TMS320F240PQ Programming
Hello everyone,
Two years ago a question was asked regarding prorgamming a TMS320F240PQ chip using an XDS510-USB 2.0 prgorammer in this thread: (Thread).
The answer was send by  (Hareesh Janakiraman) in a personal message.
I have a similar question where I am trying to program this chip using a XDS510 USB programmer: Programmer link. Is it possible to use the same solution using this programmer?
If it is not it is no issue to purchase the programmer that is used in the previous thread. This appears to be a chinese emulator: (Other programmer link).
For both options, would it be possible for someone to send me the solution that is mentioned by mr Janakiraman on the other thread?
Any other method of programming this chip would also be very much appreciated.
Thank you in advance
  • Sybren,
             Assuming you have a working board that you are able to communicate with using CCSv3.3, you could either use the DOS command line utility Prg2xx.exe or SDFlash. I will send you a friendship request. Please accept it, which will enable me to send you the utility privately.
