Other Parts Discussed in Thread: TPS65070, AM1808, OMAP-L138
is there a reason why both, logic PD and SPECTRUM DIGITAL power DDR2 Memory and controller from a LDO?
Is it possible to use a DCDC from the TPS65070 instead?
Thomas.
Thomas,
All the static voltages are supplied via an LDO, because the core voltages can be varied to take advantage of the Dynamic Voltage Frequency Scaling (DVFS) of AM18x. There is no reason why one couldn't power all the respective rails from a single supply for each rail, however then you cannot take advantage of the DVFS feature.
