TDA4VE-Q1: Clock Tree Tool
Part Number: TDA4VE-Q1
Hi TI team,
I am looking for the TDA4VE Clock Tree Tool. Did you released it ?
Thanks for your support.
Stephan.
  • Hello Stephan,
    We do not offer a Clock Tree Tool for TDA4VE.  Rather, we provide a Linux command line tool called k3conf that can query/report the state of the device including PLLs and clock frequencies.
    • k3conf dump processor
    • k3conf dump device
    • k3conf dump clocks
    Kyle
  • Hello Kyle,
    understood, but I am hardware engineer, not software. I am trying to understand clock tree configuration at board level, without using a Linux OS.
    The TDA4VE reference manual is not pretty clear as some signal name are not consistent from on chapter to the other. The TDA4VE has 2 LPDDR4 controllers, could you tell me the PLL number which is clocking the two different LPDDR4 controllers. Thanks for your support. Stephan.
  • Hello Stephan,
    The primary DDR clock is generated from MAIN_PLL12.HSDIV0 and MAIN_PLL26.HSDIV0 for DDR0 and DDR1 respectively.
    Kyle
