
    #define DDRSS_PHY_147_DATA 0x00000000
    #define DDRSS_PHY_148_DATA 0x00000000
    #define DDRSS_PHY_149_DATA 0x00000000
    #define DDRSS_PHY_150_DATA 0x00000000
    #define DDRSS_PHY_151_DATA 0x00000000
    #define DDRSS_PHY_152_DATA 0x00000000
    #define DDRSS_PHY_153_DATA 0x00000000
    #define DDRSS_PHY_154_DATA 0x00000000
    #define DDRSS_PHY_155_DATA 0x00000000
    #define DDRSS_PHY_156_DATA 0x00000000
    #define DDRSS_PHY_157_DATA 0x00000000
    #define DDRSS_PHY_158_DATA 0x00000000
    #define DDRSS_PHY_159_DATA 0x00000000
    #define DDRSS_PHY_160_DATA 0x00000000
    #define DDRSS_PHY_161_DATA 0x00000000
    #define DDRSS_PHY_162_DATA 0x00000000
    #define DDRSS_PHY_163_DATA 0x00000000
    #define DDRSS_PHY_164_DATA 0x00000000
    #define DDRSS_PHY_165_DATA 0x00000000
    #define DDRSS_PHY_166_DATA 0x00000000
    #define DDRSS_PHY_167_DATA 0x00000000
    #define DDRSS_PHY_168_DATA 0x00000000
    #define DDRSS_PHY_169_DATA 0x00000000
    #define DDRSS_PHY_170_DATA 0x00000000
    #define DDRSS_PHY_171_DATA 0x00000000
    #define DDRSS_PHY_172_DATA 0x00000000
    #define DDRSS_PHY_173_DATA 0x00000000
    #define DDRSS_PHY_174_DATA 0x00000000
    #define DDRSS_PHY_175_DATA 0x00000000
    #define DDRSS_PHY_176_DATA 0x00000000
    #define DDRSS_PHY_177_DATA 0x00000000
    #define DDRSS_PHY_178_DATA 0x00000000
    #define DDRSS_PHY_179_DATA 0x00000000
    #define DDRSS_PHY_180_DATA 0x00000000
    #define DDRSS_PHY_181_DATA 0x00000000
    #define DDRSS_PHY_182_DATA 0x00000000
    #define DDRSS_PHY_183_DATA 0x00000000
    #define DDRSS_PHY_184_DATA 0x00000000
    #define DDRSS_PHY_185_DATA 0x00000000
    #define DDRSS_PHY_186_DATA 0x00000000
    #define DDRSS_PHY_187_DATA 0x00000000
    #define DDRSS_PHY_188_DATA 0x00000000
    #define DDRSS_PHY_189_DATA 0x00000000
    #define DDRSS_PHY_190_DATA 0x00000000
    #define DDRSS_PHY_191_DATA 0x00000000
    #define DDRSS_PHY_192_DATA 0x00000000
    #define DDRSS_PHY_193_DATA 0x00000000
    #define DDRSS_PHY_194_DATA 0x00000000
    #define DDRSS_PHY_195_DATA 0x00000000
    #define DDRSS_PHY_196_DATA 0x00000000
    #define DDRSS_PHY_197_DATA 0x00000000
    #define DDRSS_PHY_198_DATA 0x00000000
    #define DDRSS_PHY_199_DATA 0x00000000
    #define DDRSS_PHY_200_DATA 0x00000000
    #define DDRSS_PHY_201_DATA 0x00000000
    #define DDRSS_PHY_202_DATA 0x00000000
    #define DDRSS_PHY_203_DATA 0x00000000
    #define DDRSS_PHY_204_DATA 0x00000000
    #define DDRSS_PHY_205_DATA 0x00000000
    #define DDRSS_PHY_206_DATA 0x00000000
    #define DDRSS_PHY_207_DATA 0x00000000
    #define DDRSS_PHY_208_DATA 0x00000000
    #define DDRSS_PHY_209_DATA 0x00000000
    #define DDRSS_PHY_210_DATA 0x00000000
    #define DDRSS_PHY_211_DATA 0x00000000
    #define DDRSS_PHY_212_DATA 0x00000000
    #define DDRSS_PHY_213_DATA 0x00000000
    #define DDRSS_PHY_214_DATA 0x00000000
    #define DDRSS_PHY_215_DATA 0x00000000
    #define DDRSS_PHY_216_DATA 0x00000000
    #define DDRSS_PHY_217_DATA 0x00000000
    #define DDRSS_PHY_218_DATA 0x00000000
    #define DDRSS_PHY_219_DATA 0x00000000
    #define DDRSS_PHY_220_DATA 0x00000000
    #define DDRSS_PHY_221_DATA 0x00000000
    #define DDRSS_PHY_222_DATA 0x00000000
    #define DDRSS_PHY_223_DATA 0x00000000
    #define DDRSS_PHY_224_DATA 0x00000000
    #define DDRSS_PHY_225_DATA 0x00000000
    #define DDRSS_PHY_226_DATA 0x00000000
    #define DDRSS_PHY_227_DATA 0x00000000
    #define DDRSS_PHY_228_DATA 0x00000000
    #define DDRSS_PHY_229_DATA 0x00000000
    #define DDRSS_PHY_230_DATA 0x00000000
    #define DDRSS_PHY_231_DATA 0x00000000
    #define DDRSS_PHY_232_DATA 0x00000000
    #define DDRSS_PHY_233_DATA 0x00000000
    #define DDRSS_PHY_234_DATA 0x00000000
    #define DDRSS_PHY_235_DATA 0x00000000
    #define DDRSS_PHY_236_DATA 0x00000000
    #define DDRSS_PHY_237_DATA 0x00000000
    #define DDRSS_PHY_238_DATA 0x00000000
    #define DDRSS_PHY_239_DATA 0x00000000
    #define DDRSS_PHY_240_DATA 0x00000000
    #define DDRSS_PHY_241_DATA 0x00000000
    #define DDRSS_PHY_242_DATA 0x00000000
    #define DDRSS_PHY_243_DATA 0x00000000
    #define DDRSS_PHY_244_DATA 0x00000000
    #define DDRSS_PHY_245_DATA 0x00000000
    #define DDRSS_PHY_246_DATA 0x00000000
    #define DDRSS_PHY_247_DATA 0x00000000
    #define DDRSS_PHY_248_DATA 0x00000000
    #define DDRSS_PHY_249_DATA 0x00000000
    #define DDRSS_PHY_250_DATA 0x00000000
    #define DDRSS_PHY_251_DATA 0x00000000
    #define DDRSS_PHY_252_DATA 0x00000000
    #define DDRSS_PHY_253_DATA 0x00000000
    #define DDRSS_PHY_254_DATA 0x00000000
    #define DDRSS_PHY_255_DATA 0x00000000
    #define DDRSS_PHY_256_DATA 0x04C00000
    #define DDRSS_PHY_257_DATA 0x00000000
    #define DDRSS_PHY_258_DATA 0x00000200
    #define DDRSS_PHY_259_DATA 0x00000000
    #define DDRSS_PHY_260_DATA 0x00000000
    #define DDRSS_PHY_261_DATA 0x00000000
    #define DDRSS_PHY_262_DATA 0x00000000
    #define DDRSS_PHY_263_DATA 0x00000000
    #define DDRSS_PHY_264_DATA 0x00000001
    #define DDRSS_PHY_265_DATA 0x00000000
    #define DDRSS_PHY_266_DATA 0x00000000
    #define DDRSS_PHY_267_DATA 0x010101FF
    #define DDRSS_PHY_268_DATA 0x00010000
    #define DDRSS_PHY_269_DATA 0x00C00004
    #define DDRSS_PHY_270_DATA 0x00CC0008
    #define DDRSS_PHY_271_DATA 0x00660201
    #define DDRSS_PHY_272_DATA 0x00000000
    #define DDRSS_PHY_273_DATA 0x00000000
    #define DDRSS_PHY_274_DATA 0x00000000
    #define DDRSS_PHY_275_DATA 0x0000AAAA
    #define DDRSS_PHY_276_DATA 0x00005555
    #define DDRSS_PHY_277_DATA 0x0000B5B5
    #define DDRSS_PHY_278_DATA 0x00004A4A
    #define DDRSS_PHY_279_DATA 0x00005656
    #define DDRSS_PHY_280_DATA 0x0000A9A9
    #define DDRSS_PHY_281_DATA 0x0000B7B7
    #define DDRSS_PHY_282_DATA 0x00004848
    #define DDRSS_PHY_283_DATA 0x00000000
    #define DDRSS_PHY_284_DATA 0x00000000
    #define DDRSS_PHY_285_DATA 0x08000000
    #define DDRSS_PHY_286_DATA 0x0F000008
    #define DDRSS_PHY_287_DATA 0x00000F0F
    #define DDRSS_PHY_288_DATA 0x00E4E400
    #define DDRSS_PHY_289_DATA 0x00070820
    #define DDRSS_PHY_290_DATA 0x000C0020
    #define DDRSS_PHY_291_DATA 0x00062000
    #define DDRSS_PHY_292_DATA 0x00000000
    #define DDRSS_PHY_293_DATA 0x55555555
    #define DDRSS_PHY_294_DATA 0xAAAAAAAA
    #define DDRSS_PHY_295_DATA 0x55555555
    #define DDRSS_PHY_296_DATA 0xAAAAAAAA
    #define DDRSS_PHY_297_DATA 0x00005555
    #define DDRSS_PHY_298_DATA 0x01000100
    #define DDRSS_PHY_299_DATA 0x00800180
    #define DDRSS_PHY_300_DATA 0x00000000
    #define DDRSS_PHY_301_DATA 0x00000000
    #define DDRSS_PHY_302_DATA 0x00000000
    #define DDRSS_PHY_303_DATA 0x00000000
    #define DDRSS_PHY_304_DATA 0x00000000
    #define DDRSS_PHY_305_DATA 0x00000000
    #define DDRSS_PHY_306_DATA 0x00000000
    #define DDRSS_PHY_307_DATA 0x00000000
    #define DDRSS_PHY_308_DATA 0x00000000
    #define DDRSS_PHY_309_DATA 0x00000000
    #define DDRSS_PHY_310_DATA 0x00000000
    #define DDRSS_PHY_311_DATA 0x00000000
    #define DDRSS_PHY_312_DATA 0x00000000
    #define DDRSS_PHY_313_DATA 0x00000000
    #define DDRSS_PHY_314_DATA 0x00000000
    #define DDRSS_PHY_315_DATA 0x00000000
    #define DDRSS_PHY_316_DATA 0x00000000
    #define DDRSS_PHY_317_DATA 0x00000000
    #define DDRSS_PHY_318_DATA 0x00000000
    #define DDRSS_PHY_319_DATA 0x00000000
    #define DDRSS_PHY_320_DATA 0x00000000
    #define DDRSS_PHY_321_DATA 0x00000004
    #define DDRSS_PHY_322_DATA 0x00000000
    #define DDRSS_PHY_323_DATA 0x00000000
    #define DDRSS_PHY_324_DATA 0x00000000
    #define DDRSS_PHY_325_DATA 0x00000000
    #define DDRSS_PHY_326_DATA 0x00000000
    #define DDRSS_PHY_327_DATA 0x00000000
    #define DDRSS_PHY_328_DATA 0x041F07FF
    #define DDRSS_PHY_329_DATA 0x00000000
    #define DDRSS_PHY_330_DATA 0x01BBB001
    #define DDRSS_PHY_331_DATA 0x2000BBB0
    #define DDRSS_PHY_332_DATA 0x20000140
    #define DDRSS_PHY_333_DATA 0x07FF0200
    #define DDRSS_PHY_334_DATA 0x0000DD01
    #define DDRSS_PHY_335_DATA 0x10100303
    #define DDRSS_PHY_336_DATA 0x10101010
    #define DDRSS_PHY_337_DATA 0x10101010
    #define DDRSS_PHY_338_DATA 0x00021010
    #define DDRSS_PHY_339_DATA 0x00100010
    #define DDRSS_PHY_340_DATA 0x00100010
    #define DDRSS_PHY_341_DATA 0x00100010
    #define DDRSS_PHY_342_DATA 0x00100010
    #define DDRSS_PHY_343_DATA 0x02000010
    #define DDRSS_PHY_344_DATA 0x51515041
    #define DDRSS_PHY_345_DATA 0x31804000
    #define DDRSS_PHY_346_DATA 0x04BF0340
    #define DDRSS_PHY_347_DATA 0x01008080
    #define DDRSS_PHY_348_DATA 0x03040001
    #define DDRSS_PHY_349_DATA 0x00000403
    #define DDRSS_PHY_350_DATA 0x42100010
    #define DDRSS_PHY_351_DATA 0x010C053E
    #define DDRSS_PHY_352_DATA 0x000F0C12
    #define DDRSS_PHY_353_DATA 0x01000140
    #define DDRSS_PHY_354_DATA 0x00600120
    #define DDRSS_PHY_355_DATA 0x00000C00
    #define DDRSS_PHY_356_DATA 0x000001A0
    #define DDRSS_PHY_357_DATA 0x20100200
    #define DDRSS_PHY_358_DATA 0x00000004
    #define DDRSS_PHY_359_DATA 0x76543210
    #define DDRSS_PHY_360_DATA 0x00000008
    #define DDRSS_PHY_361_DATA 0x02800280
    #define DDRSS_PHY_362_DATA 0x02800280
    #define DDRSS_PHY_363_DATA 0x02800280
    #define DDRSS_PHY_364_DATA 0x02800280
    #define DDRSS_PHY_365_DATA 0x00000280
    #define DDRSS_PHY_366_DATA 0x00008000
    #define DDRSS_PHY_367_DATA 0x00800080
    #define DDRSS_PHY_368_DATA 0x00800080
    #define DDRSS_PHY_369_DATA 0x00800080
    #define DDRSS_PHY_370_DATA 0x00800080
    #define DDRSS_PHY_371_DATA 0x00800080
    #define DDRSS_PHY_372_DATA 0x00800080
    #define DDRSS_PHY_373_DATA 0x00800080
    #define DDRSS_PHY_374_DATA 0x00800080
    #define DDRSS_PHY_375_DATA 0x01000080
    #define DDRSS_PHY_376_DATA 0x01000000
    #define DDRSS_PHY_377_DATA 0x00000000
    #define DDRSS_PHY_378_DATA 0x00000000
    #define DDRSS_PHY_379_DATA 0x00080200
    #define DDRSS_PHY_380_DATA 0x00000000
    #define DDRSS_PHY_381_DATA 0x00000000
    #define DDRSS_PHY_382_DATA 0x00000000
    #define DDRSS_PHY_383_DATA 0x00000000
    #define DDRSS_PHY_384_DATA 0x00000000
    #define DDRSS_PHY_385_DATA 0x00000000
    #define DDRSS_PHY_386_DATA 0x00000000
    #define DDRSS_PHY_387_DATA 0x00000000
    #define DDRSS_PHY_388_DATA 0x00000000
    #define DDRSS_PHY_389_DATA 0x00000000
    #define DDRSS_PHY_390_DATA 0x00000000
    #define DDRSS_PHY_391_DATA 0x00000000
    #define DDRSS_PHY_392_DATA 0x00000000
    #define DDRSS_PHY_393_DATA 0x00000000
    #define DDRSS_PHY_394_DATA 0x00000000
    #define DDRSS_PHY_395_DATA 0x00000000
    #define DDRSS_PHY_396_DATA 0x00000000
    #define DDRSS_PHY_397_DATA 0x00000000
    #define DDRSS_PHY_398_DATA 0x00000000
    #define DDRSS_PHY_399_DATA 0x00000000
    #define DDRSS_PHY_400_DATA 0x00000000
    #define DDRSS_PHY_401_DATA 0x00000000
    #define DDRSS_PHY_402_DATA 0x00000000
    #define DDRSS_PHY_403_DATA 0x00000000
    #define DDRSS_PHY_404_DATA 0x00000000
    #define DDRSS_PHY_405_DATA 0x00000000
    #define DDRSS_PHY_406_DATA 0x00000000
    #define DDRSS_PHY_407_DATA 0x00000000
    #define DDRSS_PHY_408_DATA 0x00000000
    #define DDRSS_PHY_409_DATA 0x00000000
    #define DDRSS_PHY_410_DATA 0x00000000
    #define DDRSS_PHY_411_DATA 0x00000000
    #define DDRSS_PHY_412_DATA 0x00000000
    #define DDRSS_PHY_413_DATA 0x00000000
    #define DDRSS_PHY_414_DATA 0x00000000
    #define DDRSS_PHY_415_DATA 0x00000000
    #define DDRSS_PHY_416_DATA 0x00000000
    #define DDRSS_PHY_417_DATA 0x00000000
    #define DDRSS_PHY_418_DATA 0x00000000
    #define DDRSS_PHY_419_DATA 0x00000000
    #define DDRSS_PHY_420_DATA 0x00000000
    #define DDRSS_PHY_421_DATA 0x00000000
    #define DDRSS_PHY_422_DATA 0x00000000
    #define DDRSS_PHY_423_DATA 0x00000000
    #define DDRSS_PHY_424_DATA 0x00000000
    #define DDRSS_PHY_425_DATA 0x00000000
    #define DDRSS_PHY_426_DATA 0x00000000
    #define DDRSS_PHY_427_DATA 0x00000000
    #define DDRSS_PHY_428_DATA 0x00000000
    #define DDRSS_PHY_429_DATA 0x00000000
    #define DDRSS_PHY_430_DATA 0x00000000
    #define DDRSS_PHY_431_DATA 0x00000000
    #define DDRSS_PHY_432_DATA 0x00000000
    #define DDRSS_PHY_433_DATA 0x00000000
    #define DDRSS_PHY_434_DATA 0x00000000
    #define DDRSS_PHY_435_DATA 0x00000000
    #define DDRSS_PHY_436_DATA 0x00000000
    #define DDRSS_PHY_437_DATA 0x00000000
    #define DDRSS_PHY_438_DATA 0x00000000
    #define DDRSS_PHY_439_DATA 0x00000000
    #define DDRSS_PHY_440_DATA 0x00000000
    #define DDRSS_PHY_441_DATA 0x00000000
    #define DDRSS_PHY_442_DATA 0x00000000
    #define DDRSS_PHY_443_DATA 0x00000000
    #define DDRSS_PHY_444_DATA 0x00000000
    #define DDRSS_PHY_445_DATA 0x00000000
    #define DDRSS_PHY_446_DATA 0x00000000
    #define DDRSS_PHY_447_DATA 0x00000000
    #define DDRSS_PHY_448_DATA 0x00000000
    #define DDRSS_PHY_449_DATA 0x00000000
    #define DDRSS_PHY_450_DATA 0x00000000
    #define DDRSS_PHY_451_DATA 0x00000000
    #define DDRSS_PHY_452_DATA 0x00000000
    #define DDRSS_PHY_453_DATA 0x00000000
    #define DDRSS_PHY_454_DATA 0x00000000
    #define DDRSS_PHY_455_DATA 0x00000000
    #define DDRSS_PHY_456_DATA 0x00000000
    #define DDRSS_PHY_457_DATA 0x00000000
    #define DDRSS_PHY_458_DATA 0x00000000
    #define DDRSS_PHY_459_DATA 0x00000000
    #define DDRSS_PHY_460_DATA 0x00000000
    #define DDRSS_PHY_461_DATA 0x00000000
    #define DDRSS_PHY_462_DATA 0x00000000
    #define DDRSS_PHY_463_DATA 0x00000000
    #define DDRSS_PHY_464_DATA 0x00000000
    #define DDRSS_PHY_465_DATA 0x00000000
    #define DDRSS_PHY_466_DATA 0x00000000
    #define DDRSS_PHY_467_DATA 0x00000000
    #define DDRSS_PHY_468_DATA 0x00000000
    #define DDRSS_PHY_469_DATA 0x00000000
    #define DDRSS_PHY_470_DATA 0x00000000
    #define DDRSS_PHY_471_DATA 0x00000000
    #define DDRSS_PHY_472_DATA 0x00000000
    #define DDRSS_PHY_473_DATA 0x00000000
    #define DDRSS_PHY_474_DATA 0x00000000
    #define DDRSS_PHY_475_DATA 0x00000000
    #define DDRSS_PHY_476_DATA 0x00000000
    #define DDRSS_PHY_477_DATA 0x00000000
    #define DDRSS_PHY_478_DATA 0x00000000
    #define DDRSS_PHY_479_DATA 0x00000000
    #define DDRSS_PHY_480_DATA 0x00000000
    #define DDRSS_PHY_481_DATA 0x00000000
    #define DDRSS_PHY_482_DATA 0x00000000
    #define DDRSS_PHY_483_DATA 0x00000000
    #define DDRSS_PHY_484_DATA 0x00000000
    #define DDRSS_PHY_485_DATA 0x00000000
    #define DDRSS_PHY_486_DATA 0x00000000
    #define DDRSS_PHY_487_DATA 0x00000000
    #define DDRSS_PHY_488_DATA 0x00000000
    #define DDRSS_PHY_489_DATA 0x00000000
    #define DDRSS_PHY_490_DATA 0x00000000
    #define DDRSS_PHY_491_DATA 0x00000000
    #define DDRSS_PHY_492_DATA 0x00000000
    #define DDRSS_PHY_493_DATA 0x00000000
    #define DDRSS_PHY_494_DATA 0x00000000
    #define DDRSS_PHY_495_DATA 0x00000000
    #define DDRSS_PHY_496_DATA 0x00000000
    #define DDRSS_PHY_497_DATA 0x00000000
    #define DDRSS_PHY_498_DATA 0x00000000
    #define DDRSS_PHY_499_DATA 0x00000000
    #define DDRSS_PHY_500_DATA 0x00000000
    #define DDRSS_PHY_501_DATA 0x00000000
    #define DDRSS_PHY_502_DATA 0x00000000
    #define DDRSS_PHY_503_DATA 0x00000000
    #define DDRSS_PHY_504_DATA 0x00000000
    #define DDRSS_PHY_505_DATA 0x00000000
    #define DDRSS_PHY_506_DATA 0x00000000
    #define DDRSS_PHY_507_DATA 0x00000000
    #define DDRSS_PHY_508_DATA 0x00000000
    #define DDRSS_PHY_509_DATA 0x00000000
    #define DDRSS_PHY_510_DATA 0x00000000
    #define DDRSS_PHY_511_DATA 0x00000000
    #define DDRSS_PHY_512_DATA 0x00000100
    #define DDRSS_PHY_513_DATA 0x00000000
    #define DDRSS_PHY_514_DATA 0x00000000
    #define DDRSS_PHY_515_DATA 0x00000000
    #define DDRSS_PHY_516_DATA 0x00000000
    #define DDRSS_PHY_517_DATA 0x00000100
    #define DDRSS_PHY_518_DATA 0x00000000
    #define DDRSS_PHY_519_DATA 0x00000000
    #define DDRSS_PHY_520_DATA 0x00000000
    #define DDRSS_PHY_521_DATA 0x00000000
    #define DDRSS_PHY_522_DATA 0x00000000
    #define DDRSS_PHY_523_DATA 0x00000000
    #define DDRSS_PHY_524_DATA 0x00000000
    #define DDRSS_PHY_525_DATA 0x00DCBA98
    #define DDRSS_PHY_526_DATA 0x00000000
    #define DDRSS_PHY_527_DATA 0x00000000
    #define DDRSS_PHY_528_DATA 0x00000000
    #define DDRSS_PHY_529_DATA 0x00000000
    #define DDRSS_PHY_530_DATA 0x00000000
    #define DDRSS_PHY_531_DATA 0x00000000
    #define DDRSS_PHY_532_DATA 0x00000000
    #define DDRSS_PHY_533_DATA 0x00000000
    #define DDRSS_PHY_534_DATA 0x00000000
    #define DDRSS_PHY_535_DATA 0x00000000
    #define DDRSS_PHY_536_DATA 0x00000000
    #define DDRSS_PHY_537_DATA 0x00000000
    #define DDRSS_PHY_538_DATA 0x00000000
    #define DDRSS_PHY_539_DATA 0x00000000
    #define DDRSS_PHY_540_DATA 0x0A418820
    #define DDRSS_PHY_541_DATA 0x103F0000
    #define DDRSS_PHY_542_DATA 0x000F0100
    #define DDRSS_PHY_543_DATA 0x0000000F
    #define DDRSS_PHY_544_DATA 0x000002BB
    #define DDRSS_PHY_545_DATA 0x00030000
    #define DDRSS_PHY_546_DATA 0x00000300
    #define DDRSS_PHY_547_DATA 0x00000300
    #define DDRSS_PHY_548_DATA 0x00000300
    #define DDRSS_PHY_549_DATA 0x00000300
    #define DDRSS_PHY_550_DATA 0x00000300
    #define DDRSS_PHY_551_DATA 0x42080010
    #define DDRSS_PHY_552_DATA 0x0000003E
    #define DDRSS_PHY_553_DATA 0x00000000
    #define DDRSS_PHY_554_DATA 0x00000000
    #define DDRSS_PHY_555_DATA 0x00000000
    #define DDRSS_PHY_556_DATA 0x00000000
    #define DDRSS_PHY_557_DATA 0x00000000
    #define DDRSS_PHY_558_DATA 0x00000000
    #define DDRSS_PHY_559_DATA 0x00000000
    #define DDRSS_PHY_560_DATA 0x00000000
    #define DDRSS_PHY_561_DATA 0x00000000
    #define DDRSS_PHY_562_DATA 0x00000000
    #define DDRSS_PHY_563_DATA 0x00000000
    #define DDRSS_PHY_564_DATA 0x00000000
    #define DDRSS_PHY_565_DATA 0x00000000
    #define DDRSS_PHY_566_DATA 0x00000000
    #define DDRSS_PHY_567_DATA 0x00000000
    #define DDRSS_PHY_568_DATA 0x00000000
    #define DDRSS_PHY_569_DATA 0x00000000
    #define DDRSS_PHY_570_DATA 0x00000000
    #define DDRSS_PHY_571_DATA 0x00000000
    #define DDRSS_PHY_572_DATA 0x00000000
    #define DDRSS_PHY_573_DATA 0x00000000
    #define DDRSS_PHY_574_DATA 0x00000000
    #define DDRSS_PHY_575_DATA 0x00000000
    #define DDRSS_PHY_576_DATA 0x00000000
    #define DDRSS_PHY_577_DATA 0x00000000
    #define DDRSS_PHY_578_DATA 0x00000000
    #define DDRSS_PHY_579_DATA 0x00000000
    #define DDRSS_PHY_580_DATA 0x00000000
    #define DDRSS_PHY_581_DATA 0x00000000
    #define DDRSS_PHY_582_DATA 0x00000000
    #define DDRSS_PHY_583_DATA 0x00000000
    #define DDRSS_PHY_584_DATA 0x00000000
    #define DDRSS_PHY_585_DATA 0x00000000
    #define DDRSS_PHY_586_DATA 0x00000000
    #define DDRSS_PHY_587_DATA 0x00000000
    #define DDRSS_PHY_588_DATA 0x00000000
    #define DDRSS_PHY_589_DATA 0x00000000
    #define DDRSS_PHY_590_DATA 0x00000000
    #define DDRSS_PHY_591_DATA 0x00000000
    #define DDRSS_PHY_592_DATA 0x00000000
    #define DDRSS_PHY_593_DATA 0x00000000
    #define DDRSS_PHY_594_DATA 0x00000000
    #define DDRSS_PHY_595_DATA 0x00000000
    #define DDRSS_PHY_596_DATA 0x00000000
    #define DDRSS_PHY_597_DATA 0x00000000
    #define DDRSS_PHY_598_DATA 0x00000000
    #define DDRSS_PHY_599_DATA 0x00000000
    #define DDRSS_PHY_600_DATA 0x00000000
    #define DDRSS_PHY_601_DATA 0x00000000
    #define DDRSS_PHY_602_DATA 0x00000000
    #define DDRSS_PHY_603_DATA 0x00000000
    #define DDRSS_PHY_604_DATA 0x00000000
    #define DDRSS_PHY_605_DATA 0x00000000
    #define DDRSS_PHY_606_DATA 0x00000000
    #define DDRSS_PHY_607_DATA 0x00000000
    #define DDRSS_PHY_608_DATA 0x00000000
    #define DDRSS_PHY_609_DATA 0x00000000
    #define DDRSS_PHY_610_DATA 0x00000000
    #define DDRSS_PHY_611_DATA 0x00000000
    #define DDRSS_PHY_612_DATA 0x00000000
    #define DDRSS_PHY_613_DATA 0x00000000
    #define DDRSS_PHY_614_DATA 0x00000000
    #define DDRSS_PHY_615_DATA 0x00000000
    #define DDRSS_PHY_616_DATA 0x00000000
    #define DDRSS_PHY_617_DATA 0x00000000
    #define DDRSS_PHY_618_DATA 0x00000000
    #define DDRSS_PHY_619_DATA 0x00000000
    #define DDRSS_PHY_620_DATA 0x00000000
    #define DDRSS_PHY_621_DATA 0x00000000
    #define DDRSS_PHY_622_DATA 0x00000000
    #define DDRSS_PHY_623_DATA 0x00000000
    #define DDRSS_PHY_624_DATA 0x00000000
    #define DDRSS_PHY_625_DATA 0x00000000
    #define DDRSS_PHY_626_DATA 0x00000000
    #define DDRSS_PHY_627_DATA 0x00000000
    #define DDRSS_PHY_628_DATA 0x00000000
    #define DDRSS_PHY_629_DATA 0x00000000
    #define DDRSS_PHY_630_DATA 0x00000000
    #define DDRSS_PHY_631_DATA 0x00000000
    #define DDRSS_PHY_632_DATA 0x00000000
    #define DDRSS_PHY_633_DATA 0x00000000
    #define DDRSS_PHY_634_DATA 0x00000000
    #define DDRSS_PHY_635_DATA 0x00000000
    #define DDRSS_PHY_636_DATA 0x00000000
    #define DDRSS_PHY_637_DATA 0x00000000
    #define DDRSS_PHY_638_DATA 0x00000000
    #define DDRSS_PHY_639_DATA 0x00000000
    #define DDRSS_PHY_640_DATA 0x00000000
    #define DDRSS_PHY_641_DATA 0x00000000
    #define DDRSS_PHY_642_DATA 0x00000000
    #define DDRSS_PHY_643_DATA 0x00000000
    #define DDRSS_PHY_644_DATA 0x00000000
    #define DDRSS_PHY_645_DATA 0x00000000
    #define DDRSS_PHY_646_DATA 0x00000000
    #define DDRSS_PHY_647_DATA 0x00000000
    #define DDRSS_PHY_648_DATA 0x00000000
    #define DDRSS_PHY_649_DATA 0x00000000
    #define DDRSS_PHY_650_DATA 0x00000000
    #define DDRSS_PHY_651_DATA 0x00000000
    #define DDRSS_PHY_652_DATA 0x00000000
    #define DDRSS_PHY_653_DATA 0x00000000
    #define DDRSS_PHY_654_DATA 0x00000000
    #define DDRSS_PHY_655_DATA 0x00000000
    #define DDRSS_PHY_656_DATA 0x00000000
    #define DDRSS_PHY_657_DATA 0x00000000
    #define DDRSS_PHY_658_DATA 0x00000000
    #define DDRSS_PHY_659_DATA 0x00000000
    #define DDRSS_PHY_660_DATA 0x00000000
    #define DDRSS_PHY_661_DATA 0x00000000
    #define DDRSS_PHY_662_DATA 0x00000000
    #define DDRSS_PHY_663_DATA 0x00000000
    #define DDRSS_PHY_664_DATA 0x00000000
    #define DDRSS_PHY_665_DATA 0x00000000
    #define DDRSS_PHY_666_DATA 0x00000000
    #define DDRSS_PHY_667_DATA 0x00000000
    #define DDRSS_PHY_668_DATA 0x00000000
    #define DDRSS_PHY_669_DATA 0x00000000
    #define DDRSS_PHY_670_DATA 0x00000000
    #define DDRSS_PHY_671_DATA 0x00000000
    #define DDRSS_PHY_672_DATA 0x00000000
    #define DDRSS_PHY_673_DATA 0x00000000
    #define DDRSS_PHY_674_DATA 0x00000000
    #define DDRSS_PHY_675_DATA 0x00000000
    #define DDRSS_PHY_676_DATA 0x00000000
    #define DDRSS_PHY_677_DATA 0x00000000
    #define DDRSS_PHY_678_DATA 0x00000000
    #define DDRSS_PHY_679_DATA 0x00000000
    #define DDRSS_PHY_680_DATA 0x00000000
    #define DDRSS_PHY_681_DATA 0x00000000
    #define DDRSS_PHY_682_DATA 0x00000000
    #define DDRSS_PHY_683_DATA 0x00000000
    #define DDRSS_PHY_684_DATA 0x00000000
    #define DDRSS_PHY_685_DATA 0x00000000
    #define DDRSS_PHY_686_DATA 0x00000000
    #define DDRSS_PHY_687_DATA 0x00000000
    #define DDRSS_PHY_688_DATA 0x00000000
    #define DDRSS_PHY_689_DATA 0x00000000
    #define DDRSS_PHY_690_DATA 0x00000000
    #define DDRSS_PHY_691_DATA 0x00000000
    #define DDRSS_PHY_692_DATA 0x00000000
    #define DDRSS_PHY_693_DATA 0x00000000
    #define DDRSS_PHY_694_DATA 0x00000000
    #define DDRSS_PHY_695_DATA 0x00000000
    #define DDRSS_PHY_696_DATA 0x00000000
    #define DDRSS_PHY_697_DATA 0x00000000
    #define DDRSS_PHY_698_DATA 0x00000000
    #define DDRSS_PHY_699_DATA 0x00000000
    #define DDRSS_PHY_700_DATA 0x00000000
    #define DDRSS_PHY_701_DATA 0x00000000
    #define DDRSS_PHY_702_DATA 0x00000000
    #define DDRSS_PHY_703_DATA 0x00000000
    #define DDRSS_PHY_704_DATA 0x00000000
    #define DDRSS_PHY_705_DATA 0x00000000
    #define DDRSS_PHY_706_DATA 0x00000000
    #define DDRSS_PHY_707_DATA 0x00000000
    #define DDRSS_PHY_708_DATA 0x00000000
    #define DDRSS_PHY_709_DATA 0x00000000
    #define DDRSS_PHY_710_DATA 0x00000000
    #define DDRSS_PHY_711_DATA 0x00000000
    #define DDRSS_PHY_712_DATA 0x00000000
    #define DDRSS_PHY_713_DATA 0x00000000
    #define DDRSS_PHY_714_DATA 0x00000000
    #define DDRSS_PHY_715_DATA 0x00000000
    #define DDRSS_PHY_716_DATA 0x00000000
    #define DDRSS_PHY_717_DATA 0x00000000
    #define DDRSS_PHY_718_DATA 0x00000000
    #define DDRSS_PHY_719_DATA 0x00000000
    #define DDRSS_PHY_720_DATA 0x00000000
    #define DDRSS_PHY_721_DATA 0x00000000
    #define DDRSS_PHY_722_DATA 0x00000000
    #define DDRSS_PHY_723_DATA 0x00000000
    #define DDRSS_PHY_724_DATA 0x00000000
    #define DDRSS_PHY_725_DATA 0x00000000
    #define DDRSS_PHY_726_DATA 0x00000000
    #define DDRSS_PHY_727_DATA 0x00000000
    #define DDRSS_PHY_728_DATA 0x00000000
    #define DDRSS_PHY_729_DATA 0x00000000
    #define DDRSS_PHY_730_DATA 0x00000000
    #define DDRSS_PHY_731_DATA 0x00000000
    #define DDRSS_PHY_732_DATA 0x00000000
    #define DDRSS_PHY_733_DATA 0x00000000
    #define DDRSS_PHY_734_DATA 0x00000000
    #define DDRSS_PHY_735_DATA 0x00000000
    #define DDRSS_PHY_736_DATA 0x00000000
    #define DDRSS_PHY_737_DATA 0x00000000
    #define DDRSS_PHY_738_DATA 0x00000000
    #define DDRSS_PHY_739_DATA 0x00000000
    #define DDRSS_PHY_740_DATA 0x00000000
    #define DDRSS_PHY_741_DATA 0x00000000
    #define DDRSS_PHY_742_DATA 0x00000000
    #define DDRSS_PHY_743_DATA 0x00000000
    #define DDRSS_PHY_744_DATA 0x00000000
    #define DDRSS_PHY_745_DATA 0x00000000
    #define DDRSS_PHY_746_DATA 0x00000000
    #define DDRSS_PHY_747_DATA 0x00000000
    #define DDRSS_PHY_748_DATA 0x00000000
    #define DDRSS_PHY_749_DATA 0x00000000
    #define DDRSS_PHY_750_DATA 0x00000000
    #define DDRSS_PHY_751_DATA 0x00000000
    #define DDRSS_PHY_752_DATA 0x00000000
    #define DDRSS_PHY_753_DATA 0x00000000
    #define DDRSS_PHY_754_DATA 0x00000000
    #define DDRSS_PHY_755_DATA 0x00000000
    #define DDRSS_PHY_756_DATA 0x00000000
    #define DDRSS_PHY_757_DATA 0x00000000
    #define DDRSS_PHY_758_DATA 0x00000000
    #define DDRSS_PHY_759_DATA 0x00000000
    #define DDRSS_PHY_760_DATA 0x00000000
    #define DDRSS_PHY_761_DATA 0x00000000
    #define DDRSS_PHY_762_DATA 0x00000000
    #define DDRSS_PHY_763_DATA 0x00000000
    #define DDRSS_PHY_764_DATA 0x00000000
    #define DDRSS_PHY_765_DATA 0x00000000
    #define DDRSS_PHY_766_DATA 0x00000000
    #define DDRSS_PHY_767_DATA 0x00000000
    #define DDRSS_PHY_768_DATA 0x00000100
    #define DDRSS_PHY_769_DATA 0x00000000
    #define DDRSS_PHY_770_DATA 0x00000000
    #define DDRSS_PHY_771_DATA 0x00000000
    #define DDRSS_PHY_772_DATA 0x00000000
    #define DDRSS_PHY_773_DATA 0x00000100
    #define DDRSS_PHY_774_DATA 0x00000000
    #define DDRSS_PHY_775_DATA 0x00000000
    #define DDRSS_PHY_776_DATA 0x00000000
    #define DDRSS_PHY_777_DATA 0x00000000
    #define DDRSS_PHY_778_DATA 0x00000000
    #define DDRSS_PHY_779_DATA 0x00000000
    #define DDRSS_PHY_780_DATA 0x00000000
    #define DDRSS_PHY_781_DATA 0x00DCBA98
    #define DDRSS_PHY_782_DATA 0x00000000
    #define DDRSS_PHY_783_DATA 0x00000000
    #define DDRSS_PHY_784_DATA 0x00000000
    #define DDRSS_PHY_785_DATA 0x00000000
    #define DDRSS_PHY_786_DATA 0x00000000
    #define DDRSS_PHY_787_DATA 0x00000000
    #define DDRSS_PHY_788_DATA 0x00000000
    #define DDRSS_PHY_789_DATA 0x00000000
    #define DDRSS_PHY_790_DATA 0x00000000
    #define DDRSS_PHY_791_DATA 0x00000000
    #define DDRSS_PHY_792_DATA 0x00000000
    #define DDRSS_PHY_793_DATA 0x00000000
    #define DDRSS_PHY_794_DATA 0x00000000
    #define DDRSS_PHY_795_DATA 0x00000000
    #define DDRSS_PHY_796_DATA 0x16A4A0E6
    #define DDRSS_PHY_797_DATA 0x103F0000
    #define DDRSS_PHY_798_DATA 0x000F0000
    #define DDRSS_PHY_799_DATA 0x0000000F
    #define DDRSS_PHY_800_DATA 0x000002BB
    #define DDRSS_PHY_801_DATA 0x00030000
    #define DDRSS_PHY_802_DATA 0x00000300
    #define DDRSS_PHY_803_DATA 0x00000300
    #define DDRSS_PHY_804_DATA 0x00000300
    #define DDRSS_PHY_805_DATA 0x00000300
    #define DDRSS_PHY_806_DATA 0x00000300
    #define DDRSS_PHY_807_DATA 0x42080010
    #define DDRSS_PHY_808_DATA 0x0000003E
    #define DDRSS_PHY_809_DATA 0x00000000
    #define DDRSS_PHY_810_DATA 0x00000000
    #define DDRSS_PHY_811_DATA 0x00000000
    #define DDRSS_PHY_812_DATA 0x00000000
    #define DDRSS_PHY_813_DATA 0x00000000
    #define DDRSS_PHY_814_DATA 0x00000000
    #define DDRSS_PHY_815_DATA 0x00000000
    #define DDRSS_PHY_816_DATA 0x00000000
    #define DDRSS_PHY_817_DATA 0x00000000
    #define DDRSS_PHY_818_DATA 0x00000000
    #define DDRSS_PHY_819_DATA 0x00000000
    #define DDRSS_PHY_820_DATA 0x00000000
    #define DDRSS_PHY_821_DATA 0x00000000
    #define DDRSS_PHY_822_DATA 0x00000000
    #define DDRSS_PHY_823_DATA 0x00000000
    #define DDRSS_PHY_824_DATA 0x00000000
    #define DDRSS_PHY_825_DATA 0x00000000
    #define DDRSS_PHY_826_DATA 0x00000000
    #define DDRSS_PHY_827_DATA 0x00000000
    #define DDRSS_PHY_828_DATA 0x00000000
    #define DDRSS_PHY_829_DATA 0x00000000
    #define DDRSS_PHY_830_DATA 0x00000000
    #define DDRSS_PHY_831_DATA 0x00000000
    #define DDRSS_PHY_832_DATA 0x00000000
    #define DDRSS_PHY_833_DATA 0x00000000
    #define DDRSS_PHY_834_DATA 0x00000000
    #define DDRSS_PHY_835_DATA 0x00000000
    #define DDRSS_PHY_836_DATA 0x00000000
    #define DDRSS_PHY_837_DATA 0x00000000
    #define DDRSS_PHY_838_DATA 0x00000000
    #define DDRSS_PHY_839_DATA 0x00000000
    #define DDRSS_PHY_840_DATA 0x00000000
    #define DDRSS_PHY_841_DATA 0x00000000
    #define DDRSS_PHY_842_DATA 0x00000000
    #define DDRSS_PHY_843_DATA 0x00000000
    #define DDRSS_PHY_844_DATA 0x00000000
    #define DDRSS_PHY_845_DATA 0x00000000
    #define DDRSS_PHY_846_DATA 0x00000000
    #define DDRSS_PHY_847_DATA 0x00000000
    #define DDRSS_PHY_848_DATA 0x00000000
    #define DDRSS_PHY_849_DATA 0x00000000
    #define DDRSS_PHY_850_DATA 0x00000000
    #define DDRSS_PHY_851_DATA 0x00000000
    #define DDRSS_PHY_852_DATA 0x00000000
    #define DDRSS_PHY_853_DATA 0x00000000
    #define DDRSS_PHY_854_DATA 0x00000000
    #define DDRSS_PHY_855_DATA 0x00000000
    #define DDRSS_PHY_856_DATA 0x00000000
    #define DDRSS_PHY_857_DATA 0x00000000
    #define DDRSS_PHY_858_DATA 0x00000000
    #define DDRSS_PHY_859_DATA 0x00000000
    #define DDRSS_PHY_860_DATA 0x00000000
    #define DDRSS_PHY_861_DATA 0x00000000
    #define DDRSS_PHY_862_DATA 0x00000000
    #define DDRSS_PHY_863_DATA 0x00000000
    #define DDRSS_PHY_864_DATA 0x00000000
    #define DDRSS_PHY_865_DATA 0x00000000
    #define DDRSS_PHY_866_DATA 0x00000000
    #define DDRSS_PHY_867_DATA 0x00000000
    #define DDRSS_PHY_868_DATA 0x00000000
    #define DDRSS_PHY_869_DATA 0x00000000
    #define DDRSS_PHY_870_DATA 0x00000000
    #define DDRSS_PHY_871_DATA 0x00000000
    #define DDRSS_PHY_872_DATA 0x00000000
    #define DDRSS_PHY_873_DATA 0x00000000
    #define DDRSS_PHY_874_DATA 0x00000000
    #define DDRSS_PHY_875_DATA 0x00000000
    #define DDRSS_PHY_876_DATA 0x00000000
    #define DDRSS_PHY_877_DATA 0x00000000
    #define DDRSS_PHY_878_DATA 0x00000000
    #define DDRSS_PHY_879_DATA 0x00000000
    #define DDRSS_PHY_880_DATA 0x00000000
    #define DDRSS_PHY_881_DATA 0x00000000
    #define DDRSS_PHY_882_DATA 0x00000000
    #define DDRSS_PHY_883_DATA 0x00000000
    #define DDRSS_PHY_884_DATA 0x00000000
    #define DDRSS_PHY_885_DATA 0x00000000
    #define DDRSS_PHY_886_DATA 0x00000000
    #define DDRSS_PHY_887_DATA 0x00000000
    #define DDRSS_PHY_888_DATA 0x00000000
    #define DDRSS_PHY_889_DATA 0x00000000
    #define DDRSS_PHY_890_DATA 0x00000000
    #define DDRSS_PHY_891_DATA 0x00000000
    #define DDRSS_PHY_892_DATA 0x00000000
    #define DDRSS_PHY_893_DATA 0x00000000
    #define DDRSS_PHY_894_DATA 0x00000000
    #define DDRSS_PHY_895_DATA 0x00000000
    #define DDRSS_PHY_896_DATA 0x00000000
    #define DDRSS_PHY_897_DATA 0x00000000
    #define DDRSS_PHY_898_DATA 0x00000000
    #define DDRSS_PHY_899_DATA 0x00000000
    #define DDRSS_PHY_900_DATA 0x00000000
    #define DDRSS_PHY_901_DATA 0x00000000
    #define DDRSS_PHY_902_DATA 0x00000000
    #define DDRSS_PHY_903_DATA 0x00000000
    #define DDRSS_PHY_904_DATA 0x00000000
    #define DDRSS_PHY_905_DATA 0x00000000
    #define DDRSS_PHY_906_DATA 0x00000000
    #define DDRSS_PHY_907_DATA 0x00000000
    #define DDRSS_PHY_908_DATA 0x00000000
    #define DDRSS_PHY_909_DATA 0x00000000
    #define DDRSS_PHY_910_DATA 0x00000000
    #define DDRSS_PHY_911_DATA 0x00000000
    #define DDRSS_PHY_912_DATA 0x00000000
    #define DDRSS_PHY_913_DATA 0x00000000
    #define DDRSS_PHY_914_DATA 0x00000000
    #define DDRSS_PHY_915_DATA 0x00000000
    #define DDRSS_PHY_916_DATA 0x00000000
    #define DDRSS_PHY_917_DATA 0x00000000
    #define DDRSS_PHY_918_DATA 0x00000000
    #define DDRSS_PHY_919_DATA 0x00000000
    #define DDRSS_PHY_920_DATA 0x00000000
    #define DDRSS_PHY_921_DATA 0x00000000
    #define DDRSS_PHY_922_DATA 0x00000000
    #define DDRSS_PHY_923_DATA 0x00000000
    #define DDRSS_PHY_924_DATA 0x00000000
    #define DDRSS_PHY_925_DATA 0x00000000
    #define DDRSS_PHY_926_DATA 0x00000000
    #define DDRSS_PHY_927_DATA 0x00000000
    #define DDRSS_PHY_928_DATA 0x00000000
    #define DDRSS_PHY_929_DATA 0x00000000
    #define DDRSS_PHY_930_DATA 0x00000000
    #define DDRSS_PHY_931_DATA 0x00000000
    #define DDRSS_PHY_932_DATA 0x00000000
    #define DDRSS_PHY_933_DATA 0x00000000
    #define DDRSS_PHY_934_DATA 0x00000000
    #define DDRSS_PHY_935_DATA 0x00000000
    #define DDRSS_PHY_936_DATA 0x00000000
    #define DDRSS_PHY_937_DATA 0x00000000
    #define DDRSS_PHY_938_DATA 0x00000000
    #define DDRSS_PHY_939_DATA 0x00000000
    #define DDRSS_PHY_940_DATA 0x00000000
    #define DDRSS_PHY_941_DATA 0x00000000
    #define DDRSS_PHY_942_DATA 0x00000000
    #define DDRSS_PHY_943_DATA 0x00000000
    #define DDRSS_PHY_944_DATA 0x00000000
    #define DDRSS_PHY_945_DATA 0x00000000
    #define DDRSS_PHY_946_DATA 0x00000000
    #define DDRSS_PHY_947_DATA 0x00000000
    #define DDRSS_PHY_948_DATA 0x00000000
    #define DDRSS_PHY_949_DATA 0x00000000
    #define DDRSS_PHY_950_DATA 0x00000000
    #define DDRSS_PHY_951_DATA 0x00000000
    #define DDRSS_PHY_952_DATA 0x00000000
    #define DDRSS_PHY_953_DATA 0x00000000
    #define DDRSS_PHY_954_DATA 0x00000000
    #define DDRSS_PHY_955_DATA 0x00000000
    #define DDRSS_PHY_956_DATA 0x00000000
    #define DDRSS_PHY_957_DATA 0x00000000
    #define DDRSS_PHY_958_DATA 0x00000000
    #define DDRSS_PHY_959_DATA 0x00000000
    #define DDRSS_PHY_960_DATA 0x00000000
    #define DDRSS_PHY_961_DATA 0x00000000
    #define DDRSS_PHY_962_DATA 0x00000000
    #define DDRSS_PHY_963_DATA 0x00000000
    #define DDRSS_PHY_964_DATA 0x00000000
    #define DDRSS_PHY_965_DATA 0x00000000
    #define DDRSS_PHY_966_DATA 0x00000000
    #define DDRSS_PHY_967_DATA 0x00000000
    #define DDRSS_PHY_968_DATA 0x00000000
    #define DDRSS_PHY_969_DATA 0x00000000
    #define DDRSS_PHY_970_DATA 0x00000000
    #define DDRSS_PHY_971_DATA 0x00000000
    #define DDRSS_PHY_972_DATA 0x00000000
    #define DDRSS_PHY_973_DATA 0x00000000
    #define DDRSS_PHY_974_DATA 0x00000000
    #define DDRSS_PHY_975_DATA 0x00000000
    #define DDRSS_PHY_976_DATA 0x00000000
    #define DDRSS_PHY_977_DATA 0x00000000
    #define DDRSS_PHY_978_DATA 0x00000000
    #define DDRSS_PHY_979_DATA 0x00000000
    #define DDRSS_PHY_980_DATA 0x00000000
    #define DDRSS_PHY_981_DATA 0x00000000
    #define DDRSS_PHY_982_DATA 0x00000000
    #define DDRSS_PHY_983_DATA 0x00000000
    #define DDRSS_PHY_984_DATA 0x00000000
    #define DDRSS_PHY_985_DATA 0x00000000
    #define DDRSS_PHY_986_DATA 0x00000000
    #define DDRSS_PHY_987_DATA 0x00000000
    #define DDRSS_PHY_988_DATA 0x00000000
    #define DDRSS_PHY_989_DATA 0x00000000
    #define DDRSS_PHY_990_DATA 0x00000000
    #define DDRSS_PHY_991_DATA 0x00000000
    #define DDRSS_PHY_992_DATA 0x00000000
    #define DDRSS_PHY_993_DATA 0x00000000
    #define DDRSS_PHY_994_DATA 0x00000000
    #define DDRSS_PHY_995_DATA 0x00000000
    #define DDRSS_PHY_996_DATA 0x00000000
    #define DDRSS_PHY_997_DATA 0x00000000
    #define DDRSS_PHY_998_DATA 0x00000000
    #define DDRSS_PHY_999_DATA 0x00000000
    #define DDRSS_PHY_1000_DATA 0x00000000
    #define DDRSS_PHY_1001_DATA 0x00000000
    #define DDRSS_PHY_1002_DATA 0x00000000
    #define DDRSS_PHY_1003_DATA 0x00000000
    #define DDRSS_PHY_1004_DATA 0x00000000
    #define DDRSS_PHY_1005_DATA 0x00000000
    #define DDRSS_PHY_1006_DATA 0x00000000
    #define DDRSS_PHY_1007_DATA 0x00000000
    #define DDRSS_PHY_1008_DATA 0x00000000
    #define DDRSS_PHY_1009_DATA 0x00000000
    #define DDRSS_PHY_1010_DATA 0x00000000
    #define DDRSS_PHY_1011_DATA 0x00000000
    #define DDRSS_PHY_1012_DATA 0x00000000
    #define DDRSS_PHY_1013_DATA 0x00000000
    #define DDRSS_PHY_1014_DATA 0x00000000
    #define DDRSS_PHY_1015_DATA 0x00000000
    #define DDRSS_PHY_1016_DATA 0x00000000
    #define DDRSS_PHY_1017_DATA 0x00000000
    #define DDRSS_PHY_1018_DATA 0x00000000
    #define DDRSS_PHY_1019_DATA 0x00000000
    #define DDRSS_PHY_1020_DATA 0x00000000
    #define DDRSS_PHY_1021_DATA 0x00000000
    #define DDRSS_PHY_1022_DATA 0x00000000
    #define DDRSS_PHY_1023_DATA 0x00000000
    #define DDRSS_PHY_1024_DATA 0x00000100
    #define DDRSS_PHY_1025_DATA 0x00000000
    #define DDRSS_PHY_1026_DATA 0x00000000
    #define DDRSS_PHY_1027_DATA 0x00000000
    #define DDRSS_PHY_1028_DATA 0x00000000
    #define DDRSS_PHY_1029_DATA 0x00000100
    #define DDRSS_PHY_1030_DATA 0x00000000
    #define DDRSS_PHY_1031_DATA 0x00000000
    #define DDRSS_PHY_1032_DATA 0x00000000
    #define DDRSS_PHY_1033_DATA 0x00000000
    #define DDRSS_PHY_1034_DATA 0x00000000
    #define DDRSS_PHY_1035_DATA 0x00000000
    #define DDRSS_PHY_1036_DATA 0x00000000
    #define DDRSS_PHY_1037_DATA 0x00DCBA98
    #define DDRSS_PHY_1038_DATA 0x00000000
    #define DDRSS_PHY_1039_DATA 0x00000000
    #define DDRSS_PHY_1040_DATA 0x00000000
    #define DDRSS_PHY_1041_DATA 0x00000000
    #define DDRSS_PHY_1042_DATA 0x00000000
    #define DDRSS_PHY_1043_DATA 0x00000000
    #define DDRSS_PHY_1044_DATA 0x00000000
    #define DDRSS_PHY_1045_DATA 0x00000000
    #define DDRSS_PHY_1046_DATA 0x00000000
    #define DDRSS_PHY_1047_DATA 0x00000000
    #define DDRSS_PHY_1048_DATA 0x00000000
    #define DDRSS_PHY_1049_DATA 0x00000000
    #define DDRSS_PHY_1050_DATA 0x00000000
    #define DDRSS_PHY_1051_DATA 0x00000000
    #define DDRSS_PHY_1052_DATA 0x2307B9AC
    #define DDRSS_PHY_1053_DATA 0x10030000
    #define DDRSS_PHY_1054_DATA 0x000F0000
    #define DDRSS_PHY_1055_DATA 0x0000000F
    #define DDRSS_PHY_1056_DATA 0x000002BB
    #define DDRSS_PHY_1057_DATA 0x00030000
    #define DDRSS_PHY_1058_DATA 0x00000300
    #define DDRSS_PHY_1059_DATA 0x00000300
    #define DDRSS_PHY_1060_DATA 0x00000300
    #define DDRSS_PHY_1061_DATA 0x00000300
    #define DDRSS_PHY_1062_DATA 0x00000300
    #define DDRSS_PHY_1063_DATA 0x42080010
    #define DDRSS_PHY_1064_DATA 0x0000003E
    #define DDRSS_PHY_1065_DATA 0x00000000
    #define DDRSS_PHY_1066_DATA 0x00000000
    #define DDRSS_PHY_1067_DATA 0x00000000
    #define DDRSS_PHY_1068_DATA 0x00000000
    #define DDRSS_PHY_1069_DATA 0x00000000
    #define DDRSS_PHY_1070_DATA 0x00000000
    #define DDRSS_PHY_1071_DATA 0x00000000
    #define DDRSS_PHY_1072_DATA 0x00000000
    #define DDRSS_PHY_1073_DATA 0x00000000
    #define DDRSS_PHY_1074_DATA 0x00000000
    #define DDRSS_PHY_1075_DATA 0x00000000
    #define DDRSS_PHY_1076_DATA 0x00000000
    #define DDRSS_PHY_1077_DATA 0x00000000
    #define DDRSS_PHY_1078_DATA 0x00000000
    #define DDRSS_PHY_1079_DATA 0x00000000
    #define DDRSS_PHY_1080_DATA 0x00000000
    #define DDRSS_PHY_1081_DATA 0x00000000
    #define DDRSS_PHY_1082_DATA 0x00000000
    #define DDRSS_PHY_1083_DATA 0x00000000
    #define DDRSS_PHY_1084_DATA 0x00000000
    #define DDRSS_PHY_1085_DATA 0x00000000
    #define DDRSS_PHY_1086_DATA 0x00000000
    #define DDRSS_PHY_1087_DATA 0x00000000
    #define DDRSS_PHY_1088_DATA 0x00000000
    #define DDRSS_PHY_1089_DATA 0x00000000
    #define DDRSS_PHY_1090_DATA 0x00000000
    #define DDRSS_PHY_1091_DATA 0x00000000
    #define DDRSS_PHY_1092_DATA 0x00000000
    #define DDRSS_PHY_1093_DATA 0x00000000
    #define DDRSS_PHY_1094_DATA 0x00000000
    #define DDRSS_PHY_1095_DATA 0x00000000
    #define DDRSS_PHY_1096_DATA 0x00000000
    #define DDRSS_PHY_1097_DATA 0x00000000
    #define DDRSS_PHY_1098_DATA 0x00000000
    #define DDRSS_PHY_1099_DATA 0x00000000
    #define DDRSS_PHY_1100_DATA 0x00000000
    #define DDRSS_PHY_1101_DATA 0x00000000
    #define DDRSS_PHY_1102_DATA 0x00000000
    #define DDRSS_PHY_1103_DATA 0x00000000
    #define DDRSS_PHY_1104_DATA 0x00000000
    #define DDRSS_PHY_1105_DATA 0x00000000
    #define DDRSS_PHY_1106_DATA 0x00000000
    #define DDRSS_PHY_1107_DATA 0x00000000
    #define DDRSS_PHY_1108_DATA 0x00000000
    #define DDRSS_PHY_1109_DATA 0x00000000
    #define DDRSS_PHY_1110_DATA 0x00000000
    #define DDRSS_PHY_1111_DATA 0x00000000
    #define DDRSS_PHY_1112_DATA 0x00000000
    #define DDRSS_PHY_1113_DATA 0x00000000
    #define DDRSS_PHY_1114_DATA 0x00000000
    #define DDRSS_PHY_1115_DATA 0x00000000
    #define DDRSS_PHY_1116_DATA 0x00000000
    #define DDRSS_PHY_1117_DATA 0x00000000
    #define DDRSS_PHY_1118_DATA 0x00000000
    #define DDRSS_PHY_1119_DATA 0x00000000
    #define DDRSS_PHY_1120_DATA 0x00000000
    #define DDRSS_PHY_1121_DATA 0x00000000
    #define DDRSS_PHY_1122_DATA 0x00000000
    #define DDRSS_PHY_1123_DATA 0x00000000
    #define DDRSS_PHY_1124_DATA 0x00000000
    #define DDRSS_PHY_1125_DATA 0x00000000
    #define DDRSS_PHY_1126_DATA 0x00000000
    #define DDRSS_PHY_1127_DATA 0x00000000
    #define DDRSS_PHY_1128_DATA 0x00000000
    #define DDRSS_PHY_1129_DATA 0x00000000
    #define DDRSS_PHY_1130_DATA 0x00000000
    #define DDRSS_PHY_1131_DATA 0x00000000
    #define DDRSS_PHY_1132_DATA 0x00000000
    #define DDRSS_PHY_1133_DATA 0x00000000
    #define DDRSS_PHY_1134_DATA 0x00000000
    #define DDRSS_PHY_1135_DATA 0x00000000
    #define DDRSS_PHY_1136_DATA 0x00000000
    #define DDRSS_PHY_1137_DATA 0x00000000
    #define DDRSS_PHY_1138_DATA 0x00000000
    #define DDRSS_PHY_1139_DATA 0x00000000
    #define DDRSS_PHY_1140_DATA 0x00000000
    #define DDRSS_PHY_1141_DATA 0x00000000
    #define DDRSS_PHY_1142_DATA 0x00000000
    #define DDRSS_PHY_1143_DATA 0x00000000
    #define DDRSS_PHY_1144_DATA 0x00000000
    #define DDRSS_PHY_1145_DATA 0x00000000
    #define DDRSS_PHY_1146_DATA 0x00000000
    #define DDRSS_PHY_1147_DATA 0x00000000
    #define DDRSS_PHY_1148_DATA 0x00000000
    #define DDRSS_PHY_1149_DATA 0x00000000
    #define DDRSS_PHY_1150_DATA 0x00000000
    #define DDRSS_PHY_1151_DATA 0x00000000
    #define DDRSS_PHY_1152_DATA 0x00000000
    #define DDRSS_PHY_1153_DATA 0x00000000
    #define DDRSS_PHY_1154_DATA 0x00000000
    #define DDRSS_PHY_1155_DATA 0x00000000
    #define DDRSS_PHY_1156_DATA 0x00000000
    #define DDRSS_PHY_1157_DATA 0x00000000
    #define DDRSS_PHY_1158_DATA 0x00000000
    #define DDRSS_PHY_1159_DATA 0x00000000
    #define DDRSS_PHY_1160_DATA 0x00000000
    #define DDRSS_PHY_1161_DATA 0x00000000
    #define DDRSS_PHY_1162_DATA 0x00000000
    #define DDRSS_PHY_1163_DATA 0x00000000
    #define DDRSS_PHY_1164_DATA 0x00000000
    #define DDRSS_PHY_1165_DATA 0x00000000
    #define DDRSS_PHY_1166_DATA 0x00000000
    #define DDRSS_PHY_1167_DATA 0x00000000
    #define DDRSS_PHY_1168_DATA 0x00000000
    #define DDRSS_PHY_1169_DATA 0x00000000
    #define DDRSS_PHY_1170_DATA 0x00000000
    #define DDRSS_PHY_1171_DATA 0x00000000
    #define DDRSS_PHY_1172_DATA 0x00000000
    #define DDRSS_PHY_1173_DATA 0x00000000
    #define DDRSS_PHY_1174_DATA 0x00000000
    #define DDRSS_PHY_1175_DATA 0x00000000
    #define DDRSS_PHY_1176_DATA 0x00000000
    #define DDRSS_PHY_1177_DATA 0x00000000
    #define DDRSS_PHY_1178_DATA 0x00000000
    #define DDRSS_PHY_1179_DATA 0x00000000
    #define DDRSS_PHY_1180_DATA 0x00000000
    #define DDRSS_PHY_1181_DATA 0x00000000
    #define DDRSS_PHY_1182_DATA 0x00000000
    #define DDRSS_PHY_1183_DATA 0x00000000
    #define DDRSS_PHY_1184_DATA 0x00000000
    #define DDRSS_PHY_1185_DATA 0x00000000
    #define DDRSS_PHY_1186_DATA 0x00000000
    #define DDRSS_PHY_1187_DATA 0x00000000
    #define DDRSS_PHY_1188_DATA 0x00000000
    #define DDRSS_PHY_1189_DATA 0x00000000
    #define DDRSS_PHY_1190_DATA 0x00000000
    #define DDRSS_PHY_1191_DATA 0x00000000
    #define DDRSS_PHY_1192_DATA 0x00000000
    #define DDRSS_PHY_1193_DATA 0x00000000
    #define DDRSS_PHY_1194_DATA 0x00000000
    #define DDRSS_PHY_1195_DATA 0x00000000
    #define DDRSS_PHY_1196_DATA 0x00000000
    #define DDRSS_PHY_1197_DATA 0x00000000
    #define DDRSS_PHY_1198_DATA 0x00000000
    #define DDRSS_PHY_1199_DATA 0x00000000
    #define DDRSS_PHY_1200_DATA 0x00000000
    #define DDRSS_PHY_1201_DATA 0x00000000
    #define DDRSS_PHY_1202_DATA 0x00000000
    #define DDRSS_PHY_1203_DATA 0x00000000
    #define DDRSS_PHY_1204_DATA 0x00000000
    #define DDRSS_PHY_1205_DATA 0x00000000
    #define DDRSS_PHY_1206_DATA 0x00000000
    #define DDRSS_PHY_1207_DATA 0x00000000
    #define DDRSS_PHY_1208_DATA 0x00000000
    #define DDRSS_PHY_1209_DATA 0x00000000
    #define DDRSS_PHY_1210_DATA 0x00000000
    #define DDRSS_PHY_1211_DATA 0x00000000
    #define DDRSS_PHY_1212_DATA 0x00000000
    #define DDRSS_PHY_1213_DATA 0x00000000
    #define DDRSS_PHY_1214_DATA 0x00000000
    #define DDRSS_PHY_1215_DATA 0x00000000
    #define DDRSS_PHY_1216_DATA 0x00000000
    #define DDRSS_PHY_1217_DATA 0x00000000
    #define DDRSS_PHY_1218_DATA 0x00000000
    #define DDRSS_PHY_1219_DATA 0x00000000
    #define DDRSS_PHY_1220_DATA 0x00000000
    #define DDRSS_PHY_1221_DATA 0x00000000
    #define DDRSS_PHY_1222_DATA 0x00000000
    #define DDRSS_PHY_1223_DATA 0x00000000
    #define DDRSS_PHY_1224_DATA 0x00000000
    #define DDRSS_PHY_1225_DATA 0x00000000
    #define DDRSS_PHY_1226_DATA 0x00000000
    #define DDRSS_PHY_1227_DATA 0x00000000
    #define DDRSS_PHY_1228_DATA 0x00000000
    #define DDRSS_PHY_1229_DATA 0x00000000
    #define DDRSS_PHY_1230_DATA 0x00000000
    #define DDRSS_PHY_1231_DATA 0x00000000
    #define DDRSS_PHY_1232_DATA 0x00000000
    #define DDRSS_PHY_1233_DATA 0x00000000
    #define DDRSS_PHY_1234_DATA 0x00000000
    #define DDRSS_PHY_1235_DATA 0x00000000
    #define DDRSS_PHY_1236_DATA 0x00000000
    #define DDRSS_PHY_1237_DATA 0x00000000
    #define DDRSS_PHY_1238_DATA 0x00000000
    #define DDRSS_PHY_1239_DATA 0x00000000
    #define DDRSS_PHY_1240_DATA 0x00000000
    #define DDRSS_PHY_1241_DATA 0x00000000
    #define DDRSS_PHY_1242_DATA 0x00000000
    #define DDRSS_PHY_1243_DATA 0x00000000
    #define DDRSS_PHY_1244_DATA 0x00000000
    #define DDRSS_PHY_1245_DATA 0x00000000
    #define DDRSS_PHY_1246_DATA 0x00000000
    #define DDRSS_PHY_1247_DATA 0x00000000
    #define DDRSS_PHY_1248_DATA 0x00000000
    #define DDRSS_PHY_1249_DATA 0x00000000
    #define DDRSS_PHY_1250_DATA 0x00000000
    #define DDRSS_PHY_1251_DATA 0x00000000
    #define DDRSS_PHY_1252_DATA 0x00000000
    #define DDRSS_PHY_1253_DATA 0x00000000
    #define DDRSS_PHY_1254_DATA 0x00000000
    #define DDRSS_PHY_1255_DATA 0x00000000
    #define DDRSS_PHY_1256_DATA 0x00000000
    #define DDRSS_PHY_1257_DATA 0x00000000
    #define DDRSS_PHY_1258_DATA 0x00000000
    #define DDRSS_PHY_1259_DATA 0x00000000
    #define DDRSS_PHY_1260_DATA 0x00000000
    #define DDRSS_PHY_1261_DATA 0x00000000
    #define DDRSS_PHY_1262_DATA 0x00000000
    #define DDRSS_PHY_1263_DATA 0x00000000
    #define DDRSS_PHY_1264_DATA 0x00000000
    #define DDRSS_PHY_1265_DATA 0x00000000
    #define DDRSS_PHY_1266_DATA 0x00000000
    #define DDRSS_PHY_1267_DATA 0x00000000
    #define DDRSS_PHY_1268_DATA 0x00000000
    #define DDRSS_PHY_1269_DATA 0x00000000
    #define DDRSS_PHY_1270_DATA 0x00000000
    #define DDRSS_PHY_1271_DATA 0x00000000
    #define DDRSS_PHY_1272_DATA 0x00000000
    #define DDRSS_PHY_1273_DATA 0x00000000
    #define DDRSS_PHY_1274_DATA 0x00000000
    #define DDRSS_PHY_1275_DATA 0x00000000
    #define DDRSS_PHY_1276_DATA 0x00000000
    #define DDRSS_PHY_1277_DATA 0x00000000
    #define DDRSS_PHY_1278_DATA 0x00000000
    #define DDRSS_PHY_1279_DATA 0x00000000
    #define DDRSS_PHY_1280_DATA 0x00000000
    #define DDRSS_PHY_1281_DATA 0x00000100
    #define DDRSS_PHY_1282_DATA 0x00000000
    #define DDRSS_PHY_1283_DATA 0x00000000
    #define DDRSS_PHY_1284_DATA 0x00000000
    #define DDRSS_PHY_1285_DATA 0x00000000
    #define DDRSS_PHY_1286_DATA 0x00050000
    #define DDRSS_PHY_1287_DATA 0x04000100
    #define DDRSS_PHY_1288_DATA 0x00000055
    #define DDRSS_PHY_1289_DATA 0x00000000
    #define DDRSS_PHY_1290_DATA 0x00000000
    #define DDRSS_PHY_1291_DATA 0x00000000
    #define DDRSS_PHY_1292_DATA 0x00000000
    #define DDRSS_PHY_1293_DATA 0x01002000
    #define DDRSS_PHY_1294_DATA 0x00004001
    #define DDRSS_PHY_1295_DATA 0x00020028
    #define DDRSS_PHY_1296_DATA 0x00010100
    #define DDRSS_PHY_1297_DATA 0x00000001
    #define DDRSS_PHY_1298_DATA 0x00000000
    #define DDRSS_PHY_1299_DATA 0x0F0F0E06
    #define DDRSS_PHY_1300_DATA 0x00010101
    #define DDRSS_PHY_1301_DATA 0x010F0004
    #define DDRSS_PHY_1302_DATA 0x00000000
    #define DDRSS_PHY_1303_DATA 0x00000000
    #define DDRSS_PHY_1304_DATA 0x00000064
    #define DDRSS_PHY_1305_DATA 0x00000000
    #define DDRSS_PHY_1306_DATA 0x00000000
    #define DDRSS_PHY_1307_DATA 0x01020103
    #define DDRSS_PHY_1308_DATA 0x0F020102
    #define DDRSS_PHY_1309_DATA 0x03030303
    #define DDRSS_PHY_1310_DATA 0x03030303
    #define DDRSS_PHY_1311_DATA 0x00040000
    #define DDRSS_PHY_1312_DATA 0x00005201
    #define DDRSS_PHY_1313_DATA 0x00000000
    #define DDRSS_PHY_1314_DATA 0x00000000
    #define DDRSS_PHY_1315_DATA 0x00000000
    #define DDRSS_PHY_1316_DATA 0x00000000
    #define DDRSS_PHY_1317_DATA 0x00000000
    #define DDRSS_PHY_1318_DATA 0x00000000
    #define DDRSS_PHY_1319_DATA 0x07070001
    #define DDRSS_PHY_1320_DATA 0x00005400
    #define DDRSS_PHY_1321_DATA 0x000040A2
    #define DDRSS_PHY_1322_DATA 0x00024410
    #define DDRSS_PHY_1323_DATA 0x00004410
    #define DDRSS_PHY_1324_DATA 0x00004410
    #define DDRSS_PHY_1325_DATA 0x00004410
    #define DDRSS_PHY_1326_DATA 0x00004410
    #define DDRSS_PHY_1327_DATA 0x00004410
    #define DDRSS_PHY_1328_DATA 0x00004410
    #define DDRSS_PHY_1329_DATA 0x00004410
    #define DDRSS_PHY_1330_DATA 0x00004410
    #define DDRSS_PHY_1331_DATA 0x00004410
    #define DDRSS_PHY_1332_DATA 0x00000000
    #define DDRSS_PHY_1333_DATA 0x00000046
    #define DDRSS_PHY_1334_DATA 0x00000400
    #define DDRSS_PHY_1335_DATA 0x00000008
    #define DDRSS_PHY_1336_DATA 0x00000000
    #define DDRSS_PHY_1337_DATA 0x00000000
    #define DDRSS_PHY_1338_DATA 0x00000000
    #define DDRSS_PHY_1339_DATA 0x00000000
    #define DDRSS_PHY_1340_DATA 0x00000000
    #define DDRSS_PHY_1341_DATA 0x03000000
    #define DDRSS_PHY_1342_DATA 0x00000000
    #define DDRSS_PHY_1343_DATA 0x00000000
    #define DDRSS_PHY_1344_DATA 0x00000000
    #define DDRSS_PHY_1345_DATA 0x04102006
    #define DDRSS_PHY_1346_DATA 0x00041020
    #define DDRSS_PHY_1347_DATA 0x01C98C98
    #define DDRSS_PHY_1348_DATA 0x3F400000
    #define DDRSS_PHY_1349_DATA 0x3F3F1F3F
    #define DDRSS_PHY_1350_DATA 0x0000001F
    #define DDRSS_PHY_1351_DATA 0x00000000
    #define DDRSS_PHY_1352_DATA 0x00000000
    #define DDRSS_PHY_1353_DATA 0x00000000
    #define DDRSS_PHY_1354_DATA 0x00000001
    #define DDRSS_PHY_1355_DATA 0x00000000
    #define DDRSS_PHY_1356_DATA 0x00000000
    #define DDRSS_PHY_1357_DATA 0x00000000
    #define DDRSS_PHY_1358_DATA 0x00000000
    #define DDRSS_PHY_1359_DATA 0x76543210
    #define DDRSS_PHY_1360_DATA 0x00000098
    #define DDRSS_PHY_1361_DATA 0x00000000
    #define DDRSS_PHY_1362_DATA 0x00000000
    #define DDRSS_PHY_1363_DATA 0x00000000
    #define DDRSS_PHY_1364_DATA 0x00040700
    #define DDRSS_PHY_1365_DATA 0x00000000
    #define DDRSS_PHY_1366_DATA 0x00000000
    #define DDRSS_PHY_1367_DATA 0x00000000
    #define DDRSS_PHY_1368_DATA 0x00000002
    #define DDRSS_PHY_1369_DATA 0x00000100
    #define DDRSS_PHY_1370_DATA 0x00000000
    #define DDRSS_PHY_1371_DATA 0x0001F7C2
    #define DDRSS_PHY_1372_DATA 0x00000002
    #define DDRSS_PHY_1373_DATA 0x00000000
    #define DDRSS_PHY_1374_DATA 0x00001142
    #define DDRSS_PHY_1375_DATA 0x03020400
    #define DDRSS_PHY_1376_DATA 0x00000080
    #define DDRSS_PHY_1377_DATA 0x03900390
    #define DDRSS_PHY_1378_DATA 0x03900390
    #define DDRSS_PHY_1379_DATA 0x03900390
    #define DDRSS_PHY_1380_DATA 0x03900390
    #define DDRSS_PHY_1381_DATA 0x03900390
    #define DDRSS_PHY_1382_DATA 0x03900390
    #define DDRSS_PHY_1383_DATA 0x00000300
    #define DDRSS_PHY_1384_DATA 0x00000300
    #define DDRSS_PHY_1385_DATA 0x00000300
    #define DDRSS_PHY_1386_DATA 0x00000300
    #define DDRSS_PHY_1387_DATA 0x31823FB7
    #define DDRSS_PHY_1388_DATA 0x00000000
    #define DDRSS_PHY_1389_DATA 0x0C000D3F
    #define DDRSS_PHY_1390_DATA 0x30000D3F
    #define DDRSS_PHY_1391_DATA 0x300D3F11
    #define DDRSS_PHY_1392_DATA 0x01770000
    #define DDRSS_PHY_1393_DATA 0x000D3FBB
    #define DDRSS_PHY_1394_DATA 0x00000C11
    #define DDRSS_PHY_1395_DATA 0x300D3F11
    #define DDRSS_PHY_1396_DATA 0x01770000
    #define DDRSS_PHY_1397_DATA 0x300C3F11
    #define DDRSS_PHY_1398_DATA 0x01770000
    #define DDRSS_PHY_1399_DATA 0x300C3F11
    #define DDRSS_PHY_1400_DATA 0x01770000
    #define DDRSS_PHY_1401_DATA 0x300D3F11
    #define DDRSS_PHY_1402_DATA 0x01770000
    #define DDRSS_PHY_1403_DATA 0x300D3F11
    #define DDRSS_PHY_1404_DATA 0x01770000
    #define DDRSS_PHY_1405_DATA 0x20040004
    3. Here is the full boot log
    U-Boot SPL 2021.01-g78a217ca9e (Nov 02 2022 - 20:54:51 +0000)
    SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar')
    CONFIG_MTEST_R5 is enabled
    Testing DDR...
    Testing 0x80000000 ... 0x80000100:
    Number of iterations: 2
    Pattern: 0xff
    Iteration:      1Pattern 0x000000ff  Writing...            Reading...Iteration:      2Pattern 0xffffff00  Writing...            Reading...Tested 2 iteration(s) with 0 errors.
    Trying to boot from MMC1
    Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
    Loading Environment from MMC... OK
    init_env from device 9 not supported!
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.7(release):v2.7.0-359-g1309c6c805-dirty
    NOTICE:  BL31: Built : 11:40:36, Sep  8 2022
    U-Boot 2021.01-g78a217ca9e (Nov 02 2022 - 20:54:51 +0000)
    SoC:   AM62X SR1.0 GP
    Model: Texas Instruments K3 AM625 SoC
    EEPROM not available at 0x50, trying to read at 0x51
    Reading on-board EEPROM at 0x51 failed -19
    DRAM:  2 GiB
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Reading on-board EEPROM at 0x51 failed 1
    Net:   No ethernet found.
    Hit any key to stop autoboot:  2  1  0
    switch to partitions #0, OK
    mmc0(part 0) is current device
    SD/MMC found on device 0
    Failed to load 'boot.scr'
    ** Unrecognized filesystem type **
    18674176 bytes read in 137 ms (130 MiB/s)
    41521 bytes read in 2 ms (19.8 MiB/s)
       Loading Device Tree to 000000008fef2000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 5.10.145-g8b51d20b6e (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Fri Oct 28 12:41:58 UTC 2022
    [    0.000000] Machine model: Keysight P550 AM625-based
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
    [    0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 13 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009d900000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9d900000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 13 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@9da00000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009c7fffff]
    [    0.000000]   node   0: [mem 0x000000009c800000-0x000000009e6fffff]
    [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
    [    0.000000]   node   0: [mem 0x000000009e780000-0x000000009fffffff]
    [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000] cma: Reserved 512 MiB at 0x00000000dd000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=cc549980-34a4-4ce3-b5d6-c0771cd3affc rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 1456536K/2097152K available (11008K kernel code, 1148K rwdata, 4160K rodata, 1792K init, 432K bss, 116328K reserved, 524288K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000080030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000004] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008490] Console: colour dummy device 80x25
    [    0.013085] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023768] pid_max: default: 32768 minimum: 301
    [    0.028579] LSM: Security Framework initializing
    [    0.033369] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.040953] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.050772] rcu: Hierarchical SRCU implementation.
    [    0.055973] Platform MSI: msi-controller@1820000 domain created
    [    0.062231] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.071460] EFI services will not be available.
    [    0.076282] smp: Bringing up secondary CPUs ...
    [    0.081587] Detected VIPT I-cache on CPU1
    [    0.081626] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.081641] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
    [    0.081708] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.081836] smp: Brought up 1 node, 2 CPUs
    [    0.111224] SMP: Total of 2 processors activated.
    [    0.116037] CPU features: detected: 32-bit EL0 Support
    [    0.121310] CPU features: detected: CRC32 instructions
    [    0.134171] CPU: All CPU(s) started at EL2
    [    0.138379] alternatives: patching kernel code
    [    0.144054] devtmpfs: initialized
    [    0.152929] KASLR disabled due to lack of seed
    [    0.157700] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.167680] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.189992] pinctrl core: initialized pinctrl subsystem
    [    0.196091] DMI not present or invalid.
    [    0.200725] NET: Registered protocol family 16
    [    0.206861] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.214220] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.222298] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.230973] thermal_sys: Registered thermal governor 'step_wise'
    [    0.230979] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.237624] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.251329] ASID allocator initialised with 65536 entries
    [    0.273177] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.280058] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.286910] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.293761] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.301829] cryptd: max_cpu_qlen set to 1000
    [    0.309181] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
    [    0.318187] vcc_5v0: supplied by vmain_pd
    [    0.322793] vcc_3v3_sys: supplied by vmain_pd
    [    0.327703] vcc_1v8: supplied by vcc_3v3_sys
    [    0.333016] iommu: Default domain type: Translated
    [    0.338367] SCSI subsystem initialized
    [    0.342545] mc: Linux media interface: v0.10
    [    0.346932] videodev: Linux video capture interface: v2.00
    [    0.352613] pps_core: LinuxPPS API ver. 1 registered
    [    0.357688] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.367037] PTP clock support registered
    [    0.371077] EDAC MC: Ver: 3.0.0
    [    0.374947] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
    [    0.382085] FPGA manager framework
    [    0.385656] Advanced Linux Sound Architecture Driver Initialized.
    [    0.392807] clocksource: Switched to clocksource arch_sys_counter
    [    0.399274] VFS: Disk quotas dquot_6.6.0
    [    0.403340] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.415794] NET: Registered protocol family 2
    [    0.420603] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.429427] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.438210] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.446415] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
    [    0.454196] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.461118] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.468015] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.475506] NET: Registered protocol family 1
    [    0.480504] RPC: Registered named UNIX socket transport module.
    [    0.486592] RPC: Registered udp transport module.
    [    0.491404] RPC: Registered tcp transport module.
    [    0.496213] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.502809] PCI: CLS 0 bytes, default 64
    [    0.507525] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.519624] Initialise system trusted keyrings
    [    0.524413] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.534742] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.541389] NFS: Registering the id_resolver key type
    [    0.546605] Key type id_resolver registered
    [    0.550889] Key type id_legacy registered
    [    0.555070] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.561927] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.569719] 9p: Installing v9fs 9p2000 file system support
    [    0.609842] Key type asymmetric registered
    [    0.614040] Asymmetric key parser 'x509' registered
    [    0.619067] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.626632] io scheduler mq-deadline registered
    [    0.631263] io scheduler kyber registered
    [    0.636651] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.643009] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.654771] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.666207] cacheinfo: Unable to detect cache hierarchy for CPU 0
    [    0.679067] brd: module loaded
    [    0.689193] loop: module loaded
    [    0.693172] megasas: 07.714.04.00-rc1
    [    0.699951] tun: Universal TUN/TAP device driver, 1.6
    [    0.705583] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.712007] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.718117] sky2: driver version 1.30
    [    0.722387] VFIO - User Level meta-driver version: 0.3
    [    0.728610] i2c /dev entries driver
    [    0.733624] sdhci: Secure Digital Host Controller Interface driver
    [    0.739969] sdhci: Copyright(c) Pierre Ossman
    [    0.744645] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.751081] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.757502] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.765100] optee: probing for conduit method.
    [    0.769686] optee: revision 3.19 (afacf356)
    [    0.769979] optee: dynamic shared memory is enabled
    [    0.779519] optee: initialized driver
    [    0.784997] NET: Registered protocol family 17
    [    0.789711] 9pnet: Installing 9P2000 support
    [    0.794166] Key type dns_resolver registered
    [    0.798705] Loading compiled-in X.509 certificates
    [    0.811135] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar')
    [    0.846726] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.854044] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.860259] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
    [    0.868690] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    0.877945] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    0.886987] ti-bcdma 485c0100.dma-controller: Number of rings: 82
    [    0.895123] ti-bcdma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    0.906330] ti-pktdma 485c0000.dma-controller: Number of rings: 150
    [    0.916388] ti-pktdma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    0.926866] printk: console [ttyS2] disabled
    [    0.931321] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 19, base_baud = 3000000) is a 8250
    [    0.940091] printk: console [ttyS2] enabled
    [    0.948537] printk: bootconsole [ns16550a0] disabled
    [    0.962918] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [    0.968116] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:06 UTC (6)
    [    1.080039] mmc0: CQHCI version 5.10
    [    1.092602] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.099372] pca953x 1-0022: using AI
    [    1.123558] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.124945] pca953x 1-0022: failed writing register
    [    1.136206] pca953x: probe of 1-0022 failed with error -121
    [    1.144114] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    1.157439] ALSA device list:
    [    1.160418]   No soundcards found.
    [    1.164342] Waiting for root device PARTUUID=cc549980-34a4-4ce3-b5d6-c0771cd3affc...
    [    1.232193] mmc0: Command Queue Engine enabled
    [    1.236652] mmc0: new HS200 MMC card at address 0001
    [    1.242398] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    1.247165] mmcblk0boot0: mmc0:0001 G1M15L partition 1 31.5 MiB
    [    1.253284] mmcblk0boot1: mmc0:0001 G1M15L partition 2 31.5 MiB
    [    1.259388] mmcblk0rpmb: mmc0:0001 G1M15L partition 3 4.00 MiB, chardev (237:0)
    [    1.269381]  mmcblk0: p1
    [    1.291548] EXT4-fs (mmcblk0p1): recovery complete
    [    1.296838] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
    [    1.305005] VFS: Mounted root (ext4 filesystem) on device 179:1.
    [    1.311386] devtmpfs: mounted
    [    1.315874] Freeing unused kernel memory: 1792K
    [    1.320511] Run /sbin/init as init process
    [    1.397476] systemd[1]: System time before build time, advancing clock.
    [    1.432987] NET: Registered protocol family 10
    [    1.438510] Segment Routing with IPv6
    [    1.452339] systemd[1]: systemd 250.5+ running in system mode (-PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    [    1.484080] systemd[1]: Detected architecture arm64.
    Welcome to Keysight P550  1.0!
    [    1.521465] systemd[1]: Hostname set to <p550>.
    [    1.852577] systemd[1]: Queued start job for default target Multi-User System.
    [    1.892645] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [    1.915203] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    1.939012] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    1.962813] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    1.985378] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    2.009190] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    2.033198] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    2.048969] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    2.068923] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    2.084951] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    2.101354] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    2.132298] systemd[1]: Journal Audit Socket was skipped because of a failed condition check (ConditionSecurity=audit).
    [    2.144147] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    2.165731] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    2.181884] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    2.205743] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    2.229450] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    2.249562] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    2.277536] systemd[1]: Mounting Huge Pages File System...
    [    2.297721] systemd[1]: Mounting POSIX Message Queue File System...
    [    2.325699] systemd[1]: Mounting Kernel Debug File System...
    [    2.349540] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
    [    2.367424] systemd[1]: Mounting Temporary Directory /tmp...
    [    2.394456] systemd[1]: Starting Create List of Static Device Nodes...
    [    2.422835] systemd[1]: Starting Load Kernel Module configfs...
    [    2.450349] systemd[1]: Starting Load Kernel Module drm...
    [    2.478211] systemd[1]: Starting Load Kernel Module fuse...
    [    2.491559] fuse: init (API version 7.32)
    [    2.496030] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
    [    2.509372] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    2.522270] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    2.536450] systemd[1]: Starting Journal Service...
    [    2.555104] systemd[1]: Load Kernel Modules was skipped because all trigger condition checks failed.
    [    2.570523] systemd[1]: Starting Generate network units from Kernel command line...
             Starting Generate network …ts from Kernel command line...
    [    2.602175] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    2.638349] systemd[1]: Starting Apply Kernel Variables...
    [    2.639645] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
    [    2.674510] systemd[1]: Starting Coldplug All udev Devices...
    [    2.710974] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory /tmp.
    [  OK  ] Finished Create List of Static Device Nodes.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [  OK  ] Finished Generate network units from Kernel command line.
    [  OK  ] Finished Remount Root and Kernel File Systems.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Reached target Preparation for Network.
             Mounting FUSE Control File System...
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    3.017596] systemd-journald[145]: Received client request to flush runtime journal.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted FUSE Control File System.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /var/volatile...
             Starting Rule-based Manage…for Device Events and Files...
    [  OK  ] Finished Coldplug All udev Devices.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started Rule-based Manager for Device Events and Files.
             Starting Network Configuration...
    [  OK  ] Finished Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [    3.840938] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    3.888976] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    3.900464] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [    3.916701] cfg80211: failed to load regulatory.db
    [  OK  ] Started Network Configuration.
             Starting Network Name Resolution...
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target Timer Units.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Reached target Socket Units.
    [  OK  ] Reached target Basic System.
             Starting D-Bus System Message Bus...
    [    4.508643] random: dbus-daemon: uninitialized urandom read (12 bytes read)
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
    [    4.576416] random: dbus-daemon: uninitialized urandom read (12 bytes read)
             Starting User Login Management...
    [  OK  ] Started D-Bus System Message Bus.
    [    4.805370] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000
    [    4.894950] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
    [    4.984496] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
    [    5.088695] remoteproc remoteproc0: 5000000.m4fss is available
    [    5.134895] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
    [    5.146775] remoteproc remoteproc0: powering up 5000000.m4fss
    [    5.152691] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
    [    5.177773] remoteproc remoteproc0: request_firmware failed: -2
    [  OK  ] Started User Login Management.
    [  OK  ] Reached target Multi-User System.
             Starting Record Runlevel Change in UTMP...
    [  OK  ] Finished Record Runlevel Change in UTMP.
    [    5.404389] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    5.440917] random: crng init done
    ERROR:   Unhandled External Abort received on 0x80000001 from S-EL1
    ERROR:   exception reason=1 syndrome=0x92000[    5.458743] platform 78000000.r5f: configured R5F for IPC-only mode
    010
    Unhandled Exception from EL1
    x0             = 0xffff8000117aa090
    x1             = 0xffff000001977000
    x2             = 0x0000000000000000
    x3             = 0xffff000001829c00
    x4             = 0xffff000000289e10
    x5             = 0x000000000000008b
    x6             = 0x0000000000000041
    x7             = 0xffff800011[    5.493699] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9d900000
    1d4000
    x8             = 0xffff8000110ba494
    x9             = 0x0140000000000000
    x10            = 0x0000000000001000
    x11            = 0xffff800011a7d000
    x12            = 0x0000000000000000
    x13            = 0x0000000000000036
    x14            = 0x0000000000000036
    x15            = 0x0000b602b56eb126
    x16            = 0xffff000001642060
    x17            = 0x0000000000000000
    x18            = 0xfffffdffffec9780
    x19            = 0xffff00000525a880
    x20            = 0xffff000000289c10
    x21            = 0xffff00000525a890
    x22            = 0xffff000000289c00
    x23            = 0xffff00000525a920
    x24            = 0x0000000000000027
    x25            = 0xffff800008c12100
    x26            = 0xffff800011182348
    x27            = 0x0000000000000100
    x28            = 0x0000000000000013
    x29            = 0xffff8000115ab910
    x30            = 0xffff800008c0f32c
    scr_el3        = 0x000000000000073d
    sctlr_el3      = 0x0000000030cd183f
    cptr_el3       = 0x0000000000000000
    tcr_el3        = 0x0000000080803520
    daif           = 0x00000000000002c0
    mair_el3       = 0x00000000004404ff
    spsr_el3       = 0x0000000080000005
    elr_el3        = 0xffff800008c0f33c
    ttbr0_el3      = 0x000000009e7920c0
    esr_el3        = 0x0000000092000010
    far_el3        = 0xffff8000117aa090
    spsr_el1       = 0x0000000040000005
    elr_el1        = 0xffff8000104bae40
    spsr_abt       = 0x0000000000000000
    spsr_und       = 0x0000000000000000
    spsr_irq       = 0x0000000000000000
    spsr_fiq       = 0x0000000000000000
    sctlr_el1      = 0x0000000034d4d91d
    actlr_el1      = 0x0000000000000000
    cpacr_el1      = 0x0000000000300000
    csselr_el1     = 0x0000000000000000
    sp_el1         = 0xffff8000115ab910
    esr_el1        = 0x0000000056000000
    ttbr0_el1      = 0x0000000084133000
    ttbr1_el1      = 0x009a000082ee5000
    mair_el1       = 0x000c0400bb44ffff
    amair_el1      = 0x0000000000000000
    tcr_el1        = 0x00000032b5d03590
    tpidr_el1      = 0xffff80006ec5d000
    tpidr_el0      = 0x0000ffffa610c1e0
    tpidrro_el0    = 0x0000000000000000
    par_el1        = 0x0000000000000000
    mpidr_el1      = 0x0000000080000001
    afsr0_el1      = 0x0000000000000000
    afsr1_el1      = 0x0000000000000000
    contextidr_el1 = 0x0000000000000000
    vbar_el1       = 0xffff800010010800
    cntp_ctl_el0   = 0x0000000000000005
    cntp_cval_el0  = 0x000000007a9450ce
    cntv_ctl_el0   = 0x0000000000000000
    cntv_cval_el0  = 0x0000000000000000
    cntkctl_el1    = 0x00000000000000d6
    sp_el0         = 0x000000009e78cc40
    isr_el1        = 0x0000000000000040
    dacr32_el2     = 0x0000000000000000
    ifsr32_el2     = 0x0000000000000000
    cpuectlr_el1   = 0x0000000000000040
    cpumerrsr_el1  = 0x00000000001c0421
    l2merrsr_el1   = 0x000000001000c0f0
    cpuactlr_el1   = 0x00001000090ca000
    I'm looping in my colleague for his input.
    -Hong
  • For this question 2/. What SW changes was made, we have made further updates
    This is the dts we modified in linux
    // SPDX-License-Identifier: GPL-2.0
     * AM625 SK: https://www.ti.com/lit/zip/sprr448
     * Copyright (C) 2021-2022 Texas Instruments Incorporated - https://www.ti.com/
    /dts-v1/;
    #include "k3-am625.dtsi"
    	compatible = "ti,am625";
    	model = "Keysight P550 AM625-based";
    	aliases {
    		serial2 = &main_uart0;
    		mmc0 = &sdhci0;
    	/delete-node/ chosen;
    	// Using only 2 cores
    	cpus {
    		cpu-map {
    			cluster0 {
    				/delete-node/ core2;
    				/delete-node/ core3;
    		/delete-node/ cpu@2;
    		/delete-node/ cpu@3;
    	// opp-table {
    	// 	/* Add 1.4GHz OPP for am625-sk board. Requires VDD_CORE to be at 0.85V */
    	// 	opp-1400000000 {
    	// 		opp-hz = /bits/ 64 <1400000000>;
    	// 		opp-supported-hw = <0x01 0x0004>;
    	// 		clock-latency-ns = <6000000>;
    	memory@80000000 {
    		device_type = "memory";
    		/* 2G RAM */
    		reg = <0x00000000 0x80000000 0x00000000 0x80000000>;
    	reserved-memory {
    		#address-cells = <2>;
    		#size-cells = <2>;
    		ranges;
    		rtos_ipc_memory_region: ipc-memories@9c800000 {
    			compatible = "shared-dma-pool";
    			reg = <0x00 0x9c800000 0x00 0x00300000>;
    			no-map;
    		mcu_m4fss_dma_memory_region: m4f-dma-memory@9cb00000 {
    			reg = <0x00 0x9cb00000 0x00 0x100000>;
    			no-map;
    		mcu_m4fss_memory_region: m4f-memory@9cc00000 {
    			reg = <0x00 0x9cc00000 0x00 0xd00000>;
    			no-map;
    		wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9d900000 {
    			reg = <0x00 0x9d900000 0x00 0x00100000>;
    			no-map;
    		wkup_r5fss0_core0_memory_region: r5f-memory@9da00000 {
    			reg = <0x00 0x9da00000 0x00 0x00d00000>;
    			no-map;
    		lpm_ctx_ddr: lpm-memory@9e700000 {
    			reg = <0x00 0x9e700000 0x00 0x80000>;
    			alignment = <0x1000>;
    		secure_tfa_ddr: tfa@9e780000 {
    			reg = <0x00 0x9e780000 0x00 0x80000>;
    			no-map;
    		secure_ddr: optee@9e800000 {
    			reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */
    			no-map;
    	/delete-node/ regulator-0;
    	/delete-node/ regulator-1;
    	/delete-node/ regulator-2;
    	/delete-node/ regulator-3;
    	/delete-node/ regulator-4;
    	/delete-node/ regulator-7;
    // From main domain:
    &main_conf {
    	status = "disabled";
    &main_pmx0 {
    	main_uart0_pins_default: main-uart0-pins-default {
    		pinctrl-single,pins = <
    			AM62X_IOPAD(0x1c8, PIN_INPUT, 0) /* (D14) UART0_RXD */
    			AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */
    	/delete-node/ main-i2c1-pins-default;
    	main_mmc0_pins_default: main-mmc0-pins-default {
    			AM62X_IOPAD(0x220, PIN_INPUT, 0) /* (Y3) MMC0_CMD */
    			AM62X_IOPAD(0x218, PIN_INPUT, 0) /* (AB1) MMC0_CLK */
    			AM62X_IOPAD(0x214, PIN_INPUT, 0) /* (AA2) MMC0_DAT0 */
    			AM62X_IOPAD(0x210, PIN_INPUT, 0) /* (AA1) MMC0_DAT1 */
    			AM62X_IOPAD(0x20c, PIN_INPUT, 0) /* (AA3) MMC0_DAT2 */
    			AM62X_IOPAD(0x208, PIN_INPUT, 0) /* (Y4) MMC0_DAT3 */
    			AM62X_IOPAD(0x204, PIN_INPUT, 0) /* (AB2) MMC0_DAT4 */
    			AM62X_IOPAD(0x200, PIN_INPUT, 0) /* (AC1) MMC0_DAT5 */
    			AM62X_IOPAD(0x1fc, PIN_INPUT, 0) /* (AD2) MMC0_DAT6 */
    			AM62X_IOPAD(0x1f8, PIN_INPUT, 0) /* (AC2) MMC0_DAT7 */
    	/delete-node/ main-mmc1-pins-default;
    	/delete-node/ vdd-sd-dv-pins-default;
    	/delete-node/ main-gpio1-ioexp-intr-pins-default;
    &main_uart0 {
    	pinctrl-names = "default";
    	pinctrl-0 = <&main_uart0_pins_default>;
    &main_uart1 {
    	/* Main UART1 is used by TIFS firmware */
    	status = "reserved";
    &main_uart2 {
    &main_uart3 {
    &main_uart4 {
    &main_uart5 {
    &main_uart6 {
    &mcu_uart0 {
    &mcu_i2c0 {
    &main_i2c0 {
    &main_i2c1 {
    &main_i2c2 {
    &main_i2c3 {
    &main_spi0 {
    &main_spi1 {
    &main_spi2 {
    &sdhci0 {
    	pinctrl-0 = <&main_mmc0_pins_default>;
    	ti,driver-strength-ohm = <50>;
    	disable-wp;
    &sdhci1 {
    &sdhci2 {
    &gpu {
    &usbss0 {
    &usbss1 {
    &fss {
    &cpsw3g {
    &dss {
    &ti_csi2rx0 {
    &dphy0 {
    &main_mcan0 {
    &epwm0 {
    &epwm1 {
    &epwm2 {
    &ecap0 {
    &ecap1 {
    &ecap2 {
    &mcasp0 {
    &mcasp1 {
    &mcasp2 {
    &wkup_uart0 {
    	/* WKUP UART0 is used by DM firmware */
    &wkup_i2c0 {
    &mailbox0_cluster0 {
    	mbox_m4_0: mbox-m4-0 {
    		ti,mbox-rx = <0 0 0>;
    		ti,mbox-tx = <1 0 0>;
    	mbox_r5_0: mbox-r5-0 {
    		ti,mbox-rx = <2 0 0>;
    		ti,mbox-tx = <3 0 0>;
    &mcu_m4fss {
    	mboxes = <&mailbox0_cluster0 &mbox_m4_0>;
    	memory-region = <&mcu_m4fss_dma_memory_region>,
    			<&mcu_m4fss_memory_region>;
    &wkup_r5fss0_core0 {
    	mboxes = <&mailbox0_cluster0 &mbox_r5_0>;
    	memory-region = <&wkup_r5fss0_core0_dma_memory_region>,
    			<&wkup_r5fss0_core0_memory_region>;
    &mcu_rti0 {
    	/* MCU RTI0 is used by M4F firmware */
    &wkup_rti0 {
    	/* WKUP RTI0 is used by DM firmware */
    &main_gpio0 {
    &main_gpio1 {
    This is the dts we modified in u-boot
     DTS for U-Boot A53
    /dts-v1/;
    #include <dt-bindings/leds/common.h>
    #include <dt-bindings/gpio/gpio.h>
    #include <dt-bindings/net/ti-dp83867.h>
    	aliases {
    		mmc0 = &sdhci0;
    		usb0 = &usb0;
    		//usb1 = &usb1;
    		//spi0 = &ospi0;
    	memory@80000000 {
    		/* 2G RAM */
    	reserved-memory {
    		#size-cells = <2>;
    		ranges;
    			no-map;
    			no-map;
    		wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9db00000 {
    			reg = <0x00 0x9db00000 0x00 0xc00000>;
    			no-map;
    	/delete-node/ fixed-regulator-sd;
    	/delete-node/ gpio-regulator-TLV71033;
    	extcon_usb0: extcon-usb0 {
    		compatible = "linux,extcon-usb-gpio";
    		id-gpios = <&main_gpio1 50 GPIO_ACTIVE_HIGH>;
    		pinctrl-0 = <&extcon_usb0_gpio_id_pins_default>;
    &main_pmx0 {
    	// main_i2c0_pins_default: main-i2c0-pins-default {
    	// 	pinctrl-single,pins = <
    	// 		AM62X_IOPAD(0x1e0, PIN_INPUT_PULLUP, 0) /* (B16) I2C0_SCL */
    	// 		AM62X_IOPAD(0x1e4, PIN_INPUT_PULLUP, 0) /* (A16) I2C0_SDA */
    	// main_i2c2_pins_default: main-i2c2-pins-default {
    	// 		AM62X_IOPAD(0x0b0, PIN_INPUT_PULLUP, 1) /* (K22) GPMC0_CSn2.I2C2_SCL */
    	// 		AM62X_IOPAD(0x0b4, PIN_INPUT_PULLUP, 1) /* (K24) GPMC0_CSn3.I2C2_SDA */
    	extcon_usb0_gpio_id_pins_default: extcon-usb0-gpio-id-pins-default {
    			AM62X_IOPAD(0x254, PIN_INPUT_PULLUP, 7) /* (C20) USB0_DRVVBUS.GPIO1_50 */
    	// main_usb1_pins_default: main-usb1-pins-default {
    	// 		AM62X_IOPAD(0x0258, PIN_OUTPUT, 0) /* (F18) USB1_DRVVBUS */
    &wkup_uart0 {
    &mcu_uart0 {
    &main_uart0 {
    &main_uart1 {
    &main_uart2 {
    &main_uart3 {
    &main_uart4 {
    &main_uart5 {
    &main_uart6 {
    &mcu_i2c0 {
    &wkup_i2c0 {
    &main_i2c0 {
    &main_i2c1 {
    &main_i2c2 {
    &main_i2c3 {
    &sdhci0 {
    	disable-wp;
    &sdhci1 {
    &usbss0 {
    	ti,vbus-divider;
    &usb0 {
    	extcon = <&extcon_usb0>;
    // &usb1 {
    // 	dr_mode = "host";
    // 	pinctrl-names = "default";
    // 	pinctrl-0 = <&main_usb1_pins_default>;
    &main_gpio0 {
    &main_gpio1 {
  • Hi Suan,
    What is the part number of the AM62x do you use?
    Please try to disable "&pruss" and "&gpu" in your kernel device tree to see if the crash still happens.
  • The part number we are using is 6234
    After try to disable  "&pruss" and "&gpu" in my kernel device tree, the crash still happens.
  • Hi Suan,
    I see you kernel DTS has most peripherals disabled, but can you please convert your board DTB back to DTS to check what else modules could be disabled? I want to see if we can find any module causes the exception abort.
  • This is the DTS we converted from DTB
    /dts-v1/;
          model = "AM625-based";
      interrupt-parent = <0x01>;
         #address-cells = <0x02>;
      #size-cells = <0x02>;
      chosen {
                 stdout-path = "serial2:115200n8";
             bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000";
           firmware {
                    optee {
                        compatible = "linaro,optee-tz";
                      method = "smc";
                   psci {
                        compatible = "arm,psci-1.0";
                         method = "smc";
                       phandle = <0x2e>;
         timer-cl0-cpu0 {
                    compatible = "arm,armv8-timer";
                  interrupts = <0x01 0x0d 0x08 0x01 0x0e 0x08 0x01 0x0b 0x08 0x01 0x0a 0x08>;
                  phandle = <0x2f>;
     pmu {
                   compatible = "arm,cortex-a53-pmu";
              interrupts = <0x01 0x07 0x04>;
                 phandle = <0x30>;
            bus@f0000 {
                    compatible = "simple-bus";
                    ranges = <0x00 0xf0000 0x00 0xf0000 0x00 0x30000 0x00 0x420000 0x00 0x420000 0x00 0x1000 0x00 0x600000 0x00 0x600000 0x00 0x1100 0x00 0x703000 0x00 0x703000 0x00 0x200 0x00 0x70c000 0x00 0x70c000 0x00 0x200 0x00 0xa40000 0x00 0xa40000 0x00 0x800 0x00 0x1000000 0x00 0x1000000 0x00 0x1b28400 0x00 0x8000000 0x00 0x8000000 0x00 0x200000 0x00 0xe000000 0x00 0xe000000 0x00 0x1d20000 0x00 0xfd00000 0x00 0xfd00000 0x00 0x20000 0x00 0x20000000 0x00 0x20000000 0x00 0xa008000 0x00 0x30040000 0x00 0x30040000 0x00 0x80000 0x00 0x30101000 0x00 0x30101000 0x00 0x10100 0x00 0x30200000 0x00 0x30200000 0x00 0x10000 0x00 0x31000000 0x00 0x31000000 0x00 0x50000 0x00 0x31100000 0x00 0x31100000 0x00 0x50000 0x00 0x40900000 0x00 0x40900000 0x00 0x30000 0x00 0x43600000 0x00 0x43600000 0x00 0x10000 0x00 0x44043000 0x00 0x44043000 0x00 0xfe0 0x00 0x44860000 0x00 0x44860000 0x00 0x40000 0x00 0x48000000 0x00 0x48000000 0x00 0x6400000 0x00 0x60000000 0x00 0x60000000 0x00 0x8000000 0x00 0x70000000 0x00 0x70000000 0x00 0x10000 0x01 0x00 0x01 0x00 0x00 0x310000 0x05 0x00 0x05 0x00 0x01 0x00 0x00 0x4000000 0x00 0x4000000 0x00 0x1ff1400 0x00 0xb00000 0x00 0xb00000 0x00 0x2400 0x00 0x2b000000 0x00 0x2b000000 0x00 0x300400 0x00 0x43000000 0x00 0x43000000 0x00 0x20000 0x00 0x78000000 0x00 0x78000000 0x00 0x8000 0x00 0x78100000 0x00 0x78100000 0x00 0x8000>;
              phandle = <0x31>;
                  bus@4000000 {
                        ranges = <0x00 0x4000000 0x00 0x4000000 0x00 0x1ff1400>;
                       phandle = <0x32>;
                           pinctrl@4084000 {
                             compatible = "pinctrl-single";
                                    reg = <0x00 0x4084000 0x00 0x88>;
                              #pinctrl-cells = <0x01>;
                                   pinctrl-single,register-width = <0x20>;
                                 pinctrl-single,function-mask = <0xffffffff>;
                                  phandle = <0x33>;
                     serial@4a00000 {
                                compatible = "ti,am64-uart\0ti,am654-uart";
                                  reg = <0x00 0x4a00000 0x00 0x100>;
                                   interrupts = <0x00 0xb9 0x04>;
                              power-domains = <0x02 0x95 0x01>;
                              clocks = <0x03 0x95 0x00>;
                             clock-names = "fclk";
                              phandle = <0x34>;
                         i2c@4900000 {
                               compatible = "ti,am64-i2c\0ti,omap4-i2c";
                                   reg = <0x00 0x4900000 0x00 0x100>;
                                    interrupts = <0x00 0x6b 0x04>;
                               #address-cells = <0x01>;
                                    #size-cells = <0x00>;
                                    power-domains = <0x02 0x6a 0x01>;
                                    clocks = <0x03 0x6a 0x02>;
                                   clock-names = "fck";
                             phandle = <0x35>;
                        spi@4b00000 {
                              compatible = "ti,am654-mcspi\0ti,omap4-mcspi";
                             reg = <0x00 0x4b00000 0x00 0x400>;
                              interrupts = <0x00 0xb0 0x04>;
                              power-domains = <0x02 0x93 0x01>;
                              clocks = <0x03 0x93 0x00>;
                             phandle = <0x36>;
                        spi@4b10000 {
                             reg = <0x00 0x4b10000 0x00 0x400>;
                              interrupts = <0x00 0xb1 0x04>;
                              power-domains = <0x02 0x94 0x01>;
                              clocks = <0x03 0x94 0x00>;
                             phandle = <0x37>;
                        interrupt-controller@4210000 {
                             compatible = "ti,sci-intr";
                               reg = <0x00 0x4210000 0x00 0x200>;
                                ti,intr-trigger-type = <0x01>;
                               interrupt-controller;
                              #interrupt-cells = <0x01>;
                                 ti,sci = <0x04>;
                              ti,sci-dev-id = <0x05>;
                                    ti,interrupt-ranges = <0x00 0x68 0x04>;
                              phandle = <0x05>;
                         gpio@4201000 {
                              compatible = "ti,am64-gpio\0ti,keystone-gpio";
                             reg = <0x00 0x4201000 0x00 0x100>;
                              gpio-controller;
                               #gpio-cells = <0x02>;
                               interrupt-parent = <0x05>;
                                  interrupts = <0x1e 0x1f>;
                                    #interrupt-cells = <0x02>;
                               ti,ngpio = <0x18>;
                                  ti,davinci-gpio-unbanked = <0x00>;
                             power-domains = <0x02 0x4f 0x01>;
                             clocks = <0x03 0x4f 0x00>;
                                    clock-names = "gpio";
                                    phandle = <0x38>;
                       watchdog@4880000 {
                                compatible = "ti,j7-rti-wdt";
                                reg = <0x00 0x4880000 0x00 0x100>;
                                 clocks = <0x03 0x83 0x00>;
                                power-domains = <0x02 0x83 0x01>;
                                assigned-clocks = <0x03 0x83 0x00>;
                              assigned-clock-parents = <0x03 0x83 0x02>;
                              phandle = <0x39>;
                         m4fss@5000000 {
                             compatible = "ti,am64-m4fss";
                             reg = <0x00 0x5000000 0x00 0x30000 0x00 0x5040000 0x00 0x10000>;
                                reg-names = "iram\0dram";
                                    ti,sci = <0x04>;
                                 ti,sci-dev-id = <0x09>;
                               ti,sci-proc-ids = <0x18 0xff>;
                                resets = <0x06 0x09 0x01>;
                               firmware-name = "am62-mcu-m4f0_0-fw";
                               mboxes = <0x07 0x08>;
                                 memory-region = <0x09 0x0a>;
                                    phandle = <0x3a>;
              bus@b00000 {
                     ranges = <0x00 0xb00000 0x00 0xb00000 0x00 0x2400 0x00 0x2b000000 0x00 0x2b000000 0x00 0x300400 0x00 0x43000000 0x00 0x43000000 0x00 0x20000 0x00 0x78000000 0x00 0x78000000 0x00 0x8000 0x00 0x78100000 0x00 0x78100000 0x00 0x8000>;
                      phandle = <0x3b>;
                          syscon@43000000 {
                                    compatible = "syscon\0simple-mfd";
                               reg = <0x00 0x43000000 0x00 0x20000>;
                                  #size-cells = <0x01>;
                                  ranges = <0x00 0x00 0x43000000 0x20000>;
                             phandle = <0x1b>;
                                 chipid@14 {
                                         compatible = "ti,am654-chipid";
                                       reg = <0x14 0x04>;
                                            phandle = <0x3c>;
                      serial@2b300000 {
                                  reg = <0x00 0x2b300000 0x00 0x100>;
                                  interrupts = <0x00 0xba 0x04>;
                             power-domains = <0x02 0x72 0x01>;
                             clocks = <0x03 0x72 0x00>;
                             phandle = <0x3d>;
                        i2c@2b200000 {
                                 reg = <0x00 0x2b200000 0x00 0x100>;
                                 interrupts = <0x00 0xa5 0x04>;
                                 power-domains = <0x02 0x6b 0x01>;
                                 clocks = <0x03 0x6b 0x04>;
                                  phandle = <0x3e>;
                     watchdog@2b000000 {
                             reg = <0x00 0x2b000000 0x00 0x100>;
                             clocks = <0x03 0x84 0x00>;
                                    power-domains = <0x02 0x84 0x01>;
                                    assigned-clocks = <0x03 0x84 0x00>;
                                  assigned-clock-parents = <0x03 0x84 0x02>;
                                  phandle = <0x3f>;
                     rtc@2b1f0000 {
                                  compatible = "ti,am62-rtc";
                                    reg = <0x00 0x2b1f0000 0x00 0x100>;
                                    interrupts = <0x00 0x64 0x04>;
                               clocks = <0x03 0x75 0x06 0x03 0x75 0x00>;
                             clock-names = "vbus\0osc32k";
                             power-domains = <0x02 0x75 0x01>;
                             wakeup-source;
                                phandle = <0x40>;
                           temperature-sensor@b00000 {
                                   compatible = "ti,j7200-vtm";
                                    reg = <0x00 0xb00000 0x00 0x400 0x00 0xb01000 0x00 0x400 0x00 0x43000300 0x00 0x10>;
                                   power-domains = <0x02 0x5f 0x01>;
                                   #thermal-sensor-cells = <0x01>;
                                 phandle = <0x23>;
                            r5fss@78000000 {
                               compatible = "ti,am62-r5fss";
                                    ranges = <0x78000000 0x00 0x78000000 0x8000 0x78100000 0x00 0x78100000 0x8000>;
                                power-domains = <0x02 0x77 0x01>;
                                phandle = <0x41>;
                                    r5f@78000000 {
                                         compatible = "ti,am62-r5f";
                                           reg = <0x78000000 0x8000 0x78100000 0x8000>;
                                          reg-names = "atcm\0btcm";
                                      ti,sci = <0x04>;
                                           ti,sci-dev-id = <0x79>;
                                         ti,sci-proc-ids = <0x01 0xff>;
                                          resets = <0x06 0x79 0x01>;
                                         firmware-name = "am62-wkup-r5f0_0-fw";
                                        ti,atcm-enable = <0x01>;
                                     ti,btcm-enable = <0x01>;
                                          ti,loczrama = <0x01>;
                                          mboxes = <0x07 0x0b>;
                                            memory-region = <0x0c 0x0d>;
                                       phandle = <0x42>;
                sram@70000000 {
                            compatible = "mmio-sram";
                        reg = <0x00 0x70000000 0x00 0x10000>;
                           ranges = <0x00 0x00 0x70000000 0x10000>;
                      phandle = <0x43>;
                 interrupt-controller@1800000 {
                      compatible = "arm,gic-v3";
                      ranges;
                        #interrupt-cells = <0x03>;
                       reg = <0x00 0x1800000 0x00 0x10000 0x00 0x1880000 0x00 0xc0000 0x00 0x1880000 0x00 0xc0000 0x01 0x00 0x00 0x2000 0x01 0x10000 0x00 0x1000 0x01 0x20000 0x00 0x2000>;
                      interrupts = <0x01 0x09 0x04>;
                         phandle = <0x01>;
                     msi-controller@1820000 {
                                compatible = "arm,gic-v3-its";
                               reg = <0x00 0x1820000 0x00 0x10000>;
                              socionext,synquacer-pre-its = <0x1000000 0x400000>;
                                  msi-controller;
                                    #msi-cells = <0x01>;
                             phandle = <0x44>;
               syscon@100000 {
                      reg = <0x00 0x100000 0x00 0x20000>;
                           ranges = <0x00 0x00 0x100000 0x20000>;
                         phandle = <0x45>;
                     phy@4044 {
                              compatible = "ti,am654-phy-gmii-sel";
                              reg = <0x4044 0x08>;
                                 #phy-cells = <0x01>;
                                  phandle = <0x1c>;
                     clock@4130 {
                                    compatible = "ti,am62-epwm-tbclk\0syscon";
                               reg = <0x4130 0x04>;
                                  #clock-cells = <0x01>;
                                 phandle = <0x1f>;
                            dss-oldi-io-ctrl@8600 {
                                compatible = "syscon";
                               reg = <0x8600 0x200>;
                                 phandle = <0x1d>;
                   bus@48000000 {
                        compatible = "simple-mfd";
                        dma-ranges;
                      ranges = <0x00 0x48000000 0x00 0x48000000 0x00 0x6400000>;
                           ti,sci-dev-id = <0x19>;
                         phandle = <0x46>;
                     mailbox@4d000000 {
                              compatible = "ti,am654-secure-proxy";
                              #mbox-cells = <0x01>;
                              reg-names = "target_data\0rt\0scfg";
                               reg = <0x00 0x4d000000 0x00 0x80000 0x00 0x4a600000 0x00 0x80000 0x00 0x4a400000 0x00 0x80000>;
                                   interrupt-names = "rx_012";
                             interrupts = <0x00 0x22 0x04>;
                                phandle = <0x11>;
                           interrupt-controller@48000000 {
                               compatible = "ti,sci-inta";
                                 reg = <0x00 0x48000000 0x00 0x100000>;
                              #interrupt-cells = <0x00>;
                                msi-controller;
                                  ti,sci = <0x04>;
                               ti,sci-dev-id = <0x1c>;
                             ti,interrupt-ranges = <0x04 0x44 0x24>;
                               ti,unmapped-event-sources = <0x0e 0x0f>;
                              phandle = <0x10>;
                         dma-controller@485c0100 {
                                   compatible = "ti,am64-dmss-bcdma";
                              reg = <0x00 0x485c0100 0x00 0x100 0x00 0x4c000000 0x00 0x20000 0x00 0x4a820000 0x00 0x20000 0x00 0x4aa40000 0x00 0x20000 0x00 0x4bc00000 0x00 0x100000>;
                                 reg-names = "gcfg\0bchanrt\0rchanrt\0tchanrt\0ringrt";
                                msi-parent = <0x10>;
                                 #dma-cells = <0x03>;
                                  ti,sci = <0x04>;
                               ti,sci-dev-id = <0x1a>;
                             ti,sci-rm-range-bchan = <0x20>;
                                   ti,sci-rm-range-rchan = <0x21>;
                                 ti,sci-rm-range-tchan = <0x22>;
                               phandle = <0x0e>;
                          dma-controller@485c0000 {
                                    compatible = "ti,am64-dmss-pktdma";
                              reg = <0x00 0x485c0000 0x00 0x100 0x00 0x4a800000 0x00 0x20000 0x00 0x4aa00000 0x00 0x40000 0x00 0x4b800000 0x00 0x400000>;
                              reg-names = "gcfg\0rchanrt\0tchanrt\0ringrt";
                               #dma-cells = <0x02>;
                                ti,sci = <0x04>;
                             ti,sci-dev-id = <0x1e>;
                                   ti,sci-rm-range-tchan = <0x23 0x24 0x25 0x26>;
                                ti,sci-rm-range-tflow = <0x10 0x11 0x12 0x13>;
                             ti,sci-rm-range-rchan = <0x29 0x2b 0x2d 0x2f 0x31 0x33>;
                                    ti,sci-rm-range-rflow = <0x2a 0x2c 0x2e 0x32>;
                                 phandle = <0x0f>;
                   system-controller@44043000 {
                          compatible = "ti,k2g-sci";
                     ti,host-id = <0x0c>;
                      mbox-names = "rx\0tx";
                     mboxes = <0x11 0x0c 0x11 0x0d>;
                         reg-names = "debug_messages\0lpm";
                            reg = <0x00 0x44043000 0x00 0xfe0 0x00 0x78000000 0x00 0x8000>;
                        ti,lpm-firmware-name = "ti-sysfw/ti-fs-stub-firmware-am62x-gp-signed.bin";
                           phandle = <0x04>;
                       power-controller {
                                compatible = "ti,sci-pm-domain";
                             #power-domain-cells = <0x02>;
                             phandle = <0x02>;
                        clock-controller {
                                 compatible = "ti,k2g-sci-clk";
                                #clock-cells = <0x02>;
                               phandle = <0x03>;
                          reset-controller {
                                   compatible = "ti,sci-reset";
                                    #reset-cells = <0x02>;
                                   phandle = <0x06>;
             crypto@40900000 {
                       compatible = "ti,am62-sa3ul";
                       reg = <0x00 0x40900000 0x00 0x1200>;
                      power-domains = <0x02 0x46 0x00>;
                           ranges = <0x00 0x40900000 0x00 0x40900000 0x00 0x30000>;
                          dmas = <0x0f 0xf501 0x00 0x0f 0x7506 0x00 0x0f 0x7507 0x00>;
                           dma-names = "tx\0rx1\0rx2";
                     phandle = <0x47>;
                         rng@40910000 {
                              compatible = "inside-secure,safexcel-eip76";
                               reg = <0x00 0x40910000 0x00 0x7d>;
                                interrupts = <0x00 0x81 0x04>;
                                   clocks = <0x03 0x46 0x00>;
                                   phandle = <0x48>;
             pinctrl@f4000 {
                        reg = <0x00 0xf4000 0x00 0x2ac>;
                       phandle = <0x49>;
                             pinctrl-single,pins = <0x1c8 0x50000 0x1cc 0x10000>;
                                    phandle = <0x12>;
                       main-i2c1-pins-default {
                                  pinctrl-single,pins = <0x1e8 0x60000 0x1ec 0x60000>;
                                 phandle = <0x13>;
                               pinctrl-single,pins = <0x220 0x50000 0x218 0x50000 0x214 0x50000 0x210 0x50000 0x20c 0x50000 0x208 0x50000 0x204 0x50000 0x200 0x50000 0x1fc 0x50000 0x1f8 0x50000>;
                              phandle = <0x17>;
                         main-mmc1-pins-default {
                                    pinctrl-single,pins = <0x23c 0x50000 0x234 0x50000 0x230 0x50000 0x22c 0x50000 0x228 0x50000 0x224 0x50000 0x240 0x50000>;
                                 phandle = <0x1a>;
                            vdd-sd-dv-pins-default {
                               pinctrl-single,pins = <0x7c 0x10007>;
                                 phandle = <0x2b>;
                            main-gpio1-ioexp-intr-pins-default {
                                   pinctrl-single,pins = <0x1d4 0x50007>;
                                    phandle = <0x15>;
              serial@2800000 {
                           reg = <0x00 0x2800000 0x00 0x100>;
                            interrupts = <0x00 0xb2 0x04>;
                       power-domains = <0x02 0x92 0x01>;
                       clocks = <0x03 0x92 0x00>;
                         pinctrl-0 = <0x12>;
                           phandle = <0x4a>;
              serial@2810000 {
                           reg = <0x00 0x2810000 0x00 0x100>;
                            interrupts = <0x00 0xb3 0x04>;
                       power-domains = <0x02 0x98 0x01>;
                       clocks = <0x03 0x98 0x00>;
                       phandle = <0x4b>;
                  serial@2820000 {
                       reg = <0x00 0x2820000 0x00 0x100>;
                        interrupts = <0x00 0xb4 0x04>;
                           power-domains = <0x02 0x99 0x01>;
                           clocks = <0x03 0x99 0x00>;
                           phandle = <0x4c>;
              serial@2830000 {
                           reg = <0x00 0x2830000 0x00 0x100>;
                            interrupts = <0x00 0xb5 0x04>;
                       power-domains = <0x02 0x9a 0x01>;
                       clocks = <0x03 0x9a 0x00>;
                       phandle = <0x4d>;
                  serial@2840000 {
                       reg = <0x00 0x2840000 0x00 0x100>;
                        interrupts = <0x00 0xb6 0x04>;
                           power-domains = <0x02 0x9b 0x01>;
                           clocks = <0x03 0x9b 0x00>;
                           phandle = <0x4e>;
              serial@2850000 {
                           reg = <0x00 0x2850000 0x00 0x100>;
                            interrupts = <0x00 0xb7 0x04>;
                       power-domains = <0x02 0x9c 0x01>;
                       clocks = <0x03 0x9c 0x00>;
                       phandle = <0x4f>;
                  serial@2860000 {
                       reg = <0x00 0x2860000 0x00 0x100>;
                        interrupts = <0x00 0xb8 0x04>;
                           power-domains = <0x02 0x9e 0x01>;
                           clocks = <0x03 0x9e 0x00>;
                           phandle = <0x50>;
              i2c@20000000 {
                       reg = <0x00 0x20000000 0x00 0x100>;
                       interrupts = <0x00 0xa1 0x04>;
                       power-domains = <0x02 0x66 0x01>;
                       clocks = <0x03 0x66 0x02>;
                        phandle = <0x51>;
                   i2c@20010000 {
                            reg = <0x00 0x20010000 0x00 0x100>;
                            interrupts = <0x00 0xa2 0x04>;
                            power-domains = <0x02 0x67 0x01>;
                            clocks = <0x03 0x67 0x02>;
                       pinctrl-0 = <0x13>;
                         clock-frequency = <0x186a0>;
                          phandle = <0x52>;
                      gpio@22 {
                                compatible = "ti,tca6424";
                                   reg = <0x22>;
                                   gpio-controller;
                                    gpio-line-names = "GPIO_CPSW2_RST\0GPIO_CPSW1_RST\0PRU_DETECT\0MMC1_SD_EN\0VPP_LDO_EN\0EXP_PS_3V3_En\0EXP_PS_5V0_En\0EXP_HAT_DETECT\0GPIO_AUD_RSTn\0GPIO_eMMC_RSTn\0UART1_FET_BUF_EN\0WL_LT_EN\0GPIO_HDMI_RSTn\0CSI_GPIO1\0CSI_GPIO2\0PRU_3V3_EN\0HDMI_INTn\0TEST_GPIO2\0MCASP1_FET_EN\0MCASP1_BUF_BT_EN\0MCASP1_FET_SEL\0UART1_FET_SEL\0TSINT#\0IO_EXP_TEST_LED";
                               interrupt-parent = <0x14>;
                                  interrupts = <0x17 0x02>;
                                  pinctrl-0 = <0x15>;
                                    phandle = <0x2a>;
              i2c@20020000 {
                       reg = <0x00 0x20020000 0x00 0x100>;
                       interrupts = <0x00 0xa3 0x04>;
                       power-domains = <0x02 0x68 0x01>;
                       clocks = <0x03 0x68 0x02>;
                        phandle = <0x53>;
                   i2c@20030000 {
                            reg = <0x00 0x20030000 0x00 0x100>;
                            interrupts = <0x00 0xa4 0x04>;
                            power-domains = <0x02 0x69 0x01>;
                            clocks = <0x03 0x69 0x02>;
                     phandle = <0x54>;
                spi@20100000 {
                            reg = <0x00 0x20100000 0x00 0x400>;
                            interrupts = <0x00 0xac 0x04>;
                            power-domains = <0x02 0x8d 0x01>;
                            clocks = <0x03 0xac 0x00>;
                            phandle = <0x55>;
               spi@20110000 {
                           reg = <0x00 0x20110000 0x00 0x400>;
                           interrupts = <0x00 0xad 0x04>;
                           power-domains = <0x02 0x8e 0x01>;
                           clocks = <0x03 0xad 0x00>;
                           phandle = <0x56>;
              spi@20120000 {
                          reg = <0x00 0x20120000 0x00 0x400>;
                          interrupts = <0x00 0xae 0x04>;
                          power-domains = <0x02 0x8f 0x01>;
                          clocks = <0x03 0xae 0x00>;
                          phandle = <0x57>;
             interrupt-controller@a00000 {
                     reg = <0x00 0xa00000 0x00 0x800>;
                        ti,sci = <0x04>;
                     ti,sci-dev-id = <0x03>;
                           ti,interrupt-ranges = <0x00 0x20 0x10>;
                     phandle = <0x16>;
                gpio@600000 {
                     reg = <0x00 0x600000 0x00 0x100>;
                       gpio-controller;
                        interrupt-parent = <0x16>;
                           interrupts = <0xbe 0xbf 0xc0 0xc1 0xc2 0xc3>;
                            ti,ngpio = <0x57>;
                          power-domains = <0x02 0x4d 0x01>;
                          clocks = <0x03 0x4d 0x00>;
                         phandle = <0x2d>;
                    gpio@601000 {
                         reg = <0x00 0x601000 0x00 0x100>;
                           gpio-controller;
                       interrupts = <0xb4 0xb5 0xb6 0xb7 0xb8 0xb9>;
                        ti,ngpio = <0x58>;
                      power-domains = <0x02 0x4e 0x01>;
                      clocks = <0x03 0x4e 0x00>;
                     phandle = <0x14>;
                mmc@fa10000 {
                      compatible = "ti,am62-sdhci";
                      reg = <0x00 0xfa10000 0x00 0x260 0x00 0xfa18000 0x00 0x134>;
                     interrupts = <0x00 0x85 0x04>;
                        power-domains = <0x02 0x39 0x01>;
                        clocks = <0x03 0x39 0x05 0x03 0x39 0x06>;
                      clock-names = "clk_ahb\0clk_xin";
                          assigned-clocks = <0x03 0x39 0x06>;
                        assigned-clock-parents = <0x03 0x39 0x08>;
                       mmc-ddr-1_8v;
                           mmc-hs200-1_8v;
                     ti,trm-icp = <0x02>;
                      bus-width = <0x08>;
                        ti,clkbuf-sel = <0x07>;
                      ti,otap-del-sel-legacy = <0x00>;
                           ti,otap-del-sel-mmc-hs = <0x00>;
                        ti,otap-del-sel-ddr52 = <0x09>;
                      ti,otap-del-sel-hs200 = <0x06>;
                       pinctrl-0 = <0x17>;
                         ti,driver-strength-ohm = <0x32>;
                      disable-wp;
                            phandle = <0x58>;
               mmc@fa00000 {
                     reg = <0x00 0xfa00000 0x00 0x260 0x00 0xfa08000 0x00 0x134>;
                            interrupts = <0x00 0x53 0x04>;
                       power-domains = <0x02 0x3a 0x01>;
                       clocks = <0x03 0x3a 0x05 0x03 0x3a 0x06>;
                       ti,otap-del-sel-sd-hs = <0x00>;
                     ti,otap-del-sel-sdr12 = <0x0f>;
                           ti,otap-del-sel-sdr25 = <0x0f>;
                         ti,otap-del-sel-sdr50 = <0x0c>;
                       ti,otap-del-sel-sdr104 = <0x06>;
                            ti,otap-del-sel-ddr50 = <0x09>;
                          ti,itap-del-sel-legacy = <0x00>;
                       ti,itap-del-sel-sd-hs = <0x00>;
                     ti,itap-del-sel-sdr12 = <0x00>;
                           ti,itap-del-sel-sdr25 = <0x00>;
                       bus-width = <0x04>;
                         vmmc-supply = <0x18>;
                         vqmmc-supply = <0x19>;
                           pinctrl-0 = <0x1a>;
                          disable-wp;
                        no-1-8-v;
                        phandle = <0x59>;
                   mmc@fa20000 {
                         reg = <0x00 0xfa20000 0x00 0x260 0x00 0xfa28000 0x00 0x134>;
                        interrupts = <0x00 0x52 0x04>;
                           power-domains = <0x02 0xb8 0x01>;
                           clocks = <0x03 0xb8 0x05 0x03 0xb8 0x06>;
                            phandle = <0x5a>;
               gpu@fd00000 {
                     compatible = "ti,am62-pvr\0img,pvr-axe116m";
                      reg = <0x00 0xfd00000 0x00 0x20000>;
                     interrupts = <0x00 0x56 0x04>;
                        power-domains = <0x02 0xbb 0x01>;
                        clocks = <0x03 0xbb 0x00>;
                        phandle = <0x5b>;
                   dwc3-usb@f900000 {
                            compatible = "ti,am62-usb";
                      reg = <0x00 0xf900000 0x00 0x800>;
                       clocks = <0x03 0xa1 0x03>;
                      clock-names = "ref";
                       ti,syscon-phy-pll-refclk = <0x1b 0x4008>;
                          power-domains = <0x02 0xb2 0x01>;
                          ranges;
                     phandle = <0x5c>;
                         usb@31000000 {
                              compatible = "snps,dwc3";
                                  reg = <0x00 0x31000000 0x00 0x50000>;
                                interrupts = <0x00 0xbc 0x04 0x00 0xbc 0x04>;
                                  interrupt-names = "host\0peripheral";
                                  maximum-speed = "high-speed";
                                  dr_mode = "otg";
                               phandle = <0x5d>;
                 dwc3-usb@f910000 {
                            reg = <0x00 0xf910000 0x00 0x800>;
                     clocks = <0x03 0xa2 0x03>;
                     ti,syscon-phy-pll-refclk = <0x1b 0x4018>;
                        power-domains = <0x02 0xb3 0x01>;
                        ranges;
                           phandle = <0x5e>;
                       usb@31100000 {
                                reg = <0x00 0x31100000 0x00 0x50000>;
                              interrupts = <0x00 0xe2 0x04 0x00 0xe2 0x04>;
                                dr_mode = "otg";
                             phandle = <0x5f>;
               bus@fc00000 {
                        reg = <0x00 0xfc00000 0x00 0x70000>;
                            ranges;
                       phandle = <0x60>;
                           spi@fc40000 {
                                 compatible = "ti,am654-ospi\0cdns,qspi-nor";
                                  reg = <0x00 0xfc40000 0x00 0x100 0x05 0x00 0x01 0x00>;
                               interrupts = <0x00 0x8b 0x04>;
                                  cdns,fifo-depth = <0x100>;
                             cdns,fifo-width = <0x04>;
                                 cdns,trigger-address = <0x00>;
                                clocks = <0x03 0x4b 0x07>;
                               assigned-clocks = <0x03 0x4b 0x07>;
                             assigned-clock-parents = <0x03 0x4b 0x08>;
                                    assigned-clock-rates = <0x9ef21aa>;
                              power-domains = <0x02 0x4b 0x01>;
                                   phandle = <0x61>;
             ethernet@8000000 {
                      compatible = "ti,am642-cpsw-nuss";
                      reg = <0x00 0x8000000 0x00 0x200000>;
                            reg-names = "cpsw_nuss";
                         ranges = <0x00 0x00 0x00 0x8000000 0x00 0x200000>;
                      clocks = <0x03 0x0d 0x00>;
                     assigned-clocks = <0x03 0x0d 0x03>;
                           assigned-clock-parents = <0x03 0x0d 0x0b>;
                           power-domains = <0x02 0x0d 0x01>;
                           dmas = <0x0f 0xc600 0x0f 0x0f 0xc601 0x0f 0x0f 0xc602 0x0f 0x0f 0xc603 0x0f 0x0f 0xc604 0x0f 0x0f 0xc605 0x0f 0x0f 0xc606 0x0f 0x0f 0xc607 0x0f 0x0f 0x4600 0x0f>;
                          dma-names = "tx0\0tx1\0tx2\0tx3\0tx4\0tx5\0tx6\0tx7\0rx";
                       phandle = <0x62>;
                           ethernet-ports {
                                   port@1 {
                                      reg = <0x01>;
                                      ti,mac-only;
                                           label = "port1";
                                        phys = <0x1c 0x01>;
                                            mac-address = [00 00 00 00 00 00];
                                         ti,syscon-efuse = <0x1b 0x200>;
                                         phandle = <0x63>;
                                    port@2 {
                                       reg = <0x02>;
                                       ti,mac-only;
                                            label = "port2";
                                         phys = <0x1c 0x02>;
                                          phandle = <0x64>;
                            mdio@f00 {
                             compatible = "ti,cpsw-mdio\0ti,davinci_mdio";
                             reg = <0x00 0xf00 0x00 0x100>;
                               bus_freq = <0xf4240>;
                               phandle = <0x65>;
                          cpts@3d000 {
                                 compatible = "ti,j721e-cpts";
                                 reg = <0x00 0x3d000 0x00 0x400>;
                                   clock-names = "cpts";
                                   interrupts-extended = <0x01 0x00 0x66 0x04>;
                                  interrupt-names = "cpts";
                              ti,cpts-ext-ts-inputs = <0x04>;
                                    ti,cpts-periodic-outputs = <0x02>;
             dss@30200000 {
                          compatible = "ti,am625-dss";
                           reg = <0x00 0x30200000 0x00 0x1000 0x00 0x30201000 0x00 0x1000 0x00 0x30202000 0x00 0x1000 0x00 0x30206000 0x00 0x1000 0x00 0x30207000 0x00 0x1000 0x00 0x30208000 0x00 0x1000 0x00 0x3020a000 0x00 0x1000 0x00 0x3020b000 0x00 0x1000>;
                      reg-names = "common\0common1\0vidl1\0vid\0ovr1\0ovr2\0vp1\0vp2";
                           ti,am65x-oldi-io-ctrl = <0x1d>;
                         power-domains = <0x02 0xba 0x01>;
                         clocks = <0x03 0xba 0x06 0x03 0xba 0x00 0x03 0xba 0x02>;
                      clock-names = "fck\0vp1\0vp2";
                     interrupts = <0x00 0x54 0x04 0x00 0x55 0x04>;
                        phandle = <0x66>;
                            ports {
                             phandle = <0x67>;
               spinlock@2a000000 {
                       compatible = "ti,am64-hwspinlock";
                          reg = <0x00 0x2a000000 0x00 0x1000>;
                         #hwlock-cells = <0x01>;
                       phandle = <0x68>;
                  mailbox@29000000 {
                           compatible = "ti,am64-mailbox";
                         reg = <0x00 0x29000000 0x00 0x200>;
                         interrupts = <0x00 0x4c 0x04 0x00 0x4d 0x04>;
                           ti,mbox-num-users = <0x04>;
                     ti,mbox-num-fifos = <0x10>;
                       phandle = <0x07>;
                           mbox-m4-0 {
                                   ti,mbox-rx = <0x00 0x00 0x00>;
                              ti,mbox-tx = <0x01 0x00 0x00>;
                                 phandle = <0x08>;
                            mbox-r5-0 {
                                    ti,mbox-rx = <0x02 0x00 0x00>;
                               ti,mbox-tx = <0x03 0x00 0x00>;
                                  phandle = <0x0b>;
                    ticsi2rx@30102000 {
                            compatible = "ti,j721e-csi2rx";
                          dmas = <0x0e 0x00 0x4700 0x00 0x0e 0x00 0x4701 0x00 0x0e 0x00 0x4702 0x00 0x0e 0x00 0x4703 0x00>;
                            dma-names = "rx0\0rx1\0rx2\0rx3";
                        reg = <0x00 0x30102000 0x00 0x1000>;
                       power-domains = <0x02 0xb6 0x01>;
                            ranges;
                       phandle = <0x69>;
                           csi-bridge@30101000 {
                                 compatible = "cdns,csi2rx";
                                   reg = <0x00 0x30101000 0x00 0x1000>;
                                  clocks = <0x03 0xb6 0x00 0x03 0xb6 0x03 0x03 0xb6 0x00 0x03 0xb6 0x00 0x03 0xb6 0x04 0x03 0xb6 0x04>;
                                    clock-names = "sys_clk\0p_clk\0pixel_if0_clk\0pixel_if1_clk\0pixel_if2_clk\0pixel_if3_clk";
                              phys = <0x1e>;
                             phy-names = "dphy";
                               phandle = <0x6a>;
                                   ports {
                                            port@0 {
                                               reg = <0x00>;
                                               phandle = <0x6b>;
                                          port@1 {
                                             reg = <0x01>;
                                             phandle = <0x6c>;
                                        port@2 {
                                                   reg = <0x02>;
                                                   phandle = <0x6d>;
                                      port@3 {
                                                 reg = <0x03>;
                                                 phandle = <0x6e>;
                                            port@4 {
                                               reg = <0x04>;
                                               phandle = <0x6f>;
               phy@30110000 {
                            compatible = "ti,j721e-dphy\0cdns,dphy";
                         reg = <0x00 0x30110000 0x00 0x1100>;
                        #phy-cells = <0x00>;
                         power-domains = <0x02 0xb9 0x01>;
                          phandle = <0x1e>;
             can@20701000 {
                          compatible = "bosch,m_can";
                            reg = <0x00 0x20701000 0x00 0x200 0x00 0x20708000 0x00 0x8000>;
                        reg-names = "m_can\0message_ram";
                            power-domains = <0x02 0x62 0x01>;
                            clocks = <0x03 0x62 0x06 0x03 0x62 0x01>;
                          clock-names = "hclk\0cclk";
                            interrupts = <0x00 0x9b 0x04 0x00 0x9c 0x04>;
                      interrupt-names = "int0\0int1";
                            bosch,mram-cfg = <0x00 0x80 0x40 0x40 0x40 0x40 0x20 0x20>;
                     phandle = <0x70>;
                watchdog@e000000 {
                         reg = <0x00 0xe000000 0x00 0x100>;
                          clocks = <0x03 0x7d 0x00>;
                         power-domains = <0x02 0x7d 0x01>;
                         assigned-clocks = <0x03 0x7d 0x00>;
                       assigned-clock-parents = <0x03 0x7d 0x02>;
                      phandle = <0x71>;
                 watchdog@e010000 {
                          reg = <0x00 0xe010000 0x00 0x100>;
                           clocks = <0x03 0x7e 0x00>;
                          power-domains = <0x02 0x7e 0x01>;
                          assigned-clocks = <0x03 0x7e 0x00>;
                        assigned-clock-parents = <0x03 0x7e 0x02>;
                       phandle = <0x72>;
                  watchdog@e020000 {
                           reg = <0x00 0xe020000 0x00 0x100>;
                            clocks = <0x03 0x7f 0x00>;
                           power-domains = <0x02 0x7f 0x01>;
                           assigned-clocks = <0x03 0x7f 0x00>;
                         assigned-clock-parents = <0x03 0x7f 0x02>;
                        phandle = <0x73>;
                   watchdog@e030000 {
                            reg = <0x00 0xe030000 0x00 0x100>;
                     clocks = <0x03 0x80 0x00>;
                            power-domains = <0x02 0x80 0x01>;
                            assigned-clocks = <0x03 0x80 0x00>;
                          assigned-clock-parents = <0x03 0x80 0x02>;
                         phandle = <0x74>;
                    watchdog@e0f0000 {
                     reg = <0x00 0xe0f0000 0x00 0x100>;
                      clocks = <0x03 0x82 0x00>;
                     power-domains = <0x02 0x82 0x01>;
                     assigned-clocks = <0x03 0x82 0x00>;
                           assigned-clock-parents = <0x03 0x82 0x02>;
                          phandle = <0x75>;
             pwm@23000000 {
                          compatible = "ti,am64-epwm\0ti,am3352-ehrpwm";
                         #pwm-cells = <0x03>;
                          reg = <0x00 0x23000000 0x00 0x100>;
                          power-domains = <0x02 0x56 0x01>;
                          clocks = <0x1f 0x00 0x03 0x56 0x00>;
                           clock-names = "tbclk\0fck";
                      phandle = <0x76>;
                 pwm@23010000 {
                      reg = <0x00 0x23010000 0x00 0x100>;
                      power-domains = <0x02 0x57 0x01>;
                      clocks = <0x1f 0x01 0x03 0x57 0x00>;
                          phandle = <0x77>;
             pwm@23020000 {
                          reg = <0x00 0x23020000 0x00 0x100>;
                          power-domains = <0x02 0x58 0x01>;
                          clocks = <0x1f 0x02 0x03 0x58 0x00>;
                      phandle = <0x78>;
                 pwm@23100000 {
                      compatible = "ti,am3352-ecap";
                      reg = <0x00 0x23100000 0x00 0x100>;
                      power-domains = <0x02 0x33 0x01>;
                      clocks = <0x03 0x33 0x00>;
                       phandle = <0x79>;
                  pwm@23110000 {
                       reg = <0x00 0x23110000 0x00 0x100>;
                       power-domains = <0x02 0x34 0x01>;
                       clocks = <0x03 0x34 0x00>;
                        phandle = <0x7a>;
                   pwm@23120000 {
                        reg = <0x00 0x23120000 0x00 0x100>;
                        power-domains = <0x02 0x35 0x01>;
                        clocks = <0x03 0x35 0x00>;
                         phandle = <0x7b>;
                    mcasp@2b00000 {
                        compatible = "ti,am33xx-mcasp-audio";
                        reg = <0x00 0x2b00000 0x00 0x2000 0x00 0x2b08000 0x00 0x400>;
                      reg-names = "mpu\0dat";
                            interrupts = <0x00 0xec 0x04 0x00 0xeb 0x04>;
                      interrupt-names = "tx\0rx";
                        dmas = <0x0e 0x00 0xc500 0x00 0x0e 0x00 0x4500 0x00>;
                      dma-names = "tx\0rx";
                      clocks = <0x03 0xbe 0x00>;
                      power-domains = <0x02 0xbe 0x01>;
                      assigned-clocks = <0x03 0xbe 0x00>;
                            assigned-clock-parents = <0x03 0xbe 0x02>;
                            phandle = <0x7c>;
               mcasp@2b10000 {
                           reg = <0x00 0x2b10000 0x00 0x2000 0x00 0x2b18000 0x00 0x400>;
                       interrupts = <0x00 0xee 0x04 0x00 0xed 0x04>;
                           dmas = <0x0e 0x00 0xc501 0x00 0x0e 0x00 0x4501 0x00>;
                         clocks = <0x03 0xbf 0x00>;
                         power-domains = <0x02 0xbf 0x01>;
                         assigned-clocks = <0x03 0xbf 0x00>;
                       assigned-clock-parents = <0x03 0xbf 0x02>;
                       phandle = <0x7d>;
                  mcasp@2b20000 {
                      reg = <0x00 0x2b20000 0x00 0x2000 0x00 0x2b28000 0x00 0x400>;
                          interrupts = <0x00 0xf0 0x04 0x00 0xef 0x04>;
                      dmas = <0x0e 0x00 0xc502 0x00 0x0e 0x00 0x4502 0x00>;
                            clocks = <0x03 0xc0 0x00>;
                            power-domains = <0x02 0xc0 0x01>;
                            assigned-clocks = <0x03 0xc0 0x00>;
                          assigned-clock-parents = <0x03 0xc0 0x02>;
                          phandle = <0x7e>;
             pruss@30040000 {
                        compatible = "ti,am625-pruss";
                       reg = <0x00 0x30040000 0x00 0x80000>;
                     power-domains = <0x02 0x51 0x01>;
                          ranges = <0x00 0x00 0x30040000 0x80000>;
                     phandle = <0x7f>;
                         memories@0 {
                                reg = <0x00 0x2000 0x2000 0x2000 0x10000 0x10000>;
                             reg-names = "dram0\0dram1\0shrdram2";
                             phandle = <0x80>;
                        cfg@26000 {
                                compatible = "ti,pruss-cfg\0syscon";
                                 reg = <0x26000 0x200>;
                               ranges = <0x00 0x26000 0x2000>;
                                 phandle = <0x81>;
                             clocks {
                                     coreclk-mux@3c {
                                                reg = <0x3c>;
                                                #clock-cells = <0x00>;
                                               clocks = <0x03 0x51 0x00 0x03 0x51 0x14>;
                                             assigned-clocks = <0x20>;
                                                 assigned-clock-parents = <0x03 0x51 0x14>;
                                                phandle = <0x20>;
                                           iepclk-mux@30 {
                                               reg = <0x30>;
                                              clocks = <0x03 0x51 0x03 0x20>;
                                                  assigned-clocks = <0x21>;
                                              assigned-clock-parents = <0x20>;
                                                   phandle = <0x21>;
                            interrupt-controller@20000 {
                                   compatible = "ti,pruss-intc";
                                   reg = <0x20000 0x2000>;
                                  interrupts = <0x00 0x58 0x04 0x00 0x59 0x04 0x00 0x5a 0x04 0x00 0x5b 0x04 0x00 0x5c 0x04 0x00 0x5d 0x04 0x00 0x5e 0x04 0x00 0x5f 0x04>;
                              interrupt-names = "host_intr0\0host_intr1\0host_intr2\0host_intr3\0host_intr4\0host_intr5\0host_intr6\0host_intr7";
                                phandle = <0x22>;
                           pru@34000 {
                                   compatible = "ti,am625-pru";
                                    reg = <0x34000 0x3000 0x22000 0x100 0x22400 0x100>;
                                reg-names = "iram\0control\0debug";
                                  firmware-name = "am62x-pru0-fw";
                               interrupt-parent = <0x22>;
                                  interrupts = <0x10 0x02 0x02>;
                             interrupt-names = "vring";
                                phandle = <0x82>;
                           pru@38000 {
                                    reg = <0x38000 0x3000 0x24000 0x100 0x24400 0x100>;
                                  firmware-name = "am62x-pru1-fw";
                                  interrupts = <0x12 0x03 0x03>;
                                phandle = <0x83>;
         thermal-zones {
             phandle = <0x84>;
                 main0-thermal {
                     polling-delay-passive = <0xfa>;
                           polling-delay = <0x1f4>;
                        thermal-sensors = <0x23 0x00>;
                         phandle = <0x85>;
                     trips {
                                 main0-crit {
                                        temperature = <0x19a28>;
                                     hysteresis = <0x7d0>;
                                     type = "critical";
                                        phandle = <0x86>;
                 main1-thermal {
                        thermal-sensors = <0x23 0x01>;
                         phandle = <0x87>;
                     trips {
                                 main1-crit {
                                     type = "critical";
                                        phandle = <0x88>;
        cpus {
                  cpu-map {
                            cluster0 {
                             phandle = <0x89>;
                                 core0 {
                                     cpu = <0x24>;
                                    core1 {
                                        cpu = <0x25>;
             cpu@0 {
                         compatible = "arm,cortex-a53";
                        reg = <0x00>;
                        device_type = "cpu";
                         enable-method = "psci";
                       i-cache-size = <0x8000>;
                            i-cache-line-size = <0x40>;
                      i-cache-sets = <0x100>;
                            d-cache-size = <0x8000>;
                         d-cache-line-size = <0x40>;
                           d-cache-sets = <0x80>;
                          next-level-cache = <0x26>;
                     operating-points-v2 = <0x27>;
                     clocks = <0x03 0x87 0x00>;
                            phandle = <0x24>;
               cpu@1 {
                          reg = <0x01>;
                       clocks = <0x03 0x88 0x00>;
                      phandle = <0x25>;
        opp-table {
                compatible = "operating-points-v2-ti-cpu";
                   opp-shared;
                 syscon = <0x1b>;
              phandle = <0x27>;
                  opp-200000000 {
                      opp-hz = <0x00 0xbebc200>;
                           opp-supported-hw = <0x01 0x07>;
                           clock-latency-ns = <0x5b8d80>;
                          opp-suspend;
              opp-400000000 {
                          opp-hz = <0x00 0x17d78400>;
                    opp-600000000 {
                        opp-hz = <0x00 0x23c34600>;
                  opp-800000000 {
                      opp-hz = <0x00 0x2faf0800>;
                opp-1000000000 {
                           opp-hz = <0x00 0x3b9aca00>;
                       opp-supported-hw = <0x01 0x06>;
             opp-1250000000 {
                        opp-hz = <0x00 0x4a817c80>;
                            opp-supported-hw = <0x01 0x04>;
         l2-cache0 {
                 compatible = "cache";
                 cache-level = <0x02>;
                 cache-size = <0x40000>;
                   cache-sets = <0x200>;
                   phandle = <0x26>;
      aliases {
                serial2 = "/bus@f0000/serial@2800000";
               mmc0 = "/bus@f0000/mmc@fa10000";
                    mmc1 = "/bus@f0000/mmc@fa00000";
        memory@80000000 {
                reg = <0x00 0x80000000 0x00 0x80000000>;
          reserved-memory {
                 ranges;
                     reg = <0x00 0x9c800000 0x00 0x300000>;
                          no-map;
                            phandle = <0x8a>;
                            no-map;
                      phandle = <0x09>;
                     reg = <0x00 0x9cc00000 0x00 0xe00000>;
                          no-map;
                            phandle = <0x0a>;
               r5f-dma-memory@9da00000 {
                       reg = <0x00 0x9da00000 0x00 0x100000>;
                            no-map;
                      phandle = <0x0c>;
                 r5f-memory@9db00000 {
                          no-map;
                            phandle = <0x0d>;
                           phandle = <0x8b>;
              tfa@9e780000 {
                         no-map;
                           phandle = <0x8c>;
              optee@9e800000 {
                         reg = <0x00 0x9e800000 0x00 0x1800000>;
                     no-map;
                       phandle = <0x8d>;
         regulator-0 {
               compatible = "regulator-fixed";
             regulator-name = "vmain_pd";
              regulator-min-microvolt = <0x4c4b40>;
              regulator-max-microvolt = <0x4c4b40>;
              regulator-always-on;
                   regulator-boot-on;
                  phandle = <0x28>;
     regulator-1 {
                 regulator-name = "vcc_5v0";
                   vin-supply = <0x28>;
                 regulator-boot-on;
                phandle = <0x2c>;
           regulator-2 {
               regulator-name = "vcc_3v3_sys";
             regulator-min-microvolt = <0x325aa0>;
             regulator-max-microvolt = <0x325aa0>;
                   regulator-boot-on;
                  phandle = <0x29>;
     regulator-3 {
                 regulator-name = "vdd_mmc1";
                  regulator-boot-on;
                 enable-active-high;
               vin-supply = <0x29>;
                gpio = <0x2a 0x03 0x00>;
                 phandle = <0x18>;
            regulator-4 {
                  compatible = "regulator-gpio";
                 regulator-name = "tlv71033";
             pinctrl-0 = <0x2b>;
               regulator-min-microvolt = <0x1b7740>;
               regulator-boot-on;
              vin-supply = <0x2c>;
               gpios = <0x2d 0x1f 0x00>;
               states = <0x1b7740 0x00 0x325aa0 0x01>;
                   phandle = <0x19>;
      regulator-7 {
                  regulator-name = "vcc_1v8";
                    regulator-max-microvolt = <0x1b7740>;
                  regulator-boot-on;
                 phandle = <0x8e>;
            __symbols__ {
                  psci = "/firmware/psci";
               a53_timer0 = "/timer-cl0-cpu0";
             pmu = "/pmu";
             cbass_main = "/bus@f0000";
                cbass_mcu = "/bus@f0000/bus@4000000";
                mcu_pmx0 = "/bus@f0000/bus@4000000/pinctrl@4084000";
                 mcu_uart0 = "/bus@f0000/bus@4000000/serial@4a00000";
                  mcu_i2c0 = "/bus@f0000/bus@4000000/i2c@4900000";
               mcu_spi0 = "/bus@f0000/bus@4000000/spi@4b00000";
                    mcu_spi1 = "/bus@f0000/bus@4000000/spi@4b10000";
                 mcu_gpio_intr = "/bus@f0000/bus@4000000/interrupt-controller@4210000";
                mcu_gpio0 = "/bus@f0000/bus@4000000/gpio@4201000";
                   mcu_rti0 = "/bus@f0000/bus@4000000/watchdog@4880000";
                   mcu_m4fss = "/bus@f0000/bus@4000000/m4fss@5000000";
             cbass_wakeup = "/bus@f0000/bus@b00000";
                   wkup_conf = "/bus@f0000/bus@b00000/syscon@43000000";
                    chipid = "/bus@f0000/bus@b00000/syscon@43000000/chipid@14";
              wkup_uart0 = "/bus@f0000/bus@b00000/serial@2b300000";
              wkup_i2c0 = "/bus@f0000/bus@b00000/i2c@2b200000";
                  wkup_rti0 = "/bus@f0000/bus@b00000/watchdog@2b000000";
                 wkup_rtc0 = "/bus@f0000/bus@b00000/rtc@2b1f0000";
             wkup_vtm0 = "/bus@f0000/bus@b00000/temperature-sensor@b00000";
                    wkup_r5fss0 = "/bus@f0000/bus@b00000/r5fss@78000000";
                    wkup_r5fss0_core0 = "/bus@f0000/bus@b00000/r5fss@78000000/r5f@78000000";
                 oc_sram = "/bus@f0000/sram@70000000";
                 gic500 = "/bus@f0000/interrupt-controller@1800000";
                   gic_its = "/bus@f0000/interrupt-controller@1800000/msi-controller@1820000";
             main_conf = "/bus@f0000/syscon@100000";
                   phy_gmii_sel = "/bus@f0000/syscon@100000/phy@4044";
             epwm_tbclk = "/bus@f0000/syscon@100000/clock@4130";
               dss_oldi_io_ctrl = "/bus@f0000/syscon@100000/dss-oldi-io-ctrl@8600";
                dmss = "/bus@f0000/bus@48000000";
                    secure_proxy_main = "/bus@f0000/bus@48000000/mailbox@4d000000";
                  inta_main_dmss = "/bus@f0000/bus@48000000/interrupt-controller@48000000";
              main_bcdma = "/bus@f0000/bus@48000000/dma-controller@485c0100";
                    main_pktdma = "/bus@f0000/bus@48000000/dma-controller@485c0000";
                 dmsc = "/bus@f0000/system-controller@44043000";
               k3_pds = "/bus@f0000/system-controller@44043000/power-controller";
                  k3_clks = "/bus@f0000/system-controller@44043000/clock-controller";
                    k3_reset = "/bus@f0000/system-controller@44043000/reset-controller";
             crypto = "/bus@f0000/crypto@40900000";
                    rng = "/bus@f0000/crypto@40900000/rng@40910000";
                 main_pmx0 = "/bus@f0000/pinctrl@f4000";
               main_uart0_pins_default = "/bus@f0000/pinctrl@f4000/main-uart0-pins-default";
               main_i2c1_pins_default = "/bus@f0000/pinctrl@f4000/main-i2c1-pins-default";
                 main_mmc0_pins_default = "/bus@f0000/pinctrl@f4000/main-mmc0-pins-default";
                   main_mmc1_pins_default = "/bus@f0000/pinctrl@f4000/main-mmc1-pins-default";
             vdd_sd_dv_pins_default = "/bus@f0000/pinctrl@f4000/vdd-sd-dv-pins-default";
               main_gpio1_ioexp_intr_pins_default = "/bus@f0000/pinctrl@f4000/main-gpio1-ioexp-intr-pins-default";
                 main_uart0 = "/bus@f0000/serial@2800000";
             main_uart1 = "/bus@f0000/serial@2810000";
                 main_uart2 = "/bus@f0000/serial@2820000";
             main_uart3 = "/bus@f0000/serial@2830000";
                 main_uart4 = "/bus@f0000/serial@2840000";
             main_uart5 = "/bus@f0000/serial@2850000";
                 main_uart6 = "/bus@f0000/serial@2860000";
             main_i2c0 = "/bus@f0000/i2c@20000000";
                    main_i2c1 = "/bus@f0000/i2c@20010000";
                   exp1 = "/bus@f0000/i2c@20010000/gpio@22";
               main_i2c2 = "/bus@f0000/i2c@20020000";
              main_i2c3 = "/bus@f0000/i2c@20030000";
             main_spi0 = "/bus@f0000/spi@20100000";
                    main_spi1 = "/bus@f0000/spi@20110000";
                   main_spi2 = "/bus@f0000/spi@20120000";
                  main_gpio_intr = "/bus@f0000/interrupt-controller@a00000";
             main_gpio0 = "/bus@f0000/gpio@600000";
                    main_gpio1 = "/bus@f0000/gpio@601000";
                   sdhci0 = "/bus@f0000/mmc@fa10000";
              sdhci1 = "/bus@f0000/mmc@fa00000";
                 sdhci2 = "/bus@f0000/mmc@fa20000";
                    gpu = "/bus@f0000/gpu@fd00000";
                  usbss0 = "/bus@f0000/dwc3-usb@f900000";
                usb0 = "/bus@f0000/dwc3-usb@f900000/usb@31000000";
                   usbss1 = "/bus@f0000/dwc3-usb@f910000";
                 usb1 = "/bus@f0000/dwc3-usb@f910000/usb@31100000";
                    fss = "/bus@f0000/bus@fc00000";
                  ospi0 = "/bus@f0000/bus@fc00000/spi@fc40000";
                  cpsw3g = "/bus@f0000/ethernet@8000000";
                cpsw_port1 = "/bus@f0000/ethernet@8000000/ethernet-ports/port@1";
                    cpsw_port2 = "/bus@f0000/ethernet@8000000/ethernet-ports/port@2";
                cpsw3g_mdio = "/bus@f0000/ethernet@8000000/mdio@f00";
                dss = "/bus@f0000/dss@30200000";
             dss_ports = "/bus@f0000/dss@30200000/ports";
              hwspinlock = "/bus@f0000/spinlock@2a000000";
               mailbox0_cluster0 = "/bus@f0000/mailbox@29000000";
                  mbox_m4_0 = "/bus@f0000/mailbox@29000000/mbox-m4-0";
                   mbox_r5_0 = "/bus@f0000/mailbox@29000000/mbox-r5-0";
                    ti_csi2rx0 = "/bus@f0000/ticsi2rx@30102000";
             cdns_csi2rx0 = "/bus@f0000/ticsi2rx@30102000/csi-bridge@30101000";
                csi0_port0 = "/bus@f0000/ticsi2rx@30102000/csi-bridge@30101000/ports/port@0";
                csi0_port1 = "/bus@f0000/ticsi2rx@30102000/csi-bridge@30101000/ports/port@1";
                csi0_port2 = "/bus@f0000/ticsi2rx@30102000/csi-bridge@30101000/ports/port@2";
                csi0_port3 = "/bus@f0000/ticsi2rx@30102000/csi-bridge@30101000/ports/port@3";
                csi0_port4 = "/bus@f0000/ticsi2rx@30102000/csi-bridge@30101000/ports/port@4";
                dphy0 = "/bus@f0000/phy@30110000";
                   main_mcan0 = "/bus@f0000/can@20701000";
                 main_rti0 = "/bus@f0000/watchdog@e000000";
                    main_rti1 = "/bus@f0000/watchdog@e010000";
               main_rti2 = "/bus@f0000/watchdog@e020000";
                  main_rti3 = "/bus@f0000/watchdog@e030000";
             main_rti15 = "/bus@f0000/watchdog@e0f0000";
               epwm0 = "/bus@f0000/pwm@23000000";
                  epwm1 = "/bus@f0000/pwm@23010000";
             epwm2 = "/bus@f0000/pwm@23020000";
                ecap0 = "/bus@f0000/pwm@23100000";
                   ecap1 = "/bus@f0000/pwm@23110000";
              ecap2 = "/bus@f0000/pwm@23120000";
                 mcasp0 = "/bus@f0000/mcasp@2b00000";
                  mcasp1 = "/bus@f0000/mcasp@2b10000";
                   mcasp2 = "/bus@f0000/mcasp@2b20000";
                    pruss = "/bus@f0000/pruss@30040000";
             pruss_mem = "/bus@f0000/pruss@30040000/memories@0";
               pruss_cfg = "/bus@f0000/pruss@30040000/cfg@26000";
                  pruss_coreclk_mux = "/bus@f0000/pruss@30040000/cfg@26000/clocks/coreclk-mux@3c";
               pruss_iepclk_mux = "/bus@f0000/pruss@30040000/cfg@26000/clocks/iepclk-mux@30";
              pruss_intc = "/bus@f0000/pruss@30040000/interrupt-controller@20000";
               pru0 = "/bus@f0000/pruss@30040000/pru@34000";
               pru1 = "/bus@f0000/pruss@30040000/pru@38000";
               thermal_zones = "/thermal-zones";
                   main0_thermal = "/thermal-zones/main0-thermal";
                 main0_crit = "/thermal-zones/main0-thermal/trips/main0-crit";
                 main1_thermal = "/thermal-zones/main1-thermal";
               main1_crit = "/thermal-zones/main1-thermal/trips/main1-crit";
               cluster0 = "/cpus/cpu-map/cluster0";
                cpu0 = "/cpus/cpu@0";
                cpu1 = "/cpus/cpu@1";
                a53_opp_table = "/opp-table";
                L2_0 = "/l2-cache0";
                 rtos_ipc_memory_region = "/reserved-memory/ipc-memories@9c800000";
                    mcu_m4fss_dma_memory_region = "/reserved-memory/m4f-dma-memory@9cb00000";
                mcu_m4fss_memory_region = "/reserved-memory/m4f-memory@9cc00000";
                    wkup_r5fss0_core0_dma_memory_region = "/reserved-memory/r5f-dma-memory@9da00000";
                wkup_r5fss0_core0_memory_region = "/reserved-memory/r5f-memory@9db00000";
                    lpm_ctx_ddr = "/reserved-memory/lpm-memory@9e700000";
                    secure_tfa_ddr = "/reserved-memory/tfa@9e780000";
                secure_ddr = "/reserved-memory/optee@9e800000";
              vmain_pd = "/regulator-0";
                 vcc_5v0 = "/regulator-1";
             vcc_3v3_sys = "/regulator-2";
             vdd_mmc1 = "/regulator-3";
                vdd_sd_dv = "/regulator-4";
                  vcc_1v8 = "/regulator-7";
    There are some warning messages when converting, which I not sure if it will affected the DTS
  • Hi Suan,
    Sorry for my late response.
    I am not sure if you have resolved the issue, but I just got a chance reviewed your DTS, and it seems the "pruss" node is not disabled.
  • Hi Suan,
    I am wondering if you have resolved this issue. If not, please ignore my previous comment about disabling pruss, but disable "main_rti15" node in your kernel dts to see if it solves the kernel crash issue.
