Part Number: AM625
Hi Team,
Inquiry from customer:
We use an am62x with a LPDDR4 memory and have an issue with memory access.
This is what happens (we think). Let’s say you have process that heavily loads the LPDDR4 memory running on one A53 core. At the same time a graphic process on another core heavily trying to read/write to the LPDDR4 memory. 2 processes from different cores want to access the LPDDR4 memory at the same time. In this case we think that both cores have the same priority to the memory.
What we want is to set some kind of memory access prioritization letting our main process on one core always have higher access than for example GPU, other cores and peripherals to the LPDDR4 memory. The reason for this is that on one A53 core we run a real time application process. It is very important that this process not get blocked/starved from access the LPDDR4 memory which we think it is by the GPU when it is rendering(drawing) on the screen.
Is it possible to priorities memory access in this way?
We understand that there is a tool called Resource Partitioning Tool based on SysConfig tool.
Is this something we can use to achieve what we want?"
BR,
-RT
