Hi all, Now I have a questions.
I want to set GPIO0_118 as a interrupt input pin on mcu2_0, The pinmux has been finished. But when set the interrupt func, it returns -1;
I trace the code, and find that in function "GPIO_socConfigIntrPath()" which located in "pdk/packages/ti/drv/gpio/soc/j721e/GPIO_soc.c", something is wrong.
through the GPIO_socGetIrqRange(ir_id, dst_id, &irq_range_start, &irq_range_num); the irq_range_num = 4;
and my gpiopin is gpio0_118, means the banknum=7,so it return error;
the code is as below
int32_t GPIO_socConfigIntrPath(uint32_t portNum, uint32_t pinNum,void *hwAttrs,bool setIntrPath) { GPIO_v0_HwAttrs *cfg = (GPIO_v0_HwAttrs *)hwAttrs; GPIO_IntCfg *intCfg; ... if(CSL_PASS == retVal) { /* Get the valid range of valid interrupts based on the ir_id. */ retVal = GPIO_socGetIrqRange(ir_id, dst_id, &irq_range_start, &irq_range_num); } ... if(CSL_PASS == retVal) { if(bankNum <= irq_range_num) { dst_host_irq = irq_range_start + bankNum; #if defined (BUILD_C7X) intCfg[pinNum].eventId = dst_host_irq; /* CLEC i/p Event Idx - Use Range from BoardCfg */ intCfg[pinNum].intNum += bankNum; /* CLEC o/p to C7x core */ #elif defined (BUILD_C66X) /* On C66x, we use Event Combiner to map the interrupt to the CPU Intc. To * do this, OSAL expects that event number holds the interrupt number and we * use the macro for interrupt number to specify we wish to use Event * Combiner. */ intCfg[pinNum].eventId = dst_host_irq; /* The interrupt number is initialized with the required Offset */ intCfg[pinNum].intNum = OSAL_REGINT_INTVEC_EVENT_COMBINER; /* OSAL expects the Combiner macro at the interrupt number */ #else intCfg[pinNum].intNum = dst_host_irq; /* Core Interrupt Idx - Use Range from BoardCfg */ #endif } else { retVal = CSL_EFAIL; } } ... return(retVal); }
I want to know:
1. where define the irq_range_num to be 4; and why?
2. How can I get a irq_num for GPIO0_118, and How can I config the Interrupt router?
