Part Number: CCSTUDIO
Hi Experts,
Our customer has a concern as shown:
He has some troubles with CCS. He gets message "forbidden" when he try to open Resource Explorer. He can open Resource Explorer in his Internet browser. He set "Native" mode in Network Connections in CCS. He has cleared the directories listed in the troubleshooting guide, and restarted CCS several times.
Additional Information. Also, he saw such messages: "Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/Updates/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started" in updating log.
I have initially have referred him to this links below to see if this are helpful:
- CCS: Code Composer Studio
forum - Code Composer Studio forum
- CCS: CCS v8 Cannot read Code Generation Tools Repository
But then, I received feedback as shown below:
"Thank you for your answer on my assistance request!
I have tried all what you wrote:
1. I have deleted workspace folder
2. I have suppressed work of windows firewall
3. I have tried use "Help->Install New Software", but get "Unable to
read repository at
software-dl.ti.com/.../content.xml.
Unable to read repository at
find valid certification path to requested target"
But the problem is still with me, I still can see "403 Forbidden" when
press "Resource Explorer" or "Browse and Import Examples" at the
"Getting Started Page". In error log i can see "REX Setting browser URL
to: ">dev.ti.com/tirex4-desktop" in Message field and "An exception
stack trace is not available." in Exception Stack Trace.
May be I can try something else?
Our system admin doesn't find reason of message "403 Forbidden". Could
you say, where can we find any additional information about what CCS
doesn't like? May be there are any logs which we should look?
Problem of "unable to find valid certification path to requested target"
solved by changing settings. But I still cann't open resource browser
inside CCS (in external internet browser it opens without any problems).
Additional information.
Part of eclipse log (several attempts to open "Resource Explorer" and
"Browse and Import Examples"):
ENTRY com.ti.ccstudio.ui 1 0 2023-04-04 16:01:07.051
!MESSAGE CCS IDE session started!
CCS build: 12.1.0.00007
CCS location: C:/ti/ccs1210/ccs
Workspace location: D:/Projects/CodeCompWS
!ENTRY org.eclipse.e4.ui.workbench 1 0 2023-04-04 16:01:11.929
!MESSAGE REX Setting browser URL to: dev.ti.com/tirex4-desktop
!ENTRY org.eclipse.e4.ui.workbench 1 0 2023-04-04 16:01:22.997
!ENTRY org.eclipse.e4.ui.workbench 1 0 2023-04-04 16:01:26.014
!ENTRY org.eclipse.e4.ui.workbench 1 0 2023-04-04 16:01:31.073
!MESSAGE REX Setting browser URL to: dev.ti.com/.../wizard
!ENTRY org.eclipse.e4.ui.workbench 1 0 2023-04-04 16:01:33.567
!ENTRY org.eclipse.e4.ui.workbench 1 0 2023-04-04 16:01:35.858
Unfortunately I have many new troubles with CCS. I am didn't how i done
it, but now i receive Crash report Job in status bar. I have reinstall
CCS, but Crashreport Job still with me. After that I have erased all
records containing ccs or simlelink or eclipse in windows registry,
after that I have installed CCS in another folder (and another disk
also), but Crash report Job is still with me. Now I try to understand
reasons of these troubles.
Because of it I still not create request in E2E forum.
Maybe you could answer what the message "An internal error occurred
during: "Replace IU job" means?
Exception Stack Trace:
java.lang.NullPointerException
at
com.ti.ccstudio.app.center.internal.CCSAppCenter.log(CCSAppCenter.java:446)
at
com.ti.ccstudio.app.center.internal.CCSAppCenter._replaceIusWithLatest(CCSAppCenter.java:414)
at
com.ti.ccstudio.app.center.internal.CCSAppCenter.access$3(CCSAppCenter.java:358)
at
com.ti.ccstudio.app.center.internal.CCSAppCenter$2.run(CCSAppCenter.java:234)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
We hope to received your advice on this. Thank you so much in advance.
Gerald
