TDA4VM: Report segmentation fault at runtime
Part Number: TDA4VM
Hi team,
The program runs with a segmentation fault error with the following prompt. Restart and the problem persists.
Could you help check this case? Thanks.
Cherry
  • Hi Cherry,
    Seems to be the graph verify has failed.
    Could you please enable the remote core logs by running "source ./vision_apps_init.sh" before running the application.
    Please share both the logs (in .txt format instead of screenshot).
    Nikhil
