TDA4VM: unable to run app multi camera demo when enable openvx ldc or mosaic node
Part Number: TDA4VM
Hello Ti expert:
I am running [rtos + qnx sdk805] on our customed board(based on TDA4VM),  I add a camera driver and try to run app multi camera in vision_apps.
My camera has a resolution of 1280x1285(there are 5 embedded lines so the actual resolution is 1280x1280), The 4 camera frame was integrited by TI9702 and output as a interleaved manner.
But if I try to create mosaic or ldc node, the application would stock at vxVerifyGraph, I only can write camera frame from capture node. When running sdk0703,  the same code runs fine. Could you help me to check whether my config for LDC and masaic is wrong?
below is my main.c
