error in make ipnc: ld returned 1 exit status
Dear all:
I used Davinci DM368IPNC-IMX036-A175(TMS320DM368)   dvsdk_2_10_01_18 and linux-2.6.18_pro500
I have already modified Makefile and Rule.make. ex : MVTOOL_PREFIX , CSTOOL_PREFIX , ..........
But when I make the ipnc .  I encounter serveral errors as below:
Making all in subdirectory update...
make[5]: Entering directory `/home/dvdev/Workdir/IPNetCam/ipnc_app/utils/update'
make[5]: Nothing to be done for `all'.
make[5]: Leaving directory `/home/dvdev/Workdir/IPNetCam/ipnc_app/utils/update'
make[4]: Leaving directory `/home/dvdev/Workdir/IPNetCam/ipnc_app/utils'
make[3]: Leaving directory `/home/dvdev/Workdir/IPNetCam/ipnc_app'
make[2]: Leaving directory `/home/dvdev/Workdir/IPNetCam/ipnc/av_capture/application/ipnc'
make[1]: Leaving directory `/home/dvdev/Workdir/IPNetCam/ipnc'
make -fMAKEFILE.MK -C/home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/../application/test exe
make[1]: Entering directory `/home/dvdev/Workdir/IPNetCam/ipnc/av_capture/application/test'
make -fMAKEFILE.MK -C./moduletest MODULE=moduletest exe
make[2]: Entering directory `/home/dvdev/Workdir/IPNetCam/ipnc/av_capture/application/test/moduletest'
moduletest: Linking to .out
/opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -lpthread -lpng -fPIC -lasound -o/home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/../bin//moduletest.out /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/lib//moduletest.a /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/lib//alg.a /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/lib//drv.a /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/lib//alg.a /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/lib//image_tune.a /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/lib//osa.a /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/lib//csl.a /home/dvdev/Workdir/IPNetCam/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti/sdo/linuxutils/cmem/lib/cmem.a470MV /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/../framework/alg/lib/alg_facetrack_ti.a /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/../framework/alg/lib/alg_saldre_ti.a /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/../framework/alg/src/alg_config/linker.cmd  /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/../framework/alg/lib/alg_vstab_ti.a /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/../framework/alg/lib/alg_osd_ti.a /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/../framework/alg/src/aewb_ti/lib/alg_awb_ti.a  /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/../framework/alg/src/aewb_ti/lib/alg_flicker_detect_ti.a /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/../framework/alg/src/aewb_ap/lib/Appro_2a_lib.a /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/../framework/alg/src/aewb_ap/lib/Appro_aew_control.a /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/../framework/alg/lib/fr_ti/alg_fr_ti.a /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/../framework/alg/lib/fr_ti/libeOkaoFr.a /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/../framework/alg/lib/fr_ti/libeOkaoPt.a /home/dvdev/Workdir/IPNetCam/ipnc/av_capture/build/../framework/alg/lib/fr_ti/libeOkaoCo.a /home/dvdev/Workdir/IPNetCam/dvsdk_2_10_01_18/dm365mm/lib/libdm365mm.a
/opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/../lib/gcc/armv5tl-montavista-linux-gnueabi/4.2.0/../../../../armv5tl-montavista-linux-gnueabi/bin/ld: cannot find /home/dvdev/Workdir/IPNetCam/dvsdk_2_10_01_18/framework_components_2_24/packages/ti/sdo/fc/ires/edma3chan/lib/release/edma3Chan.a470MV
collect2: ld returned 1 exit status
make[2]: *** [exe] Error 1
make[2]: Leaving directory `/home/dvdev/Workdir/IPNetCam/ipnc/av_capture/application/test/moduletest'
make[1]: *** [exe] Error 2
make[1]: Leaving directory `/home/dvdev/Workdir/IPNetCam/ipnc/av_capture/application/test'
make: *** [exe] Error 2
 Besides there is something wrong with my dvsdk_2_10_01_18, I've pointed in:
http://e2e.ti.com/support/embedded/f/354/t/121995.aspx
Dose anyone know what's wrong ??
please tell me.
thanks for your visit
 any help would be great!
Best regards
