TDA4VM: SR1.0 Linux system stuck
Part Number: TDA4VM
Hi TI Experts,
SDK8.4 boots successfully on SR1.1 device, but fails to boot on SR1.0.
This board is our own design, can you give me some suggestions?
Below is the running log of SPL.
U-Boot SPL 2021.01 (Dec 28 2022 - 13:48:30 +0800)
Model: Texas Instruments K3 J721E SoC
SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.6(release):v2.7-rc0-dirty
NOTICE:  BL31: Built : 09:18:58, Aug 30 2022
I/TC:
I/TC: OP-TEE version: 3.17.0-125-g15a746d28 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Tue Aug 30 09:19:19 UTC 2022 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
U-Boot SPL 2021.01 (Dec 28 2022 - 13:48:17 +0800)
U-Boot 2021.01 (Dec 28 2022 - 13:48:17 +0800)
SoC:   J721E SR1.0 GP
DRAM:  4 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from FAT... OK
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   No ethernet found.
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
443 bytes read in 10 ms (43 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
1 bytes read in 13 ms (0 Bytes/s)
Already setup.
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
847284 bytes read in 47 ms (17.2 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 847284 bytes: Success!
302028 bytes read in 24 ms (12 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 302028 bytes: Success!
Failed to load '/lib/firmware/j7-main-r5f1_0-fw'
Failed to load '/lib/firmware/j7-main-r5f1_1-fw'
1473300 bytes read in 72 ms (19.5 MiB/s)
Load Remote Processor 6 with data@addr=0x82000000 1473300 bytes: Success!
Load Remote Processor 7 with data@addr=0x82000000 1473300 bytes: Success!
12980176 bytes read in 547 ms (22.6 MiB/s)
Load Remote Processor 8 with data@addr=0x82000000 12980176 bytes: Success!
18520576 bytes read in 775 ms (22.8 MiB/s)
117806 bytes read in 16 ms (7 MiB/s)
   Loading Device Tree to 000000008fee0000, end 000000008fffffff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.120-g95b90aa828 (fuquanfeng@RD15) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Fri Dec 30 15:15:30 CST 2022
[    0.000000] Machine model: Texas Instruments K3 J721E SoC
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000aeffffff]
[    0.000000]   node   0: [mem 0x00000000af000000-0x00000000afffffff]
[    0.000000]   node   0: [mem 0x00000000b0000000-0x00000000b7ffffff]
[    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000e5ffffff]
[    0.000000]   node   0: [mem 0x00000000e6000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008a6ffffff]
[    0.000000]   node   0: [mem 0x00000008a7000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] cma: Reserved 400 MiB at 0x00000000e7000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=6623acc4-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x000000009a800000-0x000000009e800000] (64MB)
[    0.000000] Memory: 1827988K/4194304K available (10880K kernel code, 1126K rwdata, 4188K rodata, 1792K init, 431K bss, 1956716K reserved, 409600K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8a7800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008a7030000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a7040000
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008409] Console: colour dummy device 80x25
[    0.012974] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023644] pid_max: default: 32768 minimum: 301
[    0.028400] LSM: Security Framework initializing
[    0.033158] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.040736] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.049522] rcu: Hierarchical SRCU implementation.
[    0.054579] Platform MSI: msi-controller@1820000 domain created
[    0.060836] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.070139] EFI services will not be available.
[    0.074872] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[    0.088145] Detected PIPT I-cache on CPU1
[    0.088168] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.088179] GICv3: CPU1: using allocated LPI pending table @0x00000008a7050000
[    0.088215] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.088264] smp: Brought up 1 node, 2 CPUs
[    0.117609] SMP: Total of 2 processors activated.
[    0.122414] CPU features: detected: 32-bit EL0 Support
[    0.127668] CPU features: detected: CRC32 instructions
[    0.141648] CPU: All CPU(s) started at EL2
[    0.145846] alternatives: patching kernel code
[    0.150873] devtmpfs: initialized
[    0.160084] KASLR disabled due to lack of seed
[    0.164733] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.174695] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.186837] pinctrl core: initialized pinctrl subsystem
[    0.192492] DMI not present or invalid.
[    0.196739] NET: Registered protocol family 16
[    0.201965] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.209282] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.217344] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.225645] thermal_sys: Registered thermal governor 'step_wise'
[    0.225647] thermal_sys: Registered thermal governor 'power_allocator'
[    0.232239] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.245872] ASID allocator initialised with 65536 entries
[    0.263519] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.270374] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.277224] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.284071] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.291534] cryptd: max_cpu_qlen set to 1000
[    0.297526] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.0 JTAGID[0x0bb6402f] Detected
[    0.306305] vsys_3v3: supplied by evm_12v0
[    0.310666] vsys_5v0: supplied by evm_12v0
[    0.315054] vdd_mmc1: supplied by vsys_3v3
[    0.319713] iommu: Default domain type: Translated
[    0.324850] SCSI subsystem initialized
[    0.328895] mc: Linux media interface: v0.10
[    0.333278] videodev: Linux video capture interface: v2.00
[    0.338907] pps_core: LinuxPPS API ver. 1 registered
[    0.343978] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.353316] PTP clock support registered
[    0.357334] EDAC MC: Ver: 3.0.0
[    0.361076] FPGA manager framework
[    0.364586] Advanced Linux Sound Architecture Driver Initialized.
[    0.371193] clocksource: Switched to clocksource arch_sys_counter
[    0.377516] VFS: Disk quotas dquot_6.6.0
[    0.381549] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.391190] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[    0.397481] NET: Registered protocol family 2
[    0.402222] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.410876] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.419631] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.427833] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.435642] TCP: Hash tables configured (established 32768 bind 32768)
[    0.442431] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.449324] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.456724] NET: Registered protocol family 1
[    0.461451] RPC: Registered named UNIX socket transport module.
[    0.467509] RPC: Registered udp transport module.
[    0.472324] RPC: Registered tcp transport module.
[    0.477128] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.483712] PCI: CLS 0 bytes, default 64
[    0.488091] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.498425] Initialise system trusted keyrings
[    0.503067] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.511244] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.517462] NFS: Registering the id_resolver key type
[    0.522648] Key type id_resolver registered
[    0.526922] Key type id_legacy registered
[    0.531046] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.537894] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.545535] 9p: Installing v9fs 9p2000 file system support
[    0.570832] Key type asymmetric registered
[    0.575018] Asymmetric key parser 'x509' registered
[    0.580015] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.587574] io scheduler mq-deadline registered
[    0.592198] io scheduler kyber registered
[    0.597547] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.603716] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.611928] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.618194] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.625941] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.633910] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    0.642163] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[    0.649245] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[    0.657877] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.670402] brd: module loaded
[    0.676927] loop: module loaded
[    0.680726] megasas: 07.714.04.00-rc1
[    0.686093] tun: Universal TUN/TAP device driver, 1.6
[    0.691516] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.697921] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.703992] sky2: driver version 1.30
[    0.708231] VFIO - User Level meta-driver version: 0.3
[    0.713946] i2c /dev entries driver
[    0.718116] sdhci: Secure Digital Host Controller Interface driver
[    0.724441] sdhci: Copyright(c) Pierre Ossman
[    0.729047] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.735284] ledtrig-cpu: registered to indicate activity on CPUs
[    0.741592] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.748745] optee: probing for conduit method.
[    0.753306] optee: revision 3.17 (15a746d2)
[    0.753433] optee: dynamic shared memory is enabled
E/TC:1 0 std_entry_with_parg:234 Bad arg address 0x8a8074000
[    0.768234] optee: initialized driver
[    0.772951] NET: Registered protocol family 17
[    0.777566] 9pnet: Installing 9P2000 support
[    0.781962] Key type dns_resolver registered
[    0.786411] Loading compiled-in X.509 certificates
[    0.795808] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.802144] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.809904] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
[    0.854953] omap_i2c 2010000.i2c: bus 0 rev0.12 at 400 kHz
[    0.861030] omap_i2c 2030000.i2c: bus 1 rev0.12 at 400 kHz
[    0.867444] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[    0.877420] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    0.886238] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[    0.896112] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    0.905638] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    0.915518] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    0.922277] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    0.931357] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    0.941515] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    0.948278] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    0.956220] printk: console [ttyS2] disabled
[    0.960614] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 21, base_baud = 3000000) is a 8250
[    0.969356] printk: console [ttyS2] enabled
[    0.977791] printk: bootconsole [ns16550a0] disabled
[    0.989717] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[    1.035202] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.043544] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver unknown
[    1.051582] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    1.065564] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
Thanks in advance.
    Can you please  share the logs for both 1.0 & 1.1?
    Also can you confirm that 1.0 hangs after:
    Is this is a GP device or a HS(high secure sample)?
    - Keerthy
    Thanks for your reply!
    Below is the running log of SPL on SR1.1.
    I/TC:
    SoC:   J721E SR1.0 GP
    DRAM:  4 GiB
    Flash: 0 Bytes
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    443 bytes read in 8 ms (53.7 KiB/s)
    Running uenvcmd ...
    1 bytes read in 12 ms (0 Bytes/s)
    Already setup.
    847284 bytes read in 45 ms (18 MiB/s)
    302028 bytes read in 23 ms (12.5 MiB/s)
    1473300 bytes read in 71 ms (19.8 MiB/s)
    12980176 bytes read in 546 ms (22.7 MiB/s)
    18455040 bytes read in 769 ms (22.9 MiB/s)
    115573 bytes read in 14 ms (7.9 MiB/s)
    Starting kernel ...
    [    0.000000] Linux version 5.10.120-g95b90aa828 (fuquanfeng@RD15) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #4 SMP PREEMPT Wed Apr 12 09:42:22 CST 2023
    [    0.000000] Memory: 1828064K/4194304K available (10816K kernel code, 1126K rwdata, 4188K rodata, 1792K init, 433K bss, 1956640K reserved, 409600K cma-reserved)
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008405] Console: colour dummy device 80x25
    [    0.012969] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023640] pid_max: default: 32768 minimum: 301
    [    0.028398] LSM: Security Framework initializing
    [    0.033155] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.040732] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.049521] rcu: Hierarchical SRCU implementation.
    [    0.054574] Platform MSI: msi-controller@1820000 domain created
    [    0.060832] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070135] EFI services will not be available.
    [    0.074867] smp: Bringing up secondary CPUs ...
    [    0.088138] Detected PIPT I-cache on CPU1
    [    0.088160] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.088171] GICv3: CPU1: using allocated LPI pending table @0x00000008a7050000
    [    0.088205] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.088257] smp: Brought up 1 node, 2 CPUs
    [    0.117603] SMP: Total of 2 processors activated.
    [    0.122408] CPU features: detected: 32-bit EL0 Support
    [    0.127663] CPU features: detected: CRC32 instructions
    [    0.141632] CPU: All CPU(s) started at EL2
    [    0.145829] alternatives: patching kernel code
    [    0.150855] devtmpfs: initialized
    [    0.159965] KASLR disabled due to lack of seed
    [    0.164605] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.174567] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.186570] pinctrl core: initialized pinctrl subsystem
    [    0.192224] DMI not present or invalid.
    [    0.196475] NET: Registered protocol family 16
    [    0.201702] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.209020] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.217080] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.225381] thermal_sys: Registered thermal governor 'step_wise'
    [    0.225383] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.231967] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.245601] ASID allocator initialised with 65536 entries
    [    0.261960] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.268816] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.275662] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.282508] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.289964] cryptd: max_cpu_qlen set to 1000
    [    0.295955] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.0 JTAGID[0x0bb6402f] Detected
    [    0.304722] vsys_3v3: supplied by evm_12v0
    [    0.309075] vsys_5v0: supplied by evm_12v0
    [    0.313380] vdd_mmc1: supplied by vsys_3v3
    [    0.317910] iommu: Default domain type: Translated
    [    0.323041] SCSI subsystem initialized
    [    0.327063] mc: Linux media interface: v0.10
    [    0.331445] videodev: Linux video capture interface: v2.00
    [    0.337076] pps_core: LinuxPPS API ver. 1 registered
    [    0.342147] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.351485] PTP clock support registered
    [    0.355502] EDAC MC: Ver: 3.0.0
    [    0.359210] FPGA manager framework
    [    0.362724] Advanced Linux Sound Architecture Driver Initialized.
    [    0.369326] clocksource: Switched to clocksource arch_sys_counter
    [    0.375647] VFS: Disk quotas dquot_6.6.0
    [    0.379680] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.389317] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
    [    0.395607] NET: Registered protocol family 2
    [    0.400353] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.408998] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.417750] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.425953] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
    [    0.433770] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.440563] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.447455] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.454858] NET: Registered protocol family 1
    [    0.459600] RPC: Registered named UNIX socket transport module.
    [    0.465657] RPC: Registered udp transport module.
    [    0.470471] RPC: Registered tcp transport module.
    [    0.475275] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.481860] PCI: CLS 0 bytes, default 64
    [    0.486243] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.496487] Initialise system trusted keyrings
    [    0.501117] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.509264] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.515489] NFS: Registering the id_resolver key type
    [    0.520674] Key type id_resolver registered
    [    0.524948] Key type id_legacy registered
    [    0.529066] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.535914] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.543555] 9p: Installing v9fs 9p2000 file system support
    [    0.569297] Key type asymmetric registered
    [    0.573483] Asymmetric key parser 'x509' registered
    [    0.578481] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.586039] io scheduler mq-deadline registered
    [    0.590664] io scheduler kyber registered
    [    0.595915] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.602075] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.610059] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.616325] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.624040] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.631944] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.640210] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.647292] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.655875] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.668167] brd: module loaded
    [    0.674700] loop: module loaded
    [    0.678473] megasas: 07.714.04.00-rc1
    [    0.683706] tun: Universal TUN/TAP device driver, 1.6
    [    0.689088] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.695493] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.701563] sky2: driver version 1.30
    [    0.705763] VFIO - User Level meta-driver version: 0.3
    [    0.711438] i2c /dev entries driver
    [    0.715541] sdhci: Secure Digital Host Controller Interface driver
    [    0.721862] sdhci: Copyright(c) Pierre Ossman
    [    0.726449] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.732627] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.738904] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.746025] optee: probing for conduit method.
    [    0.750588] optee: revision 3.17 (15a746d2)
    [    0.750719] optee: dynamic shared memory is enabled
    E/TC:1 0 std_entry_with_parg:234 Bad arg address 0x8a8027000
    [    0.765520] optee: initialized driver
    [    0.770161] NET: Registered protocol family 17
    [    0.774777] 9pnet: Installing 9P2000 support
    [    0.779175] Key type dns_resolver registered
    [    0.783629] Loading compiled-in X.509 certificates
    [    0.792041] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.798392] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.806037] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
    [    0.849581] omap_i2c 2010000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.855684] omap_i2c 2030000.i2c: bus 1 rev0.12 at 400 kHz
    [    0.862115] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    0.872095] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    0.880910] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    0.890778] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    0.900290] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    0.910168] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    0.916927] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    0.925940] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    0.936086] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    0.942850] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    0.950787] printk: console [ttyS2] disabled
    [    0.955180] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 21, base_baud = 3000000) is a 8250
    [    0.963923] printk: console [ttyS2] enabled
    [    0.972359] printk: bootconsole [ns16550a0] disabled
    [    0.984195] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.029334] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.037674] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver unknown
    [    1.045714] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.059674] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    1.168950] sdhci-am654 4f80000.mmc: sdhci_am654_probe Start
    [    1.174612] sdhci-am654 4fb0000.mmc: sdhci_am654_probe Start
    [    1.174617] sdhci-am654 4f80000.mmc: sdhci_am654_probe 11
    [    1.180261] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 11
    [    1.180331] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 22
    [    1.185693] sdhci-am654 4f80000.mmc: sdhci_am654_probe 22
    [    1.191083] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 33
    [    1.196426] sdhci-am654 4f80000.mmc: sdhci_am654_probe 33
    [    1.201864] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 44
    [    1.207206] sdhci-am654 4f80000.mmc: sdhci_am654_probe 44
    [    1.212602] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 55
    [    1.217960] sdhci-am654 4f80000.mmc: sdhci_am654_probe 55
    [    1.223383] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 66
    [    1.228735] sdhci-am654 4f80000.mmc: sdhci_am654_probe 66
    [    1.245094] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 77
    [    1.250508] sdhci_am654_init 4fb0000.mmc Start
    [    1.255169] sdhci_am654_init 4fb0000.mmc abc
    [    1.255206] sdhci-am654 4f80000.mmc: sdhci_am654_probe 77
    [    1.259651] sdhci_am654_init 4fb0000.mmc 111
    [    1.264989] sdhci_am654_init 4f80000.mmc Start
    [    1.270664] sdhci_am654_init 4fb0000.mmc 222
    [    1.274023] sdhci_am654_init 4f80000.mmc abc
    [    1.278500] sdhci_am654_init 4fb0000.mmc 333
    [    1.282888] sdhci_am654_init 4f80000.mmc 123
    [    1.287335] sdhci_am654_init 4fb0000.mmc 444
    [    1.291742] sdhci_am654_init 4f80000.mmc 456
    [    1.300602] sdhci_am654_init 4f80000.mmc 789
    [    1.305040] sdhci_am654_init 4f80000.mmc 111
    [    1.309476] sdhci_am654_init 4f80000.mmc 222
    [    1.313912] sdhci_am654_init 4f80000.mmc 333
    [    1.318376] sdhci_am654_init 4f80000.mmc 444
    [    1.318409] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    1.322869] sdhci_am654_init 4f80000.mmc 555
    [    1.333761] mmc1: CQHCI version 5.10
    [    1.333796] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    1.337325] sdhci_am654_init 4f80000.mmc 666
    [    1.337336] sdhci_am654_init 4f80000.mmc 777
    [    1.348314] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    1.359572] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    1.366394] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    1.373605] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.384245] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    1.393580] mmc1: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.401100] sdhci_am654_init 4f80000.mmc 888
    [    1.405629] sdhci-am654 4f80000.mmc: sdhci_am654_probe 88
    [    1.411114] sdhci-am654 4f80000.mmc: sdhci_am654_probe 99
    [    1.418300] spi-nor spi0.0: mt35xl512aba (65536 Kbytes)
    [    1.423532] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    1.430131] Creating 8 MTD partitions on "47040000.spi.0":
    [    1.435602] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.441599] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.447267] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.453022] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.458544] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    1.464237] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
    [    1.470343] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.476103] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.483045] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.490421] mmc1: Command Queue Engine enabled
    [    1.494865] mmc1: new DDR MMC card at address 0001
    [    1.499932] mmcblk1: mmc1:0001 8GUF4R 7.28 GiB
    [    1.504534] mmcblk1boot0: mmc1:0001 8GUF4R partition 1 31.9 MiB
    [    1.510516] mmcblk1boot1: mmc1:0001 8GUF4R partition 2 31.9 MiB
    [    1.516508] mmcblk1rpmb: mmc1:0001 8GUF4R partition 3 4.00 MiB, chardev (237:0)
    [    1.525092]  mmcblk1: p1 p2 p3 p4 < p5 p6 p7 p8 >
    [    1.529340] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.538150] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver unknown
    [    1.546204] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.559896] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    1.566920] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.574152] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.580489] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    1.590805] sdhci-am654 4fb0000.mmc: sdhci_am654_probe Start
    [    1.590807] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    1.590825] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    1.596474] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 11
    [    1.604773] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    1.610983] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 22
    [    1.616303] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    1.623572] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 33
    [    1.628973] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    1.636272] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 44
    [    1.641641] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    1.648922] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 55
    [    1.664889] ALSA device list:
    [    1.667025] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 66
    [    1.669944]   No soundcards found.
    [    1.678870] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 77
    [    1.684269] sdhci_am654_init 4fb0000.mmc Start
    [    1.688875] sdhci_am654_init 4fb0000.mmc abc
    [    1.693307] sdhci_am654_init 4fb0000.mmc 111
    [    1.697739] sdhci_am654_init 4fb0000.mmc 222
    [    1.702169] sdhci_am654_init 4fb0000.mmc 333
    [    1.706600] sdhci_am654_init 4fb0000.mmc 444
    [    1.711182] sdhci_am654_init 4fb0000.mmc 555
    [    1.715621] mmc0: CQHCI version 5.10
    [    1.719185] sdhci_am654_init 4fb0000.mmc 666
    [    1.723625] sdhci_am654_init 4fb0000.mmc 777
    [    2.656209] mmc0: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    2.663692] sdhci_am654_init 4fb0000.mmc 888
    [    2.668158] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 88
    [    2.673551] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 99
    [    2.679256] Waiting for root device PARTUUID=6623acc4-02...
    [    2.734436] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
    [    2.741310] mmcblk0: mmc0:aaaa SA16G 14.8 GiB
    [    2.748283]  mmcblk0: p1 p2
    [    2.776662] EXT4-fs (mmcblk0p2): recovery complete
    [    2.782300] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    2.790419] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    2.802252] devtmpfs: mounted
    [    2.806124] Freeing unused kernel memory: 1792K
    [    2.810749] Run /sbin/init as init process
    [    3.011700] systemd[1]: System time before build time, advancing clock.
    [    3.066098] NET: Registered protocol family 10
    [    3.071018] Segment Routing with IPv6
    [    3.098716] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    3.120441] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [    3.158370] systemd[1]: Set hostname to <j7-evm>.
    [    3.354198] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
    [    3.426415] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.433169] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    3.445494] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    3.455438] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    3.477408] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.484740] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    3.505399] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.512582] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    3.533528] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    3.557445] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    3.581439] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    3.597388] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    3.617379] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    3.633390] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    3.655474] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    3.677425] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    3.700583] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    3.721535] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    3.753594] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    3.761947] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    3.785621] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    3.806508] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    3.829620] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    3.849509] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    3.871658] systemd[1]: Mounting Huge Pages File System...
    [    3.891603] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.915559] systemd[1]: Mounting Kernel Debug File System...
    [    3.936681] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    3.955745] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st…odes for the current kernel...
    [    3.983515] systemd[1]: Starting Start psplash boot splash screen...
    [    4.008499] systemd[1]: Starting RPC Bind...
    [    4.021568] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    4.033464] systemd[1]: Starting Journal Service...
    [    4.062181] systemd[1]: Starting Load Kernel Modules...
    [    4.077605] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.092032] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    4.098251] cryptodev: loading out-of-tree module taints kernel.
    [    4.099980] systemd[1]: Starting udev Coldplug all Devices...
             Starting udev Coldplug all Devices...[    4.111246] cryptodev: driver 1.10 loaded.
    [    4.132197] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    4.149780] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta… nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    4.375419] systemd-journald[154]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [    4.509822] urandom_read_iter: 47 callbacks suppressed
    [    4.509825] random: systemd: uninitialized urandom read (16 bytes read)
    [  OK  ] Reached target Local File Systems (Pre).
    [    4.537468] random: systemd: uninitialized urandom read (16 bytes read)
             Mounting /media/ram...
    [    4.548248] random: systemd-journal: uninitialized urandom read (16 bytes read)
             Mounting /var/volatile...
             Starting udev Wait for Complete Device Initialization...
             Starting udev Kernel Device Manager...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started Create Volatile Files and Directories.
    [  OK  ] Started udev Kernel Device Manager.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [    5.018423] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [    5.098583] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [    5.121655] img_dec 4300000.video-decoder: decoder registered as /dev/video0
    [    5.253038] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
    [    5.253285] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power domains
    [    5.273448] img_enc 4200000.video-encoder: encoder registered as /dev/video1
    [    5.286281] PVR_K:  189: Read BVNC 22.104.208.318 from HW device registers
    [    5.333462] remoteproc remoteproc0: 4d80800000.dsp is available
    [    5.353960] PVR_K:  189: RGX Device registered with BVNC 22.104.208.318
    [    5.387165] remoteproc remoteproc0: attaching to 4d80800000.dsp
    [    5.449266] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
    [    5.505678] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
    [    5.617813]  remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [    5.664516] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    5.731739] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    5.737273] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [    5.773113] platform 41000000.r5f: configured R5F for IPC-only mode
    [    5.789892]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    5.830585] urandom_read_iter: 21 callbacks suppressed
    [    5.830589] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.845579] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.845617] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    5.856233] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.900558] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
    [    5.943997] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [    5.948093] remoteproc remoteproc1: 41000000.r5f is available
    [    5.959610] remoteproc remoteproc1: attaching to 41000000.r5f
    [    5.966283] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    5.973617]  remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    5.984930] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    5.991693]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    5.998625] remoteproc remoteproc1: remote processor 41000000.r5f is now attached
    [    6.001971] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    6.016771] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
    [    6.023776] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    6.056036] platform 5c00000.r5f: configured R5F for IPC-only mode
    [    6.145712] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    6.173631] remoteproc remoteproc2: 4d81800000.dsp is available
    [    6.202636] remoteproc remoteproc2: attaching to 4d81800000.dsp
    [    6.234060] remoteproc remoteproc3: 5c00000.r5f is available
    [    6.266910] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
    [    6.306361] remoteproc remoteproc3: attaching to 5c00000.r5f
    [    6.359923]  remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [    6.406193] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [    6.449355] random: crng init done
    [    6.452751] random: 16 urandom warning(s) missed due to ratelimiting
    [  OK  ] Started Load/Save Random Seed.
    [    6.481376]  remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    6.491527] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    6.497114] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [    6.516940]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [    6.529874] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    6.545030] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
    [    6.553060] remoteproc remoteproc2: remote processor 4d81800000.dsp is now attached
    [    6.567132]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [    6.589287] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
    [    6.602361] remoteproc remoteproc3: remote processor 5c00000.r5f is now attached
    [    6.648333] platform 5d00000.r5f: configured R5F for IPC-only mode
    [    6.674610] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [    6.687223] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [    6.705840] remoteproc remoteproc5: 5d00000.r5f is available
    [    6.713876] remoteproc remoteproc5: attaching to 5d00000.r5f
    [    6.721473] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [    6.730594]  remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [    6.733125] remoteproc remoteproc4: 64800000.dsp is available
    [    6.741510] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    6.756690] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [    6.816198]  remoteproc5#vdev0buffer: registered virtio4 (type 7)
    [    6.888588] remoteproc remoteproc5: remote processor 5d00000.r5f is now attached
    [    6.904413] remoteproc remoteproc4: attaching to 64800000.dsp
    [    6.961585] remoteproc remoteproc4: unsupported resource 65538
    [    6.981447] k3_r5_rproc bus@100000:r5fss@5e00000: MCU cluster requires both R5F cores to be enabled, num_cores = 0
    [    7.020082] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [    7.028895]  remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
    [    7.041798] virtio_rpmsg_bus virtio5: rpmsg host is online
    [    7.047414] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [    7.055150] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
    [    7.063364]  remoteproc4#vdev0buffer: registered virtio5 (type 7)
    [    7.069701] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
    [    7.077395] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
    [    7.084695] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
    [    7.092379] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
    [    7.099705] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
    [    7.106089] remoteproc remoteproc4: remote processor 64800000.dsp is now attached
    [    7.107367] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
    [    7.123269] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
    [    7.131215] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
    [    7.141000] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [  OK  ] Found device /dev/mmcblk1p2.
             Starting File System Check on /dev/mmcblk1p2...
    [  OK  ] Started File System Check on /dev/mmcblk1p2.
             Mounting /run/media/mmcblk1p2...
    [    8.006094] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Mounted /run/media/mmcblk1p2.
    [  OK  ] Found device /dev/mmcblk0p1.
             Starting File System Check on /dev/mmcblk0p1...
    [  OK  ] Found device /dev/mmcblk1p8.
             Starting File System Check on /dev/mmcblk1p8...
    [  OK  ] Found device /dev/mmcblk1p6.
             Starting File System Check on /dev/mmcblk1p6...
    [  OK  ] Found device /dev/mmcblk1p1.
             Starting File System Check on /dev/mmcblk1p1...
    [  OK  ] Found device /dev/mmcblk1p3.
             Starting File System Check on /dev/mmcblk1p3...
    [  OK  ] Started File System Check on /dev/mmcblk1p6.
             Mounting /run/media/mmcblk1p6...
    [  OK  ] Started File System Check on /dev/mmcblk1p1.
             Mounting /run/media/mmcblk1p1...
    [    8.351055] EXT4-fs (mmcblk1p6): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Mounted /run/media/mmcblk1p6.
    [  OK  ] Mounted /run/media/mmcblk1p1.
    [  OK  ] Started File System Check on /dev/mmcblk0p1.
             Mounting /run/media/mmcblk0p1...
    [  OK  ] Found device /dev/mmcblk1p5.
             Starting File System Check on /dev/mmcblk1p5...
    [  OK  ] Mounted /run/media/mmcblk0p1.
    [  OK  ] Started File System Check on /dev/mmcblk1p3.
             Mounting /run/media/mmcblk1p3...
    [  OK  ] Started File System Check on /dev/mmcblk1p8.
             Mounting /run/media/mmcblk1p8...
    [    8.558216] EXT4-fs (mmcblk1p3): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Started File System Check on /dev/mmcblk1p5.
    [  OK  ] Mounted /run/media/mmcblk1p3.
    [  OK  ] Mounted /run/media/mmcblk1p8.
             Mounting /run/media/mmcblk1p5...
    [    8.670109] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [    8.708805] EXT4-fs (mmcblk1p5): mounted filesystem with ordered data mode. Opts: (null)
    [    8.721541] ext4 filesystem being mounted at /run/media/mmcblk1p5 supports timestamps until 2038 (0x7fffffff)
    [  OK  ] Mounted /run/media/mmcblk1p5.
    [    8.743296] usbcore: registered new interface driver usbfs
    [    8.810928] usbcore: registered new interface driver hub
    [  OK  ] Found device /dev/mmcblk1p7.[    8.825224] usbcore: registered new device driver usb
             Starting File System Check on /dev/mmcblk1p7...
    [  OK  ] Started File System Check on /dev/mmcblk1p7.
             Mounting /run/media/mmcblk1p7...
    [    8.970102] EXT4-fs (mmcblk1p7): mounted filesystem with ordered data mode. Opts: (null)
    [    8.980955] ext4 filesystem being mounted at /run/media/mmcblk1p7 supports timestamps until 2038 (0x7fffffff)
    [  OK  ] Mounted /run/media/mmcblk1p7.
    [  OK  ] Started udev Wait for Complete Device Initialization.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Print notice about GPLv3 packages...
             Starting set host name as per compatible name...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting Update pmic regis…fety feature on power rails...
             Starting rc.pvr.service...
             Starting startwlanap...
             Starting startwlansta...
             Starting Login Service...
    [  OK  ] Started TEE Supplicant.
             Starting Update weston ini… based on the platform name...
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Started startwlansta.
    [  OK  ] Reached target Network (Pre).
             Starting NetwE/TC:1 0 std_entry_with_parg:234 Bad arg address 0x8adc0c000
    ork Service...
    [  OK  ] Started Update pmic regist…safety feature on power rails.
    [  OK  ] Started Update weston ini …ge based on the platform name.
    [  OK  ] Started set host name as per compatible name.
    [  OK  ] Started Telephony service.
    [  OK  ] Started startwlanap.
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...[    9.602558] start set bcm89811 reg...
    [    9.618307] Bluetooth: Core ver 2.22
    [    9.624788] NET: Registered protocol family 31
    [    9.633225] Bluetooth: HCI device and connection manager initialized
    [    9.645536] Bluetooth: HCI socket layer initialized
    [    9.654913] Bluetooth: L2CAP socket layer initialized
    [    9.664681] Bluetooth: SCO socket layer initialized
    [    9.680943] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [Generic PHY] (irq=POLL)
    [    9.713417] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
    [  OK  ] Started Login Service.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Started Serial Getty on ttyS3.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started rc.pvr.service.
             Starting weston.service...
    [  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
    NOTICE: This file system contains the following GPLv3 packages:
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gstreamer1.0-libav-dev
            gstreamer1.0-libav
            gzip
            less
            libasm1
            libbfd
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libreadline-dev
            libreadline8
            libunistring-dev
            libunistring2
            m4-dev
            m4
            make
            nettle-dev
            nettle
            parted
            python3-rfc3987
            python3-strict-rfc3339
            tar
            which
            zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
    [  OK  ] Started weston.service.
             Starting DEMO...
             Starting telnetd.service...
    [  OK  ] Started DEMO.
    [  OK  ] Started telnetd.service.
    [   13.323631] PVR_K:  1365: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
    [   13.346198] PVR_K:  1365: Shader binary image 'rgx.sh.22.104.208.318' loaded
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project j7-evm ttyS2
    Arago 2021.09 j7-evm ttyS2
    j7-evm login:
    Below is the running log of SPL on SR1.0.
    I/TC:
    SoC:   J721E SR1.0 GP
    DRAM:  4 GiB
    Flash: 0 Bytes
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    443 bytes read in 9 ms (47.9 KiB/s)
    Running uenvcmd ...
    Already setup.
    1473300 bytes read in 73 ms (19.2 MiB/s)
    18455040 bytes read in 770 ms (22.9 MiB/s)
    Starting kernel ...
    [    0.023639] pid_max: default: 32768 minimum: 301
    [    0.040733] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.049527] rcu: Hierarchical SRCU implementation.
    [    0.054578] Platform MSI: msi-controller@1820000 domain created
    [    0.060847] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070148] EFI services will not be available.
    [    0.074883] smp: Bringing up secondary CPUs ...
    [    0.088157] Detected PIPT I-cache on CPU1
    [    0.088180] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.088190] GICv3: CPU1: using allocated LPI pending table @0x00000008a7050000
    [    0.088224] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.088274] smp: Brought up 1 node, 2 CPUs
    [    0.117617] SMP: Total of 2 processors activated.
    [    0.122422] CPU features: detected: 32-bit EL0 Support
    [    0.127676] CPU features: detected: CRC32 instructions
    [    0.141701] CPU: All CPU(s) started at EL2
    [    0.145898] alternatives: patching kernel code
    [    0.150928] devtmpfs: initialized
    [    0.160048] KASLR disabled due to lack of seed
    [    0.164691] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.174655] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.186665] pinctrl core: initialized pinctrl subsystem
    [    0.192324] DMI not present or invalid.
    [    0.196572] NET: Registered protocol family 16
    [    0.201796] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.209116] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.217182] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.225480] thermal_sys: Registered thermal governor 'step_wise'
    [    0.225482] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.232073] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.245709] ASID allocator initialised with 65536 entries
    [    0.262046] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.268902] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.275748] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.282594] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.290058] cryptd: max_cpu_qlen set to 1000
    [    0.296057] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.0 JTAGID[0x0bb6402f] Detected
    [    0.304821] vsys_3v3: supplied by evm_12v0
    [    0.309175] vsys_5v0: supplied by evm_12v0
    [    0.313480] vdd_mmc1: supplied by vsys_3v3
    [    0.318079] iommu: Default domain type: Translated
    [    0.323199] SCSI subsystem initialized
    [    0.327177] mc: Linux media interface: v0.10
    [    0.331549] videodev: Linux video capture interface: v2.00
    [    0.337181] pps_core: LinuxPPS API ver. 1 registered
    [    0.342250] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.351590] PTP clock support registered
    [    0.355608] EDAC MC: Ver: 3.0.0
    [    0.359334] FPGA manager framework
    [    0.362840] Advanced Linux Sound Architecture Driver Initialized.
    [    0.369450] clocksource: Switched to clocksource arch_sys_counter
    [    0.375791] VFS: Disk quotas dquot_6.6.0
    [    0.379824] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.389428] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
    [    0.395721] NET: Registered protocol family 2
    [    0.400467] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.409051] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.417804] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.426005] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
    [    0.433812] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.440610] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.447504] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.454911] NET: Registered protocol family 1
    [    0.459628] RPC: Registered named UNIX socket transport module.
    [    0.465684] RPC: Registered udp transport module.
    [    0.470498] RPC: Registered tcp transport module.
    [    0.475301] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.481885] PCI: CLS 0 bytes, default 64
    [    0.486272] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.496519] Initialise system trusted keyrings
    [    0.501139] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.509309] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.515513] NFS: Registering the id_resolver key type
    [    0.520743] Key type id_resolver registered
    [    0.525016] Key type id_legacy registered
    [    0.529136] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.535985] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.543626] 9p: Installing v9fs 9p2000 file system support
    [    0.568792] Key type asymmetric registered
    [    0.572978] Asymmetric key parser 'x509' registered
    [    0.577977] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.585536] io scheduler mq-deadline registered
    [    0.590161] io scheduler kyber registered
    [    0.595413] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.601596] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.609602] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.615859] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.623590] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.631480] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.639743] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.646832] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.655413] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.667709] brd: module loaded
    [    0.674212] loop: module loaded
    [    0.677972] megasas: 07.714.04.00-rc1
    [    0.683217] tun: Universal TUN/TAP device driver, 1.6
    [    0.688601] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.695007] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.701078] sky2: driver version 1.30
    [    0.705284] VFIO - User Level meta-driver version: 0.3
    [    0.710965] i2c /dev entries driver
    [    0.715079] sdhci: Secure Digital Host Controller Interface driver
    [    0.721396] sdhci: Copyright(c) Pierre Ossman
    [    0.726057] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.732242] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.738527] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.745668] optee: probing for conduit method.
    [    0.750223] optee: revision 3.17 (15a746d2)
    [    0.750364] optee: dynamic shared memory is enabled
    E/TC:1 0 std_entry_with_parg:234 Bad arg address 0x8a856b000
    [    0.765166] optee: initialized driver
    [    0.769816] NET: Registered protocol family 17
    [    0.774431] 9pnet: Installing 9P2000 support
    [    0.778831] Key type dns_resolver registered
    [    0.783289] Loading compiled-in X.509 certificates
    [    0.791721] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.798061] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.805701] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
    [    0.849217] omap_i2c 2010000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.855341] omap_i2c 2030000.i2c: bus 1 rev0.12 at 400 kHz
    [    0.861777] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    0.871759] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    0.880574] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    0.890441] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    0.899973] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    0.909850] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    0.916610] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    0.925619] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    0.935763] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    0.942522] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    0.950464] printk: console [ttyS2] disabled
    [    0.954858] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 21, base_baud = 3000000) is a 8250
    [    0.963602] printk: console [ttyS2] enabled
    [    0.972038] printk: bootconsole [ns16550a0] disabled
    [    0.983839] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.029457] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.037793] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver unknown
    [    1.045828] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.059802] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    1.182165] sdhci-am654 4f80000.mmc: sdhci_am654_probe Start
    [    1.187823] sdhci-am654 4f80000.mmc: sdhci_am654_probe 11
    [    1.206470] sdhci-am654 4fb0000.mmc: sdhci_am654_probe Start
    [    1.212129] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 11
    [    1.217585] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 22
    [    1.222982] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 33
    [    1.228411] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 44
    [    1.228434] sdhci-am654 4f80000.mmc: sdhci_am654_probe 22
    [    1.233813] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 55
    [    1.239215] sdhci-am654 4f80000.mmc: sdhci_am654_probe 33
    [    1.244599] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 66
    [    1.249996] sdhci-am654 4f80000.mmc: sdhci_am654_probe 44
    [    1.260746] sdhci-am654 4f80000.mmc: sdhci_am654_probe 55
    [    1.266201] sdhci-am654 4f80000.mmc: sdhci_am654_probe 66
    [    1.266222] sdhci-am654 4fb0000.mmc: sdhci_am654_probe 77
    [    1.276976] sdhci_am654_init 4fb0000.mmc Start
    [    1.281594] sdhci_am654_init 4fb0000.mmc abc
    [    1.286033] sdhci_am654_init 4fb0000.mmc 111
    [    1.290470] sdhci_am654_init 4fb0000.mmc 222
    [    1.294909] sdhci_am654_init 4fb0000.mmc 333
    [    1.294912] sdhci-am654 4f80000.mmc: sdhci_am654_probe 77
    [    1.299361] sdhci_am654_init 4fb0000.mmc 444
    [    1.304755] sdhci_am654_init 4f80000.mmc Start
    I found this line of code in this function, SR1.0 hangs after running this line of code.
    This is  a GP device.
    Quanfeng
  • My fault, SDK8.4 can boot successfully on other SR1.0 boards, this issue isn't  related to Silicon version.
    So is this a particular sample issue? Can we close this issue?
    - Keerthy
